ROCKNROLL 0 Posted February 17, 2014 Share Posted February 17, 2014 I thought of an even better idea for the avast entries. Why not combine all 3 of them and have it like this:[Avast! Antivirus More*]LangSecRef=3024 Detect1=HKCU\Software\ALWIL Software\Avast\5.0 Detect2=HKCU\Software\AVAST Software\AvastDetect3=HKLM\Software\AVAST Software\AvastDefault=False FileKey1=%CommonAppData%\Alwil Software\Avast5\backup|*.*|RECURSE FileKey2=%CommonAppData%\AVAST Software\Avast\backup|*.*|RECURSEFileKey3=%CommonAppData%\AVAST Software\Avast\report|*.txtFileKey4=%CommonAppData%\AVAST Software\Avast\log|*.*FileKey5=%CommonAppData%\AVAST Software\Avast|Log.db;backend.txt All Avast versions in 1 entry and freed alittle more room for winapp2. Edit: [Call of Juarez Logs*]Section=GamesDetect=HKLM\SOFTWARE\Techland\CallofJuarez2Default=FalseFileKey1=%Documents%\call of juarez\Out\logs|*.log|RECURSEFileKey2=%Documents%\Call of Juarez - Bound in Blood\Out\logs|*.log|RECURSE Remove Detect 1 as it is causing to detect Call of Juarez if any techland game is installed. Link to post Share on other sites
Winapp2.ini 0 Posted February 17, 2014 Author Share Posted February 17, 2014 Thanks Link to post Share on other sites
FreeRyde 0 Posted February 17, 2014 Share Posted February 17, 2014 Edit: [Call of Juarez Logs*] Section=Games Detect=HKLM\SOFTWARE\Techland\CallofJuarez2 Default=False FileKey1=%Documents%\call of juarez\Out\logs|*.log|RECURSE FileKey2=%Documents%\Call of Juarez - Bound in Blood\Out\logs|*.log|RECURSE Remove Detect 1 as it is causing to detect Call of Juarez if any techland game is installed. Did you test before posting? Detect1 only requires improved detection, not removal. Detect2 only detects expansion pack: Call of Juarez - Bound in Blood Detect1 detects original base game: Call of Juarez Modified: [Call of Juarez Logs*] Section=Games Detect1=HKLM\SOFTWARE\Techland\CallOfJuarez Detect2=HKLM\SOFTWARE\Techland\CallofJuarez2 Default=False FileKey1=%Documents%\call of juarez\Out\logs|*.log|RECURSE FileKey2=%Documents%\Call of Juarez - Bound in Blood\Out\logs|*.log|RECURSE - Improved Detect1 Link to post Share on other sites
ricktendo64 0 Posted February 17, 2014 Share Posted February 17, 2014 New [WebSite-Watcher*] LangSecRef=3021 Detect=HKCU\Software\aignes\wswatch Default=False FileKey1=%AppData%\aignes\WebSite-Watcher\config\autobackup|*.*|RECURSE FileKey2=%AppData%\aignes\WebSite-Watcher\config\favicons|*.*|RECURSE FileKey3=%AppData%\aignes\WebSite-Watcher\config\log|*.*|RECURSE FileKey4=%AppData%\aignes\WebSite-Watcher\config\settings|*.cfg_bak*|RECURSE Link to post Share on other sites
ROCKNROLL 0 Posted February 17, 2014 Share Posted February 17, 2014 No I didn't test out Call of Juarez. I actually don't have that game. It was just one of those things that kept popping up on my cleaner when it wasn't on my system. I never even heard of it untill I saw it in winapp2. Link to post Share on other sites
siliconman01 0 Posted February 18, 2014 Share Posted February 18, 2014 On Windows 8.1, the FileKey1 entry for [Windows Burn Cache*] is different. Here is the change. I suspect the original post is in error. [Windows Burn Cache*]LangSecRef=3025Detect=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\CD BurningDefault=FalseWarning=This option will wipe all files that are waiting to be burned to a CD/DVD/BRDFileKey1=%LocalAppData%\Microsoft\Windows\Burn\Temporary Burn Folder|*.* Link to post Share on other sites
Winapp2.ini 0 Posted February 18, 2014 Author Share Posted February 18, 2014 Seems like a logical conclusion Thanks! Link to post Share on other sites
FreeRyde 0 Posted February 18, 2014 Share Posted February 18, 2014 On Windows 8.1, the FileKey1 entry for [Windows Burn Cache*] is different. Here is the change. I suspect the original post is in error. [Windows Burn Cache*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\CD Burning Default=False Warning=This option will wipe all files that are waiting to be burned to a CD/DVD/BRD FileKey1=%LocalAppData%\Microsoft\Windows\Burn\Temporary Burn Folder|*.* siliconman01's correction of FileKey1 now works for Win 7 also. Modified: [Windows Burn Cache*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\CD Burning Default=False Warning=This option will wipe all files that are waiting to be burned to a CD/DVD/BRD FileKey1=%LocalAppData%\Microsoft\CD Burning|*.* FileKey2=%LocalAppData%\Microsoft\Windows\Burn\Burn|*.* FileKey3=%LocalAppData%\Microsoft\Windows\Burn\Temporary Burn Folder|*.* Now works for XP and Vista also. - Added FileKey1 and 2 - FileKey3 address corrected Link to post Share on other sites
Winapp2.ini 0 Posted February 18, 2014 Author Share Posted February 18, 2014 The dreaded Windows XP path differences 'A' Link to post Share on other sites
SMalik 0 Posted February 19, 2014 Share Posted February 19, 2014 Revised Entry Changed the DetectFile with Detect. [Wise Care 365*]LangSecRef=3024Detect=HKLM\SOFTWARE\WiseCleaner\WiseCare365Default=FalseFileKey1=%AppData%\Wise Care 365|Errorlog.txt;FailToRemove.dat New Entry [Wise Care 365 Backups*]LangSecRef=3024Detect=HKLM\SOFTWARE\WiseCleaner\WiseCare365Default=FalseFileKey1=%AppData%\Wise Care 365\Backup|*.* Link to post Share on other sites
Winapp2.ini 0 Posted February 19, 2014 Author Share Posted February 19, 2014 Are those backups safe to remove? Link to post Share on other sites
SMalik 0 Posted February 19, 2014 Share Posted February 19, 2014 Are those backups safe to remove? Registry backups in a .reg file. Link to post Share on other sites
Hav0c 0 Posted February 19, 2014 Share Posted February 19, 2014 Question, [Steam More*] Section=Games Detect=HKCU\Software\Valve\Steam Default=False FileKey1=F:\Steam|*.log|RECURSE FileKey2=%ProgramFiles%\Valve\Steam|Steam.log FileKey3=%ProgramFiles%\Valve\Steam\SteamLogs|*.log Only deletes log files, maybe to rename to Steam Logs ? Link to post Share on other sites
Winapp2.ini 0 Posted February 19, 2014 Author Share Posted February 19, 2014 Weird, see attached image as I did a test again. All four work for me http://i.imgur.com/q0nylby.png Link to post Share on other sites
SMalik 0 Posted February 19, 2014 Share Posted February 19, 2014 Revised Entry Added *.powerlog into FileKey1 [iTunes Logs*]LangSecRef=3023Detect=HKLM\SOFTWARE\Apple Computer, Inc.\iTunesDefault=FalseFileKey1=%AppData%\Apple Computer\Logs\CrashReporter\MobileDevice|*.crash;*.log;*.powerlog|RECURSEFileKey2=%AppData%\Apple Computer\Logs\CrashReporter\MobileDevice\*\DiagnosticLogs|*.*|RECURSEFileKey3=%AppData%\Apple Computer\Logs\DeviceLink|*.logFileKey4=%AppData%\Apple Computer\Logs\MobileBackup|*.logFileKey5=%WinDir%\System32\config\systemprofile\AppData\Roaming\Apple Computer\Logs|*.log|RECURSEFileKey6=%WinDir%\SysWOW64\config\systemprofile\AppData\Roaming\Apple Computer\Logs|*.log|RECURSE Link to post Share on other sites
JDPower 0 Posted February 20, 2014 Share Posted February 20, 2014 Are those backups safe to remove? Registry backups in a .reg file. That'll be a no then. Link to post Share on other sites
Moderators Nergal 0 Posted February 20, 2014 Moderators Share Posted February 20, 2014 That'll be a no then. I agree, not safe to remove wholesale Link to post Share on other sites
SMalik 0 Posted February 20, 2014 Share Posted February 20, 2014 That'll be a no then. I'm not in favor either, but what about the other Winapp2 entries that remove registry backups? Link to post Share on other sites
Winapp2.ini 0 Posted February 20, 2014 Author Share Posted February 20, 2014 We've been moving towards filtering them out over time Link to post Share on other sites
ROCKNROLL 0 Posted February 20, 2014 Share Posted February 20, 2014 Another look through winapp2. These 2 entries seem to be just the samething: [Aegisub (Auto Backups)*]LangSecRef=3023Detect=HKLM\SOFTWARE\AegisubDefault=FalseWarning=Aegisub automatically saves a backup copy of each script you open. This will delete them.FileKey1=%AppData%\Aegisub\autoback|*.*|REMOVESELF[Aegisub (Autosaves)*]LangSecRef=3023Detect=HKLM\SOFTWARE\AegisubDefault=FalseWarning=Aegisub automatically saves a copy of each script you are working on. This will delete them.FileKey1=%AppData%\Aegisub\autosave|*.*|REMOVESELF We can combine these 2 to make this: [Aegisub Auto backups/saves*]LangSecRef=3023Detect=HKLM\SOFTWARE\AegisubDefault=FalseWarning=Aegisub automatically saves a backup copy of each script you open or you are working on. This will delete them.FileKey1=%AppData%\Aegisub\autoback|*.*|REMOVESELF FileKey2=%AppData%\Aegisub\autosave|*.*|REMOVESELF I'm not sure if that name is good enough, but I edited the warning and combined both filekeys. EDIT: I wanted to post this here yesterday, but my internet went down for a long time. Remove entry: [AdwCleaner 3 Quarantine*]LangSecRef=3024Warning=You will not be able to undo your changes after running this.Detect=HKLM\Software\AdwCleanerDefault=FalseFileKey1=%SystemDrive%\AdwCleaner\Quarantine|*.*|RECURSE It just doesn't seem right to have a cleaning program clean out quarantine folders. It would be much more efficient to have the program itself handle that. Link to post Share on other sites
Coffee4Joe 0 Posted February 22, 2014 Share Posted February 22, 2014 Added Filekey 9&10 [Reddit To Go!*] LangSecRef=3031 DetectFile=%LocalAppData%\Packages\*.RedditToGo_* Default=False FileKey1=%LocalAppData%\Packages\*.RedditToGo_*\RoamingState|history.txt FileKey2=%LocalAppData%\Packages\*.RedditToGo_*\AC\Microsoft\CryptnetUrlCache\Content|*.* FileKey3=%LocalAppData%\Packages\*.RedditToGo_*\AC\Microsoft\CryptnetUrlCache\MetaData*.* FileKey4=%LocalAppData%\Packages\*.RedditToGo_*\AC\Microsoft\CLR_v4.0\UsageLogs|*.*|RECURSE FileKey5=%LocalAppData%\Packages\*.RedditToGo_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey6=%LocalAppData%\Packages\*.RedditToGo_*\AC\INetCache|*.*|RECURSE FileKey7=%LocalAppData%\Packages\*.RedditToGo_*\AC\INetCookies|*.*|RECURSE FileKey8=%LocalAppData%\Packages\*.RedditToGo_*\AC\INetHistory|*.*|RECURSE FileKey9=%LocalAppData%\Packages\*.RedditToGo_*\AC\AppCache|*.*|RECURSE FileKey10=%LocalAppData%\Packages\*.RedditToGo_*\AC\Temp|*.* RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\55382ross456.RedditToGo_02dxdbb1qg9kw\SearchHistory Link to post Share on other sites
Winapp2.ini 0 Posted February 23, 2014 Author Share Posted February 23, 2014 Remove entry: [AdwCleaner 3 Quarantine*] LangSecRef=3024 Warning=You will not be able to undo your changes after running this. Detect=HKLM\Software\AdwCleaner Default=False FileKey1=%SystemDrive%\AdwCleaner\Quarantine|*.*|RECURSE It just doesn't seem right to have a cleaning program clean out quarantine folders. It would be much more efficient to have the program itself handle that. adwcleaner doesn't have that functionality,and as far as i know doesn't allow you to restore from the quarantine Link to post Share on other sites
siliconman01 0 Posted February 23, 2014 Share Posted February 23, 2014 adwcleaner doesn't have that functionality,and as far as i know doesn't allow you to restore from the quarantine I do not use adwcleaner 3.0 so I cannot confirm this; however, post #2 on this forum thread indicates that quarantine restore is available. http://www.bleepingcomputer.com/forums/t/506366/does-adwcleaner-automatically-quarantine/ Link to post Share on other sites
Winapp2.ini 0 Posted February 23, 2014 Author Share Posted February 23, 2014 Seems it actually is possible, though I'm not sure that the entry is bad, since Adwcleaner is more of a one-run-and-done utility, designed to remove everything it finds. Link to post Share on other sites
ROCKNROLL 0 Posted February 23, 2014 Share Posted February 23, 2014 I don't that it is a bad idea having it in winapp2, I just thought that it is much more effcient to have adwcleaner handle this instead of winapp2. I see some people perfer it here, so thus we can leave it alone. Link to post Share on other sites
