Winapp2.ini Posted May 1, 2013 Author Share Posted May 1, 2013 I tend to agree for the apple ones, but removing driver installation files like the nvidia and amd ones should be okay, since they're not required for an uninstall. They're just left-overs from the installers. I will remove the entries if you guys would like them removed though winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Nergal Posted May 1, 2013 Moderators Share Posted May 1, 2013 yikes I agree too much FileKey1=%SystemDrive%\Drivers|*.*|REMOVESELF Many other things might keep things there at c:\drivers\ besides realtek ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
siliconman01 Posted May 1, 2013 Share Posted May 1, 2013 Please do NOT remove the [Nvidia Graphics Driver Installation Files*] unless someone can point to a problem that it is causing. I've been removing this for months on Windows 7 and Windows 8 with no issues uncovered...at least on my systems. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted May 1, 2013 Author Share Posted May 1, 2013 I think the realtek one is probably too broad. the AMD/Nvidia ones should be okay though, for the reasons I stated above. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Coffee4Joe Posted May 1, 2013 Share Posted May 1, 2013 [Realtek Driver Installation Files*] LangSecRef=3025 Detect=HKLM\SOFTWARE\Realtek Default=False Warning=This will delete your Realtek driver installation files. FileKey1=%SystemDrive%\Drivers|*.*|REMOVESELF I have one pc with realtek audio. This folder/location doesn't exist for me. Quick search online sounds like that folder holds backups of OEM stuff Link to comment Share on other sites More sharing options...
JDPower Posted May 1, 2013 Share Posted May 1, 2013 I have one pc with realtek audio. This folder/location doesn't exist for me. Quick search online sounds like that folder holds backups of OEM stuff It exists on my laptop BUT contains USB controller files, nothing to do with Realtek. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted May 1, 2013 Moderators Share Posted May 1, 2013 Don't those driver setup files create a unique folder inside of C:\Drivers instead of just unpacking all files in it, example: C:\Drivers\Some Developer\Driver Files This line does seem too broad/dangerous/generic/uncareful: FileKey1=%SystemDrive%\Drivers|*.*|REMOVESELF Link to comment Share on other sites More sharing options...
JDPower Posted May 1, 2013 Share Posted May 1, 2013 Don't those driver setup files create a unique folder inside of C:\Drivers instead of just unpacking all files in it, example: C:\Drivers\Some Developer\Driver Files Obviously can only answer for mine but here it doesn't, they are directly in the drivers folder (seems a strange approach if it's used by several software companies, one would HOPE they'd behave as you suggest if the folder wasn't empty on install) Link to comment Share on other sites More sharing options...
SMalik Posted May 2, 2013 Share Posted May 2, 2013 After removing the NVIDIA Graphics Driver Installation Files, I tried 4 different registry cleaner programs and they all found NVIDIA driver related data as errors since the driver installations files were not present. I removed NVIDIA driver related data from the Windows Registry. After that, I was not able to update the driver or uninstall the driver either. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted May 2, 2013 Author Share Posted May 2, 2013 Well the installer information is kept in the registry, try manually uninstalling via the uninstaller executable from \Program Files\NVidia (or whereever) Without C:\AMD, I have no trouble uninstalling or updating my graphics drivers. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
siliconman01 Posted May 2, 2013 Share Posted May 2, 2013 The [Nvidia Graphics Driver Installation Files*] does contain the warning Warning=You will not be able to do an uninstall of your drivers without first reinstalling them. I've always been able to download and successfully install new updates (either released or beta versions) right over the top of an old version of NVidia. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
siliconman01 Posted May 2, 2013 Share Posted May 2, 2013 Changing [Nvidia Graphics Driver Installation Files*] from: [Nvidia Graphics Driver Installation Files*] LangSecRef=3023 Detect=HKCU\Software\NVIDIA Corporation Default=False Warning=You will not be able to do an uninstall of your drivers without first reinstalling them. FileKey1=%SystemDrive%\Nvidia|*.*|REMOVESELF FileKey2=%ProgramFiles%\NVIDIA Corporation\Installer2|*.*|RECURSE to [Nvidia Graphics Driver Installation Files*] LangSecRef=3023 Detect=HKCU\Software\NVIDIA Corporation Default=False FileKey1=%SystemDrive%\Nvidia|*.*|REMOVESELF is a solution to the problem that Saad2011 aptly points out. I recommend this change be made. %SystemDrive%\Nvidia is an extraction folder that is used by the Nvidia installer when performing an update. After the update is completed, this folder is no longer needed or used. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
SMalik Posted May 2, 2013 Share Posted May 2, 2013 Changing [Nvidia Graphics Driver Installation Files*] from: [Nvidia Graphics Driver Installation Files*] LangSecRef=3023 Detect=HKCU\Software\NVIDIA Corporation Default=False Warning=You will not be able to do an uninstall of your drivers without first reinstalling them. FileKey1=%SystemDrive%\Nvidia|*.*|REMOVESELF FileKey2=%ProgramFiles%\NVIDIA Corporation\Installer2|*.*|RECURSE to [Nvidia Graphics Driver Installation Files*] LangSecRef=3023 Detect=HKCU\Software\NVIDIA Corporation Default=False FileKey1=%SystemDrive%\Nvidia|*.*|REMOVESELF is a solution to the problem that Saad2011 aptly points out. I recommend this change be made. %SystemDrive%\Nvidia is an extraction folder that is used by the Nvidia installer when performing an update. After the update is completed, this folder is no longer needed or used. Yes, this one is safe but removing driver installation files from FileKey2=%ProgramFiles%\NVIDIA Corporation\Installer2|*.*|RECURSE is COMPLETELY unsafe. Link to comment Share on other sites More sharing options...
SMalik Posted May 2, 2013 Share Posted May 2, 2013 Well the installer information is kept in the registry, try manually uninstalling via the uninstaller executable from \Program Files\NVidia (or whereever) Without C:\AMD, I have no trouble uninstalling or updating my graphics drivers. I have tried every possible thing, but nothing worked out. The uninstaller executable's were in the driver installation folder (C:\Program Files\NVIDIA Corporation\Installer2) that CCleaner removed. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted May 2, 2013 Author Share Posted May 2, 2013 I see. I'll amend the nvidia entry as needed and remove the realtek one. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Andavari Posted May 3, 2013 Moderators Share Posted May 3, 2013 Updated: Updated: FileKey2 Added: FileKey3 and FileKey4 [VSO Downloader (Logs)*] LangSecRef=3023 Detect=HKCU\Software\VSO\VSO Downloader Default=False FileKey1=%AppData%\VSO|*.log FileKey2=%AppData%\VSO\VSO Downloader\*\items|*.item|RECURSE FileKey3=%CommonAppData%\VSO\VSO Downloader\*\log|*.log FileKey4=%CommonAppData%\VSO\VSO Downloader\*\items|*.item|RECURSE ------------------------- New: [Wise YouTube Downloader*] LangSecRef=3023 DetectFile=%ProgramFiles%\Wise\Wise YouTube Downloader\WiseDownloader.exe Default=False FileKey1=%SystemDrive%\ThumbnailCache|*.* FileKey2=%AppData%\Wise YouTube Downloader|FileListConfig.ini Link to comment Share on other sites More sharing options...
nodles Posted May 3, 2013 Share Posted May 3, 2013 NEW ENTRY [Neverwinter (beta)*] Section=Games Detect=HKCU\Software\Cryptic\Neverwinter Default=False FileKey1=%SystemDrive%\Users\Public\Games\Cryptic Studios|*.log|RECURSE FileKey2=%SystemDrive%\Users\Public\Games\Cryptic Studios\localdata|_SWMWindowPosList.txt Link to comment Share on other sites More sharing options...
SMalik Posted May 3, 2013 Share Posted May 3, 2013 Revised Entry Added RegKey1. [Adobe Acrobat More*] LangSecRef=3021 Detect=HKCU\Software\Adobe\Adobe Acrobat Default=False RegKey1=HKCU\Software\Adobe\Acrobat Distiller\PrinterJobControl FileKey1=%LocalAppData%\Adobe\Acrobat\*\Updater|*.log Link to comment Share on other sites More sharing options...
SMalik Posted May 4, 2013 Share Posted May 4, 2013 New Entries [ESPN Cricinfo*] Section=Windows 8 Apps DetectFile=%LocalAppData%\Packages\ESPNCricinfo.ESPNCricinfo_y1atfjxm9t5ma Default=False FileKey1=%LocalAppData%\Packages\ESPNCricinfo.ESPNCricinfo_y1atfjxm9t5ma\AC\INetCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\ESPNCricinfo.ESPNCricinfo_y1atfjxm9t5ma\AC\INetCookies|*.*|RECURSE FileKey3=%LocalAppData%\Packages\ESPNCricinfo.ESPNCricinfo_y1atfjxm9t5ma\AC\INetHistory|*.*|RECURSE FileKey4=%LocalAppData%\Packages\ESPNCricinfo.ESPNCricinfo_y1atfjxm9t5ma\AC\Microsoft\CLR_v4.0\NativeImages\Temp|*.*|RECURSE FileKey5=%LocalAppData%\Packages\ESPNCricinfo.ESPNCricinfo_y1atfjxm9t5ma\AC\Microsoft\CLR_v4.0|*.log|RECURSE FileKey6=%LocalAppData%\Packages\ESPNCricinfo.ESPNCricinfo_y1atfjxm9t5ma\AC\Microsoft\CryptnetUrlCache\Content|*.* FileKey7=%LocalAppData%\Packages\ESPNCricinfo.ESPNCricinfo_y1atfjxm9t5ma\AC\Microsoft\CryptnetUrlCache\MetaData|*.* FileKey8=%LocalAppData%\Packages\ESPNCricinfo.ESPNCricinfo_y1atfjxm9t5ma\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey9=%LocalAppData%\Packages\ESPNCricinfo.ESPNCricinfo_y1atfjxm9t5ma\AC\PRICache|*.* FileKey10=%LocalAppData%\Packages\ESPNCricinfo.ESPNCricinfo_y1atfjxm9t5ma\AC\Temp|*.* FileKey11=%LocalAppData%\Packages\ESPNCricinfo.ESPNCricinfo_y1atfjxm9t5ma\LocalState|*.*|RECURSE FileKey12=%LocalAppData%\Packages\ESPNCricinfo.ESPNCricinfo_y1atfjxm9t5ma\TempState|*.*|RECURSE [ESPN FC*] Section=Windows 8 Apps DetectFile=%LocalAppData%\Packages\ESPNCricinfo.ESPNFC_y1atfjxm9t5ma Default=False FileKey1=%LocalAppData%\Packages\ESPNCricinfo.ESPNFC_y1atfjxm9t5ma\AC\INetCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\ESPNCricinfo.ESPNFC_y1atfjxm9t5ma\AC\INetCookies|*.*|RECURSE FileKey3=%LocalAppData%\Packages\ESPNCricinfo.ESPNFC_y1atfjxm9t5ma\AC\INetHistory|*.*|RECURSE FileKey4=%LocalAppData%\Packages\ESPNCricinfo.ESPNFC_y1atfjxm9t5ma\AC\Microsoft\CLR_v4.0|*.log|RECURSE FileKey5=%LocalAppData%\Packages\ESPNCricinfo.ESPNFC_y1atfjxm9t5ma\AC\PRICache|*.* FileKey6=%LocalAppData%\Packages\ESPNCricinfo.ESPNFC_y1atfjxm9t5ma\AC\Temp|*.* FileKey7=%LocalAppData%\Packages\ESPNCricinfo.ESPNFC_y1atfjxm9t5ma\LocalState|*.*|RECURSE FileKey8=%LocalAppData%\Packages\ESPNCricinfo.ESPNFC_y1atfjxm9t5ma\TempState|*.*|RECURSE Link to comment Share on other sites More sharing options...
SMalik Posted May 4, 2013 Share Posted May 4, 2013 Revised Entries Added FileKey1 in both entries. [Auslogics BoostSpeed 5*] LangSecRef=3024 Detect=HKCU\Software\Auslogics\BoostSpeed\ Default=False FileKey1=%ProgramFiles%\Auslogics\Auslogics BoostSpeed|rdboot.log FileKey2=%AppData%\Auslogics|*.htm;*.html;*.log;*.rsc;*.sta;*.xml|RECURSE RegKey1=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|DiskCleaner.AppLogic.ErrorsFailed RegKey2=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|DiskCleaner.AppLogic.ErrorsFound RegKey3=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|DiskCleaner.AppLogic.ErrorsRemoved RegKey4=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|DiskCleaner.AppLogic.LastScan RegKey5=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|RegCleaner.AppLogic.ErrorsFailed RegKey6=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|RegCleaner.AppLogic.ErrorsFound RegKey7=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|RegCleaner.AppLogic.ErrorsRemoved RegKey8=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|RegCleaner.AppLogic.LastScan RegKey9=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|TrackEraser.LastScan.DateTimeLo RegKey10=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|TrackEraser.LastScan.DateTimeHi RegKey11=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|TrackEraser.LastScan.FailedToRemove RegKey12=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|TrackEraser.LastScan.Found RegKey13=HKCU\Software\Auslogics\BoostSpeed\5.x\Settings|TrackEraser.LastScan.Removed [Auslogics Registry Defrag*] LangSecRef=3024 Detect=HKCU\Software\Auslogics\Registry Defrag Default=False FileKey1=%ProgramFiles%\Auslogics\Registry Defrag|rdboot.log FileKey2=%AppData%\Auslogics\Registry Defrag\Reports|*.* FileKey3=%AppData%\Auslogics\Registry Defrag\Logs|*.* Link to comment Share on other sites More sharing options...
ricktendo64 Posted May 4, 2013 Share Posted May 4, 2013 4th time requesting...somebody please do Adobe Reader metro app Link to comment Share on other sites More sharing options...
SMalik Posted May 5, 2013 Share Posted May 5, 2013 New Entry [Adobe Reader*] Section=Windows 8 Apps DetectFile=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga Default=False FileKey1=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga\AC\INetCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga\AC\INetCookies|*.*|RECURSE FileKey3=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga\AC\INetHistory|*.*|RECURSE FileKey4=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga\AC\Microsoft\CLR_v4.0|*.log|RECURSE FileKey5=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga\AC\PRICache|*.* FileKey6=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga\AC\Temp|*.* FileKey7=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga\LocalState|*.*|RECURSE FileKey8=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga\TempState|*.*|RECURSE Link to comment Share on other sites More sharing options...
ricktendo64 Posted May 5, 2013 Share Posted May 5, 2013 Thanks, I am good at the regular apps just have no clue what is safe to remove from a Win8 app BTW modified entry, added RegKey 1&2 to delete last open location & MRU docs [Adobe Reader*] Section=Windows 8 Apps DetectFile=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga Default=True FileKey1=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga\AC\INetCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga\AC\INetCookies|*.*|RECURSE FileKey3=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga\AC\INetHistory|*.*|RECURSE FileKey4=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga\AC\Microsoft\CLR_v4.0|*.log|RECURSE FileKey5=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga\AC\PRICache|*.* FileKey6=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga\AC\Temp|*.* FileKey7=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga\LocalState|*.*|RECURSE FileKey8=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga\TempState|*.*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga\PersistedPickerData\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga!App\DefaultOpenFileSingle|LastLocation RegKey2=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga\PersistedStorageItemTable\MostRecentlyUsed Edit: added last open location Link to comment Share on other sites More sharing options...
APMichael Posted May 5, 2013 Share Posted May 5, 2013 I recognized that some of the ExcludeKeys don't work. Conclusion: If you exclude a single file only (without a wildcard *), you have to use a backslash instead of the pipe symbol. Here is an example: ExcludeKey1=FILE|%ProgramFiles%\ProgramXY|file.exe (does not work) ExcludeKey1=FILE|%ProgramFiles%\ProgramXY\file.exe (does work) The pipe symbol is necessary if you use a wildcard (*) or a separator (: ExcludeKey1=FILE|%ProgramFiles%\ProgramXY|*.exe;*.log Modified entry: [ElsterFormular*] LangSecRef=3021 Detect=HKLM\SOFTWARE\Landesfinanzdirektion Thüringen\ElsterFormular Default=False FileKey1=%AppData%\elsterformular\*\log|*.log FileKey2=%AppData%\elsterformular\*\tmp|*.*|RECURSE FileKey3=%LocalAppData%\.elfohilfe|*.*|REMOVESELF FileKey4=%CommonAppData%\elsterformular|*.log Link to comment Share on other sites More sharing options...
Coffee4Joe Posted May 5, 2013 Share Posted May 5, 2013 [Adobe Reader*] Section=Windows 8 Apps DetectFile=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga Default=True FileKey1=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga\AC\INetCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga\AC\INetCookies|*.*|RECURSE FileKey3=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga\AC\INetHistory|*.*|RECURSE FileKey4=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga\AC\Microsoft\CLR_v4.0|*.log|RECURSE FileKey5=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga\AC\PRICache|*.* FileKey6=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga\AC\Temp|*.* FileKey7=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga\LocalState|*.*|RECURSE FileKey8=%LocalAppData%\Packages\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga\TempState|*.*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga\PersistedPickerData\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga!App\DefaultOpenFileSingle|LastLocation RegKey2=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga\PersistedStorageItemTable\MostRecentlyUsed RegKey3=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\AdobeSystemsIncorporated.AdobeReader_ynb6jyjzte8ga\SearchHistory added RegKey3 these two Keys look like they can be added to most 8 apps HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\ "APP ID" \SearchHistory HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\ "APP ID" \PersistedStorageItemTable\MostRecentlyUsed Link to comment Share on other sites More sharing options...
