Moderators Nergal Posted March 1, 2017 Moderators Share Posted March 1, 2017 Detect=HKLM\Software\Florian Heidenreich\Mp3tag because there is NO "HKLM..." Mp3Tag: [Mp3tag Portable on X:*]LangSecRef=3023Default=FalseFileKey1=x:\Portable\Mp3tag|Mp3tagError.logI'd add a detectfile and point it to a file within x:\portable\mp3tag ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Moderators Andavari Posted March 1, 2017 Moderators Share Posted March 1, 2017 Please change: [AccurateRip Cache*] Detect1=HKCU\Software\AWSoftware\EAC to Detect1=HKCU\Software\AWSoftware\EACU There is no EACU key location for the version I use. Instead of changing it just add a Detect2 to detect it on your system so users of previous versions aren't left with a useless non-functional cleaner. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted March 1, 2017 Moderators Share Posted March 1, 2017 Please change: [Mp3tag*] LangSecRef=3024 FileKey1=%AppData%\Mp3tag|Mp3tagError.log to LangSecRef=3023 ( = Multimedia) FileKey1=%AppData%\Mp3tag|Mp3tagError.log;Mp3tagSettings.zip The backup settings ZIP archive file is there for a valid reason and that being the user intentionally clicked in the menu for Mp3tag to create it! It absolutely doesn't need to be removed blindly as it could be a complete pain in the ass to reconfigure from scratch like I have my configuration of it, and I'd be rather upset no make that pissed off if I'd lose my backup copy of the configuration. Link to comment Share on other sites More sharing options...
Makumbo Posted March 1, 2017 Share Posted March 1, 2017 I'd add a detectfile and point it to a file within x:\portable\mp3tag I will do that. Thanks. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted March 1, 2017 Moderators Share Posted March 1, 2017 The backup settings ZIP archive file is there for a valid reason and that being the user intentionally clicked in the menu for Mp3tag to create it! It absolutely doesn't need to be removed blindly as it could be a complete pain in the ass to reconfigure from scratch like I have my configuration of it, and I'd be rather upset no make that pissed off if I'd lose my backup copy of the configuration.I agree ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
ROCKNROLL Posted March 2, 2017 Share Posted March 2, 2017 I fixed the detect for AccurateRip: https://github.com/MoscaDotTo/Winapp2/commit/cf3873c7388c93742c473c0b1f836da528c74424 I am a maintainer for Winapp2. I also have a open-source group on Steam. http://steamcommunity.com/groups/opencommunity Link to comment Share on other sites More sharing options...
siliconman01 Posted March 2, 2017 Share Posted March 2, 2017 So, i use FileKey1=x:\Portable\Mp3tag|Mp3tagError.log and delete the line Detect=HKLM\Software\Florian Heidenreich\Mp3tag because there is NO "HKLM..." Mp3Tag: [Mp3tag Portable on X:*] LangSecRef=3023 Default=False FileKey1=x:\Portable\Mp3tag|Mp3tagError.log The "Detect=HKLM\Software\Florian Heidenreich\Mp3tag" should not be deleted. It is in Detect=HKLM\Software\WOW6432Node... it does exist. This cleaning code works fine on my Windows 10x64 Pro systems with the free version of Mp3tag. [Mp3tag*] LangSecRef=3023 Detect=HKLM\Software\Florian Heidenreich\Mp3tag Default=False FileKey1=%AppData%\Mp3tag|Mp3tagError.log Note that LangSecRef in the code above has been changed from 3024 to 3023 as requested. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
SMalik Posted March 2, 2017 Share Posted March 2, 2017 Please change: [Adobe Reader XI*] to [Adobe Reader 11.0*] (same name as in winapp.ini) The correct name of the program is [Adobe Reader XI*]. I already have requested Piriform to fix it in winapp.ini Link to comment Share on other sites More sharing options...
Makumbo Posted March 2, 2017 Share Posted March 2, 2017 The "Detect=HKLM\Software\Florian Heidenreich\Mp3tag" should not be deleted. It is in Detect=HKLM\Software\WOW6432Node... it does exist. This cleaning code works fine on my Windows 10x64 Pro systems with the free version of Mp3tag. In my Windows 7 64 Bit it does NOT exists. I searched the registry for "Florian" - NOTHING ;( And I think that that is the correct way to "install" a PORTABLE version of a program: No registry; ALL needed Files in the programms directory. And if you don't like it anymore: Just delete that directory... Link to comment Share on other sites More sharing options...
Moderators Nergal Posted March 2, 2017 Moderators Share Posted March 2, 2017 The "Detect=HKLM\Software\Florian Heidenreich\Mp3tag" should not be deleted. It is in Detect=HKLM\Software\WOW6432Node... it does exist. This cleaning code works fine on my Windows 10x64 Pro systems with the free version of Mp3tag.In my Windows 7 64 Bit it does NOT exists.I searched the registry for "Florian" - NOTHING ;( And I think that that is the correct way to "install" a PORTABLE version of a program:No registry; ALL needed Files in the programms directory.And if you don't like it anymore: Just delete that directory...*couple things1 the os sees HKLM\software and Wow6432 as the same thing.2 not all portable is the same, some do leave tracks, stealth programs do not (ccleaner as example), but not all portable versions of apps are as clean ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
ROCKNROLL Posted March 2, 2017 Share Posted March 2, 2017 I just installed mp3tag on my system. It put a registry key in my Wow6432. I assume the other detect is for 32-bit versions, but I didn't see a choice of 32 or 64, so it must just go by whatever your system is. During the installation, it gave me a choice to install portable or standard installation, and I choice standard. The portable version will probably not have a registry entry. I am a maintainer for Winapp2. I also have a open-source group on Steam. http://steamcommunity.com/groups/opencommunity Link to comment Share on other sites More sharing options...
Moderators Andavari Posted March 2, 2017 Moderators Share Posted March 2, 2017 The "Detect=HKLM\Software\Florian Heidenreich\Mp3tag" should not be deleted. Exactly! ------------- Mp3tag Portable is a true 100% portable, it doesn't create any registry settings. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted March 2, 2017 Moderators Share Posted March 2, 2017 (edited) I fixed the detect for AccurateRip: https://github.com/MoscaDotTo/Winapp2/commit/cf3873c7388c93742c473c0b1f836da528c74424 It is wrong! All it needed was a Detect3= for that EACU key the other person posted. The dBpowerAMP detect key needs to remain like the original cleaner had for it. It cleans AccurateRip cache for two completely different CD ripping programs; dBpowerAMP and EAC. -------------------- Here's a correction for AccurateRip Cache including the newly added EACU reference, alphabetized: Updated: [AccurateRip Cache*]LangSecRef=3023 Detect1=HKCU\Software\AWSoftware\EAC Detect2=HKCU\Software\AWSoftware\EACU Detect3=HKCU\Software\Illustrate\dBpowerAMP Default=False FileKey1=%AppData%\AccurateRip\AccurateRipCache|dBAR*.bin This was the original: [AccurateRip Cache*] LangSecRef=3023 Detect1=HKCU\Software\AWSoftware\EAC Detect2=HKCU\Software\Illustrate\dBpowerAMP Default=False FileKey1=%AppData%\AccurateRip\AccurateRipCache|dBAR*.bin Edited March 2, 2017 by Andavari Link to comment Share on other sites More sharing options...
ROCKNROLL Posted March 3, 2017 Share Posted March 3, 2017 It is wrong! All it needed was a Detect3= for that EACU key the other person posted. The dBpowerAMP detect key needs to remain like the original cleaner had for it. It cleans AccurateRip cache for two completely different CD ripping programs; dBpowerAMP and EAC. -------------------- Here's a correction for AccurateRip Cache including the newly added EACU reference, alphabetized: Updated: This was the original: Ah OK. That makes more sense now. Should be correct way now: https://github.com/MoscaDotTo/Winapp2/commit/15d58878157f6d0bd7cca4fb67b67d2ca396f6fa I am a maintainer for Winapp2. I also have a open-source group on Steam. http://steamcommunity.com/groups/opencommunity Link to comment Share on other sites More sharing options...
SMalik Posted March 4, 2017 Share Posted March 4, 2017 New Entry [screenpresso*]LangSecRef=3024DetectFile=%AppData%\Learnpulse\ScreenpressoDefault=FalseFileKey1=%Pictures%\Screenpresso\Thumbnails|*.*|RECURSEFileKey2=%AppData%\Learnpulse\Screenpresso|settings.copy.xml Link to comment Share on other sites More sharing options...
ROCKNROLL Posted March 4, 2017 Share Posted March 4, 2017 Updated: https://github.com/MoscaDotTo/Winapp2/commit/68e491a9dd5eb41679426832065d9ca28542d849 I am a maintainer for Winapp2. I also have a open-source group on Steam. http://steamcommunity.com/groups/opencommunity Link to comment Share on other sites More sharing options...
dvdbane Posted March 5, 2017 Share Posted March 5, 2017 [Revo Uninstaller Pro*] this entry should be remove, somehow survived the purge https://forum.piriform.com/index.php?showtopic=32310&page=183&do=findComment&comment=243084 i think we should combine [ESET NOD32 Antivirus*] and [ESET Smart Security*] use wildcard to support other eset product like eset internet security but i can only confirm for these 3 and FK1 should be remove unless you're enabling HIPS log, no entries can go to MB currenly my HIPS log at 18.3MB with 58k entries [ESET*]LangSecRef=3021Detect=HKLM\Software\ESET\ESET SecurityDefault=FalseWarning=You may need to run this in safe mode. You should also disable the ERA service to properly clean the ERA files.FileKey1=%CommonAppData%\ESET\ESET*\Logs|*.*|RECURSEFileKey2=%CommonAppData%\ESET\ESET*\Oldfiles|*.*|RECURSEFileKey3=%CommonAppData%\ESET\ESET*\Updfiles|*.*|REMOVESELFFileKey4=%LocalAppData%\VirtualStore\ProgramData\ESET\ESET*\Logs|*.*|RECURSEFileKey5=%LocalAppData%\VirtualStore\ProgramData\ESET\ESET*\Oldfiles|*.*|RECURSEFileKey6=%LocalAppData%\VirtualStore\ProgramData\ESET\ESET*\Updfiles|*.*|REMOVESELF Link to comment Share on other sites More sharing options...
ROCKNROLL Posted March 6, 2017 Share Posted March 6, 2017 Updated: https://github.com/MoscaDotTo/Winapp2/commit/da7841101017e393c5a858cbde52a78063b30545 I don't know what you meant by remove FK1, so correct me if I missed something. I am a maintainer for Winapp2. I also have a open-source group on Steam. http://steamcommunity.com/groups/opencommunity Link to comment Share on other sites More sharing options...
Moderators Andavari Posted March 6, 2017 Moderators Share Posted March 6, 2017 I don't know what you meant by remove FK1 FK1 probably means FileKey1. An instance where spelling it out would've caused no guess work or confusion. Link to comment Share on other sites More sharing options...
ROCKNROLL Posted March 7, 2017 Share Posted March 7, 2017 FK1 probably means FileKey1. An instance where spelling it out would've caused no guess work or confusion. Yes I figured that much, but I meant like if he means for me to remove the filekey1 from ESET or if he took it out already or what? I am a maintainer for Winapp2. I also have a open-source group on Steam. http://steamcommunity.com/groups/opencommunity Link to comment Share on other sites More sharing options...
dvdbane Posted March 9, 2017 Share Posted March 9, 2017 Yes I figured that much, but I meant like if he means for me to remove the filekey1 from ESET or if he took it out already or what? sorry for the confusion actually i missed two query which to ask for anyone to confirm that the entry working similarly for other ESET software that use the same location as those 3 software mentioned - eset internet security(EIS),ESET Smart Security(ESS),ESET NOD32 Antivirus(EAV) another one regarding the warning related to ERA - does using ERA generate big size log files which the Filekey1 needed? Link to comment Share on other sites More sharing options...
ROCKNROLL Posted March 10, 2017 Share Posted March 10, 2017 As of right now, I am putting Winapp2 additions on hold for now, so no new additions will be added for awhile. I am currently working on overhauling Winapp2. Most changes will just be under the hood stuff. There maybe some others, like combing some entries and all. You can check out the progress on GitHub in the Development folder. If you have any new additions to add, please just wait until the overhaul is done. Than you for your understanding. I am a maintainer for Winapp2. I also have a open-source group on Steam. http://steamcommunity.com/groups/opencommunity Link to comment Share on other sites More sharing options...
ROCKNROLL Posted March 10, 2017 Share Posted March 10, 2017 Ok, first update to the development build was to combine all the ABBYY FineReader entries into one. It is also my first time trying to use wildcards in Winapp2. Please test it out and see if it works alright. I am a maintainer for Winapp2. I also have a open-source group on Steam. http://steamcommunity.com/groups/opencommunity Link to comment Share on other sites More sharing options...
SMalik Posted March 10, 2017 Share Posted March 10, 2017 New Entries [software Reporter Tool*]LangSecRef=3029SpecialDetect=DET_CHROMEDefault=FalseFileKey1=%LocalAppData%\Google\Software Reporter Tool|*.log [setupMetrics*]LangSecRef=3029SpecialDetect=DET_CHROMEDefault=FalseFileKey1=%ProgramFiles%\Google\Chrome\Application\SetupMetrics|*.*|RECURSE[Chrome Temps*]LangSecRef=3029SpecialDetect=DET_CHROMEDefault=FalseFileKey1=%ProgramFiles%\Google\Chrome\Temp|*.*|RECURSE Link to comment Share on other sites More sharing options...
siliconman01 Posted March 10, 2017 Share Posted March 10, 2017 New Entry: [Kaspersky Dump Files (.dmp)*] [Kaspersky Dump Files (.dmp)*] LangSecRef=3024 Detect=HKCU\Software\KasperskyLab Default=False FileKey1=%CommonAppData%\Kaspersky Lab\|*.dmp;*.dmp.stat;*.log Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
