Moderators Nergal Posted May 4, 2015 Moderators Share Posted May 4, 2015 I use Windows Live products. Anyone know if it's safe to delete: %LocalAppData%\Windows Live\.cache|*.* ?? If so I can remove 34 items totaling 136 MBs... The best way to check is to temporarily rename the folder (with all live apps killed) and see if all live products survive running afterwards. if the folder recreates on the first product you're pretty safe, but I'd still suggest test all the live software to be sure. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
SMalik Posted May 4, 2015 Share Posted May 4, 2015 New Entry [Auslogics BoostSpeed 7*]LangSecRef=3024Detect=HKLM\Software\Auslogics\BoostSpeed\7.xDefault=FalseFileKey1=%CommonAppData%\Auslogics\BoostSpeed\7.x|*.err;*.htm;*.html;*.log;*.rsc;*.sta;*.xml|RECURSEFileKey2=%ProgramFiles%\Auslogics\Auslogics BoostSpeed|rdboot.logRegKey1=HKLM\Software\Auslogics\BoostSpeed\7.x\Settings|DiskDefrag.DisksList.SelectedDrivesRegKey2=HKLM\Software\Auslogics\BoostSpeed\7.x\Settings|DiskDefrag.LastDefragment.DateTimeRegKey3=HKLM\Software\Auslogics\BoostSpeed\7.x\Settings|DiskDefrag.LastDefragment.DisksListRegKey4=HKLM\Software\Auslogics\BoostSpeed\7.x\Settings|DiskDefrag.LastDefragment.FilesCountRegKey5=HKLM\Software\Auslogics\BoostSpeed\7.x\Settings|RegCleaner.AppLogic.ErrorsFailedRegKey6=HKLM\Software\Auslogics\BoostSpeed\7.x\Settings|RegCleaner.AppLogic.ErrorsFoundRegKey7=HKLM\Software\Auslogics\BoostSpeed\7.x\Settings|RegCleaner.AppLogic.ErrorsRemovedRegKey8=HKLM\Software\Auslogics\BoostSpeed\7.x\Settings|RegCleaner.AppLogic.ErrorsRemovedTotalRegKey9=HKLM\Software\Auslogics\BoostSpeed\7.x\Settings|RegCleaner.AppLogic.LastScanRegKey10=HKLM\SOFTWARE\Wow6432Node\Auslogics\BoostSpeed\7.x\Settings|DiskDefrag.DisksList.SelectedDrivesRegKey11=HKLM\SOFTWARE\Wow6432Node\Auslogics\BoostSpeed\7.x\Settings|DiskDefrag.LastDefragment.DateTimeRegKey12=HKLM\SOFTWARE\Wow6432Node\Auslogics\BoostSpeed\7.x\Settings|DiskDefrag.LastDefragment.DisksListRegKey13=HKLM\SOFTWARE\Wow6432Node\Auslogics\BoostSpeed\7.x\Settings|DiskDefrag.LastDefragment.FilesCountRegKey14=HKLM\SOFTWARE\Wow6432Node\Auslogics\BoostSpeed\7.x\Settings|RegCleaner.AppLogic.ErrorsFailedRegKey15=HKLM\SOFTWARE\Wow6432Node\Auslogics\BoostSpeed\7.x\Settings|RegCleaner.AppLogic.ErrorsFoundRegKey16=HKLM\SOFTWARE\Wow6432Node\Auslogics\BoostSpeed\7.x\Settings|RegCleaner.AppLogic.ErrorsRemovedRegKey17=HKLM\SOFTWARE\Wow6432Node\Auslogics\BoostSpeed\7.x\Settings|RegCleaner.AppLogic.ErrorsRemovedTotalRegKey18=HKLM\SOFTWARE\Wow6432Node\Auslogics\BoostSpeed\7.x\Settings|RegCleaner.AppLogic.LastScan Link to comment Share on other sites More sharing options...
SMalik Posted May 4, 2015 Share Posted May 4, 2015 New Entry [Windows Defender More*]LangSecRef=3025Detect=HKLM\Software\Microsoft\Windows DefenderDefault=FalseFileKey1=%CommonAppData%\Microsoft\Windows Defender\Definition Updates\Backup|*.*|RECURSEFileKey2=%CommonAppData%\Microsoft\Windows Defender\Scans|*.bin;*.bin*FileKey3=%CommonAppData%\Microsoft\Windows Defender\Scans\History\Service|*.logFileKey4=%CommonAppData%\Microsoft\Windows Defender\Scans\Scans\History\CacheManager|*.*|RECURSEFileKey5=%CommonAppData%\Microsoft\Windows Defender\Support|*.*|RECURSE I think the Windows Defender entry's LangSecRef should be changed to 3025. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted May 4, 2015 Moderators Share Posted May 4, 2015 I think the Windows Defender entry's LangSecRef should be changed to 3025. Not a bad thought, could you start a suggestion thread with that (it's not a winapp2 entry so there's no way to do that from here). ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
CSGalloway Posted May 5, 2015 Share Posted May 5, 2015 The best way to check is to temporarily rename the folder (with all live apps killed) and see if all live products survive running afterwards. if the folder recreates on the first product you're pretty safe, but I'd still suggest test all the live software to be sure. I wrote: >>>>>>>>>>>>>>>>>>> %UserProfile%\AppData\Local\Windows Live\.cache Is it safe to remove the files in this folder? What are the positives and the drawbacks please? C:\Users\username\AppData\Local\Windows Live\.cache Mine has 34 files totaling 136 MBs.... I use Live Messenger, and Live Mail.... <<<<<<<<<<<<<<<<<< to Microsoft Answers and got this back: >>>>>>>>>>>>>>>>>> That hidden folder contains the installers for all of the elements of older installations of the Windows (Live) Essentials suite. Later installations put these files at C:\Program Files (x86)\Common Files\Windows Live\.cache instead, so if you find a similar collection of folders and files there, you can safely delete the ones in the user profile. If you completely remove the installer files for any of the programs, you'll probably not be able to repair or uninstall them easily. <<<<<<<<<<<<<<<<< And I guess there is no way to test for the existence of both folders in CCleaner? Link to comment Share on other sites More sharing options...
Moderators Andavari Posted May 5, 2015 Moderators Share Posted May 5, 2015 And I guess there is no way to test for the existence of both folders in CCleaner? A dummy cleaner that is used for detection purposes only but deletes nothing may be a workaround - although I've never tried that before. Link to comment Share on other sites More sharing options...
CSGalloway Posted May 5, 2015 Share Posted May 5, 2015 A dummy cleaner that is used for detection purposes only but deletes nothing may be a workaround - although I've never tried that before. I am not sure what you mean, in my case. I'd be interested in a sample please - when you or someone else has time.... Link to comment Share on other sites More sharing options...
dvdbane Posted May 5, 2015 Share Posted May 5, 2015 That hidden folder contains the installers for all of the elements of older installations of the Windows (Live) Essentials suite. Later installations put these files at C:\Program Files (x86)\Common Files\Windows Live\.cache instead, so if you find a similar collection of folders and files there, you can safely delete the ones in the user profile. If you completely remove the installer files for any of the programs, you'll probably not be able to repair or uninstall them easily. <<<<<<<<<<<<<<<<< And I guess there is no way to test for the existence of both folders in CCleaner? what about using the new location as detect and the old location as cleaning rule? Link to comment Share on other sites More sharing options...
Moderators Andavari Posted May 5, 2015 Moderators Share Posted May 5, 2015 I am not sure what you mean, in my case. I'd be interested in a sample please - when you or someone else has time.... I've tried this and it works, it only shows the entry in CCleaner but does absolutely nothing: [Detect Windows Temp*] LangSecRef=3025 Default=True DetectFile=%windir%\Temp Link to comment Share on other sites More sharing options...
rulman Posted May 5, 2015 Share Posted May 5, 2015 https://technet.microsoft.com/en-us/library/security/MS15-041 indows 7 for 32-bit Systems Service Pack 1 Microsoft .NET Framework 3.5.1 (3037574) Information Disclosure Important 2901112 inMS14-009 Windows 7 for 32-bit Systems Service Pack 1 Microsoft .NET Framework 4 [1] (3037578) Information Disclosure Important 2901110 inMS14-009 Windows 7 for 32-bit Systems Service Pack 1 Microsoft .NET Framework 4.5/4.5.1/4.5.2 (3037581) Information Disclosure Important 2901126 inMS14-009 Windows 7 for x64-based Systems Service Pack 1 Microsoft .NET Framework 3.5.1 (3037574) Information Disclosure Important 2901112 inMS14-009 Windows 7 for x64-based Systems Service Pack 1 Microsoft .NET Framework 4 [1] (3037578) Information Disclosure Important 2901110 inMS14-009 Windows 7 for x64-based Systems Service Pack 1 Microsoft .NET Framework 4.5/4.5.1/4.5.2 (3037581) Information Disclosure Important 2901126 inMS14-009 Remove old update replace ; KB3037581 replace KB2901126 So ; Remove KB2901126 Windows 7 for 32-bit Systems Service Pack 1 (3046306) Remote Code Execution Critical 2876331 in MS13-089 Windows 7 for x64-based Systems Service Pack 1 (3046306) Remote Code Execution Critical 2876331 in MS13-089 REmove Update KB2876331 Link to comment Share on other sites More sharing options...
CSGalloway Posted May 5, 2015 Share Posted May 5, 2015 what about using the new location as detect and the old location as cleaning rule? so then something like this: [Old Windows Live Cache*] LangSecRef=3021 Warning=This will remove Cache files for old installs of Windows Live - use with caution DetectFile=%CommonProgramFiles%\Windows Live|.cache Default=False FileKey1=%LocalAppData%\Windows Live\.cache|*.*|RECURSE Not tested... Link to comment Share on other sites More sharing options...
JDPower Posted May 6, 2015 Share Posted May 6, 2015 OpenDNS told me lies. When the site was down and I PINGed I got a positive response, but looking closer the response did NOT come from forum.piriform.com instead OpenDNS substituted its own Adserver site. That ticked me of and I no longer use them Not quite sure what it's got to do with this topic, BUT OpenDNS don't serve ads any more Link to comment Share on other sites More sharing options...
testovich.10 Posted May 7, 2015 Share Posted May 7, 2015 Thanks. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted May 7, 2015 Moderators Share Posted May 7, 2015 Just so nobody is confused by @JDPower's post (4938) I banned the member who is likey spam ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
JDPower Posted May 7, 2015 Share Posted May 7, 2015 Just so nobody is confused by @JDPower's post (4938) I banned the member who is likey spam You say that like people aren't USUALLY confused by my posts Link to comment Share on other sites More sharing options...
siliconman01 Posted May 9, 2015 Share Posted May 9, 2015 Modified Entry: - Changed Name from [bitDefender Total Security 2014 (Logs)*] to [bitDefender Total Security 2014/15 (Logs)*] - Changed Detect to Detect1 - Added Detect2 [BitDefender Total Security 2014/15 (Logs)*] LangSecRef=3024 Detect1=HKLM\Software\BitDefender\Bitdefender Total Security Detect2=HKLM\Software\BitDefender\Bitdefender Total Security 2015 Warning=This removes only logs created while scanning external drives and other special unneeded scan logs generated by Bitdefender scanner. Default=False FileKey1=%AppData%\Bitdefender\Desktop\profiles\Logs\*|*.xml Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 8940 PC and Dell XPS 16 9640 Laptop. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
ROCKNROLL Posted May 10, 2015 Share Posted May 10, 2015 The following entries I either shrunk, reworded, or fixed grammar issues in the warnings only: [All Zombies Must Die! Installers*]Section=GamesDetect=HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\All Zombies Must Die!_is1Warning=This will remove AMD Driver Package, DirectX and Visual C++ installers in your All Zombies Must Die installation directory. They can be reinstalled in your installation source. Default=False FileKey1=%ProgramFiles%\Doublesix Games\All Zombies Must Die!\Prerequisites|*.*|REMOVESELF[bitDefender Total Security 2014 (Logs)*]LangSecRef=3024Detect=HKLM\Software\BitDefender\Bitdefender Total Security Warning=This removes logs created while scanning external drives and other unneeded scan logs generated by Bitdefender scanner. Default=False FileKey1=%AppData%\Bitdefender\Desktop\profiles\Logs\*|*.xml[burn Zombie Burn! .NET Installer*]Section=GamesDetect=HKLM\Software\Burn Zombie BurnWarning=This will remove the NET Framework 3.0 installer in your Burn Zombie Burn installation directory. It can be reinstalled in your installation source. Default=False FileKey1=%ProgramFiles%\P2 Games\Burn Zombie Burn\REQS\NET|*.*|REMOVESELF[CCDump*]LangSecRef=3024DetectFile=%ProgramFiles%\CCleaner\CCDump.exeWarning=This removes files winapp.ini, winsys.ini, winreg.ini and regkeys.output.txt from the CCleaner folder. These files are retrieved from CCDump.exe. Default=False FileKey1=%ProgramFiles%\CCleaner|winapp.ini;winreg.ini;winsys.ini;regkeys.output.txt[Civilization 5 Installers*]Section=GamesDetect=HKCU\Software\Firaxis\Civilization5Warning=This will remove DirectX and Visual C++ installers in your Civilization 5 installation directory. They can be reinstalled in your installation source.Default=FalseFileKey1=%ProgramFiles%\Civilization V*\DirectX|*.*|REMOVESELFFileKey2=%ProgramFiles%\Civilization V*\VCRedist|*.*|REMOVESELF[Desura Game Installation Tools*]Section=GamesDetect=HKLM\Software\DesuraDetectFile=%ProgramFiles%\DesuraWarning=This will remove tools that are needed in game installations. Don't use this is you have limited bandwidth as they will be re-downloaded on next game installation that needs the same tool.Default=FalseFileKey1=%CommonAppData%\Desura\DesuraApp\tools|*.*|RECURSEFileKey2=%LocalAppData%\VirtualStore\ProgramData\Desura\DesuraApp\tools|*.*|RECURSEExcludeKey1=PATH|%CommonAppData%\Desura\DesuraApp\tools\installcheck[Device Manager Cache XP*]LangSecRef=3025DetectOS=|5.1Warning=This clears cached drivers of connected devices. As soon as you connect a new device to your computer, this file will regenerate.Default=FalseFileKey1=%WinDir%\inf|INFCACHE.1[Device Manager Cache*]LangSecRef=3025DetectOS=6.0|Warning=This clears cached drivers of connected devices. As soon as you connect a new device to your computer, this file will regenerate.Default=FalseFileKey1=%WinDir%\System32\DriverStore|INFCACHE.1[Join.Me Install Backups*]LangSecRef=3022Detect=HKCU\Software\join.meWarning=This will remove all old versions of Join.Me that are automatically backed up on each install.Default=FalseFileKey1=%LocalAppData%\join.me\join.me.*.*.*.*|*.*|REMOVESELF[Kodak AiO Software (Disable Startup)*]LangSecRef=3021Detect1=HKLM\Software\Eastman Kodak Company\KODAK AiO Home CenterDetect2=HKLM\Software\Kodak\Kodak AiO SoftwareWarning=Disables the Kodak AiO Software from automatically starting with Windows. Every time you print, it will re-enable itself to start with Windows.Default=FalseRegKey1=HKLM\Software\Microsoft\Windows\CurrentVersion\Run|EKAIO2StatusMonitorRegKey2=HKLM\Software\Microsoft\Windows\CurrentVersion\Run|EKStatusMonitor[MS Notepad*]LangSecRef=3025Detect=HKCU\Software\Microsoft\NotepadWarning=If Notepad stops remembering your window size settings, this entry will reset it back to the default size.Default=FalseRegKey1=HKCU\Software\Microsoft\Notepad|iWindowPosDXRegKey2=HKCU\Software\Microsoft\Notepad|iWindowPosDYRegKey3=HKCU\Software\Microsoft\Notepad|iWindowPosXRegKey4=HKCU\Software\Microsoft\Notepad|iWindowPosY[Nokia Software Updater 3 Cache*]LangSecRef=3021Detect=HKCU\Software\Nokia\NSU3Warning=This will remove Nokia phone firmwares, applications and other files stored by Nokia Suite Updater. Files will be re-downloaded when updating phone.Default=FalseFileKey1=%LocalAppData%\Nokia\NSU3\NOSSU2|*.*|RECURSEExcludeKey1=FILE|%LocalAppData%\Nokia\NSU3\NOSSU2\usergroups.cfgExcludeKey2=PATH|%LocalAppData%\Nokia\NSU3\NOSSU2\Flash[Nokia Software Updater Cache - Old Versions*]LangSecRef=3021DetectFile1=%CommonAppData%\Nokia\Nokia Service Layer\ADetectFile2=%CommonProgramFiles%\Nokia\Service Layer\AWarning=This will remove all files stored by old versions of Nokia Software Updater, which are no longer supported.Default=FalseFileKey1=%CommonAppData%\Nokia\Nokia Service Layer\A|*.*|REMOVESELFFileKey2=%CommonProgramFiles%\Nokia\Service Layer\A|*.*|REMOVESELFFileKey3=%LocalAppData%\VirtualStore\ProgramData\Nokia\Nokia Service Layer\A|*.*|REMOVESELFFileKey4=%LocalAppData%\VirtualStore\Program Files*\Common Files\Nokia\Service Layer\A|*.*|REMOVESELF[Nokia Suite Updater Cache*]LangSecRef=3021Detect=HKLM\Software\Nokia\Nokia SuiteWarning=This will remove Nokia phone firmwares, applications and other files stored by Nokia Suite Updater. Files will be re-downloaded when updating phone.Default=FalseFileKey1=%CommonAppData%\Nokia\Nokia Suite\NOSSU2|*.*|RECURSEFileKey2=%LocalAppData%\VirtualStore\ProgramData\Nokia\Nokia Suite\NOSSU2|*.*|RECURSEExcludeKey1=FILE|%CommonAppData%\Nokia\Nokia Suite\NOSSU2\usergroups.cfgExcludeKey2=PATH|%CommonAppData%\Nokia\Nokia Suite\NOSSU2\Flash[Norton Power Eraser*]LangSecRef=3024DetectFile=%CommonAppData%\Norton\NPE\NPEsettings.datWarning=This removes ALL files of Norton's scan tool known as Norton Power Eraser. This tool should be downloaded fresh from Symantec after each run.Default=FalseFileKey1=%CommonAppData%\Norton\NPE|*.*|REMOVESELFFileKey2=%LocalAppData%\NPE|*.*|REMOVESELFFileKey3=%UserProfile%\Desktop|NPE.exeFileKey4=%LocalAppData%\VirtualStore\ProgramData\Norton\NPE|*.*|REMOVESELF[Panther*]LangSecRef=3025DetectFile=%Windir%\PantherWarning=The Windows\Panther directory is used during a Windows version upgrade. Following the upgrade, this directory can be safely removed.Default=FalseFileKey1=%Windir%\Panther\|*.*|REMOVESELF[PerfectUpdater*]LangSecRef=3024Detect=HKCU\Software\Raxco\PerfectUpdaterWarning=This cleans the installation logs, backup files after updating, and the downloads for new updates used for updating your drivers.Default=FalseFileKey1=%AppData%\Raxco\PerfectUpdater|*.logFileKey2=%AppData%\Raxco\PerfectUpdater\Backup|*.*FileKey3=%AppData%\Raxco\PerfectUpdater\Download|*.*[QIP 2012 Privacy items*]LangSecRef=3022Detect=HKCU\Software\QIPDetectFile=%AppData%\QIPWarning=Selecting this will delete any contact list backups, chat history, received files, opened tabs settings and other non-encrypted privacy items.Default=FalseFileKey1=%AppData%\QIP\Profiles\*\BackupCL|*.*FileKey2=%AppData%\QIP\Profiles\*\History|*.*|RECURSEFileKey3=%AppData%\QIP\Profiles\*\ICQ|*.*|RECURSEFileKey4=%AppData%\QIP\Profiles\*\RcvdFiles|*.*|RECURSEFileKey5=%AppData%\QIP\Profiles\*\|session.tabs[Recent Items More*]LangSecRef=3025DetectFile=%AppData%\Microsoft\windows\recent\customdestinationsWarning=Running this will remove task lists from the start menu. It also removes user pinned items to the Quick Access list of Windows 10 File Explorer.Default=FalseFileKey1=%AppData%\Microsoft\windows\recent\automaticdestinations|*.*|RECURSEFileKey2=%AppData%\Microsoft\windows\recent\customdestinations|*.*|RECURSE[Rkill*]LangSecRef=3024DetectFile1=%UserProfile%\Desktop\RkillDetectFile2=%UserProfile%\Desktop\Rkill.txtWarning=This will delete your Rkill Log. Make sure you've reviewed it first.Default=FalseFileKey1=%UserProfile%\Desktop\Rkill|*.*|REMOVESELFFileKey2=%UserProfile%\Desktop|*rkill*.*[RoboBasket3*]LangSecRef=3024DetectFile=%AppData%\RoboBasket3Warning=This may prompt you with an error upon trying to view the log. Just click continue.Default=FalseFileKey1=%AppData%\RoboBasket3|log.database[soluto Dumps*]LangSecRef=3024Detect=HKLM\Software\SolutoWarning=This will remove Soluto's dump files. If you use this feature to diagnose dumps, do not use this entry.Default=FalseFileKey1=%CommonAppData%\Soluto\Dumps|*.*|RECURSEFileKey2=%CommonAppData%\Soluto\Logs\KMCustomDumpFolder|*.*|RECURSEFileKey3=%LocalAppData%\VirtualStore\ProgramData\Soluto\Dumps|*.*|RECURSEFileKey4=%LocalAppData%\VirtualStore\ProgramData\Soluto\Logs\KMCustomDumpFolder|*.*|RECURSE[steam Installers*]Section=GamesDetect=HKCU\Software\Valve\SteamWarning=Run this entry AFTER you have launched all of your steam games once, as they will not be able to load for the first time. After the first launch, these files become useless.Default=FalseFileKey1=%ProgramFiles%\Steam\Steamapps\common|*redist.msi*;*redist*.exe;*setup*.msi;*pbsvc*.exe;*UPlay*Installer*.exe;WMFADist.exe;SPInstaller.exe;python*.msi;bitmap2substance_installer.exe;perforce*.exe;p4vinst*.exe;mcpp*.*;firewallinstallhelper.dll;gameuxinstallhelper.dll;eadm-installer.exe;wmpappcompat.exe;umdf.exe;Microsoft .NET Framework*.cmd;Microsoft .NET Framework*.bat;NDP*.exe;WMFDist*.exe;PhysX*.msi;PhysX*.exe;*d3dx11*.cat;*d3dx11*.inf;prompt.bat;GDFInstall.exe;DSInstaller.exe;d3d*.exe;directx*.exe;*.msu;Windows*-KB*.exe;cmp.bat;PVRTexTool.exe;wmp11-windowsxp-x86-enu.exe;*.vdk;RGB9RAST*.msi;WIC*.exe;XPSEPC*.exe;msxml6.msi;AdbeRdr*.*;*inst*.vdf;*.cab;*.msp;ac3filter*.exe;GamesExplorerIntegrationTool.exe;install.ini;globdata.ini;install.exe;install.res.*.dll;eula.*.*;DSETUP.DLL;oalinst.exe;dsetup32.dll;D3D*Install.exe;D3D*Install*.dll;dotnetfx*.exe;*vc*red*.exe;*vc*red.msi;WindowsInstaller*.exe;locdata.*.ini;setupres.*.dll;*setup*.exe;wapres.*.dll;*NetFx*.*|RECURSE[WD Smartware Public Downloads File Removal*]LangSecRef=3024Detect=HKCU\Software\Western Digital\WD SmartwareWarning=This removes unnecessary files that have been installed by Western Digital Smartware MyCloud products.Default=FalseFileKey1=%SystemDrive%\Users\Public\Documents\Downloads\WD_SmartWare_Installer_*\|*.*|REMOVESELF[Windows 8 Sharing MFU*]DetectOS=6.2|LangSecRef=3025Detect=HKCU\Software\Microsoft\WindowsWarning=This will remove the frequently shared list. This does not remove the Apps listed under sharing.Default=FalseRegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\SharingMFU[Windows XP Error Reporting*]DetectOS=|5.2LangSecRef=3025Warning=This deletes the error reports generated by Windows errors. Make sure you review the error reports first before using this cleaner.Default=FalseFileKey1=%WinDir%\pchealth\ERRORREP|*.*|RECURSEFileKey2=%LocalAppData%\PCHealth\ErrorRep\QSignoff|*.* Also, during my process of reviewing some of the warning, I stumbled across this entry: [scribe (Finished Jobs)*]LangSecRef=3021Detect=HKCU\Software\NCH Software\ScribeWarning=This will copies of files related you have run through Scribe. Default=False FileKey1=%AppData%\NCH Software\Scribe\Done|*.* The warning makes no sense. Does anyone know what it is suppose to be saying and could edit it for me? I am a maintainer for Winapp2. I also have a open-source group on Steam. http://steamcommunity.com/groups/opencommunity Link to comment Share on other sites More sharing options...
siliconman01 Posted May 10, 2015 Share Posted May 10, 2015 The following entries I either shrunk, reworded, or fixed grammar issues in the warnings only: [bitDefender Total Security 2014 (Logs)*] LangSecRef=3024 Detect=HKLM\Software\BitDefender\Bitdefender Total Security Warning=This removes logs created while scanning external drives and other unneeded scan logs generated by Bitdefender scanner. FileKey1=%AppData%\Bitdefender\Desktop\profiles\Logs\*|*.xml [CCDump*] LangSecRef=3024 DetectFile=%ProgramFiles%\CCleaner\CCDump.exe Warning=This removes files winapp.ini, winsys.ini, winreg.ini and regkeys.output.txt from the CCleaner folder. These files are retrieved from CCDump.exe. FileKey1=%ProgramFiles%\CCleaner|winapp.ini;winreg.ini;winsys.ini;regkeys.output.txt I do not recommend that "Default=False" be removed from [CCDump*] Also, during my process of reviewing some of the warning, I stumbled across this entry: [scribe (Finished Jobs)*] LangSecRef=3021 Detect=HKCU\Software\NCH Software\Scribe Warning=This will copies of files related you have run through Scribe. FileKey1=%AppData%\NCH Software\Scribe\Done|*.* The warning makes no sense. Does anyone know what it is suppose to be saying and could edit it for me? I suspect that this should be "Warning=This will remove copies of related files that you have run through Scribe" and based on my post above, the Bitdefender entry becomes: Again I do not recommend that "Default=False" be removed from [bitdefender Total Security 2014/15 (Logs)*] [BitDefender Total Security 2014/15 (Logs)*] LangSecRef=3024 Detect1=HKLM\Software\BitDefender\Bitdefender Total Security Detect2=HKLM\Software\BitDefender\Bitdefender Total Security 2015 Warning=This removes logs created while scanning external drives and other unneeded scan logs generated by Bitdefender scanner. Default=False FileKey1=%AppData%\Bitdefender\Desktop\profiles\Logs\*|*.xml Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 8940 PC and Dell XPS 16 9640 Laptop. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
dvdbane Posted May 10, 2015 Share Posted May 10, 2015 The following entries I either shrunk, reworded, or fixed grammar issues in the warnings only: [All Zombies Must Die! Installers*] Section=Games Detect=HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall\All Zombies Must Die!_is1 Warning=This will remove AMD Driver Package, DirectX and Visual C++ installers in your All Zombies Must Die installation directory. They can be reinstalled in your installation source. FileKey1=%ProgramFiles%\Doublesix Games\All Zombies Must Die!\Prerequisites|*.*|REMOVESELF [burn Zombie Burn! .NET Installer*] Section=Games Detect=HKLM\Software\Burn Zombie Burn Warning=This will remove the NET Framework 3.0 installer in your Burn Zombie Burn installation directory. It can be reinstalled in your installation source. FileKey1=%ProgramFiles%\P2 Games\Burn Zombie Burn\REQS\NET|*.*|REMOVESELF Also, during my process of reviewing some of the warning, I stumbled across this entry: [scribe (Finished Jobs)*] LangSecRef=3021 Detect=HKCU\Software\NCH Software\Scribe Warning=This will copies of files related you have run through Scribe. FileKey1=%AppData%\NCH Software\Scribe\Done|*.* The warning makes no sense. Does anyone know what it is suppose to be saying and could edit it for me? missing Default=False too Link to comment Share on other sites More sharing options...
ROCKNROLL Posted May 10, 2015 Share Posted May 10, 2015 Sorry. Bleachbit, by default, is default-false and it removed the default=false parts off winapp2 to help save space. I must have forgotten to readd those there. EDIT: I edited my entries and fixed those. I am a maintainer for Winapp2. I also have a open-source group on Steam. http://steamcommunity.com/groups/opencommunity Link to comment Share on other sites More sharing options...
SMalik Posted May 10, 2015 Share Posted May 10, 2015 New Entry [east-tec Eraser*]LangSecRef=3024Detect=HKLM\Software\East-Tec\east-tec EraserDefault=FalseFileKey1=%ProgramFiles%\east-tec Eraser|except.logFileKey2=%CommonAppData%\East-Tec\east-tec Eraser\Updates|*.*|RECURSE Link to comment Share on other sites More sharing options...
Winapp2.ini Posted May 10, 2015 Author Share Posted May 10, 2015 This was submitted to me via email I found the ACE file on my computer (in a different dir) but I can't really say these are junk, since I don't know their purpose. [AMD/ATI Promo Videos*] LangSecRef=3024 Detect1=HKLM\Software\AMD Detect2=HKLM\Software\ATI Detect3=HKLM\Software\ATI Technologies DetectFile=%ProgramFiles%\ATI Technologies\ATI.ACE Default=False Warning= This will delete your Promo videos. You cannot restore back. FileKey1=%ProgramFiles%\ATI Technologies\ATI.ACE\Core-Static|*.mp4 FileKey2=%WinDir%\winsxs\amd64_microsoft-windows-videosamples_*|Wildlife.wmv Found: C:\Program Files (x86)\ATI Technologies\ATI.ACE\Core-Static\PreviewApp.mp4 C:\Windows\winsxs\amd64_microsoft-windows-videosamples_31bf3856ad364e35_6.1.7600.16385_none_51a21f033003affd\Wildlife.wmv [sprint Hero RUU Installer Log*] LangSecRef=3023 DetectFile=%SystemDrive%\ruu_log Default=False FileKey1=%SystemDrive%\ruu_log|*.*|REMOVESELF Found: C:\ruu_log\RUU_140802T151815.log C:\ruu_log\RUU_140802T152120.log C:\ruu_log\RUU_140802T151839.log winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
ROCKNROLL Posted May 11, 2015 Share Posted May 11, 2015 I don't think the AMD one should be touched. I can't seem to find the .mp4 file on my system at all and judging where the location of the .wmv file is, I would say it is risky. I don't know about the Sprint logs since I don't use that. I am a maintainer for Winapp2. I also have a open-source group on Steam. http://steamcommunity.com/groups/opencommunity Link to comment Share on other sites More sharing options...
Winapp2.ini Posted May 11, 2015 Author Share Posted May 11, 2015 RUU stands for Rom Update Utility I imagine, I've seen the term associated with HTC android handsets in the past. Probably fine to delete the logs winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
siliconman01 Posted May 13, 2015 Share Posted May 13, 2015 Sorry. Bleachbit, by default, is default-false and it removed the default=false parts off winapp2 to help save space. I must have forgotten to readd those there. EDIT: I edited my entries and fixed those. Thanks, I was hoping there was a simple explanation and thanks for fixing these. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 8940 PC and Dell XPS 16 9640 Laptop. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
