Moderators Nergal Posted September 27, 2012 Moderators Share Posted September 27, 2012 So am I right in saying that Piriform themselves don't issue an 'official' winapp2 file, but that this forum are the 'keepers' of the file and update/amend it based of member suggestions/feedback yes, you are correct. And many entries are then picked up by the developers and added to the program ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Moderators mta Posted September 27, 2012 Moderators Share Posted September 27, 2012 I know how a big winapp2.ini file effects the speed of loading CCleaner, do you know if that's still the same once those entries are addedd to the program? And once added, does winapp2.ini (the person) then remove the entries from winapp2.ini (the file)? (As someone called him earlier in this thread, maybe we need a naming convention, something like winapp2.ini(hero) and winapp2.ini(file) to reflect the difference) Backup now & backup often.It's your digital life - protect it with a backup.Three things are certain; Birth, Death and loss of data. You control the last. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted September 27, 2012 Moderators Share Posted September 27, 2012 1st question: I think (at a guess) that it doesn't (as much) slow it down when they're built in because the program isn't reading an external file 2nd question: yes he does. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Winapp2.ini Posted September 27, 2012 Author Share Posted September 27, 2012 I know how a big winapp2.ini file effects the speed of loading CCleaner, do you know if that's still the same once those entries are addedd to the program? And once added, does winapp2.ini (the person) then remove the entries from winapp2.ini (the file)? (As someone called him earlier in this thread, maybe we need a naming convention, something like winapp2.ini(hero) and winapp2.ini(file) to reflect the difference) From the current update, these changes should be of interest to your section question. As for my forum username.. probably a poor choice in hindsight! Removed in this version: [CoolNovo - Cache*] LangSecRef=3029 DetectFile1=%AppData%\MapleStudio\ChromePlus\Application\Chrome.exe DetectFile2=%LocalAppData%\MapleStudio\ChromePlus\Application\Chrome.exe Default=False FileKey1=%AppData%\MapleStudio\ChromePlus\User Data\Default\Cache|*.*|RECURSE - Added to CCleaner [CoolNovo - Cookies*] LangSecRef=3029 DetectFile1=%AppData%\MapleStudio\ChromePlus\Application\Chrome.exe DetectFile2=%LocalAppData%\MapleStudio\ChromePlus\Application\Chrome.exe Default=False FileKey1=%AppData%\MapleStudio\ChromePlus\User Data\Default|*Cookies|RECURSE - Added to CCleaner [CoolNovo - Form Data*] LangSecRef=3029 DetectFile1=%AppData%\MapleStudio\ChromePlus\Application\Chrome.exe DetectFile2=%LocalAppData%\MapleStudio\ChromePlus\Application\Chrome.exe Default=False FileKey1=%AppData%\MapleStudio\ChromePlus\User Data\Default|Web Data|RECURSE - Added to CCleaner [CoolNovo - History*] LangSecRef=3029 DetectFile1=%AppData%\MapleStudio\ChromePlus\Application\Chrome.exe DetectFile2=%LocalAppData%\MapleStudio\ChromePlus\Application\Chrome.exe Default=False FileKey1=%AppData%\MapleStudio\ChromePlus\User Data\Default|*History*|RECURSE FileKey2=%AppData%\MapleStudio\ChromePlus\User Data\Default|Thumbnails|RECURSE FileKey3=%AppData%\MapleStudio\ChromePlus\User Data\Default|Visited Links|RECURSE - Added to CCleaner [CoolNovo - Session Restore*] LangSecRef=3029 DetectFile1=%AppData%\MapleStudio\ChromePlus\Application\Chrome.exe DetectFile2=%LocalAppData%\MapleStudio\ChromePlus\Application\Chrome.exe Default=False FileKey1=%AppData%\MapleStudio\ChromePlus\User Data\Default|Current*|RECURSE FileKey2=%LocalAppData%\Chromium\User Data\Default|Last*|RECURSE - Added to CCleaner [Temp Files*] ID=2013 LangSecRef=3029 Detect=HKCU\Software\Chromium DetectFile1=%LocalAppData%\Google\Chrome\Application\chrome.exe DetectFile2=%ProgramFiles%\Google\Chrome\Application\chrome.exe DetectFile3=%LocalAppData%\Flock\Application\flock.exe DetectFile4=%ProgramFiles%\Flock\Application\flock.exe DetectFile5=%LocalAppData%\Google\Chrome SxS\Application\chrome.exe DetectFile6=%ProgramFiles%\Google\Chrome SxS\Application\chrome.exe DetectFile7=%LocalAppData%\SRWare Iron\iron.exe DetectFile8=%ProgramFiles%\SRWare Iron\iron.exe DetectFile9=%ProgramFiles%\Chromium\chrome.exe DetectFile10=%LocalAppData%\Chromium\chrome.exe DetectFile11=%ProgramFiles%\Chromium\Application\chrome.exe DetectFile12=%LocalAppData%\Chromium\Application\chrome.exe DetectFile13=%AppData%\ChromePlus\chrome.exe DetectFile14=%LocalAppData%\RockMelt\Application\rockmelt.exe DetectFile15=%ProgramFiles%\RockMelt\Application\rockmelt.exe Default=False FileKey1=%LocalAppData%\Google\Chrome|*.tmp|RECURSE FileKey2=%LocalAppData%\Flock|*.tmp|RECURSE FileKey3=%LocalAppData%\Google\Chrome SxS|*.tmp|RECURSE FileKey4=%LocalAppData%\SRWare Iron|*.tmp|RECURSE FileKey5=%LocalAppData%\Chromium|*.tmp|RECURSE FileKey6=%LocalAppData%\Chrome Plus|*.tmp|RECURSE FileKey7=%LocalAppData%\Rockmelt|*.tmp|RECURSE - Added to CCleaner winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Andavari Posted September 28, 2012 Moderators Share Posted September 28, 2012 Don't leave me hanging! What was it? It was for Windows Explorer Shell Extensions. As for my forum username.. probably a poor choice in hindsight! I think it was brilliant myself, you chose that name all those years ago, and then made the file so much better by injecting it with new life keeping it active. Link to comment Share on other sites More sharing options...
siliconman01 Posted September 28, 2012 Share Posted September 28, 2012 winapp2.ini, please consider removing the code below. it is not really the proper or best way to handle the ctfmon.exe running issue. [ctfmon.exe (disable startup)*] langsecref=3021 detect1=hkcu\software\microsoft\office detect2=hklm\software\microsoft\office default=false warning=this will only temporarily disable the microsoft office installed file ctfmon.exe from starting with windows. ctfmon.exe is known to cause severe system slow downs and can be permanently disabled using the free ctfmon-remover: http://www.gerhard-schlager.at/en/projects/ctfmonremover/ regkey1=hklm\software\microsoft\windows\currentversion\run|ctfmon.exe regkey2=hkcu\software\microsoft\windows\currentversion\run|ctfmon.exe regkey3=hku\.default\software\microsoft\windows\currentversion\run|ctfmon.exe Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted September 28, 2012 Moderators Share Posted September 28, 2012 winapp2.ini, please consider removing the code below. it is not really the proper or best way to handle the ctfmon.exe running issue. [ctfmon.exe (disable startup)*] langsecref=3021 detect1=hkcu\software\microsoft\office detect2=hklm\software\microsoft\office default=false warning=this will only temporarily disable the microsoft office installed file ctfmon.exe from starting with windows. ctfmon.exe is known to cause severe system slow downs and can be permanently disabled using the free ctfmon-remover: http://www.gerhard-schlager.at/en/projects/ctfmonremover/ regkey1=hklm\software\microsoft\windows\currentversion\run|ctfmon.exe regkey2=hkcu\software\microsoft\windows\currentversion\run|ctfmon.exe regkey3=hku\.default\software\microsoft\windows\currentversion\run|ctfmon.exe +1 ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Winapp2.ini Posted September 28, 2012 Author Share Posted September 28, 2012 will do. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Andavari Posted September 29, 2012 Moderators Share Posted September 29, 2012 The original coder of ctfmon.exe is attempting to stop ctfmon.exe from starting up on system reboot. I originally wrote it, and the Warning= section was there to give a clue how to properly disable it using CTFMON-Remover, well at least that works in WinXP: Warning=This will only temporarily disable the Microsoft Office installed file ctfmon.exe from starting with Windows. ctfmon.exe is known to cause severe system slow downs and can be permanently disabled using the free CTFMON-Remover: http://www.gerhard-schlager.at/en/projects/ctfmonremover/ Link to comment Share on other sites More sharing options...
SMalik Posted September 29, 2012 Share Posted September 29, 2012 new entries [windows live movie maker*] langsecref=3023 detect=hkcu\software\microsoft\windows live\movie maker default=false regkey1=hkcu\software\microsoft\windows live\movie maker|browseformusicdirectory regkey2=hkcu\software\microsoft\windows live\movie maker|browseforpicturesdirectory regkey3=hkcu\software\microsoft\windows live\movie maker|browseforprojectsdirectory regkey4=hkcu\software\microsoft\windows live\movie maker|rendertofiledirectory regkey5=hkcu\software\microsoft\windows live\movie maker|snapshotfiledirectory regkey6=hkcu\software\microsoft\windows live\movie maker\recent filekey1=%localappdata%\microsoft\windows live movie maker|*.*|recurse [windows live photo gallery*] langsecref=3023 detect=hkcu\software\microsoft\windows live\photo gallery default=false regkey1=hkcu\software\microsoft\windows live\photo gallery|galleryscopedfolders filekey1=%localappdata%\microsoft\windows live photo gallery|*.*|recurse why i am seeing everything here in lower case? Link to comment Share on other sites More sharing options...
Winapp2.ini Posted September 29, 2012 Author Share Posted September 29, 2012 forum bug winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
qsdewa Posted September 30, 2012 Share Posted September 30, 2012 [sUPERAntiSpyware Quarantine*] LangSecRef=3024 Detect=HKCU\SOFTWARE\SUPERAntiSpyware.com\SUPERAntiSpyware Default=False Warning=This will delete the files which SUPERAntiSpyware moved into quarantine. If you are not sure what this is about, uncheck this option. FileKey=%AppData%\SUPERAntiSpyware.com\SUPERAntiSpyware\Quarantine|*.* The quarantined files of SUPERAntiSpyware. It does not work for me at the moment but I can not figure out what I missed. Maybe someone knows. Link to comment Share on other sites More sharing options...
siliconman01 Posted September 30, 2012 Share Posted September 30, 2012 I honestly do not feel that winapp2.ini should be permitted to remove "quarantined" files of security programs. All security programs have their own option to remove one or all quarantined files. The potential of a CCleaner user deleting a false positive in quarantine by having winapp2.ini code such as {superantispyware quarantine*] check marked is pretty great in my opinion. Obviously this would prevent the user from returning a valid file (flagged as false positive) to its normal location. I feel the user should have to "think twice" by having to use the security program's option to empty quarantined files. Most security companies recommend that a quarantined file should not be dumped for at least a week. And I continue to feel that Piriform should fix the winapp.ini code for Malwarebytes so that it does NOT delete quarantined items. JMO... Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
Alan_B Posted September 30, 2012 Share Posted September 30, 2012 The quarantined files of SUPERAntiSpyware. It does not function for me at the moment but I can not figure out what I missed. Maybe someone knows. If you expect SUPERAntiSpyware to permit meddling with its special quarantine folder by CCleaner then you have a low opinion of SUPERAntiSpyware. Link to comment Share on other sites More sharing options...
pook1y7985 Posted September 30, 2012 Share Posted September 30, 2012 Additions [Jetclean Logs *] LangSecRef=3024 DetectFile=%ProgramFiles%\BlueSprig\JetClean\JetClean.exe Default=False FileKey1=%AppData%\BlueSprig\JetClean\Log|*.* [Jetclean Registry Backups *] LangSecRef=3024 DetectFile=%ProgramFiles%\BlueSprig\JetClean\JetClean.exe Default=False Warning="Deleting the backups will result in you being unable to undo any changes by Jetclean. Be sure you are okay with removing the backups!" FileKey1=%AppData%\BlueSprig\JetClean\Backup|*.reg Modifications Removed FileKey1 because I saw no such folder is created. It does not create user reports. Added Warning that this one actually removed your backups. [Auslogics Registry Cleaner Backups*] LangSecRef=3024 Detect=HKCU\Software\Auslogics\Registry Cleaner Default=False Warning="Deleting the backups will result in you being unable to undo any changes by Auslogics Registry Cleaner. Be sure you are okay with removing the backups! FileKey1=%AppData%\Auslogics\Rescue\Auslogics Registry Cleaner|*.rsc Link to comment Share on other sites More sharing options...
Winapp2.ini Posted September 30, 2012 Author Share Posted September 30, 2012 I think we agreed some 50 or 70 pages back that we wouldn't meddle with quarantines winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
APMichael Posted October 1, 2012 Share Posted October 1, 2012 Modified entry: (Fixed wrong path.) [sun Java Cache*] LangSecRef=3022 DetectOS=6.0 Detect=HKLM\SOFTWARE\JavaSoft\Java Runtime Environment Default=False FileKey1=%LocalLowAppData%\Sun\Java\Deployment\cache|*.*|RECURSE FileKey2=%LocalLowAppData%\Sun\Java\Deployment\SystemCache|*.*|RECURSE FileKey3=%WinDir%\System32\config\systemprofile\AppData\LocalLow\Sun\Java\Development\Cache|*.*|RECURSE FileKey4=%WinDir%\SysWOW64\config\systemprofile\AppData\LocalLow\Sun\Java\Development\Cache|*.*|RECURSE Link to comment Share on other sites More sharing options...
Winapp2.ini Posted October 1, 2012 Author Share Posted October 1, 2012 Thanks! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
pook1y7985 Posted October 2, 2012 Share Posted October 2, 2012 New Entry [Leapfrog Connect Cache *] LangSecRef=3021 DetectFile=%ProgramFiles%\LeapFrog\LeapFrog Connect\LeapFrogConnect.exe Default=False FileKey1=%CommonAppData%\Leapfrog\LeapFrog Connect\cache\*\http|*.* FileKey2=%CommonAppData%\Leapfrog\LeapFrog Connect\cache\*\https|*.* Filekey3=%CommonAppData%\Leapfrog\LeapFrog Connect\cache\*\prepared|*.* Filekey4=%CommonAppData%\Leapfrog\LeapFrog Connect\cache\*\cookies|*.* Filekey5=%CommonAppData%\Leapfrog\LeapFrog Connect\cache\*\data7\*\|*.* Filekey6=%CommonAppData%\Leapfrog\LeapFrog Connect\DownloadCache|*.* Link to comment Share on other sites More sharing options...
Winapp2.ini Posted October 2, 2012 Author Share Posted October 2, 2012 Thanks! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
nodles Posted October 2, 2012 Share Posted October 2, 2012 NEW ENTRY [DriveImage XML*] LangSecRef=3021 Detect=HKLM\SOFTWARE\Runtime Software\DIXML Default=False FileKey1=%ProgramFiles%\Runtime Software\DriveImage XML|log.txt Link to comment Share on other sites More sharing options...
ricktendo64 Posted October 2, 2012 Share Posted October 2, 2012 MountPoints2* deletes the custom %SystemDrive% icon and my BluRay description (says its a CD-Rom) in Windows 8, maybe a good idea to put a WARNING Before: After: Link to comment Share on other sites More sharing options...
qsdewa Posted October 2, 2012 Share Posted October 2, 2012 NEW [sUMo Log*] LangSecRef=3024 Detect=HKCU\Software\KC Softwares\SUMo Default=False FileKey1=%AppData%\KC Softwares\SUMo|*.log or FileKey1=%AppData%\KC Softwares\SUMo|SUMo.log PS: Should or shouldn't this ... thing be used? Link to comment Share on other sites More sharing options...
nodles Posted October 2, 2012 Share Posted October 2, 2012 PS: Should or shouldn't this ... thing be used? What thing? Dots? Link to comment Share on other sites More sharing options...
qsdewa Posted October 2, 2012 Share Posted October 2, 2012 What thing? Dots? No ^^, the code-thing like [Name*] LangSecRef= Detect/DetectFile= Default=False FileKey/RegKey Link to comment Share on other sites More sharing options...
