CCleaner Community Forums
Winapp2.ini additions
  • Moderators
Does anyone know why IE 10 for windows 7 keeps creating a Adobe folder in the Roaming folder of the users/app data ? I don't have flash installed so am wondering why every time I delete the thing that IE 10 keeps recreating it . I know it's probably off topic but figgered this to be the best place to get an answer or maybe some idea why.
quick guess would be an adobe plug-in
Link to post
  • Moderators
I never got an answer as to why winapp2.ini kept deleting my search settings either after the last update. ]
no that was the right place for that, we just aren't sure why it happened and as yet cannot recreate it iirc
Link to post
MODIFIED ENTRY
[search Everything*]
LangSecRef=3024
DetectFile=%ProgramFiles%\Everything
Default=False
FileKey1=%AppData%\Everything|Errorlog.txt
FileKey2=%ProgramFiles%\Everything|Errorlog.txt
- Added FileKey1
Link to post
New entries:
[VMware Workstation*]
LangSecRef=3024
Detect=HKLM\SOFTWARE\VMware, Inc.\Installer\VMware Workstation
Default=False
FileKey1=%SystemDrive%|*.rnd;*resetlog.txt|RECURSE
FileKey2=%ProgramFiles%\VMware\VMware Workstation|*.txt;*.html
FileKey3=%ProgramFiles%\VMware\VMware Workstation\OVFTool|*.txt;*.rtf;*.eula
FileKey4=%ProgramFiles%\VMware\VMware vCenter Converter Standalone|*.txt;*.rtf;*.zip|RECURSE
FileKey5=%ProgramFiles%\VMware\VMware VIX|*.txt;*.rtf
FileKey6=%Documents%\My Virtual Machines|*.log|RECURSE
FileKey7=%CommonAppData%\VMware\hostd|*.log;*.gz|RECURSE
FileKey8=%CommonAppData%\VMware\Installer|*.*|REMOVESELF
FileKey9=%LocalAppData%\VMware\VMware vCenter Converter Standalone Client\Logs|*.log;*.gz
FileKey10=%CommonAppData%\\VMware\VMware vCenter Converter Standalone|*.log;*.gz;*.zip|RECURSE
ExcludeKey1=FILE|%ProgramFiles%\VMware\VMware VIX\|vixwrapper-config.txt
ExcludeKey2=FILE|%ProgramFiles%\VMware\VMware Workstation\|vixwrapper-product-config.txt
ExcludeKey3=FILE|%ProgramFiles%\VMware\VMware vCenter Converter Standalone\Help|*.txt|RECURSE
[VMware Player*]
LangSecRef=3024
Detect=HKLM\SOFTWARE\VMware, Inc.\VMware Player
Default=False
FileKey1=%ProgramFiles%\VMware\VMware Player|*.txt;*.html;*.rtf
FileKey2=%ProgramFiles%\VMware\VMware Player\OVFTool|*.txt;*.rtf;*.eula
FileKey3=%Documents%\My Virtual Machines|*.log|RECURSE
FileKey4=%LocalAppData%\VMware|*.log
ExcludeKey1=FILE|%ProgramFiles%\VMware\VMware Player\|vixwrapper-product-config.txt
Link to post
New entries:
[uSB Safely Remove*]
LangSecRef=3024
Detect=HKCU\SOFTWARE\SafelyRemove
Default=False
FileKey1=%ProgramFiles%\USB Safely Remove|*.DIZ;*.txt;*.rtf;*.url
FileKey2=%AppData%\USBSRService|*.txt
FileKey3=%AppData%\USBSafelyRemove|*.txt
[Reg Organizer*]
LangSecRef=3024
Detect=HKCU\Software\ChemTable Software\Reg Organizer
Default=False
FileKey1=%ProgramFiles%\Reg Organizer|*.txt
FileKey2=%LocalAppData%\ChemTable Software\Reg Organizer|*.log|RECURSE
[Joboshare DVD Toolkit*]
LangSecRef=3023
Detect=HKCU\Software\Joboshare\
Default=False
FileKey1=%SystemDrive%|*temp.txt;*test.txt
FileKey2=%Documents%\Joboshare\DVD Copy\log|*.*|REMOVESELF
FileKey3=%Documents%\Joboshare\DVD Copy\ifo_temp|*.*|REMOVESELF
FileKey4=%AppData%\dvdcss|*.*|REMOVESELF
Link to post
I read it that that folder only contained links, but that it would count that link as the actual file, as well as the file it links to. So the winsxs folder is actually just the size of the few bytes a folder of links takes up. I'll happily admit I may have misunderstood it though ^_^
I have investigated WinSXS some more and report my findings at
http://forum.piriform.com/index.php?showtopic=38203
I knew WinSXS was bad but now I am appalled.
Some experts claim the real things are in WinSXS and the Hard Links are in System32 and SysWOW64.
I find that infact Microsoft changed the rules with every executable that it created.
Link to post
New entry:
[TVersity*]
LangSecRef=3023
Detect=HKLM\SOFTWARE\TVersity\Media Server
Default=False
FileKey1=%WinDir%\system32/|tversity.cookies;TVersityMediaServer.log;*.1;*.2;*.3
FileKey2=%ProgramFiles%\TVersity\Media Server|*.txt;*.rtf;*.url;*TVersityCodecPackSetup*
FileKey3=%ProgramFiles%\TVersity\Media Server\logs|*.log;*.txt;*.xml;*.zip|RECURSE
FileKey4=%ProgramFiles%\TVersity Codec Pack|*.exe;*.url
FileKey5=%ProgramFiles%\Xiph.Org\|*.txt;*.rtf;AUTHORS;COPYRIGHTS;HISTORY;README|RECURSE
FileKey6=%WinDir%\system32\config\systemprofile\AppData\Local\Temp\TVersity Media Server|*.*|REMOVESELF
ExcludeKey1=FILE|%ProgramFiles%\TVersity\Media Server\|version.txt;*HOWTO Share Media.txt
ExcludeKey2=FILE|%ProgramFiles%\TVersity Codec Pack\|uninst.exe
Link to post
MODIFIED ENTRY
Added the highlighted lines.
Windows Compatibility Assistant*]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant
Default=False
RegKey1=HKCU\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant\Persisted
RegKey2=HKCU\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant\Store
RegKey3=HKU\.DEFAULT\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant\Store
RegKey4=HKU\S-1-5-18\Software\Microsoft\Windows NT\CurrentVersion\AppCompatFlags\Compatibility Assistant\Store
Link to post
New
[Mixxx logs*]
LangSecRef=3023
DetectFile=%UserProfile%\Local Settings\Application Data\Mixxx
Default=False
FileKey1=%UserProfile%\Local Settings\Application Data\Mixxx|mixxx.log
update
[VirtualBox logs*]
LangSecRef=3024
DetectFile=%UserProfile%\.VirtualBox\
Default=False
FileKey1=%UserProfile%\.VirtualBox|VBoxSVC.log.*;VBoxSVC.*;*.log
FileKey2=%UserProfile%\VirtualBox VMs\*\Logs|*.log
[NVIDIA Updates*]
LangSecRef=3023
Detect=HKLM\Software\NVIDIA Corporation
Default=False
FileKey1=%CommonAppData%\Nvidia\Updates|*.bak
FileKey2=%CommonAppData%\Nvidia\Updatus|*.bak
Link to post
modified
added ;*.log.* to FileKey3 for the rare instance minecraft hangs when closing and doesn't remove *.log.* files itself
[Minecraft*]
Section=Games
DetectFile=%AppData%\.minecraft
Default=False
FileKey1=%AppData%\.minecraft\stats|*.old
FileKey2=%AppData%\.minecraft\server|server.log
FileKey3=%AppData%\.minecraft|*.log;*.log.*
FileKey4=%AppData%\.minecraft\crash-reports|*.*
Link to post
Found some really good artifacts to delete. Some already in winapp2/ccleaner default, but others winapp2 doesn't do. please add :)
Open -> Run Dialog
  • ntuser.dat\Software\Microsoft\Windows\CurrentVersion\Explorer\ComDlg32\LastVisitedMRU
  • ntuser.dat\Software\Microsoft\Windows\CurrentVersion\Explorer\ComDlg32\LastVisitedPidlMRU
  • ntuser.dat\Software\Microsoft\Windows\CurrentVersion\Explorer\ComDlg32\LastVisitedPidlMRULegacy
UserAssist Key
  • ntuser.dat\Software\Microsoft\Windows\CurrentVersion\Explorer\UserAssist
ProgramsCache Key
  • ntuser.dat\Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage\ProgramsCache
  • ntuser.dat\Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage2\ProgramsCache
  • ntuser.dat\Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage2\ProgramsCacheTBP
  • ntuser.dat\Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage2\ProgramsCacheSMP
MUICache Key
  • ntuser.dat\Software\Microsoft\Windows\ShellNoRoam\MUICache
  • usrclass.dat\Local Settings\Software\Microsoft\Windows\Shell\MuiCache
Run Key and Miscellaneous Applications
  • ntuser.dat\Software\Microsoft\Windows\CurrentVersion\Run
  • ntuser.dat\Software\Microsoft\Windows\CurrentVersion\Run\?*\
  • ntuser.dat\Software\Microsoft\Windows\CurrentVersion\RunOnce\
  • ntuser.dat\Software\Microsoft\Windows\CurrentVersion\Explorer\RunMRU
  • ntuser.dat\Software\Sysinternals\?*\EulaAccepted
Recent Documents and Associated Keys
  • ntuser.dat\Software\Microsoft\Windows\CurrentVersion\Explorer\RecentDocs
  • ntuser.dat\Software\Microsoft\Windows\CurrentVersion\Applets\?*\Recent [File List]
  • ntuser.dat\Software\Adobe\?*\?*\AVGeneral\cRecentFiles\?*\tDIText
  • and others ...
For the standard ‘Explorer\RecentDocs’ item, this key contains the recent documents as identified in the Windows "My Recent Documents" menu. Within the key is a "MRUListEx" value that identifies the most recently viewed items. If one parses the MRUListEx, one can display the items in the order that they were accessed relative to each other.
StreamMRU Key
  • ntuser.dat\Software\Microsoft\Windows\CurrentVersion\Explorer\StreamMRU
Open -> Save Dialog
  • ntuser.dat\Software\Microsoft\Windows\CurrentVersion\Explorer\ComDlg32\OpenSaveMRU/?*/
  • ntuser.dat\Software\Microsoft\Windows\CurrentVersion\Explorer\ComDlg32\OpenSavePidlMRU/?*/
Keys Associated with Office Documents
  • ntuser.dat\Software\Microsoft\Office\?*\?*\Recent Files
  • ntuser.dat\Software\Microsoft\Office\Office\?*\?*\File MRU
  • ntuser.dat\Software\Microsoft\Office\Office\?*\?*\Place MRU
  • and others ...
OpenWithList Key
  • ntuser.dat\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts\?*\OpenWithList
Search History
  • ntuser.dat\Software\Microsoft\Search Assistant\ACMru
  • ntuser.dat\Software\Microsoft\Windows\CurrentVersion\Explorer\WordWheelQuery
Favorites key
  • ntuser.dat\Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage\Favorites
  • ntuser.dat\Software\Microsoft\Windows\CurrentVersion\Explorer\StartPage2\Favorites
  • ntuser.dat\Software\Microsoft\Windows\CurrentVersion\Explorer\Taskband\Favorites
Miscellaneous Metadata
  • ntuser.dat\Software\Microsoft\Windows\CurrentVersion\Explorer\MountPoints2
  • ntuser.dat\Software\Microsoft\Windows\CurrentVersion\Explorer\Map Network Drive MRU
  • ntuser.dat\Software\Microsoft\Windows\CurrentVersion\Explorer\ControlPanel
  • ntuser.dat\Software\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders
  • and others ...
Credits to tzworks for these locations!
Link to post
New entries:
[PS3 Media Server*]
LangSecRef=3023
Detect=HKCU\Software\PS3 Media Server
Default=False
FileKey1=%ProgramFiles%\PS3 Media Server|*log;*.txt;*.md|RECURSE
ExcludeKey1=FILE|%ProgramFiles%\PS3 Media Server\plugins\|README.txt
[Radialix 2*]
LangSecRef=3021
Detect=HKCU\Software\Radialix
Default=False
FileKey1=%ProgramFiles%\Radialix 2|*diz;*.txt;*.url
FileKey2=%ProgramFiles%\Radialix 2\Tools\UPX|COPYING;LICENSE
Link to post
Open -> Run Dialog
UserAssist Key
ProgramsCache Key
MUICache Key
  • and others ...
StreamMRU Key
Open -> Save Dialog
  • and others ...
OpenWithList Key
Search History
Favorites key
  • and others ...
I'll look into it.
Link to post
New entry:
[Oxygen 14*]
LangSecRef=3021
Detect=HKCU\Software\ej-technologies
Default=False
FileKey1=%ProgramFiles%\Oxygen XML Editor 14|*.properties;*.log;*.txt
FileKey2=%ProgramFiles%\Oxygen XML Editor 14\lib|*.txt|RECURSE
FileKey3=%ProgramFiles%\Oxygen XML Editor 14\jre|COPYRIGHT;LICENSE;*.txt;*.html
FileKey4=%ProgramFiles%\Oxygen XML Editor 14\dicts|*.txt;*.html
FileKey5=%ProgramFiles%\Oxygen XML Editor 14\.install4j|*.log
FileKey6=%AppData%\com.oxygenxml|*.history
ExcludeKey1=FILE|%ProgramFiles%\Oxygen XML Editor 14\.install4j\|files.log
Link to post
Merged/Modified entry:
[sun Java (More)*]
LangSecRef=3022
Detect=HKLM\SOFTWARE\JavaSoft\Java Runtime Environment
Default=False
FileKey1=%LocalAppData%\Sun\Java\Deployment\cache|*.*|RECURSE
FileKey2=%LocalAppData%\Sun\Java\Deployment\SystemCache|*.*|RECURSE
FileKey3=%WinDir%\system32\config\systemprofile\Local Settings\Application Data\Sun\Development\Cache|*.*|RECURSE
FileKey4=%WinDir%\SysWOW64\config\systemprofile\Local Settings\Application Data\Sun\Development\Cache|*.*|RECURSE
FileKey5=%LocalAppData%\Sun\Java\Deployment\Log|*.*|RECURSE
FileKey6=%appdata%\Sun\Java\Deployment\cache|*.*|RECURSE
FileKey7=%AppData%\Sun\Java\Deployment\log|*.*|RECURSE
FileKey8=%AppData%\Sun\Java\Deployment\tmp|*.*|RECURSE
FileKey9=%ProgramFiles%\Java\jre*|COPYRIGHT;LICENSE;README;*.txt;*.html
- Merged Sun Java Cache & Sun Java Logs
- Renamed to Sun Java (More)
- Edited lines 1,2,3,4,5
- Added lines 6,7,8,9 for Java 7/8
Never did see any trace of FileKey2, 3 or 4?
I believe Java 6 is using LocalAppData found old cache there on my PC.
Java 7 using AppData
Link to post
[sun Java (More)*]
LangSecRef=3022
Default=False
FileKey6=%AppData%\Sun\Java\Deployment\log|*.*|RECURSE
FileKey7=%AppData%\Sun\Java\Deployment\tmp|*.*|RECURSE
FileKey8=%ProgramFiles%\Java\jre7|COPYRIGHT;LICENSE;README;*.txt;*.html
its only beta right now but for future you can add jre8 also :)
i mean FileKey8=%ProgramFiles%\Java\jre*|COPYRIGHT;LICENSE;README;*.txt;*.html or something like that
Link to post
New entries:
[slimBoat*]
LangSecRef=3022
DetectFile=%ProgramFiles%\SlimBoat\SlimBoat.exe
Default=False
FileKey1=%LocalAppData%\FlashPeak\SlimBoat\cache|*.*|RECURSE
FileKey2=%LocalAppData%\FlashPeak\SlimBoat\cookies|*.*|RECURSE
FileKey3=%LocalAppData%\FlashPeak\SlimBoat\iconcache|*.*|RECURSE
FileKey4=%LocalAppData%\FlashPeak\SlimBoat\LocalStorage|*.*|RECURSE
FileKey5=%LocalAppData%\FlashPeak\SlimBoat\history
[slimBrowser*]
LangSecRef=3022
DetectFile=%ProgramFiles%\SlimBrowser\sbframe.exe
Default=False
FileKey1=%AppData%\SlimBrowser\iconcache|*.*|RECURSE
FileKey2=%AppData%\SlimBrowser|freqsite.txt
FileKey3=%AppData%\SlimBrowser|freqform.txt
FileKey4=%AppData%\SlimBrowser|RecentCloseW.ini
Link to post
[sun Java (More)*]
Thanks ProPaan.
I've put your edit iinto the entry.
Link to post
  • Moderators
New:
[MS Office Remove Hidden Data Tool (Log)*]
LangSecRef=3021
Detect=HKLM\SOFTWARE\Microsoft\Office\Common\Remove Hidden Data Tool
Default=False
FileKey1=%SystemDrive%|propfix.log
Link to post
  • Moderators
New entry
[sun Java Update*]
LangSecRef=3022
Warning=Java will no longer check the internet for updates, notify and/or manage update downloads.
Default=False
FileKey1=%CommonProgramFiles%\Java\Java Update|*.*|RECURSE
RegKey1=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run\SunJavaUpdateSched
RegKey2=HKLM\SOFTWARE\Wow6432Node\Microsoft\Windows\CurrentVersion\Run\SunJavaUpdateSched
please no. Please keep in mind that ccleaner is a gentle JUNK cleaner. It's not for removing those things you (and many of us) find annoying. Let's try to keep that in mind and the idea in mind that the community version's main and stated goal is to road test entries for the myriad of programs users might have but the developers don't and for newer discovered features of things (like our wonderful windows8 section.)
Secondly the inbuilt java clean does not get cache. I know I've been testing the various java rules last week.
Link to post
Register a new account
Sign in
