dvdbane Posted February 27, 2015 Share Posted February 27, 2015 [Yahoo Messenger Logs*] LangSecRef=3022 Detect=HKCU\Software\Yahoo\pager Default=False FileKey1=%LocalAppData%\VirtualStore\*\Yahoo!\Messenger\logs|*.log FileKey2=%ProgramFiles%\Yahoo!\Messenger|*.log FileKey3=%LocalAppData%\VirtualStore\Program Files*\Yahoo!\Messenger\Cache|*.log;*.tmp FileKey4=%LocalAppData%\VirtualStore\Program Files*\Yahoo!\Messenger\logs|*.log|RECURSE ExcludeKey1=%ProgramFiles%\Yahoo!\Messenger\INSTALL.LOG - Added FileKey4 - and tested... FileKey1 and new FileKey4 almost same..the different only RECURSE if you have YM installed, you should check for FileKey2 also if its need RECURSE too Link to comment Share on other sites More sharing options...
CSGalloway Posted February 27, 2015 Share Posted February 27, 2015 Yes RECURSE is needed..... FileKey1 and new FileKey4 almost same..the different only RECURSE if you have YM installed, you should check for FileKey2 also if its need RECURSE too Link to comment Share on other sites More sharing options...
Moderators Nergal Posted February 27, 2015 Moderators Share Posted February 27, 2015 Whatever happened to "CCleaner ini clean.bat"? I've still got it in my CC folder, and run once in a blue moon, not one for the winapp site? Or is it just pointless (can't say I've ever noticed CC launch quicker after running it but my OCD side likes it )Do you mean trim.bat? ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
dvdbane Posted February 27, 2015 Share Posted February 27, 2015 Yes RECURSE is needed..... then i think you should edit your entry to include that changes Link to comment Share on other sites More sharing options...
JDPower Posted February 27, 2015 Share Posted February 27, 2015 Do you mean trim.bat? No, I mean "CCleaner ini clean.bat" (it alphabetised the CCleaner ini, to make it easier to find entries in it and allegedly speed up CC launch time) Link to comment Share on other sites More sharing options...
APMichael Posted February 27, 2015 Share Posted February 27, 2015 Modified entry: [Dyn Updater*]LangSecRef=3022Detect=HKCU\Software\Dyn\Dyn UpdaterDefault=FalseFileKey1=%CommonAppData%\Dyn\Updater|*.log;*.msi FileKey2=%LocalAppData%\VirtualStore\ProgramData\Dyn\Updater|*.log;*.msi Modified entry: [ElsterFormular*]LangSecRef=3021Detect=HKLM\SOFTWARE\Landesfinanzdirektion Thüringen\ElsterFormularDefault=FalseFileKey1=%AppData%\elsterformular\*\log|*.log;*.log.*FileKey2=%AppData%\elsterformular\*\tmp|*.*|RECURSEFileKey3=%AppData%\elsterformular\pluginmanager\data|*_cpy.zipFileKey4=%LocalAppData%\.elfohilfe|*.*|REMOVESELFFileKey5=%LocalAppData%\elfopatch|*.*|REMOVESELFFileKey6=%CommonAppData%\elsterformular|*.logFileKey7=%LocalAppData%\VirtualStore\ProgramData\elsterformular|*.log New entry: [devolo Cockpit*]LangSecRef=3024Detect=HKLM\SOFTWARE\devolo\dLANDefault=FalseFileKey1=%ProgramFiles%\devolo\dlan|dlanhistory.*txt;dlanstats.*xml;support.html;support.zipFileKey2=%ProgramFiles%\devolo\dlan\updates|*.*|RECURSE New entry: [FreeCommander XE*]LangSecRef=3021DetectFile=%LocalAppData%\FreeCommanderXEDefault=FalseFileKey1=%LocalAppData%\FreeCommanderXE\Settings\Bkp_Settings_*|*.*|REMOVESELFFileKey2=%ProgramFiles%\FreeCommander XE\backup|*.*|REMOVESELF New entry: [inSSIDer Home*]LangSecRef=3024Detect=HKCU\Software\MetaGeek, LLC\inSSIDer HomeDefault=FalseFileKey1=%LocalAppData%\MetaGeek,_LLC|ConnectionErrorLog;MetaGeek-OUI.backup New entry: [Notepad++ More*]LangSecRef=3021Detect=HKLM\SOFTWARE\Notepad++Default=FalseFileKey1=%AppData%\Notepad++\backup|*.*|REMOVESELFFileKey2=%AppData%\Notepad++\plugins\config|PluginManagerGpup.xml;PluginManagerPlugins.xml;PluginManagerPlugins.zipFileKey3=%AppData%\Notepad++\plugins\config\plugin_install_temp|*.*|REMOVESELF Link to comment Share on other sites More sharing options...
SMalik Posted February 28, 2015 Share Posted February 28, 2015 New Entry [Tipard Video Converter Ultimate*]LangSecRef=3023Detect=HKCU\Software\Tipard Studio\Tipard Video Converter UltimateDefault=FalseFileKey1=%LocalAppData%\Tipard Studio\Tipard Video Converter Ultimate|*.txtRegKey1=HKCU\Software\Tipard Studio\Tipard Video Converter Ultimate\Edit|LastVideoFilePath Link to comment Share on other sites More sharing options...
dvdbane Posted February 28, 2015 Share Posted February 28, 2015 [VoidTools Search Everything*] LangSecRef=3024 DetectFile1=%ProgramFiles%\Everything DetectFile2=%AppData%\Everything Default=False FileKey1=%AppData%\Everything|*.csv;*.txt FileKey2=%ProgramFiles%\Everything|*.csv;*.txt FileKey3=%LocalAppData%\VirtualStore\Program Files*\Everything|*.txt;*.csv ExcludeKey1=FILE|%AppData%\Everything|Filters.csv ExcludeKey2=FILE|%ProgramFiles%\Everything|Filters.csv ExcludeKey3=FILE|%LocalAppData%\VirtualStore\Program Files*\Everything|Filters.csv - add exclude for Filters.csv remove [Extensions Databases*] - included in Cookies Link to comment Share on other sites More sharing options...
SMalik Posted February 28, 2015 Share Posted February 28, 2015 Kaspersky has changed the Kaspersky Pure name to Total Security. Please replace the [Kaspersky & Kaspersky Pure x.x*] entry with the one listed below. [Kaspersky*]LangSecRef=3024Detect=HKCU\Software\KasperskyLabDefault=FalseWarning=Make sure to disable “Self Defense” before cleaning.FileKey1=%CommonAppData%\Kaspersky Lab\*\Bases\Cache|*.*|RECURSEFileKey2=%CommonAppData%\Kaspersky Lab\*\Data\Updater\Temporary Files|*.*|RECURSEFileKey3=%CommonAppData%\Kaspersky Lab\*\Temp|*.*FileKey4=%LocalAppData%\VirtualStore\ProgramData\Kaspersky Lab\*\Bases\Cache|*.*|RECURSEFileKey5=%LocalAppData%\VirtualStore\ProgramData\Kaspersky Lab\*\Data\Updater\Temporary Files|*.*|RECURSEFileKey6=%LocalAppData%\VirtualStore\ProgramData\Kaspersky Lab\*\Temp|*.* Link to comment Share on other sites More sharing options...
dvdbane Posted March 3, 2015 Share Posted March 3, 2015 almost all chrome entries use Detect instead of DetectFile except these two [GPU Cache*] [html5 Storage*] SpecialDetect=DET_CHROME Detect1=HKCU\Software\Torch Detect2=HKCU\Software\SuperBird ( but missing Detect for chromium ) [Logs*]LangSecRef=3029SpecialDetect=DET_CHROMEDetect1=HKCU\Software\TorchDetect2=HKCU\Software\SuperBirdDefault=FalseFileKey1=%LocalAppData%\Google\Chrome*\Application|debug.logFileKey2=%LocalAppData%\Google\Chrome*\User Data\*|*LOG.*;Log;*.log|RECURSEFileKey3=%LocalAppData%\Chrome Plus\Application|debug.logFileKey4=%LocalAppData%\Chrome Plus\User Data\*|*LOG.*;Log;*.log|RECURSEFileKey5=%LocalAppData%\Chromium\Application|debug.logFileKey6=%LocalAppData%\Chromium\User Data\*|*LOG.*;Log;*.log|RECURSEFileKey7=%LocalAppData%\Flock\Application|debug.logFileKey8=%LocalAppData%\Flock\User Data\*|*LOG.*;Log;*.log|RECURSEFileKey9=%LocalAppData%\Rockmelt\Application|debug.logFileKey10=%LocalAppData%\Rockmelt\User Data\*|*LOG.*;Log;*.log|RECURSEFileKey11=%LocalAppData%\SRWare Iron\Application|debug.logFileKey12=%LocalAppData%\SRWare Iron\User Data\*|*LOG.*;Log;*.log|RECURSEFileKey13=%LocalAppData%\Torch\Application|debug.logFileKey14=%LocalAppData%\Torch\User Data\*|*LOG.*;Log;*.log|RECURSEFileKey15=%LocalAppData%\SuperBird\Application|debug.logFileKey16=%LocalAppData%\SuperBird\User Data\*|*LOG.*;Log;*.log|RECURSEFileKey17=%LocalAppData%\VirtualStore\Program Files*\Google\Chrome\Application|debug.logExcludeKey1=PATH|%LocalAppData%\Google\Chrome*\User Data\*\Local Extension Settings\|*.*ExcludeKey2=PATH|%LocalAppData%\Google\Chrome*\User Data\*\Local App Settings\|*.*ExcludeKey3=PATH|%LocalAppData%\Google\Chrome*\User Data\*\Extensions\|*.*ExcludeKey4=PATH|%LocalAppData%\Chrome Plus\User Data\*\Local Extension Settings\|*.*ExcludeKey5=PATH|%LocalAppData%\Chrome Plus\User Data\*\Local App Settings\|*.*ExcludeKey6=PATH|%LocalAppData%\Chrome Plus\User Data\*\Extensions\|*.*ExcludeKey7=PATH|%LocalAppData%\Chromium\User Data\*\Local Extension Settings\|*.*ExcludeKey8=PATH|%LocalAppData%\Chromium\User Data\*\Local App Settings\|*.*ExcludeKey9=PATH|%LocalAppData%\Chromium\User Data\*\Extensions\|*.*ExcludeKey10=PATH|%LocalAppData%\Flock\User Data\*\Local Extension Settings\|*.*ExcludeKey11=PATH|%LocalAppData%\Flock\User Data\*\Local App Settings\|*.*ExcludeKey12=PATH|%LocalAppData%\Flock\User Data\*\Extensions\|*.*ExcludeKey13=PATH|%LocalAppData%\Rockmelt\User Data\*\Local Extension Settings\|*.*ExcludeKey14=PATH|%LocalAppData%\Rockmelt\User Data\*\Local App Settings\|*.*ExcludeKey15=PATH|%LocalAppData%\Rockmelt\User Data\*\Extensions\|*.*ExcludeKey16=PATH|%LocalAppData%\SRWare Iron\User Data\*\Local Extension Settings\|*.*ExcludeKey17=PATH|%LocalAppData%\SRWare Iron\User Data\*\Local App Settings\|*.*ExcludeKey18=PATH|%LocalAppData%\SRWare Iron\User Data\*\Extensions\|*.*ExcludeKey19=PATH|%LocalAppData%\Torch\User Data\*\Local Extension Settings\|*.*ExcludeKey20=PATH|%LocalAppData%\Torch\User Data\*\Local App Settings\|*.*ExcludeKey21=PATH|%LocalAppData%\Torch\User Data\*\Extensions\|*.*ExcludeKey22=PATH|%LocalAppData%\Superbird\User Data\*\Local Extension Settings\|*.*ExcludeKey23=PATH|%LocalAppData%\Superbird\User Data\*\Local App Settings\|*.*ExcludeKey24=PATH|%LocalAppData%\Superbird\User Data\*\Extensions\|*.* - add missing "s" to \User Data\*\Extensions Link to comment Share on other sites More sharing options...
siliconman01 Posted March 11, 2015 Share Posted March 11, 2015 New Entry: [jv16 PowerTools X Backup Files*] [jv16 PowerTools X Backup Files*] LangSecRef=3024 DetectFile=%ProgramFiles%\jv16 PowerTools X\jv16PT.exe Default=False FileKey1=%ProgramFiles%\jv16 PowerTools X\Backups|*.*|RECURSE FileKey2=%ProgramFiles%\jv16 PowerTools X\Settings|UserActionLog.txt FileKey3=%LocalAppData%\VirtualStore\Program Files*\jv16 PowerTools X\Backups|*.*|RECURSE FileKey4=%LocalAppData%\VirtualStore\Program Files*\jv16 PowerTools X\Settings|UserActionLog.txt ExcludeKey1=FILE|%ProgramFiles%\jv16 PowerTools X\Backups\License.xbin_backup Revised Entry to incorporate jv16 PowerTools X. Plus shortened name a bit. [jv16 PowerTools Reg Compact Backups*] LangSecRef=3024 DetectFile1=%ProgramFiles%\jv16 PowerTools 2009\jv16PT.exe DetectFile2=%ProgramFiles%\jv16 PowerTools 2010\jv16PT.exe DetectFile3=%ProgramFiles%\jv16 PowerTools 2011\jv16PT.exe DetectFile4=%ProgramFiles%\jv16 PowerTools 2012\jv16PT.exe DetectFile5=%ProgramFiles%\jv16 PowerTools 2013\jv16PT.exe DetectFile6=%ProgramFiles%\jv16 PowerTools 2014\jv16PT.exe DetectFile7=%ProgramFiles%\jv16 PowerTools X\jv16PT.exe Default=False Warning=This removes the registry hive backup files generated by jv16 PowerTools during a registry compaction. These files are not needed once the compaction is successfully completed. They can be safely deleted. NOTE that the system must be rebooted following a registry compaction completion in order for jv16 to release these files for deletion. FileKey1=%LocalAppData%\Microsoft\Windows|UsrClass.dat.jv16pt* FileKey2=%SystemDrive%\Documents and Settings\NetworkService|NTUSER.DAT.jv16pt* FileKey3=%SystemDrive%\Documents and Settings\LocalService|NTUSER.DAT.jv16pt* FileKey4=%SystemDrive%\Documents and Settings\NetworkService.NT*|NTUSER.DAT.jv16pt* FileKey5=%SystemDrive%\Documents and Settings\LocalService.NT*|NTUSER.DAT.jv16pt* FileKey6=%UserProfile%|NTUSER.DAT.jv16pt* FileKey7=%WinDir%\System32\config|Default.jv16pt*;software.jv16pt*;system.jv16pt*;SAM.jv16pt*;COMPONENTS.jv16pt* FileKey8=%WinDir%\ServiceProfiles\LocalService|NTUSER.DAT.jv16pt* FileKey9=%WinDir%\ServiceProfiles\NetworkService|NTUSER.DAT.jv16pt* Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted March 11, 2015 Moderators Share Posted March 11, 2015 Longest warning EVER in the previous post, most users "too long" = "don't read and just press ok" ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
JDPower Posted March 11, 2015 Share Posted March 11, 2015 Longest warning EVER in the previous post, most users "too long" = "don't read and just press ok" I think it can safely be reduced to "Removes registry backups created during a registry compaction. Requires reboot before deletion is possible" Link to comment Share on other sites More sharing options...
Moderators Nergal Posted March 11, 2015 Moderators Share Posted March 11, 2015 Better ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
ninjamask Posted March 13, 2015 Share Posted March 13, 2015 Third party tool to the game League of Legends.http://leaguelsi.com/ [LoL Summonerinfo Logs*] Section=Games DetectFile=%ProgramFiles%\LSI\logs\ Default=False FileKey1=%ProgramFiles%\LSI\logs|*.* [LoL Summonerinfo Replays*] Section=Games DetectFile=%ProgramFiles%\LSI\replays\ Default=False FileKey1=%ProgramFiles%\LSI\replays|*.* Warning=This will delete all your saved replays. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted March 14, 2015 Author Share Posted March 14, 2015 About to look at [steam Installers*] again.. I just bought 3 4TB harddrives, so I threw two of them into a RAID0 array and I'm currently downloading all of my steam games. I'll be away for the next week but they should hopefully maybe finish over that period of time? Not sure. It's a few terabytes (close to 3.5 I think) and my network is terribad in the dorm. We'll see. Either way, eventually I'm going to improve it as much as I can with the steam games I have access to winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
dvdbane Posted March 17, 2015 Share Posted March 17, 2015 (edited) [Omnibox Shortcut*] LangSecRef=3029 SpecialDetect=DET_CHROME Default=False FileKey1=%LocalAppData%\Google\Chrome\User Data\*|Shortcuts - new [WebRTCIdentityStore*] LangSecRef=3029 SpecialDetect=DET_CHROME Default=False FileKey1=%LocalAppData%\Google\Chrome\User Data\*|WebRTCIdentityStore - new [Web Data*] LangSecRef=3029 SpecialDetect=DET_CHROME Warning=This will remove Autofill, Autocomplete, Search Engines keyword, Sign-in and Credit Card info Default=False FileKey1=%LocalAppData%\Google\Chrome\User Data\*|Web Data - rename from [Search Engines Data*] to [Web Data*] [Local Storage*] LangSecRef=3029 SpecialDetect=DET_CHROME Detect1=HKCU\Software\Torch Detect2=HKCU\Software\SuperBird Detect3=HKCU\Software\Chromium Default=False FileKey1=%LocalAppData%\Google\Chrome SxS\User Data\*\Local Storage|http*.*|RECURSE FileKey2=%LocalAppData%\Chrome Plus\User Data\*\Local Storage|http*.*|RECURSE FileKey3=%LocalAppData%\Chromium\User Data\*\Local Storage|http*.*|RECURSE FileKey4=%LocalAppData%\Flock\User Data\*\Local Storage|http*.*|RECURSE FileKey5=%LocalAppData%\Rockmelt\User Data\*\Local Storage|http*.*|RECURSE FileKey6=%LocalAppData%\SRWare Iron\User Data\*\Local Storage|http*.*|RECURSE FileKey7=%LocalAppData%\Torch\User Data\*\Local Storage|http*.*|RECURSE FileKey8=%LocalAppData%\SuperBird\User Data\*\Local Storage|http*.*|RECURSE - change filekey1 to only detect Chrome SxS - remove chrome from [Local Storage*] - *.localstorage-journal -- included in Internet Cache - *.localstorage -- included in Cookies [GPU Cache*] LangSecRef=3029 SpecialDetect=DET_CHROME Detect1=HKCU\Software\Torch Detect2=HKCU\Software\SuperBird Detect3=HKCU\Software\Chromium Default=False FileKey1=%LocalAppData%\Google\Chrome SxS\User Data\*\GPUCache|*.* FileKey2=%LocalAppData%\Chrome Plus\User Data\*\GPUCache|*.* FileKey3=%LocalAppData%\Chromium\User Data\*\GPUCache|*.* FileKey4=%LocalAppData%\Flock\User Data\*\GPUCache|*.* FileKey6=%LocalAppData%\Rockmelt\User Data\*\GPUCache|*.* FileKey7=%LocalAppData%\SRWare Iron\User Data\*\GPUCache|*.* FileKey8=%LocalAppData%\Torch\User Data\*\GPUCache|*.* FileKey9=%LocalAppData%\SuperBird\User Data\*\GPUCache|*.* - change detect - remove filekey 5 and 6 - filekey1 changed to only detect Chrome SxS as Internet Cache already include chrome's GPUCache if chrome SxS included in internet cache, probably no need for filekey1 [HTML5 Storage*] LangSecRef=3029 SpecialDetect=DET_CHROME Detect1=HKCU\Software\Torch Detect2=HKCU\Software\SuperBird Detect3=HKCU\Software\Chromium Default=False FileKey1=%LocalAppData%\Google\Chrome*\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSE FileKey2=%LocalAppData%\Chrome Plus\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSE FileKey3=%LocalAppData%\Chromium\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSE FileKey4=%LocalAppData%\Flock\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSE FileKey5=%LocalAppData%\Rockmelt\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSE FileKey6=%LocalAppData%\SRWare Iron\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSE FileKey7=%LocalAppData%\Torch\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSE FileKey8=%LocalAppData%\SuperBird\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSE - change detect - combine filekey 5 and 6 [Application Cache*] LangSecRef=3029 SpecialDetect=DET_CHROME Detect1=HKCU\Software\Torch Detect2=HKCU\Software\SuperBird Detect3=HKCU\Software\Chromium Default=False FileKey1=%LocalAppData%\Google\Chrome*\User Data\*\Application Cache|*.*|REMOVESELF FileKey2=%LocalAppData%\Chrome Plus\User Data\*\Application Cache|*.*|REMOVESELF FileKey3=%LocalAppData%\Chromium\User Data\*\Application Cache|*.*|REMOVESELF FileKey4=%LocalAppData%\Flock\User Data\*\Application Cache|*.*|REMOVESELF FileKey5=%LocalAppData%\Rockmelt\User Data\*\Application Cache|*.*|REMOVESELF FileKey6=%LocalAppData%\SRWare Iron\User Data\*\Application Cache|*.*|REMOVESELF FileKey7=%LocalAppData%\Torch\User Data\*\Application Cache|*.*|REMOVESELF FileKey8=%LocalAppData%\SuperBird\User Data\*\Application Cache|*.*|REMOVESELF - combine filekey 5 and 6 [Bookmark Backup*] LangSecRef=3029 SpecialDetect=DET_CHROME Detect1=HKCU\Software\Torch Detect2=HKCU\Software\SuperBird Detect3=HKCU\Software\Chromium Default=False FileKey1=%LocalAppData%\Google\Chrome*\User Data\*|*Bookmarks.bak FileKey2=%LocalAppData%\Chrome Plus\User Data\*|*Bookmarks.bak FileKey3=%LocalAppData%\Chromium\User Data\*|*Bookmarks.bak FileKey4=%LocalAppData%\Flock\User Data\*|*Bookmarks.bak FileKey5=%LocalAppData%\Rockmelt\User Data\*|*Bookmarks.bak FileKey6=%LocalAppData%\SRWare Iron\User Data\*|*Bookmarks.bak FileKey7=%LocalAppData%\Torch\User Data\*|*Bookmarks.bak FileKey8=%LocalAppData%\SuperBird\User Data\*|*Bookmarks.bak - combine filekey 5 and 6 Edited March 19, 2015 by dvdbane Link to comment Share on other sites More sharing options...
SMalik Posted March 18, 2015 Share Posted March 18, 2015 New Entry [Camtasia Studio 8*]LangSecRef=3024Detect=HKCU\Software\TechSmith\Camtasia Studio\8.0Default=FalseRegKey1=HKCU\Software\TechSmith\Camtasia Studio\8.0\Camtasia Recorder\8.0\General|lstLastSaveDir RegKey2=HKCU\Software\TechSmith\Camtasia Studio\8.0\Camtasia Studio\8.0|ExportAsZipMruRegKey3=HKCU\Software\TechSmith\Camtasia Studio\8.0\Camtasia Studio\8.0|FileSaveAsMru RegKey4=HKCU\Software\TechSmith\Camtasia Studio\8.0\Camtasia Studio\8.0|MRUImportFolderRegKey5=HKCU\Software\TechSmith\Camtasia Studio\8.0\Camtasia Studio\8.0|MRUOpenProjectFolderRegKey6=HKCU\Software\TechSmith\Camtasia Studio\8.0\Camtasia Studio\8.0|RecentRecordingsMru Link to comment Share on other sites More sharing options...
dvdbane Posted March 19, 2015 Share Posted March 19, 2015 remove certain entries from my previous post [Comodo Dragon (More)*] LangSecRef=3029 Detect=HKLM\Software\ComodoGroup\Dragon Default=False ExcludeKey1=PATH|%LocalAppData%\COMODO\Dragon\User Data\First Run ExcludeKey2=PATH|%LocalAppData%\COMODO\Dragon\User Data\Local State FileKey1=%LocalAppData%\COMODO|*.lock|RECURSE FileKey2=%LocalAppData%\COMODO|*.old|RECURSE FileKey3=%LocalAppData%\COMODO\Dragon\User Data|*.* FileKey4=%LocalAppData%\COMODO\Dragon\User Data\Temp|*.*|RECURSE FileKey5=%LocalAppData%\COMODO\Dragon\User Data\Default|Extension Cookies FileKey6=%LocalAppData%\COMODO\Dragon\User Data\Default|Archived History FileKey7=%LocalAppData%\COMODO\Dragon\User Data\Default|Archived History-journal FileKey8=%LocalAppData%\COMODO\Dragon\User Data\Default|History FileKey9=%LocalAppData%\COMODO\Dragon\User Data\Default|History Index FileKey10=%LocalAppData%\COMODO\Dragon\User Data\Default|History Index * FileKey11=%LocalAppData%\COMODO\Dragon\User Data\Default|History-journal FileKey12=%LocalAppData%\COMODO\Dragon\User Data\Default|Network Action Predictor-journal FileKey13=%LocalAppData%\COMODO\Dragon\User Data\Default|Top Sites FileKey14=%LocalAppData%\COMODO\Dragon\User Data\Default|Top Sites-journal FileKey15=%LocalAppData%\COMODO\Dragon\User Data\Default|Visited Links FileKey16=%LocalAppData%\COMODO\Dragon\User Data\Default\Application Cache|*.*|RECURSE FileKey17=%LocalAppData%\COMODO\Dragon\User Data\Default\Extensions\Temp|*.* FileKey18=%LocalAppData%\COMODO\Dragon\User Data\Default\Extension Rules|*.*|RECURSE FileKey19=%LocalAppData%\COMODO\Dragon\User Data\Default\File System|*.*|RECURSE FileKey20=%LocalAppData%\COMODO\Dragon\User Data\Default\GPUCache|*.*|RECURSE FileKey21=%LocalAppData%\COMODO\Dragon\User Data\Default\Media Cache|*.*|RECURSE FileKey22=%LocalAppData%\COMODO\Dragon\User Data\Default\Session Storage|*.*|RECURSE FileKey23=%LocalAppData%\COMODO\Dragon\User Data\Default\Temp|*.*|RECURSE FileKey24=%LocalAppData%\COMODO\Dragon\User Data\Performance Monitor Databases|*.*|REMOVESELF FileKey25=%SystemDrive%\first_launch|*.*|REMOVESELF - fix excludekey [EaseUS Data Recovery Wizard*] LangSecRef=3024 DetectFile=%ProgramFiles%\EaseUS\EaseUS Data Recovery Wizard Default=False FileKey1=%ProgramFiles%\EaseUS\EaseUS Data Recovery Wizard|*.log FileKey2=%LocalAppData%\VirtualStore\Program Files*\EaseUS\EaseUS Data Recovery Wizard|*.log ExcludeKey1=FILE|%ProgramFiles%\EaseUS\EaseUS Data Recovery Wizard\install.log - fix excludekey [JDownloader2 Temps*] LangSecRef=3022 Detect=HKLM\SOFTWARE\Classes\JDownloader2 DetectFile=%ProgramFiles%\JDownloader 2\ Default=False FileKey1=%ProgramFiles%\JDownloader*2*\tmp|*.*|RECURSE FileKey2=%ProgramFiles%\JDownloader*2*\captchas|*.*|RECURSE FileKey3=%LocalAppData%\VirtualStore\Program Files*\JDownloader*2*\tmp|*.*|RECURSE FileKey4=%LocalAppData%\VirtualStore\Program Files*\JDownloader*2*\captchas|*.*|RECURSE FileKey5=%ProgramFiles%\JDownloader*2*\cfg|CaptchaDialogDimensions_*.json FileKey6=%LocalAppData%\VirtualStore\Program Files*\JDownloader*2*\cfg|CaptchaDialogDimensions_*.json ExcludeKey1=FILE|%ProgramFiles%\JDownloader*2*\cfg\subconf_*.ejs ExcludeKey2=FILE|%LocalAppData%\VirtualStore\Program Files*\JDownloader*2*\cfg\subconf_*.ejs - fix excludekey [Proteus*] Section=Games Detect=HKCU\Software\Valve\Steam\Apps\219680 Default=False FileKey1=%Documents%\Proteus\logs|*.* ExcludeKey1=FILE|%Documents%\Proteus\logs\rng.txt - fix excludekey [Raptr Logs*] LangSecRef=3021 Detect=HKCU\Software\Raptr DetectFile=%ProgramFiles%\Raptr Default=False FileKey1=%AppData%\Raptr|*.log|RECURSE FileKey2=%ProgramFiles%\Raptr|*.log FileKey3=%LocalAppData%\VirtualStore\Program Files*\Raptr|*.log ExcludeKey1=FILE|%ProgramFiles%\Raptr\install.log - fix excludekey [TVersity*] LangSecRef=3023 Detect=HKLM\Software\TVersity\Media Server Default=False FileKey1=%ProgramFiles%\TVersity\Media Server|*.rtf;*.url;*TVersityCodecPackSetup* FileKey2=%ProgramFiles%\TVersity\Media Server\logs|*.log;*.txt;*.xml;*.zip|RECURSE FileKey3=%ProgramFiles%\TVersity Codec Pack|*.exe;*.url FileKey5=%WinDir%\System32\config\systemprofile\AppData\Local\Temp\TVersity Media Server|*.*|REMOVESELF FileKey6=%WinDir%\System32\config\systemprofile\Local Settings\Application Data\Temp\TVersity Media Server|*.*|REMOVESELF FileKey7=%WinDir%\System32|tversity.cookies;TVersityMediaServer.log;*.1;*.2;*.3 FileKey8=%LocalAppData%\VirtualStore\Program Files*\TVersity\Media Server\logs|*.log;*.txt;*.xml;*.zip|RECURSE FileKey9=%LocalAppData%\VirtualStore\Program Files*\TVersity Codec Pack|*.exe;*.url ExcludeKey1=FILE|%ProgramFiles%\TVersity\Media Server\|version.txt;*HOWTO Share Media.txt ExcludeKey2=FILE|%ProgramFiles%\TVersity Codec Pack\uninst.exe - fix excludekey [Yahoo Messenger Logs*] LangSecRef=3022 Detect=HKCU\Software\Yahoo\pager Default=False FileKey1=%LocalAppData%\VirtualStore\*\Yahoo!\Messenger\logs|*.log FileKey2=%ProgramFiles%\Yahoo!\Messenger|*.log FileKey3=%LocalAppData%\VirtualStore\Program Files*\Yahoo!\Messenger\Cache|*.log;*.tmp ExcludeKey1=FILE|%ProgramFiles%\Yahoo!\Messenger\INSTALL.LOG - fix excludekey the tutorial on how to create winapp2.ini on the first page missing ExcludeKey info this is what i found can be use for excludekey seem almost no difference between FILE and PATH ExcludeKey1=FILE|%AppData%\Microsoft\Word\listgal.dat ExcludeKey1=FILE|%AppData%\Microsoft\Word\|listgal.dat ExcludeKey1=FILE|%AppData%\Microsoft\Word\|listgal.dat;*test.dat ExcludeKey1=FILE|%AppData%\Microsoft\Word*|listgal.dat ExcludeKey1=FILE|%AppData%\Microsoft\Word|*listgal.dat ExcludeKey1=FILE|%AppData%\Microsoft\Word\*.dat ExcludeKey1=FILE|%AppData%\Microsoft\Word|*.* ExcludeKey1=FILE|%AppData%\Microsoft\Word\|*.* ExcludeKey1=PATH|%AppData%\Microsoft\Word\STARTUP ExcludeKey1=PATH|%LocalAppData%\Superbird\User Data\*\Extensions\|*.* ExcludeKey1=PATH|%LocalAppData%\Superbird\User Data\*\Extensions|*.* ExcludeKey1=PATH|%AppData%\Microsoft\Word\listgal.dat ExcludeKey1=PATH|%AppData%\Microsoft\Word\*.dat Link to comment Share on other sites More sharing options...
Moderators Andavari Posted March 19, 2015 Moderators Share Posted March 19, 2015 the tutorial on how to create winapp2.ini on the first page missing ExcludeKey info this is what i found can be use for excludekey seem almost no difference between FILE and PATH Don't forget excluding registry data, example: ExcludeKey1=REG|HKCR\DoNotDelete ExcludeKey2=REG|HKCR\DoNotDelete2 ExcludeKey3=REG|HKCR\DoNotDelete3 Link to comment Share on other sites More sharing options...
Winapp2.ini Posted March 26, 2015 Author Share Posted March 26, 2015 updated What's new in winapp2.ini 5.04.150325General:11 New Entries06 Modified Entries01 Removed EntriesNote: Change log excludes minor changes (mild pathing changes, key reordering, non-major key tweaks, etc)Verbose:------------------------------------------------------------------------------New Entries:[Camtasia Studio 8*]LangSecRef=3024Detect=HKCU\Software\TechSmith\Camtasia Studio\8.0Default=FalseRegKey1=HKCU\Software\TechSmith\Camtasia Studio\8.0\Camtasia Recorder\8.0\General|lstLastSaveDirRegKey2=HKCU\Software\TechSmith\Camtasia Studio\8.0\Camtasia Studio\8.0|ExportAsZipMruRegKey3=HKCU\Software\TechSmith\Camtasia Studio\8.0\Camtasia Studio\8.0|FileSaveAsMruRegKey4=HKCU\Software\TechSmith\Camtasia Studio\8.0\Camtasia Studio\8.0|MRUImportFolderRegKey5=HKCU\Software\TechSmith\Camtasia Studio\8.0\Camtasia Studio\8.0|MRUOpenProjectFolderRegKey6=HKCU\Software\TechSmith\Camtasia Studio\8.0\Camtasia Studio\8.0|RecentRecordingsMru[devolo Cockpit*]LangSecRef=3024Detect=HKLM\SOFTWARE\devolo\dLANDefault=FalseFileKey1=%ProgramFiles%\devolo\dlan|dlanhistory.*txt;dlanstats.*xml;support.html;support.zipFileKey2=%ProgramFiles%\devolo\dlan\updates|*.*|RECURSE[FreeCommander XE*]LangSecRef=3021DetectFile=%LocalAppData%\FreeCommanderXEDefault=FalseFileKey1=%LocalAppData%\FreeCommanderXE\Settings\Bkp_Settings_*|*.*|REMOVESELFFileKey2=%ProgramFiles%\FreeCommander XE\backup|*.*|REMOVESELF[inSSIDer Home*]LangSecRef=3024Detect=HKCU\Software\MetaGeek, LLC\inSSIDer HomeDefault=FalseFileKey1=%LocalAppData%\MetaGeek,_LLC|ConnectionErrorLog;MetaGeek-OUI.backup[jv16 PowerTools X Backup Files*]LangSecRef=3024DetectFile=%ProgramFiles%\jv16 PowerTools X\jv16PT.exeDefault=FalseFileKey1=%ProgramFiles%\jv16 PowerTools X\Backups|*.*|RECURSEFileKey2=%ProgramFiles%\jv16 PowerTools X\Settings|UserActionLog.txtFileKey3=%LocalAppData%\VirtualStore\Program Files*\jv16 PowerTools X\Backups|*.*|RECURSEFileKey4=%LocalAppData%\VirtualStore\Program Files*\jv16 PowerTools X\Settings|UserActionLog.txtExcludeKey1=FILE|%ProgramFiles%\jv16 PowerTools X\Backups\License.xbin_backup[LoL Summonerinfo Logs*]Section=GamesDetectFile=%ProgramFiles%\LSI\logs\Default=FalseFileKey1=%ProgramFiles%\LSI\logs|*.*[LoL Summonerinfo Replays*]Section=GamesDetectFile=%ProgramFiles%\LSI\replays\Default=FalseFileKey1=%ProgramFiles%\LSI\replays|*.*Warning=This will delete all your saved replays.[Notepad++ More*]LangSecRef=3021Detect=HKLM\SOFTWARE\Notepad++Default=FalseFileKey1=%AppData%\Notepad++\backup|*.*|REMOVESELFFileKey2=%AppData%\Notepad++\plugins\config|PluginManagerGpup.xml;PluginManagerPlugins.xml;PluginManagerPlugins.zipFileKey3=%AppData%\Notepad++\plugins\config\plugin_install_temp|*.*|REMOVESELF[Omnibox Shortcut*]LangSecRef=3029SpecialDetect=DET_CHROMEDefault=FalseFileKey1=%LocalAppData%\Google\Chrome\User Data\*|Shortcuts[Tipard Video Converter Ultimate*]LangSecRef=3023Detect=HKCU\Software\Tipard Studio\Tipard Video Converter UltimateDefault=FalseFileKey1=%LocalAppData%\Tipard Studio\Tipard Video Converter Ultimate|*.txtRegKey1=HKCU\Software\Tipard Studio\Tipard Video Converter Ultimate\Edit|LastVideoFilePath[WebRTCIdentityStore*]LangSecRef=3029SpecialDetect=DET_CHROMEDefault=FalseFileKey1=%LocalAppData%\Google\Chrome\User Data\*|WebRTCIdentityStore------------------------------------------------------------------------------Modified Entries:[ElsterFormular*]LangSecRef=3021Detect=HKLM\SOFTWARE\Landesfinanzdirektion Thüringen\ElsterFormularDefault=FalseFileKey1=%AppData%\elsterformular\*\log|*.log;*.log.*FileKey2=%AppData%\elsterformular\*\tmp|*.*|RECURSEFileKey3=%AppData%\elsterformular\pluginmanager\data|*_cpy.zipFileKey4=%LocalAppData%\.elfohilfe|*.*|REMOVESELFFileKey5=%LocalAppData%\elfopatch|*.*|REMOVESELFFileKey6=%CommonAppData%\elsterformular|*.logFileKey7=%LocalAppData%\VirtualStore\ProgramData\elsterformular|*.log - Added FileKeys3,5,6,7 [jv16 PowerTools Reg Compact Backups*]LangSecRef=3024DetectFile1=%ProgramFiles%\jv16 PowerTools 2009\jv16PT.exeDetectFile2=%ProgramFiles%\jv16 PowerTools 2010\jv16PT.exeDetectFile3=%ProgramFiles%\jv16 PowerTools 2011\jv16PT.exeDetectFile4=%ProgramFiles%\jv16 PowerTools 2012\jv16PT.exeDetectFile5=%ProgramFiles%\jv16 PowerTools 2013\jv16PT.exeDetectFile6=%ProgramFiles%\jv16 PowerTools 2014\jv16PT.exeDetectFile7=%ProgramFiles%\jv16 PowerTools X\jv16PT.exeDefault=FalseWarning=This removes the registry hive backup files generated by jv16 PowerTools during a registry compaction. These files are not needed once the compaction is successfully completed. They can be safely deleted. NOTE that the system must be rebooted following a registry compaction completion in order for jv16 to release these files for deletion.FileKey1=%LocalAppData%\Microsoft\Windows|UsrClass.dat.jv16pt*FileKey2=%SystemDrive%\Documents and Settings\NetworkService|NTUSER.DAT.jv16pt*FileKey3=%SystemDrive%\Documents and Settings\LocalService|NTUSER.DAT.jv16pt*FileKey4=%SystemDrive%\Documents and Settings\NetworkService.NT*|NTUSER.DAT.jv16pt*FileKey5=%SystemDrive%\Documents and Settings\LocalService.NT*|NTUSER.DAT.jv16pt*FileKey6=%UserProfile%|NTUSER.DAT.jv16pt*FileKey7=%WinDir%\System32\config|Default.jv16pt*;software.jv16pt*;system.jv16pt*;SAM.jv16pt*;COMPONENTS.jv16pt*FileKey8=%WinDir%\ServiceProfiles\LocalService|NTUSER.DAT.jv16pt*FileKey9=%WinDir%\ServiceProfiles\NetworkService|NTUSER.DAT.jv16pt* - Shortened Registry to Reg - Added support for PowerTools X [Kaspersky*]LangSecRef=3024Detect=HKCU\Software\KasperskyLabDefault=FalseWarning=Make sure to disable “Self Defense” before cleaning.FileKey1=%CommonAppData%\Kaspersky Lab\*\Bases\Cache|*.*|RECURSEFileKey2=%CommonAppData%\Kaspersky Lab\*\Data\Updater\Temporary Files|*.*|RECURSEFileKey3=%CommonAppData%\Kaspersky Lab\*\Temp|*.*FileKey4=%LocalAppData%\VirtualStore\ProgramData\Kaspersky Lab\*\Bases\Cache|*.*|RECURSEFileKey5=%LocalAppData%\VirtualStore\ProgramData\Kaspersky Lab\*\Data\Updater\Temporary Files|*.*|RECURSEFileKey6=%LocalAppData%\VirtualStore\ProgramData\Kaspersky Lab\*\Temp|*.* - Renamed from [Kaspersky & Kaspersky Pure x.x*] - Removed many filekeys [VoidTools Search Everything*]LangSecRef=3024DetectFile1=%ProgramFiles%\EverythingDetectFile2=%AppData%\EverythingDefault=FalseFileKey1=%AppData%\Everything|*.csv;*.txtFileKey2=%ProgramFiles%\Everything|*.csv;*.txtFileKey3=%LocalAppData%\VirtualStore\Program Files*\Everything|*.txt;*.csvExcludeKey1=FILE|%AppData%\Everything|Filters.csvExcludeKey2=FILE|%ProgramFiles%\Everything|Filters.csvExcludeKey3=FILE|%LocalAppData%\VirtualStore\Program Files*\Everything|Filters.csv - Added ExcludeKeys[Web Data*]LangSecRef=3029SpecialDetect=DET_CHROMEWarning=This will remove Autofill, Autocomplete, Search Engines keyword, Sign-in and Credit Card infoDefault=FalseFileKey1=%LocalAppData%\Google\Chrome\User Data\*|Web Data -Renamed from Search Engines Data [Yahoo Messenger Logs*]LangSecRef=3022Detect=HKCU\Software\Yahoo\pagerDefault=FalseFileKey1=%LocalAppData%\VirtualStore\*\Yahoo!\Messenger\logs|*.logFileKey2=%ProgramFiles%\Yahoo!\Messenger|*.logFileKey3=%LocalAppData%\VirtualStore\Program Files*\Yahoo!\Messenger\Cache|*.log;*.tmpFileKey4=%LocalAppData%\VirtualStore\Program Files*\Yahoo!\Messenger\logs|*.log|RECURSEExcludeKey1=%ProgramFiles%\Yahoo!\Messenger\INSTALL.LOG - Added FileKey4 ------------------------------------------------------------------------------Removed Entries:[Extensions Databases*]LangSecRef=3029SpecialDetect=DET_CHROMEDetectFile=%LocalAppData%\Google\ChromeFileKey1=%LocalAppData%\Google\Chrome\User Data\Default\IndexedDB|*.*|RECURSE - Included in Cookies*------------------------------------------------------------------------------ winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
APMichael Posted March 30, 2015 Share Posted March 30, 2015 (edited) Thanks for the update!Missed changes: [Dyn Updater*]LangSecRef=3022Detect=HKCU\Software\Dyn\Dyn UpdaterDefault=FalseFileKey1=%CommonAppData%\Dyn\Updater|*.log;*.msiFileKey2=%LocalAppData%\VirtualStore\ProgramData\Dyn\Updater|*.log;*.msi Edited March 30, 2015 by APMichael Link to comment Share on other sites More sharing options...
SMalik Posted April 4, 2015 Share Posted April 4, 2015 New Entry [Action Center*]LangSecRef=3025Detect=HKCU\Software\Microsoft\Windows\CurrentVersion\Action CenterDefault=FalseRegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Action Center\ChecksRegKey2=HKCU\Software\Microsoft\Windows\CurrentVersion\Action Center\Providers\EventLog Link to comment Share on other sites More sharing options...
SMalik Posted April 4, 2015 Share Posted April 4, 2015 Revised Entry Changed from: FileKey2=%LocalAppData%\Microsoft\Windows\Burn\Burn|*.*|RECURSE Changed to: FileKey2=%LocalAppData%\Microsoft\Windows\Burn|*.*|RECURSE Do we really need FileKey1=%LocalAppData%\Microsoft\CD Burning|*.* ? I don't see this location anywhere on Win 7 or 8.1. I don't remember if it was on Vista. [Windows Burn Cache*] LangSecRef=3025Detect=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\CD BurningDefault=FalseWarning=This option will wipe all files that are waiting to be burned to a CD/DVD/BRDFileKey1=%LocalAppData%\Microsoft\CD Burning|*.*FileKey2=%LocalAppData%\Microsoft\Windows\Burn|*.*|RECURSE From Win 8.1 Link to comment Share on other sites More sharing options...
Coffee4Joe Posted April 5, 2015 Share Posted April 5, 2015 Added FileKey13 [Skype Temporary Files*] LangSecRef=3022 Detect=HKCU\Software\Skype Default=False FileKey1=%AppData%\Skype\DbTemp|*.*|RECURSE FileKey2=%AppData%\Skype|*.tmp|RECURSE FileKey3=%AppData%\Skype\|*.db-journal|RECURSE FileKey4=%AppData%\Skype\*\simcache|*.* FileKey5=%AppData%\Skype\*\httpfe|*.* FileKey6=%AppData%\Skype\*\ecache|*.* FileKey7=%AppData%\Skype\DataRv|*.* FileKey8=%AppData%\Skype\*\media_messaging\media_cache|*.* FileKey9=%AppData%\Skype\*\media_messaging\storage_db\asyncdb\tmp|*.* FileKey10=%AppData%\Skype\*\media_messaging\media_cache\asyncdb\tmp|*.* FileKey11=%AppData%\Skype\*\qikdb\tmp|*.* FileKey12=%AppData%\Skype\*\logs|*.* FileKey13=%UserProfile%\Tracing\WPPMedia\*.*|RECURSE Latest skype 7.3.0.101 seems to have lync logs now (probably from them moving lync to skype for business). http://tomtalks.uk/2013/08/lync-2013-and-lync-2010-client-log-file-paths/http://blogs.technet.com/b/nexthop/archive/2013/01/14/lync-2013-the-new-lync-web-app.aspx I've only noticed the %UserProfile%\Tracing path added, none of the others. "If the user is experiencing issues with audio/video when using Lync web App, collect the Lync Web App MediaStack logs at %userprofile%\tracing\WPPMedia\." Link to comment Share on other sites More sharing options...
