Winapp2.ini additions
Winapp2.ini
Added RegKey1 and FileKeys 10 & 11
[Netflix*]
LangSecRef=3031
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\4DF9E0F8.Netflix_mcm4njqhnhss8
DetectFile=%LocalAppData%\Packages\4DF9E0F8.Netflix_mcm4njqhnhss8
Default=False
FileKey1=%LocalAppData%\Packages\4DF9E0F8.Netflix_*\AC\INetCache|*.*|RECURSE
FileKey2=%LocalAppData%\Packages\4DF9E0F8.Netflix_*\AC\INetCookies|*.*|RECURSE
FileKey3=%LocalAppData%\Packages\4DF9E0F8.Netflix_*\AC\INetHistory|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\4DF9E0F8.Netflix_*\AC\Microsoft\CLR_v4.0\UsageLogs|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\4DF9E0F8.Netflix_*\AC\PRICache|*.*
FileKey6=%LocalAppData%\Packages\4DF9E0F8.Netflix_*\AC\Temp|*.*
FileKey7=%LocalAppData%\Packages\4DF9E0F8.Netflix_*\TempState|*.*|RECURSE
FileKey8=%LocalAppData%\Packages\4DF9E0F8.Netflix_*\LocalState|*.tmp|RECURSE
FileKey9=%LocalAppData%\Packages\4DF9E0F8.Netflix_*\LocalState\LiveTile|*.*
FileKey10=%LocalAppData%\Packages\4DF9E0F8.Netflix_*\AC\Microsoft\CryptnetUrlCache\Content|*.*
FileKey11=%LocalAppData%\Packages\4DF9E0F8.Netflix_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.*
RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\4DF9E0F8.Netflix_mcm4njqhnhss8\SearchHistory
Edited by Coffee4Joe
Link to comment
How to make CCleaner start after downloading new winapi.ini with CCEnhancer-3.9 ?
I'm sure a very old version i used to have ,would start ccleaner after the new winapi.ini had downloaded.
All i can see in the options is to start ccleaner silently,but i want ccleaner to start normally and automatically after the new winapi.ini has finished downloading.
I always have to physically click on ccleaner.exe to start it and that way doesn't seem to load the CCEnhancer ini entries.
This started happening after i updated to the 3 versions of CCEnhancer (a while ago now),and i've never been able to get that function back,where ccleaner just opens up after running  CCEnhancer.
I'm sure it used to work with the old v2 of CCEnhancer.
p.s..i tried editing portable location,but it doesn't make any difference.
it seems to happen on installed and portable versions of ccleaner.
EDIT::it's the same on win7 and win xp.
Link to comment
CCEnhancer is not a supported Piriform product so questions about it won't/can't be answered here I'm afraid, try the CCEnhancer site
(MODERATOR EDIT: LINKING TO SITE ALSO NOT SUPPORTED, IF USER HAS IT, THEY KNOW WHERE TO GO).
Link to comment
Added Filekey 5,6,&7
[Skype Metro More*]
LangSecRef=3031
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.SkypeApp_kzf8qxf38zg5c
DetectFile=%LocalAppData%\Packages\Microsoft.SkypeApp_kzf8qxf38zg5c
Default=False
FileKey1=%LocalAppData%\Packages\Microsoft.SkypeApp_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.*
FileKey2=%LocalAppData%\Packages\Microsoft.SkypeApp_*\AC\PRICache|*.*
FileKey3=%LocalAppData%\Packages\Microsoft.SkypeApp_*\LocalState|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\Microsoft.SkypeApp_*\TempState|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\Microsoft.SkypeApp_*\AC\INetCache|*.*|RECURSE
FileKey6=%LocalAppData%\Packages\Microsoft.SkypeApp_*\AC\INetCookies|*.*|RECURSE
FileKey7=%LocalAppData%\Packages\Microsoft.SkypeApp_*\AC\INetHistory|*.*|RECURSE
Link to comment
You wanna have some consistency then as there are several posts suggesting, and linking to, the CCEnhancer site here previously (that's where I got the link from ;) ). And they clearly don't know where to go or they wouldn't keep turning up here, so I don't see any problem pointing them in the right direction, after all the purpose of this forum is to help people isn't it ;)
Link to comment
  • Moderators
If there are other links it's just cause they were missed by moderation staff, not for lack of consistency. The developers are (currently) tolerant of the existence of enhancing product but have ask it not be mentioned, promoted or aided openly on the forum as it slightly fractures the program's license. On a personal note, it is unwise to argue with moderation especially when said moderator is working on a 15 total-sleep-hour week (insert stupid winky face here)
Link to comment
No one's arguing (seriously), so personal note not necessary.
If that's the rule though it may be an idea for a mod to do a forum search for the program at some point and remove links to it as that's what I did to make sure I was ok to link to it's site. Perhaps a forum sticky could be made at some point stating that it can't be discussed and why (I presumed it was the same reason as why we don't discuss or help with rival cleaners, was totally unaware of licensing issues)
Link to comment
There's a link to this thread at the top of winapp2.ini, so it's possible people who download the file with voldemort and then seek assistance follow that link in lieu of going back to the ministry of magic
So it would be an easy fix then to stop those users coming here - either they remove the link address when using it, or you can remove it, after all most users who have it from here got it from this thread so probably know exactly where to come.
Edit: Actually, having just read the first section of winapp2 for the first time, I didn't realise "they who shall not be named" were named in the file, let alone so prominently. So we can host, and promote download of, a file with 'their' website, Twitter, Facebook, donate links, yet we can't mention the website on the forum thread all that is hosted? What, briefly, are the licensing issues Nergal mentioned? (feel free to pm me if stating that is also too sensitive to post)
Link to comment
To be fair, a link to the BleachBit (we're allowed to mention that here, right?) forums should also be added to the top of the file. Andrew's users could get confused about the proper support channels too.
I'm Shane.
Link to comment
I'm liking it. The new mouse friendly context menu when right clicking apps on start is nice. I was hoping they'd add a faster way to fully close apps instead of dragging and holding them on the bottom, but that might be me being impatent.
Link to comment
Yes it's there, The X puts the app into the suspended state instead of fully closing. I think the system is supposed self terminate suspended apps after x-time has passed or if you're running low on memory/battery. I normally just alt+f4 to close one and use the drag 'n hold if I need to restart it.
Link to comment
Sorry if this is the wrong place to start a new conversation, but I have recently started using Winapp2.ini and thought I would point out that the OpenOffice entry appears not to relate to OpenOffice 4 as the FileKeys are incorrect.
e.g. FileKey2 should be %AppData%\OpenOffice\4\user|registrymodifications.xcu;registration.xml
and FileKey7 should be%AppData%\OpenOffice\4\user\uno_packages\cache\uno_packages|*.tmp
I am afraid I cannot correct all the entries and am also uncomfortable knowing whether even the above corrections are safe.
Hope this helps and that eventually there will be an updated entry in Winapp2.ini.
Link to comment
Thanks for posting :) That modification is actually pending, the next update will be
[OpenOffice.org*]
LangSecRef=3021
Detect1=HKLM\SOFTWARE\OpenOffice.org
Detect2=HKLM\SOFTWARE\Wow6432Node\OpenOffice.org
Detect3=HKLM\SOFTWARE\OpenOffice
Detect4=HKLM\SOFTWARE\Wow6432Node\OpenOffice
Default=False
FileKey1=%AppData%\OpenOffice*\*\user|*.log|RECURSE
FileKey2=%AppData%\OpenOffice*\*\user|registrymodifications.xcu;registration.xml
FileKey3=%AppData%\OpenOffice*\*\user\config\imagecache|*.*
FileKey4=%AppData%\OpenOffice*\*\user\registry\cache|*.*
FileKey5=%AppData%\OpenOffice*\*\user\registry\data\org\openoffice\Office|Views.xcu;Writer.xcu;Common.xcu;Histories.xcu
FileKey6=%AppData%\OpenOffice*\*\user\registry\data\org\openoffice\ucb|Hierarchy.xcu;Store.xcu
FileKey7=%ProgramFiles%\OpenOffice*\share\uno_packages\cache\uno_packages|*.tmp
Link to comment
Updated
What's new in winapp2.ini 4.11.140312
General:
20 New Entries
12 Modified Entries
04 Removed Entries
Verbose:
New Entries:
[Adobe Customization Wizard*]
LangSecRef=3021
Detect=HKCU\Software\Adobe\Adobe Customization Wizard 8
Detect2=HKCU\Software\Adobe\Adobe Customization Wizard 9
Detect3=HKCU\Software\Adobe\Adobe Customization Wizard X
Detect4=HKCU\Software\Adobe\Adobe Customization Wizard XI
Default=False
RegKey1=HKCU\Software\Adobe\Adobe Customization Wizard 8\Recent File List
RegKey2=HKCU\Software\Adobe\Adobe Customization Wizard 9\Recent File List
RegKey3=HKCU\Software\Adobe\Adobe Customization Wizard X\Recent File List
RegKey4=HKCU\Software\Adobe\Adobe Customization Wizard XI\Recent File List
[Anfibia Switch*]
LangSecRef=3021
Detect=HKCU\Software\Anfibia Switch
Default=False
FileKey1=%CommonAppData%\Anfibia Switch|*.log|RECURSE
[Auto Text Expander*]
LangSecRef=3021
DetectFile=%AppData%\Winsome Technologies\Auto Text Expander 1.0
Default=False
FileKey1=%AppData%\Winsome Technologies\Auto Text Expander 1.0|*.log
[Chrome HTML5 Storage*]
LangSecRef=3029
SpecialDetect=DET_CHROME
DetectFile1=%LocalAppData%\Chromium
DetectFile2=%LocalAppData%\Google\Chrome
DetectFile3=%LocalAppData%\Google\Chrome SxS
DetectFile4=%ProgramFiles%\Google\Chrome
DetectFile5=%ProgramFiles%\Google\Chrome SxS
Default=False
FileKey1=%LocalAppData%\Chromium\User Data\*\File System|*.*|REMOVESELF
FileKey2=%LocalAppData%\Google\Chrome*\User Data\*\File System|*.*|REMOVESELF
[Disk Space Fan History*]
Warning=You will need to rescan your disks.
Detect=HKCU\Software\Cookapp\DSF4
Default=False
FileKey1=%AppData%\DiskSpaceFan|history_C.sqlite
[Disk Space Fan Log*]
LangSecRef=3024
Default=False
FileKey1=%AppData%\DiskSpaceFan|log.txt
[Dr.Web CureIt! Log*]
LangSecRef=3024
DetectFile=%UserProfile%\Doctor Web
Default=False
FileKey1=%UserProfile%\Doctor Web|*.log
[Duke Nukem 3D*]
Section=Games
Detect=HKCU\Software\Valve\Steam\Apps\225140
Default=False
FileKey1=%ProgramFiles%\Steam\SteamApps\common\Duke Nukem 3D\bin|stderr.txt;stdout.txt
[Efficient Calendar*]
LangSecRef=3021
DetectFile=%AppData%\Efficient Calendar
Default=False
FileKey1=%AppData%\Efficient Calendar\MRUItems|*.*|RECURSE
[Email Index*]
LangSecRef=3030
SpecialDetect=DET_THUNDERBIRD
Default=False
Warning=This will cause your message index to be deleted, searching emails may be slow until it is rebuilt.
FileKey1=%AppData%\Thunderbird\Profiles|global-messages-db.sqlite|RECURSE
[FileManager*]
LangSecRef=3031
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\FileManager_cw5n1h2txyewy
Default=False
[Hyper for Youtube*]
LangSecRef=3031
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\19120CensoredUser.HyperforYouTube_c0tqyanwsgfn6
DetectFile=%LocalAppData%\Packages\19120CensoredUser.HyperforYouTube_c0tqyanwsgfn6
Default=False
FileKey1=%LocalAppData%\Packages\*.HyperforYouTube_*\AC\Microsoft\CryptnetUrlCache\Content|*.*
FileKey2=%LocalAppData%\Packages\*.HyperforYouTube_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.*
FileKey3=%LocalAppData%\Packages\*.HyperforYouTube_*\AC\INetCache|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\*.HyperforYouTube_*\AC\INetCookies|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\*.HyperforYouTube_*\AC\INetHistory|*.*|RECURSE
FIleKey6=%LocalAppData%\Packages\*.HyperforYouTube_*\TempState|*.*|RECURSE
FileKey7=%LocalAppData%\Packages\*.HyperforYouTube_*\LocalState|*.*|RECURSE
FileKey8=%LocalAppData%\Packages\*.HyperforYouTube_*\AC\Microsoft\CLR_v4.0\UsageLogs|*.*|RECURSE
RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\19120CensoredUser.HyperforYouTube_c0tqyanwsgfn6\SearchHistory
[iPhone Temporary Files*]
LangSecRef=3023
Detect=HKLM\SOFTWARE\Apple Computer, Inc.\iTunes
Default=False
FileKey1=%CommonAppData%\Apple Computer\iTunes\iPhone Temporary Files|*.*|RECURSE
[Malwarebytes Anti-Malware 2.0*]
LangSecRef=3024
Detect=HKLM\Software\Microsoft\Windows\CurrentVersion\App Paths\mbam.exe
Default=False
FileKey1=%CommonAppData%\Malwarebytes\Malwarebytes Anti-Malware\Logs|*.*
[RecollX*]
LangSecRef=3021
DetectFile=%AppData%\Advansys\RecollX
Default=False
FileKey1=%AppData%\Advansys\RecollX\log|*.*|RECURSE
[Reflector Dump Files*]
LangSecRef=3021
DetectFile=%AppData%\Reflector
Default=False
FileKey1=%AppData%\Reflector|*.dmp
[Reflector Log Files*]
LangSecRef=3021
Default=False
FileKey1=%AppData%\Reflector|*.log
[WinSAT Shader Cache*]
DetectOS=6.0
LangSecRef=3025
DetectFile=%WinDir%\Performance\WinSAT
Default=False
FileKey1=%WinDir%\Performance\WinSAT|shadercache*.*
[Wondershare Video Converter*]
LangSecRef=3023
Detect=HKLM\SOFTWARE\Wondershare\Wondershare Video Converter Pro
Default=False
FileKey1=%AllUsersProfile%\Documents\Wondershare|*.*|REMOVESELF
FileKey2=%CommonAppData%\Wondershare Video Converter*|*.dat.bak
FileKey3=%CommonAppData%\Wondershare Video Converter*\TempSiteIconDir
FileKey4=%CommonAppData%\Wondershare Video Converter*\TempThumbDir
FileKey5=%ProgramFiles%\Wondershare\Video Converter*\Log|*.*|REMOVESELF
[Wondershare Video Converter Ultimate*]
LangSecRef=3023
Detect=HKLM\SOFTWARE\Wondershare Video Converter Ultimate
Default=False
FileKey1=%ProgramFiles%\Wondershare Video Converter Ultimate\Log|*.*|RECURSE
FileKey2=%ProgramFiles%\Wondershare Video Converter Ultimate\TempThumbDir|*.*|RECURSE
FileKey3=%CommonAppData%\Wondershare Video Converter Ultimate|*.dat.bak
FileKey4=%CommonAppData%\Wondershare Video Converter Ultimate\TempSiteIconDir|*.*|REMOVESELF
FileKey5=%CommonAppData%\Wondershare Video Converter Ultimate\TempThumbDir|*.*|REMOVESELF
Modified Entries:
[Aimersoft Video Converter Ultimate*]
LangSecRef=3023
Detect=HKLM\SOFTWARE\Aimersoft\Aimersoft Video Converter Ultimate
Default=False
FileKey1=%ProgramFiles%\Aimersoft\Video Converter Ultimate\Log|*.*|RECURSE
FileKey2=%ProgramFiles%\Aimersoft\Video Converter Ultimate\TempThumbDir|*.*|RECURSE
FileKey3=%CommonAppData%\Aimersoft Video Converter Ultimate|*.dat.bak
FileKey4=%CommonAppData%\Aimersoft Video Converter Ultimate\TempSiteIconDir|*.*|REMOVESELF
FileKey5=%CommonAppData%\Aimersoft Video Converter Ultimate\TempThumbDir|*.*|REMOVESELF
    - Added FileKey2
    - Imrpoved FileKeys4 and 5
[Chrome GPU Cache*]
LangSecRef=3029
Default=False
FileKey1=%LocalAppData%\Chromium\User Data\*\GPUCache|*.*
FileKey2=%LocalAppData%\Google\Chrome*\User Data\*\GPUCache|*.*
FileKey3=%ProgramFiles%\Google\Chrome*\User Data\*\GPUCache|*.*
    - Fixed FileKey numbering
[Clam Sentinel*]
LangSecRef=3021
Detect=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{060FE577-1BDF-4330-ACCA-B6760AB07191}_is1
Default=False
FileKey1=%AppData%\ClamSentinel|*.txt
FileKey2=%AllUsersProfile%\.clamwin\log|*.*|REMOVESELF
FileKey3=%ProgramFiles%\ClamSentinel|*.txt
[ClamWin*]
LangSecRef=3021
Detect=HKLM\SOFTWARE\ClamWin
Default=False
FileKey1=%AppData%\.clamwin\log|*.*|REMOVESELF
FileKey3=%ProgramFiles%\ClamWin\bin|*.txt
[iSkysoft Video Converter Ultimate*]
LangSecRef=3023
Detect=HKLM\SOFTWARE\iSkysoft\iSkysoft Video Converter Ultimate
Default=False
FileKey1=%ProgramFiles%\iSkysoft\Video Converter Ultimate\Log|*.*|RECURSE
FileKey2=%ProgramFiles%\iSkysoft\Video Converter Ultimate\TempThumbDir|*.*|RECURSE
FileKey3=%CommonAppData%\iSkysoft Video Converter Ultimate|*.dat.bak
FileKey4=%CommonAppData%\iSkysoft Video Converter Ultimate\TempSiteIconDir|*.*|REMOVESELF
FileKey5=%CommonAppData%\iSkysoft Video Converter Ultimate\TempThumbDir|*.*|REMOVESELF
    - Added FileKey2
    - Improved FileKeys4 and 5
[Local Storage*]
Warning=This will completely clear all local storage items.
LangSecRef=3029
DetectFile1=%LocalAppData%\Torch
Default=False
FileKey1=%LocalAppData%\Chrome Plus\User Data\*\Local Storage|http*.*|RECURSE
FileKey2=%LocalAppData%\Chromium\User Data\*\Local Storage|http*.*|RECURSE
FileKey3=%LocalAppData%\Flock\User Data\*\Local Storage|http*.*|RECURSE
FileKey4=%LocalAppData%\Google\Chrome\User Data\*\Local Storage|http*.*|RECURSE
FileKey5=%LocalAppData%\Google\Chrome SxS\User Data\*\Local Storage|http*.*|RECURSE
FileKey6=%LocalAppData%\Rockmelt\User Data\*\Local Storage|http*.*|RECURSE
FileKey7=%LocalAppData%\SRWare Iron\User Data\*\Local Storage|http*.*|RECURSE
FileKey8=%LocalAppData%\Torch\User Data\*\Local Storage|http*.*|RECURSE
    - No longer deletes extension preferences
[Netflix*]
LangSecRef=3031
Default=False
    - Added RegKey1
    - Added FileKey10 and 11
[NVIDIA Logs*]
LangSecRef=3023
Detect=HKLM\Software\NVIDIA Corporation
Default=False
FileKey1=%CommonAppData%\NVIDIA|*.log|RECURSE
FileKey2=%CommonAppData%\NVIDIA\NvBackend|*.log|RECURSE
FileKey3=%LocalAppData%\NVIDIA\NvBackend|*.bak
FileKey4=%ProgramFiles%\NVIDIA Corporation\NetworkAccessManager\Apache Group\Apache2\logs|*.*
    - Added FileKey4
[OpenOffice.org*]
LangSecRef=3021
Default=False
    - Added Detect3 and 4
    - Improved all FileKeys
[SkyDrive App Logs*]
LangSecRef=3031
DetectFile=%LocalAppData%\Microsoft\Windows\SkyDrive
Default=False
FileKey1=%LocalAppData%\Microsoft\Windows\SkyDrive\logs|*.*|RECURSE
FileKey2=%LocalAppData%\Microsoft\SkyDrive\logs|*.*|RECURSE
    - Improved FileKeys1 and 2
[Skype Metro More*]
LangSecRef=3031
Default=False
    - Added FileKey5 through 7
[X-Chat 2*]
LangSecRef=3022
DetectFile=%AppData%\X-Chat 2
Default=False
Warning=This removes Chat Scrollback and Logs
FileKey1=%AppData%\X-Chat 2\scrollback|*.*|REMOVESELF
FileKey2=%AppData%\X-Chat 2\xchatlogs|*.*|REMOVESELF
    - Added warning
Removed Entries:
[Adobe Customization Wizard 8*]
LangSecRef=3021
Default=False
    - Condensed into Adobe Customization Wizard
[Adobe Customization Wizard 9*]
LangSecRef=3021
Detect=HKCU\Software\Adobe\Adobe Customization Wizard 9
Default=False
RegKey1=HKCU\Software\Adobe\Adobe Customization Wizard 9\Recent File List
[Adobe Customization Wizard X*]
LangSecRef=3021
Detect=HKCU\Software\Adobe\Adobe Customization Wizard X
Default=False
RegKey1=HKCU\Software\Adobe\Adobe Customization Wizard X\Recent File List
[Adobe Customization Wizard XI*]
LangSecRef=3021
Detect=HKCU\Software\Adobe\Adobe Customization Wizard XI
Default=False
RegKey1=HKCU\Software\Adobe\Adobe Customization Wizard XI\Recent File List
Link to comment
Register a new account
Sign in
Important Information
