SMalik Posted June 9, 2015 Share Posted June 9, 2015 New Entry [Hauppauge WinTV 7*]LangSecRef=3024Detect=HKLM\SOFTWARE\Hauppauge\WinTV7Default=FalseFileKey1=%SystemDrive%\|hcwDriverInstall.txtFileKey2=%Public%\WinTV\Installation Log|*.txtFileKey3=%Public%\WinTV\Logs\minidump|*.*|RECURSE Link to comment Share on other sites More sharing options...
pcorbett Posted June 12, 2015 Share Posted June 12, 2015 Hello Can anyone assist me please on making a working entry in winapp2.ini. I wish to secure erase the list of USB storage entries in the registry when ccleaner runs. The area I am trying to erase is HKLM\SYSTEM\CurrentControlSet\Enum\USBSTOR and then a key like Disk&Ven_SanDisk&Prod_Cruzer&Rev_7.01 and all subsequent sub keys within that key. I have read up on the documents and wrote the following within winapp2.ini, but this is not erasing the key Disk&Ven_SanDisk&Prod_Cruzer&Rev_7.01. The key I was erasing is just a test usb drive that I inserted to test the script. [uSB Storage Devices]LangSecRef=3004LangRef=3125WarningRef=3203RegKey1=HKLM\SYSTEM\CurrentControlSet\Enum\USBSTOR\Disk&Ven_SanDisk&Prod_Cruzer&Rev_7.01 I have also tried using a | before Disk&Ven_ key. Can anyone assist me in this please. Is this correct or what am I missing to make this work ? Also why can you exclude a folder, file or registry entry, but and only include a folder or file in OPTIONS Thank you in Advance Link to comment Share on other sites More sharing options...
Moderators Nergal Posted June 12, 2015 Moderators Share Posted June 12, 2015 Hello Can anyone assist me please on making a working entry in winapp2.ini. Thank you in Advance You were missing a detect, which I added.I'm not familiar with WarningRef did I miss a new winapp2 type? [USB Storage Devices] LangSecRef=3004 LangRef=3125 WarningRef=3203 Detect=HKLM\SYSTEM\CurrentControlSet\Enum\USBSTOR\ RegKey1=HKLM\SYSTEM\CurrentControlSet\Enum\USBSTOR\Disk&Ven_SanDisk&Prod_Cruzer&Rev_7.01 Also currently you only seem to be removing the entry for one device ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
pcorbett Posted June 13, 2015 Share Posted June 13, 2015 Ok thanks mate. The USB entry was just one I had handy and was testing the script on it to see if it worked ok. The script was used off the documentation on the website and it had a reference to a warningref but I don't know what it referenced to. Thanks for the assist. I will test it out now Link to comment Share on other sites More sharing options...
JDPower Posted June 13, 2015 Share Posted June 13, 2015 The script was used off the documentation on the website and it had a reference to a warningref but I don't know what it referenced to You're right, I just looked, it is mentioned, but ONLY on THIS PAGE. I've never seen it used anywhere, so dunno if it's internal code that has been left in the documentation accidentally Link to comment Share on other sites More sharing options...
Winapp2.ini Posted June 15, 2015 Author Share Posted June 15, 2015 That warningref calls the Menu Order Cache warning. Guess it just references built in warnings (kind of like a special detect) winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted June 21, 2015 Share Posted June 21, 2015 Revised Entry Added: %Public%\Videos\Pause Buffer|*.*|RECURSE http://forum.piriform.com/index.php?showtopic=32310&p=263115 [Hauppauge WinTV 7*]LangSecRef=3024Detect=HKLM\SOFTWARE\Hauppauge\WinTV7Default=False FileKey1=%SystemDrive%\|hcwDriverInstall.txt FileKey2=%Public%\Videos\Pause Buffer|*.*|RECURSEFileKey3=%Public%\WinTV\Installation Log|*.txtFileKey4=%Public%\WinTV\Logs\minidump|*.*|RECURSE Link to comment Share on other sites More sharing options...
SMalik Posted June 21, 2015 Share Posted June 21, 2015 Revised Entries Added the highlighted ones. [Wondershare Dr.Fone for Android*]LangSecRef=3021Detect=HKLM\SOFTWARE\Wondershare\Dr.Fone for AndroidDefault=FalseFileKey1=%SystemDrive%\DrFoneForAndroid|*.*|REMOVESELFFileKey2=%ProgramFiles%\Wondershare\Dr.Fone for Android\log|*.*|RECURSEFileKey3=%CommonAppData%\Wondershare\DrFoneAndroid\Log|*.*|RECURSEFileKey4=%CommonAppData%\Wondershare\ProductFeatures\LocalLogs|*.*|RECURSEFileKey5=%CommonAppData%\Wondershare\ProductFeatures\RemoteLogs|*.*|RECURSEFileKey6=%LocalAppData%\VirtualStore\Program Files*\Wondershare\Dr.Fone for Android\log|*.*|RECURSE[Wondershare Dr.Fone for iOS*]LangSecRef=3021Detect=HKLM\SOFTWARE\Wondershare\Dr.Fone for iOSDefault=FalseFileKey1=%SystemDrive%\Wondershare_DrFone_Backup|*.*|REMOVESELFFileKey2=%CommonAppData%\Wondershare\Dr.Fone\log|*.*|RECURSEFileKey3=%CommonAppData%\Wondershare\ProductFeatures\LocalLogs|*.*|RECURSEFileKey4=%CommonAppData%\Wondershare\ProductFeatures\RemoteLogs|*.*|RECURSEFileKey5=%LocalAppData%\VirtualStore\ProgramData\Wondershare\Dr.Fone\log|*.*|RECURSE [Wondershare SafeEraser*]LangSecRef=3021Detect=HKLM\Software\Wondershare\SafeEraserDefault=FalseFileKey1=%SystemDrive%\se_tmp|*.*|REMOVESELFFileKey2=%ProgramFiles%\Wondershare\SafeEraser\se_tmp_win|*.*|REMOVESELFFileKey3=%AppData%\HYXDevPsnList|*.*|REMOVESELFFileKey4=%AppData%\se_tmp|*.*|REMOVESELFFileKey5=%AppData%\se_tmp_win|*.*|REMOVESELFFileKey6=%AppData%\Wondershare\SafeEraser|*.log Link to comment Share on other sites More sharing options...
SMalik Posted June 26, 2015 Share Posted June 26, 2015 New Entry [Logitech Unifying Software*]LangSecRef=3024Detect=HKCU\Software\Logitech\UnifyingDefault=FalseFileKey1=%CommonAppData%\LogiShrd\Unifying|*.txt Link to comment Share on other sites More sharing options...
Winapp2.ini Posted June 27, 2015 Author Share Posted June 27, 2015 updated - sorry for the delay What's new in winapp2.ini 5.07.150626 General: 04 New Entries32 Modified Entries02 Removed Entries Note: Change log excludes minor changes (mild pathing changes, key reordering, non-major key tweaks, etc) Verbose: ------------------------------------------------------------------------------ New Entries: [CyberLink Downloader*]LangSecRef=3023Detect=HKCU\Software\CyberLink\CLDownloaderDefault=FalseFileKey1=%CommonAppData%\CyberLink\CBE\*|*.*|RECURSEFileKey2=%CommonAppData%\CyberLink\Downloader|*.*|RECURSE [East-Tec Eraser*]LangSecRef=3024Detect=HKLM\Software\East-Tec\east-tec EraserDefault=FalseFileKey1=%ProgramFiles%\east-tec Eraser|except.logFileKey2=%CommonAppData%\East-Tec\east-tec Eraser\Updates|*.*|RECURSEFileKey3=%AppData%\East-Tec\east-tec Eraser|*.rst [Hauppauge WinTV 7*]LangSecRef=3024Detect=HKLM\SOFTWARE\Hauppauge\WinTV7Default=FalseFileKey1=%SystemDrive%\|hcwDriverInstall.txtFileKey2=%Public%\Videos\Pause Buffer|*.*|RECURSEFileKey3=%Public%\WinTV\Installation Log|*.txtFileKey4=%Public%\WinTV\Logs\minidump|*.*|RECURSE [VS Code*]LangSecRef=3021DetectFile=%AppData%\CodeDefault=FalseFileKey1=%AppData%\Code\GPUCache|*.*FileKey2=%AppData%\Code\Local Storage|*.*FileKey3=%AppData%\Code|cookies;cookies-journalFileKey4=%LocalAppData%\SquirrelTemp|*.log ------------------------------------------------------------------------------ Modified Entries: [Adobe Acrobat DC*]LangSecRef=3021Detect1=HKLM\SOFTWARE\Adobe\Adobe Acrobat\DCDetect2=HKCU\Software\Adobe\Adobe Acrobat\DCDefault=FalseFileKey1=%ProgramFiles%\Adobe\Acrobat DC\Setup Files|*.*|REMOVESELFFileKey2=%CommonAppData%\Adobe\Setup|*.*|REMOVESELFFileKey3=%LocalAppData%\Adobe\Acrobat|*.idx|RECURSEFileKey4=%LocalAppData%\Adobe\Acrobat\DC\Cache|*.*FileKey5=%LocalAppData%\Adobe\Acrobat\DC|UserCache.binRegKey1=HKCU\Software\Adobe\Adobe Acrobat\DC\AVConversionFromPDFRegKey2=HKCU\Software\Adobe\Adobe Acrobat\DC\AVConversionToPDFRegKey3=HKCU\Software\Adobe\Adobe Acrobat\DC\AVGeneral\cDockablesRegKey4=HKCU\Software\Adobe\Adobe Acrobat\DC\AVGeneral\cToolbarsRegKey5=HKCU\Software\Adobe\Adobe Acrobat\DC\RememberedViews\cNoCategoryFilesRegKey6=HKCU\Software\Adobe\Adobe Acrobat\DC\ShareIdentityRegKey7=HKCU\Software\Adobe\Adobe Synchronizer\DC- Revised entirely, removed lines included in CCleaner [Aimersoft Helper Compact*]LangSecRef=3021Detect=HKLM\SOFTWARE\Aimersoft\Aimersoft Helper CompactDefault=FalseFileKey1=%CommonProgramFiles%\Aimersoft\Aimersoft Helper Compact\DATADICT|*.*|RECURSEFileKey2=%CommonProgramFiles%\Aimersoft\Aimersoft Helper Compact\Log|*.*|RECURSEFileKey3=%CommonProgramFiles%\Aimersoft\Aimersoft Helper Compact\Temp|*.*|RECURSEFileKey4=%CommonProgramFiles%\Aimersoft\Aimersoft Helper Compact|ProductUpdateLists.xml;ASHelper.exe_temp;ASHelperSetup.exe_tempFileKey5=%LocalAppData%\VirtualStore\Program Files*\Common Files\Aimersoft\Aimersoft Helper Compact\Log|*.*|RECURSEFileKey6=%LocalAppData%\VirtualStore\Program Files*\Common Files\Aimersoft\Aimersoft Helper Compact\Temp|*.*|RECURSEFileKey7=%LocalAppData%\VirtualStore\Program Files*\Common Files\Aimersoft\Aimersoft Helper Compact|ProductUpdateLists.xml;ASHelper.exe_temp;ASHelperSetup.exe_tempRegKey1=HKLM\SOFTWARE\Aimersoft\Aimersoft Helper CompactRegKey2=HKLM\SOFTWARE\Wow6432Node\Aimersoft\Aimersoft Helper Compact - Added FileKey1- Added RegKey1 and 2[Application Cache*]LangSecRef=3029SpecialDetect=DET_CHROMEDetect1=HKCU\Software\TorchDetect2=HKCU\Software\SuperBirdDetect3=HKCU\Software\ChromiumDefault=FalseFileKey1=%LocalAppData%\Google\Chrome*\User Data\*\Application Cache|*.*|REMOVESELFFileKey2=%LocalAppData%\Chrome Plus\User Data\*\Application Cache|*.*|REMOVESELFFileKey3=%LocalAppData%\Chromium\User Data\*\Application Cache|*.*|REMOVESELFFileKey4=%LocalAppData%\Flock\User Data\*\Application Cache|*.*|REMOVESELFFileKey5=%LocalAppData%\Rockmelt\User Data\*\Application Cache|*.*|REMOVESELFFileKey6=%LocalAppData%\SRWare Iron\User Data\*\Application Cache|*.*|REMOVESELFFileKey7=%LocalAppData%\Torch\User Data\*\Application Cache|*.*|REMOVESELFFileKey8=%LocalAppData%\SuperBird\User Data\*\Application Cache|*.*|REMOVESELFFileKey9=%LocalAppData%\Amigo\User Data\*\Application Cache|*.*|REMOVESELF - Added FileKey9[Ashampoo Snap 8*]LangSecRef=3024Detect=HKCU\Software\Ashampoo\Ashampoo Snap 8Default=FalseFileKey1=%LocalAppData%\CrashRpt\UnsentCrashReports|*.*|RECURSEFileKey2=%AppData%\Ashampoo\Ashampoo Snap 8|*.*|RECURSEFileKey3=%ProgramFiles%\Ashampoo\Ashampoo Snap 8|_NLogMsg.txtFileKey4=%LocalAppData%\VirtualStore\Program Files*\Ashampoo\Ashampoo Snap 8|_NLogMsg.txt - Added FileKey4[Auslogics BoostSpeed 7*]LangSecRef=3024Detect=HKLM\Software\Auslogics\BoostSpeed\7.xDefault=FalseFileKey1=%CommonAppData%\Auslogics\BoostSpeed\7.x|*.err;*.htm;*.html;*.log;*.rsc;*.sta;*.xml|RECURSEFileKey2=%ProgramFiles%\Auslogics\Auslogics BoostSpeed|rdboot.logFileKey3=%LocalAppData%\VirtualStore\Program Files*\Auslogics\Auslogics BoostSpeed|rdboot.logRegKey1=HKLM\Software\Auslogics\BoostSpeed\7.x\Settings|DiskDefrag.DisksList.SelectedDrivesRegKey2=HKLM\Software\Auslogics\BoostSpeed\7.x\Settings|DiskDefrag.LastDefragment.DateTimeRegKey3=HKLM\Software\Auslogics\BoostSpeed\7.x\Settings|DiskDefrag.LastDefragment.DisksListRegKey4=HKLM\Software\Auslogics\BoostSpeed\7.x\Settings|DiskDefrag.LastDefragment.FilesCountRegKey5=HKLM\Software\Auslogics\BoostSpeed\7.x\Settings|RegCleaner.AppLogic.ErrorsFailedRegKey6=HKLM\Software\Auslogics\BoostSpeed\7.x\Settings|RegCleaner.AppLogic.ErrorsFoundRegKey7=HKLM\Software\Auslogics\BoostSpeed\7.x\Settings|RegCleaner.AppLogic.ErrorsRemovedRegKey8=HKLM\Software\Auslogics\BoostSpeed\7.x\Settings|RegCleaner.AppLogic.ErrorsRemovedTotalRegKey9=HKLM\Software\Auslogics\BoostSpeed\7.x\Settings|RegCleaner.AppLogic.LastScanRegKey10=HKLM\SOFTWARE\Wow6432Node\Auslogics\BoostSpeed\7.x\Settings|DiskDefrag.DisksList.SelectedDrivesRegKey11=HKLM\SOFTWARE\Wow6432Node\Auslogics\BoostSpeed\7.x\Settings|DiskDefrag.LastDefragment.DateTimeRegKey12=HKLM\SOFTWARE\Wow6432Node\Auslogics\BoostSpeed\7.x\Settings|DiskDefrag.LastDefragment.DisksListRegKey13=HKLM\SOFTWARE\Wow6432Node\Auslogics\BoostSpeed\7.x\Settings|DiskDefrag.LastDefragment.FilesCountRegKey14=HKLM\SOFTWARE\Wow6432Node\Auslogics\BoostSpeed\7.x\Settings|RegCleaner.AppLogic.ErrorsFailedRegKey15=HKLM\SOFTWARE\Wow6432Node\Auslogics\BoostSpeed\7.x\Settings|RegCleaner.AppLogic.ErrorsFoundRegKey16=HKLM\SOFTWARE\Wow6432Node\Auslogics\BoostSpeed\7.x\Settings|RegCleaner.AppLogic.ErrorsRemovedRegKey17=HKLM\SOFTWARE\Wow6432Node\Auslogics\BoostSpeed\7.x\Settings|RegCleaner.AppLogic.ErrorsRemovedTotalRegKey18=HKLM\SOFTWARE\Wow6432Node\Auslogics\BoostSpeed\7.x\Settings|RegCleaner.AppLogic.LastScan - Added FileKey3[backup*]LangSecRef=3029SpecialDetect=DET_CHROMEDefault=FalseFileKey1=%LocalAppData%\Google\Chrome*\Application|old_chrome.exeFileKey2=%ProgramFiles%\Google\Chrome*\Application|old_chrome.exeFileKey3=%LocalAppData%\Amigo\Application|old_amigo.exe - Added FileKey3 [battle.Net Client Logs*]Section=GamesDetect=HKCU\Software\Blizzard Entertainment\Battle.netDefault=FalseFileKey1=%CommonAppData%\Battle.net\Client\Blizzard Launcher.*\Logs|*.*|RECURSEFileKey2=%CommonAppData%\Battle.net\Client\Logs|*.*|RECURSEFileKey3=%LocalAppData%\Battle.Net\Logs|*.*|RECURSEFileKey4=%LocalAppData%\VirtualStore\ProgramData\Battle.net\Client\Blizzard Launcher.*\Logs|*.*|RECURSEFileKey5=%LocalAppData%\VirtualStore\ProgramData\Battle.net\Client\Logs|*.*|RECURSEFileKey6=%LocalAppData%\Blizzard Entertainment\System Survey|*.log|RECURSE - Added FileKey6[bookmark Backup*]LangSecRef=3029SpecialDetect=DET_CHROMEDetect1=HKCU\Software\TorchDetect2=HKCU\Software\SuperBirdDetect3=HKCU\Software\ChromiumDefault=FalseFileKey1=%LocalAppData%\Google\Chrome*\User Data\*|*Bookmarks.bakFileKey2=%LocalAppData%\Chrome Plus\User Data\*|*Bookmarks.bakFileKey3=%LocalAppData%\Chromium\User Data\*|*Bookmarks.bakFileKey4=%LocalAppData%\Flock\User Data\*|*Bookmarks.bakFileKey5=%LocalAppData%\Rockmelt\User Data\*|*Bookmarks.bakFileKey6=%LocalAppData%\SRWare Iron\User Data\*|*Bookmarks.bakFileKey7=%LocalAppData%\Torch\User Data\*|*Bookmarks.bakFileKey8=%LocalAppData%\SuperBird\User Data\*|*Bookmarks.bakFileKey9=%LocalAppData%\Amigo\User Data\Default\*|*Bookmarks.bak - Added FileKey9[CyberLink Crash Dumps*]LangSecRef=3023Detect=HKCU\Software\CyberLinkDefault=FalseFileKey1=%CommonAppData%\CyberLink\Boomerang\*\|*.xml;*.dmpFileKey2=%LocalAppData%\VirtualStore\ProgramData\CyberLink\Boomerang\*\|*.xml;*.dmpFileKey3=%CommonAppData%\CyberLink\PowerDVD15\Boomerang\*\|*.xml;*.dmpFileKey4=%LocalAppData%\VirtualStore\ProgramData\CyberLink\PowerDVD15\Boomerang\*\|*.xml;*.dmp - Added FileKey.3 and 4[Extensions State*]LangSecRef=3029SpecialDetect=DET_CHROMEDefault=FalseFileKey1=%LocalAppData%\Google\Chrome*\User Data\*\Extension State|*.*|RECURSEFileKey2=%LocalAppData%\Amigo\User Data\*\Extension State|*.*|RECURSE - Added FileKey2[FlashPlayer AssetCache*]LangSecRef=3029SpecialDetect=DET_CHROMEDetect1=HKCU\Software\TorchDetect2=HKCU\Software\SuperBirdDefault=FalseFileKey1=%LocalAppData%\Google\Chrome*\User Data\*\Pepper Data\Shockwave Flash\CacheWritableAdobeRoot\AssetCache|*.*|RECURSEFileKey2=%LocalAppData%\Chrome Plus\User Data\*\Pepper Data\Shockwave Flash\CacheWritableAdobeRoot\AssetCache|*.*|RECURSEFileKey3=%LocalAppData%\Chromium\User Data\*\Pepper Data\Shockwave Flash\CacheWritableAdobeRoot\AssetCache|*.*|RECURSEFileKey4=%LocalAppData%\Flock\User Data\*\Pepper Data\Shockwave Flash\CacheWritableAdobeRoot\AssetCache|*.*|RECURSEFileKey5=%LocalAppData%\Rockmelt\User Data\*\Pepper Data\Shockwave Flash\CacheWritableAdobeRoot\AssetCache|*.*|RECURSEFileKey6=%LocalAppData%\SRWare Iron\User Data\*\Pepper Data\Shockwave Flash\CacheWritableAdobeRoot\AssetCache|*.*|RECURSEFileKey7=%LocalAppData%\Torch\User Data\*\Pepper Data\Shockwave Flash\CacheWritableAdobeRoot\AssetCache|*.*|RECURSEFileKey8=%LocalAppData%\SuperBird\User Data\*\Pepper Data\Shockwave Flash\CacheWritableAdobeRoot\AssetCache|*.*|RECURSEFileKey9=%LocalAppData%\Amigo\User Data\*\Pepper Data\Shockwave Flash\CacheWritableAdobeRoot\AssetCache|*.*|RECURSE - Added FileKey9[FlashPlayer Settings*]LangSecRef=3029SpecialDetect=DET_CHROMEDetect1=HKCU\Software\TorchDetect2=HKCU\Software\SuperBirdDefault=FalseFileKey1=%LocalAppData%\Google\Chrome*\User Data\*\Pepper Data\Shockwave Flash\WritableRoot\macromedia.com|*.*|RECURSEFileKey2=%LocalAppData%\Chrome Plus\User Data\*\Pepper Data\Shockwave Flash\WritableRoot\macromedia.com|*.*|RECURSEFileKey3=%LocalAppData%\Chromium\User Data\*\Pepper Data\Shockwave Flash\WritableRoot\macromedia.com|*.*|RECURSEFileKey4=%LocalAppData%\Flock\User Data\*\Pepper Data\Shockwave Flash\WritableRoot\macromedia.com|*.*|RECURSEFileKey5=%LocalAppData%\Rockmelt\User Data\*\Pepper Data\Shockwave Flash\WritableRoot\macromedia.com|*.*|RECURSEFileKey6=%LocalAppData%\SRWare Iron\User Data\*\Pepper Data\Shockwave Flash\WritableRoot\macromedia.com|*.*|RECURSEFileKey7=%LocalAppData%\Torch\User Data\*\Pepper Data\Shockwave Flash\WritableRoot\macromedia.com|*.*|RECURSEFileKey8=%LocalAppData%\SuperBird\User Data\*\Pepper Data\Shockwave Flash\WritableRoot\macromedia.com|*.*|RECURSEFileKey9=%LocalAppData%\Amigo\User Data\*\Pepper Data\Shockwave Flash\WritableRoot\macromedia.com|*.*|RECURSE - Added FileKey9[FlashPlayer SharedObjects*]LangSecRef=3029SpecialDetect=DET_CHROMEDetect1=HKCU\Software\TorchDetect2=HKCU\Software\SuperBirdDefault=FalseFileKey1=%LocalAppData%\Google\Chrome*\User Data\*\Pepper Data\Shockwave Flash\WritableRoot\#SharedObjects|*.*|RECURSEFileKey2=%LocalAppData%\Chrome Plus\User Data\*\Pepper Data\Shockwave Flash\WritableRoot\#SharedObjects|*.*|RECURSEFileKey3=%LocalAppData%\Chromium\User Data\*\Pepper Data\Shockwave Flash\WritableRoot\#SharedObjects|*.*|RECURSEFileKey4=%LocalAppData%\Flock\User Data\*\Pepper Data\Shockwave Flash\WritableRoot\#SharedObjects|*.*|RECURSEFileKey5=%LocalAppData%\Rockmelt\User Data\*\Pepper Data\Shockwave Flash\WritableRoot\#SharedObjects|*.*|RECURSEFileKey6=%LocalAppData%\SRWare Iron\User Data\*\Pepper Data\Shockwave Flash\WritableRoot\#SharedObjects|*.*|RECURSEFileKey7=%LocalAppData%\Torch\User Data\*\Pepper Data\Shockwave Flash\WritableRoot\#SharedObjects|*.*|RECURSEFileKey8=%LocalAppData%\SuperBird\User Data\*\Pepper Data\Shockwave Flash\WritableRoot\#SharedObjects|*.*|RECURSEFileKey9=%LocalAppData%\Amigo\User Data\*\Pepper Data\Shockwave Flash\WritableRoot\#SharedObjects|*.*|RECURSE - Added FileKey9[GPU Cache*]LangSecRef=3029SpecialDetect=DET_CHROMEDetect1=HKCU\Software\TorchDetect2=HKCU\Software\SuperBirdDetect3=HKCU\Software\ChromiumDefault=FalseFileKey1=%LocalAppData%\Google\Chrome SxS\User Data\*\GPUCache|*.*FileKey2=%LocalAppData%\Chrome Plus\User Data\*\GPUCache|*.*FileKey3=%LocalAppData%\Chromium\User Data\*\GPUCache|*.*FileKey4=%LocalAppData%\Flock\User Data\*\GPUCache|*.*FileKey6=%LocalAppData%\Rockmelt\User Data\*\GPUCache|*.*FileKey7=%LocalAppData%\SRWare Iron\User Data\*\GPUCache|*.*FileKey8=%LocalAppData%\Torch\User Data\*\GPUCache|*.*FileKey9=%LocalAppData%\SuperBird\User Data\*\GPUCache|*.*FileKey10=%LocalAppData%\Amigo\User Data\*\GPUCache|*.* - Added FileKey10[html5 Storage*]LangSecRef=3029SpecialDetect=DET_CHROMEDetect1=HKCU\Software\TorchDetect2=HKCU\Software\SuperBirdDetect3=HKCU\Software\ChromiumDefault=FalseFileKey1=%LocalAppData%\Google\Chrome*\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSEFileKey2=%LocalAppData%\Chrome Plus\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSEFileKey3=%LocalAppData%\Chromium\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSEFileKey4=%LocalAppData%\Flock\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSEFileKey5=%LocalAppData%\Rockmelt\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSEFileKey6=%LocalAppData%\SRWare Iron\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSEFileKey7=%LocalAppData%\Torch\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSEFileKey8=%LocalAppData%\SuperBird\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSEFileKey9=%LocalAppData%\Amigo\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSE - Added FileKey9[intel Installation Logs*]LangSecRef=3024Detect1=HKCU\Software\IntelDetect2=HKLM\Software\IntelDefault=FalseFileKey1=%UserProfile%\Intel\Logs|*logFileKey2=%ProgramFiles%\Intel\InfInst|*.*|REMOVESELFFileKey3=%WinDir%\debug\intel\logs|*.*|REMOVESELFFileKey4=%WinDir%\SysWOW64\config\systemprofile\Intel\Logs|*.*|REMOVESELFFileKey5=%WinDir%\System32\config\systemprofile\Intel\Logs|*.*|REMOVESELFFileKey6=%LocalAppData%\VirtualStore\Program Files*\Intel\InfInst|*.*|REMOVESELFFileKey7=%CommonAppData%\intel|*.log|REMOVESELF - Removed FileKey1=%SystemDrive%\Intel*|*.*|REMOVESELF[iSkysoft Helper Compact*]LangSecRef=3021Detect=HKLM\Software\iSkysoft\iSkysoft Helper CompactDefault=FalseFileKey1=%CommonProgramFiles%\iSkysoft\iSkysoft Helper Compact\DATADICT|*.*|RECURSEFileKey2=%CommonProgramFiles%\iSkysoft\iSkysoft Helper Compact\log|*.*|RECURSEFileKey3=%CommonProgramFiles%\iSkysoft\iSkysoft Helper Compact\Temp|*.*|RECURSEFileKey4=%CommonProgramFiles%\iSkysoft\iSkysoft Helper Compact|ProductUpdateLists.xml;ISHelper.exe_temp;ISHelperSetup.exe_tempFileKey5=%LocalAppData%\VirtualStore\Program Files*\Common Files\iSkysoft\iSkysoft Helper Compact\log|*.*|RECURSEFileKey6=%LocalAppData%\VirtualStore\Program Files*\Common Files\iSkysoft\iSkysoft Helper Compact\Temp|*.*|RECURSEFileKey7=%LocalAppData%\VirtualStore\Program Files*\Common Files\iSkysoft\iSkysoft Helper Compact|ProductUpdateLists.xml;ISHelper.exe_temp;ISHelperSetup.exe_tempRegKey1=HKLM\SOFTWARE\iSkysoft\iSkysoft Helper CompactRegKey2=HKLM\SOFTWARE\Wow6432Node\iSkysoft\iSkysoft Helper Compact - Added FileKey1- Added RegKeys1 and 2[Local Storage*]LangSecRef=3029SpecialDetect=DET_CHROMEDetect1=HKCU\Software\TorchDetect2=HKCU\Software\SuperBirdDetect3=HKCU\Software\ChromiumDefault=FalseFileKey1=%LocalAppData%\Google\Chrome SxS\User Data\*\Local Storage|http*.*|RECURSEFileKey2=%LocalAppData%\Chrome Plus\User Data\*\Local Storage|http*.*|RECURSEFileKey3=%LocalAppData%\Chromium\User Data\*\Local Storage|http*.*|RECURSEFileKey4=%LocalAppData%\Flock\User Data\*\Local Storage|http*.*|RECURSEFileKey5=%LocalAppData%\Rockmelt\User Data\*\Local Storage|http*.*|RECURSEFileKey6=%LocalAppData%\SRWare Iron\User Data\*\Local Storage|http*.*|RECURSEFileKey7=%LocalAppData%\Torch\User Data\*\Local Storage|http*.*|RECURSEFileKey8=%LocalAppData%\SuperBird\User Data\*\Local Storage|http*.*|RECURSEFileKey9=%LocalAppData%\Amigo\User Data\*\Local Storage|http*.*|RECURSE - Added FileKey9[LogiShrd Logs*]LangSecRef=3021DetectFile=%AppData%\LogiShrdDefault=FalseFileKey1=%AppData%\LogiShrd\Updater|LuUpdater.log;UpdateList.csvFileKey2=%CommonAppData%\Logishrd\unifying|EngineLog.*FileKey3=%CommonAppData%\LogiShrd|*.log|RECURSEFileKey4=%LocalAppData%\VirtualStore\ProgramData\Logishrd\unifying|EngineLog.*FileKey5=%LocalAppData%\VirtualStore\ProgramData\LogiShrd|*.log|RECURSEFileKey6=%CommonAppData%\LogiShrd\Unifying|*.txt - Added FileKey6[Logs*]LangSecRef=3029SpecialDetect=DET_CHROMEDetect1=HKCU\Software\TorchDetect2=HKCU\Software\SuperBirdDefault=FalseFileKey1=%LocalAppData%\Google\Chrome*\Application|debug.logFileKey2=%LocalAppData%\Google\Chrome*\User Data\*|*LOG.*;Log;*.log;*.old|RECURSEFileKey3=%LocalAppData%\Chrome Plus\Application|debug.logFileKey4=%LocalAppData%\Chrome Plus\User Data\*|*LOG.*;Log;*.log;*.old|RECURSEFileKey5=%LocalAppData%\Chromium\Application|debug.logFileKey6=%LocalAppData%\Chromium\User Data\*|*LOG.*;Log;*.log;*.old|RECURSEFileKey7=%LocalAppData%\Flock\Application|debug.logFileKey8=%LocalAppData%\Flock\User Data\*|*LOG.*;Log;*.log;*.old|RECURSEFileKey9=%LocalAppData%\Rockmelt\Application|debug.logFileKey10=%LocalAppData%\Rockmelt\User Data\*|*LOG.*;Log;*.log;*.old|RECURSEFileKey11=%LocalAppData%\SRWare Iron\Application|debug.logFileKey12=%LocalAppData%\SRWare Iron\User Data\*|*LOG.*;Log;*.log;*.old|RECURSEFileKey13=%LocalAppData%\Torch\Application|debug.logFileKey14=%LocalAppData%\Torch\User Data\*|*LOG.*;Log;*.log;*.old|RECURSEFileKey15=%LocalAppData%\SuperBird\Application|debug.logFileKey16=%LocalAppData%\SuperBird\User Data\*|*LOG.*;Log;*.log;*.old|RECURSEFileKey17=%LocalAppData%\VirtualStore\Program Files*\Google\Chrome\Application|debug.logFileKey18=%LocalAppData%\Amigo\Application|debug.logFileKey19=%LocalAppData%\Amigo\User Data\*\*|*LOG.*;Log;*.log;*.old|RECURSEExcludeKey1=PATH|%LocalAppData%\Google\Chrome*\User Data\*\Local Extension Settings\|*.*ExcludeKey2=PATH|%LocalAppData%\Google\Chrome*\User Data\*\Local App Settings\|*.*ExcludeKey3=PATH|%LocalAppData%\Google\Chrome*\User Data\*\Extensions\|*.*ExcludeKey4=PATH|%LocalAppData%\Chrome Plus\User Data\*\Local Extension Settings\|*.*ExcludeKey5=PATH|%LocalAppData%\Chrome Plus\User Data\*\Local App Settings\|*.*ExcludeKey6=PATH|%LocalAppData%\Chrome Plus\User Data\*\Extensions\|*.*ExcludeKey7=PATH|%LocalAppData%\Chromium\User Data\*\Local Extension Settings\|*.*ExcludeKey8=PATH|%LocalAppData%\Chromium\User Data\*\Local App Settings\|*.*ExcludeKey9=PATH|%LocalAppData%\Chromium\User Data\*\Extensions\|*.*ExcludeKey10=PATH|%LocalAppData%\Flock\User Data\*\Local Extension Settings\|*.*ExcludeKey11=PATH|%LocalAppData%\Flock\User Data\*\Local App Settings\|*.*ExcludeKey12=PATH|%LocalAppData%\Flock\User Data\*\Extensions\|*.*ExcludeKey13=PATH|%LocalAppData%\Rockmelt\User Data\*\Local Extension Settings\|*.*ExcludeKey14=PATH|%LocalAppData%\Rockmelt\User Data\*\Local App Settings\|*.*ExcludeKey15=PATH|%LocalAppData%\Rockmelt\User Data\*\Extensions\|*.*ExcludeKey16=PATH|%LocalAppData%\SRWare Iron\User Data\*\Local Extension Settings\|*.*ExcludeKey17=PATH|%LocalAppData%\SRWare Iron\User Data\*\Local App Settings\|*.*ExcludeKey18=PATH|%LocalAppData%\SRWare Iron\User Data\*\Extensions\|*.*ExcludeKey19=PATH|%LocalAppData%\Torch\User Data\*\Local Extension Settings\|*.*ExcludeKey20=PATH|%LocalAppData%\Torch\User Data\*\Local App Settings\|*.*ExcludeKey21=PATH|%LocalAppData%\Torch\User Data\*\Extensions\|*.*ExcludeKey22=PATH|%LocalAppData%\Superbird\User Data\*\Local Extension Settings\|*.*ExcludeKey23=PATH|%LocalAppData%\Superbird\User Data\*\Local App Settings\|*.*ExcludeKey24=PATH|%LocalAppData%\Superbird\User Data\*\Extensions\|*.*ExcludeKey25=PATH|%LocalAppData%\Amigo\User Data\*\Local Extension Settings\|*.*ExcludeKey26=PATH|%LocalAppData%\Amigo\User Data\*\Local App Settings\|*.*ExcludeKey27=PATH|%LocalAppData%\Amigo\User Data\*\Extensions\|*.* - Added FileKeys18 and 19[Omnibox Shortcut*]LangSecRef=3029SpecialDetect=DET_CHROMEDefault=FalseFileKey1=%LocalAppData%\Google\Chrome*\User Data\*|ShortcutsFileKey2=%LocalAppData%\Amigo\User Data\*\*|Shortcuts - Added FileKey2 [Opera More*]LangSecRef=3027SpecialDetect=DET_OPERADefault=FalseFileKey1=%LocalAppData%\Opera\Opera*\application_cache|*.*|REMOVESELFFileKey2=%LocalAppData%\Opera\Opera*\icons|*.*|REMOVESELFFileKey3=%LocalAppData%\Opera\Opera*\Logs|*.*|REMOVESELFFileKey4=%LocalAppData%\Opera\Opera*\temporary_downloads|*.*|REMOVESELFFileKey5=%LocalAppData%\Opera\Opera*\thumbnails|*.*|REMOVESELFFileKey6=%LocalAppData%\Opera\Opera*\vps|*.*|REMOVESELFFileKey7=%AppData%\Opera Software\Opera Stable|Bookmarks.bakFileKey8=%AppData%\Opera Software\Opera Stable\Extension Cookies|*.*FileKey9=%AppData%\Opera Software\Opera Stable\Extension State|LOG.oldFileKey10=%AppData%\Opera Software\Opera Stable\File System\Origins|LOG.oldRegKey1=HKCU\Software\Opera Software|Last CommandLine v2 - Added FileKeys7-10 [Private Internet Access VPN*]LangSecRef=3022DetectFile=%AppData%\Titanium\appdata\com.privateinternetaccess.vpnDefault=FalseFileKey1=%AppData%\Titanium\appdata\com.privateinternetaccess.vpn|*.logFileKey2=%ProgramFiles%\pia_manager\log|*.*FileKey3=%ProgramFiles%\pia_manager\tmp|*.*FileKey4=%LocalAppData%\VirtualStore\Program Files*\pia_manager\log|*.*FileKey5=%LocalAppData%\VirtualStore\Program Files*\pia_manager\tmp|*.*FileKey6=%UserProfile%|.pia_manager_crash.log - Added FileKey4-6 [Razer Synapse*]LangSecRef=3024DetectFile=%CommonAppData%\Razer\SynapseDefault=FalseFileKey1=%CommonAppData%\Razer\Synapse\Logs|*.*FileKey2=%CommonAppData%\Razer\Synapse\Accounts\*\DataSync|SyncDate.txtFileKey3=%LocalAppData%\Razer\RzUninstallation\Logs|*.*FileKey4=%LocalAppData%\VirtualStore\ProgramData\Razer\Synapse\Logs|*.*FileKey5=%LocalAppData%\VirtualStore\ProgramData\Razer\Synapse\Accounts\*\DataSync|SyncDate.txtFileKey6=%CommonAppData%\Razer\InGameEngine\Logs|*.* - Added FileKey6[session Storage*]LangSecRef=3029SpecialDetect=DET_CHROMEDefault=FalseFileKey1=%LocalAppData%\Google\Chrome*\User Data\*\Session Storage|*.*|RECURSEFileKey2=%LocalAppData%\Amigo\User Data\*\Session Storage|*.*|RECURSE - Added FileKey2[Web Data*]LangSecRef=3029SpecialDetect=DET_CHROMEWarning=This will remove Autofill, Autocomplete, Search Engines keyword, Sign-in and Credit Card infoDefault=FalseFileKey1=%LocalAppData%\Google\Chrome*\User Data\*|Web DataFileKey2=%LocalAppData%\Amigo\User Data\*\*|Web Data - Added FileKey2[WebRTCIdentityStore*]LangSecRef=3029SpecialDetect=DET_CHROMEDefault=FalseFileKey1=%LocalAppData%\Google\Chrome\User Data\*|WebRTCIdentityStoreFileKey2=%LocalAppData%\Amigo\User Data\*\*|WebRTCIdentityStore - Added FileKey2 [Windows Compatibility Assistant*]LangSecRef=3025Detect=HKCU\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility AssistantDefault=FalseRegKey1=HKCU\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant\PersistedRegKey2=HKCU\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant\StoreRegKey3=HKCU\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\LayersRegKey4=HKLM\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\LayersRegKey5=HKU\.DEFAULT\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant\PersistedRegKey6=HKU\.DEFAULT\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant\Store - Added RegKeys3 and 4[Wondershare Dr.Fone for Android*]LangSecRef=3021Detect=HKLM\SOFTWARE\Wondershare\Dr.Fone for AndroidDefault=FalseFileKey1=%SystemDrive%\DrFoneForAndroid|*.*|REMOVESELFFileKey2=%ProgramFiles%\Wondershare\Dr.Fone for Android\log|*.*|RECURSEFileKey3=%CommonAppData%\Wondershare\DrFoneAndroid\Log|*.*|RECURSEFileKey4=%CommonAppData%\Wondershare\ProductFeatures\LocalLogs|*.*|RECURSEFileKey5=%CommonAppData%\Wondershare\ProductFeatures\RemoteLogs|*.*|RECURSEFileKey6=%LocalAppData%\VirtualStore\Program Files*\Wondershare\Dr.Fone for Android\log|*.*|RECURSE - Added FileKeys 3-5[Wondershare Dr.Fone for iOS*]LangSecRef=3021Detect=HKLM\SOFTWARE\Wondershare\Dr.Fone for iOSDefault=FalseFileKey1=%SystemDrive%\Wondershare_DrFone_Backup|*.*|REMOVESELFFileKey2=%CommonAppData%\Wondershare\Dr.Fone\log|*.*|RECURSEFileKey3=%CommonAppData%\Wondershare\ProductFeatures\LocalLogs|*.*|RECURSEFileKey4=%CommonAppData%\Wondershare\ProductFeatures\RemoteLogs|*.*|RECURSEFileKey5=%LocalAppData%\VirtualStore\ProgramData\Wondershare\Dr.Fone\log|*.*|RECURSE - Added FileKeys3 and 4[Wondershare Helper Compact*]LangSecRef=3021Detect=HKLM\Software\Wondershare\Wondershare Helper CompactDefault=FalseFileKey1=%CommonProgramFiles%\Wondershare\Wondershare Helper Compact\DATADICT|*.*|RECURSEFileKey2=%CommonProgramFiles%\Wondershare\Wondershare Helper Compact\Log|*.*|RECURSEFileKey3=%CommonProgramFiles%\Wondershare\Wondershare Helper Compact\Temp|*.*|RECURSEFileKey4=%CommonProgramFiles%\Wondershare\Wondershare Helper Compact|ProductUpdateLists.xml;WSHelper.exe_temp;WSHelperSetup.exe_tempFileKey5=%LocalAppData%\VirtualStore\Program Files*\Common Files\Wondershare\Wondershare Helper Compact\Log|*.*|RECURSEFileKey6=%LocalAppData%\VirtualStore\Program Files*\Common Files\Wondershare\Wondershare Helper Compact\Temp|*.*|RECURSEFileKey7=%LocalAppData%\VirtualStore\Program Files*\Common Files\Wondershare\Wondershare Helper Compact|ProductUpdateLists.xml;WSHelper.exe_temp;WSHelperSetup.exe_tempRegKey1=HKLM\Software\Wondershare\Wondershare Helper CompactRegKey2=HKLM\SOFTWARE\Wow6432Node\Wondershare\Wondershare Helper Compact - Added FileKey1- Added RegKeys1 and 2[Wondershare SafeEraser*]LangSecRef=3021Detect=HKLM\Software\Wondershare\SafeEraserDefault=FalseFileKey1=%SystemDrive%\se_tmp|*.*|REMOVESELFFileKey2=%ProgramFiles%\Wondershare\SafeEraser\se_tmp_win|*.*|REMOVESELFFileKey3=%AppData%\HYXDevPsnList|*.*|REMOVESELFFileKey4=%AppData%\se_tmp|*.*|REMOVESELFFileKey5=%AppData%\se_tmp_win|*.*|REMOVESELFFileKey6=%AppData%\Wondershare\SafeEraser|*.log - Added FileKey2------------------------------------------------------------------------------Removed Entries: [LibreOffice Recent List*]LangSecRef=3021Detect=HKLM\Software\LibreOfficeDefault=FalseWarning=Will also revert all custom settings to defaults.FileKey1=%AppData%\LibreOffice\*\User|*.xcu - Removed for deleting user settings [PowerDVD*]LangSecRef=3024Detect=HKCU\Software\Cyberlink\PowerDVDDefault=FalseFileKey1=%Documents%\CyberLink\PowerDVD|*.plsFileKey2=%ProgramFiles%\CyberLink\PowerDVD|*.plsFileKey3=%LocalAppData%\VirtualStore\Program Files*\CyberLink\PowerDVD|*.pls - Removed for removing user playlists ------------------------------------------------------------------------------ winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted June 27, 2015 Share Posted June 27, 2015 updated - sorry for the delay What's new in winapp2.ini 5.07.150626 General: 04 New Entries 32 Modified Entries 02 Removed Entries Note: Change log excludes minor changes (mild pathing changes, key reordering, non-major key tweaks, etc) Verbose: ------------------------------------------------------------------------------ New Entries: [CyberLink Downloader*] LangSecRef=3023 Detect=HKCU\Software\CyberLink\CLDownloader Default=False FileKey1=%CommonAppData%\CyberLink\CBE\*|*.*|RECURSE FileKey2=%CommonAppData%\CyberLink\Downloader|*.*|RECURSE [East-Tec Eraser*] LangSecRef=3024 Detect=HKLM\Software\East-Tec\east-tec Eraser Default=False FileKey1=%ProgramFiles%\east-tec Eraser|except.log FileKey2=%CommonAppData%\East-Tec\east-tec Eraser\Updates|*.*|RECURSE FileKey3=%AppData%\East-Tec\east-tec Eraser|*.rst [Hauppauge WinTV 7*] LangSecRef=3024 Detect=HKLM\SOFTWARE\Hauppauge\WinTV7 Default=False FileKey1=%SystemDrive%\|hcwDriverInstall.txt FileKey2=%Public%\Videos\Pause Buffer|*.*|RECURSE FileKey3=%Public%\WinTV\Installation Log|*.txt FileKey4=%Public%\WinTV\Logs\minidump|*.*|RECURSE [VS Code*] LangSecRef=3021 DetectFile=%AppData%\Code Default=False FileKey1=%AppData%\Code\GPUCache|*.* FileKey2=%AppData%\Code\Local Storage|*.* FileKey3=%AppData%\Code|cookies;cookies-journal FileKey4=%LocalAppData%\SquirrelTemp|*.log ------------------------------------------------------------------------------ Modified Entries: [Adobe Acrobat DC*] LangSecRef=3021 Detect1=HKLM\SOFTWARE\Adobe\Adobe Acrobat\DC Detect2=HKCU\Software\Adobe\Adobe Acrobat\DC Default=False FileKey1=%ProgramFiles%\Adobe\Acrobat DC\Setup Files|*.*|REMOVESELF FileKey2=%CommonAppData%\Adobe\Setup|*.*|REMOVESELF FileKey3=%LocalAppData%\Adobe\Acrobat|*.idx|RECURSE FileKey4=%LocalAppData%\Adobe\Acrobat\DC\Cache|*.* FileKey5=%LocalAppData%\Adobe\Acrobat\DC|UserCache.bin RegKey1=HKCU\Software\Adobe\Adobe Acrobat\DC\AVConversionFromPDF RegKey2=HKCU\Software\Adobe\Adobe Acrobat\DC\AVConversionToPDF RegKey3=HKCU\Software\Adobe\Adobe Acrobat\DC\AVGeneral\cDockables RegKey4=HKCU\Software\Adobe\Adobe Acrobat\DC\AVGeneral\cToolbars RegKey5=HKCU\Software\Adobe\Adobe Acrobat\DC\RememberedViews\cNoCategoryFiles RegKey6=HKCU\Software\Adobe\Adobe Acrobat\DC\ShareIdentity RegKey7=HKCU\Software\Adobe\Adobe Synchronizer\DC - Revised entirely, removed lines included in CCleaner [Aimersoft Helper Compact*] LangSecRef=3021 Detect=HKLM\SOFTWARE\Aimersoft\Aimersoft Helper Compact Default=False FileKey1=%CommonProgramFiles%\Aimersoft\Aimersoft Helper Compact\DATADICT|*.*|RECURSE FileKey2=%CommonProgramFiles%\Aimersoft\Aimersoft Helper Compact\Log|*.*|RECURSE FileKey3=%CommonProgramFiles%\Aimersoft\Aimersoft Helper Compact\Temp|*.*|RECURSE FileKey4=%CommonProgramFiles%\Aimersoft\Aimersoft Helper Compact|ProductUpdateLists.xml;ASHelper.exe_temp;ASHelperSetup.exe_temp FileKey5=%LocalAppData%\VirtualStore\Program Files*\Common Files\Aimersoft\Aimersoft Helper Compact\Log|*.*|RECURSE FileKey6=%LocalAppData%\VirtualStore\Program Files*\Common Files\Aimersoft\Aimersoft Helper Compact\Temp|*.*|RECURSE FileKey7=%LocalAppData%\VirtualStore\Program Files*\Common Files\Aimersoft\Aimersoft Helper Compact|ProductUpdateLists.xml;ASHelper.exe_temp;ASHelperSetup.exe_temp RegKey1=HKLM\SOFTWARE\Aimersoft\Aimersoft Helper Compact RegKey2=HKLM\SOFTWARE\Wow6432Node\Aimersoft\Aimersoft Helper Compact - Added FileKey1 - Added RegKey1 and 2 [Application Cache*] LangSecRef=3029 SpecialDetect=DET_CHROME Detect1=HKCU\Software\Torch Detect2=HKCU\Software\SuperBird Detect3=HKCU\Software\Chromium Default=False FileKey1=%LocalAppData%\Google\Chrome*\User Data\*\Application Cache|*.*|REMOVESELF FileKey2=%LocalAppData%\Chrome Plus\User Data\*\Application Cache|*.*|REMOVESELF FileKey3=%LocalAppData%\Chromium\User Data\*\Application Cache|*.*|REMOVESELF FileKey4=%LocalAppData%\Flock\User Data\*\Application Cache|*.*|REMOVESELF FileKey5=%LocalAppData%\Rockmelt\User Data\*\Application Cache|*.*|REMOVESELF FileKey6=%LocalAppData%\SRWare Iron\User Data\*\Application Cache|*.*|REMOVESELF FileKey7=%LocalAppData%\Torch\User Data\*\Application Cache|*.*|REMOVESELF FileKey8=%LocalAppData%\SuperBird\User Data\*\Application Cache|*.*|REMOVESELF FileKey9=%LocalAppData%\Amigo\User Data\*\Application Cache|*.*|REMOVESELF - Added FileKey9 [Ashampoo Snap 8*] LangSecRef=3024 Detect=HKCU\Software\Ashampoo\Ashampoo Snap 8 Default=False FileKey1=%LocalAppData%\CrashRpt\UnsentCrashReports|*.*|RECURSE FileKey2=%AppData%\Ashampoo\Ashampoo Snap 8|*.*|RECURSE FileKey3=%ProgramFiles%\Ashampoo\Ashampoo Snap 8|_NLogMsg.txt FileKey4=%LocalAppData%\VirtualStore\Program Files*\Ashampoo\Ashampoo Snap 8|_NLogMsg.txt - Added FileKey4 [Auslogics BoostSpeed 7*] LangSecRef=3024 Detect=HKLM\Software\Auslogics\BoostSpeed\7.x Default=False FileKey1=%CommonAppData%\Auslogics\BoostSpeed\7.x|*.err;*.htm;*.html;*.log;*.rsc;*.sta;*.xml|RECURSE FileKey2=%ProgramFiles%\Auslogics\Auslogics BoostSpeed|rdboot.log FileKey3=%LocalAppData%\VirtualStore\Program Files*\Auslogics\Auslogics BoostSpeed|rdboot.log RegKey1=HKLM\Software\Auslogics\BoostSpeed\7.x\Settings|DiskDefrag.DisksList.SelectedDrives RegKey2=HKLM\Software\Auslogics\BoostSpeed\7.x\Settings|DiskDefrag.LastDefragment.DateTime RegKey3=HKLM\Software\Auslogics\BoostSpeed\7.x\Settings|DiskDefrag.LastDefragment.DisksList RegKey4=HKLM\Software\Auslogics\BoostSpeed\7.x\Settings|DiskDefrag.LastDefragment.FilesCount RegKey5=HKLM\Software\Auslogics\BoostSpeed\7.x\Settings|RegCleaner.AppLogic.ErrorsFailed RegKey6=HKLM\Software\Auslogics\BoostSpeed\7.x\Settings|RegCleaner.AppLogic.ErrorsFound RegKey7=HKLM\Software\Auslogics\BoostSpeed\7.x\Settings|RegCleaner.AppLogic.ErrorsRemoved RegKey8=HKLM\Software\Auslogics\BoostSpeed\7.x\Settings|RegCleaner.AppLogic.ErrorsRemovedTotal RegKey9=HKLM\Software\Auslogics\BoostSpeed\7.x\Settings|RegCleaner.AppLogic.LastScan RegKey10=HKLM\SOFTWARE\Wow6432Node\Auslogics\BoostSpeed\7.x\Settings|DiskDefrag.DisksList.SelectedDrives RegKey11=HKLM\SOFTWARE\Wow6432Node\Auslogics\BoostSpeed\7.x\Settings|DiskDefrag.LastDefragment.DateTime RegKey12=HKLM\SOFTWARE\Wow6432Node\Auslogics\BoostSpeed\7.x\Settings|DiskDefrag.LastDefragment.DisksList RegKey13=HKLM\SOFTWARE\Wow6432Node\Auslogics\BoostSpeed\7.x\Settings|DiskDefrag.LastDefragment.FilesCount RegKey14=HKLM\SOFTWARE\Wow6432Node\Auslogics\BoostSpeed\7.x\Settings|RegCleaner.AppLogic.ErrorsFailed RegKey15=HKLM\SOFTWARE\Wow6432Node\Auslogics\BoostSpeed\7.x\Settings|RegCleaner.AppLogic.ErrorsFound RegKey16=HKLM\SOFTWARE\Wow6432Node\Auslogics\BoostSpeed\7.x\Settings|RegCleaner.AppLogic.ErrorsRemoved RegKey17=HKLM\SOFTWARE\Wow6432Node\Auslogics\BoostSpeed\7.x\Settings|RegCleaner.AppLogic.ErrorsRemovedTotal RegKey18=HKLM\SOFTWARE\Wow6432Node\Auslogics\BoostSpeed\7.x\Settings|RegCleaner.AppLogic.LastScan - Added FileKey3 [backup*] LangSecRef=3029 SpecialDetect=DET_CHROME Default=False FileKey1=%LocalAppData%\Google\Chrome*\Application|old_chrome.exe FileKey2=%ProgramFiles%\Google\Chrome*\Application|old_chrome.exe FileKey3=%LocalAppData%\Amigo\Application|old_amigo.exe - Added FileKey3 [battle.Net Client Logs*] Section=Games Detect=HKCU\Software\Blizzard Entertainment\Battle.net Default=False FileKey1=%CommonAppData%\Battle.net\Client\Blizzard Launcher.*\Logs|*.*|RECURSE FileKey2=%CommonAppData%\Battle.net\Client\Logs|*.*|RECURSE FileKey3=%LocalAppData%\Battle.Net\Logs|*.*|RECURSE FileKey4=%LocalAppData%\VirtualStore\ProgramData\Battle.net\Client\Blizzard Launcher.*\Logs|*.*|RECURSE FileKey5=%LocalAppData%\VirtualStore\ProgramData\Battle.net\Client\Logs|*.*|RECURSE FileKey6=%LocalAppData%\Blizzard Entertainment\System Survey|*.log|RECURSE - Added FileKey6 [bookmark Backup*] LangSecRef=3029 SpecialDetect=DET_CHROME Detect1=HKCU\Software\Torch Detect2=HKCU\Software\SuperBird Detect3=HKCU\Software\Chromium Default=False FileKey1=%LocalAppData%\Google\Chrome*\User Data\*|*Bookmarks.bak FileKey2=%LocalAppData%\Chrome Plus\User Data\*|*Bookmarks.bak FileKey3=%LocalAppData%\Chromium\User Data\*|*Bookmarks.bak FileKey4=%LocalAppData%\Flock\User Data\*|*Bookmarks.bak FileKey5=%LocalAppData%\Rockmelt\User Data\*|*Bookmarks.bak FileKey6=%LocalAppData%\SRWare Iron\User Data\*|*Bookmarks.bak FileKey7=%LocalAppData%\Torch\User Data\*|*Bookmarks.bak FileKey8=%LocalAppData%\SuperBird\User Data\*|*Bookmarks.bak FileKey9=%LocalAppData%\Amigo\User Data\Default\*|*Bookmarks.bak - Added FileKey9 [CyberLink Crash Dumps*] LangSecRef=3023 Detect=HKCU\Software\CyberLink Default=False FileKey1=%CommonAppData%\CyberLink\Boomerang\*\|*.xml;*.dmp FileKey2=%LocalAppData%\VirtualStore\ProgramData\CyberLink\Boomerang\*\|*.xml;*.dmp FileKey3=%CommonAppData%\CyberLink\PowerDVD15\Boomerang\*\|*.xml;*.dmp FileKey4=%LocalAppData%\VirtualStore\ProgramData\CyberLink\PowerDVD15\Boomerang\*\|*.xml;*.dmp - Added FileKey.3 and 4 [Extensions State*] LangSecRef=3029 SpecialDetect=DET_CHROME Default=False FileKey1=%LocalAppData%\Google\Chrome*\User Data\*\Extension State|*.*|RECURSE FileKey2=%LocalAppData%\Amigo\User Data\*\Extension State|*.*|RECURSE - Added FileKey2 [FlashPlayer AssetCache*] LangSecRef=3029 SpecialDetect=DET_CHROME Detect1=HKCU\Software\Torch Detect2=HKCU\Software\SuperBird Default=False FileKey1=%LocalAppData%\Google\Chrome*\User Data\*\Pepper Data\Shockwave Flash\CacheWritableAdobeRoot\AssetCache|*.*|RECURSE FileKey2=%LocalAppData%\Chrome Plus\User Data\*\Pepper Data\Shockwave Flash\CacheWritableAdobeRoot\AssetCache|*.*|RECURSE FileKey3=%LocalAppData%\Chromium\User Data\*\Pepper Data\Shockwave Flash\CacheWritableAdobeRoot\AssetCache|*.*|RECURSE FileKey4=%LocalAppData%\Flock\User Data\*\Pepper Data\Shockwave Flash\CacheWritableAdobeRoot\AssetCache|*.*|RECURSE FileKey5=%LocalAppData%\Rockmelt\User Data\*\Pepper Data\Shockwave Flash\CacheWritableAdobeRoot\AssetCache|*.*|RECURSE FileKey6=%LocalAppData%\SRWare Iron\User Data\*\Pepper Data\Shockwave Flash\CacheWritableAdobeRoot\AssetCache|*.*|RECURSE FileKey7=%LocalAppData%\Torch\User Data\*\Pepper Data\Shockwave Flash\CacheWritableAdobeRoot\AssetCache|*.*|RECURSE FileKey8=%LocalAppData%\SuperBird\User Data\*\Pepper Data\Shockwave Flash\CacheWritableAdobeRoot\AssetCache|*.*|RECURSE FileKey9=%LocalAppData%\Amigo\User Data\*\Pepper Data\Shockwave Flash\CacheWritableAdobeRoot\AssetCache|*.*|RECURSE - Added FileKey9 [FlashPlayer Settings*] LangSecRef=3029 SpecialDetect=DET_CHROME Detect1=HKCU\Software\Torch Detect2=HKCU\Software\SuperBird Default=False FileKey1=%LocalAppData%\Google\Chrome*\User Data\*\Pepper Data\Shockwave Flash\WritableRoot\macromedia.com|*.*|RECURSE FileKey2=%LocalAppData%\Chrome Plus\User Data\*\Pepper Data\Shockwave Flash\WritableRoot\macromedia.com|*.*|RECURSE FileKey3=%LocalAppData%\Chromium\User Data\*\Pepper Data\Shockwave Flash\WritableRoot\macromedia.com|*.*|RECURSE FileKey4=%LocalAppData%\Flock\User Data\*\Pepper Data\Shockwave Flash\WritableRoot\macromedia.com|*.*|RECURSE FileKey5=%LocalAppData%\Rockmelt\User Data\*\Pepper Data\Shockwave Flash\WritableRoot\macromedia.com|*.*|RECURSE FileKey6=%LocalAppData%\SRWare Iron\User Data\*\Pepper Data\Shockwave Flash\WritableRoot\macromedia.com|*.*|RECURSE FileKey7=%LocalAppData%\Torch\User Data\*\Pepper Data\Shockwave Flash\WritableRoot\macromedia.com|*.*|RECURSE FileKey8=%LocalAppData%\SuperBird\User Data\*\Pepper Data\Shockwave Flash\WritableRoot\macromedia.com|*.*|RECURSE FileKey9=%LocalAppData%\Amigo\User Data\*\Pepper Data\Shockwave Flash\WritableRoot\macromedia.com|*.*|RECURSE - Added FileKey9 [FlashPlayer SharedObjects*] LangSecRef=3029 SpecialDetect=DET_CHROME Detect1=HKCU\Software\Torch Detect2=HKCU\Software\SuperBird Default=False FileKey1=%LocalAppData%\Google\Chrome*\User Data\*\Pepper Data\Shockwave Flash\WritableRoot\#SharedObjects|*.*|RECURSE FileKey2=%LocalAppData%\Chrome Plus\User Data\*\Pepper Data\Shockwave Flash\WritableRoot\#SharedObjects|*.*|RECURSE FileKey3=%LocalAppData%\Chromium\User Data\*\Pepper Data\Shockwave Flash\WritableRoot\#SharedObjects|*.*|RECURSE FileKey4=%LocalAppData%\Flock\User Data\*\Pepper Data\Shockwave Flash\WritableRoot\#SharedObjects|*.*|RECURSE FileKey5=%LocalAppData%\Rockmelt\User Data\*\Pepper Data\Shockwave Flash\WritableRoot\#SharedObjects|*.*|RECURSE FileKey6=%LocalAppData%\SRWare Iron\User Data\*\Pepper Data\Shockwave Flash\WritableRoot\#SharedObjects|*.*|RECURSE FileKey7=%LocalAppData%\Torch\User Data\*\Pepper Data\Shockwave Flash\WritableRoot\#SharedObjects|*.*|RECURSE FileKey8=%LocalAppData%\SuperBird\User Data\*\Pepper Data\Shockwave Flash\WritableRoot\#SharedObjects|*.*|RECURSE FileKey9=%LocalAppData%\Amigo\User Data\*\Pepper Data\Shockwave Flash\WritableRoot\#SharedObjects|*.*|RECURSE - Added FileKey9 [GPU Cache*] LangSecRef=3029 SpecialDetect=DET_CHROME Detect1=HKCU\Software\Torch Detect2=HKCU\Software\SuperBird Detect3=HKCU\Software\Chromium Default=False FileKey1=%LocalAppData%\Google\Chrome SxS\User Data\*\GPUCache|*.* FileKey2=%LocalAppData%\Chrome Plus\User Data\*\GPUCache|*.* FileKey3=%LocalAppData%\Chromium\User Data\*\GPUCache|*.* FileKey4=%LocalAppData%\Flock\User Data\*\GPUCache|*.* FileKey6=%LocalAppData%\Rockmelt\User Data\*\GPUCache|*.* FileKey7=%LocalAppData%\SRWare Iron\User Data\*\GPUCache|*.* FileKey8=%LocalAppData%\Torch\User Data\*\GPUCache|*.* FileKey9=%LocalAppData%\SuperBird\User Data\*\GPUCache|*.* FileKey10=%LocalAppData%\Amigo\User Data\*\GPUCache|*.* - Added FileKey10 [html5 Storage*] LangSecRef=3029 SpecialDetect=DET_CHROME Detect1=HKCU\Software\Torch Detect2=HKCU\Software\SuperBird Detect3=HKCU\Software\Chromium Default=False FileKey1=%LocalAppData%\Google\Chrome*\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSE FileKey2=%LocalAppData%\Chrome Plus\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSE FileKey3=%LocalAppData%\Chromium\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSE FileKey4=%LocalAppData%\Flock\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSE FileKey5=%LocalAppData%\Rockmelt\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSE FileKey6=%LocalAppData%\SRWare Iron\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSE FileKey7=%LocalAppData%\Torch\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSE FileKey8=%LocalAppData%\SuperBird\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSE FileKey9=%LocalAppData%\Amigo\User Data\*\File System|*.log;*MANIFEST*;*.old|RECURSE - Added FileKey9 [intel Installation Logs*] LangSecRef=3024 Detect1=HKCU\Software\Intel Detect2=HKLM\Software\Intel Default=False FileKey1=%UserProfile%\Intel\Logs|*log FileKey2=%ProgramFiles%\Intel\InfInst|*.*|REMOVESELF FileKey3=%WinDir%\debug\intel\logs|*.*|REMOVESELF FileKey4=%WinDir%\SysWOW64\config\systemprofile\Intel\Logs|*.*|REMOVESELF FileKey5=%WinDir%\System32\config\systemprofile\Intel\Logs|*.*|REMOVESELF FileKey6=%LocalAppData%\VirtualStore\Program Files*\Intel\InfInst|*.*|REMOVESELF FileKey7=%CommonAppData%\intel|*.log|REMOVESELF - Removed FileKey1=%SystemDrive%\Intel*|*.*|REMOVESELF [iSkysoft Helper Compact*] LangSecRef=3021 Detect=HKLM\Software\iSkysoft\iSkysoft Helper Compact Default=False FileKey1=%CommonProgramFiles%\iSkysoft\iSkysoft Helper Compact\DATADICT|*.*|RECURSE FileKey2=%CommonProgramFiles%\iSkysoft\iSkysoft Helper Compact\log|*.*|RECURSE FileKey3=%CommonProgramFiles%\iSkysoft\iSkysoft Helper Compact\Temp|*.*|RECURSE FileKey4=%CommonProgramFiles%\iSkysoft\iSkysoft Helper Compact|ProductUpdateLists.xml;ISHelper.exe_temp;ISHelperSetup.exe_temp FileKey5=%LocalAppData%\VirtualStore\Program Files*\Common Files\iSkysoft\iSkysoft Helper Compact\log|*.*|RECURSE FileKey6=%LocalAppData%\VirtualStore\Program Files*\Common Files\iSkysoft\iSkysoft Helper Compact\Temp|*.*|RECURSE FileKey7=%LocalAppData%\VirtualStore\Program Files*\Common Files\iSkysoft\iSkysoft Helper Compact|ProductUpdateLists.xml;ISHelper.exe_temp;ISHelperSetup.exe_temp RegKey1=HKLM\SOFTWARE\iSkysoft\iSkysoft Helper Compact RegKey2=HKLM\SOFTWARE\Wow6432Node\iSkysoft\iSkysoft Helper Compact - Added FileKey1 - Added RegKeys1 and 2 [Local Storage*] LangSecRef=3029 SpecialDetect=DET_CHROME Detect1=HKCU\Software\Torch Detect2=HKCU\Software\SuperBird Detect3=HKCU\Software\Chromium Default=False FileKey1=%LocalAppData%\Google\Chrome SxS\User Data\*\Local Storage|http*.*|RECURSE FileKey2=%LocalAppData%\Chrome Plus\User Data\*\Local Storage|http*.*|RECURSE FileKey3=%LocalAppData%\Chromium\User Data\*\Local Storage|http*.*|RECURSE FileKey4=%LocalAppData%\Flock\User Data\*\Local Storage|http*.*|RECURSE FileKey5=%LocalAppData%\Rockmelt\User Data\*\Local Storage|http*.*|RECURSE FileKey6=%LocalAppData%\SRWare Iron\User Data\*\Local Storage|http*.*|RECURSE FileKey7=%LocalAppData%\Torch\User Data\*\Local Storage|http*.*|RECURSE FileKey8=%LocalAppData%\SuperBird\User Data\*\Local Storage|http*.*|RECURSE FileKey9=%LocalAppData%\Amigo\User Data\*\Local Storage|http*.*|RECURSE - Added FileKey9 [LogiShrd Logs*] LangSecRef=3021 DetectFile=%AppData%\LogiShrd Default=False FileKey1=%AppData%\LogiShrd\Updater|LuUpdater.log;UpdateList.csv FileKey2=%CommonAppData%\Logishrd\unifying|EngineLog.* FileKey3=%CommonAppData%\LogiShrd|*.log|RECURSE FileKey4=%LocalAppData%\VirtualStore\ProgramData\Logishrd\unifying|EngineLog.* FileKey5=%LocalAppData%\VirtualStore\ProgramData\LogiShrd|*.log|RECURSE FileKey6=%CommonAppData%\LogiShrd\Unifying|*.txt - Added FileKey6 [Logs*] LangSecRef=3029 SpecialDetect=DET_CHROME Detect1=HKCU\Software\Torch Detect2=HKCU\Software\SuperBird Default=False FileKey1=%LocalAppData%\Google\Chrome*\Application|debug.log FileKey2=%LocalAppData%\Google\Chrome*\User Data\*|*LOG.*;Log;*.log;*.old|RECURSE FileKey3=%LocalAppData%\Chrome Plus\Application|debug.log FileKey4=%LocalAppData%\Chrome Plus\User Data\*|*LOG.*;Log;*.log;*.old|RECURSE FileKey5=%LocalAppData%\Chromium\Application|debug.log FileKey6=%LocalAppData%\Chromium\User Data\*|*LOG.*;Log;*.log;*.old|RECURSE FileKey7=%LocalAppData%\Flock\Application|debug.log FileKey8=%LocalAppData%\Flock\User Data\*|*LOG.*;Log;*.log;*.old|RECURSE FileKey9=%LocalAppData%\Rockmelt\Application|debug.log FileKey10=%LocalAppData%\Rockmelt\User Data\*|*LOG.*;Log;*.log;*.old|RECURSE FileKey11=%LocalAppData%\SRWare Iron\Application|debug.log FileKey12=%LocalAppData%\SRWare Iron\User Data\*|*LOG.*;Log;*.log;*.old|RECURSE FileKey13=%LocalAppData%\Torch\Application|debug.log FileKey14=%LocalAppData%\Torch\User Data\*|*LOG.*;Log;*.log;*.old|RECURSE FileKey15=%LocalAppData%\SuperBird\Application|debug.log FileKey16=%LocalAppData%\SuperBird\User Data\*|*LOG.*;Log;*.log;*.old|RECURSE FileKey17=%LocalAppData%\VirtualStore\Program Files*\Google\Chrome\Application|debug.log FileKey18=%LocalAppData%\Amigo\Application|debug.log FileKey19=%LocalAppData%\Amigo\User Data\*\*|*LOG.*;Log;*.log;*.old|RECURSE ExcludeKey1=PATH|%LocalAppData%\Google\Chrome*\User Data\*\Local Extension Settings\|*.* ExcludeKey2=PATH|%LocalAppData%\Google\Chrome*\User Data\*\Local App Settings\|*.* ExcludeKey3=PATH|%LocalAppData%\Google\Chrome*\User Data\*\Extensions\|*.* ExcludeKey4=PATH|%LocalAppData%\Chrome Plus\User Data\*\Local Extension Settings\|*.* ExcludeKey5=PATH|%LocalAppData%\Chrome Plus\User Data\*\Local App Settings\|*.* ExcludeKey6=PATH|%LocalAppData%\Chrome Plus\User Data\*\Extensions\|*.* ExcludeKey7=PATH|%LocalAppData%\Chromium\User Data\*\Local Extension Settings\|*.* ExcludeKey8=PATH|%LocalAppData%\Chromium\User Data\*\Local App Settings\|*.* ExcludeKey9=PATH|%LocalAppData%\Chromium\User Data\*\Extensions\|*.* ExcludeKey10=PATH|%LocalAppData%\Flock\User Data\*\Local Extension Settings\|*.* ExcludeKey11=PATH|%LocalAppData%\Flock\User Data\*\Local App Settings\|*.* ExcludeKey12=PATH|%LocalAppData%\Flock\User Data\*\Extensions\|*.* ExcludeKey13=PATH|%LocalAppData%\Rockmelt\User Data\*\Local Extension Settings\|*.* ExcludeKey14=PATH|%LocalAppData%\Rockmelt\User Data\*\Local App Settings\|*.* ExcludeKey15=PATH|%LocalAppData%\Rockmelt\User Data\*\Extensions\|*.* ExcludeKey16=PATH|%LocalAppData%\SRWare Iron\User Data\*\Local Extension Settings\|*.* ExcludeKey17=PATH|%LocalAppData%\SRWare Iron\User Data\*\Local App Settings\|*.* ExcludeKey18=PATH|%LocalAppData%\SRWare Iron\User Data\*\Extensions\|*.* ExcludeKey19=PATH|%LocalAppData%\Torch\User Data\*\Local Extension Settings\|*.* ExcludeKey20=PATH|%LocalAppData%\Torch\User Data\*\Local App Settings\|*.* ExcludeKey21=PATH|%LocalAppData%\Torch\User Data\*\Extensions\|*.* ExcludeKey22=PATH|%LocalAppData%\Superbird\User Data\*\Local Extension Settings\|*.* ExcludeKey23=PATH|%LocalAppData%\Superbird\User Data\*\Local App Settings\|*.* ExcludeKey24=PATH|%LocalAppData%\Superbird\User Data\*\Extensions\|*.* ExcludeKey25=PATH|%LocalAppData%\Amigo\User Data\*\Local Extension Settings\|*.* ExcludeKey26=PATH|%LocalAppData%\Amigo\User Data\*\Local App Settings\|*.* ExcludeKey27=PATH|%LocalAppData%\Amigo\User Data\*\Extensions\|*.* - Added FileKeys18 and 19 [Omnibox Shortcut*] LangSecRef=3029 SpecialDetect=DET_CHROME Default=False FileKey1=%LocalAppData%\Google\Chrome*\User Data\*|Shortcuts FileKey2=%LocalAppData%\Amigo\User Data\*\*|Shortcuts - Added FileKey2 [Opera More*] LangSecRef=3027 SpecialDetect=DET_OPERA Default=False FileKey1=%LocalAppData%\Opera\Opera*\application_cache|*.*|REMOVESELF FileKey2=%LocalAppData%\Opera\Opera*\icons|*.*|REMOVESELF FileKey3=%LocalAppData%\Opera\Opera*\Logs|*.*|REMOVESELF FileKey4=%LocalAppData%\Opera\Opera*\temporary_downloads|*.*|REMOVESELF FileKey5=%LocalAppData%\Opera\Opera*\thumbnails|*.*|REMOVESELF FileKey6=%LocalAppData%\Opera\Opera*\vps|*.*|REMOVESELF FileKey7=%AppData%\Opera Software\Opera Stable|Bookmarks.bak FileKey8=%AppData%\Opera Software\Opera Stable\Extension Cookies|*.* FileKey9=%AppData%\Opera Software\Opera Stable\Extension State|LOG.old FileKey10=%AppData%\Opera Software\Opera Stable\File System\Origins|LOG.old RegKey1=HKCU\Software\Opera Software|Last CommandLine v2 - Added FileKeys7-10 [Private Internet Access VPN*] LangSecRef=3022 DetectFile=%AppData%\Titanium\appdata\com.privateinternetaccess.vpn Default=False FileKey1=%AppData%\Titanium\appdata\com.privateinternetaccess.vpn|*.log FileKey2=%ProgramFiles%\pia_manager\log|*.* FileKey3=%ProgramFiles%\pia_manager\tmp|*.* FileKey4=%LocalAppData%\VirtualStore\Program Files*\pia_manager\log|*.* FileKey5=%LocalAppData%\VirtualStore\Program Files*\pia_manager\tmp|*.* FileKey6=%UserProfile%|.pia_manager_crash.log - Added FileKey4-6 [Razer Synapse*] LangSecRef=3024 DetectFile=%CommonAppData%\Razer\Synapse Default=False FileKey1=%CommonAppData%\Razer\Synapse\Logs|*.* FileKey2=%CommonAppData%\Razer\Synapse\Accounts\*\DataSync|SyncDate.txt FileKey3=%LocalAppData%\Razer\RzUninstallation\Logs|*.* FileKey4=%LocalAppData%\VirtualStore\ProgramData\Razer\Synapse\Logs|*.* FileKey5=%LocalAppData%\VirtualStore\ProgramData\Razer\Synapse\Accounts\*\DataSync|SyncDate.txt FileKey6=%CommonAppData%\Razer\InGameEngine\Logs|*.* - Added FileKey6 [session Storage*] LangSecRef=3029 SpecialDetect=DET_CHROME Default=False FileKey1=%LocalAppData%\Google\Chrome*\User Data\*\Session Storage|*.*|RECURSE FileKey2=%LocalAppData%\Amigo\User Data\*\Session Storage|*.*|RECURSE - Added FileKey2 [Web Data*] LangSecRef=3029 SpecialDetect=DET_CHROME Warning=This will remove Autofill, Autocomplete, Search Engines keyword, Sign-in and Credit Card info Default=False FileKey1=%LocalAppData%\Google\Chrome*\User Data\*|Web Data FileKey2=%LocalAppData%\Amigo\User Data\*\*|Web Data - Added FileKey2 [WebRTCIdentityStore*] LangSecRef=3029 SpecialDetect=DET_CHROME Default=False FileKey1=%LocalAppData%\Google\Chrome\User Data\*|WebRTCIdentityStore FileKey2=%LocalAppData%\Amigo\User Data\*\*|WebRTCIdentityStore - Added FileKey2 [Windows Compatibility Assistant*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant Default=False RegKey1=HKCU\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant\Persisted RegKey2=HKCU\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant\Store RegKey3=HKCU\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers RegKey4=HKLM\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Layers RegKey5=HKU\.DEFAULT\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant\Persisted RegKey6=HKU\.DEFAULT\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant\Store - Added RegKeys3 and 4 [Wondershare Dr.Fone for Android*] LangSecRef=3021 Detect=HKLM\SOFTWARE\Wondershare\Dr.Fone for Android Default=False FileKey1=%SystemDrive%\DrFoneForAndroid|*.*|REMOVESELF FileKey2=%ProgramFiles%\Wondershare\Dr.Fone for Android\log|*.*|RECURSE FileKey3=%CommonAppData%\Wondershare\DrFoneAndroid\Log|*.*|RECURSE FileKey4=%CommonAppData%\Wondershare\ProductFeatures\LocalLogs|*.*|RECURSE FileKey5=%CommonAppData%\Wondershare\ProductFeatures\RemoteLogs|*.*|RECURSE FileKey6=%LocalAppData%\VirtualStore\Program Files*\Wondershare\Dr.Fone for Android\log|*.*|RECURSE - Added FileKeys 3-5 [Wondershare Dr.Fone for iOS*] LangSecRef=3021 Detect=HKLM\SOFTWARE\Wondershare\Dr.Fone for iOS Default=False FileKey1=%SystemDrive%\Wondershare_DrFone_Backup|*.*|REMOVESELF FileKey2=%CommonAppData%\Wondershare\Dr.Fone\log|*.*|RECURSE FileKey3=%CommonAppData%\Wondershare\ProductFeatures\LocalLogs|*.*|RECURSE FileKey4=%CommonAppData%\Wondershare\ProductFeatures\RemoteLogs|*.*|RECURSE FileKey5=%LocalAppData%\VirtualStore\ProgramData\Wondershare\Dr.Fone\log|*.*|RECURSE - Added FileKeys3 and 4 [Wondershare Helper Compact*] LangSecRef=3021 Detect=HKLM\Software\Wondershare\Wondershare Helper Compact Default=False FileKey1=%CommonProgramFiles%\Wondershare\Wondershare Helper Compact\DATADICT|*.*|RECURSE FileKey2=%CommonProgramFiles%\Wondershare\Wondershare Helper Compact\Log|*.*|RECURSE FileKey3=%CommonProgramFiles%\Wondershare\Wondershare Helper Compact\Temp|*.*|RECURSE FileKey4=%CommonProgramFiles%\Wondershare\Wondershare Helper Compact|ProductUpdateLists.xml;WSHelper.exe_temp;WSHelperSetup.exe_temp FileKey5=%LocalAppData%\VirtualStore\Program Files*\Common Files\Wondershare\Wondershare Helper Compact\Log|*.*|RECURSE FileKey6=%LocalAppData%\VirtualStore\Program Files*\Common Files\Wondershare\Wondershare Helper Compact\Temp|*.*|RECURSE FileKey7=%LocalAppData%\VirtualStore\Program Files*\Common Files\Wondershare\Wondershare Helper Compact|ProductUpdateLists.xml;WSHelper.exe_temp;WSHelperSetup.exe_temp RegKey1=HKLM\Software\Wondershare\Wondershare Helper Compact RegKey2=HKLM\SOFTWARE\Wow6432Node\Wondershare\Wondershare Helper Compact - Added FileKey1 - Added RegKeys1 and 2 [Wondershare SafeEraser*] LangSecRef=3021 Detect=HKLM\Software\Wondershare\SafeEraser Default=False FileKey1=%SystemDrive%\se_tmp|*.*|REMOVESELF FileKey2=%ProgramFiles%\Wondershare\SafeEraser\se_tmp_win|*.*|REMOVESELF FileKey3=%AppData%\HYXDevPsnList|*.*|REMOVESELF FileKey4=%AppData%\se_tmp|*.*|REMOVESELF FileKey5=%AppData%\se_tmp_win|*.*|REMOVESELF FileKey6=%AppData%\Wondershare\SafeEraser|*.log - Added FileKey2 ------------------------------------------------------------------------------ Removed Entries: [LibreOffice Recent List*] LangSecRef=3021 Detect=HKLM\Software\LibreOffice Default=False Warning=Will also revert all custom settings to defaults. FileKey1=%AppData%\LibreOffice\*\User|*.xcu - Removed for deleting user settings [PowerDVD*] LangSecRef=3024 Detect=HKCU\Software\Cyberlink\PowerDVD Default=False FileKey1=%Documents%\CyberLink\PowerDVD|*.pls FileKey2=%ProgramFiles%\CyberLink\PowerDVD|*.pls FileKey3=%LocalAppData%\VirtualStore\Program Files*\CyberLink\PowerDVD|*.pls - Removed for removing user playlists ------------------------------------------------------------------------------ Thanks for the update. This entry's name and detect should be changed. FileKey2 and FileKey6 are the same. [LogiShrd Logs*] LangSecRef=3021 DetectFile=%AppData%\LogiShrd Default=False FileKey1=%AppData%\LogiShrd\Updater|LuUpdater.log;UpdateList.csv FileKey2=%CommonAppData%\Logishrd\unifying|EngineLog.* FileKey3=%CommonAppData%\LogiShrd|*.log|RECURSE FileKey4=%LocalAppData%\VirtualStore\ProgramData\Logishrd\unifying|EngineLog.* FileKey5=%LocalAppData%\VirtualStore\ProgramData\LogiShrd|*.log|RECURSE FileKey6=%CommonAppData%\LogiShrd\Unifying|*.txt How about: [Logitech Logs*] LangSecRef=3021 Detect=HKCU\Software\Logitech Default=False FileKey1=%AppData%\LogiShrd\Updater|LuUpdater.log;UpdateList.csv FileKey2=%CommonAppData%\LogiShrd\Unifying|*.txt FileKey3=%CommonAppData%\LogiShrd|*.log|RECURSE FileKey4=%LocalAppData%\VirtualStore\ProgramData\Logishrd\unifying|*.txt FileKey5=%LocalAppData%\VirtualStore\ProgramData\LogiShrd|*.log|RECURSE Link to comment Share on other sites More sharing options...
APMichael Posted June 27, 2015 Share Posted June 27, 2015 updated - sorry for the delay You don't have to apologize. Thanks for the update! Missed posts: #4967 [Acrobat Reader DC*] and [Adobe Acrobat Distiller*] ( [Acrobat Reader DC*] and [Adobe Acrobat DC*] are different. ) #4988 ( and #4987. I can't comment those posts because I don't use Chrome. ) Link to comment Share on other sites More sharing options...
SMalik Posted June 27, 2015 Share Posted June 27, 2015 You don't have to apologize. Thanks for the update! Missed posts: #4967 [Acrobat Reader DC*] and [Adobe Acrobat Distiller*] ( [Acrobat Reader DC*] and [Adobe Acrobat DC*] are different. ) #4988 ( and #4987. I can't comment those posts because I don't use Chrome. ) The entries I mentioned in this post http://forum.piriform.com/index.php?showtopic=32310&p=262796 breaks some of the Chrome extensions. I have provided a solution in the post http://forum.piriform.com/index.php?showtopic=32310&p=262822 ,but they ignored it. Please look at the attached snapshot where one of the Chrome extension was broken because of those entries. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted June 27, 2015 Author Share Posted June 27, 2015 The entries I mentioned in this post http://forum.piriform.com/index.php?showtopic=32310&p=262796 breaks some of the Chrome extensions. I have provided a solution in the post http://forum.piriform.com/index.php?showtopic=32310&p=262822 ,but they ignored it. Please look at the attached snapshot where one of the Chrome extension was broken because of those entries. chrome_issue.png I can't reproduce this on windows 8.1.1 Pro x64 and Google Chrome Canary + Latest ABP. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted June 28, 2015 Share Posted June 28, 2015 Revised Entry Added: %CommonAppData%\Hauppauge|*.log [Hauppauge WinTV 7*]LangSecRef=3024Detect=HKLM\SOFTWARE\Hauppauge\WinTV7Default=FalseFileKey1=%SystemDrive%\|hcwDriverInstall.txtFileKey2=%CommonAppData%\Hauppauge|*.logFileKey3=%Public%\Videos\Pause Buffer|*.*|RECURSEFileKey4=%Public%\WinTV\Installation Log|*.txtFileKey5=%Public%\WinTV\Logs\minidump|*.*|RECURSE Link to comment Share on other sites More sharing options...
SMalik Posted July 2, 2015 Share Posted July 2, 2015 New Entry [Garmin Express*]LangSecRef=3024Detect=HKCU\Software\Garmin\ExpressDefault=FalseFileKey1=%CommonAppData%\Garmin\Logs|*.log;*.txt|RECURSE Revised Entry Changed LangSecRef from 3021 to 3024 [GARMIN MapSource*]LangSecRef=3024Detect=HKCU\Software\Garmin\MapSourceDefault=FalseFileKey1=%AppData%\GARMIN\MapSource\TileCache|*.*|REMOVESELF Link to comment Share on other sites More sharing options...
Stickz Posted July 4, 2015 Share Posted July 4, 2015 New Entries to add Nuclear Dawn Support. The average person can run these and reduce the game size by a few gigabytes. Anything which could conflict with certain types of users is disabled by default. The cache rebuilds automatically and custom content redownloads automatically, so is enabled by default. Edit 1: Add warnings about removing content. Edit 2: Add removal of custom content. Edit 3: Add removal of game tutorials. (most people run these once) Edit 4: Add removal of skirmish gamemode (un-played, some servers support re-downloading) Edit 5: Allow windows clients to remove garbage for linux/mac clients. [Nuclear Dawn Cache*] Section=Games Detect=HKCU\Software\Valve\Steam\Apps\17710 Default=True FileKey1=%ProgramFiles%\Steam\SteamApps\common\Nuclear Dawn\config\html|*.*|RECURSE FileKey2=%ProgramFiles%\Steam\SteamApps\common\Nuclear Dawn\nucleardawn\cache|*.*|RECURSE FileKey3=%ProgramFiles%\Steam\SteamApps\common\Nuclear Dawn\nucleardawn\materials\temp|*.vtf|RECURSE FileKey4=%ProgramFiles%\Steam\SteamApps\common\Nuclear Dawn\nucleardawn\downloads|*.*|RECURSE [Nuclear Dawn Custom Content*] Section=Games Detect=HKCU\Software\Valve\Steam\Apps\17710 Default=True Warning=Fixes verson mismatches, removes old custom map versions and removes old content. Redownload from server requried. FileKey1=%ProgramFiles%\Steam\SteamApps\common\Nuclear Dawn\nucleardawn\models|*.*|RECURSE FileKey2=%ProgramFiles%\Steam\SteamApps\common\Nuclear Dawn\nucleardawn\materials\models|*.*|RECURSE FileKey3=%ProgramFiles%\Steam\SteamApps\common\Nuclear Dawn\nucleardawn\materials\sprites|*.*|RECURSE FileKey4=%ProgramFiles%\Steam\SteamApps\common\Nuclear Dawn\nucleardawn\sound\quake|*.*|RECURSE FileKey5=%ProgramFiles%\Steam\SteamApps\common\Nuclear Dawn\nucleardawn\maps|*corner*;*roadwork*;*rock*;*frost*;*mars*|RECURSE [Nuclear Dawn Developer Files*] Section=Games Detect=HKCU\Software\Valve\Steam\Apps\17710 Default=False Warning=This will remove content used by game, map and community developers. FileKey1=%ProgramFiles%\Steam\SteamApps\common\Nuclear Dawn\sdk_content|*.*|REMOVESELF FileKey2=%ProgramFiles%\Steam\SteamApps\common\Nuclear Dawn\sdk_tools|*.*|REMOVESELF FileKey3=%ProgramFiles%\Steam\SteamApps\common\Nuclear Dawn\platform\AddOns|*.*|RECURSE FileKey4=%ProgramFiles%\Steam\SteamApps\common\Nuclear Dawn\nucleardawn\scripts\vehicles|*.*|REMOVESELF FileKey5=%ProgramFiles%\Steam\SteamApps\common\Nuclear Dawn\nucleardawn\scripts\units|*.*|REMOVESELF FileKey6=%ProgramFiles%\Steam\SteamApps\common\Nuclear Dawn\nucleardawn\scripts\scripted_props|*.*|REMOVESELF FileKey7=%ProgramFiles%\Steam\SteamApps\common\Nuclear Dawn\nucleardawn\maps|*example*|RECURSE FileKey8=%ProgramFiles%\Steam\SteamApps\common\Nuclear Dawn\nucleardawn\maps\ai_data|nd_codetest.nav|RECURSE FileKey9=%ProgramFiles%\Steam\SteamApps\common\Nuclear Dawn\bin|*bsp*;*vtex*;SDKLauncher.exe;modelbrowser.exe|RECURSE [Nuclear Dawn Demos/Screenshots*] Section=Games Detect=HKCU\Software\Valve\Steam\Apps\17710 Default=False Warning=This will remove all demos and screenshots which are not uploaded to steam cloud. FileKey1=%ProgramFiles%\Steam\SteamApps\common\Nuclear Dawn\nucleardawn\maps|*.dem*|RECURSE FileKey2=%ProgramFiles%\Steam\SteamApps\common\Nuclear Dawn\nucleardawn\donedemos|*.*|RECURSE FileKey3=%ProgramFiles%\Steam\SteamApps\common\Nuclear Dawn\nucleardawn\screenshots|*.*|RECURSE [Nuclear Dawn Mac/Linux Binaries*] Section=Games DetectOS=6.0| Detect=HKCU\Software\Valve\Steam\Apps\17710 Default=False Warning=This will remove mac and linux binaries. (designed for Windows ONLY) FileKey1=%ProgramFiles%\Steam\SteamApps\common\Nuclear Dawn\nucleardawn\bin|client.so;client.dylib|RECURSE [Nuclear Dawn SK Gamemode*] Section=Games Detect=HKCU\Software\Valve\Steam\Apps\17710 Default=False Warning=Redownload of skrimish gamemode required to play. Not supported by all servers. FileKey1=%ProgramFiles%\Steam\SteamApps\common\Nuclear Dawn\nucleardawn\maps|*sk_*|RECURSE [Nuclear Dawn Tutorials*] Section=Games Detect=HKCU\Software\Valve\Steam\Apps\17710 Default=False Warning=This will prevent running of Nuclear Dawn Tutorials but will free over 850mb of disk space. FileKey1=%ProgramFiles%\Steam\SteamApps\common\Nuclear Dawn\nucleardawn\media|*tutorial*|RECURSE FileKey2=%ProgramFiles%\Steam\SteamApps\common\Nuclear Dawn\nucleardawn\maps|*training*|RECURSE FileKey3=%ProgramFiles%\Steam\SteamApps\common\Nuclear Dawn\nucleardawn\maps\ai_data|*training*|RECURSE FileKey4=%ProgramFiles%\Steam\SteamApps\common\Nuclear Dawn\nucleardawn\sound\voices\tutorial|*.*|REMOVESELF Link to comment Share on other sites More sharing options...
SMalik Posted July 5, 2015 Share Posted July 5, 2015 Revised Entry Changed the Detect from HKCU\Software\Microsoft\ASP.NET as this path in not available. [ASP.NET*]LangSecRef=3025Detect=HKLM\SOFTWARE\Microsoft\ASP.NETDefault=FalseFileKey1=%WinDir%\Microsoft.net\Framework\*\Temporary ASP.NET Files|*.*|RECURSEFileKey2=%WinDir%\Microsoft.net\Framework64\*\Temporary ASP.NET Files|*.*|RECURSE Link to comment Share on other sites More sharing options...
SMalik Posted July 5, 2015 Share Posted July 5, 2015 New Entry [stored MIME Types*]LangSecRef=3025Detect=HKCU\Software\Microsoft\Windows Default=FalseRegKey1=HKCU\Software\Classes\MIME\Database\Content Type Link to comment Share on other sites More sharing options...
SMalik Posted July 9, 2015 Share Posted July 9, 2015 Revised Entry Changed: Detect=HKLM\Software\Wow6432Node\Microsoft\Windows\CurrentVersion\Uninstall\Greenshot_is1Corrected/Replaced: FileKey1=%AppData%\Greenshot|*.log[Greenshot*]LangSecRef=3024DetectFile=%AppData%\GreenshotDefault=FalseFileKey1=%LocalAppData%\Greenshot|*.log Link to comment Share on other sites More sharing options...
siliconman01 Posted July 10, 2015 Share Posted July 10, 2015 Below are a list of names that need to changed to accommodate Windows 10. [Windows 7/8/10 MUICache*] [Windows 7/8/10 QuickLaunch*] [Windows 7/8/10 ShellBags*] [Windows 8/10 ScreenShot Index*] [Windows 8/10 Search History*] [Windows 8/10 Sharing MFU*] [Windows 8/10 Start Menu Cache*] These are showing up in CCleaner on my Windows 10 x64 Pro Tech Preview Build 10166 systems. In checking the code, it does appear that they all apply to Windows 10. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
SMalik Posted July 11, 2015 Share Posted July 11, 2015 Some entries under the Windows category/button have the words "Windows 7/8, Windows 8 and Windows". I think these words should be removed because they're already under the Windows category/button. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted July 11, 2015 Author Share Posted July 11, 2015 [Windows 7/8 ShellBags*]DetectOS=6.1|LangSecRef=3025Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\ShellDefault=FalseWarning=This will delete window size, window position and view setting of all folders.RegKey1=HKCR\Local Settings\Software\Microsoft\Windows\Shell\BagMRURegKey2=HKCR\Local Settings\Software\Microsoft\Windows\Shell\Bags [Windows XP ShellBags*]DetectOS=|5.1LangSecRef=3025Detect=HKCU\Software\Microsoft\Windows\ShellNoRoamDefault=FalseWarning=This will delete window size, window position and view setting of all folders.RegKey1=HKCU\Software\Microsoft\Windows\ShellNoRoam\BagMRURegKey2=HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags If we remove the windows version from the two, we'll have an error. I'm not personally sure whether the two can be safely combined, perhaps someone else knows? winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
dvdbane Posted July 12, 2015 Share Posted July 12, 2015 just do it like browser entries http://forum.piriform.com/index.php?showtopic=32310&page=241&do=findComment&comment=259118 Link to comment Share on other sites More sharing options...
Moderators Nergal Posted July 12, 2015 Moderators Share Posted July 12, 2015 just do it like browser entries http://forum.piriform.com/index.php?showtopic=32310&page=241&do=findComment&comment=259118 I don't understand what you are suggesting, the post I read was refuted by the same logic as winapp2 (user) just provided. Two entries (whether or not both entries are detected I believe) can not share a name as on will be overruled (I assume the first in the file gets priority). If you can (or anyone) prove that combining them (I.e. xp shellbags and Vista/7/8 and 10) cause no issue on all effected OS versions (in this case xp Sp2(with hotfix) through windows 10) then they can be merged and "windows" removed from the name ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
