Winapp2.ini additions
Winapp2.ini
So Groove Music has been rebranded Media Player, I added fk9 and fk11, this will clear the recent media from the home tab.
[Groove Music/Media Player *]
LangSecRef=3031
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.ZuneMusic_8wekyb3d8bbwe
FileKey1=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\AC\AppCache|*.*|RECURSE
FileKey2=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\AC\INet*|*.*|RECURSE
FileKey3=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\AC\Microsoft\CLR_v4.0\UsageLogs|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE
FileKey6=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\AC\PRICache|*.*|RECURSE
FileKey7=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\AC\Temp|*.*|RECURSE
FileKey8=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\AC\TokenBroker\Cache|*.*|RECURSE
FileKey9=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\LocalCache\Image|*.*|RECURSE
FileKey10=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\LocalCache\PlayReady|*.*|RECURSE
FileKey11=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\LocalState|*.tmp;AppState.json*;*.db*
FileKey12=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\LocalState\Database\*|*.log
FileKey13=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\LocalState\ImageCache|*.*|RECURSE
FileKey14=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\LocalState\ImageRetrievalFailure|*.*|RECURSE
FileKey15=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\LocalState\ImageStore|*.*|RECURSE
FileKey16=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\LocalState\navigationHistory|*.*|RECURSE
FileKey17=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\LocalState\PlayReady|*.*|RECURSE
FileKey18=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\TempState|*.*|RECURSE
RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.ZuneMusic_8wekyb3d8bbwe\SearchHistory
Link to comment
  • 2 weeks later...
I think the entries in "winapp.ini" for "REAL Player" need some (more) "tweaking" because it seems CC doesn't clean out some special folders used by REAL Player. Perhaps this is a "Permissions issue" ?
When I went through "Winapp.ini" I came across some things that raised some question marks. What are the target folders of 1) "%Appdata%" 2) "%LocalAppdata%" and 3) "%CommonAppData%" ?
I assume "%LocalAppdata%" points to the folder "Local" under "AppData" ? But the 2 other variables remain a mystery for me. Or are these only meant for Windows 10 and 11 ?
System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc
A discussion always stimulates the braincells !!!
Link to comment
- That was very usefull information. Seems the entries for Real Player are good after all.
- I also saw the following "\real*player\". Is this asterisk a typo ? Or has this been done deliberately ? Does CCleaner allow that syntax ?
Link to comment
24 minutes ago, Willy2 said:
... - I also saw the following "\real*player\". Is this asterisk a typo ? Or has this been done deliberately ? Does CCleaner allow that syntax ?
No, the asterisk is not a typo. It is used as a wildcard. Since the folder name differs for different versions of Real Player, the wildcard can be used to clean up all versions with only one FileKey.
Link to comment
6 hours ago, 212eta said:
Winapp2.ini
Has not been updated since June 15, 2022.
Is it normal? :o
There's a more recent revision with a substantial number of large changes last posted in July, I'm hoping to find time very soon to finish the remaining work on winapp2ool required to pivot to distributing this version. Apologies for the large delay, midway through this project very many real-life things cropped up which prevented me from working on it for about 2.5 months.
relevant github PR: https://github.com/MoscaDotTo/Winapp2/pull/895
my current local copy (dated 220718 but this isn't accurate) diff vs 220615: https://github.com/MoscaDotTo/Winapp2/files/9786452/diff.txt
diff.txt is best viewed with a monowidth font
v220717 (most recent available on github): https://raw.githubusercontent.com/MoscaDotTo/Winapp2/Branch1/Winapp2.ini
Link to comment
  • 1 month later...
Modified entry:  [Cyberlink PowerDVD *]
Added FileKey1
[CyberLink PowerDVD *]
LangSecRef=3023
Detect1=HKCU\Software\CyberLink\PowerDVD14
Detect2=HKCU\Software\CyberLink\PowerDVD15
Detect3=HKCU\Software\CyberLink\PowerDVD16
Detect4=HKCU\Software\CyberLink\PowerDVD17
Detect5=HKCU\Software\CyberLink\PowerDVD18
Detect6=HKCU\Software\CyberLink\PowerDVD19
Detect7=HKCU\Software\CyberLink\PowerDVD20
Detect8=HKCU\Software\CyberLink\PowerDVD21
Detect9=HKCU\Software\CyberLink\PowerDVD22
FileKey1=%AppData%\CyberLink\Webview|*.old|RECURSE
FileKey2=%CommonAppData%\Cyberlink\Evoparser|*.xml
FileKey3=%CommonAppData%\SUPPORTDIR\*|*.log
FileKey4=%LocalAppData%\Cyberlink\DigitalHome|*.log|RECURSE
FileKey5=%LocalAppData%\Cyberlink\PowerDVD*|*.log|RECURSE
FileKey6=%LocalAppData%\Cyberlink\PowerDVD*\*\PowerDVDMainAP|*.*|RECURSE
FileKey7=%LocalAppData%\Cyberlink\PowerDVD*\cache*|*.*|RECURSE
FileKey8=%LocalAppData%\Cyberlink\PowerDVD*\CL_DMP_Browser|*.*|RECURSE
FileKey9=%LocalAppData%\Cyberlink\PowerDVD*\DB*\computer|*.db|RECURSE
FileKey10=%LocalAppData%\Cyberlink\PowerDVD*\DefaultMember|*.*|RECURSE
RegKey1=HKCU\Software\CyberLink\PowerDVD15\CLMPSvc\MediaObj\MediaCache5\Data5
RegKey2=HKCU\Software\CyberLink\PowerDVD15\CLMPSvc\MediaObj\MediaCache5\ProgramInfo
RegKey3=HKCU\Software\CyberLink\PowerDVD15\CLMPSvc\MediaObj\MediaCache5\Thumbnail5
RegKey4=HKCU\Software\CyberLink\PowerDVD16\CLMPSvc\MediaObj\MediaCache5\Data5
RegKey5=HKCU\Software\CyberLink\PowerDVD16\CLMPSvc\MediaObj\MediaCache5\ProgramInfo
RegKey6=HKCU\Software\CyberLink\PowerDVD16\CLMPSvc\MediaObj\MediaCache5\Thumbnail5
RegKey7=HKCU\Software\CyberLink\PowerDVD17\CLMPSvc\MediaObj\MediaCache5\Data5
RegKey8=HKCU\Software\CyberLink\PowerDVD17\CLMPSvc\MediaObj\MediaCache5\ProgramInfo
RegKey9=HKCU\Software\CyberLink\PowerDVD17\CLMPSvc\MediaObj\MediaCache5\Thumbnail5
RegKey10=HKCU\Software\CyberLink\PowerDVD18\CLMPSvc\MediaObj\MediaCache5\Data5
RegKey11=HKCU\Software\CyberLink\PowerDVD18\CLMPSvc\MediaObj\MediaCache5\ProgramInfo
RegKey12=HKCU\Software\CyberLink\PowerDVD18\CLMPSvc\MediaObj\MediaCache5\Thumbnail5
RegKey13=HKCU\Software\CyberLink\PowerDVD19\CLMPSvc\MediaObj\MediaCache5\Data5
RegKey14=HKCU\Software\CyberLink\PowerDVD19\CLMPSvc\MediaObj\MediaCache5\ProgramInfo
RegKey15=HKCU\Software\CyberLink\PowerDVD19\CLMPSvc\MediaObj\MediaCache5\Thumbnail5
RegKey16=HKCU\Software\CyberLink\PowerDVD20\CLMPSvc\MediaObj\MediaCache5\Data5
RegKey17=HKCU\Software\CyberLink\PowerDVD20\CLMPSvc\MediaObj\MediaCache5\ProgramInfo
RegKey18=HKCU\Software\CyberLink\PowerDVD20\CLMPSvc\MediaObj\MediaCache5\Thumbnail5
RegKey19=HKCU\Software\CyberLink\PowerDVD20\CoarseSnapshot\MediaObj\MediaCache5\Data5
RegKey20=HKCU\Software\CyberLink\PowerDVD20\CoarseSnapshot\MediaObj\MediaCache5\ProgramInfo
RegKey21=HKCU\Software\CyberLink\PowerDVD21\CLMPSvc\MediaObj\MediaCache5\Data5
RegKey22=HKCU\Software\CyberLink\PowerDVD21\CLMPSvc\MediaObj\MediaCache5\ProgramInfo
RegKey23=HKCU\Software\CyberLink\PowerDVD21\CLMPSvc\MediaObj\MediaCache5\Thumbnail5
RegKey24=HKCU\Software\CyberLink\PowerDVD21\CoarseSnapshot\MediaObj\MediaCache5\Data5
RegKey25=HKCU\Software\CyberLink\PowerDVD21\CoarseSnapshot\MediaObj\MediaCache5\ProgramInfo
RegKey26=HKCU\Software\CyberLink\PowerDVD22\CLMPSvc\MediaObj\MediaCache5\Data5
RegKey27=HKCU\Software\CyberLink\PowerDVD22\CLMPSvc\MediaObj\MediaCache5\ProgramInfo
RegKey28=HKCU\Software\CyberLink\PowerDVD22\CLMPSvc\MediaObj\MediaCache5\Thumbnail5
RegKey29=HKCU\Software\CyberLink\PowerDVD22\CoarseSnapshot\MediaObj\MediaCache5\Data5
RegKey30=HKCU\Software\CyberLink\PowerDVD22\CoarseSnapshot\MediaObj\MediaCache5\ProgramInfo
Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System);  Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC.  ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system):   Bitdefender Internet Security 2022, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more.
Link to comment
if I don't use winapptool and download winapp2.ini directly - do I use https://raw.githubusercontent.com/MoscaDotTo/Winapp2/Branch1/Winapp2.ini or another one?
:Master
  copy "https://raw.githubusercontent.com/MoscaDotTo/Winapp2/master/Winapp2.ini"              C:\TCMD\WinApp2_Ini\Winapp2_Unix.ini
  copy "https://raw.githubusercontent.com/MoscaDotTo/Winapp2/master/Winapp3/Winapp3.ini"      C:\TCMD\WinApp2_Ini\Winapp3_Unix.ini
  goto :keep
:branch
  copy "https://raw.githubusercontent.com/MoscaDotTo/Winapp2/MoscaDotTo-patch-1/Winapp2.ini"  C:\TCMD\WinApp2_Ini\Winapp2_Unix.ini
  goto :keep
Or are these correct?
Link to comment
Branch1 is where "beta" versions of winapp2ool and winapp2.ini live (at least, as far as this particular major revision to winapp2.ini is concerned). I should be ready to push it to master soon, but I had some winapp2ool work to cover and in pursuit of that found numerous bugs that also needed to be fixed to be compatible with some of the changes I made to winapp2.ini. The work is almost done (sorry for the wait - I wasn't able to work meaningfully on this for several months)
as of right now, the latest pending winapp2.ini can be found at the branch1 link, but once to push to master is complete it will be available in the normal link.
Link to comment
Recall that much has changed in winapp2.ini on the Branch1 and many entries have been merged, renamed, or reworked. You may want to carefully review your scan results before cleaning. winapp2ool on branch1 has been updated to support diffing this massive set of changes more helpfully. (listing which entries have been merged or renamed, for example)
Link to comment
Modified entry:  [Windows Logs *]
Added FileKey44
[Windows Logs *]
LangSecRef=3025
Detect=HKLM\Software\Microsoft\Windows
FileKey1=%CommonAppData%\Microsoft\Diagnosis\DownloadedSettings|*.json.bk
FileKey2=%CommonAppData%\Microsoft\Diagnosis\ETLLogs|*.*|RECURSE
FileKey3=%CommonAppData%\Microsoft\DiagnosticLogCSP|*.*|RECURSE
FileKey4=%CommonAppData%\Microsoft\Network\Downloader|*.*|RECURSE
FileKey5=%CommonAppData%\Microsoft\WDF|*.*|RECURSE
FileKey6=%CommonAppData%\Microsoft\Windows Security Health\Logs|*.*|RECURSE
FileKey7=%CommonAppData%\Microsoft\Windows\wfp|*.etl
FileKey8=%CommonAppData%\USOShared\Logs|*.*|RECURSE
FileKey9=%LocalAppData%\ConnectedDevicesPlatform|*.log
FileKey10=%LocalAppData%\Diagnostics|*.*|RECURSE
FileKey11=%LocalAppData%\Microsoft\Dialer|*.log.txt
FileKey12=%LocalAppData%\Microsoft\msipc\Logs|*.*
FileKey13=%LocalAppData%\Microsoft\Windows\Explorer|*.etl
FileKey14=%ProgramFiles%\UNP\*Logs|*.*
FileKey15=%SystemDrive%|DumpStack.log
FileKey16=%SystemDrive%\PerfLogs\System\Diagnostics|*.*|RECURSE
FileKey17=%SystemDrive%\PerfLogs\System\Performance|*.*|RECURSE
FileKey18=%WinDir%\AppCompat\Programs|*.txt;*.xml
FileKey19=%WinDir%\AppCompat\Programs\Install|*.txt;*.xml
FileKey20=%WinDir%\debug\WIA|*.log
FileKey21=%WinDir%\INF|*.etl;*.log*
FileKey22=%WinDir%\Logs\CBS|*.cab
FileKey23=%WinDir%\Panther|cbs.log;DDACLSys.log;miglog.xml;Migrep.html;PostGatherPnPList.log;PreGatherPnPList.log;*.tmp
FileKey24=%WinDir%\Panther\FastCleanup|*.log
FileKey25=%WinDir%\Panther\Rollback|*.txt
FileKey26=%WinDir%\Panther\UnattendGC|diagerr.xml;diagwrn.xml
FileKey27=%WinDir%\repair|setup.log
FileKey28=%WinDir%\security\logs|*.*|RECURSE
FileKey29=%WinDir%\ServiceProfiles\NetworkService\debug|*.log
FileKey30=%WinDir%\System32\CatRoot|*.tmp
FileKey31=%WinDir%\System32\CatRoot_bak|*.*|REMOVESELF
FileKey32=%WinDir%\System32\catroot2|*.chk;*.log;*.jrs;*.txt
FileKey33=%WinDir%\System32\LogFiles\HTTPERR|*.log
FileKey34=%WinDir%\System32\LogFiles\Scm|*.*|RECURSE
FileKey35=%WinDir%\System32\LogFiles\setupcln|*.*|RECURSE
FileKey36=%WinDir%\System32\LogFiles\Srt|*.*|RECURSE
FileKey37=%WinDir%\System32\LogFiles\WMI|*.*|RECURSE
FileKey38=%WinDir%\System32\LogFiles\WUDF|*.*
FileKey39=%WinDir%\System32\SleepStudy|*.etl
FileKey40=%WinDir%\System32\SleepStudy\ScreenOn|*.etl
FileKey41=%WinDir%\System32\sysprep\Panther\IE|diagerr.xml;diagwrn.xml;*.log
FileKey42=%WinDir%\System32\WDI\*|snapshot.etl|REMOVESELF
FileKey43=%WinDir%\System32\WDI\LogFiles\StartupInfo|*.*|RECURSE
FileKey44=%WinDir%\Temp|*.log
RegKey1=HKLM\Software\Microsoft\RADAR\HeapLeakDetection\DiagnosedApplications
RegKey2=HKLM\Software\Microsoft\Tracing
RegKey3=HKLM\Software\Wow6432Node\Microsoft\RADAR\HeapLeakDetection\DiagnosedApplications
RegKey4=HKLM\Software\Wow6432Node\Microsoft\Tracing
Link to comment
Added FileKey44
[Windows Logs *]
JFYI: The directory "%WinDir%\Temp" has always been cleaned by CCleaner ("System - Temporary Files").
(Probably the files were still in use and therefore locked for a short time.)
Link to comment
Modified entry:  [jv16 PowerTools *]
Added |RECURSE to FileKey3
[jv16 PowerTools *]
LangSecRef=3024
DetectFile=%ProgramFiles%\jv16 PowerTools*
FileKey1=%ProgramFiles%\jv16 PowerTools*|*.log;*.reg
FileKey2=%ProgramFiles%\jv16 PowerTools*\Settings|*.log
FileKey3=%ProgramFiles%\jv16 PowerTools*\Temp|*.*|RECURSE
Link to comment
Oops.  You are correct.  Please forget my modified to  Windows Logs *]
Edited by siliconman01
Link to comment
Modified entry:  [Ashampoo Burning Studio *]
Added Ashampoo Burning Studio 24
LangSecRef=3024
Detect1=HKCU\Software\Ashampoo\Ashampoo Burning Studio 5
Detect2=HKCU\Software\Ashampoo\Ashampoo Burning Studio 6
Detect3=HKCU\Software\Ashampoo\Ashampoo Burning Studio 7
Detect4=HKCU\Software\Ashampoo\Ashampoo Burning Studio 8
Detect5=HKCU\Software\Ashampoo\Ashampoo Burning Studio 12
Detect6=HKCU\Software\Ashampoo\Ashampoo Burning Studio 14
Detect7=HKCU\Software\Ashampoo\Ashampoo Burning Studio 15
Detect8=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16
Detect9=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18
Detect10=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19
Detect11=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20
Detect12=HKCU\Software\Ashampoo\Ashampoo Burning Studio 21
Detect13=HKCU\Software\Ashampoo\Ashampoo Burning Studio 22
Detect14=HKCU\Software\Ashampoo\Ashampoo Burning Studio 23
Detect15=HKCU\Software\Ashampoo\Ashampoo Burning Studio 24
Detect16=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2007
Detect17=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2009
Detect18=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2012
Detect19=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016
Detect20=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017
Detect21=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018
Detect22=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019
FileKey1=%AppData%\Ashampoo|*.log;*.txt;*.xml|RECURSE
FileKey2=%CommonAppData%\Ashampoo|ico_ashampoo_deals.ico
FileKey3=%CommonAppData%\Ashampoo\drivers|driverdatabase.xml|REMOVESELF
FileKey4=%LocalAppData%\Ashampoo\BaNT|*.*|RECURSE
RegKey1=HKCU\Software\Ashampoo\Ashampoo Burning Studio 5\Burn Image Project\SelectImage
RegKey2=HKCU\Software\Ashampoo\Ashampoo Burning Studio 5\Data Disc Project\AddDialog
RegKey3=HKCU\Software\Ashampoo\Ashampoo Burning Studio 5\Data Disc Project\DumpImage
RegKey4=HKCU\Software\Ashampoo\Ashampoo Burning Studio 5\Unknown Project\AddDialog
RegKey5=HKCU\Software\Ashampoo\Ashampoo Burning Studio 6\Burn Image Project\SelectImage
RegKey6=HKCU\Software\Ashampoo\Ashampoo Burning Studio 6\Data Disc Project\AddDialog
RegKey7=HKCU\Software\Ashampoo\Ashampoo Burning Studio 6\Unknown Project\AddDialog
RegKey8=HKCU\Software\Ashampoo\Ashampoo Burning Studio 7\Burn Image Project\SelectImage
RegKey9=HKCU\Software\Ashampoo\Ashampoo Burning Studio 7\Data Disc Project\AddDialog
RegKey10=HKCU\Software\Ashampoo\Ashampoo Burning Studio 7\Unknown Project\AddDialog
RegKey11=HKCU\Software\Ashampoo\Ashampoo Burning Studio 8\Data Disc Project\AddDialog
RegKey12=HKCU\Software\Ashampoo\Ashampoo Burning Studio 14\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory
RegKey13=HKCU\Software\Ashampoo\Ashampoo Burning Studio 14\tempFiles
RegKey14=HKCU\Software\Ashampoo\Ashampoo Burning Studio 15\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory
RegKey15=HKCU\Software\Ashampoo\Ashampoo Burning Studio 15\tempFiles
RegKey16=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory
RegKey17=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Backup Project\BackupOptions|CustomLocation
RegKey18=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\BDMV Disc Project\SelectBDMVFolder|BdmvPath
RegKey19=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Browse Image Project\BrowseImageFile|ImagePath
RegKey20=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory
RegKey21=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory
RegKey22=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Burn Image Project\SelectImage|ImagePath
RegKey23=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Data Disc Project\DumpImage|ImagePath
RegKey24=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory
RegKey25=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\DVD-Video Disc Project\MoviesPage|Path
RegKey26=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\DVD-Video Disc Project\SaveDialog_authed.CMoviesPage.Movies|InitialDirectory
RegKey27=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Logs
RegKey28=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\tempFiles
RegKey29=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Unknown Project
RegKey30=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\VCD Project\SaveDialog_OnAddMovies|InitialDirectory
RegKey31=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\VIDEO_TS Disc Project\DumpImage|ImagePath
RegKey32=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath
RegKey33=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory
RegKey34=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Backup Project\BackupOptions|CustomLocation
RegKey35=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\BDMV Disc Project\SelectBDMVFolder|BdmvPath
RegKey36=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Browse Image Project\BrowseImageFile|ImagePath
RegKey37=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory
RegKey38=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory
RegKey39=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Burn Image Project\SelectImage|ImagePath
RegKey40=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Data Disc Project\DumpImage|ImagePath
RegKey41=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory
RegKey42=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\DVD-Video Disc Project\MoviesPage|Path
RegKey43=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\DVD-Video Disc Project\SaveDialog_authed.CMoviesPage.Movies|InitialDirectory
RegKey44=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Logs
RegKey45=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\tempFiles
RegKey46=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Unknown Project
RegKey47=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\VCD Project\SaveDialog_OnAddMovies|InitialDirectory
RegKey48=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\VIDEO_TS Disc Project\DumpImage|ImagePath
RegKey49=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath
RegKey50=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory
RegKey51=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Backup Project\BackupOptions|CustomLocation
RegKey52=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\BDMV Disc Project\SelectBDMVFolder|BdmvPath
RegKey53=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Browse Image Project\BrowseImageFile|ImagePath
RegKey54=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory
RegKey55=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory
RegKey56=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Burn Image Project\SelectImage|ImagePath
RegKey57=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Data Disc Project\DumpImage|ImagePath
RegKey58=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory
RegKey59=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\DVD-Video Disc Project\MoviesPage|Path
RegKey60=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\DVD-Video Disc Project\SaveDialog_authed.CMoviesPage.Movies|InitialDirectory
RegKey61=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Logs
RegKey62=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\tempFiles
RegKey63=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Unknown Project
RegKey64=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\VCD Project\SaveDialog_OnAddMovies|InitialDirectory
RegKey65=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\VIDEO_TS Disc Project\DumpImage|ImagePath
RegKey66=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath
RegKey67=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory
RegKey68=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Backup Project\BackupOptions|CustomLocation
RegKey69=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\BDMV Disc Project\SelectBDMVFolder|BdmvPath
RegKey70=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Browse Image Project\BrowseImageFile|ImagePath
RegKey71=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory
RegKey72=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory
RegKey73=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Burn Image Project\SelectImage|ImagePath
RegKey74=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Data Disc Project\DumpImage|ImagePath
RegKey75=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory
RegKey76=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\DVD-Video Disc Project\MoviesPage|Path
RegKey77=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\DVD-Video Disc Project\SaveDialog_authed.CMoviesPage.Movies|InitialDirectory
RegKey78=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Logs
RegKey79=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\tempFiles
RegKey80=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Unknown Project
RegKey81=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\VCD Project\SaveDialog_OnAddMovies|InitialDirectory
RegKey82=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\VIDEO_TS Disc Project\DumpImage|ImagePath
RegKey83=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath
RegKey84=HKCU\Software\Ashampoo\Ashampoo Burning Studio 22\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory
RegKey85=HKCU\Software\Ashampoo\Ashampoo Burning Studio 22\Backup Project\BackupOptions|CustomLocation
RegKey86=HKCU\Software\Ashampoo\Ashampoo Burning Studio 22\BDMV Disc Project\SelectBDMVFolder|BdmvPath
RegKey87=HKCU\Software\Ashampoo\Ashampoo Burning Studio 22\Browse Image Project\BrowseImageFile|ImagePath
RegKey88=HKCU\Software\Ashampoo\Ashampoo Burning Studio 22\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory
RegKey89=HKCU\Software\Ashampoo\Ashampoo Burning Studio 22\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory
RegKey90=HKCU\Software\Ashampoo\Ashampoo Burning Studio 22\Burn Image Project\SelectImage|ImagePath
RegKey91=HKCU\Software\Ashampoo\Ashampoo Burning Studio 22\Data Disc Project\DumpImage|ImagePath
RegKey92=HKCU\Software\Ashampoo\Ashampoo Burning Studio 22\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory
RegKey93=HKCU\Software\Ashampoo\Ashampoo Burning Studio 22\DVD-Video Disc Project\MoviesPage|Path
RegKey94=HKCU\Software\Ashampoo\Ashampoo Burning Studio 22\DVD-Video Disc Project\SaveDialog_authed.CMoviesPage.Movies|InitialDirectory
RegKey95=HKCU\Software\Ashampoo\Ashampoo Burning Studio 22\Logs
RegKey96=HKCU\Software\Ashampoo\Ashampoo Burning Studio 22\tempFiles
RegKey97=HKCU\Software\Ashampoo\Ashampoo Burning Studio 22\Unknown Project
RegKey98=HKCU\Software\Ashampoo\Ashampoo Burning Studio 22\VCD Project\SaveDialog_OnAddMovies|InitialDirectory
RegKey99=HKCU\Software\Ashampoo\Ashampoo Burning Studio 22\VIDEO_TS Disc Project\DumpImage|ImagePath
RegKey100=HKCU\Software\Ashampoo\Ashampoo Burning Studio 22\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath
RegKey101=HKCU\Software\Ashampoo\Ashampoo Burning Studio 23\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory
RegKey102=HKCU\Software\Ashampoo\Ashampoo Burning Studio 23\Backup Project\BackupOptions|CustomLocation
RegKey103=HKCU\Software\Ashampoo\Ashampoo Burning Studio 23\BDMV Disc Project\SelectBDMVFolder|BdmvPath
RegKey104=HKCU\Software\Ashampoo\Ashampoo Burning Studio 23\Browse Image Project\BrowseImageFile|ImagePath
RegKey105=HKCU\Software\Ashampoo\Ashampoo Burning Studio 23\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory
RegKey106=HKCU\Software\Ashampoo\Ashampoo Burning Studio 23\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory
RegKey107=HKCU\Software\Ashampoo\Ashampoo Burning Studio 23\Burn Image Project\SelectImage|ImagePath
RegKey108=HKCU\Software\Ashampoo\Ashampoo Burning Studio 23\Data Disc Project\DumpImage|ImagePath
RegKey109=HKCU\Software\Ashampoo\Ashampoo Burning Studio 23\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory
RegKey110=HKCU\Software\Ashampoo\Ashampoo Burning Studio 23\DVD-Video Disc Project\MoviesPage|Path
RegKey111=HKCU\Software\Ashampoo\Ashampoo Burning Studio 23\DVD-Video Disc Project\SaveDialog_authed.CMoviesPage.Movies|InitialDirectory
RegKey112=HKCU\Software\Ashampoo\Ashampoo Burning Studio 23\Logs
RegKey113=HKCU\Software\Ashampoo\Ashampoo Burning Studio 23\tempFiles
RegKey114=HKCU\Software\Ashampoo\Ashampoo Burning Studio 23\Unknown Project
RegKey115=HKCU\Software\Ashampoo\Ashampoo Burning Studio 23\VCD Project\SaveDialog_OnAddMovies|InitialDirectory
RegKey116=HKCU\Software\Ashampoo\Ashampoo Burning Studio 23\VIDEO_TS Disc Project\DumpImage|ImagePath
RegKey117=HKCU\Software\Ashampoo\Ashampoo Burning Studio 23\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath
RegKey118=HKCU\Software\Ashampoo\Ashampoo Burning Studio 24\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory
RegKey119=HKCU\Software\Ashampoo\Ashampoo Burning Studio 24\Backup Project\BackupOptions|CustomLocation
RegKey120=HKCU\Software\Ashampoo\Ashampoo Burning Studio 24\BDMV Disc Project\SelectBDMVFolder|BdmvPath
RegKey121=HKCU\Software\Ashampoo\Ashampoo Burning Studio 24\Browse Image Project\BrowseImageFile|ImagePath
RegKey122=HKCU\Software\Ashampoo\Ashampoo Burning Studio 24\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory
RegKey123=HKCU\Software\Ashampoo\Ashampoo Burning Studio 24\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory
RegKey124=HKCU\Software\Ashampoo\Ashampoo Burning Studio 24\Burn Image Project\SelectImage|ImagePath
RegKey125=HKCU\Software\Ashampoo\Ashampoo Burning Studio 24\Data Disc Project\DumpImage|ImagePath
RegKey126=HKCU\Software\Ashampoo\Ashampoo Burning Studio 24\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory
RegKey127=HKCU\Software\Ashampoo\Ashampoo Burning Studio 24\DVD-Video Disc Project\MoviesPage|Path
RegKey128=HKCU\Software\Ashampoo\Ashampoo Burning Studio 24\DVD-Video Disc Project\SaveDialog_authed.CMoviesPage.Movies|InitialDirectory
RegKey129=HKCU\Software\Ashampoo\Ashampoo Burning Studio 24\Logs
RegKey130=HKCU\Software\Ashampoo\Ashampoo Burning Studio 24\tempFiles
RegKey131=HKCU\Software\Ashampoo\Ashampoo Burning Studio 24\Unknown Project
RegKey132=HKCU\Software\Ashampoo\Ashampoo Burning Studio 24\VCD Project\SaveDialog_OnAddMovies|InitialDirectory
RegKey133=HKCU\Software\Ashampoo\Ashampoo Burning Studio 24\VIDEO_TS Disc Project\DumpImage|ImagePath
RegKey134=HKCU\Software\Ashampoo\Ashampoo Burning Studio 24\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath
RegKey135=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2007\Burn Image Project\AddDialog
RegKey136=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2007\Data Disc Project\AddDialog
RegKey137=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2007\Dump Image Project\DumpImage
RegKey138=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2007\Unknown Project\AddDialog
RegKey139=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2012\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory
RegKey140=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2012\Backup Project\BackupOptions|CustomLocation
RegKey141=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2012\Browse Image Project\BrowseImageFile|ImagePath
RegKey142=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2012\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory
RegKey143=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2012\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory
RegKey144=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2012\Burn Image Project\SelectImage|ImagePath
RegKey145=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2012\Data Disc Project\DumpImage|ImagePath
RegKey146=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2012\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory
RegKey147=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2012\Logs
RegKey148=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2012\tempFiles
RegKey149=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2012\Unknown Project
RegKey150=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2012\VCD Project\SaveDialog_OnAddMovies|InitialDirectory
RegKey151=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2012\VIDEO_TS Disc Project\DumpImage|ImagePath
RegKey152=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2012\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath
RegKey153=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory
RegKey154=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Backup Project\BackupOptions|CustomLocation
RegKey155=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Browse Image Project\BrowseImageFile|ImagePath
RegKey156=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory
RegKey157=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory
RegKey158=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Burn Image Project\SelectImage|ImagePath
RegKey159=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Data Disc Project\DumpImage|ImagePath
RegKey160=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory
RegKey161=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Logs
RegKey162=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\tempFiles
RegKey163=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Unknown Project
RegKey164=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\VCD Project\SaveDialog_OnAddMovies|InitialDirectory
RegKey165=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\VIDEO_TS Disc Project\DumpImage|ImagePath
RegKey166=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath
RegKey167=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory
RegKey168=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Backup Project\BackupOptions|CustomLocation
RegKey169=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Browse Image Project\BrowseImageFile|ImagePath
RegKey170=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory
RegKey171=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory
RegKey172=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Burn Image Project\SelectImage|ImagePath
RegKey173=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Data Disc Project\DumpImage|ImagePath
RegKey174=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory
RegKey175=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Logs
RegKey176=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\tempFiles
RegKey177=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Unknown Project
RegKey178=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\VCD Project\SaveDialog_OnAddMovies|InitialDirectory
RegKey179=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\VIDEO_TS Disc Project\DumpImage|ImagePath
RegKey180=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath
RegKey181=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory
RegKey182=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Backup Project\BackupOptions|CustomLocation
RegKey183=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Browse Image Project\BrowseImageFile|ImagePath
RegKey184=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory
RegKey185=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory
RegKey186=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Burn Image Project\SelectImage|ImagePath
RegKey187=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Data Disc Project\DumpImage|ImagePath
RegKey188=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory
RegKey189=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Logs
RegKey190=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\tempFiles
RegKey191=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Unknown Project
RegKey192=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\VCD Project\SaveDialog_OnAddMovies|InitialDirectory
RegKey193=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\VIDEO_TS Disc Project\DumpImage|ImagePath
RegKey194=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath
RegKey195=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory
RegKey196=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\Backup Project\BackupOptions|CustomLocation
RegKey197=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\Browse Image Project\BrowseImageFile|ImagePath
RegKey198=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory
RegKey199=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory
RegKey200=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\Burn Image Project\SelectImage|ImagePath
RegKey201=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\Data Disc Project\DumpImage|ImagePath
RegKey202=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory
RegKey203=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\Logs
RegKey204=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\tempFiles
RegKey205=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\Unknown Project
RegKey206=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\VCD Project\SaveDialog_OnAddMovies|InitialDirectory
RegKey207=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\VIDEO_TS Disc Project\DumpImage|ImagePath
RegKey208=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath
Link to comment
  • 1 month later...
Wow this topic seems dead... RIP. :(
I had a question, usually you guys are pretty good at keeping up with this sort of stuff, ie. junk files being created.
Anyway this is Firefox 109 related that was released this morning. Since updating to Firefox 109.0 this morning, I am now noticing all these little files being created when closing the browser in the "Mozilla" folder under ProgramData;
Do others see these being created in 109, I'm guessing a new rule will need to be made for this if so, I'm not very good with wildcards, anyone got an idea how to make a rule for these?
Link to comment
  • Moderators
I passed this on to developers as well
Link to comment
12 hours ago, Special said:
... Do others see these being created in 109, I'm guessing a new rule will need to be made for this if so, I'm not very good with wildcards, anyone got an idea how to make a rule for these?
I can confirm these files. Every time I close Firefox, a new file is added...
Here is a new cleanup rule:
[Cache2 *]
LangSecRef=3026
DetectFile=%AppData%\Mozilla\Firefox
FileKey1=%CommonAppData%\Mozilla*|cache2.*
Link to comment
  • 3 weeks later...
Modified entry:  [Dell Logs *]
Added FileKey9
[Dell Logs *]
LangSecRef=3024
Detect1=HKLM\Software\Dell\MUP
Detect2=HKLM\Software\Dell\UpdateService
Detect3=HKLM\Software\PC-Doctor
DetectFile1=%AppData%\Creative\DELL Webcam Center
DetectFile2=%CommonAppData%\Dell
DetectFile3=%LocalAppData%\Dell
DetectFile4=%LocalAppData%\SupportSoft\DellSupportCenter
DetectFile5=%ProgramFiles%\Dell*
FileKey1=%AppData%\Creative\DELL Webcam Center|MO_Log.txt
FileKey2=%AppData%\PCDr\*\Logs|*.*
FileKey3=%CommonAppData%\Dell\*\Log|*.*|RECURSE
FileKey4=%CommonAppData%\Dell\*\Logs|*.*|RECURSE
FileKey5=%CommonAppData%\Dell\BiosVerification|*.log
FileKey6=%CommonAppData%\Dell\D3\pla\*\*|*.log;*.txt|REMOVESELF
FileKey7=%CommonAppData%\Dell\D3\Resources\Logs\serilog|*.*
FileKey8=%CommonAppData%\Dell\Drivers\*|*.log;*.tmp|RECURSE
FileKey9=%CommonAppData%\Dell\orca\deviceq|*.*
FileKey10=%CommonAppData%\Dell\SupportAssist|*.*|RECURSE
FileKey11=%CommonAppData%\Dell\TrustedDevice|*.log
FileKey12=%CommonAppData%\Dell\Update|*.txt
FileKey13=%CommonAppData%\Dell\UpdateService\Clients\Update|*.log
FileKey14=%CommonAppData%\Dell\UpdateService\DataStore\*\*|*.log
FileKey15=%CommonAppData%\Dell\UpdateService\UpdatePackage\Log|*.log;*.txt
FileKey16=%CommonAppData%\PCDr\*\Logs|*.*
FileKey17=%LocalAppData%\Dell\*\Log|*.*
FileKey18=%LocalAppData%\Dell\DellMobileConnect|*.log
FileKey19=%LocalAppData%\SupportSoft\DellSupportCenter\*\state\logs|*.*
FileKey20=%ProgramFiles%\Dell*|*.log|RECURSE
Link to comment
  • 2 weeks later...
The latest release of Winapp2.ini (Version: 230215) removes all the user favicons in MS Edge Favorites.  In [Microsoft Edge History *]>Filekey1, the Favicons* needs to be removed.
LangSecRef=3006
DetectFile=%LocalAppData%\Microsoft\Edge*
FileKey1=%LocalAppData%\Microsoft\Edge*\User Data\*|History*;Favicons*;Visited Links*;Top Sites*;Network Action Predictor*;Shortcuts
Favorites
Link to comment
Register a new account
Sign in
Important Information
