SMalik Posted April 25, 2015 Share Posted April 25, 2015 FileKey2 could be there for any number of reasons and probably shouldn't be included just for Realtek Install Files cleanup. It's a hidden empty directory. Realtek High Definition Audio driver installation creates this directory. I have tested this by uninstalling and re-installing Realtek High Definition Audio driver a few times. I use a program that monitors installations. I have notified Realtek about this empty directory. Link to comment Share on other sites More sharing options...
APMichael Posted April 25, 2015 Share Posted April 25, 2015 New Entry [Acrobat Reader DC*] LangSecRef=3021 Detect=HKCU\Software\Adobe\Acrobat Reader\DC Default=False FileKey1=%ProgramFiles%\Adobe\Acrobat Reader DC\Setup Files|*.*|REMOVESELF FileKey2=%CommonAppData%\Adobe\Setup|*.*|REMOVESELF FileKey3=%LocalAppData%\Adobe\Acrobat\DC\Cache|*.*|RECURSE RegKey1=HKCU\Software\Adobe\Acrobat Reader\DC\AVConversionFromPDF RegKey2=HKCU\Software\Adobe\Acrobat Reader\DC\AVConversionToPDF RegKey3=HKCU\Software\Adobe\Acrobat Reader\DC\AVGeneral\cDockables RegKey4=HKCU\Software\Adobe\Acrobat Reader\DC\AVGeneral\cRecentFiles RegKey5=HKCU\Software\Adobe\Acrobat Reader\DC\AVGeneral\cToolbars RegKey6=HKCU\Software\Adobe\Acrobat Reader\DC\RememberedViews\cNoCategoryFiles RegKey7=HKCU\Software\Adobe\Acrobat Reader\DC\ShareIdentity RegKey8=HKCU\Software\Adobe\Adobe Synchronizer\DC FileKey2 shouldn't be included. In the past it prevented updates: #1604, #1605. And you wrote: #3018. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted April 25, 2015 Moderators Share Posted April 25, 2015 FileKey2 could be there for any number of reasons and probably shouldn't be included just for Realtek Install Files cleanup. No I agree that the folder mentioned is too generic and not only related to realtek ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Amtrak7 Posted April 25, 2015 Share Posted April 25, 2015 New entry [MySQL Workbench*] LangSecRef=3021 DetectFile=%AppData%\MySQL\Workbench Default=False FileKey1=%AppData%\MySQL\Workbench\log|*.log FileKey2=%AppData%\MySQL\Workbench\sql_history|*.* FileKey2=%AppData%\MySQL\Workbench\cache|*.* Link to comment Share on other sites More sharing options...
dvdbane Posted April 25, 2015 Share Posted April 25, 2015 [VoidTools Search Everything*]LangSecRef=3024DetectFile1=%ProgramFiles%\EverythingDetectFile2=%AppData%\EverythingDefault=FalseFileKey1=%AppData%\Everything|*.csv;*.txtFileKey2=%ProgramFiles%\Everything|*.csv;*.txtFileKey3=%LocalAppData%\VirtualStore\Program Files*\Everything|*.txt;*.csvExcludeKey1=FILE|%AppData%\Everything\Filters.csvExcludeKey2=FILE|%ProgramFiles%\Everything\Filters.csvExcludeKey3=FILE|%LocalAppData%\VirtualStore\Program Files*\Everything\Filters.csv - fix Excludekey Link to comment Share on other sites More sharing options...
SMalik Posted April 25, 2015 Share Posted April 25, 2015 FileKey2 shouldn't be included. In the past it prevented updates: #1604, #1605. And you wrote: #3018. I guess it is different with the new Acrobat Reader DC. I have removed the installation files and tried running the update, no issue. Link to comment Share on other sites More sharing options...
Moderators mta Posted April 25, 2015 Moderators Share Posted April 25, 2015 It's a hidden empty directory. Realtek High Definition Audio driver installation creates this directory. I have tested this by uninstalling and re-installing Realtek High Definition Audio driver a few times. I use a program that monitors installations. I have notified Realtek about this empty directory. it is also created/used by other lazy programmers who fail to follow the TMP or TEMP user and system variables. I'm not arguing the fact that it can/can't be deleted, my concern is someone running CC and using your Realtek entry, then finding other stuff has gone. yep, it's a temp folder so 'who cares' applies, but still, maybe at least a warning that not only Realtek may be effected. Backup now & backup often.It's your digital life - protect it with a backup.Three things are certain; Birth, Death and loss of data. You control the last. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted April 25, 2015 Moderators Share Posted April 25, 2015 the last sentence is my full argument against its inclusion, it covers things outside of it's named function. Warnings, in general are useless one time popups especially when over used. If you want that folder removed here's an entry, I even put a warning on it [Program Files temp folder*] LangSecRef=tbd DetectFile=%ProgramFiles%\temp Default=False Warning=some developers are lazy and fail to follow TMP or Temp user and system variables, it's a temp folder so 'who cares' I've made this warning super long, but that's okay most users clicked ok the second the window popped up. FileKey1=%ProgramFiles%\tempEdit Or, in seriousness, you could just include the folder in your personal inculdes ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
APMichael Posted April 26, 2015 Share Posted April 26, 2015 I guess it is different with the new Acrobat Reader DC. I have removed the installation files and tried running the update, no issue. I would recommend waiting for the first larger update of the new Acrobat Reader DC. Some smaller updates worked in the past also, but the bigger ones failed. Link to comment Share on other sites More sharing options...
SMalik Posted April 26, 2015 Share Posted April 26, 2015 Revised Entry Changed the Detect from HKCU to HKLM for no conflict with Adobe Acrobat DC entry. [Acrobat Reader DC*]LangSecRef=3021Detect=HKLM\Software\Adobe\Acrobat Reader\DCDefault=FalseFileKey1=%ProgramFiles%\Adobe\Acrobat Reader DC\Setup Files|*.*|REMOVESELFFileKey2=%CommonAppData%\Adobe\Setup|*.*|REMOVESELFFileKey3=%LocalAppData%\Adobe\Acrobat\DC\Cache|*.*|RECURSERegKey1=HKCU\Software\Adobe\Acrobat Reader\DC\AVConversionFromPDFRegKey2=HKCU\Software\Adobe\Acrobat Reader\DC\AVConversionToPDFRegKey3=HKCU\Software\Adobe\Acrobat Reader\DC\AVGeneral\cDockablesRegKey4=HKCU\Software\Adobe\Acrobat Reader\DC\AVGeneral\cRecentFilesRegKey5=HKCU\Software\Adobe\Acrobat Reader\DC\AVGeneral\cToolbarsRegKey6=HKCU\Software\Adobe\Acrobat Reader\DC\RememberedViews\cNoCategoryFilesRegKey7=HKCU\Software\Adobe\Acrobat Reader\DC\ShareIdentityRegKey8=HKCU\Software\Adobe\Adobe Synchronizer\DC Link to comment Share on other sites More sharing options...
SMalik Posted April 26, 2015 Share Posted April 26, 2015 New Entries [Adobe Acrobat DC*]LangSecRef=3021Detect=HKLM\SOFTWARE\Adobe\Adobe Acrobat\DCDefault=FalseFileKey1=%ProgramFiles%\Adobe\Acrobat DC\Setup Files|*.*|REMOVESELFFileKey2=%CommonAppData%\Adobe\Setup|*.*|REMOVESELFFileKey3=%LocalAppData%\Adobe\Acrobat|*.idx|RECURSEFileKey4=%LocalAppData%\Adobe\Acrobat\DC\Cache|*.*FileKey5=%LocalAppData%\Adobe\Acrobat\DC|UserCache.binRegKey1=HKCU\Software\Adobe\Adobe Acrobat\DC\AVConversionFromPDFRegKey2=HKCU\Software\Adobe\Adobe Acrobat\DC\AVConversionToPDFRegKey3=HKCU\Software\Adobe\Adobe Acrobat\DC\AVGeneral\cDockablesRegKey4=HKCU\Software\Adobe\Adobe Acrobat\DC\AVGeneral\cRecentFilesRegKey5=HKCU\Software\Adobe\Adobe Acrobat\DC\AVGeneral\cToolbarsRegKey6=HKCU\Software\Adobe\Adobe Acrobat\DC\RememberedViews\cNoCategoryFilesRegKey7=HKCU\Software\Adobe\Adobe Acrobat\DC\ShareIdentityRegKey8=HKCU\Software\Adobe\Adobe Synchronizer\DC[Adobe Acrobat Distiller DC*]LangSecRef=3021Detect=HKLM\SOFTWARE\Adobe\Acrobat Distiller\DCDefault=FalseFileKey1=%LocalAppData%\Adobe\Acrobat\Distiller DC|*.logFileKey2=%LocalAppData%\Adobe\Acrobat\Distiller DC\Cache|*.*RegKey1=HKCU\Software\Adobe\Acrobat Distiller\PrinterJobControl Link to comment Share on other sites More sharing options...
SMalik Posted April 26, 2015 Share Posted April 26, 2015 Revised Entry Changed the Detect from HKLM\Software\Adobe\Acrobat Distiller to HKLM\Software\Adobe\Acrobat Distiller\11.0 because it was having a conflict with the new Adobe Acrobat Distiller DC entry (look at the acrodc1 snapshot). Adobe Acrobat XI More entry will still popup (look at the acrodc1 snapshot) because the Adobe Acrobat DC installer creates some registry data that is shown in the acrodc2 snapshot. I have removed that data manually (subkeys 10.0, 11.0, 7.0, 8.0, 9.0) and it is not getting re-created after opening Adobe Acrobat DC. [Adobe Acrobat Distiller*]LangSecRef=3021Detect=HKLM\Software\Adobe\Acrobat Distiller\11.0Default=FalseFileKey1=%AppData%\Adobe\Acrobat\Distiller 11|*.logFileKey2=%AppData%\Adobe\Acrobat\Distiller 11\Cache|*.*RegKey1=HKCU\Software\Adobe\Acrobat Distiller\PrinterJobControl Link to comment Share on other sites More sharing options...
SMalik Posted April 26, 2015 Share Posted April 26, 2015 the last sentence is my full argument against its inclusion, it covers things outside of it's named function. Warnings, in general are useless one time popups especially when over used. If you want that folder removed here's an entry, I even put a warning on it [Program Files temp folder*] LangSecRef=tbd DetectFile=%ProgramFiles%\temp Default=False Warning=some developers are lazy and fail to follow TMP or Temp user and system variables, it's a temp folder so 'who cares' I've made this warning super long, but that's okay most users clicked ok the second the window popped up. FileKey1=%ProgramFiles%\tempEdit Or, in seriousness, you could just include the folder in your personal inculdes Developers are humans too and they can also make mistakes. After reading the 'Warning' you made for this entry, and the advice that you posted for me, it shows you have some kind of attitude problem. I raise my question again, why are you a moderator of this forum? You always find ways to insult and harass other members here. If I have to, I can make a custom entry for myself. I don't need your advise. Piriform should look into this, otherwise people like me will leave this project. Link to comment Share on other sites More sharing options...
SMalik Posted April 27, 2015 Share Posted April 27, 2015 Revised Entry Changed from: FileKey1=%ProgramFiles%\Common Files\Adobe\Installers|*.*|RECURSETo: FileKey1=%ProgramFiles%\Common Files\Adobe\Installers|*.log.gz|RECURSE There are some important files in the uninstall directory. [Adobe Updater*]LangSecRef=3021Detect=HKCU\Software\AdobeDefault=FalseFileKey1=%ProgramFiles%\Common Files\Adobe\Installers|*.log.gz|RECURSEFileKey2=%CommonAppData%\Adobe\ARM|*.*|RECURSEFileKey3=%LocalAppData%\Adobe\AAMUpdater|*.Log|RECURSEFileKey4=%LocalAppData%\Adobe\Updater*|*.log|RECURSEFileKey5=%LocalAppData%\Adobe\Acrobat\*\Updater|*.logFileKey6=%AppData%\Adobe\LogTransport*\Logs|ulog_*.tmpFileKey7=%AppData%\Adobe\Acrobat\*\Updater|*.log Link to comment Share on other sites More sharing options...
Moderators Nergal Posted May 1, 2015 Moderators Share Posted May 1, 2015 Developers are humans too and they can also make mistakes. After reading the 'Warning' you made for this entry, and the advice that you posted for me, it shows you have some kind of attitude problem. I raise my question again, why are you a moderator of this forum? You always find ways to insult and harass other members here. If I have to, I can make a custom entry for myself. I don't need your advise.1) my post was tongue and cheek. I've never insulted nor harassed a member of this thread or this forum (at least not since my first few months of coming to the site in 2009). So if you read that into my (badly englished) posts, that's on you.As far as your belief, one I've been confronted on by you on previous occasion(s), that I have a personal vendetta against you, or other submitters, you couldn't be further from correct. I don't even usually notice the submitter until I've already looked at an entry and judged it to have the possibility of causing issue, from the perspective of the developers adding the entry to ccleaner. I've mentioned before, it has been given to the moderator staff, and in particular me as a active user of the template and participant of the thread to police for this type of entry; which is all I've done (as well as simply expressed an opinion and not a veto-proof one either).EDIT For those who do not remember: an entry for windows media player included *.db. though many in the thread caught that it literally removed the users' entire music database (star ratings, play counts, notes) it was still added to the program and many people suffered, though the final template version included a warning. /EDIT 2) the warning included in my "entry" is WORD FOR WORD from the post previous to mine. It is not a slight to developers, it's a slight to the liberal use of warnings already in the template as well as the (nigh) impossibility of wording a warning especially in a entry (yours) that cleans other items besides the %programfiles%\temp folder. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
opticyclic Posted May 1, 2015 Share Posted May 1, 2015 I had 3CX VoIP Phone installed http://www.3cx.com/voip/voip-phone/ and it left the following mostly empty directories. ..\AppData\Local\3CX VoIP Phone > tree D:. ├───Cert ├───History ├───Language ├───Logs ├───Phonebook │ ├───Contacts │ ├───Phones │ └───Photos ├───Provisioned ├───Recordings ├───Snapshots ├───Updater └───Video Can you explain how I add an entry for this? I have lots of directories in appdata pertaining to old installations and I want to delete them at the root and not just specify temp files that might be in them. Is this possible? I also notice that there are lots of entries in the ini file that don't appear in the GUI. e.g. [18 Wheels of Steel*] Section=Games Detect=HKCU\Software\ValuSoft Default=False FileKey1=%Documents%\18 WoS American Long Haul|*.log;*.crash FileKey2=%Documents%\18 WoS Extreme Trucker|*.log;*.crash FileKey3=%Documents%\18 WoS Extreme Trucker 2|*.log;*.crash FileKey4=%Documents%\18 WoS Haulin|*.log;*.crash [1Click DVD Copy Pro*] LangSecRef=3023 DetectFile=%CommonAppData%\1click dvd copy pro Default=False FileKey1=%CommonAppData%\1click dvd copy pro|*.log FileKey2=%LocalAppData%\VirtualStore\ProgramData\1click dvd copy pro|*.log I don't even have a Games section on the Applications tab. Does CCleaner do some analysis of files/directories in these sections before populating the list of Applications? Link to comment Share on other sites More sharing options...
SMalik Posted May 2, 2015 Share Posted May 2, 2015 1) my post was tongue and cheek. I've never insulted nor harassed a member of this thread or this forum (at least not since my first few months of coming to the site in 2009). So if you read that into my (badly englished) posts, that's on you.As far as your belief, one I've been confronted on by you on previous occasion(s), that I have a personal vendetta against you, or other submitters, you couldn't be further from correct. I don't even usually notice the submitter until I've already looked at an entry and judged it to have the possibility of causing issue, from the perspective of the developers adding the entry to ccleaner. I've mentioned before, it has been given to the moderator staff, and in particular me as a active user of the template and participant of the thread to police for this type of entry; which is all I've done (as well as simply expressed an opinion and not a veto-proof one either). EDIT For those who do not remember: an entry for windows media player included *.db. though many in the thread caught that it literally removed the users' entire music database (star ratings, play counts, notes) it was still added to the program and many people suffered, though the final template version included a warning. /EDIT 2) the warning included in my "entry" is WORD FOR WORD from the post previous to mine. It is not a slight to developers, it's a slight to the liberal use of warnings already in the template as well as the (nigh) impossibility of wording a warning especially in a entry (yours) that cleans other items besides the %programfiles%\temp folder. A while ago, there was a new person who joined this forum and complained about one of the entries under the "Advanced" section in CCleaner. Your reply to him was "do not stick your finger in there." Isn't this a form of harrassment?! I was suprised seeing this kind of language used by a moderator and Piriform did not take any action. I have more than 10 years of experience in developing all kinds of programs especially Windows Registry cleaners, privacy erasers, and video editing programs. You remember one of my mistakes that I made in the Media Player entry, but you don't remember even one of the 100s of useful entries I provided to this project. That entry is still included in Windows Media Player, but with a warning. What is the difference? Link to comment Share on other sites More sharing options...
SMalik Posted May 2, 2015 Share Posted May 2, 2015 New Entries [Ashampoo Snap 8 (AutoSave)*]LangSecRef=3024Detect=HKCU\Software\Ashampoo\Ashampoo Snap 8Default=FalseFileKey1=%Pictures%\Ashampoo Snap 8\_SNAPDOC|*.*[Ashampoo Snap 8*]LangSecRef=3024Detect=HKCU\Software\Ashampoo\Ashampoo Snap 8Default=FalseFileKey1=%LocalAppData%\CrashRpt\UnsentCrashReports|*.*|RECURSEFileKey2=%AppData%\Ashampoo\Ashampoo Snap 8|*.*|RECURSEFileKey3=%ProgramFiles%\Ashampoo\Ashampoo Snap 8|_NLogMsg.txt Link to comment Share on other sites More sharing options...
SMalik Posted May 2, 2015 Share Posted May 2, 2015 Revised Entries Changed: FileKey1=%Documents%\Ace Utilities Backups|*.regFileKey2=%LocalAppData%\Acelogix\Ace Utilities\Backups|*.reg FileKey1=%LocalAppData%\Acelogix\System TuneUp\Backups|*.reg [Ace Utilities*]LangSecRef=3024Detect=HKCU\Software\Acelogix\Ace UtilitiesDefault=FalseFileKey1=%Documents%\Ace Utilities Backups|*.*|RECURSEFileKey2=%LocalAppData%\Acelogix\Ace Utilities\Backups|*.*|RECURSERegKey1=HKCU\Software\Acelogix\Ace Utilities\Settings|UsageHistory [system TuneUp*]LangSecRef=3024Detect=HKCU\Software\Acelogix\System TuneUpDefault=FalseFileKey1=%LocalAppData%\Acelogix\System TuneUp\Backups|*.*|RECURSE Link to comment Share on other sites More sharing options...
Moderators mta Posted May 2, 2015 Moderators Share Posted May 2, 2015 A while ago, there was a new person who joined this forum and complained about one of the entries under the "Advanced" section in CCleaner. Your reply to him was "do not stick your finger in there." Isn't this a form of harrassment?! I was suprised seeing this kind of language used by a moderator and Piriform did not take any action. I have more than 10 years of experience in developing all kinds of programs especially Windows Registry cleaners, privacy erasers, and video editing programs. You remember one of my mistakes that I made in the Media Player entry, but you don't remember even one of the 100s of useful entries I provided to this project. That entry is still included in Windows Media Player, but with a warning. What is the difference? can I suggest using PM would be a better avenue to continue this line of conversation. I don't think members want to follow this. Plus it's off topic. Backup now & backup often.It's your digital life - protect it with a backup.Three things are certain; Birth, Death and loss of data. You control the last. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted May 3, 2015 Moderators Share Posted May 3, 2015 can I suggest using PM would be a better avenue to continue this line of conversation.Great suggestion, I have commenced with this ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
ROCKNROLL Posted May 3, 2015 Share Posted May 3, 2015 I have a question/suggestion. Do you think it would be a good idea to add warnings to cache files saying something like "Removing these files may slow down the application" I just ask because files like caches and temp files are actually meant to speed up programs. I am a maintainer for Winapp2. I also have a open-source group on Steam. http://steamcommunity.com/groups/opencommunity Link to comment Share on other sites More sharing options...
Moderators mta Posted May 3, 2015 Moderators Share Posted May 3, 2015 Although your suggestion @ROCKNROLL has merit, it runs the gauntlet of immunising users against warnings in general. I think warnings should be used sparingly and only if some potential adverse effect is not obvious. Removing cache files, at worst, will make a program slow for the next usage. Hopefully users of CC and the like should realise that non-essential files are removed but with the next usage, the program will recreate anything it requires. Backup now & backup often.It's your digital life - protect it with a backup.Three things are certain; Birth, Death and loss of data. You control the last. Link to comment Share on other sites More sharing options...
ROCKNROLL Posted May 3, 2015 Share Posted May 3, 2015 You are right mta. People might just think warnings have less meaning then. Besides, who wants to go through Winapp2 and add a warning to all the cache entries. I am a maintainer for Winapp2. I also have a open-source group on Steam. http://steamcommunity.com/groups/opencommunity Link to comment Share on other sites More sharing options...
CSGalloway Posted May 4, 2015 Share Posted May 4, 2015 I use Windows Live products. Anyone know if it's safe to delete: %LocalAppData%\Windows Live\.cache|*.* ?? If so I can remove 34 items totaling 136 MBs... Link to comment Share on other sites More sharing options...
