CCleaner Community Forums
Winapp2.ini
Winapp2.ini additions
updated
thanks
typo with two entries
fixed mozila to mozilla and added \firefox\ after
should \*\shortcutCache be \*\shortcutCache|*.* ?
[shortcutCache Cache*]
LangSecRef=3026
SpecialDetect=DET_MOZILLA
Default=False
FileKey1=%LocalAppData%\Mozilla\firefox\Profiles\*\shortcutCache
[Firefox Startup Cache*]
LangSecRef=3026
Default=False
FileKey1=%LocalAppData%\Mozilla\Firefox\Profiles\*\startupCache|*.*
edit: might be able merge all %LocalAppData%\Mozilla\Firefox\Profiles\*\ entries into something like this
[some name here*]
LangSecRef=3026
Default=False
FileKey1=%LocalAppData%\Mozilla\Firefox\Profiles\*|*.*|RECURSE
Edited by Coffee4Joe
Share this post
Link to post
You forgot to add FileKey2 to "TeamSpeak 3 Logs".
[TeamSpeak 3 Logs*]
LangSecRef=3022
Detect=HKCU\Software\TeamSpeak 3 Client
Default=False
FileKey1=%LocalAppData%\TeamSpeak 3 Client\config\logs|*.*
FileKey2=%ProgramFiles%\TeamSpeak 3 Client\config\logs|*.*
Share this post
Link to post
Dropping myself a mental note
[shortcut Cache*]
LangSecRef=3026
Default=False
FileKey1=%LocalAppData%\Mozila\Profiles\*\shortcutCache|*.*
- Fixed FileKey1
- Renamed
[Thunderbird Startup Cache*]
LangSecRef=3030
SpecialDetect=DET_THUNDERBIRD
Default=False
FileKey1=%LocalAppData%\Thunderbird\Profiles\*\startupCache|*.*
- Fixed LangSecRef
Share this post
Link to post
Saad,
1) I am not an idiot do NOT talk to me as if I were one
To use an acronym N.S.S
2) This is an official forum, it is not allowed to mention by name, or especially link to COMPETITOR'S PRODUCTS.
I've removed your links et.al.
I care Not what other's remove, ccleaner is a gentle junk! Cleaner; and if this whole time you've been submitting rules from another product's code, Willy-nilly I will personally ban you.
Edit: by the way I also have PSE11 (if you'd've looked at the thread I linked...) and the following post.
I didn’t talk to you in that manner. You are always very aggressive & act like a dictator towards other forum members! I have seen your aggressive behavior towards a member & I have mentioned this in the forum (http://forum.pirifor...940#entry231824).
This was just a suggestion & I am sure there is a person who decides to accept the suggestions or not.
You have removed that link from my post & that makes me believe that you are trying to be a dictator. I & some other members of this forum are going to protest with Piriform about you & your behavior.
Go back in the forum history; since I am a member of this forum, almost all of my suggestions have been adopted by CCleaner or Winapp2.ini.
Share this post
Link to post
Felt like this needed an exclude key
[Windows Power Efficiency Diagnostics*]
LangSecRef=3025
DetectFile=%AllUsersProfile%\Microsoft\Windows\Power Efficiency Diagnostics\
Default=False
FileKey1=%AllUsersProfile%\Microsoft\Windows\Power Efficiency Diagnostics\|*.xml
ExcludeKey1=FILE|%AllUsersProfile%\Microsoft\Windows\Power Efficiency Diagnostics\energy-report-latest.xml
What's the ExcludeKey1 for? Will there be issues if the entry would just use |*.* (without Exclude)?
Share this post
Link to post
[Age of Empires*]
Section=Games
Detect1=HKLM\SOFTWARE\Microsoft\Microsoft Games\Age of Empires*
Detect2=HKLM\SOFTWARE\Microsoft\Games\Age of Empires
Default=False
FileKey1=%Documents%\My Games\Age of Mythology|*.txt
FileKey2=%Documents%\My Games\Age of Empires 3|*.txt
FileKey3=%ProgramFiles%\Microsoft Games\Age of Empires|*.RTF;*.GID
FileKey4=%ProgramFiles%\Microsoft Games\Age of Empires II|EULA.RTF;EULAx.RTF
FileKey5=%ProgramFiles%\Microsoft Games\Age of Mythology|*.rtf;*.txt
FileKey6=%ProgramFiles%\Microsoft Games\Age of Empires III|*.rtf;ESOEULA.TXT
ExcludeKey1=FILE|%ProgramFiles%\Microsoft Games\Age of Mythology|*Readme.rtf;*Readmex.rtf
ExcludeKey2=FILE|%ProgramFiles%\Microsoft Games\Age of Empires III|*Readme.rtf;*ReadmeX.rtf;*ReadmeY.rtf
RegKey1=HKLM\SOFTWARE\Microsoft\Games\Age of Empires\1.00|Zone
RegKey2=HKLM\SOFTWARE\Microsoft\Microsoft Games\Age of Empires|Zone
RegKey3=HKLM\SOFTWARE\Microsoft\Microsoft Games\Age of Empires Expansion\1.0|Zone
RegKey4=HKLM\SOFTWARE\Microsoft\Microsoft Games\Age of Empires\2.0|Zone
RegKey5=HKLM\SOFTWARE\Microsoft\Microsoft Games\Age of Empires II: The Conquerors Expansion\1.0|Zone
If I recall wildcards can't be used when using registry/Detection? So Detect1=HKLM\SOFTWARE\Microsoft\Microsoft Games\Age of Empires* probably doesn't work?
I also added Detect3 & FileKey3:
[Age of Empires*]
Section=Games
Detect3=HKLM\SOFTWARE\Wow6432Node\Microsoft\microsoft games\age of empires 3
Default=False
FileKey3=%Documents%\My Games\Age of Empires 3\RM|*.dmp.txt
Share this post
Link to post
eep it's been so long since I wrote that one but I know there was a reason for the exclude
Share this post
Link to post
There are many historical energy-report-'datestamp'.xml files which may deserve eradication.
The energy-report-latest.xml may be worth preserving - if not then why not kill the report producer (I think it has an Automatic Start service)
Share this post
Link to post
Thanks for the update. I found a typo (FK 9+10: \ instead of |):
[sun Java More*]
LangSecRef=3022
Detect=HKLM\SOFTWARE\JavaSoft\Java Runtime Environment
Default=False
FileKey1=%LocalLowAppData%\Sun\Java\Deployment\cache|*.*|RECURSE
FileKey2=%LocalLowAppData%\Sun\Java\Deployment\SystemCache|*.*|RECURSE
FileKey3=%WinDir%\System32\config\systemprofile\AppData\LocalLow\Sun\Java\Development\Cache|*.*|RECURSE
FileKey4=%WinDir%\SysWOW64\config\systemprofile\AppData\LocalLow\Sun\Java\Development\Cache|*.*|RECURSE
FileKey5=%LocalLowAppData%\Sun\Java\Deployment\Log|*.*
FileKey6=%AppData%\Sun\Java\Deployment\cache|*.*|RECURSE
FileKey7=%AppData%\Sun\Java\Deployment\log|*.*|RECURSE
FileKey8=%AppData%\Sun\Java\Deployment\tmp|*.*|RECURSE
FileKey9=%WinDir%\SysWOW64|jupdate*.log
FileKey10=%WinDir%\System32|jupdate*.log
Share this post
Link to post
Who allowed to add an entry in Winapp2.ini to wipe Software License (eula.txt) files of other software?
[R-Wipe&Clean*]
LangSecRef=3024
Detect=HKLM\Software\R-TT\R-Wipe&Clean
Default=False
FileKey1=%ProgramFiles%\R-Wipe&Clean|*.txt
FileKey2=%AppData%\R-Wipe&Clean|*.log
FileKey3=%CommonAppData%\R-Wipe&Clean|*.*|REMOVESELF
Share this post
Link to post
I agree with saad there's no reason to have licenses being cleaned (good catch)
Share this post
Link to post
I've been using
FileKey1=%AllUsersProfile%\Microsoft\Windows\Power Efficiency Diagnostics|*.*
and haven't had any problems yet.
MODIFIED ENTRY:
Changed name from [DragonAge Updater Logs*] to [Dragon Age: Origins*] and added Detect2 & FileKey2.
Section=Games
Detect=HKCU\Software\BioWare\Dragon Age
Detect2=HKLM\SOFTWARE\Wow6432Node\BioWare\Dragon Age
Default=False
FileKey1=%CommonAppData%\BioWare\Dragon Age\DA Updater\Logs|*.*
FileKey2=%Documents%\BioWare\Dragon Age\Logs|*.*
Share this post
Link to post
I think the reason I had the exclude is to keep the most recent one as it's a useful troubleshooting
or because it's locked, undeletable and didn't want users complaining it wasn't deleting though it was showing in analysis.
I like this answer though so I'll say this one (until I check on some machine and/or search the thread.)
Edit: I have reread my initial reason for it...it told me nothing
:blink:
...past me loses 10000 internets.
Edited by Nergal
Share this post
Link to post
I think there was a brief discussion about its usefulness for troubleshooting.
so did I but then I read from that point onward to page 20 and found nofink
Share this post
Link to post
Hello. I ran CCleaner with updated winapp2.ini from Voldemort then did a drive search for both *.BAK and *.TMP files and have included the list. would someone be so kind as to write the necessary rules and add them to the next winapp2.ini please?
Thank you in advance....
log.txt
Edited by Nergal
it that shall not be named
Share this post
Link to post
There's already entry for WLSetup temps:
[Windows Live Setup Temp Files*]
LangSecRef=3022
Detect=HKLM\SOFTWARE\Microsoft\Windows Live
Default=False
FileKey1=%CommonAppData%\Microsoft\WLSetup|*.tmp
Share this post
Link to post
Blah, well:
Not safe to remove because it will cause Microsoft Office (most if not all versions) to request a repair install:
C:\ProgramData\Microsoft\OFFICE\DATA\OPA11.BAK
C:\Users\All Users\Microsoft\OFFICE\DATA\OPA11.BAK
Edit:
If you happened to nuke those files on your system and got away with it then you got very lucky, but for most versions of MS Office deleting that/those file will result into a lengthy repair installation.
Edited by Andavari
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
Loading...
