Winapp2.ini additions
Winapp2.ini
A user posted this over at GitHub: https://github.com/MoscaDotTo/Winapp2/issues/42
What does everyone think? Some of them look a little too risky maybe?
The ones that delete old Windows installations, the $patchcache and the winsxs backup folder are definite no no's IMO (I do occasionally wipe the latter, but seen others have issues caused by it). In all my years of computing I've never seen a convincing/safe reason to delete the $patchcache, other than a last resort if running out of disk space. And the old installations files, seems common sense to not delete them, at least not as a matter of course in a cleaning program.
Link to comment
  • Moderators
I'm with you on this one
Link to comment
  • Moderators
What about the Windows System Volume Tracking.log*? I think it's safe, but is there anyway a wildcard could be used instead of making all those FileKeys?
I think that log has to do with restore points, but am unsure. Don't think there's a wildcard that could do it
Link to comment
I suspect the System Volume Information is inaccessible on most user systems unless the user intentionally takes ownership of the folder (which is not frequently done).
Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System);  Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC.  ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system):   Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more.
Link to comment
By the way, if anyone wanted to clean the windows.old files, you can do this in Windows built in cleaner. Just select your drive, click properties, click disk cleanup, click clean up system files, then check Windows Old I believe it's called.
I am a maintainer for Winapp2. I also have a open-source group on Steam.
http://steamcommunity.com/groups/opencommunity
Link to comment
@dvdbane: Temp Files* and SyncBackFree* are from the removed entries section (just saying cause it took me awhile to find these, lol), but thanks I corrected them, too.
https://github.com/MoscaDotTo/Winapp2/commit/efcfedc542d1b19e77f195efe4596588978ce43f
the keyword here "non-ccleaner winapp2.ini" :P
you need to be careful with Ghost's entries...he already posted the same entries here over and over again
now, he do it there
sorry Ghost, too risky but i like this one [useless File Extension 2.2*] :P
https://forum.piriform.com/index.php?showtopic=32310&page=257&do=findComment&comment=266881
did you test his entries before you update in winapp2.ini?
take [installer*] as an example from https://github.com/MoscaDotTo/Winapp2/commit/5fd04a149f1e764d9ccf72677095515ccfe0aef5
he remove the asterisk * from the filekey and from my test here with my computer, cc couldn't detect the file
and the reason why the original entry for [installer*] got asterisk like this Google\Chrome*\ because it is needed to support Chrome Sxs
if you don't understand what i mean, read here https://forum.piriform.com/index.php?showtopic=32310&page=259&do=findComment&comment=267339
FileKey4=%ProgramFiles%\Google\Chrome\Application\\Installer|.7z|RECURSE
you need to revert the entries back to before the update and please double check before update :)
Link to comment
now, he do it there
His previous name on GitHub was winapp2, he deleted his account so people wouldn't think he was winapp2 owner. I felt like he was a user here who got banned (tho I was thinking of a different user who got banned).
Anyways, there is no revert button, so can you tell me which and where needs to be fixed?
Also, you can't rely on just me know to know everything works. I posted the log here 2 days ago to make sure everyone was OK and I didn't include the ones that everyone disagreed with.
Link to comment
i know there is no Revert button
use the changelog and replace the + entries with - entries
[Argus Monitor*]
LangSecRef=3024
Detect=HKCU\Software\Argotronic\Argus Monitor
Default=False
FileKey1=%Documents%\|ArgusMonitor_EventLog.txt;ArgusMonitor_CSVLog.csv
FileKey2=%LocalAppData%\VirtualStore\Program Files*|ArgusMonitor_EventLog.txt;ArgusMonitor_CSVLog.csv
FileKey3=%ProgramFiles%\|ArgusMonitor_EventLog.txt;ArgusMonitor_CSVLog.csv
- siliconman01 fix #5747
[Foxit Reader 8.0*]
LangSecRef=3021
Detect=HKCU\Software\Foxit Software\Foxit Reader 8.0
Default=False
RegKey1=HKCU\Software\Foxit Software\Foxit Reader 8.0\Preferences\History\LastOpen
RegKey2=HKCU\Software\Foxit Software\Foxit Reader 8.0\Preferences\History\LastSession
RegKey3=HKCU\Software\Foxit Software\Foxit Reader 8.0\Preferences\Others|csInitialOpenDir
RegKey4=HKCU\Software\Foxit Software\Foxit Reader 8.0\MRU\File MRU
RegKey5=HKCU\Software\Foxit Software\Foxit Reader 8.0\MRU\Place MRU
FileKey1=%LocalAppData%\Foxit Reader\|*_old.DMP
FileKey2=%AppData%\Foxit Software\Foxit Reader\Foxit Cloud\DownloadCache|*.cache
FileKey3=%AppData%\Foxit Software\Foxit Reader\Foxit Cloud\FileIDCache|*.fcd
FileKey4=%AppData%\Foxit Software\Foxit Reader\Foxit Cloud|foxitcloud.log
FileKey5=%CommonAppData%\Foxit Software|*.log|RECURSE
- my entry #5736
[Installer*]
LangSecRef=3029
SpecialDetect=DET_CHROME
Default=False
Warning=Running this may remove Chrome's ability to automatically update to future versions on some computers.
FileKey1=%LocalAppData%\Google\Chrome*\Application\*\Installer|*.7z|RECURSE
FileKey2=%LocalAppData%\Google\Update\*\*\Installer|*.7z|RECURSE
FileKey3=%ProgramFiles%\|GUT*tmp
FileKey4=%ProgramFiles%\Google\Chrome*\Application\*\Installer|*.7z|RECURSE
FileKey5=%ProgramFiles%\Google\Update\*\*\Installer|*.7z|RECURSE
[InstallShield*]
LangSecRef=3024
Detect=HKCU\Software\InstallShield
Default=False
FileKey1=%ProgramFiles%\|_ISTMP1.DIR
FileKey2=%SystemDrive%\|_ISTMP*.DIR
btw, you should really double check before you update to prevent something like this happened again
fix missing trailing backlash
https://forum.piriform.com/index.php?showtopic=32310&page=288&do=findComment&comment=276329
update on Ghost entries that undo the fix
https://forum.piriform.com/index.php?showtopic=32310&page=288&do=findComment&comment=276386
i know we need to help you to maintain this project but if this problem happened again, we might missed some of it
no pressure, just a reminder
@all
do we really need this entry?
cc Memory Dumps already support both location
or change fk1 to FileKey1=%WinDir%\LiveKernelReports|*.dmp|RECURSE ???
incase if the entry stay inside winapp2.ini or transfer to non-ccleaner winapp2.ini, i've fix the entry
[Live Kernel Watchdog*]
LangSecRef=3025
Detect=HKCU\SOFTWARE\Microsoft
Default=False
FileKey1=%WinDir%\LiveKernelReports\WATCHDOG|*.dmp
FileKey2=%WinDir%\LiveKernelReports|*.dmp|RECURSE
- fix fk2 based on Ghost's update
Link to comment
From winapp2.com's download page:
 Winapp2.ini
A set of over 2500 extensions for CCleaner, System Ninja, BleachBit, and Avira System Speedup.
Current version: 5.19.160702
Is this site not getting updated any more with the move to GitHub?
Link to comment
 Winapp2.ini
I don't know what Robert is planning on doing to his website. I don't have control over it, so I can't do anything on my end.
To get the most up-to-date copy, you should grab them off GitHub.
Link to comment
New:
[AIMP Classic*]
LangSecRef=3023
DetectFile=%ProgramFiles%\AIMP Classic\cAIMP.exe
Default=False
FileKey1=%ProgramFiles%\AIMP Classic\Data|*.bak|RECURSE
Modified:
[AIMP 2*]
LangSecRef=3023
DetectFile=%ProgramFiles%\AIMP2\AIMP2.exe
Default=False
FileKey1=%AppData%\AIMP|*.bak
FileKey2=%LocalAppData%\VirtualStore\Program Files*\AIMP2\Data|*.bak|RECURSE
FileKey3=%ProgramFiles%\AIMP2\Data|*.bak|RECURSE
Edit FileKey2, Filekey3
Link to comment
Thanks for the fast updates!
Some small fixes:
- Winapp2.ini: "# of entries" should stay 2,569 (one new entry but also one removed).
- Non-CCleaner / Removed entries: [Memory Dumps] has no asterisk (*) and "# of removed entries" should be 51.
- Non-CCleaner / Winapp2.ini: [Memory Dumps] has no asterisk (*) and "# of entries:" should be 2,569 + 51.
Link to comment
Some small fixes:
Corrected them:
https://github.com/MoscaDotTo/Winapp2/commit/5c39e23c891371091d2b2340808fef2264b2e310
https://github.com/MoscaDotTo/Winapp2/commit/891f0075c97777e8deea9f1465fe31e448bfbe11
https://github.com/MoscaDotTo/Winapp2/commit/6b628404bce7569c3bbc0fbc5abe9f50f3ac4c4b
Ill try harder not to make these mistakes in the future.
Link to comment
[Revo Uninstaller Backups*]
LangSecRef=3024
DetectFile=%LocalAppData%\VS Revo group
Default=False
FileKey1=%LocalAppData%\VirtualStore\Program Files*\VS Revo Group\Revo Uninstaller Pro|*.bak
FileKey2=%LocalAppData%\VS Revo Group\Revo Uninstaller Free\BackupsData|*.*|RECURSE
FileKey3=%LocalAppData%\VS Revo Group\Revo Uninstaller Pro\BackupsData|*.*|RECURSE
FileKey4=%ProgramFiles%\VS Revo Group\Revo Uninstaller Pro|*.bak
- remove rupilogs.rupldb from fk1 and fk4
Link to comment
Reason?
seem like i misunderstood rupilogs.rupldb's function
i thought they stored cleaning rule inside that db, it's just list of available removal log
but rupilogs.rupldb should be remove from that entry and place in [Revo Uninstaller Pro*]
LangSecRef=3024
Detect=HKCU\Software\VS Revo Group\Revo Uninstaller Pro
Warning=You need to manually download rupilogs.rupldb via Log Database in Option if you disable "Check for update on startup"
Default=False
FileKey1=%AppData%\ruplp\log|*.log
FileKey2=%ProgramFiles%\VS Revo Group\Revo Uninstaller Pro|rupilogs.rupldb
FileKey3=%LocalAppData%\VS Revo Group\Revo Uninstaller Pro|RUPLogsData.ini
FileKey4=%LocalAppData%\VS Revo Group\Revo Uninstaller Pro\Logs\*|*.*|REMOVESELF
RegKey1=HKCU\Software\VS Revo Group\Revo Uninstaller Pro\Uninstaller\Traced\LogsUSs
 - fk2 for log downloaded
 - fk3 for list of log downloaded, doesn't change when fk2 cleaned
 - regkey same as fk3
 - change detect to HKCU\Software\VS Revo Group
 - add warning
Link to comment
Register a new account
Sign in
Important Information
