Winapp2.ini additions
Winapp2.ini
Thanks! :)
Missed correction (from Coffee4Joe, "fixed mozila to mozilla and added \firefox\ after"):
[shortcut Cache*]
LangSecRef=3026
SpecialDetect=DET_MOZILLA
Default=False
FileKey1=%LocalAppData%\Mozilla\Firefox\Profiles\*\shortcutCache|*.*
Typo (doubled backslash):
[Diablo 2 + LOD Logs*]
Section=Games
Detect=HKCU\Software\Blizzard Entertainment\Diablo II
Default=False
FileKey1=%ProgramFiles%\Diablo II|bnupdate.log;BnetLog.txt;D*.txt
FileKey2=%SystemDrive%\\Diablo II|bnupdate.log;BnetLog.txt;D*.txt
Link to comment
New Entries
[Corel VideoStudio Pro X6*]
LangSecRef=3023
Detect=HKCU\Software\Ulead Systems\Corel VideoStudio Pro\16.0
Default=False
FileKey1=%Documents%\Corel VideoStudio Pro\16.0\AudioTmp|*.*
FileKey2=%Documents%\Corel VideoStudio Pro\16.0\SmartProxy|*.*
RegKey1=HKCU\Software\Ulead Systems\Corel VideoStudio Pro\16.0\HerRFL
[Foxit Reader 6*]
LangSecRef=3021
Detect=HKCU\Software\Foxit Software\Foxit Reader 6.0
Default=True
RegKey1=HKCU\Software\Foxit Software\Foxit Reader 6.0\Preferences\History\LastOpen
RegKey2=HKCU\Software\Foxit Software\Foxit Reader 6.0\Preferences\History\Options
RegKey3=HKCU\Software\Foxit Software\Foxit Reader 6.0\Recent File List
RegKey4=HKCU\Software\Foxit Software\Foxit Reader 6.0\RecentFiles
FileKey1=%AppData%\Foxit Software\Foxit Reader\StartPage\Start|history.txt
Revised Entry
Corrected the detect path and added RegKey1. I have Daemon Tools Lite on my system.
[Daemon Tools More*]
LangSecRef=3024
Detect=HKCU\Software\Disc Soft
Default=False
RegKey1=HKCU\Software\Disc Soft\DAEMON Tools Pro\GuiNamespace|MountFolder
FileKey1=%AppData%\DAEMON Tools*\IconsCache|*.*|RECURSE
FileKey2=%AppData%\DAEMON Tools*\ImageInfoCache|*.*|RECURSE
FileKey3=%AppData%\DAEMON Tools*|ImgList.dat
I suggest adding 'wwahost.exe.log' in Windows 8 Apps entries.
For Example: %LocalAppData%\Packages\Microsoft.BingNews_8wekyb3d8bbwe\AC\Microsoft\CLR_v4.0\UsageLogs|wwahost.exe.log
Link to comment
  • Moderators
www.winapp2.com down?
up for me 1/2 hour later than you checked
Link to comment
Guest Keatah
Yes. I also tried on 2 other systems without custom hosts. No change.
I'll just wait a few days and see if it doesn't resolve itself.
Link to comment
I can access it through a proxy.
SBCglobal and Comcast aren't allowing the site for whatever reason.
When my Gmail was not accessible I found that the Google Search engine was also broken,
BUT my Startpage Search Engine still got al the results from Google because Startpage is/uses a proxy to protect my privacy from Google.
I could access through a proxy because the proxy used a different Domain Name Server than I was using.
Perhaps your problem is your DNS
Just give me the IP addresses of your Primary and Secondary DNS,
and I will add it to my test script of 29 DNS, each of which can resolve winapp2.com
It will take less than 1 minute for me to run the test on your DNS and advise you.
Link to comment
I think we should change the [indexing Traces*] name to [MS Search More*].
[MS Search More*]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows
Default=False
FileKey1=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\GatherLogs\SystemIndex|*.*|RECURSE
FileKey2=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\PropMap|*.*|RECURSE
FileKey3=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\SecStore|*.*|RECURSE
FileKey4=%CommonAppData%\Microsoft\Search\Data\Applications\Windows|Windows.edb
Link to comment
From winapp's hosting company:
[Resolved] Vox Server - Comcast
It appears that the internet provider Comcast has placed some sort of routing block for their customers to our web hosting server Vox. This results in Comcast users unable to access server and any websites hosted on it. This may be confirmed by a Comcast customer by running a traceroute to an affected domain name.
I'm Shane.
Link to comment
  • Moderators
how weird, I'm on Comcast and was unaffected.
Link to comment
Guest Keatah
Well whatever. It is working now and that's good enough for me. If I was to fully investigate each glitch I'd end up in the psych ward no doubt.
Link to comment
New Entry
[Aimersoft Video Converter Ultimate*]
LangSecRef=3023
Detect=HKLM\SOFTWARE\Aimersoft\Aimersoft Video Converter Ultimate
Default=False
FileKey1=%CommonAppData%\Aimersoft Video Converter Ultimate\TempSiteIconDir
FileKey2=%CommonAppData%\Aimersoft Video Converter Ultimate\TempThumbDir
FileKey3=%CommonAppData%\Aimersoft Video Converter Ultimate|*.dat.bak
Revised Entry
Added RegKey10.
[Auslogics BoostSpeed 5*]
LangSecRef=3024
Detect=HKCU\Software\Auslogics\BoostSpeed\
Default=False
FileKey1=%AppData%\Auslogics|*.htm;*.html;*.log;*.rsc;*.sta;*.xml|RECURSE
RegKey1=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|DiskCleaner.AppLogic.ErrorsFailed
RegKey2=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|DiskCleaner.AppLogic.ErrorsFound
RegKey3=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|DiskCleaner.AppLogic.ErrorsRemoved
RegKey4=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|DiskCleaner.AppLogic.LastScan
RegKey5=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|RegCleaner.AppLogic.ErrorsFailed
RegKey6=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|RegCleaner.AppLogic.ErrorsFound
RegKey7=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|RegCleaner.AppLogic.ErrorsRemoved
RegKey8=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|RegCleaner.AppLogic.LastScan
RegKey9=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|TrackEraser.LastScan.DateTimeLo
RegKey10=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|TrackEraser.LastScan.DateTimeHi
RegKey11=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|TrackEraser.LastScan.FailedToRemove
RegKey12=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|TrackEraser.LastScan.Found
RegKey13=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|TrackEraser.LastScan.Removed
Link to comment
LangSecRef should be changed.
[Realtek Driver Installation Files*]
LangSecRef=3025
Detect=HKLM\SOFTWARE\Realtek
Default=False
Warning=This will delete your Realtek driver installation files.
FileKey1=%SystemDrive%\Drivers|*.*|REMOVESELF
The entries listed below are very aggressive. These should not be in Winapp2.ini.
[Apple Installer Cache*]
[Apple MobileSync Backup*]
[Nvidia Graphics Driver Installation Files*]
Link to comment
Register a new account
Sign in
Important Information
