CCleaner Community Forums
Winapp2.ini
Winapp2.ini additions
NEW ENTRY
[CyberLink PhotoDirector 4*]
LangSecRef=3023
Detect1=HKLM\SOFTWARE\CyberLink\PhotoDirector4
Detect2=HKLM\SOFTWARE\Wow6432Node\CyberLink\PhotoDirector4
Default=False
FileKey1=%CommonAppData%\CyberLink\Downloader|*.*
FileKey2=%Pictures%\PhotoDirector\4.0\*|*.*|RECURSE
ExcludeKey1=FILE|%Pictures%\PhotoDirector\4.0\*|*.phd
Share this post
Link to post
are %commonappdata% and %pictures% something special that winapp2.ini can handle or are they new system variable I'm not familar with?
Share this post
Link to post
They're built into ccleaner
CommonAppData points to \all users\application data and \program data\
pictures points to my pictures
Share this post
Link to post
NEW ENTRY
[MAGIX Video Pro X4*]
LangSecRef=3023
Detect=HKCU\Software\MAGIX AG\Videodeluxe18_pro
Default=False
FileKey1=%Documents%\MAGIX\Video_Pro_X4\AudioTemp|*.*|RECURSE
Share this post
Link to post
NEW
[captcha brotherhood*]
LangSecRef=3024
DetectFile=%LocalAppData%\Captcha_Brotherhood
Default=False
FileKey1=%LocalAppData%\Captcha_Brotherhood|solver_logFile.txt
PS: No option to add portable programs like Cryptload?
Share this post
Link to post
as portable can be found anywhere and (usually) have no registry keys, it is not possible to create general public cleaning rules for portable programs. As my portable drive is always the same letter on my computer I can run my own portable app cleaning, however my rules wouldn't work for you.
Share this post
Link to post
Though we can make rules for the default installation, and you can create a symlink to the portable one. :) That's what I do for several things on my system, namely Steam and Origin
Share this post
Link to post
PortableApps.com software installed in the default location "C:\PortableApps" is what I'd call feasible to make cleaners for. As long as it's on drive C: it can be detected using DetectFile.
Share this post
Link to post
Would it be safe to assume it defaults to %SystemDrive%? I always run my system on C, so I wouldn't be able to check.
Share this post
Link to post
PortableApps installer defaulting to it? I really don't know if they're using some variable to find the OS drive, or if it's just some bog standard assume it's drive C.
Share this post
Link to post
I see no harm in making filekeys/regkeys for C:\, though it's different from the rest of the file format. :)
Share this post
Link to post
note there's a great difference between "portable programs" and "portableapps" (besides that one of them is a brand name ;) ) Most applications from PortableApps (John Haller) cleanup after themselves after Exit (and keep the data in the application's folder)
as far as PortableApps programs Portable Firefox and Portable Chrome, there is a solution in custom location. As I said, any other portable programs would depend on the user. Yes most portable programs have an installed version, and thus could be converted within a personal winapp2, for PortableApps most already have entries and (until custom location is universal) can be made by a users via ccleaner's export command. Imho inclusion of PA should not happen unless there's no corresponding internal clean
Share this post
Link to post
any chance the first post in this thread can be updated to include all the environment variables CCleaner recognises?
Share this post
Link to post
Sure thing. Give me a minute.
I've added a few more of the CCleaner specific ones, I think I've got them all in there now.
Share this post
Link to post
Great, got them, thanks for that.
Share this post
Link to post
Should that possibly be renamed, since it's also for FileKey?
DetectFile paths
To:
DetectFile and FileKey paths
Edit:
These are missing from it, that is if CCleaner supports them:
%SystemDirectory%
%SystemDirectory32%
%SystemDirectory64%
%RootDir%
Does this still work? If so it's identical to %HomeDrive% and %SystemDrive%
One question:
Is it: %Videos% (plural), or %Video% ?
Edited by Andavari
Share this post
Link to post
NEW
[phase-6 logs*]
LangSecRef=3021
DetectFile=%UserProfile%\.phase-6
Default=False
FileKey1=%UserProfile%\.phase-6\logs|phase-6.log|REMOVESELF
Share this post
Link to post
Register a new account
Sign in
