CCleaner Community Forums
Winapp2.ini additions
Winapp2.ini
@FreeRyde:
[Clam Sentinel**]
LangSecRef=3021
Detect=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{060FE577-1BDF-4330-ACCA-B6760AB07191}_is1
Default=False
FileKey1=%AllUsersProfile%\ClamSentinel|*.txt
FileKey2=%AppData%\ClamSentinel|*.txt
FileKey3=%ProgramFiles%\ClamSentinel|*.txt
I have logs in AppData in ClamSentinel. I assumed if you installed it for all users, which I just installed it for myself, then the logs would be located in all users. I have the AppData ones because that is where mine is installed because I just installed it for myself. If you run through the installer of ClamWin, you will see what I mean. They are correct as it is.
I am a maintainer for Winapp2. I also have a open-source group on Steam.
http://steamcommunity.com/groups/opencommunity
Link to comment
I'm fiddling with winapp2:
Are these 5 lines bugs?
DetectFile=ProgramFiles%\CFE Exam Prep Course
FileKey1=%CommonAppData\1click dvd copy pro|*.log
RegKey1=%HKCU\Software\sms.at\mysms\cookies
FileKey2=%Documents\Tencent Files|*.*|RECURSE
FileKey1=%CommonAppData\Trend Micro|*.log
Yes, they're either missing a % or have one where they shouldn't. Thanks!
Link to comment
On my XP PC...
%AllUsersProfile% is:
C:\Documents and Settings\All Users
%CommonAppData% is:
C:\Documents and Settings\All Users\Application Data
Maybe it's time I did an upgrade or time to go to bed. Probably both.
I didn't know that. In Vista or 7 the all users folder was condensed into just the programdata folder, in fact, for compatibility purposes, the application data folder is still in there.
Link to comment
@FreeRyde:
Good point... I did indeed install to All Users.
Link to comment
  • Moderators
[Comodo Dragon (More)*]
LangSecRef=3029 is missing
It was probably confused in that post I made when I updated it. I clearly gave a choice to use a LangSecRef, or what I'm doing from now on which is combining all of my Comodo software into it's very own unique section using something like this for example (without a LangSecRef):
Section=Comodo
Link to comment
New entry:
[Ableton Live Suite*]
LangSecRef=3023
Detect=HKLM\Software\Propellerhead Software\ReWire\Ableton Live Engine
Default=False
FileKey1=%AppData%\Ableton\Live Reports\Temp|*.*|REMOVESELF
FileKey2=%AppData%\Ableton\Live Reports\Usage|*.*|REMOVESELF
FileKey3=%AppData%\Ableton\*\Preferences|AsioLog.txt;Indexer.txt;Log.txt|RECURSE
FileKey4=%CommonAppData%\Ableton\*\Redist|vcredist*.exe
FileKey5=%ProgramFiles%\Ableton\*\Redist|vcredist*.exe
Modified:
[Ableton Live Decoding Cache*]
LangSecRef=3023
Detect=HKLM\SOFTWARE\Propellerhead Software\ReWire\Ableton Live Engine
Default=False
FileKey1=%AppData%\Ableton\Cache|*.*|RECURSE
- Changed LangSecRef to 3023 = Multimedia
Modified 'CI3demo':
[Chicken Invaders*]
Section=Games
DetectFile1=%AppData%\InterAction studios\CI3demo
DetectFile2=%ProgramFiles%\ChickenInvaders*
DetectFile3=%ProgramFiles%\Chicken Invaders*
Default=False
FileKey1=%AppData%\InterAction studios|*.log|RECURSE
FileKey2=%CommonAppData%\InterAction studios|*.log|RECURSE
FileKey3=%ProgramFiles%\ChickenInvaders*|*.log|RECURSE
FileKey4=%ProgramFiles%\Chicken Invaders*|*.log|RECURSE
FileKey5=%ProgramFiles%\*\Chicken Invaders*|*.log;*.html;*.png|RECURSE
- Renamed to Chicken Invaders
- Changed LangSecRef=3025 to Section=Games
- Added DetectFile2 and 3
- Edited FileKey1
- Added FileKey2 through 5
- All Chicken Invaders versions
Link to comment
New Entry
[Wondershare SafeEraser*]
LangSecRef=3021
Detect=HKLM\Software\Wondershare\SafeEraser
Default=False
FileKey1=%SystemDrive%\se_tmp|*.*|REMOVESELF
FileKey2=%AppData%\Wondershare\SafeEraser|*.log
FileKey3=%AppData%\HYXDevPsnList|*.*|REMOVESELF
I have corrected the Detect.
Edited by SMalik
Link to comment
New Entry
[Aviary Photo Editor*]
LangSecRef=3031
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\57AB5DD0.PhotoEditor_6hb943tstq5q8
DetectFile=%LocalAppData%\Packages\57AB5DD0.PhotoEditor_6hb943tstq5q8
Default=False
FileKey1=%LocalAppData%\Packages\57AB5DD0.PhotoEditor_*\AC\AppCache|*.*|RECURSE
FileKey2=%LocalAppData%\Packages\57AB5DD0.PhotoEditor_*\AC\INetCache|*.*|RECURSE
FileKey3=%LocalAppData%\Packages\57AB5DD0.PhotoEditor_*\AC\INetCookies|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\57AB5DD0.PhotoEditor_*\AC\INetHistory|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\57AB5DD0.PhotoEditor_*\AC\Microsoft\CLR_v4.0|*.log|RECURSE
FileKey6=%LocalAppData%\Packages\57AB5DD0.PhotoEditor_*\AC\Microsoft\CLR_v4.0\NativeImages\Temp|*.*|RECURSE
FileKey7=%LocalAppData%\Packages\57AB5DD0.PhotoEditor_*\AC\Microsoft\CLR_v4.0_32|*.log|RECURSE
FileKey8=%LocalAppData%\Packages\57AB5DD0.PhotoEditor_*\AC\Microsoft\CLR_v4.0_32\NativeImages\Temp|*.*|RECURSE
FileKey9=%LocalAppData%\Packages\57AB5DD0.PhotoEditor_*\AC\Temp|*.*
FileKey10=%LocalAppData%\Packages\57AB5DD0.PhotoEditor_*\LocalState|*.*|RECURSE
FileKey11=%LocalAppData%\Packages\57AB5DD0.PhotoEditor_*\TempState|*.*|RECURSE
Link to comment
Hey all,
Was wondering, I know this Detect=HKLM\SOFTWARE\ entrie is used for 32bit systems and this Detect=HKLM\SOFTWARE\Wow6432Node with 64bit systems.
I just did a test with Detect=HKLM\SOFTWARE\ and Detect=HKLM\SOFTWARE\Wow6432Node where the software was installed under Wow6432Node and CCleaner entrie was Detect=HKLM\SOFTWARE\, the entrie worked.
Now my question is: Why do we add Detect1=HKLM\SOFTWARE\ and Detect2=HKLM\SOFTWARE\Wow6432Node  then to a entrie ?
Every line of code written by man can be undone by man
"A loser in the real world is still a loser in the net!" - .hack//SIGN
Getting old is inevitable,  growing up is optional !!
Link to comment
Hey all,
You're right there is no need to add Detect2.
Link to comment
New Entry:  [Western Digital MyCloud Drive (Logs)*]
LangSecRef=3024
Detect=HKLM\Software\Western Digital\WD My Cloud
Default=False
FileKey1=%ProgramData%\Western Digital\Logs\WD QuickView\*\|*.log
FileKey2=%LocalAppData%\Western Digital\WDNasSetup\|*.*|RECURSE
Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 980 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System);  Windows 10 x64 Pro on Dell 8700 SE desktop, Intel i7 4770 CPU, 24 gbyte RAM, Samsung 850 EVO mSATA 512 gbyte SSD, Samsung 850 Pro 512 gbyte SSD, Nvidia 750 Ti:   Windows 10x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet.  ASUS RT-AC88U router, 8 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2019 (Local), Casper 10, DisplayFusion (3 Flat Panel Displays per system):   Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD20, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more.
Link to comment
New Entries
Should these go in Store or Games?
[Halo Spartan Assault*]
LangSecRef=3031
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.HaloSpartanAssault_8wekyb3d8bbwe
DetectFile=%LocalAppData%\Packages\Microsoft.HaloSpartanAssault_8wekyb3d8bbwe
Default=False
FileKey1=%LocalAppData%\Packages\Microsoft.HaloSpartanAssault_*\AC\Microsoft\CryptnetUrlCache\Content|*.*
FileKey2=%LocalAppData%\Packages\Microsoft.HaloSpartanAssault_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.*
FileKey3=%LocalAppData%\Packages\Microsoft.HaloSpartanAssault_*\AC\INetCache|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\Microsoft.HaloSpartanAssault_*\AC\INetCookies|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\Microsoft.HaloSpartanAssault_*\AC\INetHistory|*.*|RECURSE
[Shark Dash*]
LangSecRef=3031
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\GAMELOFTSA.SharkDashByGameloft_0pp20fcewvvtj
DetectFile=%LocalAppData%\Packages\GAMELOFTSA.SharkDashByGameloft_0pp20fcewvvtj
Default=False
FileKey1=%LocalAppData%\Packages\GAMELOFTSA.SharkDashByGameloft_*\AC\Microsoft\CryptnetUrlCache\Content|*.*
FileKey2=%LocalAppData%\Packages\GAMELOFTSA.SharkDashByGameloft_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.*
FileKey3=%LocalAppData%\Packages\GAMELOFTSA.SharkDashByGameloft_*\AC\INetCache|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\GAMELOFTSA.SharkDashByGameloft_*\AC\INetCookies|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\GAMELOFTSA.SharkDashByGameloft_*\AC\INetHistory|*.*|RECURSE
[Angry Birds Star Wars*]
LangSecRef=3031
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\1ED5AEA5.AngryBirdsBlack_p2gbknwb5d8r2
DetectFile=%LocalAppData%\Packages\1ED5AEA5.AngryBirdsBlack_p2gbknwb5d8r2
Default=False
FileKey1=%LocalAppData%\Packages\*.AngryBirdsBlack_*\AC\Microsoft\CryptnetUrlCache\Content|*.*
FileKey2=%LocalAppData%\Packages\*.AngryBirdsBlack_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.*
FileKey3=%LocalAppData%\Packages\*.AngryBirdsBlack_*\AC\INetCache|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\*.AngryBirdsBlack_*\AC\INetCookies|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\*.AngryBirdsBlack_*\AC\INetHistory|*.*|RECURSE
[Angry Birds Space*]
LangSecRef=3031
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\1ED5AEA5.AngryBirdsSpace_p2gbknwb5d8r2
DetectFile=%LocalAppData%\Packages\1ED5AEA5.AngryBirdsSpace_p2gbknwb5d8r2
Default=False
FileKey1=%LocalAppData%\Packages\*.AngryBirdsSpace_*\AC\Microsoft\CryptnetUrlCache\Content|*.*
FileKey2=%LocalAppData%\Packages\*.AngryBirdsSpace_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.*
FileKey3=%LocalAppData%\Packages\*.AngryBirdsSpace_*\AC\INetCache|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\*.AngryBirdsSpace_*\AC\INetCookies|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\*.AngryBirdsSpace_*\AC\INetHistory|*.*|RECURSE
[Gravity Guy*]
LangSecRef=3031
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\MiniclipSA.GravityGuy_gpanv85qtf6rc
DetectFile=%LocalAppData%\Packages\MiniclipSA.GravityGuy_gpanv85qtf6rc
Default=False
FileKey1=%LocalAppData%\Packages\MiniclipSA.GravityGuy_*\AC\Microsoft\CryptnetUrlCache\Content|*.*
FileKey2=%LocalAppData%\Packages\MiniclipSA.GravityGuy_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.*
FileKey3=%LocalAppData%\Packages\MiniclipSA.GravityGuy_*\AC\INetCache|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\MiniclipSA.GravityGuy_*\AC\INetCookies|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\MiniclipSA.GravityGuy_*\AC\INetHistory|*.*|RECURSE
[Reckless Racing*]
LangSecRef=3031
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Studios.RecklessRacingUltimate_8wekyb3d8bbwe
DetectFile=%LocalAppData%\Packages\Microsoft.Studios.RecklessRacingUltimate_8wekyb3d8bbwe
Default=False
FileKey1=%LocalAppData%\Packages\Microsoft.Studios.RecklessRacingUltimate_*\AC\Microsoft\CryptnetUrlCache\Content|*.*
FileKey2=%LocalAppData%\Packages\Microsoft.Studios.RecklessRacingUltimate_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.*
FileKey3=%LocalAppData%\Packages\Microsoft.Studios.RecklessRacingUltimate_*\AC\INetCache|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\Microsoft.Studios.RecklessRacingUltimate_*\AC\INetCookies|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\Microsoft.Studios.RecklessRacingUltimate_*\AC\INetHistory|*.*|RECURSE
[Shuffle Party*]
LangSecRef=3031
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.ShuffleParty_8wekyb3d8bbwe
DetectFile=%LocalAppData%\Packages\Microsoft.ShuffleParty_8wekyb3d8bbwe
Default=False
FileKey1=%LocalAppData%\Packages\Microsoft.ShuffleParty_*\AC\Microsoft\CryptnetUrlCache\Content|*.*
FileKey2=%LocalAppData%\Packages\Microsoft.ShuffleParty_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.*
FileKey3=%LocalAppData%\Packages\Microsoft.ShuffleParty_*\AC\INetCache|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\Microsoft.ShuffleParty_*\AC\INetCookies|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\Microsoft.ShuffleParty_*\AC\INetHistory|*.*|RECURSE
Edited by Coffee4Joe
Link to comment
Modified
Added FileKey 8&9
[Netflix*]
LangSecRef=3031
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\4DF9E0F8.Netflix_mcm4njqhnhss8
DetectFile=%LocalAppData%\Packages\4DF9E0F8.Netflix_mcm4njqhnhss8
Default=False
FileKey1=%LocalAppData%\Packages\4DF9E0F8.Netflix_*\AC\INetCache|*.*|RECURSE
FileKey2=%LocalAppData%\Packages\4DF9E0F8.Netflix_*\AC\INetCookies|*.*|RECURSE
FileKey3=%LocalAppData%\Packages\4DF9E0F8.Netflix_*\AC\INetHistory|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\4DF9E0F8.Netflix_*\AC\Microsoft\CLR_v4.0\UsageLogs|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\4DF9E0F8.Netflix_*\AC\PRICache|*.*
FileKey6=%LocalAppData%\Packages\4DF9E0F8.Netflix_*\AC\Temp|*.*
FileKey7=%LocalAppData%\Packages\4DF9E0F8.Netflix_*\TempState|*.*|RECURSE
FileKey8=%LocalAppData%\Packages\4DF9E0F8.Netflix_*\LocalState|*.tmp|RECURSE
FileKey9=%LocalAppData%\Packages\4DF9E0F8.Netflix_*\LocalState\LiveTile|*.*
Link to comment
New entries:
[Chicken Hunter*]
Section=Games
Detect=HKLM\Software\Chicken Hunter
Default=False
FileKey1=%ProgramFiles%\Chicken Hunter|debug.txt
[HP Drive Key Boot Utility*]
LangSecRef=3024
Detect=HKLM\Software\microsoft\windows\currentversion\uninstall\HP Drive Key Boot Utility
Default=False
FileKey1=%SystemDrive%\CPQSYSTEM|*.*|REMOVESELF
Modified:
[AI Roboform*]
LangSecRef=3022
Detect=HKCU\Software\Siber Systems
Default=False
FileKey1=%AppData%\RoboForm\_gsdata_mirrors_|*.*|RECURSE
FileKey2=%AppData%\RoboForm\_mirrors_|*.*|RECURSE
FileKey3=%Documents%\My RoboForm Data\_gsdata_|*.log;*.gss;*.gsl
FileKey4=%Documents%\My RoboForm Data|mru.rfo;cache.rfo
FileKey5=%Documents%\My RoboForm Data\*|mru.rfo;cache.rfo
RegKey1=HKCU\Software\Siber Systems|_InstallerDir
RegKey2=HKCU\Software\Siber Systems\RoboForm\Query-MRU
ExcludeKey1=FILE|%ProgramFiles%\Siber Systems\AI RoboForm\affid.txt
- Added FileKey2
- Added RegKey1
Link to comment
New entry:
[Rock of Ages*]
Section=Games
Detect=HKCU\Software\Valve\Steam\Apps\22230
Detect2=HKLM\Software\ACE Team\Rock of Ages
Default=False
FileKey1=%ProgramFiles%\ATLUS\Rock of Ages\Prerequisites|*.*|REMOVESELF
FileKey2=%ProgramFiles%\Steam\steamapps\common\Rock of Ages\Prerequisites|*.*|REMOVESELF
Link to comment
New entries:
[Drivers Installer Assistant*]
LangSecRef=3024
Detect=HKCU\Software\VB and VBA Program Settings\Drivers Installer Assistant
Default=False
FileKey1=%WinDir%\Logs\DIALog|*.txt
[DriverPack Solution Bug Report*]
LangSecRef=3024
Detect=HKCU\Software\drpsu
Default=False
Warning=This will delete your bug report! Use this if you really know what you are doing!
FileKey1=%WinDir%\Logs\SysInfo|*.*
FileKey3=%Documents%\DRP-Log|*.*
DriverPack Solution Bug Report - will automatically send information to development FTP after finishing examing your computer, so i guess its nothing to do with that information for average user
Link to comment
[NVIDIA GFExperience Logs*]
LangSecRef=3023
Detect=HKLM\Software\NVIDIA Corporation
Default=False
FileKey1=%SystemDrive%\NvidiaLogging\GFExperience|GridClientLog.log*|RECURSE
FileKey2=%CommonAppData%\NVIDIA Corporation\ShadowPlay|CaptureCore.log;*.bak;*.stat
FileKey3=%CommonAppData%\NVIDIA Corporation\GeForce Experience\Logs|GfeClientLog.log
FileKey4=%LocalAppData%\NVIDIA Corporation\ShadowPlay|*.log;*.bak
-Add Filkey 2,3,4
[NVIDIA Logs*]
LangSecRef=3023
Default=False
FileKey1=%CommonAppData%\NVIDIA|*.log|RECURSE
FileKey2=%CommonAppData%\NVIDIA\NvBackend|*.log|RECURSE
FileKey3=%LocalAppData%\NVIDIA\NvBackend|*.bak
-Add Filkey 3
[NVIDIA Updates*]
LangSecRef=3023
Default=False
FileKey1=%CommonAppData%\Nvidia\Updates|*.bak
FileKey2=%CommonAppData%\Nvidia\Updatus|*.bak
FileKey3=%CommonAppData%\Nvidia\NvBackend\Updates|*.bak
FileKey4=%CommonAppData%\Nvidia\NvBackend\Updatus|*.bak
FileKey5=%CommonAppData%\NVIDIA|Resource.old
-Add Filkey 5
Link to comment
Added RegKey1
[FilmOn*]
LangSecRef=3031
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\FilmOnLiveTVFree.FilmOnLiveTVFree_zx03kxexxb716
DetectFile=%LocalAppData%\Packages\FilmOnLiveTVFree.FilmOnLiveTVFree_zx03kxexxb716
Default=False
FileKey1=%LocalAppData%\Packages\FilmOnLiveTVFree.FilmOnLiveTVFree_*\AC\Microsoft\CryptnetUrlCache\Content|*.*
FileKey2=%LocalAppData%\Packages\FilmOnLiveTVFree.FilmOnLiveTVFree_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.*
FileKey3=%LocalAppData%\Packages\FilmOnLiveTVFree.FilmOnLiveTVFree_*\AC\Microsoft\CLR_v4.0\UsageLogs|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\FilmOnLiveTVFree.FilmOnLiveTVFree_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\FilmOnLiveTVFree.FilmOnLiveTVFree_*\AC\INetCache|*.*|RECURSE
FileKey6=%LocalAppData%\Packages\FilmOnLiveTVFree.FilmOnLiveTVFree_*\AC\INetCookies|*.*|RECURSE
FileKey7=%LocalAppData%\Packages\FilmOnLiveTVFree.FilmOnLiveTVFree_*\AC\INetHistory|*.*|RECURSE
RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\FilmOnLiveTVFree.FilmOnLiveTVFree_zx03kxexxb716\SearchHistory
Link to comment
[Total Uninstall 6*]
LangSecRef=3024
Detect=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Total Uninstall 6_is1
Default=False
FileKey1=%CommonAppData%\Martau\Total Uninstall 6\*|*.*|REMOVESELF
Total Uninstall 5 & 6 are already covered in Winapp2.ini as 'Total Uninstall' entry.
Link to comment
Revised Entry
Added: %LocalAppData%\Corel PaintShop Pro\16.0\Cache|*.*  and RegKey1
[Corel PaintShop Pro X6 More*]
LangSecRef=3023
Detect=HKCU\Software\Corel\PaintShop Pro\X6
Default=False
FileKey1=%LocalAppData%\Corel PaintShop Pro\16.0\Cache|*.*
FileKey2=%LocalAppData%\Corel PaintShop Pro\16.0\Database|*.db
RegKey1=HKCU\Software\Corel\PaintShop Pro\X6\CoreMemoryManager\0
Please replace [Adobe Acrobat More*] with [Adobe Updater Logs*]
Merged [Adobe Acrobat More*] and [Adobe Updater Logs*] entries
LangSecRef=3021
Detect=HKCU\Software\Adobe
Default=False
FileKey2=%LocalAppData%\Adobe\AAMUpdater|*.Log|RECURSE
FileKey3=%LocalAppData%\Adobe\Updater*|*.log|RECURSE
FileKey1=%LocalAppData%\Adobe\Acrobat\*\Updater|*.log
FileKey1=%AppData%\Adobe\LogTransport*\Logs|ulog_*.tmp
FileKey2=%AppData%\Adobe\Acrobat\*\Updater|*.log
New Entry
Moved: HKCU\Software\Adobe\Acrobat Distiller\PrinterJobControl  from [Adobe Acrobat More*] to [Adobe Acrobat Distiller*]
LangSecRef=3021
Detect=HKCU\Software\Adobe\Acrobat Distiller
Default=False
FileKey1=%AppData%\Adobe\Acrobat\Distiller 11|*.log
FileKey2=%AppData%\Adobe\Acrobat\Distiller 11\Cache|*.*
RegKey1=HKCU\Software\Adobe\Acrobat Distiller\PrinterJobControl
Please replace [Adobe Acrobat Cache*] entry with [Adobe Acrobat XI More*]
Changed [Adobe Acrobat Cache*] entry name to [Adobe Acrobat XI More*].
LangSecRef=3021
Detect=HKCU\Software\Adobe\Adobe Acrobat
Default=False
FileKey1=%LocalAppData%\Adobe\Acrobat|*.idx|RECURSE
FileKey2=%LocalAppData%\Adobe\Acrobat\11.0|UserCache.bin
FileKey3=%LocalAppData%\Adobe\Acrobat\11.0\Cache|*.*
Looks more professional after the changes :)
Link to comment
Any idea what is this for?
[Adobe Incompatible Icons*]
LangSecRef=3021
Default=False
FileKey1=%CommonProgramFiles%\Adobe|*.icns|RECURSE
FileKey2=%ProgramFiles%\Adobe|*.icns|RECURSE
Link to comment
Register a new account
Sign in
