Winapp2.ini additions
Winapp2.ini
Revised Entry
Changed name from [NetworkService Temps*] to [NetworkService Temporary Files*] same like [LocalService Temporary Files*] and [systemprofile Temporary Files*].
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows
Default=False
FileKey1=%SystemDrive%\Documents and Settings\NetworkService\Local Settings\Temp|*.*|RECURSE
FileKey2=%SystemDrive%\Documents and Settings\NetworkService.NT*\Local Settings\Temp|*.*|RECURSE
FileKey3=%WinDir%\ServiceProfiles\NetworkService\AppData\Local\Temp|*.*|RECURSE
Well if you want to view it as a match for other names, I think a more proper name would be Temp, since the folders they clean are called Temp.
I am a maintainer for Winapp2. I also have a open-source group on Steam.
http://steamcommunity.com/groups/opencommunity
Link to comment
  • Moderators
Do we really need the entries listed below. I cannot find those locations on Window 7, 8, 8.1 and 10. I checked a few other known privacy eraser programs and they don't have cleaning rules for the locations listed below.
[LocalService Cookies*]
LangSecRef=3022
Default=False
FileKey1=%SystemDrive%\Documents and Settings\LocalService\Cookies|*.*|RECURSE
FileKey2=%SystemDrive%\Documents and Settings\LocalService.NT*\Cookies|*.*|RECURSE
FileKey3=%WinDir%\ServiceProfiles\LocalService\AppData\Local\Temp\Cookies|*.*|REMOVESELF
FileKey4=%WinDir%\ServiceProfiles\LocalService\AppData\Roaming\Microsoft\Windows\Cookies|*.*|REMOVESELF
[LocalService History*]
LangSecRef=3022
Default=False
FileKey1=%SystemDrive%\Documents and Settings\LocalService\Local Settings\History|*.*|RECURSE
FileKey2=%SystemDrive%\Documents and Settings\LocalService.NT*\Local Settings\History|*.*|RECURSE
FileKey3=%WinDir%\ServiceProfiles\LocalService\AppData\Local\Microsoft\Windows\History|*.*|RECURSE
[LocalService Temporary Internet Files*]
LangSecRef=3022
Default=False
FileKey1=%SystemDrive%\Documents and Settings\LocalService\Local Settings\Temporary Internet Files|*.*|RECURSE
FileKey2=%SystemDrive%\Documents and Settings\LocalService.NT*\Local Settings\Temporary Internet Files|*.*|RECURSE
FileKey3=%WinDir%\ServiceProfiles\LocalService\AppData\Local\Microsoft\Windows\Temporary Internet Files|*.*|RECURSE
[NetworkService Cookies*]
LangSecRef=3022
Default=False
FileKey1=%SystemDrive%\Documents and Settings\NetworkService\Cookies|*.*|RECURSE
FileKey2=%SystemDrive%\Documents and Settings\NetworkService.NT*\Cookies|*.*|RECURSE
FileKey3=%WinDir%\ServiceProfiles\NetworkService\AppData\Local\Temp\Cookies|*.*|RECURSE
FileKey4=%WinDir%\ServiceProfiles\NetworkService\AppData\Roaming\Microsoft\Windows\Cookies|*.*|RECURSE
[NetworkService History*]
LangSecRef=3022
Default=False
FileKey1=%SystemDrive%\Documents and Settings\NetworkService\Local Settings\History|*.*|RECURSE
FileKey2=%SystemDrive%\Documents and Settings\NetworkService.NT*\Local Settings\History|*.*|RECURSE
FileKey3=%WinDir%\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Windows\History|*.*|RECURSE
[NetworkService Temporary Internet Files*]
LangSecRef=3022
Default=False
FileKey1=%SystemDrive%\Documents and Settings\NetworkService\Local Settings\Content.IE5|*.*|RECURSE
FileKey2=%SystemDrive%\Documents and Settings\NetworkService\Local Settings\Temporary Internet Files|*.*|RECURSE
FileKey3=%SystemDrive%\Documents and Settings\NetworkService.NT*\Local Settings\Content.IE5|*.*|RECURSE
FileKey4=%SystemDrive%\Documents and Settings\NetworkService.NT*\Local Settings\Temporary Internet Files|*.*|RECURSE
FileKey5=%WinDir%\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Windows\Temporary Internet Files|*.*|RECURSE
FileKey6=%WinDir%\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Windows\Content.IE5|*.*|RECURSE
[systemprofile Cookies*]
LangSecRef=3022
Default=False
FileKey1=%WinDir%\System32\config\SystemProfile\Cookies|*.*|RECURSE
FileKey2=%WinDir%\System32\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies|*.*|RECURSE
FileKey3=%WinDir%\SysWOW64\config\systemprofile\AppData\Roaming\Microsoft\Windows\Cookies|*.*|RECURSE
[systemprofile History*]
LangSecRef=3022
Default=False
FileKey1=%WinDir%\System32\config\SystemProfile\History|*.*|RECURSE
FileKey2=%WinDir%\System32\config\systemprofile\AppData\Local\Microsoft\Windows\History|*.*|RECURSE
FileKey3=%WinDir%\SysWOW64\config\systemprofile\AppData\Roaming\Microsoft\Windows\History|*.*|RECURSE
[systemprofile Temporary Internet Files*]
LangSecRef=3022
Default=False
FileKey1=%WinDir%\System32\config\SystemProfile\Local Settings\Temporary Internet Files|*.*|RECURSE
FileKey2=%WinDir%\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files|*.*|RECURSE
FileKey3=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Microsoft\Windows\Temporary Internet Files|*.*|RECURSE
At a glance, Windows XP has some of them.
And they're needed because program installations can cause Windows to switch from using a user profile location for storage of the junk, or it can change it to the %windir% location.
Edited by Andavari
Link to comment
[steam Packages*]
Section=Games
Detect=HKCU\Software\Valve\Steam
Warning=Running this entry is not recommended if you run Steam Client Beta.
FileKey1=%ProgramFiles%\Steam\package|*.zip.*
ExcludeKey1=FILE|%ProgramFiles%\Steam\package\steam_client_win32.installed
ExcludeKey2=FILE|%ProgramFiles%\Steam\package\steam_client_win32.manifest
ExcludeKey3=FILE|%ProgramFiles%\Steam\package\steam_client_publicbeta_win32.installed
ExcludeKey4=FILE|%ProgramFiles%\Steam\package\steam_client_publicbeta_win32.manifest
Why are there ExcludeKeys for in this entry? The FileKey should not touch those files, anyways.
Link to comment
EDIT:
[starCraft II Editor Recent Files*]
Section=Games
Detect=HKCU\Software\Blizzard Entertainment\StarCraft II Editor
Default=False
RegKey1=HKCU\Software\Blizzard Entertainment\StarCraft II Editor\Recent Files
Removed Detect 2 as it is unneeded.
[starCraft II Map Cache*]
Section=Games
Default=False
FileKey1=%CommonAppData%\Blizzard Entertainment\Starcraft II\Maps\Cache|*.*|RECURSE
FileKey2=%LocalAppData%\VirtualStore\ProgramData\Blizzard Entertainment\Starcraft II\Maps\Cache|*.*|RECURSE
Changed Detect=HKCU\Software\Blizzard Entertainment\StarCraft II Editor to Detect=HKCU\Software\Blizzard Entertainment\StarCraft II
[starCraft II Misc*]
Section=Games
Default=False
Warning=This will delete all of your image uploads, replays, and screenshots.
FileKey1=%Documents%\StarCraft II\ImageUploads|*.*|RECURSE
FileKey2=%Documents%\StarCraft II\Replays|*.*|RECURSE
FileKey3=%Documents%\StarCraft II\Screenshots|*.*|RECURSE
Removed Detect1 as it is unneeded and changed Detect=HKLM\Software\Wow6432Node\Blizzard Entertainment\StarCraft II to Detect=HKCU\Software\Blizzard Entertainment\StarCraft II so it will detect all versions of Starcraft 2.
Link to comment
[battle.net*]
Section=Games
Detect=HKCU\Software\Blizzard Entertainment\Battle.net
Default=False
FileKey1=%CommonAppData%\Battle.net|*.log|RECURSE
FileKey2=%CommonAppData%\Battle.net\Agent\Agent.*\Logs|*.*|RECURSE
FileKey3=%CommonAppData%\Battle.net\Agent\Logs|*.*|RECURSE
FileKey4=%CommonAppData%\Battle.net\Setup\*\Logs|*.*
FileKey5=%CommonAppData%\Battle.net\Telemetry|*.*
FileKey6=%CommonAppData%\Blizzard Entertainment\Battle.net\Cache|*.*|REMOVESELF
FileKey7=%LocalAppData%\Blizzard Entertainment\Battle.net\Cache|*.*|RECURSE
FileKey8=%LocalAppData%\Battle.net\Errors|*.*
FileKey9=%LocalAppData%\Blizzard Entertainment\System Survey|log.txt
FileKey10=%LocalAppData%\VirtualStore\ProgramData\Battle.net|*.log|RECURSE
FileKey11=%LocalAppData%\VirtualStore\ProgramData\Battle.net\Agent\Agent.*\Logs|*.*|RECURSE
FileKey12=%LocalAppData%\VirtualStore\ProgramData\Battle.net\Agent\Logs|*.*|RECURSE
FileKey13=%LocalAppData%\VirtualStore\ProgramData\Blizzard Entertainment\Battle.net\Cache|*.*|REMOVESELF
RegKey1=HKCU\Software\Blizzard Entertainment\Battle.net\Authenticator
About the RegKey1 in this entry, isn't that apart of Battle.net Authenticator that is suppose to help protect your account from hijacks? I don't think we should remove that. https://us.battle.net/support/en/article/battle-net-authenticator-faq
Link to comment
Distributed [Windows System Profile*] into separate entries. So please add these and remove [Windows System Profile*].
LangSecRef=3022
Default=False
LangSecRef=3022
Default=False
LangSecRef=3025
Default=False
FileKey1=%WinDir%\System32\config\SystemProfile\Local Settings\Temp|*.*|RECURSE
FileKey2=%WinDir%\System32\config\systemprofile\AppData\Local\Temp|*.*|RECURSE
FileKey3=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Temp|*.*|RECURSE
LangSecRef=3022
Default=False
Proper names for these entries are [LocalSystem Cookies*], [LocalSystem History*], [LocalSystem Temp Files*] and [LocalSystem Temporary Internet Files*].
Link to comment
Revised Entry
Fixed FileKey1
[WDI Logs*]
LangSecRef=3025
Default=False
FileKey1=%WinDir%\System32\WDI\*|snapshot.etl|REMOVESELF
FileKey2=%WinDir%\System32\WDI\LogFiles\StartupInfo|*.*|RECURSE
Link to comment
I tried adding the exclude rules, but they are not working.
ExcludeKey1=FILE|%LocalAppData%\Packages\Microsoft.Windows.ContentDeliveryManager_*\AC\INetCache|container.dat
ExcludeKey2=FILE|%LocalAppData%\Packages\Microsoft.Windows.ContentDeliveryManager_*\AC\INetHistory\BackgroundTransferApi|container.dat
[Content Delivery Manager*]
DetectOS=10.0|
Section=3031
Default=False
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Windows.ContentDeliveryManager_cw5n1h2txyewy
FileKey1=%LocalAppData%\Packages\Microsoft.Windows.ContentDeliveryManager_*\AC\INetCache|*.*|RECURSE
FileKey2=%LocalAppData%\Packages\Microsoft.Windows.ContentDeliveryManager_*\AC\INetCookies|*.*|RECURSE
FileKey3=%LocalAppData%\Packages\Microsoft.Windows.ContentDeliveryManager_*\AC\INetHistory|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\Microsoft.Windows.ContentDeliveryManager_*\AC\Microsoft\CryptnetUrlCache\Content|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\Microsoft.Windows.ContentDeliveryManager_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.*|RECURSE
FileKey6=%LocalAppData%\Packages\Microsoft.Windows.ContentDeliveryManager_*\AC\Temp|*.*|RECURSE
FileKey7=%LocalAppData%\Packages\Microsoft.Windows.ContentDeliveryManager_*\AC\TokenBroker\Cache|*.*|RECURSE
FileKey8=%LocalAppData%\Packages\Microsoft.Windows.ContentDeliveryManager_*\LocalCache|*.*|RECURSE
FileKey9=%LocalAppData%\Packages\Microsoft.Windows.ContentDeliveryManager_*\LocalState\Cache|*.*|RECURSE
FileKey10=%LocalAppData%\Packages\Microsoft.Windows.ContentDeliveryManager_*\TempState|*.*|RECURSE
Link to comment
You just forgot to add a backslash at the end of the path:
ExcludeKey1=FILE|%LocalAppData%\Packages\Microsoft.Windows.ContentDeliveryManager_*\AC\INetCache\|container.dat
ExcludeKey2=FILE|%LocalAppData%\Packages\Microsoft.Windows.ContentDeliveryManager_*\AC\INetHistory\BackgroundTransferApi\|container.dat
Alternative:
ExcludeKey1=FILE|%LocalAppData%\Packages\Microsoft.Windows.ContentDeliveryManager_*\AC\INetCache\container.dat
ExcludeKey2=FILE|%LocalAppData%\Packages\Microsoft.Windows.ContentDeliveryManager_*\AC\INetHistory\BackgroundTransferApi\container.dat
#4274
Link to comment
Revised Entry
Removed RegKey8=HKU\S-1-5-18\Software\Microsoft\Windows\Windows Error Reporting\Debug|StoreLocation. FileKey7 cleans this location also.
[Windows Error Reporting More*]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows\Windows Error Reporting
Default=False
FileKey1=%WinDir%\System32\config\systemprofile\AppData\Local\CrashDumps|*.dmp
FileKey2=%WinDir%\System32\config\systemprofile\Local Settings\Application Data\CrashDumps|*.dmp
FileKey3=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\CrashDumps|*.dmp
FileKey4=%WinDir%\SysWOW64\config\systemprofile\Local Settings\Application Data\CrashDumps|*.dmp
RegKey1=HKCU\Software\Microsoft\Windows\Windows Error Reporting\Debug|StoreLocation
RegKey2=HKLM\Software\Microsoft\Windows\Windows Error Reporting\Debug|StoreLocation
RegKey3=HKLM\Software\Microsoft\Windows\Windows Error Reporting\LocalDumps
RegKey4=HKLM\Software\Microsoft\Windows\Windows Error Reporting\FullLiveKernelReports|LastFullLiveReport
RegKey5=HKLM\Software\Microsoft\Windows\Windows Error Reporting\FullLiveKernelReports\win32k.sys
RegKey6=HKLM\Software\Microsoft\Windows\Windows Error Reporting\LiveKernelReports\win32k.sys
RegKey7=HKU\.DEFAULT\Software\Microsoft\Windows\Windows Error Reporting\Debug|StoreLocation
Link to comment
Please change
[NetworkService Temps*] to [NetworkService Temp Files*]
[LocalService Temporary Files*] to [LocalService Temp Files*]
[LocalSystem Temp Internet Files*] t [LocalSystem Temporary Internet Files*]
Link to comment
Revised Entry:  [Movavi Video Converter (Logs)*]
Modified FileKey1:  Changed VideoConverter16 to VideoConverter* for new version 17 of this application.
LangSecRef=3023
Detect=HKCU\Software\MOVAVI
Default=False
FileKey1=%LocalAppData%\Movavi\Logs\VideoConverter*|*.*
Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System);  Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet.  ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system):   Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD21, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more.
Link to comment
  • Moderators
New:
[Alternate File Shredder (Archive Log)*]
LangSecRef=3024
Default=False
Detect=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Alternate File Shredder_is1
FileKey1=%AppData%\Alternate\FileShredder|FileShredderLog_*.txt
New:
[Alternate File Shredder (Enable Log)*]
LangSecRef=3024
Default=False
FileKey1=%AppData%\Alternate\FileShredder|FileShredderLog.txt
Edited by Andavari
Couldn't get [code] to work correctly with Firefox 51.0.1
Link to comment
(More*)=(Enhanced*)
(More*)=(Pro*)
(More*)=(Deeper*)
(More*)=http://www.thesaurus.com/browse/more
Link to comment
Register a new account
Sign in
Important Information
