CCleaner Community Forums
Winapp2.ini additions
  • Moderators
don't get me wrong, it may be safe (can you ask the dev of enhancer in private if he added and knows anything about it, he may have added it).
Link to post
I handle all of the additions and maintenance on the file, and I pull them from emails (both sent to me and to shane), some google docs forms, and a few other places. I don't quite recall where this one came from, but I'll do some research on the cache itself and see if I can turn up anything on its safety.
Link to post
NEW ENTRY
[imgBurn More*]
LangSecRef=3021
Detect=HKCU\Software\ImgBurn
Default=False
RegKey1=HKCU\Software\ImgBurn|FILELOCATIONS_ProjectFiles
RegKey2=HKCU\Software\ImgBurn|FILELOCATIONS_QueueFiles
RegKey3=HKCU\Software\ImgBurn|ISOREAD_RecentFiles_Destination
RegKey4=HKCU\Software\ImgBurn|ISOREAD_RecentFolders_Destination
Link to post
[Connectify Hotspot*]
LangSecRef=3022
Detect=HKLM\SOFTWARE\Connectify
Default=False
FileKey1=%ProgramFiles%\Connectify|install.log
FileKey2=%ProgramFiles%\Connectify|Credits.html
FileKey3=%ProgramFiles%\Connectify\Installer|*.*|REMOVESELF
FileKey4=%ProgramFiles%\Connectify\Portal|*.*|REMOVESELF
FileKey5=%CommonAppData%\Connectify\logs|Administrator.ui.log
FileKey6=%CommonAppData%\Connectify\cache|UsageCheck.time
Link to post
Thanks
But I am not seeing this filekey in included in the AVG entry for 3.24. May need to be readded to winapp2.ini
[AVG AntiVirus Installer*]
LangSecRef=3024
Detect=HKLM\SOFTWARE\AVG
Default=False
FileKey1=%CommonAppData%\AVG*\SetupBackup|*.*
Link to post
[CloudShark Plugin for Wireshark*]
LangSecRef=3024
DetectFile=%AppData%\Wireshark\plugins\cloudshark
Default=False
FileKey1=%AppData%\Wireshark\plugins\cloudshark\tmp|*.*
I can not figure out what is in this folder even after using the plugin in Wireshark. So you decide if to add or not to add.
Link to post
Thanks
LangSecRef=3024
Default=False
[AVG AntiVirus 2013]
ID=2313
LangSecRef=3024
Detect=HKLM\SOFTWARE\AVG\AVG2013
Default=True
FileKey1=%CommonAppData%\AVG2013\Log|*.log
FileKey2=%CommonAppData%\AVG2013\scanlogs|*.log
FileKey3=%CommonAppData%\AVG2013\Log|history.xml
FileKey4=%CommonAppData%\AVG2013\update\backup|*.*
FileKey5=%CommonAppData%\AVG2013\Emc\Log|*.log
FileKey6=%CommonAppData%\AVG2013\IDS\config|*List.zip.bak
FileKey7=%CommonAppData%\AVG2013\IDS\profile|globalLoadable.bak
FileKey8=%CommonAppData%\AVG2013\Temp|*.tmp
I realize this doesn't cover all of the versions, I will add it back if you guys want
Link to post
It was two different folders. But I'm not seeing the update\backup folder at all for AVG2013 :blink:. Looks like the update backups are stored in the SetupBackup folder now.
Edit: I didn't pay much attention to AVG2013 files, was used to 2011 and 2012 all using the same locations but it looks like they moved a few things around
tracked them all down
they moved the log and temp folders to %LocalAppData% and removed two folders: scanlogs & Emc
[AVG AntiVirus 2013*]
ID=2313
LangSecRef=3024
Default=True
FileKey1=%LocalAppData%\AVG2013\log|*.log
FileKey2=%LocalAppData%\AVG2013\temp|*.tmp
FileKey4=%CommonAppData%\AVG2013\SetupBackup|*.*
FileKey5=%CommonAppData%\AVG2013\IDS\config|*List.zip.bak
FileKey6=%CommonAppData%\AVG2013\IDS\profile|globalLoadable.bak
FileKey7=%ProgramFiles%\AVG\AVG2013|updatecomps.bak
FileKey8=%ProgramFiles%\AVG\AVG2013|*.old
Link to post
Also, I recommend that the section be changed on the new [NVIDIA Updates*] from LangSecRef=3021 to LangSecRef=3023 so that it matches the other Nvidia entries.
In addition, I'm pretty sure there is an error in [Nvidia Graphics Driver Installation Files*]. FileKey2=%ProgramFiles%\NVIDIA Corporation\Install2|*.*|RECURSE should be FileKey2=%ProgramFiles%\NVIDIA Corporation\Installer2|*.*|RECURSE
Link to post
[GNU Cache*]
Appears but I don't have any of the FileKey folders....
[McAfee AntiVirus]
I have three empty folders in
C:\Documents and Settings\All Users\Application Data\McAfee\MCLOGS\Common
They all look to be Java nstall folder named.
Link to post
  • Moderators
re gnu it's the detect key that makes them, is that what you mean
Link to post
Register a new account
Sign in
