CCleaner Community Forums
Winapp2.ini
Winapp2.ini additions
Combine [sUMo Log*] and [sUMo*] to
[sUMo BAKs/LOGs*]
LangSecRef=3024
Detect=HKCU\Software\KC Softwares\SUMo
Default=False
FileKey1=%AppData%\KC Softwares\SUMo|*.log
FileKey2=%AppData%\KC Softwares\SUMo|db.bak
Change the LangSecRef in
[ACDSee 6.0 Standard Database*]
[ACDSee 6.0 Standard Registry*]
to be 3021 so it matches
[ACDSee Pro*]
Share this post
Link to post
Seems I also missed Captcha Brotherhood :(
Yes, You missed it. http://forum.piriform.com/index.php?showtopic=32310&view=findpost&p=221965
Did You miss the JDownloader updateLog.txt? http://forum.piriform.com/index.php?showtopic=32310&view=findpost&p=222417
My question once again: How often is Winapp2.ini updatet (once per month or every some weeks or randomly)?
WARNING about "Windows Media Player (Databases)*"
This will remove ratings, play counts, last played, etc.
etc.? Please a bit more specific. For example: Playlists too?
Share this post
Link to post
Thanks for the update!
Entry with a typo:
[sun Java Logs*]
LangSecRef=3022
DetectOS=6.0
Detect=HKLM\SOFTWARE\JavaSoft\Java Runtime Environment
Default=False
FileKey1=%LocalLowAppData%\Sun\Java\Deployment\Log|*.*
Share this post
Link to post
Modified:
[The Sims 3 DCBackup Files*]
Warning=This may make premium content buggy if deleted.
Section=Games
Detect=HKCU\Software\Electronic Arts\Sims 3
Default=False
FileKey1=%Documents%\Electronic arts\The sims 3\DCBackup|*.package
ExcludeKey1=FILE|%Documents%\electronic arts\The sims 3\DCBackup\ccmerged.package
[Thinstall Database*]
Warning=This will remove your Portable's settings. If settings are stored in the program's folder, this is fine.
LangSecRef=3021
DetectFile1=%AppData%\Thinstall
DetectFile2=%LocalAppData%\Thinstall
Default=False
FileKey1=%AppData%\Thinstall|*.*|REMOVESELF
FileKey2=%LocalAppData%\Thinstall|*.*|REMOVESELF
New entries:
[The Sims 3 Cache Files*]
Section=Games
Default=False
FileKey1=%Documents%\Electronic Arts\The Sims 3|socialCache.package
FileKey2=%Documents%\Electronic Arts\The Sims 3|CASPartCache.package
FileKey3=%Documents%\Electronic Arts\The Sims 3|scriptCache.package
FileKey4=%Documents%\Electronic Arts\The Sims 3|compositorCache.package
FileKey5=%Documents%\Electronic Arts\The Sims 3|simCompositorCache.package
FileKey6=%Documents%\Electronic Arts\The Sims 3\WorldCaches|*.*
FileKey7=%Documents%\Electronic Arts\The Sims 3\Thumbnails|*.*
[The Sims Medieval Logs*]
Section=Games
Detect=HKLM\Software\Electronic Arts\The Sims Medieval
Default=False
FileKey1=%Documents%\Electronic Arts\The Sims Medieval|*.log|RECURSE
FileKey2=%Documents%\Electronic Arts\The Sims Medieval|*.xml|RECURSE
[CC Magic Logs*]
Section=Games
DetectFile=%Documents%\Electronic Arts\CC Magic\Logs\
Default=False
FileKey1=%Documents%\Electronic Arts\CC Magic\Logs|*.log|RECURSE
[Call of Juarez Logs*]
Section=Games
Detect1=HKLM\SOFTWARE\Techland
Detect2=HKLM\SOFTWARE\Techland\CallofJuarez2
Default=False
FileKey1=%Documents%\call of juarez\Out\logs|*.log|RECURSE
FileKey2=%Documents%\Call of Juarez - Bound in Blood\Out\logs|*.log|RECURSE
[18 Wheels of Steel Logs*]
Section=Games
Detect=HKCU\Software\ValuSoft
Default=False
FileKey1=%Documents%\18 WoS Haulin|*.log
FileKey2=%Documents%\18 WoS American Long Haul|*.log|
[Euro Truck Simulator Logs*]
Section=Games
Detect=HKCU\Software\SCS Software\Euro Truck Simulator
Default=False
FileKey1=%Documents%\Euro Truck Simulator|*.log
[Conceiva Mezzmo*]
LangSecRef=3023
Detect=HKLM\SOFTWARE\Conceiva
Default=False
FileKey1=%ProgramFiles%\Conceiva\Mezzmo|*.txt
[uTorrent ipfilter backup*]
LangSecRef=3022
DetectFile=%AppData%\uTorrent
Default=False
FileKey1=%AppData%\utorrent|*ipfilter.bak
English language only:
[Conceiva Mezzmo (More)*]
Section=Language Files
Default=False
FileKey1=%ProgramFiles%\Conceiva\Mezzmo\Language|*.txt
ExcludeKey1=FILE|%ProgramFiles%\Conceiva\Mezzmo\Language\|au_en.txt
ExcludeKey2=FILE|%ProgramFiles%\Conceiva\Mezzmo\Language\|ms_en.txt
ExcludeKey3=FILE|%ProgramFiles%\Conceiva\Mezzmo\Language\|mz_en.txt
ExcludeKey4=FILE|%ProgramFiles%\Conceiva\Mezzmo\Language\|np_en.txt
Share this post
Link to post
Roughly every two weeks, sometimes I'm late by a few days, sometimes I miss an update all together if I'm particuarly busy, and consolidate it into one monthly update, but generally I try update the day CCleaner does, then about two weeks after that.
Share this post
Link to post
I don't know if this has been mentioned before, but the entry for deleting the Google Chrome installer seems to cause some issues. For me, it kept trying to update Chrome with the previous version and I had to reinstall manually. I think there should be a popup warning when you select this, like deleting the installers for Acrobat, etc.
Thanks for all the hard work on this!
Share this post
Link to post
The three codes below do NOT seem to apply to Windows 7; however, they show up in the Applications tab on Windows 7 systems. It appears to me that they are intended for Windows XP. They should either be modified to include Windows 7 (and probably Vista) or they should have a DetectOS=|5.1 added to the code.
[Windows Media Player (Album Art Cache)*]
LangSecRef=3023
Detect=HKCU\Software\Microsoft\MediaPlayer
Default=False
FileKey1=%WinDir%\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Media Player\Art Cache\LocalMLS|*.*|RECURSE
FileKey2=%SystemDrive%\Documents and Settings\NetworkService\Local Settings\Microsoft\Media Player\Art Cache\LocalMLS|*.*|RECURSE
FileKey3=%SystemDrive%\Documents and Settings\NetworkService\Local Settings\Application Data\Microsoft\Media Player\Art Cache\LocalMLS|*.*|RECURSE
[Windows Media Player (Databases)*]
LangSecRef=3023
Warning=This will remove ratings, play counts, last played, etc.
Default=False
FileKey1=%WinDir%\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Media Player|*.*|REMOVESELF
FileKey2=%SystemDrive%\Documents and Settings\NetworkService\Local Settings\Microsoft\Media Player|*.*|REMOVESELF
FileKey3=%SystemDrive%\Documents and Settings\NetworkService\Local Settings\Application Data\Microsoft\Media Player|*.*|REMOVESELF
[Windows Media Player (MediaGuide)*]
LangSecRef=3023
Default=False
RegKey1=HKCU\Software\Microsoft\MediaPlayer\Preferences|CurrentBackgroundScanFolder
RegKey2=HKCU\Software\Microsoft\MediaPlayer\Services\MediaGuide|CachedIconPath
RegKey3=HKCU\Software\Microsoft\MediaPlayer\Services\MediaGuide|CachedLargeLogoPath
It actually looks like the three above codes can be removed because they are included in winapp.ini.
[Windows Media Player]
ID=2033
LangSecRef=3023
Detect=HKCU\Software\Microsoft\MediaPlayer\Player
Default=True
RegKey1=HKCU\Software\Microsoft\MediaPlayer\Player\RecentFileList
RegKey2=HKCU\Software\Microsoft\MediaPlayer\Player\RecentURLList
RegKey3=HKCU\Software\Microsoft\MediaPlayer\Preferences|LastPlayList
RegKey4=HKCU\Software\Microsoft\MediaPlayer\Preferences|LastPlayListIndex
RegKey5=HKCU\Software\Microsoft\MediaPlayer\Player\Settings|SaveAsDir
RegKey6=HKCU\Software\Microsoft\MediaPlayer\AutoComplete\MediaEdit
RegKey7=HKCU\Software\Microsoft\MediaPlayer\Radio\MRUList
RegKey8=HKCU\Software\Microsoft\MediaPlayer\Services\MediaGuide|CachedIconPath
RegKey9=HKCU\Software\Microsoft\MediaPlayer\Services\MediaGuide|CachedLargeLogoPath
FileKey1=%LocalAppData%\Microsoft\Media Player|lastplayed.wpl
FileKey2=%LocalAppData%\Microsoft\Media Player|cacheentry*.*|RECURSE
FileKey3=%LocalAppData%\Microsoft\Media Player\Art Cache\LocalMLS|*.*|RECURSE
FileKey4=%LocalAppData%\Microsoft\Media Player\Transcoded Files Cache|*.*|RECURSE
Share this post
Link to post
Technical question .....
Should it be DetectOS=|5.1 or DetectOS=5.1? In other words, is the | required in the DetectOS command?
DetectOS=5.1 does not seem to work. If it is supposed to be DetectOS=|5.1, then why are there so many DetectOS=6.0 entries in Winapp2.ini ? :wacko:
Share this post
Link to post
DetectOS=5.1 means it'll only appear on Windows XP or later
DetectOS=|5.1 means it'll only appear on Windows XP
DetectOS=5.1| means it'll only appear on Windows XP or earlier
I THINK.
Share this post
Link to post
ah HA! Thanks for the quick response/clarification.
Suggest that the explanation be included in your Spoiler SHOW for how to make winapp2.ini entries.
Share this post
Link to post
Really? I haven't experienced an issue with deleting the installers, strange.
This is the section I'm referring to:
[Chrome Installer*]
LangSecRef=3029
DetectFile=%LocalAppData%\Google\Chrome
Default=False
FileKey1=%LocalAppData%\Google\Chrome\Application\*\Installer|*.*|REMOVESELF
I don't know if its just me, I haven't tested it on other systems, but it was enough of a problem I felt I should logon here and mention it. I'm using Chrome 22.0.1229.94 m on Win7 SP1 x64. When I ran CCleaner w/ Chrome installer delete selected, it got stuck on x.92 and Chrome kept prompting me to update over and over. Finally, I just went and downloaded the installer again and updated manually and problem solved.
But, IMO, it should have a Warning= line added to the entry with something like
Warning=Running this may remove Chrome's ability to automatically update to future versions
Share this post
Link to post
They way those expletive | are all over in CCleaner is enough to rip our hair out over.
Share this post
Link to post
[Chrome Installer*]
LangSecRef=3029
Default=False
it seems to me this entry should be removed if this is what occurs. (opinion)
Share this post
Link to post
Good news everyone
I can now properly handle Windows 8 issues.
sidenote: I typed "hadnle" at least six times.
Share this post
Link to post
I would, but it'd be an awkward way to end our one night stand. I'd always just be "that guy" to Windows 8's future kids and friends, I never want to be that guy
Share this post
Link to post
Well, I'm not entirely sure. There are several other installers included in winapp2 that will delete installers and setup files, but they include a warning that the user should do so at their own risk.
Here are a couple examples
[Windows Live Messenger Setup Files*]
LangSecRef=3022
Detect=HKLM\SOFTWARE\Microsoft\Windows Live\Messenger
Warning=After running this, you will not be able to uninstall Windows Live Essentials components without downloading the installer again.
Default=False
FileKey1=%LocalLowAppData%\Microsoft\Windows Live\Setup|*.*|REMOVESELF
[Adobe Reader 10.0 Setup Files*]
LangSecRef=3021
Detect=HKCU\Software\Adobe\Acrobat Reader\10.0
Warning=This will prevent a repair installation. You have to download the installer for a reinstallation.
Default=False
FileKey1=%CommonAppData%\Adobe\ARM\Reader_10.*|*.*|REMOVESELF
FileKey2=%CommonAppData%\Adobe\Setup\{AC76BA86-7AD7-*-7B44-AA1000000001}|*.*|REMOVESELF
I think it should be up to the end user to decide what they want to remove, as long as they are given proper notice of what the repercussions will be if they do delete these files.
On another note, I would like to see if anyone else encounters the same difficulties as I did when using the Chrome Install deleter option w/in CCleaner + winapp2 to confirm its not just me or it could have been some other problem.
Thanks,
pogue
Share this post
Link to post
Windows is the finicky type though, she'd only call you one of her "End Users". :lol:
Share this post
Link to post
I have a major issue with Windows 8.
Microsoft has zero rights to claim current protection by "PENDING intellectual property rights"
Share this post
Link to post
The trademarks may still be pending, but copyright is automatically applied to any creative work. Therefore their intellectual property is protected.
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
Loading...
