Winapp2.ini additions
Winapp2.ini
Windows 8 mail app gets needing ID confirmation
I’ve been trying to figure out which checkboxes to undo to keep this from happening. It doesn’t log my mail accounts out, but will ask me to confirm my identity for mail, calendar, messaging and people if/when I open these apps. After entering my password, it does fine for a while and then asks me for confirmation again later after running CCleaner with CCEnhancer. I re-trusted my computer on my account just in case, but no luck.
Thanks in advance
Link to comment
  • Moderators
From this post:
http://forum.piriform.com/index.php?showtopic=32310&page=190&do=findComment&comment=244333
[Windows Installer Baseline Cache*]
LangSecRef=3025
DetectFile=%windir%\installer\$patchcache$
Default=False
FileKey1=%windir%\installer\$patchcache$|*.*|REMOVESELF
In XP it won't show anything in CCleaner's window when clicking "Analyze", however it will remove said files when clicking "Run Cleaner".
Perhaps a warning?
Warning=This cleaner will not display any files to be removed when clicking the Analyze button.
Edit 2:
Another interesting post about that cleaner, and the post following it, so it may not be safe.
Edited by Andavari
Added some links
Link to comment
Hello,
Firstly, a huge thank you for providing the winapp2.ini file!
I found that log files for AVG 2014 were not being removed, and worked out that the path on my PC was different to yours.
I replaced...
FileKey14=%WinDir%\System32\config\systemprofile\AppData\Local\Avg2014\log|*.*
with:
FileKey14=%WinDir%\System32\config\systemprofile\Local Settings\Application Data\Avg2014\log|*.*
I'm running under Win XP, SP3, with the latest versions of CCleaner and AVG. No idea if this is peculiar to my PC or to the particular OS version, but thought I'd flag it up in case anyone else has the same issue.
Regards,
Piers.
Link to comment
  • Moderators
Hello,
I replaced...
with:
Regards,
Piers.
Particular to XP
@Winapp2.ini this needs to be added as filekey15 I think, since there's no easy EV
Link to comment
Thanks in advance
Uncheck [Windows Communications Apps*] or replace that entry in winapp2.ini with the one here http://forum.piriform.com/index.php?showtopic=32310&page=189&do=findComment&comment=244132
Link to comment
New entry:
[System Volume Information Logs*]
LangSecRef=3025
Detect=HKLM\SYSTEM\CurrentControlSet\Control\ContentIndex\Catalogs\System
Default=False
FileKey1=%SystemDrive%\System Volume Information|tracking.log
FileKey2=%SystemDrive%\System Volume Information\Chkdsk|*.*|REMOVESELF
- FileKey1 regenerates when the drive is accessed.
- FileKey2 'Chkdsk' folder and log is only generated when Chkdsk.exe is run.
If you have additional partitions you will need to list as shown in the example below, as there is no wildcard for drives.
FileKey3=M:\System Volume Information|tracking.log
FileKey4=M:\System Volume Information\Chkdsk|*.*|REMOVESELF
FileKey5=S:\System Volume Information|tracking.log
FileKey6=S:\System Volume Information\Chkdsk|*.*|REMOVESELF
Modified:
[Windows XP MUICache*]
DetectOS=|5.1
LangSecRef=3025
Detect1=HKCU\Software\Microsoft\Windows\ShellNoRoam
Detect2=HKCU\Software\Microsoft\Windows\Shell
Default=False
RegKey1=HKCU\Software\Microsoft\Windows\ShellNoRoam\MUICache
RegKey2=HKCU\Software\Microsoft\Windows\Shell\MUICache
- Removed previous 'RegKey2=HKCU\Software\Microsoft\Windows\ShellNoRoam\DUIBags'
It was deleting Details Pane settings.
Link to comment
I've edited new entry posted above
Revised new entry:
LangSecRef=3025
Default=False
- Improved Detect
Link to comment
  • Moderators
Revised new entry:
LangSecRef=3025
Default=False
- Improved Detect
Not sure about messing with System Restore.
Link to comment
  • Moderators
Not sure it's even possible after WinXP is it as the system volume info folder is locked?
Completely locked on my XP system.
Trying to browse that folder with 7-Zip results into nothing, trying to do a "dir /s" on it in a command prompt reads "File Not Found".
Link to comment
Tracking.log and 'Chkdsk' folder and log, though generated into the relevant drive's System Volume Information folder, have nothing to do with System Restore:
They coincidentally share the same folder.
- FileKey1: Tracking.log regenerates when the drive is accessed.
- FileKey2:  'Chkdsk' folder and log is only generated if Chkdsk.exe is run; and are cumulative.
Technet MS library:
The Distributed Link Tracking Client service monitors activity on NTFS volumes and stores maintenance information in a file called Tracking.log, which is located at the root of each volume in a hidden folder called System Volume Information.
MountPointManagerRemoteDatabase file (0 byte system file associated with Dynamic Disks/Volumes), Content Indexing Service databases, Volume Shadow Copy Service (Volume Snapshot) so you can back up files on a live system, Efs0.log files created by the Encrypting File System generated during the encryption and decryption process, and restore point folders created by the System Restore service all share the System Volume Information folder and are untouched
I've been running the entry several times a day for a week without any issue.
The entry could be broken down into two:
Chkdisk Logs and Distributed Link Tracking Client Log.
Link to comment
Please remove the entry listed below. There is no .log file there to be removed ever. I have been watching this entry since PerfectDisk 12.5 & until the current build, 13.0. There is a file in that location called 'PDBootLog' and that is not a .log file. It is an essential file for the program. A snapshot of the location is attached with this post.
[PerfectDisk More*]
LangSecRef=3024
Detect=HKCU\Software\Raxco\PerfectDisk
Default=False
FileKey1=%CommonAppData%\Raxco\PerfectDisk\*|*.log
Link to comment
[PerfectDisk More*]
LangSecRef=3024
Default=False
I have PerfectDisk Pro V13 (Build 770) which is the latest version of PD.  There is a log created named PDBootlog.log.  It is generated when you do a Boot Time defrag.   This is on Windows 7 x86 Professional.
Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System);  Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC.  ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system):   Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more.
Link to comment
Edited
added FileKey4-8 and RegKey1
[Reddit To Go!*]
LangSecRef=3031
DetectFile=%LocalAppData%\Packages\*.RedditToGo_*
Default=False
FileKey1=%LocalAppData%\Packages\*.RedditToGo_*\RoamingState|history.txt
FileKey2=%LocalAppData%\Packages\*.RedditToGo_*\AC\Microsoft\CryptnetUrlCache\Content|*.*
FileKey3=%LocalAppData%\Packages\*.RedditToGo_*\AC\Microsoft\CryptnetUrlCache\MetaData*.*
FileKey4=%LocalAppData%\Packages\*.RedditToGo_*\AC\Microsoft\CLR_v4.0\UsageLogs|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\*.RedditToGo_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE
FileKey6=%LocalAppData%\Packages\*.RedditToGo_*\AC\INetCache|*.*|RECURSE
FileKey7=%LocalAppData%\Packages\*.RedditToGo_*\AC\INetCookies|*.*|RECURSE
FileKey8=%LocalAppData%\Packages\*.RedditToGo_*\AC\INetHistory|*.*|RECURSE
RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\55382ross456.RedditToGo_02dxdbb1qg9kw\SearchHistory
New
[FilmOn*]
LangSecRef=3031
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\FilmOnLiveTVFree.FilmOnLiveTVFree_zx03kxexxb716
DetectFile=%LocalAppData%\Packages\FilmOnLiveTVFree.FilmOnLiveTVFree_zx03kxexxb716
Default=False
FileKey1=%LocalAppData%\Packages\FilmOnLiveTVFree.FilmOnLiveTVFree_*\AC\Microsoft\CryptnetUrlCache\Content|*.*
FileKey2=%LocalAppData%\Packages\FilmOnLiveTVFree.FilmOnLiveTVFree_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.*
FileKey3=%LocalAppData%\Packages\FilmOnLiveTVFree.FilmOnLiveTVFree_*\AC\Microsoft\CLR_v4.0\UsageLogs|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\FilmOnLiveTVFree.FilmOnLiveTVFree_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\FilmOnLiveTVFree.FilmOnLiveTVFree_*\AC\INetCache|*.*|RECURSE
FileKey6=%LocalAppData%\Packages\FilmOnLiveTVFree.FilmOnLiveTVFree_*\AC\INetCookies|*.*|RECURSE
FileKey7=%LocalAppData%\Packages\FilmOnLiveTVFree.FilmOnLiveTVFree_*\AC\INetHistory|*.*|RECURSE
Edited by Coffee4Joe
Link to comment
New entry:
[GEAR DIFx Installers*]
LangSecRef=3023
Detect1=HKCR\Installer\Products\CACFC38969C58104B8CE6D8561446C45
Detect2=HKLM\SOFTWARE\GEAR Software\DIFx
Detect3=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Components\3EC13FCAF38E85F44B0F1137C7FB5037
Default=False
FileKey1=%AppData%\188F1432-103A-4ffb-80F1-36B633C5C9E1|*.*|REMOVESELF
FileKey2=%AppData%\34BE82C4-E596-4e99-A191-52C6199EBF69|*.*|REMOVESELF
FileKey3=%AppData%\9223B3E6-70DD-4e2f-965B-DD8E02D2E20B|*.*|REMOVESELF
FileKey4=%AppData%\Downloaded Installations|*.*|REMOVESELF
FileKey5=%CommonAppData%\188F1432-103A-4ffb-80F1-36B633C5C9E1|*.*|REMOVESELF
FileKey6=%CommonAppData%\34BE82C4-E596-4e99-A191-52C6199EBF69|*.*|REMOVESELF
FileKey7=%CommonAppData%\9223B3E6-70DD-4e2f-965B-DD8E02D2E20B|*.*|REMOVESELF
FileKey8=%CommonAppData%\9727E41D-AD6A-47cd-B9BC-CF630B6013FD|*.*|REMOVESELF
FileKey9=%CommonAppData%\A73B37F8-7A4D-41f4-98A8-7F608CE8B98F|*.*|REMOVESELF
FileKey10=%LocalAppData%\Downloaded Installations|*.*|REMOVESELF
FileKey11=%ProgramFiles%\188F1432-103A-4ffb-80F1-36B633C5C9E1|*.*|REMOVESELF
FileKey12=%ProgramFiles%\34BE82C4-E596-4e99-A191-52C6199EBF69|*.*|REMOVESELF
FileKey13=%ProgramFiles%\38FDB89C-1EBD-4366-84B2-336D12CC3209|*.*|REMOVESELF
FileKey14=%ProgramFiles%\9223B3E6-70DD-4e2f-965B-DD8E02D2E20B|*.*|REMOVESELF
FileKey15=%ProgramFiles%\93E26451-CD9A-43A5-A2FA-C42392EA4001|*.*|REMOVESELF
FileKey16=%ProgramFiles%\9727E41D-AD6A-47cd-B9BC-CF630B6013FD|*.*|REMOVESELF
Link to comment
New Entries
[iSkysoft Helper Compact*]
LangSecRef=3021
Detect=HKLM\SOFTWARE\iSkysoft\iSkysoft Helper Compact
Default=False
FileKey1=%CommonProgramFiles%\iSkysoft\iSkysoft Helper Compact\log|*.*|RECURSE
[iSkysoft Video Converter Ultimate*]
LangSecRef=3023
Detect=HKLM\SOFTWARE\iSkysoft\iSkysoft Video Converter Ultimate
Default=False
FileKey1=%ProgramFiles%\iSkysoft\Video Converter Ultimate\Log|*.*|RECURSE
FileKey2=%CommonAppData%\iSkysoft Video Converter Ultimate|*.dat.bak
FileKey3=%CommonAppData%\iSkysoft Video Converter Ultimate\TempSiteIconDir
FileKey4=%CommonAppData%\iSkysoft Video Converter Ultimate\TempThumbDir
Please replace [iSkysoft Video Converter Logs*] entry with the one listed below.
[iSkysoft Video Converter*]
LangSecRef=3023
Detect=HKLM\SOFTWARE\iSkysoft\Video Converter
Default=False
FileKey1=%ProgramFiles%\iSkysoft\Video Converter\Log|*.*|RECURSE
FileKey2=%CommonAppData%\iSkysoft Video Converter|*.dat.bak
Link to comment
Modified:
[FileLocator Pro*]
LangSecRef=3024
Detect=HKCU\Software\Mythicsoft\FileLocatorPro
Detect2=HKLM\Software\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\Products\61998E0EC8628684CBDA6355E18D8A3E
Default=False
FileKey1=%AppData%\Mythicsoft\FileLocatorPro\CrashReports|*.*|REMOVESELF
FileKey2=%AppData%\Mythicsoft\FileLocatorPro\logs|*.*|REMOVESELF
FileKey3=%AppData%\Mythicsoft\FileLocatorPro|history.xml|RECURSE
FileKey4=%ProgramFiles%\*\FileLocator*|*.log;history.xml|RECURSE
FileKey5=%ProgramFiles%\FileLocator*|*.log;history.xml|RECURSE
FileKey6=%ProgramFiles%\FileLocator*\CrashReports|*.*|REMOVESELF
FileKey7=%ProgramFiles%\FileLocator*\logs|*.*|REMOVESELF
RegKey1=HKCU\Software\Mythicsoft\FileLocatorPro\RecentContains
RegKey2=HKCU\Software\Mythicsoft\FileLocatorPro\RecentFileName
RegKey3=HKCU\Software\Mythicsoft\FileLocatorPro\RecentFolders
- Added Detect2
- Added FileKey1 through 7
Link to comment
New Entry
[Wondershare Dr.Fone for Android*]
LangSecRef=3021
Detect=HKLM\SOFTWARE\Wondershare\Dr.Fone for Android
Default=False
FileKey1=%ProgramFiles%\Wondershare\Dr.Fone for Android\log|*.*|RECURSE
FileKey2=%AppData%\Wondershare\DrFoneAndroid\log|*.*|RECURSE
Link to comment
Register a new account
Sign in
Important Information
