CCleaner Community Forums
Winapp2.ini
Winapp2.ini additions
InnoExtractor fixes for Winapp2.ini:
On Windows 2000 and XP systems, the default InnoExtractor install folder is %AppData%\InnoExtractor\
On Windows Vista, 7 and 8 systems, the default InnoExtractor install folder is %LocalAppData%\InnoExtractor\
Also, the application creates temporal files into %temp%\InnoExtractorCache\ folder when you make Zip packages or self-extracting modules of your Inno Setup installers.
So, the correct addition for InnoExtractor is the follow:
[innoExtractor*]
LangSecRef=3024
DetectFile=%LocalAppData%\InnoExtractor\InnoExtractor.exe
DetectFile2=%AppData%\InnoExtractor\InnoExtractor.exe
Default=False
FileKey1=%LocalAppData%\InnoExtractor|Historial.dat
FileKey2=%AppData%\InnoExtractor|Historial.dat
FileKey3=%temp%\InnoExtractorCache|*.*|RECURSE
Best regards.
Share this post
Link to post
Thanks for improving the InnoExtractor settings
You think it would be better to use REMOVESELF here?
Share this post
Link to post
I recommend that the following codes be changed from LangSecRef=3025 to LangSecRef=3022 because they are Internet related.
[LocalService Cookies*]
[LocalService History*]
[LocalService Temporary Internet Files*]
[iETldCache*]
[NetworkService Cookies*]
[NetworkService History*]
[NetworkService Temporary Internet Files*]
[iE7pro*] probably should be changed from 3024 to 3022 as well.
Share this post
Link to post
[JDownloader Capatchas*] to [JDownloader Captchas*]
Sorry for being a smart aleck.
I have a question too: rtmpGUI creates a file named .swfinfo under %UserProfile% but no registry entries or other files.
Maybe the rule can be like this?
[rtmpGUI .swfinfo*]
LangSecRef=3024
DetectFile=%UserProfile%\.swfinfo
Default=False
FileKey1=%UserProfile%|.swfinfo
Share this post
Link to post
NEW
[Hard Drive Inspector Error Log*]
LangSecRef=3024
DetectFile=%CommonAppData%\AltrixSoft\Hard Drive Inspector
Default=False
FileKey1=%CommonAppData%\AltrixSoft\Hard Drive Inspector|log.err
NEW
[slimComputer Logs*]
LangSecRef=3024
DetectFile=%LocalAppData%\SlimWare Utilities Inc\SlimComputer
Default=False
FileKey1=%LocalAppData%\SlimWare Utilities Inc\SlimComputer\Logs|*.log
Sorry for creating two posts. If you can and want, please merge them.
Share this post
Link to post
Please add
[VNCViewer 5]
LangSecRef=3024
Detect=HKCU\Software\RealVNC\vncviewer\MRU
Default=False
RegKey1=HKCU\Software\RealVNC\vncviewer\MRU
Thanks!
Share this post
Link to post
You're deleting your detect. try this
[VNCViewer 5]
LangSecRef=3024
Default=False
Share this post
Link to post
Cleans a few things CCleaner doesn't with its Chrome cleaner.
[Comodo Dragon (More)*]
LangSecRef=3029
Detect=HKLM\Software\ComodoGroup\Dragon
Default=False
FileKey1=%LocalAppData%\COMODO|*.lock|RECURSE
FileKey2=%LocalAppData%\COMODO\Dragon\User Data\Default|Bookmarks.bak
FileKey3=%LocalAppData%\COMODO\Dragon\User Data\Default|Extension Cookies
FileKey4=%LocalAppData%\COMODO\Dragon\User Data\Default|Network Action Predictor-journal
FileKey5=%LocalAppData%\COMODO\Dragon\User Data\Default\Media Cache|*.*|RECURSE
FileKey6=%LocalAppData%\COMODO\Dragon\User Data\Default\Temp|*.*|RECURSE
For your specialized winapp2.ini file, it removes all non U.S. English language files.
[Comodo Dragon (Lang)*]
Section=Language Files
Default=False
ExcludeKey1=FILE|%ProgramFiles%\Comodo\Dragon\locales\|en-US.pak
FileKey1=%ProgramFiles%\Comodo\Dragon\locales|*.pak
Share this post
Link to post
questo è il mio file winapp2 e contiene oltre 1000 voci. Se è possibile oltre ad inserirle tutte quante,correggere un bug ovvero che quando ccleaner apre la scheda delle applicazioni nella sezione pulizia ci impiega molto tempo se il file winapp2 è personalizzato e supera le voci predefinite di ccleaner. Poi sempre se è possibile inserire nella pulizia la pulizia dei file .bcd di Easy BCD . fatemi sapere se tutte queste voci vi saranno utili per il prossimo aggiornamento di ccleaner :)
this is my file winapp2 and contains over 1000 entries. If you can put them in addition to all of them, or fix a bug that when ccleaner open the applications tab in the cleaning it takes a long time if the file is customized winapp2 and exceeds the predefined items ccleaner. Then it is always possible to insert the cleaning cleaning up files .Bcd of Easy BCD . let me know if all of these items will be useful for the next update of ccleaner :)
EDIT: This user has posted the version of Winapp2 included in the enchancing program. It was Identical to Community Verison. Poster asked me to remove this and the 19 posts that followed. He had only good thoughts in mind; he apologizes for the many Post notifications that many of you may have gotten. I have answered his slow load question in Private Message -NERGAL
Edited by Nergal
Share this post
Link to post
HA! I just read the newest version of post 1 IT'S AWESOME!!!!!!!!
Share this post
Link to post
Whatcha mean
:huh:
Share this post
Link to post
Good
I missed the 20 additional posts :P
then no worries
Share this post
Link to post
New entry:
[Microsoft Project 2010*]
LangSecRef=3021
Detect=HKCU\Software\Microsoft\Office\14.0\MS Project
Default=False
RegKey1=HKCU\Software\Microsoft\Office\14.0\MS Project\Recent File List
RegKey2=HKCU\Software\Microsoft\Office\14.0\MS Project\Recent Templates
Share this post
Link to post
[phase-6*]
LangSecRef=3021
DetectFile=%UserProfile%\.phase-6
Default=False
FileKey1=%UserProfile%\.phase-6|window-position.txt|REMOVESELF
[JDownloader*]
LangSecRef=3022
DetectFile=%ProgramFiles%\JDownloader
Default=False
FileKey1=%ProgramFiles%\JDownloader|updateLog.txt
The detect used for the other entries (Detect=HKLM\Software\JDownloader) will be deleted by CCleaner's Registry Cleaner (at least on my computer).
For the more advanced entries for power users:
List of permanently allowed IP ranges in Peerblock:
[Peerblock allowed IPs*]
LangSecRef=3024
DetectFile=%ProgramFiles%\Peerblock
Default=False
FileKey1=%ProgramFiles%\Peerblock\lists|permallow.p2b
This will delete SumatraPDF settings but also the history (sorry that it is in german):
[sumatraPDF*]
LangSecRef=3024
DetectFile=%AppData%\SumatraPDF
Default=False
FileKey1=%AppData%\SumatraPDF|sumatrapdfprefs.dat|REMOVESELF
I have some questions too:
1. How often is Winapp2.ini updatet (once per month or every some weeks or what)?
2. When will the advanced entries for power users come back?
Share this post
Link to post
It'll be back EVENTUALLY! but I need to figure out how I want to format it and make it clear it's meant to cherry pick from, not to use as an entire additional ini. I don't want people to use it and then come post here saying "what the heck, man, now my XYZ is gone!!!"
Share this post
Link to post
They wouldn't be able to complain, because we would've already deleted their lang files from their browser. :lol:
Share this post
Link to post
Register a new account
Sign in
