CCleaner Community Forums
Winapp2.ini additions
Winapp2.ini
This was sent to me today
[iTunes Temporary Files*]
LangSecRef=3023
Detect=HKLM\SOFTWARE\Apple Computer, Inc.\iTunes
Default=False
FileKey1=%CommonAppData%\Apple Computer\iTunes\iPhone Temporary Files|*.*
not going to include it since there are dmg files and other such things, I don't use itunes but if someone else would like to test it ... ;)
Link to comment
New Entry
[Wondershare Video Converter Ultimate*]
LangSecRef=3023
Detect=HKLM\SOFTWARE\Wondershare Video Converter Ultimate
Default=False
FileKey1=%ProgramFiles%\Wondershare Video Converter Ultimate\Log|*.*|RECURSE
FileKey2=%ProgramFiles%\Wondershare Video Converter Ultimate\TempThumbDir|*.*|RECURSE
FileKey3=%CommonAppData%\Wondershare Video Converter Ultimate|*.dat.bak
FileKey4=%CommonAppData%\Wondershare Video Converter Ultimate\TempSiteIconDir
FileKey5=%CommonAppData%\Wondershare Video Converter Ultimate\TempThumbDir
Revised Entries
Added the highlighted lines.
[Aimersoft Video Converter Ultimate*]
LangSecRef=3023
Detect=HKLM\SOFTWARE\Aimersoft\Aimersoft Video Converter Ultimate
Default=False
FileKey1=%ProgramFiles%\Aimersoft\Video Converter Ultimate\Log|*.*|RECURSE
FileKey2=%ProgramFiles%\Aimersoft\Video Converter Ultimate\TempThumbDir|*.*|RECURSE
FileKey3=%CommonAppData%\Aimersoft Video Converter Ultimate|*.dat.bak
FileKey4=%CommonAppData%\Aimersoft Video Converter Ultimate\TempSiteIconDir
FileKey5=%CommonAppData%\Aimersoft Video Converter Ultimate\TempThumbDir
[iSkysoft Video Converter Ultimate*]
LangSecRef=3023
Detect=HKLM\SOFTWARE\iSkysoft\iSkysoft Video Converter Ultimate
Default=False
FileKey1=%ProgramFiles%\iSkysoft\Video Converter Ultimate\Log|*.*|RECURSE
FileKey2=%ProgramFiles%\iSkysoft\Video Converter Ultimate\TempThumbDir|*.*|RECURSE
FileKey3=%CommonAppData%\iSkysoft Video Converter Ultimate|*.dat.bak
FileKey4=%CommonAppData%\iSkysoft Video Converter Ultimate\TempSiteIconDir
FileKey5=%CommonAppData%\iSkysoft Video Converter Ultimate\TempThumbDir
Wondershare Video Converter Pro is replaced by Ultimate. I think this entry should be removed. If you still like to keep it, then replace it with the one listed here.
[Wondershare Video Converter Pro*]
LangSecRef=3023
Detect=HKLM\SOFTWARE\Wondershare\Wondershare Video Converter Pro
Default=False
FileKey1=%ProgramFiles%\Wondershare Video Converter Pro\Log|*.*|RECURSE
FileKey2=%ProgramFiles%\Wondershare Video Converter Pro\TempThumbDir|*.*|RECURSE
FileKey3=%CommonAppData%\Wondershare Video Converter Pro|*.dat.bak
FileKey4=%CommonAppData%\Wondershare Video Converter Pro\TempSiteIconDir
FileKey5=%CommonAppData%\Wondershare Video Converter Pro\TempThumbDir
Link to comment
Thanks!
Any itunes users have input on post 3929?
also
[OpenOffice.org*]
LangSecRef=3021
Detect1=HKLM\SOFTWARE\OpenOffice.org
Detect2=HKLM\SOFTWARE\Wow6432Node\OpenOffice.org
Detect3=HKLM\SOFTWARE\OpenOffice
Detect4=HKLM\SOFTWARE\Wow6432Node\OpenOffice
Default=False
FileKey1=%AppData%\OpenOffice.org\*\user|*.log|RECURSE
FileKey2=%AppData%\OpenOffice.org\*\user|registrymodifications.xcu;registration.xml
FileKey3=%AppData%\OpenOffice.org\*\user\config\imagecache|*.*
FileKey4=%AppData%\OpenOffice.org\*\user\registry\cache|*.*
FileKey5=%AppData%\OpenOffice.org\*\user\registry\data\org\openoffice\Office|Views.xcu;Writer.xcu;Common.xcu;Histories.xcu
FileKey6=%AppData%\OpenOffice.org\*\user\registry\data\org\openoffice\ucb|Hierarchy.xcu;Store.xcu
FileKey7=%ProgramFiles%\OpenOffice.org 3\share\uno_packages\cache\uno_packages|*.tmp
FileKey8=%AppData%\OpenOffice\*\user|*.log|RECURSE
FileKey9=%AppData%\OpenOffice\*\user|registrymodifications.xcu;registration.xml
FileKey10=%AppData%\OpenOffice\*\user\config\imagecache|*.*
FileKey11=%AppData%\OpenOffice\*\user\registry\cache|*.*
FileKey12=%AppData%\OpenOffice\*\user\registry\data\org\openoffice\Office|Views.xcu;Writer.xcu;Common.xcu;Histories.xcu
FileKey13=%AppData%\OpenOffice\*\user\registry\data\org\openoffice\ucb|Hierarchy.xcu;Store.xcu
FileKey14=%ProgramFiles%\OpenOffice\share\uno_packages\cache\uno_packages|*.tmp
Added Detect 3 and 4.
Added FileKey 8-14
This should be cool for first.
Perhaps there should be another entry for Desktop Openoffice setup files. These are useless afer installation.
Link to comment
LangSecRef=3023
Default=False
I have iTunes 11.1.5.5. I was not able to find the path (%CommonAppData%\Apple Computer\iTunes\iPhone Temporary Files) on Windows 7 and 8 64-bit systems.
Link to comment
may be an xp only folder, thanks for the input
Not on XP either.
Perhaps an iPhone needs to be connected to generate the folder.
My Android can't help there.
Wondershare Video Converter Ultimate still exists.
I use the entry below to clean both Pro and Ultimate entries not covered by winapp.ini
The folders in REMOVESELF lines regenerate.
[Wondershare Video Converter*]
LangSecRef=3023
Default=False
FileKey1=%AllUsersProfile%\Documents\Wondershare|*.*|REMOVESELF
FileKey2=%CommonAppData%\Wondershare Video Converter*|*.dat.bak
FileKey3=%CommonAppData%\Wondershare Video Converter*\TempSiteIconDir
FileKey4=%CommonAppData%\Wondershare Video Converter*\TempThumbDir
FileKey5=%ProgramFiles%\Wondershare\Video Converter*\Log|*.*|REMOVESELF
Link to comment
Not on XP either.
LangSecRef=3023
Default=False
You misunderstood, I was talking about the "Pro" version which is now obsolete.
Link to comment
For the soon to be released Malwarebytes Anti-Malware 2.0.  I recommend that this code be "in addition" to the current Malwarebytes Anti-Malware code in Winapp2.ini because many people may elect not to upgrade to this new version.
[Malwarebytes Anti-Malware 2.0*]
LangSecRef=3024
Detect=HKLM\Software\Microsoft\Windows\CurrentVersion\App Paths\mbam.exe
Default=False
FileKey1=%CommonAppData%\Malwarebytes\Malwarebytes Anti-Malware\Logs|*.*
Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 980 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System);  Windows 10 x64 Pro on Dell 8700 SE desktop, Intel i7 4770 CPU, 24 gbyte RAM, Samsung 850 EVO mSATA 512 gbyte SSD, Samsung 850 Pro 512 gbyte SSD, Nvidia 750 Ti:   Windows 10x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet.  ASUS RT-AC88U router, 8 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2019 (Local), Casper 10, DisplayFusion (3 Flat Panel Displays per system):   Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD20, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more.
Link to comment
Edited
Added |RECURSE to filekey 1&2
[SkyDrive App Logs*]
LangSecRef=3031
DetectFile=%LocalAppData%\Microsoft\Windows\SkyDrive
Default=False
FileKey1=%LocalAppData%\Microsoft\Windows\SkyDrive\logs|*.*|RECURSE
FileKey2=%LocalAppData%\Microsoft\SkyDrive\logs|*.*|RECURSE
Link to comment
I don't think they're going to have a choice. I don't see Malwarebytes continuing to offer definition updates for legacy versions of their scanning engine.
I'm Shane.
Link to comment
  • Moderators
Probably the same people still rocking xp after next month will keep mwb's current version B)
OS and software updates are two different categories though. I'll personally update to MBAM 2.0, and it isn't like there's a choice anyways because when running the updater it will automatically download the new version.
Link to comment
New Entry:
[CrashDumps]
LangSecRef=3021
Detect=%AppData%\CrashDumps
Default=False
FileKey1=%AppData%\CrashDumps\*.*|RECURSE
This is my first one I created myself without any help. I don't know if it is right, but I'll give it a shot.
I am a maintainer for Winapp2. I also have a open-source group on Steam.
http://steamcommunity.com/groups/opencommunity
Link to comment
  • Moderators
New Entry:
[CrashDumps]
LangSecRef=3021
Default=False
Crash dumps for what? Windows? A specific program?
Link to comment
Looks like crash dumps for any game or program that had a crash. I currently have disciples.exe (game) and explorer.exe (windows) DMP files. I am on Windows 7 64-bit, by the way, so it might be different for windows 8 or xp. I think this belongs under the application section.
Link to comment
CrashDumps actually used to be an entry but has since been baked into winsys.ini
[Memory Dumps]
ID=1015
LangSecRef=3003
LangRef=3143
Default=True
FileKey1=%windir%|memory.dmp
FileKey2=%windir%\MiniDump|*.dmp
FileKey3=%LocalAppData%\CrashDumps|*.dmp
Is your path in %AppData% or %localappdata%?
Link to comment
Register a new account
Sign in
Important Information
