Winapp2.ini additions
Winapp2.ini
I have the latest versions of QuickTime and iTunes on my system (Win 8.1 64-bit). I am not seeing any issue after removing the left over empty installer folders.
You are right! The latest version (QT 7.7.6) does not show this issue anymore. Great! :) Thanks for the hint.
Link to comment
EDIT:
[battle.Net Client Logs*]
Section=Games
Detect=HKCU\Software\Blizzard Entertainment\Battle.net
Default=False
FileKey1=%CommonAppData%\Battle.net\Client\Blizzard Launcher.*\Logs|*.*|RECURSE
FileKey2=%CommonAppData%\Battle.net\Client\Logs|*.*|RECURSE
FileKey3=%Documents%\StarCraft II\GameLogs|*.*|RECURSE
FileKey4=%Documents%\StarCraft II\UserLogs|*.*|RECURSE
FileKey5=%LocalAppData%\Battle.Net\Logs|*.*|RECURSE
FileKey6=%LocalAppData%\VirtualStore\ProgramData\Battle.net\Client\Blizzard Launcher.*\Logs|*.*|RECURSE
FileKey7=%LocalAppData%\VirtualStore\ProgramData\Battle.net\Client\Logs|*.*|RECURSE
Added FileKey 3 and 4.
I am a maintainer for Winapp2. I also have a open-source group on Steam.
http://steamcommunity.com/groups/opencommunity
Link to comment
Revised Entry
Added: %AppData%\Ashampoo\Ashampoo Snap 7|*.*|RECURSE
[Ashampoo Snap 7*]
LangSecRef=3024
Detect=HKCU\Software\Ashampoo\Ashampoo Snap 7
Default=False
FileKey1=%LocalAppData%\CrashRpt\UnsentCrashReports|*.*|RECURSE
FileKey2=%AppData%\Ashampoo\Ashampoo Snap 7|*.*|RECURSE
FileKey3=%ProgramFiles%\Ashampoo\Ashampoo Snap 7|_NLogMsg.txt
Link to comment
Kodi, the new XBMC replacement (I simply edited the XBMC entries, works fine):
[Kodi Cache*]
LangSecRef=3023
DetectFile=%AppData%\kodi
Default=False
FileKey1=%AppData%\kodi\cache|*.*|RECURSE
[Kodi Packages*]
LangSecRef=3023
Default=False
FileKey1=%AppData%\kodi\addons\packages|*.*|RECURSE
[Kodi Thumbnails*]
LangSecRef=3023
Default=False
FileKey1=%AppData%\kodi\userdata\thumbnails|*.*|RECURSE
FileKey2=%AppData%\kodi.old\userdata\thumbnails|*.*|RECURSE
Link to comment
EDITED:
[Private Internet Access VPN*]
LangSecRef=3022
DetectFile=%AppData%\Titanium\appdata\com.privateinternetaccess.vpn
Default=False
FileKey1=%AppData%\Titanium\appdata\com.privateinternetaccess.vpn|*.log
FileKey2=%ProgramFiles%\pia_manager\log|*.*
FileKey3=%ProgramFiles%\pia_manager\tmp|*.*
[steam Logs*]
Section=Games
Detect=HKCU\Software\Valve\Steam
Default=False
FileKey1=%ProgramFiles%\Steam|*.log;*log.last;connection_log_*.txt;*_log.txt;remote_connections.txt;vr*_*.txt|RECURSE
FileKey2=%ProgramFiles%\Steam|Steam.log;.crash
FileKey3=%ProgramFiles%\Steam\SteamLogs|*.log
FileKey4=%ProgramFiles%\Steam\vr\runtime\logs|*.*|RECURSE
FileKey5=%AppData%\SteamVR\Logs|*.*|REMOVESELF
FileKey6=%LocalAppData%\VirtualStore\Program Files*\Steam|*.log;*log.last;connection_log_*.txt;*_log.txt;remote_connections.txt;vr*_*.txt|RECURSE
FileKey7=%LocalAppData%\VirtualStore\Program Files*\Steam|Steam.log
FileKey8=%LocalAppData%\VirtualStore\Program Files*\Steam\SteamLogs|*.log
[Team Fortress 2 Cache and Cookies*]
Section=Games
Detect=HKCU\Software\Valve\Steam\Apps\440
Default=False
FileKey1=%ProgramFiles%\Steam\SteamApps\common\Team Fortress 2\config\cookies|*.*|RECURSE
FileKey2=%ProgramFiles%\Steam\SteamApps\common\Team Fortress 2\config\html\AppCache|*.*|RECURSE
FileKey3=%ProgramFiles%\Steam\SteamApps\common\Team Fortress 2\tf\cache|*.*|RECURSE
FileKey4=%ProgramFiles%\Steam\SteamApps\common\Team Fortress 2\tf\materials\temp|*.vtf|RECURSE
FileKey5=%ProgramFiles%\Steam\SteamApps\common\Team Fortress 2\tf\download\user_custom|*.*|RECURSE
I also removed "%ProgramFiles%\Valve\" from the paths because Steam doesn't create that folder (anymore?).
Link to comment
EDIT:
[steam Browser Cache*]
Section=Games
Warning=This will also delete the thumbnails and custom background images of the games in your Library.
FileKey1=%ProgramFiles%\Steam\appcache\httpcache|*.*|RECURSE
FileKey2=%ProgramFiles%\Steam\config\cookies|*.*|RECURSE
FileKey3=%ProgramFiles%\Steam\config\htmlcache|*.*|RECURSE
FileKey4=%ProgramFiles%\Steam\config\overlaycookies|*.*|RECURSE
FileKey5=%ProgramFiles%\Steam\config\overlayhtmlcache|*.*|RECURSE
FileKey6=%ProgramFiles%\Steam\userdata\26703095\ugcmsgcache|*.*|RECURE
FileKey7=%ProgramFiles%\Steam\userdata\146582023\ugcmsgcache|*.*|RECURE
FileKey8=%LocalAppData%\VirtualStore\Program Files*\Steam\appcache\httpcache|*.*|RECURSE
FileKey9=%LocalAppData%\VirtualStore\Program Files*\Steam\config\cookies|*.*|RECURSE
FileKey10=%LocalAppData%\VirtualStore\Program Files*\Steam\config\htmlcache|*.*|RECURSE
FileKey11=%LocalAppData%\VirtualStore\Program Files*\Steam\config\overlaycookies|*.*|RECURSE
FileKey12=%LocalAppData%\VirtualStore\Program Files*\Steam\config\overlayhtmlcache|*.*|RECURSE
Added FileKey 6 and 7. I wasn't sure which those entries belong, so I just threw them with the browser cache. Is there anyway we can just combine all the steam cache sections into one, rather then having 3 seperate. I do think it will harm anything. Also, I do not know if those 2 FileKey's are the same for everyone, but those are just cache files I found at those locations. Someone should investigate to see if those apply to everyone or if they are different for everyone.
@qsdewa: No, they haven't used that path for a very long time now. I think the first versions of steam did, but not sure.
Link to comment
EDIT:
Section=Games
Off the top of my head I don't know what that entry is, other than the obvious (some sort of message cache), but your entry needs a wildcard as the number in the path seems to be different on different systems (and I only have one folder, holding just 13k).
And regarding merging entries, I certainly think the cache entries can/should be.
Link to comment
New Entry
[iMobie PhoneRescue*]
LangSecRef=3024
DetectFile=%AppData%\iMobie\PhoneRescue
Default=False
FileKey1=%AppData%\iMobie\PhoneRescue\AutoUpdate|*.*|RECURSE
FileKey2=%AppData%\iMobie\PhoneRescue\Configue|Settings.plist
FileKey3=%AppData%\iMobie\PhoneRescue\ErrorLog|*.*|RECURSE
FileKey4=%AppData%\iMobie\PhoneRescue\Files|*.*|RECURSE
FileKey5=%AppData%\iMobie\PhoneRescue|iTunesPrefs
Link to comment
Revised Entries
Added FileKey1, FileKey2, FileKey3 and FileKey4
[CyberLink PowerDirector 10*]
LangSecRef=3023
Detect=HKCU\Software\CyberLink\PowerDirector10
Default=False
FileKey1=%AppData%\CyberLink\PowerDirector\10.0\AutoSave|*.*|RECURSE
FileKey2=%AppData%\CyberLink\PowerDirector\10.0\photoTmp|*.*|RECURSE
FileKey3=%AppData%\Cyberlink\PowerDirector\10.0\WaveForms|*.*|RECURSE
FileKey4=%AppData%\Cyberlink\PowerDirector\10.0|Recentfiles.ini
FileKey6=%Documents%\CyberLink\PowerDirector\10.0\MyTitles|*.*|RECURSE
FileKey7=%Documents%\CyberLink\PowerDirector\10.0\Preview Cache Files|*.*
FileKey8=%Documents%\CyberLink\PowerDirector\10.0\ShadowEditFiles|*.MPG
FileKey9=%Documents%\CyberLink\PowerDirector\10.0\SplitterIndex|*.maidx
RegKey1=HKCU\Software\CyberLink\Hanuman
RegKey2=HKCU\Software\CyberLink\PowerDirector10\MediaObj\MediaCache5\Data5
RegKey3=HKCU\Software\CyberLink\PowerDirector10\MediaObj\MediaCache5\Thumbnail5
[CyberLink PowerDirector 11*]
LangSecRef=3023
Detect=HKCU\Software\CyberLink\PowerDirector11
Default=False
FileKey1=%AppData%\CyberLink\PowerDirector\11.0\AutoSave|*.*|RECURSE
FileKey2=%AppData%\CyberLink\PowerDirector\11.0\photoTmp|*.*|RECURSE
FileKey3=%AppData%\Cyberlink\PowerDirector\11.0\WaveForms|*.*|RECURSE
FileKey4=%AppData%\Cyberlink\PowerDirector\11.0|Recentfiles.ini
FileKey6=%Documents%\CyberLink\PowerDirector\11.0\MyTitles|*.*|RECURSE
FileKey7=%Documents%\CyberLink\PowerDirector\11.0\Preview Cache Files|*.*
FileKey8=%Documents%\CyberLink\PowerDirector\11.0\ShadowEditFiles|*.MPG
FileKey9=%Documents%\CyberLink\PowerDirector\11.0\SplitterIndex|*.maidx
RegKey2=HKCU\Software\CyberLink\PowerDirector11\MediaObj\MediaCache5\Data5
RegKey3=HKCU\Software\CyberLink\PowerDirector11\MediaObj\MediaCache5\Thumbnail5
[CyberLink PowerDirector 12*]
LangSecRef=3023
Detect=HKCU\Software\CyberLink\PowerDirector12
Default=False
FileKey1=%AppData%\CyberLink\PowerDirector\12.0\AutoSave|*.*|RECURSE
FileKey2=%AppData%\CyberLink\PowerDirector\12.0\photoTmp|*.*|RECURSE
FileKey3=%AppData%\Cyberlink\PowerDirector\12.0\WaveForms|*.*|RECURSE
FileKey4=%AppData%\Cyberlink\PowerDirector\12.0|Recentfiles.ini
FileKey6=%Documents%\CyberLink\PowerDirector\12.0\MyTitles|*.*|RECURSE
FileKey7=%Documents%\CyberLink\PowerDirector\12.0\Preview Cache Files|*.*
FileKey8=%Documents%\CyberLink\PowerDirector\12.0\ShadowEditFiles|*.MPG
FileKey9=%Documents%\CyberLink\PowerDirector\12.0\SplitterIndex|*.maidx
RegKey2=HKCU\Software\CyberLink\PowerDirector12\MediaObj\MediaCache5\Data5
RegKey3=HKCU\Software\CyberLink\PowerDirector12\MediaObj\MediaCache5\Thumbnail5
[CyberLink PowerDirector 13*]
LangSecRef=3023
Detect=HKCU\Software\CyberLink\PowerDirector13
Default=False
FileKey1=%AppData%\CyberLink\PowerDirector\13.0\AutoSave|*.*|RECURSE
FileKey2=%AppData%\CyberLink\PowerDirector\13.0\photoTmp|*.*|RECURSE
FileKey3=%AppData%\Cyberlink\PowerDirector\13.0\WaveForms|*.*|RECURSE
FileKey4=%AppData%\Cyberlink\PowerDirector\13.0|Recentfiles.ini
FileKey6=%Documents%\CyberLink\PowerDirector\13.0\MyTitles|*.*|RECURSE
FileKey7=%Documents%\CyberLink\PowerDirector\13.0\Preview Cache Files|*.*
FileKey8=%Documents%\CyberLink\PowerDirector\13.0\ShadowEditFiles|*.MPG
FileKey9=%Documents%\CyberLink\PowerDirector\13.0\SplitterIndex|*.maidx
RegKey2=HKCU\Software\CyberLink\PowerDirector13\MediaObj\MediaCache5\Data5
RegKey3=HKCU\Software\CyberLink\PowerDirector13\MediaObj\MediaCache5\Thumbnail5
Link to comment
Revised Entries
Removed: %LocalAppData%\TechSmith\Snagit|*.bin
It is in the CCleaner entry.
Added: *.sdf extension into FileKey2
I think we should merge [snagit 12 Local Dumps *] into [snagit 12 More*].
[snagit 12 More*]
LangSecRef=3024
Detect=HKCU\Software\TechSmith\SnagIt\12
Default=False
Warning=This will delete the backups of the captures that you have performed with SnagIt 12.
FileKey1=%LocalAppData%\TechSmith\Snagit\CrashDumps|*.*
FileKey2=%LocalAppData%\TechSmith\Snagit\DataStore|*.sdf;*.SNAG;*.SNAGundo;*.MP4
FileKey3=%Documents%\|SnagItDebug.log
RegKey1=HKCU\Software\TechSmith\Snagit\12|CaptureCount
RegKey2=HKCU\Software\TechSmith\Snagit\Stamps|StampCustomFolder
[snagit 11 Local Dumps (.dmp)*] merged into [snagit 11 More*].
[snagit 11 More*]
LangSecRef=3024
Detect=HKCU\Software\TechSmith\SnagIt\11
Default=False
Warning=This will delete the backups of the captures that you have performed with SnagIt 11.
RegKey1=HKCU\Software\TechSmith\Snagit\11|CaptureCount
Link to comment
  • Moderators
 I think we should merge [snagit 12 Local Dumps*] into [snagit 12 More*].
Likely that they were split because not everybody considers crashdumps to be junk (including me)
Link to comment
I'm using this program since version 9, I never saw any crashdumps of this program.
Anyways, if you guys like to keep the entries separate then fix the names of the crashdumps entries.
Here are the fixed entries:
Changed the name from [snagit 11 Local Dumps (.dmp)*].
[snagit 11 Local Dumps*]
LangSecRef=3024
Default=False
Changed the name from [snagit 12 Local Dumps *].
There was space before the asterisk.
LangSecRef=3024
Default=False
Here are the other entries:
[snagit 11 More*]
LangSecRef=3024
Default=False
FileKey1=%LocalAppData%\TechSmith\Snagit\DataStore|*.sdf;*.SNAG;*.SNAGundo;*.MP4
FileKey2=%Documents%\|SnagItDebug.log
[snagit 12 More*]
LangSecRef=3024
Default=False
Link to comment
I just searched the Winapp2.ini file and there are more than 200 crash dump/reports entries that are mixed with other stuff. Those crash dump/reports files are being wiped without the user's consent. You should also fix them.
Off course not everybody considers crash dumps/reports to be junk (including you)!
Link to comment
New
[Adblock Edge for Firefox Backups*]
LangSecRef=3026
SpecialDetect=DET_MOZILLA
Default=False
FileKey1=%AppData%\Mozilla\Firefox\Profiles\*\adblockedge|patterns-backup*.ini;*.tmp
Can we just keep the name [Adblock Edge*]?
Link to comment
  • Moderators
New
LangSecRef=3026
Default=False
No because it then interferes with the chrome entry. That's why all the add-on entries who've a version in both browsers are listed as such
Link to comment
Remove
[Firefox Extensions Log*]
LangSecRef=3026
Default=False
FileKey1=%AppData%\Mozilla\Firefox\Profiles\*|extensions.log
already inside
[Firefox Logs*]
LangSecRef=3026
Default=False
FileKey1=%ProgramFiles%\Mozilla Firefox|*.log
FILEKEY2=%APPDATA%\MOZILLA|*.LOG|RECURSE
FileKey3=%LocalAppData%\VirtualStore\Program Files*\Mozilla Firefox|*.log
Link to comment
How about just [Adblock Edge Backups (Firefox)*] for entries that duplicate in different browsers? Puts the important bit of the name first, browser clarification second. Looks a little less clumsy in my opinion (unless you consider brackets clumsy looking, in which case you'll hate this part of my post too :P )
Link to comment
New Entry
[AVG 2015*]
LangSecRef=3024
Detect=HKLM\Software\AVG\AVG2015
Default=False
FileKey1=%CommonAppData%\AVG2015\log|*.log;history.xml
FileKey2=%CommonAppData%\AVG2015\scanlogs|*.log
FileKey3=%CommonAppData%\AVG2015\update\backup|*.*
FileKey4=%CommonAppData%\AVG2015\Emc\log|*.*
FileKey5=%CommonAppData%\AVG2015\IDS\config|List.zip.bak
FileKey6=%CommonAppData%\AVG2015\IDS\profile|globalLoadable.bak
FileKey7=%CommonAppData%\AVG2015\temp|*.*
FileKey8=%CommonAppData%\AVG2015\SetupBackup|*.*|REMOVESELF
FileKey9=%CommonAppData%\MFAData\logs|*.*
FileKey10=%CommonAppData%\MFAData\pack|*.*
FileKey11=%CommonAppData%\MFAData|msistorg.dat.bkp;public_installation_log.xml
FileKey12=%LocalAppData%\AVG2015\log|*.log;*.log.*
FileKey13=%LocalAppData%\AVG2015\update|*.*
FileKey14=%LocalAppData%\AVG2015\temp|*.*
FileKey15=%LocalAppData%\MFAData\logs|*.*
FileKey16=%ProgramFiles%\AVG\AVG2015|updatecomps.bak;*.old
FileKey17=%WinDir%\System32\config\systemprofile\AppData\Local\Avg2015\dumps|*.*
FileKey18=%WinDir%\System32\config\systemprofile\Local Settings\Application Data\Avg2015\dumps|*.*
FileKey19=%WinDir%\System32\config\systemprofile\AppData\Local\Avg2015\log|*.*
FileKey20=%WinDir%\System32\config\systemprofile\Local Settings\Application Data\log|*.*
FileKey21=%WinDir%\System32\config\systemprofile\AppData\Local\Avg2015\temp|*.*
FileKey22=%WinDir%\System32\config\systemprofile\Local Settings\Application Data\temp|*.*
FileKey23=%WinDir%\System32\config\systemprofile\AppData\Local\MFAData\logs|*.*
FileKey24=%WinDir%\System32\config\systemprofile\Local Settings\MFAData\logs|*.*
FileKey25=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Avg2015\dumps|*.*
FileKey26=%WinDir%\SysWOW64\config\systemprofile\Local Settings\Application Data\dumps|*.*
FileKey27=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Avg2015\log|*.*
FileKey28=%WinDir%\SysWOW64\config\systemprofile\Local Settings\Application Data\log|*.*
FileKey29=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Avg2015\temp|*.*
FileKey30=%WinDir%\SysWOW64\config\systemprofile\Local Settings\Application Data\temp|*.*
FileKey31=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\MFAData\logs|*.*
FileKey32=%WinDir%\SysWOW64\config\systemprofile\Local Settings\MFAData\logs|*.*
Link to comment
Revised Entry
Changed the name from [McAfee AntiVirus More*] to [McAfee*]. It also works for other McAfee products.
Changed the LangSecRef from 3021 to 3024.
Corrected the Detect.
[McAfee*]
LangSecRef=3024
Detect=HKLM\Software\McAfee
Default=False
FileKey1=%CommonAppData%\McAfee\MCLOGS|*.*|RECURSE
FileKey2=%CommonAppData%\McAfee\MPF\data|*.*|RECURSE
FileKey3=%CommonAppData%\McAfee\MSC\Logs|*.*|RECURSE
FileKey4=%CommonAppData%\McAfee\VirusScan\Data|*.log;*.old
FileKey5=%CommonAppData%\McAfee\VirusScan\Logs|*.*|RECURSE
FileKey6=%LocalAppData%\VirtualStore\ProgramData\McAfee\MCLOGS|*.*|RECURSE
FileKey7=%LocalAppData%\VirtualStore\ProgramData\McAfee\MPF\data|*.*|RECURSE
FileKey8=%LocalAppData%\VirtualStore\ProgramData\McAfee\MSC\Logs|*.*|RECURSE
FileKey9=%LocalAppData%\VirtualStore\ProgramData\McAfee\VirusScan\Data|*.log;*.old
FileKey10=%LocalAppData%\VirtualStore\ProgramData\McAfee\VirusScan\Logs|*.*|RECURSE
Edited by SMalik
Link to comment
@dvdband: Those entries are different, but it would be a good idea to just combine them.
different but the entry [Firefox Logs*] will delete all *.log file inside Mozilla folder recursely which include subfolder too
why need another entry when [Firefox Logs*] already delete it?
correct me if i'm wrong
Link to comment
I reported an issue that CCleaner was wiping out Adblock Plus settings. Please look at the link below.
http://forum.piriform.com/index.php?showtopic=42263&hl=
Actually, two entries in Winaap2.ini were causing the issue. I have fixed the entries.
Revised Entries
Excluded .idb, CURRENT and LOG from this entry. Changed REMOVESELF to RECURSE
[Chrome HTML5 Storage*]
LangSecRef=3029
SpecialDetect=DET_CHROME
DetectFile1=%LocalAppData%\Chromium
DetectFile2=%LocalAppData%\Google\Chrome
DetectFile3=%LocalAppData%\Google\Chrome SxS
DetectFile4=%ProgramFiles%\Google\Chrome
DetectFile5=%ProgramFiles%\Google\Chrome SxS
DetectFile6=%LocalAppData%\Torch
DetectFile7=%LocalAppData%\SuperBird
Default=False
FileKey1=%LocalAppData%\Chrome Plus\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSE
FileKey2=%LocalAppData%\Chromium\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSE
FileKey3=%LocalAppData%\Flock\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSE
FileKey4=%LocalAppData%\Google\Chrome\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSE
FileKey5=%LocalAppData%\Google\Chrome SxS\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSE
FileKey6=%LocalAppData%\Rockmelt\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSE
FileKey7=%LocalAppData%\SRWare Iron\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSE
FileKey8=%LocalAppData%\Torch\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSE
FileKey9=%LocalAppData%\SuperBird\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSE
Excluded .log files from %LocalAppData%\Google\Chrome\User Data\*\File System\ as it is already in the entry above. Removing .log files and not removing *MANIFEST* and *.old files from this location was also causing that issue.
[Logs*]
LangSecRef=3029
DetectFile1=%LocalAppData%\Torch
DetectFile2=%LocalAppData%\SuperBird
Default=False
FileKey1=%LocalAppData%\Chrome Plus\Application|debug.log
FileKey2=%LocalAppData%\Chrome Plus\User Data\*|*LOG.*;Log;*.log|RECURSE
FileKey3=%LocalAppData%\Chromium\Application|debug.log
FileKey4=%LocalAppData%\Chromium\User Data\*|*LOG.*;Log|RECURSE
FileKey5=%LocalAppData%\Flock\Application|debug.log
FileKey6=%LocalAppData%\Flock\User Data\*|*LOG.*;Log;*.log|RECURSE
FileKey7=%LocalAppData%\Google\Chrome\Application|debug.log
FileKey8=%LocalAppData%\Google\Chrome\User Data\*|*LOG.*;Log;*.log|RECURSE
FileKey9=%LocalAppData%\Google\Chrome SxS\Application|debug.log
FileKey10=%LocalAppData%\Google\Chrome SxS\User Data\*|*LOG.*;Log;*.log|RECURSE
FileKey16=%LocalAppData%\Rockmelt\Application|debug.log
FileKey17=%LocalAppData%\Rockmelt\User Data\*|*LOG.*;Log;*.log|RECURSE
FileKey19=%LocalAppData%\SRWare Iron\Application|debug.log
FileKey20=%LocalAppData%\SRWare Iron\User Data\*|*LOG.*;Log;*.log|RECURSE
FileKey21=%LocalAppData%\Torch\Application|debug.log
FileKey22=%LocalAppData%\Torch\User Data\*|*LOG.*;Log;*.log|RECURSE
FileKey23=%LocalAppData%\SuperBird\Application|debug.log
FileKey24=%LocalAppData%\SuperBird\User Data\*|*LOG.*;Log;*.log|RECURSE
FileKey25=%LocalAppData%\VirtualStore\Program Files*\Google\Chrome\Application|debug.log
ExcludeKey1=PATH|%LocalAppData%\Google\Chrome\User Data\*\File System|*.log
ExcludeKey2=PATH|%LocalAppData%\Google\Chrome\User Data\*\Local Extension Settings\|*.*
ExcludeKey3=PATH|%LocalAppData%\Google\Chrome\User Data\*\Local App Settings\|*.*
ExcludeKey4=PATH|%LocalAppData%\Chrome Plus\User Data\*\Local Extension Settings\|*.*
ExcludeKey5=PATH|%LocalAppData%\Chrome Plus\User Data\*\Local App Settings\|*.*
ExcludeKey6=PATH|%LocalAppData%\Chromium\User Data\*\Local Extension Settings\|*.*
ExcludeKey7=PATH|%LocalAppData%\Chromium\User Data\*\Local App Settings\|*.*
ExcludeKey8=PATH|%LocalAppData%\Flock\User Data\*\Local Extension Settings\|*.*
ExcludeKey9=PATH|%LocalAppData%\Flock\User Data\*\Local App Settings\|*.*
ExcludeKey10=PATH|%LocalAppData%\Google\Chrome SxS\User Data\*\Local Extension Settings\|*.*
ExcludeKey11=PATH|%LocalAppData%\Google\Chrome SxS\User Data\*\Local App Settings\|*.*
ExcludeKey12=PATH|%LocalAppData%\Rockmelt\User Data\*\Local Extension Settings\|*.*
ExcludeKey13=PATH|%LocalAppData%\Rockmelt\User Data\*\Local App Settings\|*.*
ExcludeKey14=PATH|%LocalAppData%\SRWare Iron\User Data\*\Local Extension Settings\|*.*
ExcludeKey15=PATH|%LocalAppData%\SRWare Iron\User Data\*\Local App Settings\|*.*
ExcludeKey16=PATH|%LocalAppData%\Torch\User Data\*\Local Extension Settings\|*.*
ExcludeKey17=PATH|%LocalAppData%\Torch\User Data\*\Local App Settings\|*.*
ExcludeKey18=PATH|%LocalAppData%\Superbird\User Data\*\Local Extension Settings\|*.*
ExcludeKey19=PATH|%LocalAppData%\Superbird\User Data\*\Local App Settings\|*.*
Link to comment
In addition to dvdbane, this entry can also be removed:
[Firefox Console Log*]
LangSecRef=3026
FileKey1=%AppData%\Mozilla\Firefox|console.log
Already included in Firefox Logs entry.
Link to comment
Register a new account
Sign in
Important Information
