CSGalloway Posted April 6, 2015 Share Posted April 6, 2015 [Windows Live Setup Temp Files*]LangSecRef=3022Detect=HKLM\Software\Microsoft\Windows LiveDefault=FalseFileKey1=%CommonAppData%\Microsoft\WLSetup|*.tmpFileKey2=%LocalAppData%\VirtualStore\ProgramData\Microsoft\WLSetup|*.tmpFileKey3=%CommonProgramFiles%\Windows Live\.cache|*.tmp : Added FileKey3 Link to comment Share on other sites More sharing options...
CSGalloway Posted April 6, 2015 Share Posted April 6, 2015 New Entry: [jv16 PowerTools X Backup Files*] Revised Entry to incorporate jv16 PowerTools X. Plus shortened name a bit. [jv16 PowerTools X Backup Files*] LangSecRef=3024 DetectFile=%ProgramFiles%\jv16 PowerTools X\jv16PT.exe Default=False FileKey1=%ProgramFiles%\jv16 PowerTools X\Backups|*.*|RECURSE FileKey2=%ProgramFiles%\jv16 PowerTools X\Settings|UserActionLog.txt FileKey3=%LocalAppData%\VirtualStore\Program Files*\jv16 PowerTools X\Backups|*.*|RECURSE FileKey4=%LocalAppData%\VirtualStore\Program Files*\jv16 PowerTools X\Settings|UserActionLog.txt ExcludeKey1=FILE|%ProgramFiles%\jv16 PowerTools X\Backups\License.xbin_backup [jv16 PowerTools Reg Compact Backups*] LangSecRef=3024 DetectFile1=%ProgramFiles%\jv16 PowerTools 2009\jv16PT.exe DetectFile2=%ProgramFiles%\jv16 PowerTools 2010\jv16PT.exe DetectFile3=%ProgramFiles%\jv16 PowerTools 2011\jv16PT.exe DetectFile4=%ProgramFiles%\jv16 PowerTools 2012\jv16PT.exe DetectFile5=%ProgramFiles%\jv16 PowerTools 2013\jv16PT.exe DetectFile6=%ProgramFiles%\jv16 PowerTools 2014\jv16PT.exe DetectFile7=%ProgramFiles%\jv16 PowerTools X\jv16PT.exe Default=False Warning=This removes the registry hive backup files generated by jv16 PowerTools during a registry compaction. These files are not needed once the compaction is successfully completed. They can be safely deleted. NOTE that the system must be rebooted following a registry compaction completion in order for jv16 to release these files for deletion. FileKey1=%LocalAppData%\Microsoft\Windows|UsrClass.dat.jv16pt* FileKey2=%SystemDrive%\Documents and Settings\NetworkService|NTUSER.DAT.jv16pt* FileKey3=%SystemDrive%\Documents and Settings\LocalService|NTUSER.DAT.jv16pt* FileKey4=%SystemDrive%\Documents and Settings\NetworkService.NT*|NTUSER.DAT.jv16pt* FileKey5=%SystemDrive%\Documents and Settings\LocalService.NT*|NTUSER.DAT.jv16pt* FileKey6=%UserProfile%|NTUSER.DAT.jv16pt* FileKey7=%WinDir%\System32\config|Default.jv16pt*;software.jv16pt*;system.jv16pt*;SAM.jv16pt*;COMPONENTS.jv16pt* FileKey8=%WinDir%\ServiceProfiles\LocalService|NTUSER.DAT.jv16pt* FileKey9=%WinDir%\ServiceProfiles\NetworkService|NTUSER.DAT.jv16pt* Needs to include: C:\Program Files (x86)\jv16 PowerTools X\Backups\00019A\91F61065-CF82.tmp Link to comment Share on other sites More sharing options...
SMalik Posted April 9, 2015 Share Posted April 9, 2015 Revised Entry Added: RegKey1=HKCU\Software\Acelogix\Ace Utilities\Settings|UsageHistory [Ace Utilities*]LangSecRef=3024Detect=HKCU\Software\Acelogix\Ace UtilitiesDefault=FalseFileKey1=%Documents%\Ace Utilities Backups|*.regFileKey2=%LocalAppData%\Acelogix\Ace Utilities\Backups|*.regRegKey1=HKCU\Software\Acelogix\Ace Utilities\Settings|UsageHistory Link to comment Share on other sites More sharing options...
Coffee4Joe Posted April 9, 2015 Share Posted April 9, 2015 New [GnuCash*] LangSecRef=3021 Detect=HKCU\SOFTWARE\GSettings\org\gnucash\ Default=False Warning=This removes the last open history, auto saves and logs. RegKey1=HKCU\SOFTWARE\GSettings\org\gnucash\history FileKey1=%UserProfile%\*|*.gnucash.*.log|RECURSE FileKey2=%UserProfile%\*|*.gnucash.*.gnucash|RECURSE FileKey3=%UserProfile%\*|translog.*.log Not sure if you want to include FileKey1 &2. they are from the autosaving. There's no default folder for them, they use whichever location the user decides to save in. edit: added FileKey3 and accounts. should of been wildcard *. Link to comment Share on other sites More sharing options...
SMalik Posted April 11, 2015 Share Posted April 11, 2015 Revised Entry Changed LangSecRef from 3021 to 3023 [PhotoZoom Pro 6*]LangSecRef=3023Detect=HKCU\Software\BenVista\PhotoZoom Pro 6Default=FalseRegKey1=HKCU\Software\BenVista\PhotoZoom Pro 6|FileDirRegKey2=HKCU\Software\BenVista\PhotoZoom Pro 6\Recent Images Link to comment Share on other sites More sharing options...
SMalik Posted April 17, 2015 Share Posted April 17, 2015 Revised Entry Added: RegKey1=HKLM\SOFTWARE\Microsoft\Windows Search\VolumeInfoCache [MS Search More*]LangSecRef=3025Detect=HKCU\Software\Microsoft\WindowsDefault=FalseFileKey1=%CommonAppData%\Microsoft\Search\Data\Applications\Windows|Windows.edbFileKey2=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\GatherLogs\SystemIndex|*.*|RECURSEFileKey3=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\PropMap|*.*|RECURSEFileKey4=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\SecStore|*.*|RECURSEFileKey5=%LocalAppData%\VirtualStore\ProgramData\Microsoft\Search\Data\Applications\Windows|Windows.edbFileKey6=%LocalAppData%\VirtualStore\ProgramData\Microsoft\Search\Data\Applications\Windows\GatherLogs\SystemIndex|*.*|RECURSEFileKey7=%LocalAppData%\VirtualStore\ProgramData\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\PropMap|*.*|RECURSEFileKey8=%LocalAppData%\VirtualStore\ProgramData\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\SecStore|*.*|RECURSERegKey1=HKLM\SOFTWARE\Microsoft\Windows Search\VolumeInfoCache Link to comment Share on other sites More sharing options...
SMalik Posted April 17, 2015 Share Posted April 17, 2015 Revised EntryRe-arranged all the FileKeys in alphabetical order.[AVG 2015*]LangSecRef=3024Detect=HKLM\Software\AVG\AVG2015Default=FalseFileKey1=%CommonAppData%\AVG2015\log|*.log;*.log.lock;history.xmlFileKey2=%CommonAppData%\AVG2015\Emc\log|*.*FileKey3=%CommonAppData%\AVG2015\IDS\config|List.zip.bakFileKey4=%CommonAppData%\AVG2015\IDS\profile|globalLoadable.bakFileKey5=%CommonAppData%\AVG2015\scanlogs|*.logFileKey6=%CommonAppData%\AVG2015\SetupBackup|*.*|REMOVESELFFileKey7=%CommonAppData%\AVG2015\temp|*.*FileKey8=%CommonAppData%\AVG2015\update\backup|*.*FileKey9=%CommonAppData%\MFAData\logs|*.*FileKey10=%CommonAppData%\MFAData\pack|*.*FileKey11=%CommonAppData%\MFAData|msistorg.dat.bkp;public_installation_log.xmlFileKey12=%LocalAppData%\AVG2015\log|*.log;*.log.*FileKey13=%LocalAppData%\AVG2015\temp|*.*FileKey14=%LocalAppData%\AVG2015\update|*.*FileKey15=%LocalAppData%\MFAData\logs|*.*FileKey16=%ProgramFiles%\AVG\AVG2015|updatecomps.bak;*.oldFileKey17=%WinDir%\System32\config\systemprofile\AppData\Local\Avg2015\dumps|*.*FileKey18=%WinDir%\System32\config\systemprofile\AppData\Local\Avg2015\log|*.*FileKey19=%WinDir%\System32\config\systemprofile\AppData\Local\Avg2015\temp|*.*FileKey20=%WinDir%\System32\config\systemprofile\AppData\Local\MFAData\logs|*.*FileKey21=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Avg2015\dumps|*.*FileKey22=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Avg2015\log|*.*FileKey23=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Avg2015\temp|*.*FileKey24=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\MFAData\logs|*.*FileKey25=%WinDir%\System32\config\systemprofile\Local Settings\Application Data\Avg2015\dumps|*.*FileKey26=%WinDir%\System32\config\systemprofile\Local Settings\Application Data\log|*.*FileKey27=%WinDir%\System32\config\systemprofile\Local Settings\Application Data\temp|*.*FileKey28=%WinDir%\System32\config\systemprofile\Local Settings\MFAData\logs|*.*FileKey29=%WinDir%\SysWOW64\config\systemprofile\Local Settings\Application Data\dumps|*.*FileKey30=%WinDir%\SysWOW64\config\systemprofile\Local Settings\Application Data\log|*.*FileKey31=%WinDir%\SysWOW64\config\systemprofile\Local Settings\Application Data\temp|*.*FileKey32=%WinDir%\SysWOW64\config\systemprofile\Local Settings\MFAData\logs|*.* Link to comment Share on other sites More sharing options...
SMalik Posted April 20, 2015 Share Posted April 20, 2015 New Entry [Package Cache*]LangSecRef=3025Detect=HKCU\Software\Microsoft\WindowsDefault=FalseFileKey1=%CommonAppData%\Package Cache|*.*|RECURSE Link to comment Share on other sites More sharing options...
Moderators Nergal Posted April 20, 2015 Moderators Share Posted April 20, 2015 New Entry [Package Cache*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%CommonAppData%\Package Cache|*.*|RECURSE What is package cache? please observe the description convention and explain new entries and changes in your post (unless it's glaringly obvious). ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
siliconman01 Posted April 20, 2015 Share Posted April 20, 2015 What is package cache? please observe the description convention and explain new entries and changes in your post (unless it's glaringly obvious). There are websites that state files in Package Cache should not be deleted http://earthwithsun.com/questions/455853/can-i-delete-the-the-folder-c-programdata-package-cache Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted April 20, 2015 Moderators Share Posted April 20, 2015 There are websites that state files in Package Cache should not be deleted Thanks, good catch. That's what I thought, and why I asked. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
SMalik Posted April 20, 2015 Share Posted April 20, 2015 What is package cache? please observe the description convention and explain new entries and changes in your post (unless it's glaringly obvious). It holds cache of installed Microsoft Visual C++. Look at the attached snapshot as an example. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted April 21, 2015 Moderators Share Posted April 21, 2015 Other than your pc, do you have any evidence to counter this paragraph? When repairing, modifying, or uninstalling a product or when installing or uninstalling a patch, if source media is required the package cache is used automatically and most users will never see a prompt. Only if the package cache is missing or incomplete will Visual Studio setup will prompt to download (if connected) or locate mediaSource: http://blogs.msdn.com/b/heaths/archive/2012/07/26/how-visual-studio-2012-avoids-prompts-for-source.aspx ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
SMalik Posted April 21, 2015 Share Posted April 21, 2015 Other than your pc, do you have any evidence to counter this paragraph? Source: http://blogs.msdn.com/b/heaths/archive/2012/07/26/how-visual-studio-2012-avoids-prompts-for-source.aspx I'm not having an issue after removing this. I don't have the product (Visual Studio 2012 Ultimate) that is being discussed in the link. The cache of the products that I have removed are showing in the attached snapshot. Link to comment Share on other sites More sharing options...
JDPower Posted April 21, 2015 Share Posted April 21, 2015 It holds cache of installed Microsoft Visual C++. Look at the attached snapshot as an example. visualC++.png AND several driver installers (on my machine anyway), so I'll leave it rather than face the inevitable "installation source not found" type errors I'm not having an issue after removing this. You should give it a try yourself. Yet Link to comment Share on other sites More sharing options...
Moderators Nergal Posted April 21, 2015 Moderators Share Posted April 21, 2015 Have you attempted to do a repair install on VC after removal? ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
SMalik Posted April 21, 2015 Share Posted April 21, 2015 Have you attempted to do a repair install on VC after removal? Nope, everything is fine. Link to comment Share on other sites More sharing options...
SMalik Posted April 21, 2015 Share Posted April 21, 2015 I have revised this post. http://forum.piriform.com/index.php?showtopic=32310&p=260903 Link to comment Share on other sites More sharing options...
Moderators Andavari Posted April 21, 2015 Moderators Share Posted April 21, 2015 (edited) Do we really need FileKey1=%LocalAppData%\Microsoft\CD Burning|*.* ? I don't see this location anywhere on Win 7 or 8.1. I don't remember if it was on Vista. WinXP (taken from TweakUI as the default location): %userprofile%\Local Settings\Application Data\Microsoft\CD Burning In order for it to support XP it would need to remain. Edited April 21, 2015 by Andavari typo Link to comment Share on other sites More sharing options...
Winapp2.ini Posted April 24, 2015 Author Share Posted April 24, 2015 Update inbound; holding off on including the package cache for the time being! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Winapp2.ini Posted April 24, 2015 Author Share Posted April 24, 2015 Updated What's new in winapp2.ini 5.05.150423General:07 New Entries06 Modified Entries00 Removed EntriesNote: Change log excludes minor changes (mild pathing changes, key reordering, non-major key tweaks, etc)Verbose:------------------------------------------------------------------------------New Entries:[//N.P.P.D. RUSH//- The milk of Ultraviolet*]Section=GamesDetect=HKCU\Software\Valve\Steam\Apps\270090\Default=FalseFileKey1=%LocalAppData%\NPPDRUSH\Cache|*.*|RECURSEFileKey2=%LocalAppData%\NPPDRUSH\GPUCache|*.*|RECURSEFileKey3=%LocalAppData%\NPPDRUSH|Web Data*|RECURSE[10 Years After*]Section=GamesDetect=HKCU\Software\Valve\Steam\Apps\339240\Default=FalseFileKey1=%ProgramFiles%\Steam\SteamApps\common\10 Years After\10 Years After_Data|output_log.txtFileKey2=%LocalAppData%\VirtualStore\ProgramFiles*\Steam\SteamApps\common\10 Years After\10 Years After_Data|output_log.txt[1000 Amps*]Section=GamesDetect=HKCU\Software\Valve\Steam\Apps\205690\Default=FalseFileKey1=%ProgramFiles%\Steam\SteamApps\common\1000 Amps|stdout.txtFileKey2=%LocalAppData%\VirtualStore\ProgramFiles*\Steam\SteamApps\common\1000 Amps|stdout.txt[140*]Section=GamesDetect=HKCU\Software\Valve\Steam\Apps\242820\Default=FalseFileKey1=%ProgramFiles%\Steam\SteamApps\common\140\140_Data|output_log.txtFileKey2=%LocalAppData%\VirtualStore\ProgramFiles*\Steam\SteamApps\common\140\140_Data|output_log.txt[1954 Alcatraz*]Section=GamesDetect=HKCU\Software\Valve\Steam\Apps\255280\Default=FalseFileKey1=%ProgramFiles%\Steam\SteamApps\common\1954 Alcatraz\Alcatraz_Data|output_log.txtFileKey2=%LocalAppData%\VirtualStore\ProgramFiles*\Steam\SteamApps\common\1954 Alcatraz\Alcatraz_Data|output_log.txt[Action Center*]LangSecRef=3025Detect=HKCU\Software\Microsoft\Windows\CurrentVersion\Action CenterDefault=FalseRegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Action Center\ChecksRegKey2=HKCU\Software\Microsoft\Windows\CurrentVersion\Action Center\Providers\EventLog[GnuCash*]LangSecRef=3021Detect=HKCU\SOFTWARE\GSettings\org\gnucash\Default=FalseWarning=This removes the last open history, auto saves and logs.RegKey1=HKCU\SOFTWARE\GSettings\org\gnucash\historyFileKey1=%UserProfile%\*|*.gnucash.*.log;*.gnucash.*.gnucash;translog.*.log|RECURSE------------------------------------------------------------------------------Modified Entries:[Ace Utilities*]LangSecRef=3024Detect=HKCU\Software\Acelogix\Ace UtilitiesDefault=FalseFileKey1=%Documents%\Ace Utilities Backups|*.regFileKey2=%LocalAppData%\Acelogix\Ace Utilities\Backups|*.regRegKey1=HKCU\Software\Acelogix\Ace Utilities\Settings|UsageHistory - Added RegKey1[Dyn Updater*]LangSecRef=3022Detect=HKCU\Software\Dyn\Dyn UpdaterDefault=FalseFileKey1=%CommonAppData%\Dyn\Updater|*.log;*.msiFileKey2=%LocalAppData%\VirtualStore\ProgramData\Dyn\Updater|*.log;*.msi - Improved FileKey1 [MS Search More*]LangSecRef=3025Detect=HKCU\Software\Microsoft\WindowsDefault=FalseFileKey1=%CommonAppData%\Microsoft\Search\Data\Applications\Windows|Windows.edbFileKey2=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\GatherLogs\SystemIndex|*.*|RECURSEFileKey3=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\PropMap|*.*|RECURSEFileKey4=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\SecStore|*.*|RECURSEFileKey5=%LocalAppData%\VirtualStore\ProgramData\Microsoft\Search\Data\Applications\Windows|Windows.edbFileKey6=%LocalAppData%\VirtualStore\ProgramData\Microsoft\Search\Data\Applications\Windows\GatherLogs\SystemIndex|*.*|RECURSEFileKey7=%LocalAppData%\VirtualStore\ProgramData\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\PropMap|*.*|RECURSEFileKey8=%LocalAppData%\VirtualStore\ProgramData\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\SecStore|*.*|RECURSERegKey1=HKLM\SOFTWARE\Microsoft\Windows Search\VolumeInfoCache - Added RegKey1[skype Temporary Files*]LangSecRef=3022Detect=HKCU\Software\SkypeDefault=FalseFileKey1=%AppData%\Skype\DbTemp|*.*|RECURSEFileKey2=%AppData%\Skype|*.tmp|RECURSEFileKey3=%AppData%\Skype\|*.db-journal|RECURSEFileKey4=%AppData%\Skype\*\simcache|*.*FileKey5=%AppData%\Skype\*\httpfe|*.*FileKey6=%AppData%\Skype\*\ecache|*.*FileKey7=%AppData%\Skype\DataRv|*.*FileKey8=%AppData%\Skype\*\media_messaging\media_cache|*.*FileKey9=%AppData%\Skype\*\media_messaging\storage_db\asyncdb\tmp|*.*FileKey10=%AppData%\Skype\*\media_messaging\media_cache\asyncdb\tmp|*.*FileKey11=%AppData%\Skype\*\qikdb\tmp|*.*FileKey12=%AppData%\Skype\*\logs|*.*FileKey13=%UserProfile%\Tracing\WPPMedia\*.*|RECURSE - Added FileKey13 [Tribes: Ascend*]Section=GamesDetect=HKCU\Software\Valve\Steam\Apps\17080\Default=FalseFileKey1=%Documents%\My Games\Tribes Ascend\TribesGame\Logs|*.*FileKey2=%ProgramFiles%\Steam\steamapps\common\tribes\Binaries\Logs|*.*FileKey3=%LocalAppData%\VirtualStore\ProgramFiles*\Steam\steamapps\common\tribes\Binaries\Logs|*.* - Added FileKey3 [Windows Live Setup Temp Files*]LangSecRef=3022Detect=HKLM\Software\Microsoft\Windows LiveDefault=FalseFileKey1=%CommonAppData%\Microsoft\WLSetup|*.tmpFileKey2=%LocalAppData%\VirtualStore\ProgramData\Microsoft\WLSetup|*.tmpFileKey3=%CommonProgramFiles%\Windows Live\.cache|*.tmp - Added FileKey3 ------------------------------------------------------------------------------Removed Entries:------------------------------------------------------------------------------ Next update will likely include a sizable number of new gaming related entries winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted April 24, 2015 Share Posted April 24, 2015 New Entry [Realtek Install Files*]LangSecRef=3021Detect=HKLM\Software\RealtekDefault=FalseFileKey1=%ProgramFiles%\Realtek\Audio|*.InstallLogFileKey2=%ProgramFiles%\Temp|*.*|REMOVESELF Link to comment Share on other sites More sharing options...
SMalik Posted April 24, 2015 Share Posted April 24, 2015 Update inbound; holding off on including the package cache for the time being! Thanks for the update. Link to comment Share on other sites More sharing options...
SMalik Posted April 24, 2015 Share Posted April 24, 2015 New Entry [Acrobat Reader DC*]LangSecRef=3021Detect=HKCU\Software\Adobe\Acrobat Reader\DCDefault=FalseFileKey1=%ProgramFiles%\Adobe\Acrobat Reader DC\Setup Files|*.*|REMOVESELFFileKey2=%CommonAppData%\Adobe\Setup|*.*|REMOVESELFFileKey3=%LocalAppData%\Adobe\Acrobat\DC\Cache|*.*|RECURSERegKey1=HKCU\Software\Adobe\Acrobat Reader\DC\AVConversionFromPDFRegKey2=HKCU\Software\Adobe\Acrobat Reader\DC\AVConversionToPDFRegKey3=HKCU\Software\Adobe\Acrobat Reader\DC\AVGeneral\cDockablesRegKey4=HKCU\Software\Adobe\Acrobat Reader\DC\AVGeneral\cRecentFilesRegKey5=HKCU\Software\Adobe\Acrobat Reader\DC\AVGeneral\cToolbarsRegKey6=HKCU\Software\Adobe\Acrobat Reader\DC\RememberedViews\cNoCategoryFilesRegKey7=HKCU\Software\Adobe\Acrobat Reader\DC\ShareIdentityRegKey8=HKCU\Software\Adobe\Adobe Synchronizer\DC Link to comment Share on other sites More sharing options...
Moderators mta Posted April 25, 2015 Moderators Share Posted April 25, 2015 New Entry [Realtek Install Files*] LangSecRef=3021 Detect=HKLM\Software\Realtek Default=False FileKey1=%ProgramFiles%\Realtek\Audio|*.InstallLog FileKey2=%ProgramFiles%\Temp|*.*|REMOVESELF FileKey2 could be there for any number of reasons and probably shouldn't be included just for Realtek Install Files cleanup. Backup now & backup often.It's your digital life - protect it with a backup.Three things are certain; Birth, Death and loss of data. You control the last. Link to comment Share on other sites More sharing options...
