Moderators Nergal Posted January 21, 2015 Moderators Share Posted January 21, 2015 No not all bak or old are junk that's what we keep saying ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
CSGalloway Posted January 21, 2015 Share Posted January 21, 2015 Well then do not include the entry in winapp2.ini - thanks Link to comment Share on other sites More sharing options...
Moderators Andavari Posted January 22, 2015 Moderators Share Posted January 22, 2015 (edited) Well then do not include the entry in winapp2.ini - thanks It would help if you'd just edit it out of your post of winapp2.ini entries you submitted, that way Winapp2.ini (person) doesn't accidentally include it when he updates and it could save the casual lurker from copying it and using it at their dismay. Edited January 22, 2015 by Andavari Link to comment Share on other sites More sharing options...
CSGalloway Posted January 22, 2015 Share Posted January 22, 2015 It would help if you'd just edit it out of your post of winapp2.ini entries you submitted, that way Winapp2.ini (person) doesn't accidentally include it when he updates and it could save the casual lurker from copying it and using it at their dismay. Done..... Link to comment Share on other sites More sharing options...
dvdbane Posted January 22, 2015 Share Posted January 22, 2015 New: [Google Chrome ART*] LangSecRef=3022 SpecialDetect=DET_CHROME Default=False FileKey1=%CommonProgramFiles%\Microsoft\ART\Backup\Google Chrome\Default\Preferences.bak FileKey2=%CommonProgramFiles%\Microsoft\ART\Backup\Google Chrome\Default|*.tmp|RECURSE i checked my XP,7 and 8 with chrome installed and i can't find this folder %CommonProgramFiles%\Microsoft\ART\Backup\Google Chrome\ searching through the internet i only see threads of infected people with unwanted toolbar i don't know if this folder related to the unwanted toolbar or not but you better perform an antimalware scan just incase you're infected Link to comment Share on other sites More sharing options...
nodles Posted January 22, 2015 Share Posted January 22, 2015 MODIFIED ENTRY [Neverwinter*] Section=Games Detect=HKCU\Software\Cryptic\Neverwinter Default=False FileKey1=%ProgramFiles%\Steam\SteamApps\common\Cryptic Studios|*.log|RECURSE FileKey2=%ProgramFiles%\Steam\SteamApps\common\Cryptic Studios\localdata|_SWMWindowPosList.txt FileKey3=%SystemDrive%\Users\Public\Games\Cryptic Studios|*.log|RECURSE FileKey4=%SystemDrive%\Users\Public\Games\Cryptic Studios\localdata|_SWMWindowPosList.tx Removed "(beta)" from title & added FK1+FK2. Link to comment Share on other sites More sharing options...
CSGalloway Posted January 22, 2015 Share Posted January 22, 2015 i checked my XP,7 and 8 with chrome installed and i can't find this folder %CommonProgramFiles%\Microsoft\ART\Backup\Google Chrome\ searching through the internet i only see threads of infected people with unwanted toolbar i don't know if this folder related to the unwanted toolbar or not but you better perform an antimalware scan just incase you're infected You have to use CMD as administrator then search for the folder - Link to comment Share on other sites More sharing options...
Coffee4Joe Posted January 24, 2015 Share Posted January 24, 2015 Edited (from winapp.ini)added FileKey3= [InkScape*] LangSecRef=3023 Detect=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\inkscape.exe Default=False FileKey1=%AppData%\InkScape|*.log|RECURSE FileKey2=%UserProfile%|.recently-used.xbel FileKey3=%LocalAppData%|recently-used.xbel Link to comment Share on other sites More sharing options...
Coffee4Joe Posted January 25, 2015 Share Posted January 25, 2015 Added FileKey6=Minecrafts new launcher has it's own java runtime. [Minecraft*] Section=Games DetectFile=%AppData%\.minecraft Default=False FileKey1=%AppData%\.minecraft|*.log;*.log.* FileKey2=%AppData%\.minecraft\crash-reports|*.* FileKey3=%AppData%\.minecraft\server|server.log FileKey4=%AppData%\.minecraft\stats|*.old FileKey5=%AppData%\.minecraft\logs|*.* FileKey6=%AppData%\java|*.*|REMOVESELF Link to comment Share on other sites More sharing options...
SMalik Posted January 25, 2015 Share Posted January 25, 2015 New Entry [system TuneUp*]LangSecRef=3024Detect=HKCU\Software\Acelogix\System TuneUpDefault=FalseFileKey1=%LocalAppData%\Acelogix\System TuneUp\Backups|*.reg Link to comment Share on other sites More sharing options...
SMalik Posted January 25, 2015 Share Posted January 25, 2015 Revised Entry Changed FileKey1 Added: *.log.lock [AVG 2015*]LangSecRef=3024Detect=HKLM\Software\AVG\AVG2015Default=FalseFileKey1=%CommonAppData%\AVG2015\log|*.log;*.log.lock;history.xmlFileKey2=%CommonAppData%\AVG2015\scanlogs|*.logFileKey3=%CommonAppData%\AVG2015\update\backup|*.*FileKey4=%CommonAppData%\AVG2015\Emc\log|*.*FileKey5=%CommonAppData%\AVG2015\IDS\config|List.zip.bakFileKey6=%CommonAppData%\AVG2015\IDS\profile|globalLoadable.bakFileKey7=%CommonAppData%\AVG2015\temp|*.*FileKey8=%CommonAppData%\AVG2015\SetupBackup|*.*|REMOVESELFFileKey9=%CommonAppData%\MFAData\logs|*.*FileKey10=%CommonAppData%\MFAData\pack|*.*FileKey11=%CommonAppData%\MFAData|msistorg.dat.bkp;public_installation_log.xmlFileKey12=%LocalAppData%\AVG2015\log|*.log;*.log.*FileKey13=%LocalAppData%\AVG2015\update|*.*FileKey14=%LocalAppData%\AVG2015\temp|*.*FileKey15=%LocalAppData%\MFAData\logs|*.*FileKey16=%ProgramFiles%\AVG\AVG2015|updatecomps.bak;*.oldFileKey17=%WinDir%\System32\config\systemprofile\AppData\Local\Avg2015\dumps|*.*FileKey18=%WinDir%\System32\config\systemprofile\Local Settings\Application Data\Avg2015\dumps|*.*FileKey19=%WinDir%\System32\config\systemprofile\AppData\Local\Avg2015\log|*.*FileKey20=%WinDir%\System32\config\systemprofile\Local Settings\Application Data\log|*.*FileKey21=%WinDir%\System32\config\systemprofile\AppData\Local\Avg2015\temp|*.*FileKey22=%WinDir%\System32\config\systemprofile\Local Settings\Application Data\temp|*.*FileKey23=%WinDir%\System32\config\systemprofile\AppData\Local\MFAData\logs|*.*FileKey24=%WinDir%\System32\config\systemprofile\Local Settings\MFAData\logs|*.*FileKey25=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Avg2015\dumps|*.*FileKey26=%WinDir%\SysWOW64\config\systemprofile\Local Settings\Application Data\dumps|*.*FileKey27=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Avg2015\log|*.*FileKey28=%WinDir%\SysWOW64\config\systemprofile\Local Settings\Application Data\log|*.*FileKey29=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Avg2015\temp|*.*FileKey30=%WinDir%\SysWOW64\config\systemprofile\Local Settings\Application Data\temp|*.*FileKey31=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\MFAData\logs|*.*FileKey32=%WinDir%\SysWOW64\config\systemprofile\Local Settings\MFAData\logs|*.* Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 26, 2015 Author Share Posted January 26, 2015 Updated What's new in winapp2.ini 5.02.150126General:32 New Entries32 Modified Entries04 Removed EntriesNote: Changes now exclude minor pathing changes (REMOVESELF -> RECURSE, adding/removing minor wildcards, etc)Verbose:------------------------------------------------------------------------------New Entries:[Adblock Edge for Firefox*]LangSecRef=3026SpecialDetect=DET_MOZILLADefault=FalseFileKey1=%AppData%\Mozilla\Firefox\Profiles\*\adblockedge|patterns-backup*.ini;*.tmp[AVG 2015*]LangSecRef=3024Detect=HKLM\Software\AVG\AVG2015Default=FalseFileKey1=%CommonAppData%\AVG2015\log|*.log;history.xmlFileKey2=%CommonAppData%\AVG2015\scanlogs|*.logFileKey3=%CommonAppData%\AVG2015\update\backup|*.*FileKey4=%CommonAppData%\AVG2015\Emc\log|*.*FileKey5=%CommonAppData%\AVG2015\IDS\config|List.zip.bakFileKey6=%CommonAppData%\AVG2015\IDS\profile|globalLoadable.bakFileKey7=%CommonAppData%\AVG2015\temp|*.*FileKey8=%CommonAppData%\AVG2015\SetupBackup|*.*|REMOVESELFFileKey9=%CommonAppData%\MFAData\logs|*.*FileKey10=%CommonAppData%\MFAData\pack|*.*FileKey11=%CommonAppData%\MFAData|msistorg.dat.bkp;public_installation_log.xmlFileKey12=%LocalAppData%\AVG2015\log|*.log;*.log.*FileKey13=%LocalAppData%\AVG2015\update|*.*FileKey14=%LocalAppData%\AVG2015\temp|*.*FileKey15=%LocalAppData%\MFAData\logs|*.*FileKey16=%ProgramFiles%\AVG\AVG2015|updatecomps.bak;*.oldFileKey17=%WinDir%\System32\config\systemprofile\AppData\Local\Avg2015\dumps|*.*FileKey18=%WinDir%\System32\config\systemprofile\Local Settings\Application Data\Avg2015\dumps|*.*FileKey19=%WinDir%\System32\config\systemprofile\AppData\Local\Avg2015\log|*.*FileKey20=%WinDir%\System32\config\systemprofile\Local Settings\Application Data\log|*.*FileKey21=%WinDir%\System32\config\systemprofile\AppData\Local\Avg2015\temp|*.*FileKey22=%WinDir%\System32\config\systemprofile\Local Settings\Application Data\temp|*.*FileKey23=%WinDir%\System32\config\systemprofile\AppData\Local\MFAData\logs|*.*FileKey24=%WinDir%\System32\config\systemprofile\Local Settings\MFAData\logs|*.*FileKey25=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Avg2015\dumps|*.*FileKey26=%WinDir%\SysWOW64\config\systemprofile\Local Settings\Application Data\dumps|*.*FileKey27=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Avg2015\log|*.*FileKey28=%WinDir%\SysWOW64\config\systemprofile\Local Settings\Application Data\log|*.*FileKey29=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Avg2015\temp|*.*FileKey30=%WinDir%\SysWOW64\config\systemprofile\Local Settings\Application Data\temp|*.*FileKey31=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\MFAData\logs|*.*FileKey32=%WinDir%\SysWOW64\config\systemprofile\Local Settings\MFAData\logs|*.*[bitTorrent Sync*]LangSecRef=3023DetectFile=%AppData%\BitTorrent SyncDefault=FalseFileKey1=%AppData%\BitTorrent Sync|*.log;*.old[blade of Destiny*]Section=GamesDetectFile=%Documents%\BladeofDestinyDefault=FalseFileKey1=%Documents%\BladeofDestiny\Consolelog|*.*|RECURSE[Corel PaintShop Pro X7*]LangSecRef=3023Detect=HKCU\Software\Corel\PaintShop Pro\X7Default=FalseFileKey1=%LocalAppData%\Corel PaintShop Pro\17.0\Cache|*.*FileKey2=%LocalAppData%\Corel PaintShop Pro\17.0\Database|*.dbRegKey1=HKCU\Software\Corel\PaintShop Pro\X7\CoreMemoryManager\0 [Corel PaintShop Pro X7 (AutoPreserve)*]LangSecRef=3023Detect=HKCU\Software\Corel\PaintShop Pro\X7Default=FalseFileKey1=%Pictures%\Corel Auto-Preserve|*.* [Corel VideoStudio Pro X7*]LangSecRef=3023Detect=HKCU\Software\Ulead Systems\Corel VideoStudio Pro\17.0Default=FalseFileKey1=%Documents%\Corel VideoStudio Pro\17.0\AudioTmp|*.*FileKey2=%Documents%\Corel VideoStudio Pro\17.0\SmartProxy|*.*RegKey1=HKCU\Software\Ulead Systems\Corel VideoStudio Pro\17.0\HerRFL[CyberLink MediaCache*]LangSecRef=3023Detect=HKCU\Software\CyberLinkDefault=FalseFileKey1=%AppData%\CyberLink\MediaCache|*.*|RECURSERegKey1=HKCU\Software\CyberLink\MediaCache5\Data5RegKey2=HKCU\Software\CyberLink\MediaCache5\Thumbnail5[CyberLink PowerToGo9*]LangSecRef=3024Detect=HKCU\Software\CyberLink\Power2Go9Default=FalseFileKey1=%ProgramFiles%\Cyberlink\Power2Go9\Template\Cyberlink\frame|*.tmp[Dr. Kaiser - (DKS) PC Watcher*]LangSecRef=3024DetectFile=%WinDir%\DKSService.exeDefault=FalseFileKey1=%WinDir%|DksSystem.log[Elder Scrolls Online*]Section=GamesDetectFile=%Documents%\Elder Scrolls OnlineDefault=FalseFileKey1=%Documents%\Elder Scrolls Online\Errors|*.*FileKey2=%Documents%\Elder Scrolls Online\Logs|*.*[Extensions Databases*]LangSecRef=3029SpecialDetect=DET_CHROMEDetectFile=%LocalAppData%\Google\ChromeFileKey1=%LocalAppData%\Google\Chrome\User Data\Default\IndexedDB|*.*|RECURSE [Extensions State*]LangSecRef=3029SpecialDetect=DET_CHROMEDetectFile=%LocalAppData%\Google\ChromeFileKey1=%LocalAppData%\Google\Chrome\User Data\Default\Extension State|*.*|RECURSE[Google Chrome ART*]LangSecRef=3022SpecialDetect=DET_CHROMEDefault=FalseFileKey1=%CommonProgramFiles%\Microsoft\ART\Backup\Google Chrome\Default\Preferences.bakFileKey2=%CommonProgramFiles%\Microsoft\ART\Backup\Google Chrome\Default|*.tmp|RECURSE[History*]LangSecRef=3029SpecialDetect=DET_CHROMEDetectFile=%LocalAppData%\Google\ChromeFileKey1=%LocalAppData%\Google\Chrome\User Data\Default|History[iMobie PhoneRescue*]LangSecRef=3024DetectFile=%AppData%\iMobie\PhoneRescueDefault=FalseFileKey1=%AppData%\iMobie\PhoneRescue\AutoUpdate|*.*|RECURSEFileKey2=%AppData%\iMobie\PhoneRescue\Configue|Settings.plistFileKey3=%AppData%\iMobie\PhoneRescue\ErrorLog|*.*|RECURSEFileKey4=%AppData%\iMobie\PhoneRescue\Files|*.*|RECURSEFileKey5=%AppData%\iMobie\PhoneRescue|iTunesPrefs[Kodi Cache*]LangSecRef=3023DetectFile=%AppData%\kodiDefault=FalseFileKey1=%AppData%\kodi\cache|*.*|RECURSE[Kodi Packages*]LangSecRef=3023DetectFile=%AppData%\kodiDefault=FalseFileKey1=%AppData%\kodi\addons\packages|*.*|RECURSE[Kodi Thumbnails*]LangSecRef=3023DetectFile=%AppData%\kodiDefault=FalseFileKey1=%AppData%\kodi\userdata\thumbnails|*.*|RECURSEFileKey2=%AppData%\kodi.old\userdata\thumbnails|*.*|RECURSE[MaceCraft PowerTools hosts backups*]LangSecRef=3024Default=FalseDetectFile=%CommonProgramFiles%\jv16 PowerTools *\jv16PT.exeFileKey1=%windir%\System32\drivers\etc|hosts_PTBackup*.bak[Microsoft Deployment Toolkit*]LangSecRef=3024Warning=To Get a new Component list, check for Updates in the Management Console!DetectFile=%ProgramFiles%\Microsoft Deployment ToolkitDefault=FalseFileKey1=%ProgramFiles%\Microsoft Deployment Toolkit\Downloads|*.*|RECURSE[Microsoft Message Analyzer*]LangSecRef=3024DetectFile=%LocalAppData%\Microsoft\MessageAnalyzerWarning=This will remove Traces, Logs and remove the Configuration!Default=FalseFileKey1=%Documents%\MessageAnalyzer\Traces|*.*|RECURSEFileKey2=%LocalAppData%\Microsoft\MessageAnalyzer|*.logFileKey3=%AppData%\Microsoft\MessageAnalyzer|*.cfg[Quota Manager Data*]LangSecRef=3029SpecialDetect=DET_CHROMEDetectFile=%LocalAppData%\Google\ChromeFileKey1=%LocalAppData%\Google\Chrome\User Data\Default|QuotaManager[Rage*]Section=GamesDetect=HKCU\Software\Valve\Steam\Apps\9200Default=FalseFileKey1=%AppData%\id software\rage|*.*|RECURSE[Registry First Aid 10*]LangSecRef=3024Detect=HKCU\Software\KsL Software\RFA\10.0Default=FalseFileKey1=%ProgramFiles%\RFA 10|*.diz;*.urlFileKey2=%LocalAppData%\VirtualStore\Program Files*\RFA 10|*.diz;*.url[Reus*]Section=GamesDetect=HKCU\Software\Valve\Steam\Apps\222730Default=FalseFileKey1=%ProgramFiles%\Steam\SteamApps\common\Reus|errorReport*.txtFileKey2=%LocalAppData%\VirtualStore\Program Files*\Steam\SteamApps\common\Reus|errorReport*.txt[sAM Broadcaster*]LangSecRef=3023Detect1=HKCU\Software\SAMBCDefault=FalseFileKey1=%LocalAppData%\SpacialAudio\SAMBC|*.log|RECURSEFileKey2=%LocalAppData%\SpacialAudio\SAMBC\backup|*.*|RECURSE[search Engines Data*]LangSecRef=3029SpecialDetect=DET_CHROMEDetectFile=%LocalAppData%\Google\ChromeFileKey1=%LocalAppData%\Google\Chrome\User Data\Default|Web Data [session Storage*]LangSecRef=3029SpecialDetect=DET_CHROMEDetectFile=%LocalAppData%\Google\ChromeFileKey1=%LocalAppData%\Google\Chrome\User Data\Default\Session Storage|*.*|RECURSE[system TuneUp*]LangSecRef=3024Detect=HKCU\Software\Acelogix\System TuneUpDefault=FalseFileKey1=%LocalAppData%\Acelogix\System TuneUp\Backups|*.reg[Windows WebCache]LangSecRef=3025DetectFile=%LocalAppData%\Microsoft\Windows\WebCache\Default=FalseFileKey1=%LocalAppData%\Microsoft\Windows\WebCache|*.tmp[Windows Device Icon Downloads *]LangSecRef=3025Detect=%windir%\System32\config\systemprofile\AppData\Local\Microsoft\Device Metadata\dmrccache\downloads\Default=FalseFileKey1=%windir%\System32\config\systemprofile\AppData\Local\Microsoft\Device Metadata\dmrccache\downloads|*.tmp------------------------------------------------------------------------------Modified Entries:[Adblock Plus*]LangSecRef=3026SpecialDetect=DET_MOZILLADefault=FalseFileKey1=%AppData%\Mozilla\Firefox\Profiles\*\adblockplus|patterns-backup*.ini;*.tmp - Renamed[Adblock Plus for IE*]LangSecRef=3022Detect=HKLM\Software\Adblock Plus for IEDetectFile=%LocalAppData%\Adblock Plus for IEDefault=FalseFileKey1=%LocalAppData%\Adblock Plus for IE|patterns-backup*.iniFileKey2=%LocalLowAppData%\Adblock Plus for IE|patterns-backup*.iniFileKey3=%WinDir%\System32\config\systemprofile\AppData\LocalLow\Adblock Plus for IE|patterns-backup*.ini - Renamed [Adobe Updater*]LangSecRef=3021Detect=HKCU\Software\AdobeDefault=FalseFileKey1=%ProgramFiles%\Common Files\Adobe\Installers|*.*|RECURSEFileKey2=%CommonAppData%\Adobe\ARM|*.*|RECURSEFileKey3=%LocalAppData%\Adobe\AAMUpdater|*.Log|RECURSEFileKey4=%LocalAppData%\Adobe\Updater*|*.log|RECURSEFileKey5=%LocalAppData%\Adobe\Acrobat\*\Updater|*.logFileKey6=%AppData%\Adobe\LogTransport*\Logs|ulog_*.tmpFileKey7=%AppData%\Adobe\Acrobat\*\Updater|*.log - Renamed - Added FileKeys1 and 2[Apple Installer Cache*]LangSecRef=3023Detect=HKCU\Software\Apple Computer, Inc.Default=FalseWarning=You have to reinstall iTunes after adding a new windows user account.FileKey1=%CommonAppData%\Apple\Installer Cache|*.*|REMOVESELFFileKey2=%CommonAppData%\Apple Computer\Installer Cache|*.*|REMOVESELF - Added REMOVESELF [Ashampoo Snap 7*]LangSecRef=3024Detect=HKCU\Software\Ashampoo\Ashampoo Snap 7Default=FalseFileKey1=%LocalAppData%\CrashRpt\UnsentCrashReports|*.*|RECURSEFileKey2=%AppData%\Ashampoo\Ashampoo Snap 7|*.*|RECURSEFileKey3=%ProgramFiles%\Ashampoo\Ashampoo Snap 7|_NLogMsg.txt - Added FileKey2 [Chrome HTML5 Storage*]LangSecRef=3029SpecialDetect=DET_CHROMEDetectFile1=%LocalAppData%\ChromiumDetectFile2=%LocalAppData%\Google\ChromeDetectFile3=%LocalAppData%\Google\Chrome SxSDetectFile4=%ProgramFiles%\Google\ChromeDetectFile5=%ProgramFiles%\Google\Chrome SxSDetectFile6=%LocalAppData%\TorchDetectFile7=%LocalAppData%\SuperBirdDefault=FalseFileKey1=%LocalAppData%\Chrome Plus\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSEFileKey2=%LocalAppData%\Chromium\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSEFileKey3=%LocalAppData%\Flock\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSEFileKey4=%LocalAppData%\Google\Chrome\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSEFileKey5=%LocalAppData%\Google\Chrome SxS\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSEFileKey6=%LocalAppData%\Rockmelt\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSEFileKey7=%LocalAppData%\SRWare Iron\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSEFileKey8=%LocalAppData%\Torch\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSEFileKey9=%LocalAppData%\SuperBird\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSE - Removed *.* file target from all filekeys [Chrome Logs*]LangSecRef=3029SpecialDetect=DET_CHROMEDetectFile1=%LocalAppData%\TorchDetectFile2=%LocalAppData%\SuperBirdDefault=FalseFileKey1=%LocalAppData%\Chrome Plus\Application|debug.logFileKey2=%LocalAppData%\Chrome Plus\User Data\*|*LOG.*;Log;*.log|RECURSEFileKey3=%LocalAppData%\Chromium\Application|debug.logFileKey4=%LocalAppData%\Chromium\User Data\*|*LOG.*;Log;*.log|RECURSEFileKey5=%LocalAppData%\Flock\Application|debug.logFileKey6=%LocalAppData%\Flock\User Data\*|*LOG.*;Log;*.log|RECURSEFileKey7=%LocalAppData%\Google\Chrome\Application|debug.logFileKey8=%LocalAppData%\Google\Chrome\User Data\*|*LOG.*;Log;*.log|RECURSEFileKey9=%LocalAppData%\Google\Chrome SxS\Application|debug.logFileKey10=%LocalAppData%\Google\Chrome SxS\User Data\*|*LOG.*;Log;*.log|RECURSEFileKey16=%LocalAppData%\Rockmelt\Application|debug.logFileKey17=%LocalAppData%\Rockmelt\User Data\*|*LOG.*;Log;*.log|RECURSEFileKey19=%LocalAppData%\SRWare Iron\Application|debug.logFileKey20=%LocalAppData%\SRWare Iron\User Data\*|*LOG.*;Log;*.log|RECURSEFileKey21=%LocalAppData%\Torch\Application|debug.logFileKey22=%LocalAppData%\Torch\User Data\*|*LOG.*;Log;*.log|RECURSEFileKey23=%LocalAppData%\SuperBird\Application|debug.logFileKey24=%LocalAppData%\SuperBird\User Data\*|*LOG.*;Log;*.log|RECURSEFileKey25=%LocalAppData%\VirtualStore\Program Files*\Google\Chrome\Application|debug.logExcludeKey1=PATH|%LocalAppData%\Google\Chrome\User Data\*\Local Extension Settings\|*.*ExcludeKey2=PATH|%LocalAppData%\Google\Chrome\User Data\*\Local App Settings\|*.*ExcludeKey3=PATH|%LocalAppData%\Chrome Plus\User Data\*\Local Extension Settings\|*.*ExcludeKey4=PATH|%LocalAppData%\Chrome Plus\User Data\*\Local App Settings\|*.*ExcludeKey5=PATH|%LocalAppData%\Chromium\User Data\*\Local Extension Settings\|*.*ExcludeKey6=PATH|%LocalAppData%\Chromium\User Data\*\Local App Settings\|*.*ExcludeKey7=PATH|%LocalAppData%\Flock\User Data\*\Local Extension Settings\|*.*ExcludeKey8=PATH|%LocalAppData%\Flock\User Data\*\Local App Settings\|*.*ExcludeKey9=PATH|%LocalAppData%\Google\Chrome SxS\User Data\*\Local Extension Settings\|*.*ExcludeKey10=PATH|%LocalAppData%\Google\Chrome SxS\User Data\*\Local App Settings\|*.*ExcludeKey11=PATH|%LocalAppData%\Rockmelt\User Data\*\Local Extension Settings\|*.*ExcludeKey12=PATH|%LocalAppData%\Rockmelt\User Data\*\Local App Settings\|*.*ExcludeKey13=PATH|%LocalAppData%\SRWare Iron\User Data\*\Local Extension Settings\|*.*ExcludeKey14=PATH|%LocalAppData%\SRWare Iron\User Data\*\Local App Settings\|*.*ExcludeKey15=PATH|%LocalAppData%\Torch\User Data\*\Local Extension Settings\|*.*ExcludeKey16=PATH|%LocalAppData%\Torch\User Data\*\Local App Settings\|*.*ExcludeKey17=PATH|%LocalAppData%\Superbird\User Data\*\Local Extension Settings\|*.*ExcludeKey18=PATH|%LocalAppData%\Superbird\User Data\*\Local App Settings\|*.* - Added Exclude Keys [CyberLink PowerDirector 10*]LangSecRef=3023Detect=HKCU\Software\CyberLink\PowerDirector10Default=FalseFileKey1=%AppData%\CyberLink\PowerDirector\10.0\AutoSave|*.*|RECURSEFileKey2=%AppData%\CyberLink\PowerDirector\10.0\photoTmp|*.*|RECURSEFileKey3=%AppData%\Cyberlink\PowerDirector\10.0\WaveForms|*.*|RECURSEFileKey4=%AppData%\Cyberlink\PowerDirector\10.0|Recentfiles.iniFileKey5=%Documents%\CyberLink\PowerDirector\10.0|Snapshot(*).jpgFileKey6=%Documents%\CyberLink\PowerDirector\10.0\MyTitles|*.*|RECURSEFileKey7=%Documents%\CyberLink\PowerDirector\10.0\Preview Cache Files|*.*FileKey8=%Documents%\CyberLink\PowerDirector\10.0\ShadowEditFiles|*.MPGFileKey9=%Documents%\CyberLink\PowerDirector\10.0\SplitterIndex|*.maidxRegKey1=HKCU\Software\CyberLink\HanumanRegKey2=HKCU\Software\CyberLink\PowerDirector10\MediaObj\MediaCache5\Data5RegKey3=HKCU\Software\CyberLink\PowerDirector10\MediaObj\MediaCache5\Thumbnail5 - Added FileKeys1-4 [CyberLink PowerDirector 11*]LangSecRef=3023Detect=HKCU\Software\CyberLink\PowerDirector11Default=FalseFileKey1=%AppData%\CyberLink\PowerDirector\11.0\AutoSave|*.*|RECURSEFileKey2=%AppData%\CyberLink\PowerDirector\11.0\photoTmp|*.*|RECURSEFileKey3=%AppData%\Cyberlink\PowerDirector\11.0\WaveForms|*.*|RECURSEFileKey4=%AppData%\Cyberlink\PowerDirector\11.0|Recentfiles.iniFileKey5=%Documents%\CyberLink\PowerDirector\11.0|Snapshot(*).jpgFileKey6=%Documents%\CyberLink\PowerDirector\11.0\MyTitles|*.*|RECURSEFileKey7=%Documents%\CyberLink\PowerDirector\11.0\Preview Cache Files|*.*FileKey8=%Documents%\CyberLink\PowerDirector\11.0\ShadowEditFiles|*.MPGFileKey9=%Documents%\CyberLink\PowerDirector\11.0\SplitterIndex|*.maidxRegKey1=HKCU\Software\CyberLink\HanumanRegKey2=HKCU\Software\CyberLink\PowerDirector11\MediaObj\MediaCache5\Data5RegKey3=HKCU\Software\CyberLink\PowerDirector11\MediaObj\MediaCache5\Thumbnail5 - Added FileKeys1-4 [CyberLink PowerDirector 12*]LangSecRef=3023Detect=HKCU\Software\CyberLink\PowerDirector12Default=FalseFileKey1=%AppData%\CyberLink\PowerDirector\12.0\AutoSave|*.*|RECURSEFileKey2=%AppData%\CyberLink\PowerDirector\12.0\photoTmp|*.*|RECURSEFileKey3=%AppData%\Cyberlink\PowerDirector\12.0\WaveForms|*.*|RECURSEFileKey4=%AppData%\Cyberlink\PowerDirector\12.0|Recentfiles.iniFileKey5=%Documents%\CyberLink\PowerDirector\12.0|Snapshot(*).jpgFileKey6=%Documents%\CyberLink\PowerDirector\12.0\MyTitles|*.*|RECURSEFileKey7=%Documents%\CyberLink\PowerDirector\12.0\Preview Cache Files|*.*FileKey8=%Documents%\CyberLink\PowerDirector\12.0\ShadowEditFiles|*.MPGFileKey9=%Documents%\CyberLink\PowerDirector\12.0\SplitterIndex|*.maidxRegKey1=HKCU\Software\CyberLink\HanumanRegKey2=HKCU\Software\CyberLink\PowerDirector12\MediaObj\MediaCache5\Data5RegKey3=HKCU\Software\CyberLink\PowerDirector12\MediaObj\MediaCache5\Thumbnail5 - Added FileKeys1-4 [CyberLink PowerDirector 13*]LangSecRef=3023Detect=HKCU\Software\CyberLink\PowerDirector13Default=FalseFileKey1=%AppData%\CyberLink\PowerDirector\13.0\AutoSave|*.*|RECURSEFileKey2=%AppData%\CyberLink\PowerDirector\13.0\photoTmp|*.*|RECURSEFileKey3=%AppData%\Cyberlink\PowerDirector\13.0\WaveForms|*.*|RECURSEFileKey4=%AppData%\Cyberlink\PowerDirector\13.0|Recentfiles.iniFileKey5=%Documents%\CyberLink\PowerDirector\13.0|Snapshot(*).jpgFileKey6=%Documents%\CyberLink\PowerDirector\13.0\MyTitles|*.*|RECURSEFileKey7=%Documents%\CyberLink\PowerDirector\13.0\Preview Cache Files|*.*FileKey8=%Documents%\CyberLink\PowerDirector\13.0\ShadowEditFiles|*.MPGFileKey9=%Documents%\CyberLink\PowerDirector\13.0\SplitterIndex|*.maidxRegKey1=HKCU\Software\CyberLink\HanumanRegKey2=HKCU\Software\CyberLink\PowerDirector13\MediaObj\MediaCache5\Data5RegKey3=HKCU\Software\CyberLink\PowerDirector13\MediaObj\MediaCache5\Thumbnail5 - Added FileKeys1-4 [inkScape*]LangSecRef=3023Detect=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\App Paths\inkscape.exeDefault=FalseFileKey1=%AppData%\InkScape|*.log|RECURSEFileKey2=%UserProfile%|.recently-used.xbelFileKey3=%LocalAppData%|recently-used.xbel - Added FileKey3 [iTunes Temporary Files*]LangSecRef=3023Detect=HKLM\Software\Apple Computer, Inc.\iTunesDefault=FalseFileKey1=%Music%\iTunes|*.tmp|RECURSEFileKey2=%CommonAppData%\Apple Computer\iTunes\iPhone Temporary Files|*.*|RECURSEFileKey3=%LocalAppData%\VirtualStore\ProgramData\Apple Computer\iTunes\iPhone Temporary Files|*.*|RECURSE - Added FileKeys2 and 3 [Malwarebytes Anti-Exploit*]LangSecRef=3024DetectFile=%CommonAppData%\Malwarebytes\Malwarebytes Anti-ExploitDefault=FalseFileKey1=%CommonAppData%\Malwarebytes\Malwarebytes Anti-Exploit|*.logFileKey2=%LocalAppData%\VirtualStore\ProgramData\Malwarebytes\Malwarebytes Anti-Exploit|*.log - Renamed [Microsoft Security Essentials*]LangSecRef=3021Detect=HKCU\Software\Microsoft\Microsoft AntimalwareDefault=FalseFileKey1=%CommonAppData%\Microsoft\Microsoft Antimalware\LocalCopy|*.*|RECURSEFileKey2=%CommonAppData%\Microsoft\Microsoft Antimalware\Scans\History\Service|*.log|RECURSEFileKey3=%CommonAppData%\Microsoft\Microsoft Security Client\Support|MSSecurityClient*.logFileKey4=%LocalAppData%\VirtualStore\ProgramData\Microsoft\Microsoft Antimalware\LocalCopy|*.*|RECURSEFileKey5=%LocalAppData%\VirtualStore\ProgramData\Microsoft\Microsoft Antimalware\Scans\History\Service|*.log|RECURSEFileKey6=%LocalAppData%\VirtualStore\ProgramData\Microsoft\Microsoft Security Client\Support|MSSecurityClient*.logFileKey7=%CommonAppData%\Microsoft\Microsoft Antimalware\Network Inspection System\Support\NisLog.txt.bak - Added FileKey7 [Minecraft*]Section=GamesDetectFile=%AppData%\.minecraftDefault=FalseFileKey1=%AppData%\.minecraft|*.log;*.log.*FileKey2=%AppData%\.minecraft\crash-reports|*.*FileKey3=%AppData%\.minecraft\server|server.logFileKey4=%AppData%\.minecraft\stats|*.oldFileKey5=%AppData%\.minecraft\logs|*.*FileKey6=%AppData%\java|*.*|REMOVESELF - Added FileKey6 [McAfee*]LangSecRef=3024Detect=HKLM\Software\McAfeeDefault=FalseFileKey1=%CommonAppData%\McAfee\MCLOGS|*.*|RECURSEFileKey2=%CommonAppData%\McAfee\MPF\data|*.*|RECURSEFileKey3=%CommonAppData%\McAfee\MSC\Logs|*.*|RECURSEFileKey4=%CommonAppData%\McAfee\VirusScan\Data|*.log;*.oldFileKey5=%CommonAppData%\McAfee\VirusScan\Logs|*.*|RECURSEFileKey6=%LocalAppData%\VirtualStore\ProgramData\McAfee\MCLOGS|*.*|RECURSEFileKey7=%LocalAppData%\VirtualStore\ProgramData\McAfee\MPF\data|*.*|RECURSEFileKey8=%LocalAppData%\VirtualStore\ProgramData\McAfee\MSC\Logs|*.*|RECURSEFileKey9=%LocalAppData%\VirtualStore\ProgramData\McAfee\VirusScan\Data|*.log;*.oldFileKey10=%LocalAppData%\VirtualStore\ProgramData\McAfee\VirusScan\Logs|*.*|RECURSE - Renamed [MS Word Document Building Blocks*]LangSecRef=3021DetectFile=%AppData%\Microsoft\Document Building BlocksDefault=FalseFileKey1=%AppData%\Microsoft\Document Building Blocks|*.*|RECURSE - Renamed [Neverwinter*]Section=GamesDetect=HKCU\Software\Cryptic\NeverwinterDefault=FalseFileKey1=%ProgramFiles%\Steam\SteamApps\common\Cryptic Studios|*.log|RECURSEFileKey2=%ProgramFiles%\Steam\SteamApps\common\Cryptic Studios\localdata|_SWMWindowPosList.txtFileKey3=%SystemDrive%\Users\Public\Games\Cryptic Studios|*.log|RECURSEFileKey4=%SystemDrive%\Users\Public\Games\Cryptic Studios\localdata|_SWMWindowPosList.tx - Renamed - Added FileKeys1 and 2 [Norton Dumps*]LangSecRef=3024DetectFile=%CommonAppData%\Norton\LocalDumpsDefault=FalseFileKey1=%CommonAppData%\Norton\LocalDumps|*.dmpFileKey2=%LocalAppData%\VirtualStore\ProgramData\Norton\LocalDumps|*.dmp - Renamed [OpenRA (Logs and Replays)*]Section=GamesWarning=This will also remove your Replays!DetectFile=%Documents%\OpenRADefault=FalseFileKey1=%Documents%\OpenRA\Replays|*.*|RECURSEFileKey2=%Documents%\OpenRA\Logs|*.* - Renamed - Added FileKey1 [Private Internet Access VPN*]LangSecRef=3022DetectFile=%AppData%\Titanium\appdata\com.privateinternetaccess.vpnDefault=FalseFileKey1=%AppData%\Titanium\appdata\com.privateinternetaccess.vpn|*.logFileKey2=%ProgramFiles%\pia_manager\log|*.*FileKey3=%ProgramFiles%\pia_manager\tmp|*.* - Added FileKey3 [snagit 11 More*]LangSecRef=3024Detect=HKCU\Software\TechSmith\SnagIt\11Default=FalseWarning=This will delete the backups of the captures that you have performed with SnagIt 11.FileKey1=%LocalAppData%\TechSmith\Snagit\DataStore|*.sdf;*.SNAG;*.SNAGundo;*.MP4FileKey2=%Documents%\|SnagItDebug.logRegKey1=HKCU\Software\TechSmith\Snagit\11|CaptureCountRegKey2=HKCU\Software\TechSmith\Snagit\Stamps|StampCustomFolder - Removed FileKey1 [snagit 12 More*]LangSecRef=3024Detect=HKCU\Software\TechSmith\SnagIt\12Default=FalseWarning=This will delete the backups of the captures that you have performed with SnagIt 12.FileKey1=%LocalAppData%\TechSmith\Snagit\DataStore|*.sdf;*.SNAG;*.SNAGundo;*.MP4FileKey2=%Documents%\|SnagItDebug.logRegKey1=HKCU\Software\TechSmith\Snagit\12|CaptureCountRegKey2=HKCU\Software\TechSmith\Snagit\Stamps|StampCustomFolder - Removed FileKey1 - Tweaked new FileKey1[starCraft II Logs*]Section=GamesDetect=HKCU\Software\Blizzard Entertainment\StarCraft IIDefault=FalseFileKey1=%ProgramFiles%\Starcraft II\Logs|*.*FileKey2=%Public%\games\Starcraft II\Logs|*.*FileKey3=%SystemDrive%\Starcraft II\Logs|*.*FileKey4=%Documents%\StarCraft II\GameLogs|*.*|RECURSEFileKey5=%LocalAppData%\VirtualStore\Program Files*\Starcraft II\Logs|*.*FileKey6=%Documents%\StarCraft II\UserLogs|*.*|RECURSE - Added FileKey6 [steam Browser Cache*]Section=GamesDetect=HKCU\Software\Valve\SteamWarning=This will also delete the thumbnails and custom background images of the games in your Library.FileKey1=%ProgramFiles%\Steam\appcache\httpcache|*.*|RECURSEFileKey2=%ProgramFiles%\Steam\config\cookies|*.*|RECURSEFileKey3=%ProgramFiles%\Steam\config\htmlcache|*.*|RECURSEFileKey4=%ProgramFiles%\Steam\config\overlaycookies|*.*|RECURSEFileKey5=%ProgramFiles%\Steam\config\overlayhtmlcache|*.*|RECURSEFileKey6=%ProgramFiles%\Steam\userdata\*\ugcmsgcache|*.*|RECURSEFileKey7=%LocalAppData%\VirtualStore\Program Files*\Steam\appcache\httpcache|*.*|RECURSEFileKey8=%LocalAppData%\VirtualStore\Program Files*\Steam\config\cookies|*.*|RECURSEFileKey9=%LocalAppData%\VirtualStore\Program Files*\Steam\config\htmlcache|*.*|RECURSEFileKey10=%LocalAppData%\VirtualStore\Program Files*\Steam\config\overlaycookies|*.*|RECURSEFileKey11=%LocalAppData%\VirtualStore\Program Files*\Steam\config\overlayhtmlcache|*.*|RECURSE - Added FileKey6 [steam Logs*]Section=GamesDetect=HKCU\Software\Valve\SteamDefault=FalseFileKey1=%ProgramFiles%\Steam|*.log;*log.last;connection_log_*.txt;*_log.txt;remote_connections.txt;vr*_*.txt|RECURSEFileKey2=%ProgramFiles%\Steam|Steam.log;.crashFileKey3=%ProgramFiles%\Steam\SteamLogs|*.logFileKey4=%ProgramFiles%\Steam\vr\runtime\logs|*.*|RECURSEFileKey5=%AppData%\SteamVR\Logs|*.*|REMOVESELFFileKey6=%LocalAppData%\VirtualStore\Program Files*\Steam|*.log;*log.last;connection_log_*.txt;*_log.txt;remote_connections.txt;vr*_*.txt|RECURSEFileKey7=%LocalAppData%\VirtualStore\Program Files*\Steam|Steam.logFileKey8=%LocalAppData%\VirtualStore\Program Files*\Steam\SteamLogs|*.log - Improved FileKey2, removed outdated 'Valve' reference [Team Fortress 2 Cache and Cookies*]Section=GamesDetect=HKCU\Software\Valve\Steam\Apps\440Default=FalseFileKey1=%ProgramFiles%\Steam\SteamApps\common\Team Fortress 2\config\cookies|*.*|RECURSEFileKey2=%ProgramFiles%\Steam\SteamApps\common\Team Fortress 2\config\html\AppCache|*.*|RECURSEFileKey3=%ProgramFiles%\Steam\SteamApps\common\Team Fortress 2\tf\cache|*.*|RECURSEFileKey4=%ProgramFiles%\Steam\SteamApps\common\Team Fortress 2\tf\materials\temp|*.vtf|RECURSEFileKey5=%ProgramFiles%\Steam\SteamApps\common\Team Fortress 2\tf\download\user_custom|*.*|RECURSE - Added FileKey5 [VoidTools Search Everything Error Logs*]LangSecRef=3024DetectFile=%ProgramFiles%\EverythingDefault=FalseFileKey1=%AppData%\Everything|Errorlog.txt;Run History.csvFileKey2=%AppData%\Everything\Logs|*Log.txtFileKey3=%ProgramFiles%\Everything|Errorlog.txtFileKey4=%LocalAppData%\VirtualStore\Program Files*\Everything|Errorlog.txt - Renamed [VoidTools Search Everything (History)*]LangSecRef=3024Detect=HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\EverythingDetectFile=%AppData%\EverythingDefault=FalseFileKey1=%AppData%\Everything|*.csvFileKey2=%ProgramFiles%\Everything|*.txtFileKey3=%LocalAppData%\VirtualStore\Program Files*\Everything|*.txt - Renamed [Vuze More*]LangSecRef=3022Detect=HKCR\AzureusDefault=FalseFileKey1=%AppData%\Azureus\plugins\advancedstatistics|*.txtFileKey2=%AppData%\Azureus\plugins\progressbar|*.txtFileKey3=%ProgramFiles%\Vuze|*.logFileKey4=%ProgramFiles%\Vuze\.install4j|*.log - Added FileKeys [Windows Live Messenger More*]LangSecRef=3022Detect=HKLM\Software\Microsoft\Windows Live\MessengerDefault=FalseFileKey1=%CommonProgramFiles%\Windows Live\.cache|*.*|RECURSEFileKey2=%LocalAppData%\Microsoft\Messenger|*.uccapilog;*.bak;*.txt|RECURSEFileKey3=%LocalAppData%\Microsoft\Windows Live|*.log;*.jrs;*.sqm|RECURSEFileKey4=%LocalAppData%\Microsoft\Windows Live Contacts|*.log;*.jrs|RECURSEFileKey5=%LocalAppData%\Microsoft\Windows Live Contacts\*\*\*\Backup|*.*|RECURSEFileKey6=%ProgramFiles%\Windows Live\Messenger|*.bak|RECURSEFileKey7=%WinDir%\System32\config\systemprofile\Documents|wlidsvctrace*.txtFileKey8=%WinDir%\SysWOW64\config\systemprofile\Documents|wlidsvctrace*.txtFileKey9=%LocalAppData%\VirtualStore\Program Files*\Windows Live\Messenger|*.bak|RECURSEFileKey10=%LocalAppData%\VirtualStore\Program Files*\Common Files\Windows Live\.cache|*.*|RECURSEFileKey11=%CommonProgramFiles%\Windows Live\.cache|*.tmp - Added FileKey11 ------------------------------------------------------------------------------Removed Entries:[Adobe Updater ARM*]LangSecRef=3021Detect=HKCU\Software\AdobeDefault=FalseFileKey1=%CommonAppData%\Adobe\ARM|*.*|RECURSE[Firefox Console Log*]LangSecRef=3026SpecialDetect=DET_MOZILLADefault=FalseFileKey1=%AppData%\Mozilla\Firefox|console.log[Firefox Extensions Log*]LangSecRef=3026SpecialDetect=DET_MOZILLADefault=FalseFileKey1=%AppData%\Mozilla\Firefox\Profiles\*|extensions.log[iPhone Temporary Files*]LangSecRef=3023Detect=HKLM\Software\Apple Computer, Inc.\iTunesDefault=FalseFileKey1=%CommonAppData%\Apple Computer\iTunes\iPhone Temporary Files|*.*|RECURSEFileKey2=%LocalAppData%\VirtualStore\ProgramData\Apple Computer\iTunes\iPhone Temporary Files|*.*|RECURSE------------------------------------------------------------------------------ LMK what I missed winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
ROCKNROLL Posted January 26, 2015 Share Posted January 26, 2015 [Vuze More*]LangSecRef=3022Detect=HKCR\AzureusDefault=FalseFileKey1=%AppData%\Azureus\plugins\advancedstatistics|*.txtFileKey2=%AppData%\Azureus\plugins\progressbar|*.txtFileKey3=%ProgramFiles%\Vuze|*.logFileKey4=%ProgramFiles%\Vuze\.install4j|*.log - Added FileKeys Should say Added FileKey 3 and 4. Also, I would like to see the reasons why entries get removed. I am a maintainer for Winapp2. I also have a open-source group on Steam. http://steamcommunity.com/groups/opencommunity Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 26, 2015 Author Share Posted January 26, 2015 [Vuze More*] LangSecRef=3022 Detect=HKCR\Azureus Default=False FileKey1=%AppData%\Azureus\plugins\advancedstatistics|*.txt FileKey2=%AppData%\Azureus\plugins\progressbar|*.txt FileKey3=%ProgramFiles%\Vuze|*.log FileKey4=%ProgramFiles%\Vuze\.install4j|*.log - Added FileKeys Should say Added FileKey 3 and 4. Also, I would like to see the reasons why entries get removed. All the removed entries were merged into other entries or otherwise redundant because of other entries winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
JDPower Posted January 26, 2015 Share Posted January 26, 2015 Just a VERY minor point, cos I know it don't happen often, but would be handy if when an entry changes name you could state what from so we can find it in our existing file to replace easier Link to comment Share on other sites More sharing options...
SMalik Posted January 27, 2015 Share Posted January 27, 2015 Thanks for the update. Everything looks good except you forgot to change the name of [snagit 11 Local Dumps (.dmp)*] entry. [snagit 11 Local Dumps*]LangSecRef=3024Detect=HKCU\Software\TechSmith\SnagIt\11Default=FalseFileKey1=%LocalAppData%\TechSmith\Snagit\CrashDumps|*.* Link to comment Share on other sites More sharing options...
siliconman01 Posted January 27, 2015 Share Posted January 27, 2015 Modified Entry: [AVG PC TuneUp & TuneUp Utilities Reg Defrag Cleanup*] - Added SOFTWARE_tureg_new;SYSTEM_tureg_new to FileKey10 - Added FileKey13 - Added FileKey14 [AVG PC TuneUp & TuneUp Utilities Reg Defrag Cleanup*] LangSecRef=3024 Detect1=HKCU\Software\TuneUp\Utilities\10.0 Detect2=HKCU\Software\TuneUp\Utilities\12.0 Detect3=HKCU\Software\TuneUp\Utilities\13.0 Detect4=HKCU\Software\TuneUp\Utilities\14.0 Detect5=HKCU\Software\AVG\AWL\RegistryCleaner Default=False FileKey1=%LocalAppData%\Microsoft\Windows|USRCLASS.DAT_tureg_new.LOG*;USRCLASS.DAT_tureg_old FileKey2=%SystemDrive%\Boot|BCD_tureg_new.LOG*;BCD_tureg_old FileKey3=%SystemDrive%\Documents and Settings\LocalService|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_old FileKey4=%SystemDrive%\Documents and Settings\LocalService.NT*|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_old FileKey5=%SystemDrive%\Documents and Settings\NetworkService|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_old FileKey6=%SystemDrive%\Documents and Settings\NetworkService.NT*|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_old FileKey7=%UserProfile%|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_old FileKey8=%WinDir%\ServiceProfiles\LocalService|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_old FileKey9=%WinDir%\ServiceProfiles\NetworkService|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_old FileKey10=%WinDir%\System32\config|COMPONENTS_tureg_new.LOG*;COMPONENTS_tureg_old;DEFAULT_tureg_new.LOG*;DEFAULT_tureg_old;SAM_tureg_new.LOG*;SAM_tureg_old;SECURITY_tureg_new.LOG*;SECURITY_tureg_old;SOFTWARE_tureg_new.LOG*;SOFTWARE_tureg_old;SYSTEM_tureg_new.LOG*;SYSTEM_tureg_old;DRIVERS_tureg_new.LOG*;DRIVERS_tureg_old;SOFTWARE_tureg_new;SYSTEM_tureg_new FileKey11=%WinDir%\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Windows\|USRCLASS.DAT_tureg_old;USRCLASS.DAT_tureg_new.LOG* FileKey12=%WinDir%\ServiceProfiles\LocalService\AppData\Local\Microsoft\Windows\|USRCLASS.DAT_tureg_old;USRCLASS.DAT_tureg_new.LOG* FileKey13=%CommonAppData%|NTUSER.DAT_tureg_new.LOG1;NTUSER.DAT_tureg_new.LOG2;NTUSER.DAT_tureg_old FileKey14=%SystemDrive%\Users\Public|NTUSER.DAT_tureg_new.LOG1;NTUSER.DAT_tureg_new.LOG2;NTUSER.DAT_tureg_old Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
medmedin2014 Posted January 27, 2015 Share Posted January 27, 2015 I can't download Trim.bat from http://www.winapp2.com/trim.bat i get the following error: ForbiddenYou don't have permission to access /trim.bat on this server. Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request. Link to comment Share on other sites More sharing options...
ricktendo64 Posted January 27, 2015 Share Posted January 27, 2015 Updated Beyond Compare 3*, now works on all versions (3, 4, etc) [Beyond Compare*] LangSecRef=3021 Detect=HKCU\Software\Scooter Software\Beyond Compare Default=False FileKey1=%AppData%\Scooter Software\Beyond Compare*|*.bak;BCCommands.xml;BCSessions.xml Link to comment Share on other sites More sharing options...
APMichael Posted January 27, 2015 Share Posted January 27, 2015 Thanks for the update! Modified: Typo. [Java More*]LangSecRef=3022Detect=HKLM\Software\JavaSoft\Java Runtime EnvironmentDefault=FalseFileKey1=%AppData%\Sun\Java\Deployment\SystemCache|*.*|RECURSEFileKey2=%LocalAppData%\Sun\Java\Deployment\cache|*.*|RECURSEFileKey3=%LocalAppData%\Sun\Java\Deployment\SystemCache|*.*|RECURSEFileKey4=%LocalLowAppData%\Sun\Java\Deployment\SystemCache|*.*|RECURSEFileKey5=%WinDir%\System32\config\systemprofile\AppData\LocalLow\Sun\Java\Deployment\Cache|*.*|RECURSEFileKey6=%WinDir%\SysWOW64\config\systemprofile\AppData\LocalLow\Sun\Java\Deployment\Cache|*.*|RECURSEFileKey7=%ProgramFiles%\Java\jre*|*PATCH.ERRFileKey8=%ProgramFiles%\Java\jre*\lib\security|*.bakFileKey9=%LocalAppData%\VirtualStore\Program Files*\Java\jre*|*PATCH.ERRFileKey10=%LocalAppData%\VirtualStore\Program Files*\Java\jre*\lib\security|*.bak Modified: I think DetectFile should be: [MaceCraft PowerTools hosts backups*]LangSecRef=3024Default=FalseDetectFile=%ProgramFiles%\jv16 PowerTools *\jv16PT.exeFileKey1=%windir%\System32\drivers\etc|hosts_PTBackup*.bak Space before asterisk: [Windows Device Icon Downloads *] Remove: Already inside [internet Explorer 10/11] (FileKey7). [Windows WebCache**]LangSecRef=3025DetectFile=%LocalAppData%\Microsoft\Windows\WebCache\Default=FalseFileKey1=%LocalAppData%\Microsoft\Windows\WebCache|*.tmp Link to comment Share on other sites More sharing options...
dvdbane Posted January 28, 2015 Share Posted January 28, 2015 [VoidTools Search Everything Error Logs*] LangSecRef=3024 DetectFile=%ProgramFiles%\Everything Default=False FileKey1=%AppData%\Everything|Errorlog.txt;Run History.csv FileKey2=%AppData%\Everything\Logs|*Log.txt FileKey3=%ProgramFiles%\Everything|Errorlog.txt FileKey4=%LocalAppData%\VirtualStore\Program Files*\Everything|Errorlog.txt - Renamed [VoidTools Search Everything (History)*] LangSecRef=3024 Detect=HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\Everything DetectFile=%AppData%\Everything Default=False FileKey1=%AppData%\Everything|*.csv FileKey2=%ProgramFiles%\Everything|*.txt FileKey3=%LocalAppData%\VirtualStore\Program Files*\Everything|*.txt if you going to make it separate entries, then it should be like this [VoidTools Search Everything Error Logs*] LangSecRef=3024 DetectFile1=%ProgramFiles%\Everything DetectFile2=%AppData%\Everything Default=False FileKey1=%AppData%\Everything|*.txt FileKey2=%ProgramFiles%\Everything|*.txt FileKey3=%LocalAppData%\VirtualStore\Program Files*\Everything|*.txt [VoidTools Search Everything (History)*] LangSecRef=3024 DetectFile1=%ProgramFiles%\Everything DetectFile2=%AppData%\Everything Default=False FileKey1=%AppData%\Everything|*.csv FileKey2=%ProgramFiles%\Everything|*.csv changes - add DetectFile1,DetectFile2 - tweak FileKey according to entry name or you can use my combined entry here http://forum.piriform.com/index.php?showtopic=32310&page=235&do=findComment&comment=257393 usually it's hard to get error log and normally just a 2 line text file my history won't go to 1MB so i prefer it to be combine together you missed my [sUMo Database*] entry on the same post Link to comment Share on other sites More sharing options...
qsdewa Posted January 28, 2015 Share Posted January 28, 2015 I can't download Trim.bat from http://www.winapp2.com/trim.bat i get the following error:ForbiddenYou don't have permission to access /trim.bat on this server. Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request. Me too. I can't download any .bat files from winapp2.com Link to comment Share on other sites More sharing options...
CSGalloway Posted January 29, 2015 Share Posted January 29, 2015 I use {VOLDEMORT} and it wouldn't download the updated winapp2,ini so I had to finally use Chrome to download the INI to the desktop then move I to the CCleaner folder. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 29, 2015 Author Share Posted January 29, 2015 I use {VOLDEMORT} and it wouldn't download the updated winapp2,ini so I had to finally use Chrome to download the INI to the desktop then move I to the CCleaner folder. Shane has been travelling and hasn't had time to update the download on his end, where voldemort draws his magic from winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
CSGalloway Posted January 30, 2015 Share Posted January 30, 2015 I guess mentioning other party tools is against the rules? Sorry. | Shane has been travelling and hasn't had time to update the download on his end, where voldemort draws his magic from I would assume he just replaces the old winapp2.ini with the newer one. Hence the actually link does not change. I have heard people are having troubles downloading other files like Trim.bat - so I think it's a access rule that is not correct... Link to comment Share on other sites More sharing options...
