Moderators Andavari Posted December 28, 2013 Moderators Share Posted December 28, 2013 Don't you just hate some programs. Just spent half an hour going through Steam directories and making an entry to remove all non-English language files, lots of them in various directories (20Mb worth), then find Steam reinstalls when you try to launch it. Go through the 11-12 filekeys to try to find the troublesome one only to find if you tounch ANY of them, Steam reinstalls when you start it! I can't stand all those extra lang files being installed, but some programs refuse to operate with them missing, at least Steam reinstalls itself versus giving you no info at all as to what the problem is. One would think by now that practically all installers should/would be smart enough to not install non-system default lang files by reading what the default system lang is on the machine. I removed about 200MB (that's a crazy amount) of non-Eng lang files from an embroidery software my mother uses, and luckily it didn't break the piggish thing. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted December 28, 2013 Moderators Share Posted December 28, 2013 After repeated testing, the entries below are fine as is... ClamWin did quarantine several files; though false-positve. The quarantine logs are now stored in the Quarantine folder. 'Quarantine Browser' aka 'QRecover' is used to view content, log, and delete, or restore files. Deletion of the other log files had no bearing upon quarantined file recovery, etc. Everything restored fine after running the entry. The restoration issues you mention date back to version 0.96.4 in 2010. This has been resolved. ClamScanLog.txt is no longer used for restoration. Sidenote: This AV used extremely low resources, but used 749 MB drive space (mostly AV definitions) and has very aggressive heuristics. Sorry to cause you testing, I just remember something being posted a while ago about problems arising from deleting the scan log, just didn't realise it was from 2010. The last time I used ClamWin Portable which was months ago the defs were under 100MB, if I'm remembering correctly. I always end up deleting it off the system due to so many false positives. Link to comment Share on other sites More sharing options...
SMalik Posted December 29, 2013 Share Posted December 29, 2013 New Entry [internet History More*] LangSecRef=3029 DetectFile1=%LocalAppData%\Google\Chrome DetectFile2=%LocalAppData%\Google\Chrome SxS DetectFile3=%ProgramFiles%\Google\Chrome DetectFile4=%ProgramFiles%\Google\Chrome SxS Default=False FileKey1=%LocalAppData%\Google\Chrome\User Data\Default|History Link to comment Share on other sites More sharing options...
FreeRyde Posted December 29, 2013 Share Posted December 29, 2013 Sorry to cause you testing, I just remember something being posted a while ago about problems arising from deleting the scan log, just didn't realise it was from 2010. The last time I used ClamWin Portable which was months ago the defs were under 100MB, if I'm remembering correctly. I always end up deleting it off the system due to so many false positives. Don't be sorry, I appreciate the need to get things right. I post thinking to myself, "Have at 'er boys!" , anticipating scrutiny. If I clear the cut I'm happy. Better to have you guys challenge an entry than numerous POed users after Winapp2 posts. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted December 29, 2013 Author Share Posted December 29, 2013 New Entry [internet History More*] LangSecRef=3029 DetectFile1=%LocalAppData%\Google\Chrome DetectFile2=%LocalAppData%\Google\Chrome SxS DetectFile3=%ProgramFiles%\Google\Chrome DetectFile4=%ProgramFiles%\Google\Chrome SxS Default=False FileKey1=%LocalAppData%\Google\Chrome\User Data\Default|History If I'm not mistaken this will break chrome installs lower than version 32 winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted December 29, 2013 Share Posted December 29, 2013 If I'm not mistaken this will break chrome installs lower than version 32 I have Version 31.0.1650.63 m on my system, no issues at all. Link to comment Share on other sites More sharing options...
FreeRyde Posted December 30, 2013 Share Posted December 30, 2013 New entries: [Avast! Browser Cleanup*] LangSecRef=3024 Detect=HKCU\Software\AVAST Software\Avast Browser Cleanup Default=False RegKey1=HKCU\Software\AVAST Software\Avast Browser Cleanup [Listary*] LangSecRef=3024 Detect=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Listary_is1 Default=False FileKey1=%AppData%\Listary\CrashRpt|*.*|REMOVESELF FileKey2=%ProgramFiles%\SysTracer|*.log [MultiHasher*] LangSecRef=3024 Detect=HKLM\SOFTWARE\abelhadigital.com\MultiHasher Default=False FileKey1=%ProgramFiles%\MultiHasher|*.txt;*.zip|RECURSE [Should I Remove It? (Cache)*] LangSecRef=3024 Detect=HKCU\Software\Reason Default=False FileKey1=%ProgramFiles%\Reason\Should I Remove It|programdata.dat RegKey1=HKCU\Software\Reason\ShouldIRemoveIt\Cache [Stardock Fences*] LangSecRef=3024 Detect=HKLM\SOFTWARE\Stardock\Misc\Fences Detect2=HKLM\SOFTWARE\Stardock\Misc\Fences2 Default=False FileKey1=%AppData%\Stardock\Fences\TroubleshootingLog|*.txt FileKey2=%ProgramFiles%\Stardock\Fences|*.txt [SysTracer*] LangSecRef=3024 Detect=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\SysTracer Default=False FileKey1=%ProgramFiles%\SysTracer|SysTracerLog.txt FileKey2=%ProgramFiles%\SysTracer\tmp|*.*|REMOVESELF [SysTracer (Snapshots)*] LangSecRef=3024 Detect=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\SysTracer Default=False Warning=This will delete all of your snapshots. FileKey1=%ProgramFiles%\SysTracer\data|*.snp Modified: [AnyDVDHD*] LangSecRef=3024 Detect=HKCU\Software\SlySoft\AnyDVD Default=False FileKey1=%Documents%\AnyDVD_logs|*.*|REMOVESELF - Added REMOVESELF to FileKey1. Folder will regenerate. [Avast! Antivirus More*] LangSecRef=3024 Detect=HKCU\Software\AVAST Software\Avast Detect2=HKLM\Software\AVAST Software\Avast Default=False FileKey1=%CommonAppData%\AVAST Software\Avast\backup|*.*|RECURSE FileKey2=%CommonAppData%\AVAST Software\Avast\report|*.txt FileKey3=%CommonAppData%\AVAST Software\Avast\log|*.* FileKey4=%CommonAppData%\AVAST Software\Avast|Log.db;backend.txt - Added Detect2. HKLM since version 6.x Link to comment Share on other sites More sharing options...
siliconman01 Posted December 30, 2013 Share Posted December 30, 2013 New Entry: Bitdefender Total Security 2014 (Logs) [bitDefender Total Security 2014 (Logs)*]LangSecRef=3024Detect=HKLM\Software\BitDefender\Bitdefender Total SecurityWarning=This removes only logs created while scanning external drives and other special unneeded scan logs generated by Bitdefender scanner.Default=FalseFileKey1=%Appdata%\Bitdefender\Desktop\profiles\Logs\*\|*.xml Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
SMalik Posted December 30, 2013 Share Posted December 30, 2013 Please do not add any entries for SysTracer (http://www.blueproject.ro/systracer) like FreeRyde suggested. It is a program that tracks registry and file system changes. Removing the SysTracerLog.txt will corrupt the snapshot. It also does not make sense to remove .snp (snapshots). Please be careful when adding entries that remove .txt or .log files from the programs installation directory. Link to comment Share on other sites More sharing options...
FreeRyde Posted December 30, 2013 Share Posted December 30, 2013 Removing the 'SysTracerLog' won't corrupt anything... Here is the content of my generated SysTracerLog of 4 snapshots. It is simple information which has no bearing on working with any snapshot(s), their comparison, view, or export. There is no snapshot ID to associate any log content to a particular snapshot.. All snapshot information is read from the snapshot not the log. That info is already in the snapshot. The log is redundant , unnecessary, and has no check for growth. It could vaguely tell of a thousand snapshots which don't even exist; as they were deleted long ago. I have used this program extensively for years, and have never encountered the scenerio you suggest. Snapshot done in 00:02 74 reg keys, 91 values 0 folders, 0 files 0 apps, 0 dlls Snapshot done in 00:01 0 reg keys, 0 values 1 folders, 5 files 0 apps, 0 dlls Snapshot done in 00:13 0 reg keys, 0 values 1,624 folders, 10,367 files 0 apps, 0 dlls Snapshot done in 00:02 74 reg keys, 91 values 0 folders, 0 files 0 apps, 0 dlls The program doesn't auto track any registry or system changes. The user manually takes 'snapshots' which SysTracer Pro can compare, display differences, and export results if the user chooses. SysTracer's GUI also has a button to delete snapshots. I quess it makes sense to the author also. When I have finished determining differences in snapshots I delete them. I've added 'Warning' for you. I had thought the name of the entry self-explanatory. Link to comment Share on other sites More sharing options...
Alan_B Posted December 30, 2013 Share Posted December 30, 2013 I can't stand all those extra lang files being installed, but some programs refuse to operate with them missing, at least Steam reinstalls itself versus giving you no info at all as to what the problem is. One would think by now that practically all installers should/would be smart enough to not install non-system default lang files by reading what the default system lang is on the machine. I removed about 200MB (that's a crazy amount) of non-Eng lang files from an embroidery software my mother uses, and luckily it didn't break the piggish thing. I have an easy potential solution to the problem. Do not delete the files but replace them with short files that have the same names. It is possible that even zero length files might be acceptable replacements. I suggest testing this potential solution by replacing one of the unwanted files first, and if that does not break the installation try replacing all the unwanted files. If you identify an installation that benefits from the above, then a BAT script could be implemented that would automate removal whenever the application is updated and language files are re-installed. Below is a part of simple BAT script that eliminates unwanted Lang folders from the Foxmarks extensions of my Palemoon Browser before it launches CCleaner. A totally new and more complex BAT script would be needed to replace large files with small files instead of zapping the unwanted folders and contents. I am too busy with other projects to engage with this at the moment, but there are experts available and willing to quickly produce complex scripts if you register and ask at http://www.dostips.com/forum/viewforum.php?f=3 FOR %%a IN (Alan User) DO ( CD /D C:\Users\%%a\AppData\Roaming\Moonchild Productions\Pale Moon\Profiles\*.default\EXTENS~1\FOXMAR~1.COM\chrome\locale\ IF EXIST F* ( DIR | FIND "/" SET ANS=N & SET /P ANS="PURGE from "%%a" Profile all above except en-US ? P(urge) / N(o) :- " IF "!ANS!"=="P" ( ECHO PURGING C:\Users\%%a\AppData\Roaming\Mozilla\Firefox\Profiles\ ... FOR /D %%X IN (*) DO IF NOT %%X==en-US ECHO -RMDIR- /S /Q %%X FOR /D %%X IN (*) DO IF NOT %%X==en-US RMDIR /S /Q %%X PAUSE ) ) ) I test whether the "F*" file exists to determine whether a fresh installation of all languages has occurred. That test takes far less than one second, but if the unwanted stuff has arrived it takes somewhat longer to list all targets so I can abort if for some reason it is about to inflict collateral damage, and then after I authorize Purge they all go. NB I do not hate the French - but any application with foreign languages will include French. Link to comment Share on other sites More sharing options...
FreeRyde Posted December 30, 2013 Share Posted December 30, 2013 I have an easy potential solution to the problem. Do not delete the files but replace them with short files that have the same names. It is possible that even zero length files might be acceptable replacements. This also works with some games, such as Grand Theft Auto, that have lengthy intros. The intro video can be replaced with an empty one of same name and extention. Link to comment Share on other sites More sharing options...
SMalik Posted December 30, 2013 Share Posted December 30, 2013 Removing the 'SysTracerLog' won't corrupt anything... Here is the content of my generated SysTracerLog of 4 snapshots. It is simple information which has no bearing on working with any snapshot(s), their comparison, view, or export. There is no snapshot ID to associate any log content to a particular snapshot.. All snapshot information is read from the snapshot not the log. That info is already in the snapshot. The log is redundant , unnecessary, and has no check for growth. It could vaguely tell of a thousand snapshots which don't even exist; as they were deleted long ago. I have used this program extensively for years, and have never encountered the scenerio you suggest. Snapshot done in 00:02 74 reg keys, 91 values 0 folders, 0 files 0 apps, 0 dlls Snapshot done in 00:01 0 reg keys, 0 values 1 folders, 5 files 0 apps, 0 dlls Snapshot done in 00:13 0 reg keys, 0 values 1,624 folders, 10,367 files 0 apps, 0 dlls Snapshot done in 00:02 74 reg keys, 91 values 0 folders, 0 files 0 apps, 0 dlls The program doesn't auto track any registry or system changes. The user manually takes 'snapshots' which SysTracer Pro can compare, display differences, and export results if the user chooses. SysTracer's GUI also has a button to delete snapshots. I quess it makes sense to the author also. When I have finished determining differences in snapshots I delete them. I've added 'Warning' for you. I had thought the name of the entry self-explanatory. I'm also using this program since the first build. The entry you have suggested will remove all of the snapshots at once compared to the one in the program in which you can delete the ones you want. Link to comment Share on other sites More sharing options...
SMalik Posted December 30, 2013 Share Posted December 30, 2013 Revised Entry Corrected the FileKey12 [Windows Communications Apps*] LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\microsoft.windowscommunicationsapps_8wekyb3d8bbwe DetectFile=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\AppCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\INetCache|*.*|RECURSE FileKey3=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\INetCookies|*.*|RECURSE FileKey4=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\INetHistory|*.*|RECURSE FileKey5=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\Microsoft\CLR_v4.0\UsageLogs|*.*|RECURSE FileKey6=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\Microsoft\CryptnetUrlCache\Content|*.* FileKey7=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.* FileKey8=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey9=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\PRICache|*.* FileKey10=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\Temp|*.* FileKey11=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\TempState|*.*|RECURSE FileKey12=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\LocalState\LiveComm\*\*\DBStore\LogFiles|*.log RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\microsoft.windowscommunicationsapps_8wekyb3d8bbwe\SearchHistory Link to comment Share on other sites More sharing options...
FreeRyde Posted December 30, 2013 Share Posted December 30, 2013 I'm also using this program since the first build. The entry you have suggested will remove all of the snapshots at once compared to the one in the program in which you can delete the ones you want. Yup, it sure will... as the 'Warning' advises... If you don't want to delete them, don't check the entry. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted December 31, 2013 Author Share Posted December 31, 2013 Never thought about the empty files to replace useless lang files. Would've been nice ~8yrs ago when I used iTunes, since it required an obnoxious amount of *.lproj files for langauges i don't speak winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted December 31, 2013 Share Posted December 31, 2013 Yup, it sure will... as the 'Warning' advises... If you don't want to delete them, don't check the entry. There shouldn't be any need to remove someones customized files like the SysTracer's snapshots. Someone here had an issue recently where an entry removed all of their playlists in Windows Media Player. Maybe, someone might come up with an entry with a 'warning' saying "This Will Remove the Whole Windows directory". Link to comment Share on other sites More sharing options...
Moderators Andavari Posted December 31, 2013 Moderators Share Posted December 31, 2013 I have an easy potential solution to the problem. Do not delete the files but replace them with short files that have the same names. It is possible that even zero length files might be acceptable replacements. I suggest testing this potential solution by replacing one of the unwanted files first, and if that does not break the installation try replacing all the unwanted files. Ah, yes, the good tricks of replacing with a dummy or empty file. I've used that before with other stuff but never thought of doing so with lang files. Of course if a program uses checksum/hash verification such as lang .dll files we'd still be stuck honouring it's reinstallation. Link to comment Share on other sites More sharing options...
FreeRyde Posted January 1, 2014 Share Posted January 1, 2014 New entries: [Active@ Disk Image*] LangSecRef=3024 Detect=HKLM\SOFTWARE\LSoft Technologies\Active Disk Image Default=False FileKey1=%ProgramFiles%\LSoft Technologies\Active@ Disk Image|*.txt FileKey2=%ProgramFiles%\LSoft Technologies\Active@ Disk Image\Logs|*.*|REMOVESELF [DVDSmith*] LangSecRef=3023 Detect=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\DVDSmith Movie Backup_is1 Default=False FileKey1=%Documents%\dvdsmith|*.log [Handle Regshot (Reports)*] LangSecRef=3024 DetectFile=%SystemDrive%\Hive Default=False FileKey1=%SystemDrive%\Hive|*.css;*.html;*.reg [Handle Regshot (Snapshots)*] LangSecRef=3024 DetectFile=%SystemDrive%\Hive Default=False Warning=This will delete all saved snapshots. FileKey1=%SystemDrive%\Hive|*.hive [Replay Media Catcher*] LangSecRef=3022 Detect=HKLM\SOFTWARE\Applian Technologies\Replay Media Catcher 5 Default=False FileKey1=%LocalAppData%\Replay Media Catcher 5\History|*.*|REMOVESELF FileKey2=%LocalAppData%\Replay Media Catcher 5\Temp|*.*|REMOVESELF FileKey3=%LocalAppData%\Replay Media Catcher 5\UrlCache|*.*|REMOVESELF FileKey4=%ProgramFiles%\Applian Technologies\Replay Media Catcher*|*.html;*.txt;*.rtf [System Mechanic*] LangSecRef=3024 Detect=HKCU\Software\iolo\System Mechanic Default=False FileKey1=%AppData%\iolo\SafetyNet\Temp|*.* FileKey2=%AppData%\ioloGovernor\logs|*.*|REMOVESELF FileKey3=%CommonAppData%\iolo|*.xml;*.txt FileKey4=%CommonAppData%\iolo\ACRSummaryFiles|*.*|REMOVESELF FileKey5=%CommonAppData%\iolo\logs|*.*|REMOVESELF FileKey6=%CommonAppData%\iolo\TempResources|*.*|REMOVESELF FileKey7=%ProgramFiles%\iolo\System Mechanic|*.txt;*.xml FileKey8=%SystemDrive%\Documents and Settings\LocalService\*\iolo|*.*|REMOVESELF FileKey9=%WinDir%\System32\config|iolo App.evt [System Mechanic (Snapshots)*] LangSecRef=3024 Detect=HKCU\Software\iolo\System Mechanic Default=False Warning=This will delete System Mechanic System Snapshots Data. FileKey1=%AppData%\iolo\System Snapshots Data|*.* [WinPcap*] LangSecRef=3022 Detect=HKLM\SOFTWARE\WinPcap Default=False FileKey1=%ProgramFiles%\WinPcap|*.log FileKey2=%WinDir%\System32|-1 Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 1, 2014 Author Share Posted January 1, 2014 Ah, yes, the good tricks of replacing with a dummy or empty file. I've used that before with other stuff but never thought of doing so with lang files. Of course if a program uses checksum/hash verification such as lang .dll files we'd still be stuck honouring it's reinstallation. That's a pretty agressive linguistics tactic winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
FreeRyde Posted January 2, 2014 Share Posted January 2, 2014 New entries: [Cinema Tycoon*] Section=Games Detect1=HKCU\Software\TikGames\Cinema Tycoon Gold Detect2=HKLM\SOFTWARE\Big Fish Games\Persistence\GameDB\Cinema Tycoon Gold Detect3=HKLM\SOFTWARE\Big Fish Games\Persistence\Install\F2676T1L1 Detect4=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Cinema Tycoon 2 Movie Mania1.0 Default=False FileKey1=%ProgramFiles%\Cinema Tycoon*|flashplayer7_winax.exe;*.txt FileKey2=%WinDir%|Cinema Tycoon 2 Movie Mania Setup Log.txt [Everything (History)*] LangSecRef=3024 Detect=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Everything DetectFile=%AppData%\Everything Default=False FileKey1=%AppData%\Everything|*.csv FileKey2=%ProgramFiles%\Everything|*.txt [My Horse and Me*] Section=Games Detect=HKLM\SOFTWARE\My Horse and Me 2 Default=False FileKey1=%ProgramFiles%\Atari\W!Games\My Horse and Me|++ Finish log.txt;++ Start log.txt|RECURSE [Planet Horse*] Section=Games Detect=HKLM\SOFTWARE\SOFTWARE\Big Fish Games\Persistence\Install\F6023T1L1 DetectFile=%ProgramFiles%\Planet Horse Default=False FileKey1=%ProgramFiles%\Planet Horse|output_log.txt|RECURSE [Riding Star 3*] Section=Games Detect=HKLM\SOFTWARE\DTP\Riding Star 3 Default=False FileKey1=%ProgramFiles%\Riding Star 3|INSTALL.LOG;log.txt FileKey2=%WinDir%|DirectX.log Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 2, 2014 Author Share Posted January 2, 2014 How's this for wmdb? [Windows Media Player (Databases)*]LangSecRef=3023Detect1=HKCR\Windows.Movie.MakerDetect2=HKCU\Software\Microsoft\MediaPlayerDefault=FalseWarning=This will remove ratings, play counts, last played, etc.FileKey1=%SystemDrive%\Documents and Settings\NetworkService\Local Settings\Application Data\Microsoft\Media Player|*.*|REMOVESELFFileKey2=%SystemDrive%\Documents and Settings\NetworkService\Local Settings\Microsoft\Media Player|*.*|REMOVESELFFileKey3=%WinDir%\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Media Player|*.*|RECURSEFileKey4=%LocalAppData%\Microsoft\Media Player|*.wmdb;wmdbexport.xmlFileKey5=%WinDir%\system32\config\systemprofile\Local Settings\Application Data\Microsoft\Media Player|*.wmdbFileKey6=%SystemDrive%\Documents and Settings\Default User\Local Settings\Application Data\Microsoft\Media Player|*.wmdbFileKey7=%SystemDrive%\Documents and Settings\Administrator\Local Settings\Application Data\Microsoft\Media Player|*.wmdbExcludeKey1=%LocalAppData%\Microsoft\Media Player|CurrentDatabase*.wmdbExcludeKey2=%SystemDrive%\Documents and Settings\*\Local Settings\Microsoft\Media Player|CurrentDatabase*.wmdb winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
FreeRyde Posted January 3, 2014 Share Posted January 3, 2014 New entries: [Nancy Drew - Secret of Shadow Ranch*] Section=Games Detect1=HKLM\SOFTWARE\Big Fish Games\Persistence\Install\F7041T1L1 Detect2=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Nancy Drew - Secret of Shadow Ranch - Plus Guide1.0 DetectFile=%ProgramFiles%\Nancy Drew* Default=False FileKey1=%ProgramFiles%\Nancy Drew*|dxwebsetup.exe;*.html FileKey2=%ProgramFiles%\*\Nancy Drew*|dxwebsetup.exe;*.html [Paragon Hard Disk Manager 14 Suite*] LangSecRef=3024 Detect=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\1138529294AEED1169C70005650C0080 Default=False FileKey1=%CommonAppData%\clonehdd|*.log FileKey2=%CommonAppData%\createpart|*.log FileKey3=%CommonAppData%\deletepart|*.log FileKey4=%CommonAppData%\explauncher|*.log FileKey5=%CommonAppData%\ftw|*.log FileKey6=%CommonAppData%\launcher|*.log FileKey7=%CommonAppData%\logsaver|*.log FileKey8=%CommonAppData%\migrateos|*.log FileKey9=%CommonAppData%\redistpart|*.log FileKey10=%CommonAppData%\vmadjust|*.log FileKey11=%CommonAppData%\vmcreate|*.log FileKey12=%CommonAppData%\wipe|*.log FileKey13=%ProgramFiles%\Paragon Software\Hard Disk Manager 14 Suite\*|BioNtLog.txt;cdb.log;fdisk.txt;pwlog.txt;stubact.log FileKey14=%ProgramFiles%\Paragon Software\Hard Disk Manager 14 Suite\*\symmpi*|*.txt FileKey15=%SystemDrive%\Documents and Settings\LocalService|objsrv.log FileKey16=%WinDir%\Logs\Paragon\Client|*.log FileKey17=%WinDir%\Logs\Paragon Software\UimSetup|*.log FileKey18=%WinDir%\Logs\Paragon Software\VssRequester|*.log [Paragon Partition Manager 2014*] LangSecRef=3024 Detect=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\F8855E740A3CED1189750005650C0080 Default=False FileKey1=%CommonAppData%\converthfs|*.log FileKey2=%CommonAppData%\createpart|*.log FileKey3=%CommonAppData%\deletepart|*.log FileKey4=%CommonAppData%\explauncher|*.log FileKey5=%CommonAppData%\formatpart|*.log FileKey6=%CommonAppData%\launcher|*.log FileKey7=%CommonAppData%\logsaver|*.log FileKey8=%CommonAppData%\redistpart|*.log FileKey9=%ProgramFiles%\Paragon Software\*\program|BioNtLog.txt;cdb.log;fdisk.txt;pwlog.txt;stubact.log FileKey10=%SystemDrive%\Documents and Settings\LocalService|objsrv.log FileKey11=%WinDir%\Logs\Paragon\Client|*.log FileKey12=%WinDir%\Logs\Paragon Software\VssRequester|*.log Link to comment Share on other sites More sharing options...
rjo98 Posted January 4, 2014 Share Posted January 4, 2014 For the ManyCam cleanup, what about cleaning up the AppData\Roaming\ManyCam\Settings\MoviesThumbnails folder? It doesn't appear to remove thumbnails when you remove movies from it's queue in the program. Link to comment Share on other sites More sharing options...
FreeRyde Posted January 4, 2014 Share Posted January 4, 2014 New entries: [Active@ KillDisk*] LangSecRef=3024 Detect=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{0F62EFB8-3C1C-4EE6-B6EF-9593007F9B03}_is1 Default=False FileKey1=%ProgramFiles%\LSoft Technologies\Active@ KillDisk*|*.log;*.pdf;*.xml ExcludeKey1=FILE|%ProgramFiles%\LSoft Technologies\Active@ KillDisk*|BootDisk.pdf ExcludeKey2=FILE|%ProgramFiles%\LSoft Technologies\Active@ KillDisk*|KillDisk.pdf [Active@ UNDELETE (Logs)*] LangSecRef=3024 Detect=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{9F0B916A-F7DD-4335-923E-397979C6AE1B}_is1 FileKey1=%ProgramFiles%\LSoft Technologies\Active@ UNDELETE*|*.log;*.scan;*.txt FileKey1=%ProgramFiles%\LSoft Technologies\Active@ UNDELETE*\sessions|*.log FileKey2=%SystemDrive%\Documents and Settings\Administrator\scan_results|*.*|REMOVESELF [Active@ UNDELETE (Images)*] LangSecRef=3024 Detect=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{9F0B916A-F7DD-4335-923E-397979C6AE1B}_is1 Warning=This will delete all saved disk images. FileKey1=%ProgramFiles%\LSoft Technologies\Active@ UNDELETE*\disk_images|*.*|REMOVESELF [Active@ UNDELETE (Recovered Files)*] LangSecRef=3024 Detect=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{9F0B916A-F7DD-4335-923E-397979C6AE1B}_is1 Warning=This will delete all recovered data. FileKey1=%ProgramFiles%\LSoft Technologies\Active@ UNDELETE*\recovered|*.*|REMOVESELF [Active@ UNDELETE (Sessions)*] LangSecRef=3024 Detect=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\{9F0B916A-F7DD-4335-923E-397979C6AE1B}_is1 Warning=This will delete all saved sessions. FileKey1=%ProgramFiles%\LSoft Technologies\Active@ UNDELETE*|*.usf|RECURSE [My Riding Stables*] Section=Games Detect=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\MyRidingStables Default=False FileKey1=%ProgramFiles%\My Riding Stables*|*.txt;*.url [My Singing Monsters*] Section=Games Detect1=HKLM\SOFTWARE\Big Fish Games\Persistence\Install\F7664T1L1 Detect2=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\My Singing Monsters1.1 DetectFile=%ProgramFiles%\My Singing Monsters Default=False FileKey1=%ProgramFiles%\My Singing Monsters|dotnetfx35setup.exe;vcredist_x86.exe FileKey2=%ProgramFiles%\My Singing Monsters|*.log;*.txt|RECURSE FileKey3=%ProgramFiles%\*\My Singing Monsters|dotnetfx35setup.exe;*.html;*.PNG;vcredist_x86.exe FileKey4=%ProgramFiles%\*\My Singing Monsters|*.log;*.txt|RECURSE [Ranch Rush*] Section=Games Detect1=HKLM\SOFTWARE\Big Fish Games\Persistence\Install\F2580T1L1 Detect2=HKLM\SOFTWARE\Big Fish Games\Persistence\Install\F5659T1L1 Detect3=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Ranch Rush1.0 DetectFile=%ProgramFiles%\Ranch Rush Default=False FileKey1=%CommonAppData%\FreshGames\RanchRush\*|*.log;temp_data.ssp FileKey2=%ProgramFiles%\Ranch Rush*|*.html;*.nfo FileKey3=%WinDir%|Ranch Rush Setup Log.txt [Ride!*] Section=Games Detect1=HKLM\SOFTWARE\Big Fish Games\Persistence\Install\F2440T1L1 Detect2=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\BFG-Ride! DetectFile=%ProgramFiles%\Ride! Default=False FileKey1=%ProgramFiles%\Ride!|*.log;*.txt|RECURSE FileKey2=%ProgramFiles%\Ride!\DirectX9|*.*|REMOVESELF FileKey3=%WinDir%|DirectX.log Link to comment Share on other sites More sharing options...
