CCleaner Community Forums
Winapp2.ini additions
qsdewa, on 17 September 2012 - 07:58 PM, said:
Cleaning rules for DVDVideoSoft Free Studio ( http://dvdvideosoft.com/ ). But I am not so advanced with the rules so I don't know so much about them
[DVDVideoSoft*]
LangSecRef=3024 (maybe)
Detect/DetectFile=
Default=False
FileKey/RegKey
All the folders I found are in %AppData%\DVDVideoSoft
There are
\backup
\installation_logs
\logs
\setup
\"program's name"\History
Nergal, on 17 September 2012 - 08:21 PM, said:
you need to provide an actual detect (usually a registry key). Something that's always there
you need to provide an actual set of things to clean. If you need to, experiment (move things out of the folder see if it breaks the program, or it's ability to update).
What exactly is it you want this entry to achieve? What junk is left behind? Does the program keep a list of recently opened or saved files? Find out where those are stored
[DVDVideoSoft*]
LangSecRef=3021
DetectFile=%AppData%\DVDVideoSoft or HKCU\Software\DVDVideoSoft
Default=False
FileKey1=%AppData%\DVDVideoSoft\backup|*.*
FileKey2=%AppData%\DVDVideoSoft\installation_logs|*.*
FileKey3=%AppData%\DVDVideoSoft\logs|*.*
FileKey4=%AppData%\DVDVideoSoft\setup|*.*
FileKey5=%AppData%\DVDVideoSoft\*\History|*.*
Hope this is right now.
PS: Don't You remove old posts which have been worked into winapp2.ini?
Link to post
nope only spam posts are ever removed
I am no nope. I just wanted to ask because on other forums old posts will be removed after they have been worked into the software so the thread won't get so big and cluttered.
Link to post
"nope" is not an insult of any kind if that's what you thought it was. It simply means: No
OOOHHHH...
Than I am sorry I thought that. My german English is just too bad.
So now this ended up in spamming I think.^^ Sorry for that.
Link to post
I am no nope.
:lol: I just about doubled over laughing. Reminds me of a quote from family guy:
Meg: "This is so ironic!"
Peter: "Meg! Your mother is not an iron!"
That being said, I went ahead and made these:
[DVDVideoSoft Backup*]
LangSecRef=3024
Detect=HKCU\Software\DVDVideoSoft
Default=False
FileKey1=%AppData%\DVDVideoSoft\Backup|*.*|RECURSE
[DVDVideoSoft History*]
LangSecRef=3024
Default=False
FileKey1=%AppData%\DVDVideoSoft\*\History|*.*|RECURSE
[DVDVideoSoft Logs*]
LangSecRef=3024
Default=False
FileKey1=%AppData%\DVDVideoSoft\Logs|*.*|RECURSE
FileKey2=%AppData%\DVDVideoSoft\installation_logs|*.*|RECURSE
Link to post
LangSecRef=3024
Default=False
LangSecRef=3024
Default=False
LangSecRef=3024
Default=False
Works fine. Thank You.
Link to post
I would recommend to rename [Gimp More*] to [GIMP 2.8 More*] because of the following reasons:
  1. the name GIMP is always written with capitals
  2. the entry will only show up if GIMP 2.8 is installed
  3. there is an entry called GIMP 2.8 by default, so it would be clearer that this two entires belong together
Greets
Link to post
Modification to TuneUp Utilities Reg Defrag Cleanup for TuneUp Utilities 2013. Modified name and added Detect3.
[TuneUp Utilities 2011/12/13 Reg Defrag Cleanup*]
LangSecRef=3024
Detect1=HKCU\Software\TuneUp\Utilities\10.0
Detect2=HKCU\Software\TuneUp\Utilities\12.0
Detect3=HKCU\Software\TuneUp\Utilities\13.0
Default=False
FileKey1=%WinDir%\System32\config|SECURITY_tureg_old
FileKey2=%WinDir%\System32\config|SOFTWARE_tureg_old
FileKey3=%WinDir%\System32\config|SYSTEM_tureg_old
FileKey4=%WinDir%\System32\config|DEFAULT_tureg_new.LOG*
FileKey5=%WinDir%\System32\config|SAM_tureg_new.LOG*
FileKey6=%WinDir%\System32\config|SECURITY_tureg_new.LOG*
FileKey7=%WinDir%\System32\config|SOFTWARE_tureg_new.LOG*
FileKey8=%WinDir%\System32\config|SYSTEM_tureg_new.LOG*
FileKey9=%WinDir%\System32\config|DEFAULT_tureg_old
FileKey10=%WinDir%\System32\config|SAM_tureg_old
FileKey11=%WinDir%\ServiceProfiles\LocalService|NTUSER.DAT_tureg_old
FileKey12=%WinDir%\ServiceProfiles\LocalService|NTUSER.DAT_tureg_new.LOG*
FileKey13=%WinDir%\ServiceProfiles\NetworkService|NTUSER.DAT_tureg_old
FileKey14=%WinDir%\ServiceProfiles\NetworkService|NTUSER.DAT_tureg_new.LOG*
FileKey15=%WinDir%\System32\config|COMPONENTS_tureg_old
FileKey16=%WinDir%\System32\config|COMPONENTS_tureg_new.LOG*
FileKey17=%LocalAppData%\Microsoft\Windows|USRCLASS.DAT_tureg_old
FileKey18=%UserProfile%|NTUSER.DAT_tureg_new.LOG*
FileKey19=%UserProfile%|NTUSER.DAT_tureg_old
FileKey20=%SystemDrive%\Boot|BCD_tureg_new.LOG*
FileKey21=%SystemDrive%\Boot|BCD_tureg_old
FileKey22=%LocalAppData%\Microsoft\Windows|USRCLASS.DAT_tureg_new.LOG*
Link to post
Just to make 100% sure we get to that magic 1000 :rolleyes:
New:
[MS Visual Basic 2010 Express MRU*]
LangSecRef=3021
Detect1=HKCU\Software\Microsoft\VBExpress\10.0
Default=False
RegKey1=HKCU\Software\Microsoft\VBExpress\10.0\FileMRUList
RegKey2=HKCU\Software\Microsoft\VBExpress\10.0\ProjectMRUList
[MS Visual Basic 2010 Express Search History*]
LangSecRef=3021
Default=False
RegKey1=HKCU\Software\Microsoft\VBExpress\10.0\Find|Find 0
RegKey2=HKCU\Software\Microsoft\VBExpress\10.0\Find|Find 1
RegKey3=HKCU\Software\Microsoft\VBExpress\10.0\Find|Find 2
RegKey4=HKCU\Software\Microsoft\VBExpress\10.0\Find|Find 3
RegKey5=HKCU\Software\Microsoft\VBExpress\10.0\Find|Find 4
RegKey6=HKCU\Software\Microsoft\VBExpress\10.0\Find|Find 5
RegKey7=HKCU\Software\Microsoft\VBExpress\10.0\Find|Find 6
RegKey8=HKCU\Software\Microsoft\VBExpress\10.0\Find|Find 7
RegKey9=HKCU\Software\Microsoft\VBExpress\10.0\Find|Find 8
RegKey10=HKCU\Software\Microsoft\VBExpress\10.0\Find|Find 9
RegKey11=HKCU\Software\Microsoft\VBExpress\10.0\Find|Find 10
RegKey12=HKCU\Software\Microsoft\VBExpress\10.0\Find|Find 11
RegKey13=HKCU\Software\Microsoft\VBExpress\10.0\Find|Find 12
RegKey14=HKCU\Software\Microsoft\VBExpress\10.0\Find|Find 13
RegKey15=HKCU\Software\Microsoft\VBExpress\10.0\Find|Find 14
RegKey16=HKCU\Software\Microsoft\VBExpress\10.0\Find|Find 15
RegKey17=HKCU\Software\Microsoft\VBExpress\10.0\Find|Find 16
RegKey18=HKCU\Software\Microsoft\VBExpress\10.0\Find|Find 17
RegKey19=HKCU\Software\Microsoft\VBExpress\10.0\Find|Find 18
RegKey20=HKCU\Software\Microsoft\VBExpress\10.0\Find|Find 19
RegKey21=HKCU\Software\Microsoft\VBExpress\10.0\Find|Replace 0
RegKey22=HKCU\Software\Microsoft\VBExpress\10.0\Find|Replace 1
RegKey23=HKCU\Software\Microsoft\VBExpress\10.0\Find|Replace 2
RegKey24=HKCU\Software\Microsoft\VBExpress\10.0\Find|Replace 3
RegKey25=HKCU\Software\Microsoft\VBExpress\10.0\Find|Replace 4
RegKey26=HKCU\Software\Microsoft\VBExpress\10.0\Find|Replace 5
RegKey27=HKCU\Software\Microsoft\VBExpress\10.0\Find|Replace 6
RegKey28=HKCU\Software\Microsoft\VBExpress\10.0\Find|Replace 7
RegKey29=HKCU\Software\Microsoft\VBExpress\10.0\Find|Replace 8
RegKey30=HKCU\Software\Microsoft\VBExpress\10.0\Find|Replace 9
RegKey31=HKCU\Software\Microsoft\VBExpress\10.0\Find|Replace 10
RegKey32=HKCU\Software\Microsoft\VBExpress\10.0\Find|Replace 11
RegKey33=HKCU\Software\Microsoft\VBExpress\10.0\Find|Replace 12
RegKey34=HKCU\Software\Microsoft\VBExpress\10.0\Find|Replace 13
RegKey35=HKCU\Software\Microsoft\VBExpress\10.0\Find|Replace 14
RegKey36=HKCU\Software\Microsoft\VBExpress\10.0\Find|Replace 15
RegKey37=HKCU\Software\Microsoft\VBExpress\10.0\Find|Replace 16
RegKey38=HKCU\Software\Microsoft\VBExpress\10.0\Find|Replace 17
RegKey39=HKCU\Software\Microsoft\VBExpress\10.0\Find|Replace 18
RegKey40=HKCU\Software\Microsoft\VBExpress\10.0\Find|Replace 19
Mods:
[Amnesia - The Dark Descent*] change LangSecRef to Section=Games
[And Yet It Moves*] change LangSecRef to Section=Games
[bIT.TRIP RUNNER*] change LangSecRef to Section=Games
[Cave Story+*] change LangSecRef to Section=Games
[Cogs*] change LangSecRef to Section=Games
[Crayon Physics Deluxe*] change LangSecRef to Section=Games
[Gratuitous Space Battles*] change LangSecRef to Section=Games
[Osmos (Logs)*] change LangSecRef to Section=Games
[sanctum*] change LangSecRef to Section=Games
[Terraria*] change LangSecRef to Section=Games
:o Looks like I skipped a lot of games :wacko:
:P
Link to post
It looks to me like Avira More* needs to be deleted because it is covered in winapp.ini
winapp.ini Avira Desktop code
[AntiVir Desktop]
ID=2138
LangSecRef=3024
Detect=HKLM\SOFTWARE\Avira\AntiVir Desktop
Default=True
FileKey1=%CommonAppData%\Avira\AntiVir Desktop\TEMP|*.*
FileKey2=%CommonAppData%\Avira\Antivir Desktop\BACKUP\FAILSAFE\*.tmp
FileKey3=%CommonAppData%\Avira\AntiVir Desktop|*.old
FileKey4=%CommonAppData%\Avira\AntiVir Desktop|*.tmp
FileKey5=%ProgramFiles%\Avira\AntiVir Desktop|*.old
FileKey6=%ProgramFiles%\Avira\AntiVir Desktop|*.tmp
FileKey7=%ProgramFiles%\Avira\AntiVir Desktop\FAILSAFE|*.tmp
FileKey8=%CommonAppData%\Avira\AntiVir Desktop\LOGFILES|*.*
Winapp2.ini Avira More* code
[Avira More*]
LangSecRef=3024
Default=False
FileKey1=%CommonAppData%\Avira|*.tmp|RECURSE
FileKey2=%CommonAppData%\Avira|*.log|RECURSE
FileKey3=%ProgramFiles%\Avira|*.tmp|RECURSE
FileKey4=%ProgramFiles%\Avira|*.log|RECURSE
FileKey5=%ProgramFiles%\Avira GmbH|*.log|RECURSE
Avira More* looks like it is outdated and applies to old versions of Avira. It certainly does not apply to Avira Internet Security 2010/11/12/13
Link to post
MODIFIED ENTRY
Changed the entry name from [Windows Live Setup Logs*] to [Windows Live Setup Files*]
Lots of temp files here with .tmp ext.
LangSecRef=3022
Detect=HKLM\SOFTWARE\Microsoft\Windows Live
Default=False
FileKey1=%LocalAppData%\Microsoft\WLSetup|*.*|RECURSE
FileKey2=%CommonAppData%\Microsoft\WLSetup|*.*|RECURSE
Link to post
NEW ENTRIES:
[borderlands 2*]
Section=Games
DetectFile=%Documents%\My Games\Borderlands 2
Default=False
FileKey1=%Documents%\My Games\Borderlands 2\WillowGame\Logs|*.*
[Faster Than Light*]
LangSecRef=Games
DetectFile=%Documents%\My Games\FasterThanLight
Default=False
FileKey1=%ProgramFiles%\Steam\steamapps\common\FTL Faster Than Light\crashlogs|*.*
[Torchlight 2*]
LangSecRef=Games
Detect=HKLM\SOFTWARE\Runic Games\Torchlight II
Default=False
FileKey1=%Documents%\My Games\Runic Games\Torchlight 2\logs|*.*
Link to post
Recommended modification to TuneUp Utilities*. Changed name and added warning messages.
[TuneUp Utilities (Backups)*]
LangSecRef=3024
Detect=HKCU\Software\TuneUp
Warning=This removes ALL backups created by TuneUp Utilities during its registry and other cleaning activities.
Default=False
FileKey1=%AppData%\TuneUp Software\*\Backups|*.rcb
Link to post
Thank you for the update!
I do not know whether this was already discussed but the entry FlashGot in the section Firefox/Mozilla shows up although it is not installed.
If Stylish is also a Firefox add-on, its entry has this bug, too. I would recommend to define the detection files of this two entries more precise.
Link to post
Register a new account
Sign in
