JDPower Posted October 1, 2014 Share Posted October 1, 2014 Found a problem, it's a minor one, and it probably possibly affects only a tiny portion of the users, but anyway. It's with ASUS ai suite 2, here's the entry: [ASUS AI Suite*] LangSecRef=3024 DetectFile=%ProgramFiles%\ASUS\AI Suite* Default=False FileKey1=%ProgramFiles%\ASUS\AI Suite*|*.log;*log*.*|RECURSE FileKey2=%LocalAppData%\VirtualStore\Program Files*\ASUS\AI Suite*|*.log;*log*.*|RECURSE FileKey3=%SystemDrive%|wifi.log Yeah, bit of a clumsy entry, needs the *log*.* part removing, as that is picking up all the logo files cos they have the word log in them Link to comment Share on other sites More sharing options...
onarum Posted October 1, 2014 Share Posted October 1, 2014 Yeah, bit of a clumsy entry, needs the *log*.* part removing, as that is picking up all the logo files cos they have the word log in them ooooohhh, I see, well that was easy , thanks man. Link to comment Share on other sites More sharing options...
JDPower Posted October 1, 2014 Share Posted October 1, 2014 ooooohhh, I see, well that was easy , thanks man. No probs, hopefully winapp can remove it when he updates the file Link to comment Share on other sites More sharing options...
back_track Posted October 1, 2014 Share Posted October 1, 2014 Note: lost entry http://forum.piriform.com/index.php?showtopic=32310&p=252930 zzzz Winapp2 but its chrashed the full entry for ccleaner but its better than to stay..... now it must work! [ASUS AI Suite*] LangSecRef=3024 DetectFile=%ProgramFiles%\ASUS\AI Suite* Default=False FileKey1=%ProgramFiles%\ASUS\AI Suite*|*.log|RECURSE FileKey2=%LocalAppData%\VirtualStore\Program Files*\ASUS\AI Suite*|*.log|RECURSE FileKey3=%SystemDrive%\wifi.log ___________________________ -new [Adobe Updater ARM*] LangSecRef=3021 Warning= The program update must finished and closed! Info: forums.adobe.com/message/5407850 Detect=HKCU\Software\Adobe Default=False FileKey1=%CommonAppData%\Adobe\ARM|*.*|RECURSE Link to comment Share on other sites More sharing options...
SMalik Posted October 3, 2014 Share Posted October 3, 2014 (edited) New Entries [Adobe Photoshop Elements 13*]LangSecRef=3021Detect=HKCU\Software\Adobe\Photoshop Elements\13.0Default=FalseRegKey1=HKCU\Software\Adobe\Elements Organizer\13.0\CurrentMediaFilePathRegKey2=HKCU\Software\Adobe\Photoshop Elements\13.0\common\settings\Elements MRURegKey3=HKCU\Software\Adobe\Photoshop Elements\13.0\CurrentMediaFilePathRegKey4=HKCU\Software\Adobe\Photoshop Elements\13.0\VisitedDirs|STARTUPIMAGEDIRECTORYFileKey1=%CommonAppData%\Adobe\Elements Organizer\Catalogs\My Catalog|face.thumb.9.cacheFileKey2=%CommonAppData%\Adobe\Elements Organizer\Catalogs\My Catalog|thumb.5.cacheFileKey3=%CommonAppData%\Adobe\Elements Organizer\Catalogs\My Catalog|WaldoData\waldo.cacheFileKey4=%CommonAppData%\Adobe\Photoshop Elements\File Agent|WatchFolder.3.cacheFileKey5=%AppData%\Adobe\Elements Organizer\13.0\Organizer|status.datFileKey6=%AppData%\Adobe\Elements Organizer\13.0\Organizer|*.txt[Adobe Premiere Elements 13*]LangSecRef=3021Detect=HKCU\Software\Adobe\Premiere Elements\13.0Default=FalseRegKey1=HKCU\Software\Adobe\Premiere Elements\13.0\MRUDocumentsFileKey1=%Documents%\Adobe\Premiere Elements\13.0|*.logFileKey2=%Documents%\NewBlueFX\Logs|*.txtFileKey3=%AppData%\Adobe\Common\Thumbnail Cache|*.*|RECURSE[Foxit PhantomPDF 7 More*]LangSecRef=3021Detect=HKCU\Software\Foxit Software\Foxit PhantomPDF 7.0Default=FalseFileKey1=%LocalAppData%\Foxit PhantomPDF\msilog|*.logFileKey2=%AppData%\Foxit Software\Foxit PhantomPDF\FormFiller|AutoComplete.dsFileKey3=%AppData%\Foxit Software\RMS|FXRMS_Log.txtRegKey1=HKCU\Software\Foxit Software\Foxit PhantomPDF 7.0\Preferences\HistoryRegKey2=HKCU\Software\Foxit Software\Foxit PhantomPDF 7.0\Recent File List Edited October 5, 2014 by SMalik Link to comment Share on other sites More sharing options...
CSGalloway Posted October 4, 2014 Share Posted October 4, 2014 When I installed JDownloader2 I accepted the defaults for the install path. The JDownloader2 entries have not been showing up. Can a Detect2 be added for: C:\Users\[username]\AppData\Local\JDownloader v2.0\ please? Also there is NO JDownloader* sub-folder in %LocalAppData%\VirtualStore\ Link to comment Share on other sites More sharing options...
back_track Posted October 4, 2014 Share Posted October 4, 2014 When I installed JDownloader2 I accepted the defaults for the install path. The JDownloader2 entries have not been showing up. Can a Detect2 be added for: C:\Users\[username]\AppData\Local\JDownloader v2.0\ please? Also there is NO JDownloader* sub-folder in %LocalAppData%\VirtualStore\ You only have an folder in VirtualStore when you use files from %ProgrammFiles% _________________________________________________ -new Information (German: http://crazy-crow.de/computer-internet/avira-antivirus-und-das-umfragefenster/004574/ ) [AntiVir Desktop IPM*] LangSecRef=3024 Detect=HKLM\Software\Avira\AntiVir Desktop Default=False FileKey1=%CommonAppData%\Avira\AntiVir Desktop\IPM|*.*|RECURSE FileKey2=%LocalAppData%\VirtualStore\ProgramData\Avira\AntiVir Desktop\IPM|*.*|RECURSE Link to comment Share on other sites More sharing options...
PlNG Posted October 7, 2014 Share Posted October 7, 2014 Update to Vuze More* rules: Adding Dasu plugin data for reports, or should it go under its own rule? The data generated by Dasu amounts to: 23Mb Data | 56Mb Disk in 13k files across 5 days of usage. This is somewhat excessive IMO, but clearing the data resets the report generation functionality of the plugin, the aggregated data about ISP interference (.torrent file and port blocking), Your BT usage, and Your DNS server(s) performance. I suppose if you're aware of winapp clearing it, you'll review it beforehand. The data will be regenerated by the plugin with your BT usage. [Vuze More*] LangSecRef=3022 Detect=HKCR\Azureus Default=False FileKey1=%AppData%\Azureus\plugins\advancedstatistics|*.txt FileKey2=%AppData%\Azureus\plugins\progressbar|*.txt FileKey3=%AppData%\Azureus\plugins\dasu\reports\*.* Warning=This will delete data from Advanced Statistics, Progressbar, and Dasu plugins. You should review the Dasu plugin reports before deleting it. Link to comment Share on other sites More sharing options...
siliconman01 Posted October 8, 2014 Share Posted October 8, 2014 Modified entry: [Western Digital SmartWare*] Added FileKey7 and FileKey8 [Western Digital SmartWare*] LangSecRef=3024 DetectFile=%CommonAppData%\Western Digital Default=False FileKey1=%AppData%\Western Digital\WD SmartWare\Logs|*.* FileKey2=%CommonAppData%\Western Digital\WDFME|*.* FileKey3=%CommonAppData%\Western Digital\WD SmartWare|*.log FileKey4=%LocalAppData%\Western Digital\WD SmartWare|*log.txt FileKey5=%LocalAppData%\VirtualStore\ProgramData\Western Digital\WDFME|*.* FileKey6=%LocalAppData%\VirtualStore\ProgramData\Western Digital\WD SmartWare|*.log FileKey7=%CommonAppData%\Western Digital\Logs\WD SmartWare\*\|*.log FileKey8=%CommonAppData%\Western Digital\Logs\WD QuickView\*\|*.log Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
Coffee4Joe Posted October 9, 2014 Share Posted October 9, 2014 (edited) New. anyone that uses onenote extensively want to test it? It shouldn't delete any notes because they all get synced to that magically cloud world. edited added RECURSE on FileKEy13 [OneNote*] LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Office.OneNote_8wekyb3d8bbwe DetectFile=%LocalAppData%\Packages\Microsoft.Office.OneNote_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.Office.OneNote_*\AC\Microsoft\CryptnetUrlCache\Content|*.* FileKey2=%LocalAppData%\Packages\Microsoft.Office.OneNote_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.* FileKey3=%LocalAppData%\Packages\Microsoft.Office.OneNote_*\AC\INetCache|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.Office.OneNote_*\AC\INetCookies|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.Office.OneNote_*\AC\INetHistory|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.Office.OneNote_*\AC\Temp|*.* FileKey7=%LocalAppData%\Packages\Microsoft.Office.OneNote_*\LocalState\AppData\Local|msodata*.dat FileKey8=%LocalAppData%\Packages\Microsoft.Office.OneNote_*\LocalState\AppData\Local\Office\OTele|*.* FileKey9=%LocalAppData%\Packages\Microsoft.Office.OneNote_*\LocalState\AppData\Local\Office\16.0\WebServiceCache\AllUsers\office15client.microsoft.com|*.* FileKey10=%LocalAppData%\Packages\Microsoft.Office.OneNote_*\LocalState\AppData\Local\OneNote\16.0\OneNoteOfflineCache_Files|*.* FileKey11=%LocalAppData%\Packages\Microsoft.Office.OneNote_*\LocalState\AppData\Local\OneNote\16.0\OneNotePagePreviewCache_Files|*.* FileKey12=%LocalAppData%\Packages\Microsoft.Office.OneNote_*\LocalState\AppData\Local\OneNote\16.0|*.onecache FileKey13=%LocalAppData%\Packages\Microsoft.Office.OneNote_*\TempState|*.*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Office.OneNote_8wekyb3d8bbwe\SearchHistory Edited October 18, 2014 by Coffee4Joe Link to comment Share on other sites More sharing options...
siliconman01 Posted October 9, 2014 Share Posted October 9, 2014 Modified Entry: [Quicken Logs*] Added FileKey7 [Quicken Logs*] LangSecRef=3021 Detect=HKLM\Software\Intuit\Quicken Default=False FileKey1=%AppData%\Intuit\Quicken\Log|*.txt;*.log FileKey2=%CommonAppData%\Intuit\Quicken\Log|*.log FileKey3=%CommonAppData%\Intuit\Quicken\Log\installer|*.*|REMOVESELF FileKey4=%CommonAppData%\Intuit\SendError|*.log FileKey5=%LocalAppData%\VirtualStore\ProgramData\Intuit\Quicken\Log|*.log FileKey6=%LocalAppData%\VirtualStore\ProgramData\Intuit\SendError|*.log FileKey7=%LocalAppData%\Intuit\Common\Authorization\V1\Logs\|*.txt Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
SMalik Posted October 12, 2014 Share Posted October 12, 2014 New Entry [Auslogics Registry Cleaner 4*]LangSecRef=3024Detect1=HKLM\Software\Auslogics\Registry Cleaner\4.xDetect2=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\4.xDefault=FalseWarning=This will remove your backups, and you will be unable to undo any changes you made with Auslogics Registry Cleaner.FileKey1=%CommonAppData%\Auslogics\Registry Cleaner\4.x\Rescue\Auslogics Registry Cleaner|*.*|RECURSEFileKey2=%LocalAppData%\VirtualStore\ProgramData\Auslogics\Registry Cleaner\4.x\Rescue\Auslogics Registry Cleaner|*.*|RECURSERegKey1=HKLM\Software\Auslogics\Registry Cleaner\4.x\Settings|RegCleaner.AppLogic.ErrorsFailedRegKey2=HKLM\Software\Auslogics\Registry Cleaner\4.x\Settings|RegCleaner.AppLogic.ErrorsFoundRegKey3=HKLM\Software\Auslogics\Registry Cleaner\4.x\Settings|RegCleaner.AppLogic.ErrorsRemovedRegKey4=HKLM\Software\Auslogics\Registry Cleaner\4.x\Settings|RegCleaner.AppLogic.ErrorsRemovedTotalRegKey5=HKLM\Software\Auslogics\Registry Cleaner\4.x\Settings|RegCleaner.AppLogic.LastScanRegKey6=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\4.x\Settings|RegCleaner.AppLogic.ErrorsFailedRegKey7=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\4.x\Settings|RegCleaner.AppLogic.ErrorsFoundRegKey8=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\4.x\Settings|RegCleaner.AppLogic.ErrorsRemovedRegKey9=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\4.x\Settings|RegCleaner.AppLogic.ErrorsRemovedTotalRegKey10=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\4.x\Settings|RegCleaner.AppLogic.LastScan Link to comment Share on other sites More sharing options...
SMalik Posted October 15, 2014 Share Posted October 15, 2014 New Entries [inpaint*]LangSecRef=3021Detect=HKCU\Software\Teorex\InpaintDefault=FalseRegKey1=HKCU\Software\Teorex\Inpaint\RecentFileList[MultiViewInpaint*]LangSecRef=3021Detect=HKCU\Software\Teorex\MultiViewInpaintDefault=FalseRegKey1=HKCU\Software\Teorex\MultiViewInpaint\RecentFileList[PhotoScissors*]LangSecRef=3021Detect=HKCU\Software\Teorex\PhotoScissorsDefault=FalseRegKey1=HKCU\Software\Teorex\PhotoScissors\RecentFileList Link to comment Share on other sites More sharing options...
JDPower Posted October 15, 2014 Share Posted October 15, 2014 New Entries [inpaint*] LangSecRef=3021 Detect=HKCU\Software\Teorex\Inpaint Default=False RegKey1=HKCU\Software\Teorex\Inpaint\RecentFileList I have a slightly different Inpaint entry that I must have added myself as it's not in the main file, so would suggest the following so that it still cleans previous versions [Inpaint*] LangSecRef=3021 Detect=HKCU\Software\Teorex\Inpaint Default=True RegKey1=HKCU\Software\Teorex\Inpaint\Recent File List RegKey2=HKCU\Software\Teorex\Inpaint\RecentFileList Link to comment Share on other sites More sharing options...
Winapp2.ini Posted October 16, 2014 Author Share Posted October 16, 2014 Thanks winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Coffee4Joe Posted October 18, 2014 Share Posted October 18, 2014 Edited FileKey13 on http://forum.piriform.com/index.php?showtopic=32310&page=228&do=findComment&comment=254497 Link to comment Share on other sites More sharing options...
ZeroByDivide Posted October 21, 2014 Share Posted October 21, 2014 new entry (dunno if it's actually new or not it's not in the winapp2.ini and I didn't find it through this thread) 7Star Browser - [7Star Browser - Cookies*] LangSecRef=3029 Detect=HKCU\Software\7Star Default=False FileKey1=%LocalAppData%\7Star\7Star\User Data\Default|Cookies;Cookies-journal [7Star Browser - Local Storage*] LangSecRef=3029 Detect=HKCU\Software\7Star Default=False FileKey1=%LocalAppData%\7Star\7Star\User Data\*\Local Storage|http*.*|RECURSE [7Star - GPU Cache*] LangSecRef=3029 Detect=HKCU\Software\7Star Default=False FileKey1=%LocalAppData%\7Star\7Star\User Data\Default\GPUCache|*.*|RECURSE [7Star Browser - Internet Cache*] LangSecRef=3029 Detect=HKCU\Software\7Star Default=False FileKey1=%LocalAppData%\7Star\7Star\User Data\Default\Cache|*.*|REMOVESELF FileKey2=%LocalAppData%\7Star\7Star\User Data\Default|Favicons;Favicons-journal [7Star Browser - Internet History*] LangSecRef=3029 Detect=HKCU\Software\7Star Default=False FileKey1=%LocalAppData%\7Star\7Star\User Data\*|Archived History;Archived History-journal;History;History Provider Cache;History-journal;Visited Links;Top Sites;Top Sites-journal FileKey2=%LocalAppData%\7Star\7Star\User Data\*\JumpListIcons*|*.*|RECURSE [7Star Browser - Login Data*] LangSecRef=3029 Detect=HKCU\Software\7Star Default=False FileKey1=%LocalAppData%\7Star\7Star\User Data\Default|Login Data;Login Data-journal [7Star Browser - Logs*] LangSecRef=3029 Detect=HKCU\Software\7Star Default=False FileKey1=%LocalAppData%\7Star\7Star\Application|debug.log FileKey2=%LocalAppData%\7Star\7Star\User Data\*\Extension State|LOG.*;*.log;Log FileKey3=%LocalAppData%\7Star\7Star\User Data\*\Session Storage|LOG.*;*.log;Log [7Star Browser - Session*] LangSecRef=3029 Detect=HKCU\Software\7Star Default=False FileKey1=%LocalAppData%\7Star\7Star\User Data\*|Current Tabs;Current session;Last Tabs;Last Session Link to comment Share on other sites More sharing options...
ROCKNROLL Posted October 22, 2014 Share Posted October 22, 2014 New entry: [Peerblock Failed Lists*]LangSecRef=3024DetectFile=%ProgramFiles%\PeerblockWarning: This will delete all lists that failed to load into your peerblockFileKey1=%ProgramFiles%\Peerblock\lists|*.list.failed* I am a maintainer for Winapp2. I also have a open-source group on Steam. http://steamcommunity.com/groups/opencommunity Link to comment Share on other sites More sharing options...
SMalik Posted October 23, 2014 Share Posted October 23, 2014 Revised Entry Changed the highlighted [NVIDIA GFExperience Logs*] LangSecRef=3023 Detect=HKLM\Software\NVIDIA Corporation Default=False FileKey1=%SystemDrive%\NvidiaLogging\GFExperience|GridClientLog.log*|RECURSE FileKey2=%CommonAppData%\NVIDIA Corporation\GeForce Experience\Logs|*.log FileKey3=%CommonAppData%\NVIDIA Corporation\ShadowPlay|*.log;*.bak;*.stat FileKey4=%LocalAppData%\NVIDIA Corporation\GFExperience|*.log FileKey5=%LocalAppData%\NVIDIA Corporation\ShadowPlay|*.log;*.bak FileKey6=%LocalAppData%\VirtualStore\ProgramData\NVIDIA Corporation\GeForce Experience\Logs|*.log FileKey7=%LocalAppData%\VirtualStore\ProgramData\NVIDIA Corporation\ShadowPlay|*.log;*.bak;*.stat Link to comment Share on other sites More sharing options...
ROCKNROLL Posted October 23, 2014 Share Posted October 23, 2014 Edit entry: [AMD/ATI*]LangSecRef=3024Detect1=HKLM\Software\AMDDetect2=HKLM\Software\ATIDetect3=HKLM\Software\ATI TechnologiesDetectFile=%ProgramFiles%\ATI Technologies\ATI.ACEFileKey1=%CommonAppData%\AMD\Fuel|*.txtFileKey2=%CommonAppData%\AMD\KDB|*.logFileKey3=%LocalAppData%\AMD\Fuel|ClientProxyLog*.*FileKey4=%LocalAppData%\AMD\GLCache|*.*|RECURSEFileKey5=%LocalAppData%\ATI\ACE|*.txtFileKey6=%ProgramFiles%\AMD\OverDrive|*.logFileKey7=%ProgramFiles%\AMD\amdkmpfd|*.*|REMOVESELFFileKey8=%ProgramFiles%\ATI\CIM\Reports|*.*FileKey9=%ProgramFiles%\ATI Technologies|*.log|RECURSEFileKey10=%ProgramFiles%\ATI Technologies|cccutil64.txtFileKey11=%SystemDrive%\ATI|*.*|REMOVESELFFileKey12=%SystemDrive%\AMD|*.*|REMOVESELFFileKey13=%WinDir%\System32|CCCInstall*.logFileKey14=%WinDir%\SysWOW64|CCCInstall*.logFileKey15=%LocalAppData%\VirtualStore\Program Files*\AMD\OverDrive|*.logFileKey16=%LocalAppData%\VirtualStore\Program Files*\AMD\amdkmpfd|*.*|REMOVESELFFileKey17=%LocalAppData%\VirtualStore\Program Files*\ATI\CIM\Reports|*.*FileKey18=%LocalAppData%\VirtualStore\Program Files*\ATI Technologies|*.log|RECURSEFileKey19=%LocalAppData%\VirtualStore\Program Files*\ATI Technologies|cccutil64.txtFileKey20=%LocalAppData%\VirtualStore\ProgramData\AMD\Fuel|*.txtFileKey21=%LocalAppData%\VirtualStore\ProgramData\AMD\KDB|*.log Added FileKey 4. I am a maintainer for Winapp2. I also have a open-source group on Steam. http://steamcommunity.com/groups/opencommunity Link to comment Share on other sites More sharing options...
back_track Posted October 23, 2014 Share Posted October 23, 2014 FileKey2=%CommonAppData%\NVIDIA Corporation\GeForce Experience\Logs|*.log Sure to delt the install logs, have you test it when you want to remove the geforce driver ? Link to comment Share on other sites More sharing options...
SMalik Posted October 24, 2014 Share Posted October 24, 2014 Sure to delt the install logs, have you test it when you want to remove the geforce driver ? I'll remove the driver to check it. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted October 26, 2014 Author Share Posted October 26, 2014 Updated - sorry about the delay, I was travelling for school What's new in winapp2.ini 4.19.141026General:21 New Entries17 Modified Entries00 Removed EntriesVerbose:------------------------------------------------------------------------------New Entries:[7Star Browser - Cookies*]LangSecRef=3029Detect=HKCU\Software\7StarDefault=FalseFileKey1=%LocalAppData%\7Star\7Star\User Data\Default|Cookies;Cookies-journal [7Star Browser - Local Storage*]LangSecRef=3029Detect=HKCU\Software\7StarDefault=FalseFileKey1=%LocalAppData%\7Star\7Star\User Data\*\Local Storage|http*.*|RECURSE [7Star - GPU Cache*]LangSecRef=3029Detect=HKCU\Software\7StarDefault=FalseFileKey1=%LocalAppData%\7Star\7Star\User Data\Default\GPUCache|*.*|RECURSE [7Star Browser - Internet Cache*]LangSecRef=3029Detect=HKCU\Software\7StarDefault=FalseFileKey1=%LocalAppData%\7Star\7Star\User Data\Default\Cache|*.*|REMOVESELFFileKey2=%LocalAppData%\7Star\7Star\User Data\Default|Favicons;Favicons-journal [7Star Browser - Internet History*]LangSecRef=3029Detect=HKCU\Software\7StarDefault=FalseFileKey1=%LocalAppData%\7Star\7Star\User Data\*|Archived History;Archived History-journal;History;History Provider Cache;History-journal;Visited Links;Top Sites;Top Sites-journalFileKey2=%LocalAppData%\7Star\7Star\User Data\*\JumpListIcons*|*.*|RECURSE [7Star Browser - Login Data*]LangSecRef=3029Detect=HKCU\Software\7StarDefault=FalseFileKey1=%LocalAppData%\7Star\7Star\User Data\Default|Login Data;Login Data-journal [7Star Browser - Logs*]LangSecRef=3029Detect=HKCU\Software\7StarDefault=FalseFileKey1=%LocalAppData%\7Star\7Star\Application|debug.logFileKey2=%LocalAppData%\7Star\7Star\User Data\*\Extension State|LOG.*;*.log;LogFileKey3=%LocalAppData%\7Star\7Star\User Data\*\Session Storage|LOG.*;*.log;Log [7Star Browser - Session*]LangSecRef=3029Detect=HKCU\Software\7StarDefault=FalseFileKey1=%LocalAppData%\7Star\7Star\User Data\*|Current Tabs;Current session;Last Tabs;Last Session[Adobe Photoshop Elements 13*]LangSecRef=3021Detect=HKCU\Software\Adobe\Photoshop Elements\13.0Default=FalseRegKey1=HKCU\Software\Adobe\Elements Organizer\13.0\CurrentMediaFilePathRegKey2=HKCU\Software\Adobe\Photoshop Elements\13.0\common\settings\Elements MRURegKey3=HKCU\Software\Adobe\Photoshop Elements\13.0\CurrentMediaFilePathRegKey4=HKCU\Software\Adobe\Photoshop Elements\13.0\VisitedDirs|STARTUPIMAGEDIRECTORYFileKey1=%CommonAppData%\Adobe\Elements Organizer\Catalogs\My Catalog|face.thumb.9.cacheFileKey2=%CommonAppData%\Adobe\Elements Organizer\Catalogs\My Catalog|thumb.5.cacheFileKey3=%CommonAppData%\Adobe\Elements Organizer\Catalogs\My Catalog|WaldoData\waldo.cacheFileKey4=%CommonAppData%\Adobe\Photoshop Elements\File Agent|WatchFolder.3.cacheFileKey5=%AppData%\Adobe\Elements Organizer\13.0\Organizer|status.datFileKey6=%AppData%\Adobe\Elements Organizer\13.0\Organizer|*.txt[Adobe Premiere Elements 13*]LangSecRef=3021Detect=HKCU\Software\Adobe\Premiere Elements\13.0Default=FalseRegKey1=HKCU\Software\Adobe\Premiere Elements\13.0\MRUDocumentsFileKey1=%Documents%\Adobe\Premiere Elements\13.0|*.logFileKey2=%Documents%\NewBlueFX\Logs|*.txtFileKey3=%AppData%\Adobe\Common\Thumbnail Cache|*.*|RECURSE[Adobe Updater ARM*]LangSecRef=3021Detect=HKCU\Software\AdobeDefault=FalseFileKey1=%CommonAppData%\Adobe\ARM|*.*|RECURSE[AntiVir Desktop IPM*]LangSecRef=3024Detect=HKLM\Software\Avira\AntiVir DesktopDefault=FalseFileKey1=%CommonAppData%\Avira\AntiVir Desktop\IPM|*.*|RECURSEFileKey2=%LocalAppData%\VirtualStore\ProgramData\Avira\AntiVir Desktop\IPM|*.*|RECURSE[Auslogics Registry Cleaner 4*]LangSecRef=3024Detect1=HKLM\Software\Auslogics\Registry Cleaner\4.xDetect2=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\4.xDefault=FalseWarning=This will remove your backups, and you will be unable to undo any changes you made with Auslogics Registry Cleaner.FileKey1=%CommonAppData%\Auslogics\Registry Cleaner\4.x\Rescue\Auslogics Registry Cleaner|*.*|RECURSEFileKey2=%LocalAppData%\VirtualStore\ProgramData\Auslogics\Registry Cleaner\4.x\Rescue\Auslogics Registry Cleaner|*.*|RECURSERegKey1=HKLM\Software\Auslogics\Registry Cleaner\4.x\Settings|RegCleaner.AppLogic.ErrorsFailedRegKey2=HKLM\Software\Auslogics\Registry Cleaner\4.x\Settings|RegCleaner.AppLogic.ErrorsFoundRegKey3=HKLM\Software\Auslogics\Registry Cleaner\4.x\Settings|RegCleaner.AppLogic.ErrorsRemovedRegKey4=HKLM\Software\Auslogics\Registry Cleaner\4.x\Settings|RegCleaner.AppLogic.ErrorsRemovedTotalRegKey5=HKLM\Software\Auslogics\Registry Cleaner\4.x\Settings|RegCleaner.AppLogic.LastScanRegKey6=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\4.x\Settings|RegCleaner.AppLogic.ErrorsFailedRegKey7=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\4.x\Settings|RegCleaner.AppLogic.ErrorsFoundRegKey8=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\4.x\Settings|RegCleaner.AppLogic.ErrorsRemovedRegKey9=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\4.x\Settings|RegCleaner.AppLogic.ErrorsRemovedTotalRegKey10=HKLM\Software\Wow6432Node\Auslogics\Registry Cleaner\4.x\Settings|RegCleaner.AppLogic.LastScan[Foxit PhantomPDF 7 More*]LangSecRef=3021Detect=HKCU\Software\Foxit Software\Foxit PhantomPDF 7.0Default=FalseFileKey1=%LocalAppData%\Foxit PhantomPDF\msilog|*.logFileKey2=%AppData%\Foxit Software\Foxit PhantomPDF\FormFiller|AutoComplete.dsFileKey3=%AppData%\Foxit Software\RMS|FXRMS_Log.txtRegKey1=HKCU\Software\Foxit Software\Foxit PhantomPDF 7.0\Preferences\HistoryRegKey2=HKCU\Software\Foxit Software\Foxit PhantomPDF 7.0\Recent File List[inpaint*]LangSecRef=3021Detect=HKCU\Software\Teorex\InpaintDefault=TrueRegKey1=HKCU\Software\Teorex\Inpaint\Recent File ListRegKey2=HKCU\Software\Teorex\Inpaint\RecentFileList[MassTube*]LangSecRef=3024DetectFile=%LocalAppData%\MassTube\MassTube.exeDetectFile2=%AppData%\MassTube\MassTube.exeDetectFile3=%ProgramFiles%\MassTube\MassTube.exeDetectFile4=%SystemDrive%\Programs\MassTube\MassTube.exeDefault=FalseFileKey1=%LocalAppData%\MassTube|Historial.datFileKey2=%AppData%\MassTube|Historial.datFileKey3=%ProgramFiles%\MassTube|Historial.datFileKey4=%SystemDrive%\Programs\MassTube|Historial.datFileKey5=%temp%\MassTubeCache|*.*|RECURSEFileKey6=%LocalAppData%\MassTube\Miniaturas|*.jpgFileKey7=%AppData%\MassTube\Miniaturas|*.jpgFileKey8=%ProgramFiles%\MassTube\Miniaturas|*.jpgFileKey9=%SystemDrive%\Programs\MassTube\Miniaturas|*.jpg[MultiViewInpaint*]LangSecRef=3021Detect=HKCU\Software\Teorex\MultiViewInpaintDefault=FalseRegKey1=HKCU\Software\Teorex\MultiViewInpaint\RecentFileListRegKey2=HKCU\Software\Teorex\MultiViewInpaint\Recent File List[OneNote*]LangSecRef=3031Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Office.OneNote_8wekyb3d8bbweDetectFile=%LocalAppData%\Packages\Microsoft.Office.OneNote_8wekyb3d8bbweDefault=FalseFileKey1=%LocalAppData%\Packages\Microsoft.Office.OneNote_*\AC\Microsoft\CryptnetUrlCache\Content|*.*FileKey2=%LocalAppData%\Packages\Microsoft.Office.OneNote_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.*FileKey3=%LocalAppData%\Packages\Microsoft.Office.OneNote_*\AC\INetCache|*.*|RECURSEFileKey4=%LocalAppData%\Packages\Microsoft.Office.OneNote_*\AC\INetCookies|*.*|RECURSEFileKey5=%LocalAppData%\Packages\Microsoft.Office.OneNote_*\AC\INetHistory|*.*|RECURSEFileKey6=%LocalAppData%\Packages\Microsoft.Office.OneNote_*\AC\Temp|*.*FileKey7=%LocalAppData%\Packages\Microsoft.Office.OneNote_*\LocalState\AppData\Local|msodata*.datFileKey8=%LocalAppData%\Packages\Microsoft.Office.OneNote_*\LocalState\AppData\Local\Office\OTele|*.*FileKey9=%LocalAppData%\Packages\Microsoft.Office.OneNote_*\LocalState\AppData\Local\Office\16.0\WebServiceCache\AllUsers\office15client.microsoft.com|*.*FileKey10=%LocalAppData%\Packages\Microsoft.Office.OneNote_*\LocalState\AppData\Local\OneNote\16.0\OneNoteOfflineCache_Files|*.*FileKey11=%LocalAppData%\Packages\Microsoft.Office.OneNote_*\LocalState\AppData\Local\OneNote\16.0\OneNotePagePreviewCache_Files|*.*FileKey12=%LocalAppData%\Packages\Microsoft.Office.OneNote_*\LocalState\AppData\Local\OneNote\16.0|*.onecacheFileKey13=%LocalAppData%\Packages\Microsoft.Office.OneNote_*\TempState|*.*|RECURSERegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Office.OneNote_8wekyb3d8bbwe\SearchHistory[Peerblock Failed Lists*]LangSecRef=3024DetectFile=%ProgramFiles%\PeerblockWarning=This will delete all lists that failed to load into your peerblockDefault=FalseFileKey1=%ProgramFiles%\Peerblock\lists|*.list.failed*[PhotoScissors*]LangSecRef=3021Detect=HKCU\Software\Teorex\PhotoScissorsDefault=FalseRegKey1=HKCU\Software\Teorex\PhotoScissors\RecentFileListRegKey2=HKCU\Software\Teorex\PhotoScissors\Recent File List[Vuze Dasu Reports*]LangSecRef=3022Warning=This will delete data from Dasu plugins. You should review the Dasu plugin reports before deleting it.Detect=HKCR\AzureusDefault=FalseFileKey1=%AppData%\Azureus\plugins\dasu\reports|*.*------------------------------------------------------------------------------Modified Entries:[Amazon MP3 Downloader Log*]LangSecRef=3023Detect1=HKCR\Amazon.AmazonMP3DownloaderPluginDetect2=HKCR\Software\Amazon\MP3 DownloaderDefault=FalseFileKey1=%Documents%\Amazon MP3\Logs|*.*|REMOVESELFFileKey2=%LocalAppData%\Program Files\Amazon\MP3 Downloader\|InstallerLog.txt - Added Detect2 and FileKey2[AMD/ATI*]LangSecRef=3024Detect1=HKLM\Software\AMDDetect2=HKLM\Software\ATIDetect3=HKLM\Software\ATI TechnologiesDetectFile=%ProgramFiles%\ATI Technologies\ATI.ACEFileKey1=%CommonAppData%\AMD\Fuel|*.txtFileKey2=%CommonAppData%\AMD\KDB|*.logFileKey3=%LocalAppData%\AMD\Fuel|ClientProxyLog*.*FileKey4=%LocalAppData%\AMD\GLCache|*.*|RECURSEFileKey5=%LocalAppData%\ATI\ACE|*.txtFileKey6=%ProgramFiles%\AMD\OverDrive|*.logFileKey7=%ProgramFiles%\AMD\amdkmpfd|*.*|REMOVESELFFileKey8=%ProgramFiles%\ATI\CIM\Reports|*.*FileKey9=%ProgramFiles%\ATI Technologies|*.log|RECURSEFileKey10=%ProgramFiles%\ATI Technologies|cccutil64.txtFileKey11=%SystemDrive%\ATI|*.*|REMOVESELFFileKey12=%SystemDrive%\AMD|*.*|REMOVESELFFileKey13=%WinDir%\System32|CCCInstall*.logFileKey14=%WinDir%\SysWOW64|CCCInstall*.logFileKey15=%LocalAppData%\VirtualStore\Program Files*\AMD\OverDrive|*.logFileKey16=%LocalAppData%\VirtualStore\Program Files*\AMD\amdkmpfd|*.*|REMOVESELFFileKey17=%LocalAppData%\VirtualStore\Program Files*\ATI\CIM\Reports|*.*FileKey18=%LocalAppData%\VirtualStore\Program Files*\ATI Technologies|*.log|RECURSEFileKey19=%LocalAppData%\VirtualStore\Program Files*\ATI Technologies|cccutil64.txtFileKey20=%LocalAppData%\VirtualStore\ProgramData\AMD\Fuel|*.txtFileKey21=%LocalAppData%\VirtualStore\ProgramData\AMD\KDB|*.log - Added FileKey4 [ASUS AI Suite*]LangSecRef=3024DetectFile=%ProgramFiles%\ASUS\AI Suite*Default=FalseFileKey1=%ProgramFiles%\ASUS\AI Suite*|*.log|RECURSEFileKey2=%LocalAppData%\VirtualStore\Program Files*\ASUS\AI Suite*|*.log|RECURSEFileKey3=%SystemDrive%|wifi.log - Tweaked FileKeys1 and 2 [AVG PC TuneUp & TuneUp Utilities Logs*]LangSecRef=3024Detect1=HKCU\Software\TuneUpDetect2=HKCU\Software\AVG\AWL\RegistryCleanerDefault=FalseFileKey1=%LocalAppData%\TuneUp Software|*.log|RECURSEFileKey2=%CommonAppData%\TuneUp Software\TuneUp Utilities *|*.log|RECURSEFileKey3=%LocalAppData%\Avg\Log\|*.log;zappapi.log.1|RECURSEFileKey4=%LocalAppData%\AvgSetupLog\|*.*|REMOVESELFFileKey5=%LocalAppData%\Avg\AWL*\Log\|*.log - Added FileKeys4 & 5 [AVG PC TuneUp & TuneUp Utilities Reg Defrag Cleanup*]LangSecRef=3024Detect1=HKCU\Software\TuneUp\Utilities\10.0Detect2=HKCU\Software\TuneUp\Utilities\12.0Detect3=HKCU\Software\TuneUp\Utilities\13.0Detect4=HKCU\Software\TuneUp\Utilities\14.0Detect5=HKCU\Software\AVG\AWL\RegistryCleanerDefault=FalseFileKey1=%LocalAppData%\Microsoft\Windows|USRCLASS.DAT_tureg_new.LOG*;USRCLASS.DAT_tureg_oldFileKey2=%SystemDrive%\Boot|BCD_tureg_new.LOG*;BCD_tureg_oldFileKey3=%SystemDrive%\Documents and Settings\LocalService|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_oldFileKey4=%SystemDrive%\Documents and Settings\LocalService.NT*|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_oldFileKey5=%SystemDrive%\Documents and Settings\NetworkService|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_oldFileKey6=%SystemDrive%\Documents and Settings\NetworkService.NT*|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_oldFileKey7=%UserProfile%|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_oldFileKey8=%WinDir%\ServiceProfiles\LocalService|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_oldFileKey9=%WinDir%\ServiceProfiles\NetworkService|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_oldFileKey10=%WinDir%\System32\config|COMPONENTS_tureg_new.LOG*;COMPONENTS_tureg_old;DEFAULT_tureg_new.LOG*;DEFAULT_tureg_old;SAM_tureg_new.LOG*;SAM_tureg_old;SECURITY_tureg_new.LOG*;SECURITY_tureg_old;SOFTWARE_tureg_new.LOG*;SOFTWARE_tureg_old;SYSTEM_tureg_new.LOG*;SYSTEM_tureg_old;DRIVERS_tureg_new.LOG*;DRIVERS_tureg_oldFileKey11=%WinDir%\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Windows\|USRCLASS.DAT_tureg_old;USRCLASS.DAT_tureg_new.LOG*FileKey12=%WinDir%\ServiceProfiles\LocalService\AppData\Local\Microsoft\Windows\|USRCLASS.DAT_tureg_old;USRCLASS.DAT_tureg_new.LOG* - Added FileKeys11 and 12[innoExtractor*]LangSecRef=3024DetectFile1=%LocalAppData%\InnoExtractor\InnoExtractor.exeDetectFile2=%AppData%\InnoExtractor\InnoExtractor.exeDetectFile3=%ProgramFiles%\InnoExtractor\InnoExtractor.exeDetectFile4=%SystemDrive%\Programs\InnoExtractor\InnoExtractor.exeDefault=FalseFileKey1=%LocalAppData%\InnoExtractor|Historial.datFileKey2=%AppData%\InnoExtractor|Historial.datFileKey3=%ProgramFiles%\InnoExtractor|Historial.datFileKey4=%SystemDrive%\Programs\InnoExtractor|Historial.datFileKey5=%temp%\InnoExtractorCache|*.*|RECURSE - Added DetectFiles3 and 4 [JDownloader2 Logs*]LangSecRef=3022Detect=HKLM\SOFTWARE\Classes\JDownloader2DetectFile=%ProgramFiles%\JDownloader 2\Default=FalseFileKey1=%ProgramFiles%\JDownloader*2*|JDownloader.log;Updater_*-*-*.log;SessionInstallLog.json.*|RECURSEFileKey2=%ProgramFiles%\JDownloader*2*\logs|*.*|RECURSEFileKey3=%LocalAppData%\VirtualStore\Program Files*\JDownloader*2*|JDownloader.log;Updater_*-*-*.log;SessionInstallLog.json.*FileKey4=%LocalAppData%\VirtualStore\Program Files*\JDownloader*2*\logs|*.*|RECURSE - Tweaked FileKeys[JDownloader2 Temps*]LangSecRef=3022Detect=HKLM\SOFTWARE\Classes\JDownloader2DetectFile=%ProgramFiles%\JDownloader 2\Default=FalseFileKey1=%ProgramFiles%\JDownloader*2*\tmp|*.*|RECURSEFileKey2=%ProgramFiles%\JDownloader*2*\captchas|*.*|RECURSEFileKey3=%LocalAppData%\VirtualStore\Program Files*\JDownloader*2*\tmp|*.*|RECURSEFileKey4=%LocalAppData%\VirtualStore\Program Files*\JDownloader*2*\captchas|*.*|RECURSEFileKey5=%ProgramFiles%\JDownloader*2*\cfg|CaptchaDialogDimensions_*.jsonFileKey6=%LocalAppData%\VirtualStore\Program Files*\JDownloader*2*\cfg|CaptchaDialogDimensions_*.jsonExcludeKey1=%ProgramFiles%\JDownloader*2*\cfg\subconf_*.ejsExcludeKey2=%LocalAppData%\VirtualStore\Program Files*\JDownloader*2*\cfg\subconf_*.ejs - Tweaked FileKeys - Added Excludes [Logs*]LangSecRef=3029SpecialDetect=DET_CHROMEDetectFile1=%LocalAppData%\TorchDetectFile2=%LocalAppData%\SuperBirdDefault=FalseFileKey1=%LocalAppData%\Chrome Plus\Application|debug.logFileKey2=%LocalAppData%\Chrome Plus\User Data\*|*LOG.*;Log;*.log|RECURSEFileKey3=%LocalAppData%\Chromium\Application|debug.logFileKey4=%LocalAppData%\Chromium\User Data\*|*LOG.*;Log;*.log|RECURSEFileKey5=%LocalAppData%\Flock\Application|debug.logFileKey6=%LocalAppData%\Flock\User Data\*|*LOG.*;Log;*.log|RECURSEFileKey7=%LocalAppData%\Google\Chrome\Application|debug.logFileKey8=%LocalAppData%\Google\Chrome\User Data\*|*LOG.*;Log;*.log|RECURSEFileKey9=%LocalAppData%\Google\Chrome SxS\Application|debug.logFileKey10=%LocalAppData%\Google\Chrome SxS\User Data\*|*LOG.*;Log;*.log|RECURSEFileKey16=%LocalAppData%\Rockmelt\Application|debug.logFileKey17=%LocalAppData%\Rockmelt\User Data\*|*LOG.*;Log;*.log|RECURSEFileKey19=%LocalAppData%\SRWare Iron\Application|debug.logFileKey20=%LocalAppData%\SRWare Iron\User Data\*|*LOG.*;Log;*.log|RECURSEFileKey21=%LocalAppData%\Torch\Application|debug.logFileKey22=%LocalAppData%\Torch\User Data\*|*LOG.*;Log;*.log|RECURSEFileKey23=%LocalAppData%\SuperBird\Application|debug.logFileKey24=%LocalAppData%\SuperBird\User Data\*|*LOG.*;Log;*.log|RECURSEFileKey25=%LocalAppData%\VirtualStore\Program Files*\Google\Chrome\Application|debug.logExcludeKey1=PATH|%LocalAppData%\Google\Chrome\User Data\*\Local Extension Settings\|*.*ExcludeKey2=PATH|%LocalAppData%\Google\Chrome\User Data\*\Local App Settings\|*.*ExcludeKey3=PATH|%LocalAppData%\Chrome Plus\User Data\*\Local Extension Settings\|*.*ExcludeKey4=PATH|%LocalAppData%\Chrome Plus\User Data\*\Local App Settings\|*.*ExcludeKey5=PATH|%LocalAppData%\Chromium\User Data\*\Local Extension Settings\|*.*ExcludeKey6=PATH|%LocalAppData%\Chromium\User Data\*\Local App Settings\|*.*ExcludeKey7=PATH|%LocalAppData%\Flock\User Data\*\Local Extension Settings\|*.*ExcludeKey8=PATH|%LocalAppData%\Flock\User Data\*\Local App Settings\|*.*ExcludeKey9=PATH|%LocalAppData%\Google\Chrome SxS\User Data\*\Local Extension Settings\|*.*ExcludeKey10=PATH|%LocalAppData%\Google\Chrome SxS\User Data\*\Local App Settings\|*.*ExcludeKey11=PATH|%LocalAppData%\Rockmelt\User Data\*\Local Extension Settings\|*.*ExcludeKey12=PATH|%LocalAppData%\Rockmelt\User Data\*\Local App Settings\|*.*ExcludeKey13=PATH|%LocalAppData%\SRWare Iron\User Data\*\Local Extension Settings\|*.*ExcludeKey14=PATH|%LocalAppData%\SRWare Iron\User Data\*\Local App Settings\|*.*ExcludeKey15=PATH|%LocalAppData%\Torch\User Data\*\Local Extension Settings\|*.*ExcludeKey16=PATH|%LocalAppData%\Torch\User Data\*\Local App Settings\|*.*ExcludeKey17=PATH|%LocalAppData%\Superbird\User Data\*\Local Extension Settings\|*.*ExcludeKey18=PATH|%LocalAppData%\Superbird\User Data\*\Local App Settings\|*.* - Added Exclude Keys [MS Visual Studio Backup*]LangSecRef=3021Detect=HKCU\Software\Microsoft\VisualStudioDefault=FalseFileKey1=%Documents%\Visual Studio 2005\Backup Files|*.*|RECURSEFileKey2=%Documents%\Visual Studio 2008\Backup Files|*.*|RECURSEFileKey3=%Documents%\Visual Studio 2010\Backup Files|*.*|RECURSEFileKey4=%Documents%\Visual Studio 2012\Backup Files|*.*|RECURSEFileKey5=%Documents%\Visual Studio 2013\Backup Files|*.*|RECURSE - Added FileKey5 [MS Visual Studio MRU*]LangSecRef=3021Detect1=HKCU\Software\Microsoft\VisualStudioDefault=FalseRegKey1=HKCU\Software\Microsoft\VisualStudio\7.1\FileMRUListRegKey2=HKCU\Software\Microsoft\VisualStudio\7.1\ProjectMRUListRegKey3=HKCU\Software\Microsoft\VisualStudio\8.0\FileMRUListRegKey4=HKCU\Software\Microsoft\VisualStudio\8.0\ProjectMRUListRegKey5=HKCU\Software\Microsoft\VisualStudio\9.0\FileMRUListRegKey6=HKCU\Software\Microsoft\VisualStudio\9.0\ProjectMRUListRegKey7=HKCU\Software\Microsoft\VisualStudio\10.0\FileMRUListRegKey8=HKCU\Software\Microsoft\VisualStudio\10.0\ProjectMRUListRegKey9=HKCU\Software\Microsoft\VisualStudio\11.0\FileMRUListRegKey10=HKCU\Software\Microsoft\VisualStudio\11.0\ProjectMRUListRegKey11=HKCU\Software\Microsoft\VisualStudio\12.0\FileMRUListRegKey12=HKCU\Software\Microsoft\VisualStudio\12.0\ProjectMRUList - Added RegKeys11 and 12 [MS Visual Studio Search History*]LangSecRef=3021Detect1=HKCU\Software\Microsoft\VisualStudioDefault=FalseRegKey1=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Find 0RegKey2=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Find 1RegKey3=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Find 2RegKey4=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Find 3RegKey5=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Find 4RegKey6=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Find 5RegKey7=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Find 6RegKey8=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Find 7RegKey9=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Find 8RegKey10=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Find 9RegKey11=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Find 10RegKey12=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Find 11RegKey13=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Find 12RegKey14=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Find 13RegKey15=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Find 14RegKey16=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Find 15RegKey17=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Find 16RegKey18=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Find 17RegKey19=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Find 18RegKey20=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Find 19RegKey21=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Replace 0RegKey22=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Replace 1RegKey23=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Replace 2RegKey24=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Replace 3RegKey25=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Replace 4RegKey26=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Replace 5RegKey27=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Replace 6RegKey28=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Replace 7RegKey29=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Replace 8RegKey30=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Replace 9RegKey31=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Replace 10RegKey32=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Replace 11RegKey33=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Replace 12RegKey34=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Replace 13RegKey35=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Replace 14RegKey36=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Replace 15RegKey37=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Replace 16RegKey38=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Replace 17RegKey39=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Replace 18RegKey40=HKCU\Software\Microsoft\VisualStudio\7.1\Find|Replace 19RegKey41=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Find 0RegKey42=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Find 1RegKey43=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Find 2RegKey44=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Find 3RegKey45=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Find 4RegKey46=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Find 5RegKey47=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Find 6RegKey48=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Find 7RegKey49=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Find 8RegKey50=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Find 9RegKey51=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Find 10RegKey52=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Find 11RegKey53=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Find 12RegKey54=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Find 13RegKey55=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Find 14RegKey56=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Find 15RegKey57=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Find 16RegKey58=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Find 17RegKey59=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Find 18RegKey60=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Find 19RegKey61=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Replace 0RegKey62=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Replace 1RegKey63=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Replace 2RegKey64=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Replace 3RegKey65=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Replace 4RegKey66=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Replace 5RegKey67=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Replace 6RegKey68=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Replace 7RegKey69=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Replace 8RegKey70=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Replace 9RegKey71=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Replace 10RegKey72=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Replace 11RegKey73=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Replace 12RegKey74=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Replace 13RegKey75=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Replace 14RegKey76=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Replace 15RegKey77=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Replace 16RegKey78=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Replace 17RegKey79=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Replace 18RegKey80=HKCU\Software\Microsoft\VisualStudio\8.0\Find|Replace 19RegKey81=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Find 0RegKey82=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Find 1RegKey83=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Find 2RegKey84=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Find 3RegKey85=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Find 4RegKey86=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Find 5RegKey87=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Find 6RegKey88=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Find 7RegKey89=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Find 8RegKey90=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Find 9RegKey91=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Find 10RegKey92=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Find 11RegKey93=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Find 12RegKey94=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Find 13RegKey95=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Find 14RegKey96=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Find 15RegKey97=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Find 16RegKey98=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Find 17RegKey99=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Find 18RegKey100=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Find 19RegKey101=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Replace 0RegKey102=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Replace 1RegKey103=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Replace 2RegKey104=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Replace 3RegKey105=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Replace 4RegKey106=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Replace 5RegKey107=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Replace 6RegKey108=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Replace 7RegKey109=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Replace 8RegKey110=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Replace 9RegKey111=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Replace 10RegKey112=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Replace 11RegKey113=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Replace 12RegKey114=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Replace 13RegKey115=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Replace 14RegKey116=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Replace 15RegKey117=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Replace 16RegKey118=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Replace 17RegKey119=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Replace 18RegKey120=HKCU\Software\Microsoft\VisualStudio\9.0\Find|Replace 19RegKey121=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Find 0RegKey122=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Find 1RegKey123=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Find 2RegKey124=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Find 3RegKey125=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Find 4RegKey126=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Find 5RegKey127=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Find 6RegKey128=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Find 7RegKey129=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Find 8RegKey130=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Find 9RegKey131=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Find 10RegKey132=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Find 11RegKey133=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Find 12RegKey134=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Find 13RegKey135=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Find 14RegKey136=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Find 15RegKey137=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Find 16RegKey138=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Find 17RegKey139=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Find 18RegKey140=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Find 19RegKey141=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Replace 0RegKey142=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Replace 1RegKey143=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Replace 2RegKey144=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Replace 3RegKey145=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Replace 4RegKey146=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Replace 5RegKey147=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Replace 6RegKey148=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Replace 7RegKey149=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Replace 8RegKey150=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Replace 9RegKey151=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Replace 10RegKey152=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Replace 11RegKey153=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Replace 12RegKey154=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Replace 13RegKey155=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Replace 14RegKey156=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Replace 15RegKey157=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Replace 16RegKey158=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Replace 17RegKey159=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Replace 18RegKey160=HKCU\Software\Microsoft\VisualStudio\10.0\Find|Replace 19RegKey161=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Find 0RegKey162=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Find 1RegKey163=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Find 2RegKey164=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Find 3RegKey165=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Find 4RegKey166=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Find 5RegKey167=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Find 6RegKey168=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Find 7RegKey169=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Find 8RegKey170=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Find 9RegKey171=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Find 10RegKey172=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Find 11RegKey173=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Find 12RegKey174=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Find 13RegKey175=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Find 14RegKey176=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Find 15RegKey177=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Find 16RegKey178=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Find 17RegKey179=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Find 18RegKey180=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Find 19RegKey181=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Replace 0RegKey182=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Replace 1RegKey183=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Replace 2RegKey184=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Replace 3RegKey185=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Replace 4RegKey186=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Replace 5RegKey187=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Replace 6RegKey188=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Replace 7RegKey189=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Replace 8RegKey190=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Replace 9RegKey191=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Replace 10RegKey192=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Replace 11RegKey193=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Replace 12RegKey194=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Replace 13RegKey195=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Replace 14RegKey196=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Replace 15RegKey197=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Replace 16RegKey198=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Replace 17RegKey199=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Replace 18RegKey200=HKCU\Software\Microsoft\VisualStudio\11.0\Find|Replace 19RegKey201=HKCU\Software\Microsoft\VisualStudio\12.0\Find|FindRegKey202=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Find 0RegKey203=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Find 1RegKey204=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Find 2RegKey205=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Find 3RegKey206=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Find 4RegKey207=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Find 5RegKey208=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Find 6RegKey209=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Find 7RegKey210=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Find 8RegKey211=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Find 9RegKey212=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Find 10RegKey213=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Find 11RegKey214=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Find 12RegKey215=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Find 13RegKey216=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Find 14RegKey217=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Find 15RegKey218=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Find 16RegKey219=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Find 17RegKey220=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Find 18RegKey221=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Find 19RegKey222=HKCU\Software\Microsoft\VisualStudio\12.0\Find|ReplaceRegKey223=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Replace 0RegKey224=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Replace 1RegKey225=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Replace 2RegKey226=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Replace 3RegKey227=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Replace 4RegKey228=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Replace 5RegKey229=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Replace 6RegKey230=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Replace 7RegKey231=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Replace 8RegKey232=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Replace 9RegKey233=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Replace 10RegKey234=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Replace 11RegKey235=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Replace 12RegKey236=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Replace 13RegKey237=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Replace 14RegKey238=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Replace 15RegKey239=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Replace 16RegKey240=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Replace 17RegKey241=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Replace 18RegKey242=HKCU\Software\Microsoft\VisualStudio\12.0\Find|Replace 19 - Added RegKeys201 through 242 [NVIDIA GFExperience Logs*]LangSecRef=3023Detect=HKLM\Software\NVIDIA CorporationDefault=FalseFileKey1=%SystemDrive%\NvidiaLogging\GFExperience|GridClientLog.log*|RECURSEFileKey2=%CommonAppData%\NVIDIA Corporation\GeForce Experience\Logs|*.logFileKey3=%CommonAppData%\NVIDIA Corporation\ShadowPlay|*.log;*.bak;*.statFileKey4=%LocalAppData%\NVIDIA Corporation\GFExperience|*.logFileKey5=%LocalAppData%\NVIDIA Corporation\ShadowPlay|*.log;*.bakFileKey6=%LocalAppData%\VirtualStore\ProgramData\NVIDIA Corporation\GeForce Experience\Logs|*.logFileKey7=%LocalAppData%\VirtualStore\ProgramData\NVIDIA Corporation\ShadowPlay|*.log;*.bak;*.stat - Tweaked FileKeys 2 and 3 [Quicken Logs*]LangSecRef=3021Detect=HKLM\Software\Intuit\QuickenDefault=FalseFileKey1=%AppData%\Intuit\Quicken\Log|*.txt;*.logFileKey2=%CommonAppData%\Intuit\Quicken\Log|*.logFileKey3=%CommonAppData%\Intuit\Quicken\Log\installer|*.*|REMOVESELFFileKey4=%CommonAppData%\Intuit\SendError|*.logFileKey5=%LocalAppData%\VirtualStore\ProgramData\Intuit\Quicken\Log|*.logFileKey6=%LocalAppData%\VirtualStore\ProgramData\Intuit\SendError|*.logFileKey7=%LocalAppData%\Intuit\Common\Authorization\V1\Logs\|*.txt - Added FileKey7 [store*]DetectOS=6.2|Section=3031Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\WinStore_cw5n1h2txyewyFileKey1=%LocalAppData%\Packages\WinStore_*\AC\AppCache|*.*|RECURSEFileKey2=%LocalAppData%\Packages\WinStore_*\AC\INetCache|*.*|RECURSEFileKey3=%LocalAppData%\Packages\WinStore_*\AC\INetCookies|*.*|RECURSEFileKey4=%LocalAppData%\Packages\WinStore_*\AC\INetHistory|*.*|RECURSEFileKey5=%LocalAppData%\Packages\WinStore_*\AC\Microsoft\CLR_v4.0\UsageLogs|*.*|RECURSEFileKey6=%LocalAppData%\Packages\WinStore_*\AC\Microsoft\CryptnetUrlCache\Content|*.*FileKey7=%LocalAppData%\Packages\WinStore_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.*FileKey8=%LocalAppData%\Packages\WinStore_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSEFileKey9=%LocalAppData%\Packages\WinStore_*\AC\Microsoft\Windows Store\Cache|*.*|RECURSEFileKey10=%LocalAppData%\Packages\WinStore_*\AC\Microsoft\Windows Store\Data|history.datFileKey11=%LocalAppData%\Packages\WinStore_*\AC\PRICache|*.*FileKey12=%LocalAppData%\Packages\WinStore_*\AC\Temp|*.*FileKey13=%LocalAppData%\Packages\WinStore_*\LocalState\Cache|*.*|RECURSEFileKey14=%LocalAppData%\Packages\WinStore_*\LocalState\LiveTile|*.*|RECURSEFileKey15=%LocalAppData%\Packages\WinStore_*\LocalState\navigationHistory|*.*|RECURSEFileKey16=%LocalAppData%\Microsoft\Windows Store\Cache Medium IL|*.*|RECURSEFileKey17=%LocalAppData%\Microsoft\Windows Store\Cache|*.*|RECURSERegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\WinStore_cw5n1h2txyewy\SearchHistory - Added FileKey17 [Western Digital SmartWare*]LangSecRef=3024DetectFile=%CommonAppData%\Western DigitalDefault=FalseFileKey1=%AppData%\Western Digital\WD SmartWare\Logs|*.*FileKey2=%CommonAppData%\Western Digital\WDFME|*.*FileKey3=%CommonAppData%\Western Digital\WD SmartWare|*.logFileKey4=%LocalAppData%\Western Digital\WD SmartWare|*log.txtFileKey5=%LocalAppData%\VirtualStore\ProgramData\Western Digital\WDFME|*.*FileKey6=%LocalAppData%\VirtualStore\ProgramData\Western Digital\WD SmartWare|*.logFileKey7=%CommonAppData%\Western Digital\Logs\WD SmartWare\*\|*.logFileKey8=%CommonAppData%\Western Digital\Logs\WD QuickView\*\|*.log - Added FileKeys 7 and 8 [Windows DRM Cache*]LangSecRef=3025Detect=HKLM\Software\Microsoft\DRMDefault=FalseFileKey1=%CommonAppData%\Microsoft\Windows\DRM\Cache|*.*|RECURSEFileKey2=%LocalAppData%\VirtualStore\ProgramData\Microsoft\Windows\DRM\Cache|*.*|RECURSE - Improved FileKeys1 and 2 ------------------------------------------------------------------------------Removed Entries:------------------------------------------------------------------------------ winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Coffee4Joe Posted October 26, 2014 Share Posted October 26, 2014 thanks!edited AMD/ATI*. It was missing the Default=. trim.bat was excluding it with that missing [AMD/ATI*] LangSecRef=3024 Detect1=HKLM\Software\AMD Detect2=HKLM\Software\ATI Detect3=HKLM\Software\ATI Technologies DetectFile=%ProgramFiles%\ATI Technologies\ATI.ACE Default=False FileKey1=%CommonAppData%\AMD\Fuel|*.txt FileKey2=%CommonAppData%\AMD\KDB|*.log FileKey3=%LocalAppData%\AMD\Fuel|ClientProxyLog*.* FileKey4=%LocalAppData%\AMD\GLCache|*.*|RECURSE FileKey5=%LocalAppData%\ATI\ACE|*.txt FileKey6=%ProgramFiles%\AMD\OverDrive|*.log FileKey7=%ProgramFiles%\AMD\amdkmpfd|*.*|REMOVESELF FileKey8=%ProgramFiles%\ATI\CIM\Reports|*.* FileKey9=%ProgramFiles%\ATI Technologies|*.log|RECURSE FileKey10=%ProgramFiles%\ATI Technologies|cccutil64.txt FileKey11=%SystemDrive%\ATI|*.*|REMOVESELF FileKey12=%SystemDrive%\AMD|*.*|REMOVESELF FileKey13=%WinDir%\System32|CCCInstall*.log FileKey14=%WinDir%\SysWOW64|CCCInstall*.log FileKey15=%LocalAppData%\VirtualStore\Program Files*\AMD\OverDrive|*.log FileKey16=%LocalAppData%\VirtualStore\Program Files*\AMD\amdkmpfd|*.*|REMOVESELF FileKey17=%LocalAppData%\VirtualStore\Program Files*\ATI\CIM\Reports|*.* FileKey18=%LocalAppData%\VirtualStore\Program Files*\ATI Technologies|*.log|RECURSE FileKey19=%LocalAppData%\VirtualStore\Program Files*\ATI Technologies|cccutil64.txt FileKey20=%LocalAppData%\VirtualStore\ProgramData\AMD\Fuel|*.txt FileKey21=%LocalAppData%\VirtualStore\ProgramData\AMD\KDB|*.log Link to comment Share on other sites More sharing options...
ricktendo64 Posted October 27, 2014 Share Posted October 27, 2014 thanks! edited AMD/ATI*. It was missing the Default=. trim.bat was excluding it with that missing Same thing goes for Store* Link to comment Share on other sites More sharing options...
