CSGalloway Posted November 28, 2014 Share Posted November 28, 2014 I have JDownloader2 installed in C:\My Programs\JDownloader v2.0\ - I do however have the HKLM\... key. would it be possible to add the C:\My Programs\JDownloader v2.0 as additional filekeys to all the JDownloader2 entries? Or what is the best way to do it? I have it installed there instead of %ProgramFiles% sicne it does modify the contents of the folder..... Link to comment Share on other sites More sharing options...
Moderators Andavari Posted November 29, 2014 Moderators Share Posted November 29, 2014 C:\My Programs\JDownloader v2.0 as additional filekeys to all the JDownloader2 entries? You could try, but sometimes CCleaner won't allow full paths via winapp2.ini entries, it if doesn't allow it a workable alternative is to make an Include in 'Options->Include'. Link to comment Share on other sites More sharing options...
CSGalloway Posted November 29, 2014 Share Posted November 29, 2014 [JDownloader2 Logs*]LangSecRef=3022Detect=HKLM\SOFTWARE\Classes\JDownloader2DetectFile=%ProgramFiles%\JDownloader 2\Default=FalseFileKey1=%ProgramFiles%\JDownloader*2*|JDownloader.log;Updater_*-*-*.log;SessionInstallLog.json.*|RECURSEFileKey2=%ProgramFiles%\JDownloader*2*\logs|*.*|RECURSEFileKey3=%LocalAppData%\VirtualStore\Program Files*\JDownloader*2*|JDownloader.log;Updater_*-*-*.log;SessionInstallLog.json.*FileKey4=%LocalAppData%\VirtualStore\Program Files*\JDownloader*2*\logs|*.*|RECURSEFileKey5=C:\My Programs\JDownloader*2*|JDownloader.log;Updater_*-*-*.log;SessionInstallLog.json.*|RECURSEFileKey6=C:\My Programs\JDownloader*2*\logs|*.*|RECURSE : added FileKey5 and 6 [JDownloader2 Temps*]LangSecRef=3022Detect=HKLM\SOFTWARE\Classes\JDownloader2DetectFile=%ProgramFiles%\JDownloader 2\Default=FalseFileKey1=%ProgramFiles%\JDownloader*2*\tmp|*.*|RECURSEFileKey2=%ProgramFiles%\JDownloader*2*\captchas|*.*|RECURSEFileKey3=%LocalAppData%\VirtualStore\Program Files*\JDownloader*2*\tmp|*.*|RECURSEFileKey4=%LocalAppData%\VirtualStore\Program Files*\JDownloader*2*\captchas|*.*|RECURSEFileKey5=%ProgramFiles%\JDownloader*2*\cfg|CaptchaDialogDimensions_*.jsonFileKey6=%LocalAppData%\VirtualStore\Program Files*\JDownloader*2*\cfg|CaptchaDialogDimensions_*.jsonFileKey7=C:\My Programs\JDownloader*2*\captchas|*.*|RECURSEFileKey8=C:\My Programs\JDownloader*2*\cfg|CaptchaDialogDimensions_*.jsonFileKey9=C:\My Programs\JDownloader*2*\tmp|*.*|RECURSEExcludeKey1=%ProgramFiles%\JDownloader*2*\cfg\subconf_*.ejsExcludeKey2=%LocalAppData%\VirtualStore\Program Files*\JDownloader*2*\cfg\subconf_*.ejsExcludeKey3=C:\My Programs\JDownloader*2*\cfg\subconf_*.ejs : added FileKeys 7-9 and ExcludeKey3 Link to comment Share on other sites More sharing options...
dvdbane Posted November 29, 2014 Share Posted November 29, 2014 [JDownloader2 Logs*] : added FileKey5 and 6 [JDownloader2 Temps*] : added FileKeys 7-9 and ExcludeKey3 i think you should keep the changes to yourself only this is personal changes, not changes that would benefit anyone except yourself Link to comment Share on other sites More sharing options...
back_track Posted November 29, 2014 Share Posted November 29, 2014 You could try, but sometimes CCleaner won't allow full paths via winapp2.ini entries, it if doesn't allow it a workable alternative is to make an Include in 'Options->Include'. or use mklink to programfiles... http://technet.microsoft.com/de-de/library/cc753194%28v=ws.10%29.aspx Link to comment Share on other sites More sharing options...
SMalik Posted November 30, 2014 Share Posted November 30, 2014 New Entry It removes the traces of the Apps (not the metro apps, just regular softwares) that use the .NET Framework. It populates as programs continue to use .NET Framework. [.NET Framework SQM*] LangSecRef=3025 Detect=HKLM\Software\Microsoft\.NETFramework Default=False RegKey1=HKCU\Software\Microsoft\.NETFramework\SQM\Apps Link to comment Share on other sites More sharing options...
SMalik Posted November 30, 2014 Share Posted November 30, 2014 I think the name of both entries should be changed back to Adblock Plus. Same names are fine as they both are under two different LangSecRef. [Adblock Plus for Firefox Backups*] LangSecRef=3026 SpecialDetect=DET_MOZILLA Default=False FileKey1=%AppData%\Mozilla\Firefox\Profiles\*\adblockplus|patterns-backup*.ini;*.tmp [Adblock Plus for IE Backups*] LangSecRef=3022 Detect=HKLM\Software\Adblock Plus for IE DetectFile=%LocalAppData%\Adblock Plus for IE Default=False FileKey1=%LocalAppData%\Adblock Plus for IE|patterns-backup*.ini FileKey2=%LocalLowAppData%\Adblock Plus for IE|patterns-backup*.ini FileKey3=%WinDir%\System32\config\systemprofile\AppData\LocalLow\Adblock Plus for IE|patterns-backup*.ini Link to comment Share on other sites More sharing options...
SMalik Posted November 30, 2014 Share Posted November 30, 2014 Like I said before, these two entries should be removed from Winapp2.ini. ContextMenuHandlers and Run entries don't come under privacy/junk. [NVIDIA (Play On My TV)*] LangSecRef=3023 Detect=HKLM\Software\NVIDIA Corporation Default=False Warning=If you output to multiple displays such as an HDTV or another monitor don't enable this! RegKey1=HKCR\AVIFile\shellex\ContextMenuHandlers\NvPlayOnMyTV RegKey2=HKCR\AVIFile\shellex\ContextMenuHandlers\PlayOnMyTV RegKey3=HKCR\mpegfile\shellex\ContextMenuHandlers\NvPlayOnMyTV RegKey4=HKCR\mpegfile\shellex\ContextMenuHandlers\PlayOnMyTV RegKey5=HKCR\WMVFile\shellex\ContextMenuHandlers\NvPlayOnMyTV RegKey6=HKCR\WMVFile\shellex\ContextMenuHandlers\PlayOnMyTV RegKey7=HKLM\Software\Classes\AVIFile\shellex\ContextMenuHandlers\NvPlayOnMyTV RegKey8=HKLM\Software\Classes\AVIFile\shellex\ContextMenuHandlers\PlayOnMyTV RegKey9=HKLM\Software\Classes\mpegfile\shellex\ContextMenuHandlers\NvPlayOnMyTV RegKey10=HKLM\Software\Classes\mpegfile\shellex\ContextMenuHandlers\PlayOnMyTV RegKey11=HKLM\Software\Classes\WMVFile\shellex\ContextMenuHandlers\NvPlayOnMyTV RegKey12=HKLM\Software\Classes\WMVFile\shellex\ContextMenuHandlers\PlayOnMyTV [NVIDIA (Startup)*] LangSecRef=3023 Detect=HKLM\Software\NVIDIA Corporation Default=False RegKey1=HKLM\Software\Microsoft\Windows\CurrentVersion\Run|NvMediaCenter Link to comment Share on other sites More sharing options...
SMalik Posted November 30, 2014 Share Posted November 30, 2014 I'm using iTunes to sync my iPhone for the last 4/5 years and never saw this path in iTunes: %CommonAppData%\Apple Computer\iTunes\iPhone Temporary Files [iPhone Temporary Files*] LangSecRef=3023 Detect=HKLM\Software\Apple Computer, Inc.\iTunes Default=False FileKey1=%CommonAppData%\Apple Computer\iTunes\iPhone Temporary Files|*.*|RECURSE FileKey2=%LocalAppData%\VirtualStore\ProgramData\Apple Computer\iTunes\iPhone Temporary Files|*.*|RECURSE Link to comment Share on other sites More sharing options...
APMichael Posted November 30, 2014 Share Posted November 30, 2014 I think the name of both entries should be changed back to Adblock Plus. Same names are fine as they both are under two different LangSecRef. This will not work, because CC uses the names only (in registry or config file). You cannot use both entries together. Link to comment Share on other sites More sharing options...
siliconman01 Posted December 1, 2014 Share Posted December 1, 2014 [NVIDIA (Startup)*] LangSecRef=3023 Detect=HKLM\Software\NVIDIA Corporation Default=False RegKey1=HKLM\Software\Microsoft\Windows\CurrentVersion\Run|NvMediaCenter You may wish to add a warning message for those people who want the NvMediaCenter running so they can quickly change nVidia settings Warning=If you want the nVidia Media Center to start automatically on system startup, DO NOT check mark this cleaning element. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
SMalik Posted December 2, 2014 Share Posted December 2, 2014 You may wish to add a warning message for those people who want the NvMediaCenter running so they can quickly change nVidia settings Warning=If you want the nVidia Media Center to start automatically on system startup, DO NOT check mark this cleaning element. Really bad idea. As I recall, CCleaner is a program to remove junk and secure privacy. ContextMenuHandlers and Run entries don't come under that criteria. Let's make an entry with a WARNING to remove everything from the OS. Link to comment Share on other sites More sharing options...
CSGalloway Posted December 2, 2014 Share Posted December 2, 2014 or use mklink to programfiles... http://technet.microsoft.com/de-de/library/cc753194%28v=ws.10%29.aspx mklink /d \My Programs\JDownloader v2\ %ProgramFiles%\JDownloader v2\ Is what I would need? Link to comment Share on other sites More sharing options...
SMalik Posted December 2, 2014 Share Posted December 2, 2014 Revised Entry Added FileKey2 [Ashampoo Snap 7*] LangSecRef=3024 Detect=HKCU\Software\Ashampoo\Ashampoo Snap 7 Default=False FileKey1=%LocalAppData%\CrashRpt\UnsentCrashReports|*.*|RECURSE FileKey2=%ProgramFiles%\Ashampoo\Ashampoo Snap 7|_NLogMsg.txt Link to comment Share on other sites More sharing options...
SMalik Posted December 2, 2014 Share Posted December 2, 2014 I think we should remove these because they are a little too old. Keep Ashampoo Burning Studio 12, 14 and 15. The version 12 was released in 2012. [Ashampoo Burning Studio 07*] LangSecRef=3021 Detect=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2007 Default=False FileKey1=%AppData%\Ashampoo\Ashampoo Burning Studio 2007\Logs|*.* RegKey1=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2007\Burn Image Project\AddDialog RegKey2=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2007\Data Disc Project\AddDialog RegKey3=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2007\Dump Image Project\DumpImage RegKey4=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2007\Unknown Project\AddDialog [Ashampoo Burning Studio 09*] LangSecRef=3024 Detect=HKLM\Software\Ashampoo\Ashampoo Burning Studio 2009 Default=False FileKey1=%AppData%\Ashampoo\Ashampoo Burning Studio 2009|backupmetainfo.xml FileKey2=%AppData%\Ashampoo\Ashampoo Burning Studio 2009\Logs|*.xml FileKey3=%AppData%\Ashampoo\Logs|*.txt [Ashampoo Burning Studio 5*] LangSecRef=3021 Detect=HKCU\Software\Ashampoo\Ashampoo Burning Studio 5 Default=False RegKey1=HKCU\Software\Ashampoo\Ashampoo Burning Studio 5\Burn Image Project\SelectImage RegKey2=HKCU\Software\Ashampoo\Ashampoo Burning Studio 5\Data Disc Project\AddDialog RegKey3=HKCU\Software\Ashampoo\Ashampoo Burning Studio 5\Data Disc Project\DumpImage RegKey4=HKCU\Software\Ashampoo\Ashampoo Burning Studio 5\Unknown Project\AddDialog [Ashampoo Burning Studio 6 Free (Logs)*] LangSecRef=3023 Detect=HKCU\Software\Ashampoo\Ashampoo Burning Studio 6 Default=False FileKey1=%AppData%\Ashampoo\Ashampoo Burning Studio 6 Free\Logs|*.* [Ashampoo Burning Studio 6*] LangSecRef=3021 Detect=HKCU\Software\Ashampoo\Ashampoo Burning Studio 6 Default=False RegKey1=HKCU\Software\Ashampoo\Ashampoo Burning Studio 6\Burn Image Project\SelectImage RegKey2=HKCU\Software\Ashampoo\Ashampoo Burning Studio 6\Data Disc Project\AddDialog RegKey3=HKCU\Software\Ashampoo\Ashampoo Burning Studio 6\Unknown Project\AddDialog [Ashampoo Burning Studio 7*] LangSecRef=3021 Detect=HKCU\Software\Ashampoo\Ashampoo Burning Studio 7 Default=False RegKey1=HKCU\Software\Ashampoo\Ashampoo Burning Studio 7\Burn Image Project\SelectImage RegKey2=HKCU\Software\Ashampoo\Ashampoo Burning Studio 7\Data Disc Project\AddDialog RegKey3=HKCU\Software\Ashampoo\Ashampoo Burning Studio 7\Unknown Project\AddDialog [Ashampoo Burning Studio 8*] LangSecRef=3021 Detect=HKCU\Software\Ashampoo\Ashampoo Burning Studio 8 Default=False RegKey1=HKCU\Software\Ashampoo\Ashampoo Burning Studio 8\Data Disc Project\AddDialog Link to comment Share on other sites More sharing options...
JDPower Posted December 2, 2014 Share Posted December 2, 2014 I think we should remove these because they are a little too old People still use old software ya know Link to comment Share on other sites More sharing options...
SMalik Posted December 3, 2014 Share Posted December 3, 2014 People still use old software ya know I understand, but that old. Some of these were released in 2006 and 2007. Link to comment Share on other sites More sharing options...
JDPower Posted December 3, 2014 Share Posted December 3, 2014 I understand, but that old. Some of these were released in 2006 and 2007. I still used one of those ancient Ashampoo burners till quite recently on my old laptop as every subsequent release was bloated to hell, but the old one was small, ultra simple and quick I totally get your point, but people have lots of reasons for sticking with older software, especially with utility type softwares that don't necessarily gain anything from updates, and it's not doing any harm leaving the entries in (IMO) Link to comment Share on other sites More sharing options...
SMalik Posted December 3, 2014 Share Posted December 3, 2014 Revised Entry Changed the entry name from [MalwareBytes Anti Malware More*] to [Malwarebytes Anti-Malware*] Changed the Detect to DetectFile [Malwarebytes Anti-Malware*] LangSecRef=3024 DetectFile=%ProgramFiles%\Malwarebytes Anti-Malware\mbam.exe Default=False FileKey1=%AppData%\Malwarebytes\Malwarebytes' Anti-Malware\Logs|*.* FileKey2=%CommonAppData%\Malwarebytes\Malwarebytes*Anti-Malware\Logs|*.* FileKey3=%CommonAppData%\Malwarebytes\Malwarebytes' Anti-Malware|mbam-setup.exe FileKey4=%LocalAppData%\VirtualStore\ProgramData\Malwarebytes\Malwarebytes*Anti-Malware\Logs|*.* FileKey5=%LocalAppData%\VirtualStore\ProgramData\Malwarebytes\Malwarebytes' Anti-Malware|mbam-setup.exe Link to comment Share on other sites More sharing options...
Moderators Andavari Posted December 3, 2014 Moderators Share Posted December 3, 2014 I understand, but that old. Some of these were released in 2006 and 2007. Some software is abandoned ("abandonware"), so the newest/oldest version is the only version available anymore. Link to comment Share on other sites More sharing options...
siliconman01 Posted December 4, 2014 Share Posted December 4, 2014 Modified Entry: [Dropbox*] Added new FileKey3=%AppData%\Dropbox\logs|*.*|RECURSE [Dropbox*] LangSecRef=3024 Detect=HKCU\Software\Dropbox Default=False FileKey1=%AppData%\DropBox|Filecache.db;SigStore.db FileKey2=%AppData%\DropBox\Bin|*.log FileKey3=%AppData%\Dropbox\logs|*.*|RECURSE FileKey4=%AppData%\Dropbox\Cache|*.*|RECURSE Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
SMalik Posted December 6, 2014 Share Posted December 6, 2014 Revised Entry Added: %CommonAppData%\Aimersoft\ProductFeatures\LocalLogs|*.*|RECURSE %CommonAppData%\Aimersoft\ProductFeatures\RemoteLogs|*.*|RECURSE [Aimersoft Video Converter Ultimate More*] LangSecRef=3023 Detect=HKLM\Software\Aimersoft\Aimersoft Video Converter Ultimate Default=False FileKey1=%ProgramFiles%\Aimersoft\Video Converter Ultimate\TempThumbDir|*.*|RECURSE FileKey2=%CommonAppData%\Aimersoft\ProductFeatures\LocalLogs|*.*|RECURSE FileKey3=%CommonAppData%\Aimersoft\ProductFeatures\RemoteLogs|*.*|RECURSE FileKey4=%LocalAppData%\VirtualStore\Program Files*\Aimersoft\Video Converter Ultimate\TempThumbDir|*.*|RECURSE Link to comment Share on other sites More sharing options...
SMalik Posted December 7, 2014 Share Posted December 7, 2014 The paths in the entry belong to PowerDirector. I think we should merge this into PowerDirector and remove this entry. http://www.cyberlink.com/support/product-faq-content.do?id=13709&prodId=4 [CyberLink Crash Dumps*] LangSecRef=3023 Detect=HKCU\Software\CyberLink Default=False FileKey1=%CommonAppData%\CyberLink\Boomerang\*\|*.xml;*.dmp FileKey2=%LocalAppData%\VirtualStore\ProgramData\CyberLink\Boomerang\*\|*.xml;*.dmp Revised Entries [CyberLink PowerDirector 10*] LangSecRef=3023 Detect=HKCU\Software\CyberLink\PowerDirector10 Default=False FileKey1=%CommonAppData%\CyberLink\Boomerang\*\|*.xml;*.dmp FileKey2=%LocalAppData%\VirtualStore\ProgramData\CyberLink\Boomerang\*\|*.xml;*.dmp FileKey3=%Documents%\CyberLink\PowerDirector\10.0|Snapshot(*).jpg FileKey4=%Documents%\CyberLink\PowerDirector\10.0\MyTitles|*.*|RECURSE FileKey5=%Documents%\CyberLink\PowerDirector\10.0\Preview Cache Files|*.* FileKey6=%Documents%\CyberLink\PowerDirector\10.0\ShadowEditFiles|*.MPG FileKey7=%Documents%\CyberLink\PowerDirector\10.0\SplitterIndex|*.maidx [CyberLink PowerDirector 11*] LangSecRef=3023 Detect=HKCU\Software\CyberLink\PowerDirector11 Default=False FileKey1=%CommonAppData%\CyberLink\Boomerang\*\|*.xml;*.dmp FileKey2=%LocalAppData%\VirtualStore\ProgramData\CyberLink\Boomerang\*\|*.xml;*.dmp FileKey3=%Documents%\CyberLink\PowerDirector\11.0|Snapshot(*).jpg FileKey4=%Documents%\CyberLink\PowerDirector\11.0\MyTitles|*.*|RECURSE FileKey5=%Documents%\CyberLink\PowerDirector\11.0\Preview Cache Files|*.* FileKey6=%Documents%\CyberLink\PowerDirector\11.0\ShadowEditFiles|*.MPG FileKey7=%Documents%\CyberLink\PowerDirector\11.0\SplitterIndex|*.maidx New Entries [CyberLink PowerDirector 12*] LangSecRef=3023 Detect=HKCU\Software\CyberLink\PowerDirector12 Default=False FileKey1=%CommonAppData%\CyberLink\Boomerang\*\|*.xml;*.dmp FileKey2=%LocalAppData%\VirtualStore\ProgramData\CyberLink\Boomerang\*\|*.xml;*.dmp FileKey3=%Documents%\CyberLink\PowerDirector\12.0|Snapshot(*).jpg FileKey4=%Documents%\CyberLink\PowerDirector\12.0\MyTitles|*.*|RECURSE FileKey5=%Documents%\CyberLink\PowerDirector\12.0\Preview Cache Files|*.* FileKey6=%Documents%\CyberLink\PowerDirector\12.0\ShadowEditFiles|*.MPG FileKey7=%Documents%\CyberLink\PowerDirector\12.0\SplitterIndex|*.maidx [CyberLink PowerDirector 13*] LangSecRef=3023 Detect=HKCU\Software\CyberLink\PowerDirector13 Default=False FileKey1=%CommonAppData%\CyberLink\Boomerang\*\|*.xml;*.dmp FileKey2=%LocalAppData%\VirtualStore\ProgramData\CyberLink\Boomerang\*\|*.xml;*.dmp FileKey3=%Documents%\CyberLink\PowerDirector\13.0|Snapshot(*).jpg FileKey4=%Documents%\CyberLink\PowerDirector\13.0\MyTitles|*.*|RECURSE FileKey5=%Documents%\CyberLink\PowerDirector\13.0\Preview Cache Files|*.* FileKey6=%Documents%\CyberLink\PowerDirector\13.0\ShadowEditFiles|*.MPG FileKey7=%Documents%\CyberLink\PowerDirector\13.0\SplitterIndex|*.maidx Link to comment Share on other sites More sharing options...
SMalik Posted December 7, 2014 Share Posted December 7, 2014 New Entry [CyberLink PhotoDirector 6*] LangSecRef=3023 Detect=HKLM\SOFTWARE\CyberLink\PhotoDirector6 Default=False FileKey1=%CommonAppData%\CyberLink\Downloader|*.* FileKey2=%Pictures%\PhotoDirector\6.0\*|*.*|RECURSE ExcludeKey1=FILE|%Pictures%\PhotoDirector\6.0\*|*.phd Link to comment Share on other sites More sharing options...
siliconman01 Posted December 7, 2014 Share Posted December 7, 2014 The paths in the entry belong to PowerDirector. I think we should merge this into PowerDirector and remove this entry. http://www.cyberlink...=13709&prodId=4 [CyberLink Crash Dumps*] LangSecRef=3023 Detect=HKCU\Software\CyberLink Default=False FileKey1=%CommonAppData%\CyberLink\Boomerang\*\|*.xml;*.dmp FileKey2=%LocalAppData%\VirtualStore\ProgramData\CyberLink\Boomerang\*\|*.xml;*.dmp Cyberlink PowerDVD also has a Boomerang folder at this same path. Although I cannot confirm this, I suspect that PowerDVD stores its dumps in this same path. PowerDVD installs/uses Cyberlink's Boomerang.exe as well. Therefore I suggest this code not be changed. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
