CCleaner Community Forums
Winapp2.ini additions
Winapp2.ini
New:
[Performance Maintainer*]
LangSecRef=3024
DetectFile=%ProgramFiles%\Performance Maintainer
Default=False
FileKey1=%ProgramFiles%\Performance Maintainer\Backups|*.*|RECURSE
FileKey2=%ProgramFiles%\Performance Maintainer\log|*.*|RECURSE
FileKey3=%ProgramFiles%\Performance Maintainer\Logs|*.*|RECURSE
I can't get this one to work on my system. I need someones help, again.
I don't see anything syntactically wrong with this at first glance, is the path correct?
The path appears to be wrong, default install path would make the entry the following:
LangSecRef=3024
DetectFile=%ProgramFiles%\PC Starters\Performance Maintainer
Default=False
FileKey1=%ProgramFiles%\PC Starters\Performance Maintainer\Backups|*.*|RECURSE
FileKey2=%ProgramFiles%\PC Starters\Performance Maintainer\log|*.*|RECURSE
FileKey3=%ProgramFiles%\PC Starters\Performance Maintainer\Logs|*.*|RECURSE
Of course filekey1 shouldn't be included as we don't delete cleaner program backups do we ;)
Link to comment
@JDPower: Mine is not located in PC Starters, its just Performance Maintainer.
@Winapp2: No. There are txt files and .ini files that shouldn't be removed. Those 3 directories don't have any of those. In case your wondering, the backup files are in .xml document format, not in any .reg format or anything.
I am a maintainer for Winapp2. I also have a open-source group on Steam.
http://steamcommunity.com/groups/opencommunity
Link to comment
I installed it to test and that's where it installed by default, that was all I was saying. And making only those changes the entry worked so there's nothing wrong with the rest of the entry and it should work if those are you directory paths.
Link to comment
Updated, tested fine. (preserves bookmarks and their settings)
[WebSite-Watcher*]
LangSecRef=3021
Detect=HKCU\Software\aignes\wswatch
Default=False
FileKey1=%AppData%\aignes\WebSite-Watcher\bookmarks\bookmark_wsw|*.*|REMOVESELF
FileKey2=%AppData%\aignes\WebSite-Watcher\config\autobackup|*.zip
FileKey3=%AppData%\aignes\WebSite-Watcher\config\favicons|*.*
FileKey4=%AppData%\aignes\WebSite-Watcher\config\log|*.log
FileKey5=%AppData%\aignes\WebSite-Watcher\config\settings|*.cfg_bak*
FileKey6=%AppData%\aignes\WebSite-Watcher\config\temp|*.*
Link to comment
New
[SRWare Iron debug.log*]
LangSecRef=3029
DetectFile1=%LocalAppData%\Torch	#Correct?
Default=False
FileKey1=%ProgramFiles%\SRWare Iron|debug.log
The Steam folder is always full of crap. I delete pretty much any folder that has "cookie" or "cache" in its name and never had problems with it. But can and should such a wildcard be made?
Otherwise:
New
[Steam Cache and Cookies*]
Section=Games
Detect=HKCU\Software\Valve\Steam
Default=False
FileKey1=%ProgramFiles%\Steam\config\cookies|*.*|REMOVESELF
FileKey2=%ProgramFiles%\Steam\SteamApps\common\Team Fortress 2\config\cookies|*.*|REMOVESELF
FileKey3=%ProgramFiles%\Steam\config\overlaycookies|*.*|REMOVESELF
FileKey4=%ProgramFiles%\Steam\appcache|*.*|REMOVESELF
FileKey5=%ProgramFiles%\Steam\SteamApps\common\Team Fortress 2\config\html\AppCache|*.*|REMOVESELF
FileKey6=%ProgramFiles%\Steam\SteamApps\common\Team Fortress 2\tf\cache|*.*|REMOVESELF
FileKey7=%ProgramFiles%\Steam\steam\cached|*.*|REMOVESELF
FileKey8=%ProgramFiles%\Steam\depotcache|*.*|REMOVESELF
FileKey9=%ProgramFiles%\Steam\config\htmlcache|*.*|REMOVESELF
FileKey10=%ProgramFiles%\Steam\config\overlayhtmlcache|*.*|REMOVESELF
Link to comment
Modified:
[Disk Space Fan History*]
LangSecRef=3024
Warning=You will need to rescan your disks.
Detect=HKCU\Software\Cookapp\DSF4
Default=False
FileKey1=%AppData%\DiskSpaceFan|history_C.sqlite
- Added missing LangSecRef=3024
[DiskBoss Logs*]
LangSecRef=3024
Detect=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\DiskBoss Ultimate
Default=False
FileKey1=%LocalAppData%\DiskBoss Ultimate\data\reports|*.*|REMOVESELF
- Fixed typo in entry title
Link to comment
[Audacity Autosave*]
LangSecRef=3023
Detect=HKCU\Software\Audacity
Default=False
FileKey1=%AppData%\Audacity\AutoSave|*.autosave
new ^^
Does that need an entry, it deletes on closing the program doesn't it (mine's empty), and you wouldn't want to delete it whilst working on a project?
Link to comment
normaly but when its crashed there are files ...
but i have install 2 version of audacity and they are not compatible..... :wacko: i don't know why.
result forgott the entrie....
thx
Link to comment
please add this to release winapp2.ini
This folder in Nikon Capture NX2 may be about few GBs. All peoples who use this soft understand me )
[Nikon Capture NX2]
Section=Photo
Detect=HKLM\SOFTWARE\Nikon\Capture NX 2
Default=False
FileKey1=PATH|%localappdata%\Nikon\Capture NX\ThumbnailCache\|*.*|RECURSE
Link to comment
thx
But if it crashes, doesn't it use those autosave files to recover your project when you restart?
Link to comment
  • Moderators
useless
? Is the quoted post self-referential?
Link to comment
Yes :D
In my opinion a cleaner has to delt all caches and when the program crash. You start it again as fast as possible ....
@Nergal be free to delt it ^^
New
[sRWare Iron debug.log*]
LangSecRef=3029
Default=False
Otherwise:
New
[steam Cache and Cookies*]
Section=Games
Default=False
What makes the tf2 entry there ????? to seperate it ....
whats with these logs?
P:\Steam\logs
P:\Steam\userdata\*\*\*  remotecache.vdf what is it ...
P:\Steam\  crashhandler.dll.old; GameOverlayUI.exe.log.last ; steamerrorreporter.exe.old; vstdlib_s.dll.old
[Nexus Mod Manager Trace Logs*]
LangSecRef=3021                             Games?
DetectFile=%Documents%\Nexus Mod Manager
Default=False
FileKey1=%Documents%\Nexus Mod Manager|TraceLog*.txt
[Nexus Mod Manager*]
Section=Games
Default=False
FileKey1=%Documents%\Nexus Mod Manager|*.txt             include 1. one
DetectFile2=%LocalAppData%\Black_Tree_Gaming\NexusClient.exe*
[Nexus Mod Manager old config >0.4*]
Warning=Delt all config from old version older than 0.4 (1 year ago). Please update before!!!!
Section=Games
DetectFile=%LocalAppData%\Black_Tree_Gaming\NexusClient.exe*
DetectFile2=%Documents%\Nexus Mod Manager
Default=False
FileKey1=%LocalAppData%\Black_Tree_Gaming\NexusClient.exe*\0.1*.*.*|*.*|REMOVESELF
FileKey2=%LocalAppData%\Black_Tree_Gaming\NexusClient.exe*\0.2*.*.*|*.*|REMOVESELF
FileKey3=%LocalAppData%\Black_Tree_Gaming\NexusClient.exe*\0.3*.*.*|*.*|REMOVESELF
FileKey4=%LocalAppData%\Black_Tree_Gaming\NexusClient.exe*\0.0*.*.*|*.*|REMOVESELF
-new
Link to comment
  • Moderators
Huh?
Huh? not huh? Update xD
Uh stop please :( (I hate notifications for unimportantness :wacko: )
Link to comment
New Entry
[EaseUS MobiSaver for Android*]
LangSecRef=3021
Detect=HKLM\SOFTWARE\EaseUS\Mobisaver for Android
Default=False
FileKey1=%SystemDrive%\EaseUS MobiSaver for Android Temp Backup|*.*|RECURSE
FileKey2=%ProgramFiles%\EaseUS\EaseUS MobiSaver for Android\bin|CommDbg.txt;Eaolog;easeusue.log;mbs;PR.log
Link to comment
Okay I'm about to update the file, quick heads up I'm not including the AdBlock update because I've determined those patterns files to at least resemble the number of filter subscriptions I have and want to hold off on messing with them for now, I also skipped a few others for various reasons
Link to comment
Updated
What's new in winapp2.ini 4.12.140325
General:
14 New Entries
08 Modified Entries
02 Removed Entries
Verbose:
New Entries:
[Album Player Cache*]
LangSecRef=2023
DetectFile=%AppData%\AlbumPlayer
Default=False
FileKey1=%SystemDrive%\AlbumPlayerData\Cache|*.*|RECURSE
[AlbumPlayer Logs*]
LangSecRef=2023
Default=False
FileKey1=%SystemDrive%\AlbumPlayerData\Logging|*.*|RECURSE
[Baidu PC Faster Dump Files*]
LangSecRef=3024
Detect=HKCU\Software\Baidu Security
Default=False
FileKey1=%Documents%\Baidu Security\PC Faster\*\Dump|*.*|REMOVESELF
FileKey2=%Documents%\Baidu Security\Bav\Dump|*.*|REMOVESELF
[Baidu PC Faster Log Files*]
LangSecRef=3024
Default=False
FileKey1=%Documents%\Baidu Security\PC Faster\*\log|*.*|REMOVESELF
[Baidu PC Faster Temporary Files*]
LangSecRef=3024
Default=False
FileKey1=%CommonAppData%\Baidu Security\RpData|*.tmp
[Inno Setup Installers Temp*]
LangSecRef=3024
DetectFile=%LocalAppData%\Programs
Default=False
FileKey1=%LocalAppData%\Programs|*.*|REMOVESELF
[Nikon Capture NX2]
Section=Photo
Default=False
LangSecRef=3024
Default=False
FileKey1=%ProgramFiles%\PC Starters\Performance Maintainer\log*|*.*|RECURSE
[RssBandit*]
LangSecRef=3022
DetectFile=%AppData%\RssBandit
Default=False
FileKey1=%AppData%\RssBandit|*.bak;*.log
[Wunderlist*]
LangSecRef=3022
DetectFile=%ProgramFiles%\Wunderlist
Default=False
FileKey1=%AppData%\Titanium\appdata\com.wunderkinder.wunderlistdesktop|*.log
[Zemanda AntiLogger*]
LangSecRef=3024
DetectFile=%LocalAppData%\Zemana\Zemana AntiLogger
Default=False
FileKey1=%LocalAppData%\Zemana\Zemana AntiLogger|*.*
[Zoner Photo Studio 14*]
LangSecRef=3022
DetectFile=%LocalAppData%\Zoner\ZPS 14
Default=False
FileKey1=%LocalAppData%\Zoner\ZPS 14\ZPSCache.dat|*.*
[XWidget Backup*]
LangSecRef=3021
DetectFile=%Documents%\XWidget
Default=False
FileKey1=%Documents%\XWidget\Backup|*.*|RECURSE
[XWidget Cache*]
LangSecRef=3021
Default=False
FileKey1=%Documents%\XWidget\Cache|*.*|RECURSE
Modified Entries:
[Aimersoft Video Converter Ultimate*]
LangSecRef=3023
Detect=HKLM\SOFTWARE\Aimersoft\Aimersoft Video Converter Ultimate
Default=False
FileKey1=%ProgramFiles%\Aimersoft\Video Converter Ultimate\Log|*.*|RECURSE
FileKey2=%ProgramFiles%\Aimersoft\Video Converter Ultimate\TempThumbDir|*.*|RECURSE
FileKey3=%CommonAppData%\Aimersoft Video Converter Ultimate|*.dat.bak
FileKey4=%CommonAppData%\Aimersoft Video Converter Ultimate\TempSiteIconDir|*.*|RECURSE
FileKey5=%CommonAppData%\Aimersoft Video Converter Ultimate\TempThumbDir|*.*|RECURSE
	- Changed REMOVESELF to RECURSE
LangSecRef=3024
Default=False
	- Added LangSecRef
[iSkysoft Video Converter Ultimate*]
LangSecRef=3023
Detect=HKLM\SOFTWARE\iSkysoft\iSkysoft Video Converter Ultimate
Default=False
FileKey1=%ProgramFiles%\iSkysoft\Video Converter Ultimate\Log|*.*|RECURSE
FileKey2=%ProgramFiles%\iSkysoft\Video Converter Ultimate\TempThumbDir|*.*|RECURSE
FileKey3=%CommonAppData%\iSkysoft Video Converter Ultimate|*.dat.bak
FileKey4=%CommonAppData%\iSkysoft Video Converter Ultimate\TempSiteIconDir|*.*|RECURSE
FileKey5=%CommonAppData%\iSkysoft Video Converter Ultimate\TempThumbDir|*.*|RECURSE
[WebSite-Watcher*]
LangSecRef=3021
Default=False
	- Added FileKeys1 and 6
[Windows Burn Cache*]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\CD Burning
Default=False
Warning=This option will wipe all files that are waiting to be burned to a CD/DVD/BRD
FileKey1=%LocalAppData%\Microsoft\CD Burning|*.*
FileKey2=%LocalAppData%\Microsoft\Windows\Burn\Burn|*.*|RECURSE
	- Made FileKey2 RECURSE
	- Removed FileKey3
[Windows Update Logs*]
LangSecRef=3025
Detect=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\WindowsUpdate
Default=False
FileKey1=%WinDir%\SoftwareDistribution\DataStore\Logs|*.*
FileKey2=%WinDir%\SoftwareDistribution|*.log
	- Added FileKey2
[Wondershare Video Converter Pro*]
LangSecRef=3023
Detect=HKLM\SOFTWARE\Wondershare\Wondershare Video Converter Pro
Default=False
FileKey1=%ProgramFiles%\Wondershare Video Converter Pro\Log|*.*|RECURSE
FileKey2=%ProgramFiles%\Wondershare Video Converter Pro\TempThumbDir|*.*|RECURSE
FileKey3=%CommonAppData%\Wondershare Video Converter Pro|*.dat.bak
FileKey4=%CommonAppData%\Wondershare Video Converter Pro\TempSiteIconDir|*.*|RECURSE
FileKey5=%CommonAppData%\Wondershare Video Converter Pro\TempThumbDir|*.*|RECURSE
	- Replaced Wildcard with Pro
[Wondershare Video Converter Ultimate*]
LangSecRef=3023
Detect=HKLM\SOFTWARE\Wondershare Video Converter Ultimate
Default=False
FileKey1=%ProgramFiles%\Wondershare Video Converter Ultimate\Log|*.*|RECURSE
FileKey2=%ProgramFiles%\Wondershare Video Converter Ultimate\TempThumbDir|*.*|RECURSE
FileKey3=%CommonAppData%\Wondershare Video Converter Ultimate|*.dat.bak
FileKey4=%CommonAppData%\Wondershare Video Converter Ultimate\TempSiteIconDir|*.*|RECURSE
FileKey5=%CommonAppData%\Wondershare Video Converter Ultimate\TempThumbDir|*.*|RECURSE
Removed Entries:
[dBpoweramp*]
LangSecRef=3023
Detect=HKCU\Software\Illustrate\dBpoweramp
Default=False
FileKey1=%AppData%\dBpoweramp|*.bin
RegKey1=HKCU\Software\Illustrate\dBpoweramp|dMCLastFolder1
RegKey2=HKCU\Software\Illustrate\dBpoweramp|dMCLastFolder2
RegKey3=HKCU\Software\Illustrate\dBpoweramp|dMCLastFolder3
RegKey4=HKCU\Software\Illustrate\dBpoweramp|dMCLastFolder4
RegKey5=HKCU\Software\Illustrate\dBpoweramp|dMCLastFolder5
RegKey6=HKCU\Software\Illustrate\dBpoweramp|dMCLastFolder6
RegKey7=HKCU\Software\Illustrate\dBpoweramp|dMCLastFolder7
RegKey8=HKCU\Software\Illustrate\dBpoweramp|dMCLastFolder8
RegKey9=HKCU\Software\Illustrate\dBpoweramp|dMCLastFolder9
RegKey10=HKCU\Software\Illustrate\dBpoweramp|dMCLastFolder10
RegKey11=HKCU\Software\Illustrate\dBpoweramp|dMCLastFolder0
RegKey12=HKCU\Software\Illustrate\dBpoweramp\dMCCodec\AAC (Advanced Audio Compression)|DMCUserFolderStr
RegKey13=HKCU\Software\Illustrate\dBpoweramp\dMCCodec\Aiff|DMCUserFolderStr
RegKey14=HKCU\Software\Illustrate\dBpoweramp\dMCCodec\Apple Lossless|DMCUserFolderStr
RegKey15=HKCU\Software\Illustrate\dBpoweramp\dMCCodec\FLAC|DMCUserFolderStr
RegKey16=HKCU\Software\Illustrate\dBpoweramp\dMCCodec\mp3 (Lame)|DMCUserFolderStr
RegKey17=HKCU\Software\Illustrate\dBpoweramp\dMCCodec\ogg vorbis|DMCUserFolderStr
RegKey18=HKCU\Software\Illustrate\dBpoweramp\dMCCodec\Wave|DMCUserFolderStr
RegKey19=HKCU\Software\Illustrate\dBpoweramp\dMCCodec\Windows Media Audio 10|DMCUserFolderStr
	- Included in CCleaner v4.12
[SyncBackFree*]
LangSecRef=3024
Detect=HKCU\Software\2BrightSparks\SyncBackFree
Default=False
FileKey1=%LocalAppData%\2BrightSparks\SyncBackFree\Logs|*.*
Link to comment
Default=False
Section=Games
Default=False
Section=Games
Default=False
-new
whats with the correction of the Nexus Mod Manager ? 2 diffrent sections.../ second detection?
Ps thx winapp2
Link to comment
Register a new account
Sign in
Important Information
