CCleaner Community Forums
Winapp2.ini additions
  • Moderators
NAw, I answered my own, they're still useful :)
Addition
[Tweetro+*]
Section=Windows 8 Apps
DetectFile=%LocalAppData%\Packages\27761LazywormApplications.135450F141EEE_5tydn77rr51qw
Default=False
FileKey1=%LocalAppData%\Packages\*LazywormApplications.135450F141EEE_*\TempState|*.*
FileKey2=%LocalAppData%\Packages\*LazywormApplications.135450F141EEE_*\LocalState\Logs|*.*
FileKey3=%LocalAppData%\Packages\*LazywormApplications.135450F141EEE_*\LocalState\*\PhotoTweets|*.*
FileKey4=%LocalAppData%\Packages\*LazywormApplications.135450F141EEE_*\AC\Temp|*.*
FileKey5=%LocalAppData%\Packages\*LazywormApplications.135450F141EEE_*\AC\PRICache|*.*
FileKey6=%LocalAppData%\Packages\*LazywormApplications.135450F141EEE_*\AC\Microsoft\*|*.LOG|RECURSE
FileKey7=%LocalAppData%\Packages\*LazywormApplications.135450F141EEE_*\AC\Microsoft\*\Native Images\Temp|*.*
FileKey8=%LocalAppData%\Packages\*LazywormApplications.135450F141EEE_*\AC\Microsoft\*\Native Images\Assembly\Temp|*.*
Link to post
Guest Keatah
Regarding this entry -- FileKey2 -- I think that it shouldn't be cleaned or erased. In this specific example it erases licensing terms, command line conventions, and technical notes. Something I consider to be part of the overall documentation.
Let us be ever vigilant against adding things just to add them. It is more than sufficient to chase down leftover fragments created by a program's daily usage. Please don't chop the documentation.
[WinRAR More*]
LangSecRef=3024
Detect=HKCU\Software\WinRAR
Default=False
FileKey1=%ProgramFiles%\WinRAR|*.tmp|RECURSE
FileKey2=%ProgramFiles%\WinRAR|*.diz;*.txt;*.htm
RegKey1=HKCU\Software\WinRAR SFX
RegKey2=HKCU\Software\WinRAR\DialogEditHistory
RegKey3=HKCU\Software\WinRAR\General\Info|CommentFile
Link to post
  • Moderators
Definitely
Link to post
Trim.exe error <_<
Trim.bat working fine -_-
Then be thankful that Trim.Bat still works.
Trim.exe is something that compiled/packed Trim.bat and may need to be recreated by it's author (not me) to suit the new version of CCleaner.exe.
I am surprised to see from the screen shot that you are trying to run it on a 16 bit subsystem.
Link to post
MODIFIED ENTRY
Corrected/changed the Detect and added RegKey1.
[Config.msi Folder*]
LangSecRef=3025
Detect=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\Folders
Default=False
RegKey1=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\Folders|C:\Config.Msi\
FileKey1=%SystemDrive%\Config.msi|*.*|REMOVESELF
Link to post
What the heck is trim.exe :huh:
Edit: Is trim.exe the trimming function from CCEnhancer? I know shane recently added that feature.
Before there was Windows there were DOS tools that could convert a BAT file into an EXE, (and also COM to EXE and EXE to COM)
Last year the forum member "Tr3bg0D" contacted me when he was converting TRIM.BAT into TRIM.EXE.
This gave him benefits but after a year I cannot remember what they were.
Perhaps he published it.
Perhaps Drazen11 has done his own conversion.
Perhaps it is something related to the "Utility that cannot be named in this forum" :o
Link to post
  • Moderators
:lol:
we shall call it Voldemort
Link to post
I've added a trimming function to Voldemort, but it's not a standalone program. Trim.exe isn't one of my babies.
Link to post
NEW ENTRY
Delete Anvsoft Any Video Converter Thumbnails
[Anvsoft Any Video Converter Thumbnails*]
LangSecRef=3023
Detect=HKCU\Software\AnvSoft\Any Video Converter\
Default=False
FileKey1=%AppData%\AnvSoft\Any Video Converter\thumbs|*.*|RECURSE
NEW ENTRY
Delete Waterfox Installer
[Waterfox Installer*]
LangSecRef=3026
DetectFile=%ProgramFiles%\Waterfox\Waterfox.exe
Default=False
FileKey1=%AppData%\Waterfox Limited\Waterfox*\install|*.*|RECURSE
NEW ENTRY
Delete Adobe Bridge CS6 Cache
[Adobe Bridge CS6 Cache*]
LangSecRef=3023
Detect=HKCU\Software\Adobe\Bridge CS6\
Default=False
FileKey1=%AppData%\Adobe\Bridge CS6\Cache|*.*|RECURSE
Link to post
  • Moderators
MODIFIED ENTRY
LangSecRef=3025
Default=False
I haven't tested it but I do wonder if RegKey1 will cause an MSI installer to fail, and I wonder if Windows Installer is smart enough to re-create that registry key to know where it unpacks the setup files.
Edit:
I would've personally modified it with this, adding in a Detect2, still don't know about RegKey1 so I've left that out:
[Config.msi Folder]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Installer
Detect2=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer
Default=False
Edited by Andavari
Link to post
Hi, when upgrading LibreOffice sometimes there is a folder left.
this folder is named: "program_old", "program_old1" and so on... this is the winapp2.ini entry to remove them.
[LibreOffice x.x program_old*]
LangSecRef=3021
Detect=HKLM\Software\LibreOffice
Default=False
FileKey1=%ProgramFiles%\LibreOffice ?.?\program_old*|*.*|REMOVESELF
Link to post
  • Moderators
@squeeze,
this would be more help if posted under the WINAPP2.INI thread.
maybe a Mod can do the honours.
Link to post
new
[AVM update*]
Section=Games
DetectFile=%ProgramFiles%\AVM_update\
Default=False
FileKey1=%ProgramFiles%\AVM_update\AVM_*|*.*|REMOVESELF
How can i delt the dection file?
%ProgramFiles%\AVM_update|REMOVESELF haven't work :-(
I found this entries on my disk but i don't know what it happen when you delt this....
C:\Program Files (x86)\NVIDIA Corporation\Downloaded Installations
C:\Program Files (x86)\NVIDIA Corporation\NVIDIA Update Core
C:\Program Files (x86)\NVIDIA Corporation\System Update
C:\Program Files (x86)\NVIDIA Corporation\Update Common
C:\Program Files\NVIDIA Corporation\Installer2
Link to post
I suspect, at the very least, your graphics drivers will no longer be able to update or uninstall.
Link to post
  • Moderators
new
[AVM update*]
Section=Games
Default=False
This is a Prime example of not cleaning junk.
Entire Programs do not belong on the PUBLIC file, what is AVM updater that the entire program should be removed without even a warning. If you don't want it uninstall it or physically delete it...or explain why I'm wrong.
Edited by Nergal
Link to post
Register a new account
Sign in
