Winapp2.ini Posted April 2, 2013 Author Share Posted April 2, 2013 That entry calls for the removal of FileKey2, which will be incorporated into the next iteration winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Guest Keatah Posted April 2, 2013 Share Posted April 2, 2013 Thanks. I was writing up some documentation on the entries that are critical to the operation of 2 systems. Link to comment Share on other sites More sharing options...
Coffee4Joe Posted April 2, 2013 Share Posted April 2, 2013 [Config.msi Folder*] LangSecRef=3025 Detect=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\Folders Default=False RegKey1=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\Folders|C:\Config.Msi\ FileKey1=%SystemDrive%\Config.msi|*.*|REMOVESELF I haven't tested it but I do wonder if RegKey1 will cause an MSI installer to fail, and I wonder if Windows Installer is smart enough to re-create that registry key to know where it unpacks the setup files. I believe windows should automatically deleted the key after the installation is finnished if the install doesn't fail. /me waits for patch tuesday to see if it makes & deletes the file + key Link to comment Share on other sites More sharing options...
Winapp2.ini Posted April 2, 2013 Author Share Posted April 2, 2013 I've just noticed we've hit 3000 posts in this thread. *confetti* @C4J, I'm not sure but that sounds logically valid. We'll have to see winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Winapp2.ini Posted April 3, 2013 Author Share Posted April 3, 2013 Someone tweeted me and mentioned that an entry causes Windows Defender to not start up correctly when it's set to boot with windows. Does anyone use Windows Defender that can confirm / deny? winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Hav0c Posted April 3, 2013 Share Posted April 3, 2013 Mod Entry [ESET Smart Security*] LangSecRef=3021 Detect=HKLM\SOFTWARE\ESET\ESET Security Default=False Warning=You may need to run this in safe mode. You should also disable the ERA service to properly clean the ERA files. FileKey1=%CommonAppData%\ESET\ESET Smart Security\Updfiles|*.*|REMOVESELF FileKey2=%CommonAppData%\ESET\ESET Smart Security\Logs|*.*|RECURSE FileKey3=%CommonAppData%\ESET\ESET Smart Security\Oldfiles|*.*|RECURSE Added a warrning Edited FileKey1 so to delete the folder Removed old FileKey2 New [ESET NOD32 Antivirus*] LangSecRef=3021 Detect=HKLM\SOFTWARE\ESET\ESET Security Default=False Warning=You may need to run this in safe mode. You should also disable the ERA service to properly clean the ERA files. FileKey1=%CommonAppData%\ESET\ESET NOD32 Antivirus\Updfiles|*.*|REMOVESELF FileKey2=%CommonAppData%\ESET\ESET NOD32 Antivirus\Logs|*.*|RECURSE FileKey3=%CommonAppData%\ESET\ESET NOD32 Antivirus\Oldfiles|*.*|RECURSE Note: FileKey2 in both entries, the log .dat files can't be deleted; why the first person added it I have no idea. Can someone please just check if it contains more than the .dat files. Seeing mine only contains the .dat files can’t test FileKey2. IF so then leave as is if not remove FileKey2 then. Every line of code written by man can be undone by man . "A loser in the real world is still a loser in the net!" - .hack//SIGN . Getting old is inevitable, growing up is optional !! Link to comment Share on other sites More sharing options...
Moderators Andavari Posted April 4, 2013 Moderators Share Posted April 4, 2013 Note: FileKey2 in both entries, the log .dat files can't be deleted; why the first person added it I have no idea. Most antivirus' have to be fully turned off to delete logs, backup files, etc., and I'm not just talking about their services their drivers have to also be stopped - something which Nirsoft ServiWin can do. Maybe that's why someone wrote it, but I don't know. Link to comment Share on other sites More sharing options...
back_track Posted April 4, 2013 Share Posted April 4, 2013 This is a Prime example of not cleaning junk. Entire Programs do not belong on the PUBLIC file, what is AVM updater that the entire program should be removed without even a warning. If you don't want it uninstall it or physically delete it...or explain why I'm wrong. it is not a programm its only the installer from the avm driver which you don't need for unistall. Link to comment Share on other sites More sharing options...
Hav0c Posted April 4, 2013 Share Posted April 4, 2013 Most antivirus' have to be fully turned off to delete logs, backup files, etc., and I'm not just talking about their services their drivers have to also be stopped - something which Nirsoft ServiWin can do. Maybe that's why someone wrote it, but I don't know. Makes sense. Looks like ESET creates an eScan folder within the Log folder that contains some .dat files that can be deleted. Message from ESET : “You should be able to delete the folder updfiles but I would recommend to do this in safe mode for the antivirus package alternatively if you wish to delete the updfiles folder for ESET Remote Administrator then remeber to stop the ERA service.” Every line of code written by man can be undone by man . "A loser in the real world is still a loser in the net!" - .hack//SIGN . Getting old is inevitable, growing up is optional !! Link to comment Share on other sites More sharing options...
ricktendo64 Posted April 5, 2013 Share Posted April 5, 2013 Added RegKey9, adds support for InstallShield 2012 Spring (a.k.a. v19.0) [installShield Professional*] LangSecRef=3021 Detect=HKCU\Software\InstallShield Default=False RegKey1=HKCU\Software\InstallShield\InstallShield Professional\6.0\IsCabVu|MRU1 RegKey2=HKCU\Software\InstallShield\InstallShield Professional\6.0\IsCabVu|MRU2 RegKey3=HKCU\Software\InstallShield\InstallShield Professional\6.0\IsCabVu|MRU3 RegKey4=HKCU\Software\InstallShield\InstallShield Professional\6.0\IsCabVu|MRU4 RegKey5=HKCU\Software\InstallShield\InstallShield Cabinet and Log File Viewer\Recent File List RegKey6=HKCU\Software\InstallShield\16.0\Professional\Recent File List RegKey7=HKCU\Software\InstallShield\17.0\Professional\Recent File List RegKey8=HKCU\Software\InstallShield\18.0\Professional\Recent File List RegKey9=HKCU\Software\InstallShield\19.0\Professional\Recent File List Link to comment Share on other sites More sharing options...
Winapp2.ini Posted April 5, 2013 Author Share Posted April 5, 2013 Thanks winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
nodles Posted April 5, 2013 Share Posted April 5, 2013 NEW ENTRY [Crysis 3*] Section=Games Detect1=HKLM\SOFTWARE\Crytek\Crysis 3 Detect2=HKLM\SOFTWARE\Wow6432Node\Crytek\Crysis 3 Default=False FileKey1=%ProgramFiles%\Origin Games\Crysis 3\LogBackups|*.* Link to comment Share on other sites More sharing options...
Moderators Andavari Posted April 6, 2013 Moderators Share Posted April 6, 2013 (edited) I find it completely destructive to remove the *.tun extension, since Total Uninstall is made to aid in the complete removal of a program, and the *.tun files are the kept logs to allow that: [Total Uninstall Backups*] FileKey1=%CommonAppData%\Martau\Total Uninstall*|*.tlg;*.tun;*.zsns;*.zip|RECURSE Edited April 6, 2013 by Andavari Link to comment Share on other sites More sharing options...
Winapp2.ini Posted April 6, 2013 Author Share Posted April 6, 2013 Will nix that bit in the next update, thanks winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
CSGalloway Posted April 6, 2013 Share Posted April 6, 2013 I have searched the HDD and found several BAK and TMP files. Please do incorporate the folling into the winapp2.ini Added FileKey2 [Multi-Edit 2008 11.04*] LangSecRef=3021 Detect=HKCU\Software\Multi Edit Software\Multi-Edit\11.0 Default=False FileKey1=%AppData%\Multi Edit Software\Multi-Edit\11\Config.04\Tmp|*.* FileKey2=C:\Users\Galloway\AppData\Local\VirtualStore\Program Files (x86)\Multi-Edit 2008\Config|*.tmp Add FileKey to [Yahoo Messenger] so the following files are removed C:\Users\Galloway\AppData\Local\VirtualStore\Program Files (x86)\Yahoo!\Messenger\Cache\9G0IMTf7KSnOtr1pRkveNQ--.ProfileMap.dat.tmp C:\Users\Galloway\AppData\Local\VirtualStore\Program Files (x86)\Yahoo!\Messenger\Cache\vJH983EOLox0so80SeGvPg--.ProfileMap.dat.tmp Add FileKey to [Multi-Edit 2008 11.04*] to delete the files C:\Users\Galloway\AppData\Roaming\Multi Edit Software\Multi-Edit\11\Config.04\MeConfig.BAK C:\Users\Galloway\AppData\Roaming\Multi Edit Software\Multi-Edit\11\Config.04\WCmdMap.BAK C:\Users\Galloway\AppData\Roaming\Multi Edit Software\Multi-Edit\11\Config.04\Wordstar.BAK Add FileKey to [jv16 PowerTools Temp Files*] to delete the files C:\Users\Galloway\AppData\Local\jv16PT_temp.tmp ; = = = = = = = = [Microsoft Bing Bar*] LangSecRef=3021 Detect=HKCU\Software\AppDataLow\Software\Microsoft\BingBar Default=False FileKey1=C:\Users\Galloway\AppData\Local\Microsoft\BingBar\Apps|*.tmp [Windows Live Setup Temp Files*] LangSecRef=3022 Detect=HKLM\SOFTWARE\Microsoft\Windows Live Default=False FileKeys to handle the following files.... C:\ProgramData\Microsoft\WLSetup\wlt551C.tmp C:\Users\All Users\Microsoft\WLSetup\wlt551C.tmp [Twain Temp Files*] LanSecRef=3021 DetectFile=%WinDir%\twain_32 Default=False FileKey1=%WinDir%\twain_32|*.tmp Link to comment Share on other sites More sharing options...
SMalik Posted April 7, 2013 Share Posted April 7, 2013 Revised Entry Added RegKey3. [Windows Error Reporting More*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows\Windows Error Reporting Default=False RegKey1=HKCU\Software\Microsoft\Windows\Windows Error Reporting\Debug|StoreLocation RegKey2=HKLM\SOFTWARE\Microsoft\Windows\Windows Error Reporting\Debug|StoreLocation RegKey3=HKU\.DEFAULT\Software\Microsoft\Windows\Windows Error Reporting\Debug|StoreLocation RegKey4=HKU\S-1-5-18\Software\Microsoft\Windows\Windows Error Reporting\Debug|StoreLocation FileKey1=%WinDir%\System32\config\systemprofile\AppData\Local\CrashDumps|*.dmp FileKey2=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\CrashDumps|*.dmp Link to comment Share on other sites More sharing options...
Winapp2.ini Posted April 7, 2013 Author Share Posted April 7, 2013 Thanks winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted April 10, 2013 Share Posted April 10, 2013 I had posted [Adobe Acrobat Setup Files*] and [Adobe Reader Setup Files*] entries but now, I have removed them because I believe CCleaner is a program to clean Internet junk and optimize Windows not to erase the Installation files of the programs. I think you should also remove all the other entries that remove the installation files of the programs from Winapp2.ini Link to comment Share on other sites More sharing options...
SMalik Posted April 13, 2013 Share Posted April 13, 2013 New Entry [Adobe Photoshop Elements 11*] LangSecRef=3021 Detect=HKCU\Software\Adobe\Photoshop Elements\11.0 Default=False RegKey1=HKCU\Software\Adobe\Photoshop Elements\11.0\VisitedDirs\STARTUPIMAGEDIRECTORY RegKey2=HKCU\Software\Adobe\Photoshop Elements\11.0\CurrentMediaFilePath RegKey3=HKCU\Software\Adobe\Photoshop Elements\11.0\common\settings\Elements MRU RegKey4=HKCU\Software\Adobe\Elements Organizer\11.0\CustomCatalogPath RegKey5=HKCU\Software\Adobe\Elements Organizer\11.0\CurrentMediaFilePath FileKey1=%CommonAppData%\Adobe\Elements Organizer\Catalogs\My Catalog|backupCt.dat FileKey2=%CommonAppData%\Adobe\Elements Organizer\Catalogs\My Catalog|catalog.pse11db FileKey3=%CommonAppData%\Adobe\Elements Organizer\Catalogs\My Catalog|collstatus.dat FileKey4=%CommonAppData%\Adobe\Elements Organizer\Catalogs\My Catalog|face.thumb.9.cache FileKey5=%CommonAppData%\Adobe\Elements Organizer\Catalogs\My Catalog|peoplestatus.dat FileKey6=%CommonAppData%\Adobe\Elements Organizer\Catalogs\My Catalog|tagstatus.dat FileKey7=%CommonAppData%\Adobe\Elements Organizer\Catalogs\My Catalog|thumb.5.cache FileKey8=%CommonAppData%\Adobe\Elements Organizer\Catalogs\My Catalog|WaldoData\waldo.cache FileKey9=%CommonAppData%\Adobe\Photoshop Elements\File Agent|WatchFolder.3.cache FileKey10=%AppData%\Adobe\Elements Organizer\11.0\Organizer|APDPreferences.xml FileKey11=%AppData%\Adobe\Photoshop Elements\11.0\Editor|Adobe Photoshop Elements 11 Prefs.psp FileKey12=%Pictures%\Adobe\Desktop Wallpaper|wallpaper.bmp Link to comment Share on other sites More sharing options...
SMalik Posted April 13, 2013 Share Posted April 13, 2013 I think these entries should be removed from the Winapp2.ini: [Adobe Acrobat Setup Files*] LangSecRef=3021 Detect=HKCU\Software\Adobe\Adobe Acrobat Default=False FileKey1=%LocalAppData%\Adobe\Reader*\Setup Files|*.* [Adobe Reader 10.0 Setup Files*] LangSecRef=3021 Detect=HKCU\Software\Adobe\Acrobat Reader\10.0 Default=False Warning=This will prevent a repair installation. You have to download the installer for a reinstallation. FileKey1=%CommonAppData%\Adobe\ARM\Reader_10.*|*.*|REMOVESELF FileKey2=%CommonAppData%\Adobe\Setup\{AC76BA86-7AD7-*-7B44-AA1000000001}|*.*|REMOVESELF [Apple Installer Cache*] LangSecRef=3023 Detect=HKCU\Software\Apple Computer, Inc. Default=False Warning=You have to reinstall iTunes after adding a new windows user account. FileKey1=%CommonAppData%\Apple Computer\Installer Cache\*|*.* FileKey2=%CommonAppData%\Apple\Installer Cache\*|*.* Link to comment Share on other sites More sharing options...
Moderators Nergal Posted April 13, 2013 Moderators Share Posted April 13, 2013 (edited) really? RegKey4=HKCU\Software\Adobe\Elements Organizer\11.0\CustomCatalogPath FileKey1=%CommonAppData%\Adobe\Elements Organizer\Catalogs\My Catalog|backupCt.dat FileKey2=%CommonAppData%\Adobe\Elements Organizer\Catalogs\My Catalog|catalog.pse11db FileKey10=%AppData%\Adobe\Elements Organizer\11.0\Organizer|APDPreferences.xml FileKey11=%AppData%\Adobe\Photoshop Elements\11.0\Editor|Adobe Photoshop Elements 11 Prefs.ps FileKey12=%Pictures%\Adobe\Desktop Wallpaper|wallpaper.bmp Are any of these actually junk? Or are they junk to you because you don't use the desktop wallpaper or change any prefs. Edit: also see http://forum.piriform.com/index.php?showtopic=37893&hl=%2Bphotoshop+%2Belements Edited April 13, 2013 by Nergal clarity;added link ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
SMalik Posted April 13, 2013 Share Posted April 13, 2013 (edited) really? Are any of these actually junk? Or are they junk to you because you don't use the desktop wallpaper or change any prefs. Edit: also see http://forum.pirifor...oshop +elements Have you heard about a privacy eraser program called {Removed}? This program was introduced 15 years ago.The Adobe Photoshop Elements 11 entry that I provided is a exact copy from that program. I have {remove} on my system I also have Adobe Photoshop Elements 11 on my system. I always wipe traces of this program using that entry without any issue. By the way the FileKey12 is not related to Windows wallpaper. Edited April 13, 2013 by Nergal by moderator Link to comment Share on other sites More sharing options...
Winapp2.ini Posted April 13, 2013 Author Share Posted April 13, 2013 updated winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Nergal Posted April 13, 2013 Moderators Share Posted April 13, 2013 (edited) Saad, 1) I am not an idiot do NOT talk to me as if I were one By the way the FileKey12 is not related to Windows wallpaper To use an acronym N.S.S 2) This is an official forum, it is not allowed to mention by name, or especially link to COMPETITOR'S PRODUCTS. I've removed your links et.al. I care Not what other's remove, ccleaner is a gentle junk! Cleaner; and if this whole time you've been submitting rules from another product's code, Willy-nilly I will personally ban you. Edit: by the way I also have PSE11 (if you'd've looked at the thread I linked...) and the following post. Edited April 13, 2013 by Nergal added separation of thoughs; et more ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Moderators Nergal Posted April 13, 2013 Moderators Share Posted April 13, 2013 (edited) I have tested the most obvious of those which i complained of above: FileKey11=%AppData%\Adobe\Photoshop Elements\11.0\Editor|Adobe Photoshop Elements 11 Prefs.psp Before removal of file Note the Changes made in recent file number, History(undos) and definitly layout and that it is set to "expert" After removal of file: In all honesty it's not a wonder I've lately found your suggestions to be UBER-aggressive Edited April 13, 2013 by Nergal spelling;clarity ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
