CCleaner Community Forums
Winapp2.ini additions
  • Moderators
New Entry FileKey1=%ProgramFiles%\Adobe\Adobe|*.*|REMOVESELF
Uh. Hwhat?
Link to post
Added:
%WinDir%\Panther\FastCleanup|*.log
%WinDir%\Panther\setup.exe|*.*|REMOVESELF
Changed:
%WinDir%\inf|*.log
Sometimes there are logs with the date and time in their names.
[Windows Log Files More*]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows
Default=False
FileKey1=%WinDir%\debug\WIA|*.log
FileKey2=%WinDir%\inf|*.log
FileKey3=%WinDir%\Panther|cbs.log;DDACLSys.log;miglog.xml;Migrep.html;PostGatherPnPList.log;PreGatherPnPList.log;setupact.log;setuperr.log
FileKey4=%WinDir%\Panther\FastCleanup|*.log
FileKey5=%WinDir%\Panther\UnattendGC|diagerr.xml;diagwrn.xml
FileKey6=%WinDir%\Panther\setup.exe|*.*|REMOVESELF
FileKey7=%WinDir%|SIGVERIF.TXT
FileKey8=%WinDir%\System32\sysprep\Panther\IE|diagerr.xml;diagwrn.xml
FileKey9=%WinDir%\winsxs|poqexec.log
Link to post
Revised Entry
Replaced ControlSet001 with CurrentControlSet.
[Windows Session Manager*]
LangSecRef=3025
Detect=HKLM\Software\Microsoft\Windows
Default=False
FileKey1=%WinDir%\AppCompat\Programs|*.xml
FileKey2=%WinDir%\AppCompat\Programs\Install|*.xml
RegKey1=HKLM\SYSTEM\CurrentControlSet\Control\Session Manager|PendingFileRenameOperations
RegKey2=HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\AppCompatCache|AppCompatCache
RegKey3=HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\AppCompatCache|CacheMainSdb
RegKey4=HKLM\SYSTEM\CurrentControlSet\Control\Session Manager\AppCompatCache|SdbTime
Link to post
I think we should merge the [Windows Media Center Thumbnail Cache*] into [Windows Media Center More*].
Revised Entry
LangSecRef=3023
Detect=HKCU\Software\Microsoft\Windows\CurrentVersion\Media Center
Default=False
RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Media Center\MRU\SettingsMRU
FileKey1=%LocalAppData%\Microsoft\Ehome|Image.db;Video.db;musicThumbs.db
FileKey2=%CommonAppData%\Microsoft\eHome\thmb|TVThumb.db
FileKey3=%LocalAppData%\VirtualStore\ProgramData\Microsoft\eHome\thmb|TVThumb.db
Link to post
Updated
What's new in winapp2.ini 5.03.150224
General:
05 New Entries
29 Modified Entries
08 Removed Entries
Note:
 Change log excludes minor changes (mild pathing changes, key reordering, non-major key tweaks, etc)
Verbose:
New Entries:
[Adobe Patch Files*]
LangSecRef=3021
Detect=HKCU\Software\Adobe
Default=False
FileKey1=%ProgramFiles%\Adobe\Adobe\AdobePatchFiles|*.*|REMOVESELF
[Cortana*]
LangSecRef=3031
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Cortana_8wekyb3d8bbwe
DetectFile=%LocalAppData%\Packages\Microsoft.Cortana_8wekyb3d8bbwe
Default=False
FileKey1=%LocalAppData%\Packages\Microsoft.Cortana_*\AC\AppCache|*.*|RECURSE
FileKey2=%LocalAppData%\Packages\Microsoft.Cortana_*\TempState|*.*|RECURSE
FileKey3=%LocalAppData%\Packages\Microsoft.Cortana_*\AC\Microsoft\CryptnetUrlCache\Content|*.*
FileKey4=%LocalAppData%\Packages\Microsoft.Cortana_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.*
FileKey5=%LocalAppData%\Packages\Microsoft.Cortana_*\AC\INetCache|*.*|RECURSE
FileKey6=%LocalAppData%\Packages\Microsoft.Cortana_*\AC\INetCookies|*.*|RECURSE
FileKey7=%LocalAppData%\Packages\Microsoft.Cortana_*\AC\INetHistory|*.*|RECURSE
FileKey8=%LocalAppData%\Packages\Microsoft.Cortana_*\AC\Temp|*.*
FileKey9=%LocalAppData%\Packages\Microsoft.Cortana_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE
[Panther*]
LangSecRef=3025
DetectFile=%Windir%\Panther
Default=False
Warning=The Windows\Panther directory is created/used during a Windows version upgrade.  Following the upgrade, this directory can be safely removed.
FileKey1=%Windir%\Panther\|*.*|REMOVESELF
[The Weather Channel*]
LangSecRef=3031
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\TheWeatherChannel_t3yemqpq4kp7p
DetectFile=%LocalAppData%\Packages\Weather.TheWeatherChannel_t3yemqpq4kp7p
Default=False
FileKey1=%LocalAppData%\Packages\Weather.TheWeatherChannel_*\AC\INetCache|*.*|RECURSE
FileKey2=%LocalAppData%\Packages\Weather.TheWeatherChannel_*\AC\INetCookies|*.*|RECURSE
FileKey3=%LocalAppData%\Packages\Weather.TheWeatherChannel_*\AC\INetHistory|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\Weather.TheWeatherChannel_*\AC\Microsoft\CLR_v4.0\UsageLogs|*.log|RECURSE
FileKey5=%LocalAppData%\Packages\Weather.TheWeatherChannel_*\AC\Temp|*.*
FileKey6=%LocalAppData%\Packages\Weather.TheWeatherChannel_*\LocalState|*.tmp
FileKey7=%LocalAppData%\Packages\Weather.TheWeatherChannel_*\TempState\Bing.Maps\Cache|*.*|RECURSE
[VoidTools Search Everything*]
LangSecRef=3024
DetectFile1=%ProgramFiles%\Everything
DetectFile2=%AppData%\Everything
Default=False
FileKey1=%AppData%\Everything|*.csv;*.txt
FileKey2=%ProgramFiles%\Everything|*.csv;*.txt
FileKey3=%LocalAppData%\VirtualStore\Program Files*\Everything|*.txt;*.csv
Modified Entries:
[Adobe Reader XI More*]
LangSecRef=3021
Detect=HKLM\SOFTWARE\Adobe\Acrobat Reader\11.0
Default=False
FileKey1=%ProgramFiles%\Adobe\Reader 11.0\Setup Files|*.*|REMOVESELF
RegKey1=HKCU\Software\Adobe\Acrobat Reader\11.0\AVConversionFromPDF
RegKey2=HKCU\Software\Adobe\Acrobat Reader\11.0\AVConversionToPDF
RegKey3=HKCU\Software\Adobe\Acrobat Reader\11.0\AVGeneral\cDockables
RegKey4=HKCU\Software\Adobe\Acrobat Reader\11.0\AVGeneral\cToolbars
RegKey5=HKCU\Software\Adobe\Acrobat Reader\11.0\RememberedViews\cNoCategoryFiles
RegKey6=HKCU\Software\Adobe\Adobe Synchronizer\11.0
    - Added FIleKey1
[ART*]
LangSecRef=3029
SpecialDetect=DET_CHROME
Default=False
FileKey1=%CommonProgramFiles%\Microsoft\ART\Backup\Google Chrome\Default\Preferences.bak
FileKey2=%CommonProgramFiles%\Microsoft\ART\Backup\Google Chrome\Default|*.tmp|RECURSE
    - Renamed from Google Chrome ART
[AVG PC TuneUp & TuneUp Utilities Reg Defrag Cleanup*]
LangSecRef=3024
Detect1=HKCU\Software\TuneUp\Utilities\10.0
Detect2=HKCU\Software\TuneUp\Utilities\12.0
Detect3=HKCU\Software\TuneUp\Utilities\13.0
Detect4=HKCU\Software\TuneUp\Utilities\14.0
Detect5=HKCU\Software\AVG\AWL\RegistryCleaner
Default=False
FileKey1=%LocalAppData%\Microsoft\Windows|USRCLASS.DAT_tureg_new.LOG*;USRCLASS.DAT_tureg_old
FileKey2=%SystemDrive%\Boot|BCD_tureg_new.LOG*;BCD_tureg_old
FileKey3=%SystemDrive%\Documents and Settings\LocalService|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_old
FileKey4=%SystemDrive%\Documents and Settings\LocalService.NT*|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_old
FileKey5=%SystemDrive%\Documents and Settings\NetworkService|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_old
FileKey6=%SystemDrive%\Documents and Settings\NetworkService.NT*|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_old
FileKey7=%UserProfile%|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_old
FileKey8=%WinDir%\ServiceProfiles\LocalService|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_old
FileKey9=%WinDir%\ServiceProfiles\NetworkService|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_old
FileKey10=%WinDir%\System32\config|COMPONENTS_tureg_new.LOG*;COMPONENTS_tureg_old;DEFAULT_tureg_new.LOG*;DEFAULT_tureg_old;SAM_tureg_new.LOG*;SAM_tureg_old;SECURITY_tureg_new.LOG*;SECURITY_tureg_old;SOFTWARE_tureg_new.LOG*;SOFTWARE_tureg_old;SYSTEM_tureg_new.LOG*;SYSTEM_tureg_old;DRIVERS_tureg_new.LOG*;DRIVERS_tureg_old;SOFTWARE_tureg_new;SYSTEM_tureg_new
FileKey11=%WinDir%\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Windows\|USRCLASS.DAT_tureg_old;USRCLASS.DAT_tureg_new.LOG*
FileKey12=%WinDir%\ServiceProfiles\LocalService\AppData\Local\Microsoft\Windows\|USRCLASS.DAT_tureg_old;USRCLASS.DAT_tureg_new.LOG*
FileKey13=%CommonAppData%|NTUSER.DAT_tureg_new.LOG1;NTUSER.DAT_tureg_new.LOG2;NTUSER.DAT_tureg_old
FileKey14=%SystemDrive%\Users\Public|NTUSER.DAT_tureg_new.LOG1;NTUSER.DAT_tureg_new.LOG2;NTUSER.DAT_tureg_old
    -  Added SOFTWARE_tureg_new;SYSTEM_tureg_new  to FileKey10
    -  Added FileKey13 & 14
[backup*]
LangSecRef=3029
Default=False
FileKey1=%LocalAppData%\Google\Chrome*\Application|old_chrome.exe
FileKey2=%ProgramFiles%\Google\Chrome*\Application|old_chrome.exe
    - Renamed from Chrome Backup
[beyond Compare*]
LangSecRef=3021
Detect=HKCU\Software\Scooter Software\Beyond Compare
Default=False
FileKey1=%AppData%\Scooter Software\Beyond Compare*|*.bak;BCCommands.xml;BCSessions.xml
    - Renamed from [beyond Compare 3*]
[Corrupt SQLites*]
LangSecRef=3026
SpecialDetect=DET_MOZILLA
Default=False
FileKey1=%AppData%\Mozilla\Firefox\Profiles|*.corrupt|RECURSE
    - Renamed from Firefox Corrupt SQLites
[GPU Cache*]
LangSecRef=3029
DetectFile1=%LocalAppData%\Chromium
DetectFile6=%LocalAppData%\Torch
DetectFile7=%LocalAppData%\SuperBird
Default=False
FileKey1=%LocalAppData%\Google\Chrome*\User Data\*\GPUCache|*.*
FileKey2=%LocalAppData%\Chrome Plus\User Data\*\GPUCache|*.*
FileKey3=%LocalAppData%\Chromium\User Data\*\GPUCache|*.*
FileKey4=%LocalAppData%\Flock\User Data\*\GPUCache|*.*
FileKey5=%LocalAppData%\Google\Chrome\User Data\*\GPUCache|*.*
FileKey6=%LocalAppData%\Google\Chrome SxS\User Data\*\GPUCache|*.*
FileKey7=%LocalAppData%\Rockmelt\User Data\*\GPUCache|*.*
FileKey8=%LocalAppData%\SRWare Iron\User Data\*\GPUCache|*.*
FileKey9=%LocalAppData%\Torch\User Data\*\GPUCache|*.*
FileKey10=%LocalAppData%\SuperBird\User Data\*\GPUCache|*.*
    - Renamed from Chrome GPU Cache
[HP Install Logs*]
LangSecRef=3021
Detect=HKCU\Software\HP
DetectFile=%CommonAppData%\HP
Default=False
FileKey1=%CommonAppData%|hpzinstall.log
FileKey2=%SystemDrive%\Users\All Users|hpzinstall.log
FileKey3=%SystemDrive%\Documents and Settings\All Users\Application Data|hpzinstall.log
FileKey4=%LocalAppData%\VirtualStore\ProgramData|hpzinstall.log
FileKey5=%AppData%\HP\WebRegLogs|WebRegLog.txt
FileKey6=%SystemDrive%\hp\bin\logs|*.log
FileKey7=%CommonAppData%\Hewlett-Packard|*.log*.*;*Log.txt|RECURSE
    - Added FileKey3
[html5 Storage*]
LangSecRef=3029
Default=False
FileKey1=%LocalAppData%\Chrome Plus\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSE
FileKey2=%LocalAppData%\Chromium\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSE
FileKey3=%LocalAppData%\Flock\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSE
FileKey4=%LocalAppData%\Google\Chrome\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSE
FileKey5=%LocalAppData%\Google\Chrome SxS\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSE
FileKey6=%LocalAppData%\Rockmelt\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSE
FileKey7=%LocalAppData%\SRWare Iron\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSE
FileKey8=%LocalAppData%\Torch\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSE
FileKey9=%LocalAppData%\SuperBird\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSE
    - Renamed from Chrome HTML5 Storage
[installer*]
LangSecRef=3029
Default=False
Warning=Running this may remove Chrome's ability to automatically update to future versions on some computers.
FileKey1=%LocalAppData%\Google\Chrome*\Application\*\Installer|*.7z|RECURSE
FileKey2=%ProgramFiles%\Google\Chrome*\Application\*\Installer|*.7z|RECURSE
FileKey3=%LocalAppData%\Google\Update\*\*\Installer|*.7z|RECURSE
FileKey4=%ProgramFiles%\Google\Update\*\*\Installer|*.7z|RECURSE
FileKey5=%ProgramFiles%\|GUT*tmp
    - Renamed from Chrome Installer
[Maintenance Service*]
LangSecRef=3026
Default=False
FileKey1=%CommonAppData%\Mozilla*\logs|*.*
FileKey2=%LocalAppData%\VirtualStore\ProgramData\Mozilla*\logs|*.*
    - Renamed from Mozilla Maintenance Service Logs
[Media Player Classic More*]
LangSecRef=3023
Detect=HKCU\Software\Gabest\Media Player Classic
Detect2=HKCU\Software\MPC-HC\MPC-HC
Default=False
FileKey1=%AppData%\Media Player Classic|*.dmp;default.mpcpl
FileKey2=%AppData%\MPC-HC|*.dmp;default.mpcpl
RegKey1=HKCU\Software\Gabest\Media Player Classic\Settings|DVD Position 0
RegKey2=HKCU\Software\Gabest\Media Player Classic\Settings|DVD Position 1
RegKey3=HKCU\Software\Gabest\Media Player Classic\Settings|DVD Position 2
RegKey4=HKCU\Software\Gabest\Media Player Classic\Settings|DVD Position 3
RegKey5=HKCU\Software\Gabest\Media Player Classic\Settings|DVD Position 4
RegKey6=HKCU\Software\Gabest\Media Player Classic\Settings|DVD Position 5
RegKey7=HKCU\Software\Gabest\Media Player Classic\Settings|DVD Position 6
RegKey8=HKCU\Software\Gabest\Media Player Classic\Settings|DVD Position 7
RegKey9=HKCU\Software\Gabest\Media Player Classic\Settings|DVD Position 8
RegKey10=HKCU\Software\Gabest\Media Player Classic\Settings|DVD Position 9
RegKey11=HKCU\Software\Gabest\Media Player Classic\Settings|DVD Position 10
RegKey12=HKCU\Software\Gabest\Media Player Classic\Settings|DVD Position 11
RegKey13=HKCU\Software\Gabest\Media Player Classic\Settings|DVD Position 12
RegKey14=HKCU\Software\Gabest\Media Player Classic\Settings|DVD Position 13
RegKey15=HKCU\Software\Gabest\Media Player Classic\Settings|DVD Position 14
RegKey16=HKCU\Software\Gabest\Media Player Classic\Settings|DVD Position 15
RegKey17=HKCU\Software\Gabest\Media Player Classic\Settings|DVD Position 16
RegKey18=HKCU\Software\Gabest\Media Player Classic\Settings|DVD Position 17
RegKey19=HKCU\Software\Gabest\Media Player Classic\Settings|DVD Position 18
RegKey20=HKCU\Software\Gabest\Media Player Classic\Settings|DVD Position 19
RegKey21=HKCU\Software\Gabest\Media Player Classic\Settings|DVD Position 20
RegKey22=HKCU\Software\Gabest\Media Player Classic\Settings|LastOpenDir
RegKey23=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 0
RegKey24=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 1
RegKey25=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 2
RegKey26=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 3
RegKey27=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 4
RegKey28=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 5
RegKey29=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 6
RegKey30=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 7
RegKey31=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 8
RegKey32=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 9
RegKey33=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 10
RegKey34=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 11
RegKey35=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 12
RegKey36=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 13
RegKey37=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 14
RegKey38=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 15
RegKey39=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 16
RegKey40=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 17
RegKey41=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 18
RegKey42=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 19
RegKey42=HKCU\Software\Gabest\Media Player Classic\Settings|File Name 20
RegKey43=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 0
RegKey44=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 1
RegKey45=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 2
RegKey46=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 3
RegKey47=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 4
RegKey48=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 5
RegKey49=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 6
RegKey50=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 7
RegKey51=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 8
RegKey52=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 9
RegKey53=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 10
RegKey54=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 11
RegKey55=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 12
RegKey56=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 13
RegKey57=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 14
RegKey58=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 15
RegKey59=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 16
RegKey60=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 17
RegKey61=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 18
RegKey62=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 19
RegKey63=HKCU\Software\Gabest\Media Player Classic\Settings|File Position 20
RegKey64=HKCU\Software\MPC-HC\MPC-HC\Recent File List|File0
RegKey65=HKCU\Software\MPC-HC\MPC-HC\Recent File List|File1
RegKey66=HKCU\Software\MPC-HC\MPC-HC\Recent File List|File2
RegKey67=HKCU\Software\MPC-HC\MPC-HC\Recent File List|File3
RegKey68=HKCU\Software\MPC-HC\MPC-HC\Recent File List|File4
RegKey69=HKCU\Software\MPC-HC\MPC-HC\Recent File List|File5
RegKey70=HKCU\Software\MPC-HC\MPC-HC\Recent File List|File6
RegKey71=HKCU\Software\MPC-HC\MPC-HC\Recent File List|File7
RegKey72=HKCU\Software\MPC-HC\MPC-HC\Recent File List|File8
RegKey73=HKCU\Software\MPC-HC\MPC-HC\Recent File List|File9
RegKey74=HKCU\Software\MPC-HC\MPC-HC\Recent File List|File10
RegKey75=HKCU\Software\MPC-HC\MPC-HC\Recent File List|File11
RegKey76=HKCU\Software\MPC-HC\MPC-HC\Recent File List|File12
RegKey77=HKCU\Software\MPC-HC\MPC-HC\Recent File List|File13
RegKey78=HKCU\Software\MPC-HC\MPC-HC\Recent File List|File14
RegKey79=HKCU\Software\MPC-HC\MPC-HC\Recent File List|File15
RegKey80=HKCU\Software\MPC-HC\MPC-HC\Recent File List|File16
RegKey81=HKCU\Software\MPC-HC\MPC-HC\Recent File List|File17
RegKey82=HKCU\Software\MPC-HC\MPC-HC\Recent File List|File18
RegKey83=HKCU\Software\MPC-HC\MPC-HC\Recent File List|File19
RegKey84=HKCU\Software\MPC-HC\MPC-HC\Recent File List|File20
    - Tweaked FileKey1
    - Added FileKey2
[Minidumps*]
LangSecRef=3026
Default=False
FileKey1=%AppData%\Mozilla\Firefox\Profiles\*\minidumps|*.*
    - Renamed from Firefox Minidumps
[Net Predictions*]
LangSecRef=3026
Default=False
FileKey1=%AppData%\Mozilla\Firefox\Profiles\*|seer.sqlite;netpredictions.sqlite
    - Renamed from Firefox Net Predictions
[Nightly Backups*]
LangSecRef=3026
DetectFile1=%ProgramFiles%\Nightly
DetectFile2=%ProgramFiles%\Mozilla\Nightly
Default=False
FileKey1=%ProgramFiles%\Nightly.bak|*.*|REMOVESELF
FileKey2=%ProgramFiles%\Mozilla\Nightly.bak|*.*|REMOVESELF
    - Renamed from Mozilla Nightly Backups
[session Backups*]
LangSecRef=3026
Default=False
FileKey1=%AppData%\Mozilla\Firefox\Profiles\*|sessionstore.bak*
    - Renamed from Firefox Session Backups
[snagit 11 Local Dumps*]
LangSecRef=3024
Detect=HKCU\Software\TechSmith\SnagIt\11
Default=False
FileKey1=%LocalAppData%\TechSmith\Snagit\CrashDumps|*.*
    - Renamed from [snagit 11 Local Dumps (.dmp)*]
[startup Cache*]
LangSecRef=3026
Default=False
FileKey1=%LocalAppData%\Mozilla\Firefox\Profiles\*\startupCache|*.*
    - Renamed from Firefox Startup Cache
[Telemetry*]
LangSecRef=3026
Default=False
FileKey1=%AppData%\Mozilla\FireFox\Profiles\*|Telemetry*.*
FileKey2=%AppData%\Mozilla\FireFox\Profiles\*\saved-telemetry-pings|*.*
    - Renamed from Firefox Telemetry
[Temps*]
LangSecRef=3026
Default=False
FileKey1=%ProgramFiles%\Mozilla*|*.tmp|RECURSE
FileKey2=%LocalAppData%\VirtualStore\Program Files*\Mozilla*|*.tmp|RECURSE
    - Renamed from Mozilla Temps
[TestPilot Error Logs*]
LangSecRef=3026
Default=False
FileKey1=%AppData%\Mozilla\FireFox\Profiles|TestPilotErrorLog.*|RECURSE
    - Renamed from Firefox TestPilot Error Logs
[updates*]
LangSecRef=3026
DetectFile=%LocalAppData%\Mozilla\Updates
Default=False
FileKey1=%LocalAppData%\Mozilla\Updates|*.*|RECURSE
    - Renamed from Mozilla Updates
[update Logs*]
LangSecRef=3026
Default=False
FileKey1=%LocalAppData%\Mozilla\Firefox\*\updates|*.*|RECURSE
FileKey2=%LocalAppData%\Mozilla\Firefox\Mozilla\*|*.log|RECURSE
    - Renamed from Firefox Update Logs
[urlclassifier3.sqlite*]
LangSecRef=3026
Default=False
Warning=This will delete urlclassifier3.sqlite. If you just want to reduce its size, select Compact Databases instead.
FileKey1=%LocalAppData%\Mozilla\Firefox\Profiles\*|urlclassifier3.sqlite
    - Renamed from FIrefox urlclassifier3.sqlite
[webappsstore.sqlite*]
LangSecRef=3026
Default=False
FileKey1=%AppData%\Mozilla\Firefox\Profiles\*|webappsstore.sqlite
    - Renamed from Firefox webappstore.sqlite
LangSecRef=3025
Default=False
FileKey1=%WinDir%\inf|*.*.log;*.log;*.log*;*.log*.*;*.log*.*
FileKey2=%WinDir%\Panther|cbs.log;DDACLSys.log;miglog.xml;Migrep.html;PostGatherPnPList.log;PreGatherPnPList.log
FileKey3=%WinDir%\winsxs|poqexec.log
FileKey4=%WinDir%\debug\WIA|*.log
FileKey5=%WinDir%|SIGVERIF.TXT
FileKey6=%WinDir%\System32\sysprep\Panther\IE|diagerr.xml;diagwrn.xml
FileKey7=%WinDir%\Panther\UnattendGC|diagerr.xml;diagwrn.xml
FileKey8=%WinDir%\Panther\FastCleanup|*.log
    - Added FileKey8
Removed Entries:
[Adblock Edge For Firefox*]
LangSecRef=3026
Default=False
FileKey1=%AppData%\Mozilla\Firefox\Profiles\*\adblockedge|patterns-backup*.ini;*.tmp
    - Combined into new Adblock Plus/Edge For Firefox entry
[Adblock Plus For Firefox*]
LangSecRef=3026
Default=False
FileKey1=%AppData%\Mozilla\Firefox\Profiles\*\adblockplus|patterns-backup*.ini;*.tmp
[inno Setup Installers Temp*]
LangSecRef=3024
DetectFile=%LocalAppData%\Programs
Default=False
FileKey1=%LocalAppData%\Programs|*.*|REMOVESELF
    - Removes installed programs
[VoidTools Search Everything (History)*]
LangSecRef=3024
Default=False
    - Combined into new VoidTools Search Everything* Entry
[VoidTools Search Everything Error Logs*]
LangSecRef=3024
Default=False
FileKey1=%AppData%\Everything|*.txt
FileKey2=%ProgramFiles%\Everything|*.txt
[Windows Live Mail*]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows Live Mail
Default=False
Warning=This will reset the read counts, which will be recalculated when WLMail is started.
FileKey1=%LocalAppData%\Microsoft\Windows*Mail|*.log;*.jrs;*.chk;*.rss|RECURSE
FileKey2=%LocalAppData%\Microsoft\Windows*Mail\Backup|*.*|REMOVESELF
FileKey3=%LocalAppData%\Microsoft\Windows*Mail\*\Backup|*.*|REMOVESELF
FileKey4=%LocalAppData%\Microsoft\Windows*Mail\*.tmp|*.*|RECURSE
FileKey5=%LocalAppData%\Microsoft\Windows*Mail\*|*.MSMessageStore|RECURSE
RegKey1=HKCU\Software\Microsoft\Windows Live Mail|SearchFolderVersion
    - Removed old fileKey4 that deleted storage folders
LangSecRef=3023
Default=False
    - Merged into Windows Media Center More
[Windows WebCache*]
LangSecRef=3025
DetectFile=%LocalAppData%\Microsoft\Windows\WebCache\
Default=False
FileKey1=%LocalAppData%\Microsoft\Windows\WebCache|*.tmp
    - Included in [internet Explorer 10/11*] (FileKey7).
Link to post
After using this entry - did you wait for WLM to finish finding the emails?  It seems not to have the problems you are experiencing -
Windows Live Mail WARNING!
Finally tracked this one down - recovered and imported Windows Live emails are routinely stored as *.eml files in various folders under "Storage Folders" - and the FileKey4 entry obliterates them completely leaving behind only an email header entry.
After almost a year of hearing friends and coworkers complain from time to time that their older emails were no longer readable, I finally tracked it down to this entry added in April 2014.  Since no one noticed it at the time (new emails don't go into this folder), any backups made since April are useless in efforts to recover the lost data.  Some people have lost years of email correspondence (a few lucky ones still had backups from before April).
Either remove the offending FileKey4 entry entirely or add an appropriate warning about the potential (I'd say almost certain) loss of emails!
Link to post
Thanks for the update!
Missed post:
[HP Install Temps*]
LangSecRef=3021
Default=False
FileKey1=%CommonAppData%\HP\Installer\Temp|*.*
FileKey2=%CommonAppData%\HP\Temp|*.*
FileKey3=%ProgramFiles%\HP\Temp|*.*|RECURSE
FileKey4=%SystemDrive%\Users\All Users\HP\Installer\Temp|*.*
FileKey5=%LocalAppData%\VirtualStore\Program Files*\HP\Temp|*.*|RECURSE
FileKey6=%LocalAppData%\VirtualStore\ProgramData\HP\Installer\Temp|*.*
FileKey7=%LocalAppData%\VirtualStore\ProgramData\HP\Temp|*.*
FileKey8=%WinDir%|*.dat.temp
 - change from %UserProfile%\All Users\HP\Installer\Temp|*.*
Doubled FileKey1:
[snagit 12 More*]
LangSecRef=3024
Detect=HKCU\Software\TechSmith\SnagIt\12
Default=False
Warning=This will delete the backups of the captures that you have performed with SnagIt 12.
FileKey1=%LocalAppData%\TechSmith\Snagit\DataStore|*.SNAG;*.SNAGundo;*.MP4
FileKey2=%Documents%\|SnagItDebug.log
RegKey1=HKCU\Software\TechSmith\Snagit\12|CaptureCount
RegKey2=HKCU\Software\TechSmith\Snagit\Stamps|StampCustomFolder
Link to post
Some guys, and me too, are reporting problems regarding download any *.bat files from winapp2. I don't want to hear this is not an issue.
If we suffer from this problem we expect a little help from winapp2 admin.
I'm getting following result while trying download trim.bat file:
Forbidden
You don't have permission to access /trim.bat on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
and there is nothing more from whireshark traces
So the question is:
Could anyone help us?
Link to post
  • Moderators
Known issue with the Domain Host
Link to post
  • Moderators
As expected. Any idea how to solve this....
Couple pages back, I think Alan_b posted to the most recent. The domain either changed their rules for batch files or just the permission values on those files, the ini-compiler-@Winapp2.ini has not said which, nor should he feel obligated to devulge it.
Link to post
Forbidden
So the question is:
I'm working with my webhost to fix it.
Use this link for now:
https://www.dropbox.com/sh/4bidse629f3e9lf/AAAV6SazlDm2zVTJnms6HpNna?dl=0
Link to post
[Extensions State*]
LangSecRef=3029
Default=False
FileKey1=%LocalAppData%\Google\Chrome\User Data\*\Extension State|*.*|RECURSE
[History*]
LangSecRef=3029
Default=False
FileKey1=%LocalAppData%\Google\Chrome\User Data\*|History
[Quota Manager Data*]
LangSecRef=3029
Default=False
FileKey1=%LocalAppData%\Google\Chrome\User Data\*|QuotaManager
[session Storage*]
LangSecRef=3029
Default=False
FileKey1=%LocalAppData%\Google\Chrome\User Data\*\Session Storage|*.*|RECURSE
- remove unneeded detect
- change Default to * to support non-default profiles
[Steam Browser Cache*]
Section=Games
Detect=HKCU\Software\Valve\Steam
Default=False
Warning=This will also delete the thumbnails and custom background images of the games in your Library.
FileKey1=%ProgramFiles%\Steam\appcache\httpcache|*.*|RECURSE
FileKey2=%ProgramFiles%\Steam\config\cookies|*.*|RECURSE
FileKey3=%ProgramFiles%\Steam\config\htmlcache|*.*|RECURSE
FileKey4=%ProgramFiles%\Steam\config\overlaycookies|*.*|RECURSE
FileKey5=%ProgramFiles%\Steam\config\overlayhtmlcache|*.*|RECURSE
FileKey6=%ProgramFiles%\Steam\userdata\*\ugcmsgcache|*.*|RECURSE
FileKey7=%LocalAppData%\VirtualStore\Program Files*\Steam\appcache\httpcache|*.*|RECURSE
FileKey8=%LocalAppData%\VirtualStore\Program Files*\Steam\config\cookies|*.*|RECURSE
FileKey9=%LocalAppData%\VirtualStore\Program Files*\Steam\config\htmlcache|*.*|RECURSE
FileKey10=%LocalAppData%\VirtualStore\Program Files*\Steam\config\overlaycookies|*.*|RECURSE
FileKey11=%LocalAppData%\VirtualStore\Program Files*\Steam\config\overlayhtmlcache|*.*|RECURSE
- add Default=False
Edited by dvdbane
Link to post
Should be working from winapp2.com again - they've concluded an update to a firewall applied to the domain for a long time suddenly started interfering
Just to confirm, download *. bat files is working again on winapp2.com site.
Many thanks.
Link to post
Running CCleaner with this entry (FileKey4) causes the entire Storage Folder (C:\Users\<user>\AppData\Local\Microsoft\Windows Live Mail\Storage Folder) to be emptied and removed, and more specifically, ALL the *.eml files therein are gone.  The headers remain, but clicking on them produces an error message (A problem has occurred trying to open the message...)  A new (empty) Storage Folder is automatically recreated the next time you start Windows Live Mail.
Microsoft's Windows Live Mail import function puts all imported emails (each *.eml is an email) into respective folders beneath the Storage Folder, and many users create their own directory structure within this folder.
Just tested it again - 20 (identical) emails obliterated in an instant (on purpose).  Telling CCleaner to exclude *.eml files will also save them from deletion.
EDIT - Just updated to the latest winapp2.ini - I see the Storage Folder entry has been removed (now five FileKey entries for Windows Live Mail instead of six).  Thank you!
Link to post
Just tested it - 120 (identical) emails obliterated in an instant.  Telling CCleaner to exclude *.eml files will also save them.  But why empty and delete this folder at all?
The offending FileKey was removed in the latest update :)
Link to post
[Yahoo Messenger Logs*]
LangSecRef=3022
Detect=HKCU\Software\Yahoo\pager
Default=False
FileKey1=%LocalAppData%\VirtualStore\*\Yahoo!\Messenger\logs|*.log
FileKey2=%ProgramFiles%\Yahoo!\Messenger|*.log
FileKey3=%LocalAppData%\VirtualStore\Program Files*\Yahoo!\Messenger\Cache|*.log;*.tmp
FileKey4=%LocalAppData%\VirtualStore\Program Files*\Yahoo!\Messenger\logs|*.log|RECURSE
ExcludeKey1=%ProgramFiles%\Yahoo!\Messenger\INSTALL.LOG
- Added FileKey4 - and tested...
Link to post
It might have helped if the original poster would have mentioned what FileKey4 was - would have saved a few messages....
And yes I concur that no FileKey should appear for anything under \storage folders\ - VERY BAD IDEA
Link to post
Whatever happened to "CCleaner ini clean.bat"? I've still got it in my CC folder, and run once in a blue moon, not one for the winapp site? Or is it just pointless (can't say I've ever noticed CC launch quicker after running it but my OCD side likes it ^_^ )
Link to post
Register a new account
Sign in
