Winapp2.ini additions
Winapp2.ini
9 hours ago, SMalik said:
Any idea where system saves usage history of Store Apps on Windows 10/11? I think there should be an entry to delete usage history. ...
This data also seems to be stored in the "Network Data Usage" database. At least, everything is reset to 0 for me after deleting all files under "%WinDir%\System32\sru".
Note that some of the files are locked and can only be deleted a few minutes after closing the Task Manager and all other opened apps.
The Winapp2.ini entry [Windows Subsystems *] already deletes these files completely. (The CCleaner entry [Network Data Usage] deletes only incompletely.)
Link to comment
Modified entry:  [Intel Logs *]
Added FileKey11 and FileKey12
[Intel Logs *]
LangSecRef=3024
Detect1=HKCU\Software\Intel
Detect2=HKLM\Software\Intel
FileKey1=%CommonAppData%\Intel|*.log;*.log.bak;*Log.txt|RECURSE
FileKey2=%CommonAppData%\Intel(R) Update Manager\AppData|ium.log
FileKey3=%CommonAppData%\Intel\*\Log*|*.*
FileKey4=%CommonAppData%\Intel\GCC|gcc_svc_log_*.txt
FileKey5=%CommonAppData%\Intel\Logs|*.*
FileKey6=%LocalAppData%\Intel\SUR\QueenCreek\Collected Data|*error_stack-*.txt
FileKey7=%ProgramFiles%\Intel\*|*.log;*Log.txt|RECURSE
FileKey8=%ProgramFiles%\Intel\InfInst|*.*|REMOVESELF
FileKey9=%SystemDrive%|IFRToolLog.txt
FileKey10=%SystemDrive%\Driver_allOS\MEI\Drivers\MEI\INTERNAL|*.log|RECURSE
FileKey11=%SystemDrive%\Intel|*.log|REMOVESELF
FileKey12=%SystemDrive%\Intel\GfxCPLBatchFiles|*.*|REMOVESELF
FileKey13=%SystemDrive%\Intel\Logs|*.*|REMOVESELF
FileKey14=%UserProfile%\Intel\Logs|*.*|REMOVESELF
FileKey15=%WinDir%\debug\Intel\Logs|*.*|REMOVESELF
FileKey16=%WinDir%\System32|Default_error_Stack-*.txt;Gms.log
FileKey17=%WinDir%\System32\config\systemprofile\Intel\Logs|*.*|REMOVESELF
FileKey18=%WinDir%\SysWOW64|Gms.log
FileKey19=%WinDir%\SysWOW64\config\systemprofile\Intel\Logs|*.*|REMOVESELF
Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System);  Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC.  ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system):   Bitdefender Internet Security 2022, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more.
Link to comment
I was hoping to get a little help here with a rule I'm trying to make...
I'm trying to delete these keys while keeping the other two in red.
The rule I have is:
FileKey7=%LocalLowAppData%\ABCDEF\folderXYZ|metagameSave.json.*
but that deletes the "metagameSave.json.backup" too, I don't want that, the only way I've found to exclude the backup file is to do:
FileKey7=%LocalLowAppData%\ABCDEF\folderXYZ|metagameSave.json.1;metagameSave.json.2;metagameSave.json.3;metagameSave.json.4;metagameSave.json.5;metagameSave.json.6
etc... which will delete the keys I want while leaving the "backup" one. Is there a simpler way?
Thanks for any help & tips in advance. :)
Link to comment
The rule I have is:
FileKey7=%LocalLowAppData%\ABCDEF\folderXYZ|metagameSave.json.?
will work.......
Link to comment
11 hours ago, Special said:
... etc... which will delete the keys I want while leaving the "backup" one. Is there a simpler way? ...
The use of the "?" placeholder suggested by CSGalloway is certainly the best solution here.
In cases where it doesn't work even with the "?" placeholder, an "ExcludeKey" can also be used, like for example:
ExcludeKey1=FILE|%LocalLowAppData%\ABCDEF\folderXYZ\|metagameSave.json.backup
Link to comment
will work.......
Thanks so much you two, this worked perfectly... I didn't even know you could do it this way!
I actually tried doing the "ExcludeKey1" way too, but it wasn't working which was odd. But oh well it's all good now. :)
Link to comment
Modified entry:  [DVDFab *]
Added FileKey2
[DVDFab *]
LangSecRef=3023
Detect1=HKCU\Software\DVDFab
Detect2=HKCU\Software\DVDFab Passkey
Detect3=HKCU\Software\FabPlayer
FileKey1=%AppData%\DVDFab Player*\Advertis*|*.*|RECURSE
FileKey2=%AppData%\DVDFab\DVDFab*\regRecord|*.rec
FileKey3=%AppData%\DVDFab\DVDFab*\SceneData|*.*|RECURSE
FileKey4=%AppData%\LiveUpdate|*.log
FileKey5=%AppData%\Microsoft\Windows\Templates\Videos\Temp|*.*|RECURSE
FileKey6=%Documents%\DVDFab*|*.log
FileKey7=%Documents%\DVDFab*\Log|*.*|RECURSE
FileKey8=%Documents%\DVDFab*\SceneData|*.*|RECURSE
FileKey9=%Documents%\DVDFab*\Temp|*.*|RECURSE
FileKey10=%Documents%\DVDFab\DVDFab*\Cinavia|*.*|RECURSE
FileKey11=%Documents%\DVDFab\DVDFab*\Log|*.*|RECURSE
FileKey12=%Documents%\DVDFab\DVDFab*\Temp|*.*|RECURSE
FileKey13=%Documents%\DVDFab\updateLog|*.*|REMOVESELF
FileKey14=%Documents%\LiveUpdate|*.*|REMOVESELF
FileKey15=%Documents%\PcSetup|*.*|RECURSE
FileKey16=%LocalAppData%\DVDFab*\cache\QtWebEngine\Default\Cache|*.*
FileKey17=%LocalAppData%\DVDFab*\QtWebEngine\Default\GPUCache|*.*|REMOVESELF
RegKey1=HKCU\Software\FabPlayer|DefaultDir
RegKey2=HKCU\Software\FabPlayer|DefaultFile
Link to comment
Modfied entry: [Snagit *]
Added FileKey1
[Snagit *]
LangSecRef=3021
Detect=HKCU\Software\TechSmith\Snagit
FileKey1=%AppData%\Techsmith\Snagit\Preferences\Output\*|*.*|REMOVESELF
FileKey2=%CommonAppData%\TechSmith\Uploader|*.log
FileKey3=%Documents%|SnagitDebug.log
FileKey4=%Documents%\Snagit|*.snagx
FileKey5=%Documents%\Snagit\.metadata|*.*|RECURSE
FileKey6=%LocalAppData%\TechSmith\Logs|*.log
FileKey7=%LocalAppData%\TechSmith\Snagit|Tray.bin
FileKey8=%LocalAppData%\TechSmith\Snagit\*\NativeCrashReporting\Reports|*.dmp|RECURSE
FileKey9=%LocalAppData%\TechSmith\Snagit\*\WebView2Cache\EBWebView\*\GPUCache|*.*|REMOVESELF
FileKey10=%LocalAppData%\TechSmith\Snagit\CrashDumps|*.*|RECURSE
FileKey11=%LocalAppData%\TechSmith\Snagit\DataStore\AppIcons|*.ico
FileKey12=%LocalAppData%\TechSmith\Snagit\DataStore\WebSiteIcons|*.ico
FileKey13=%LocalAppData%\TechSmith\Snagit\Thumbnails|*.*|RECURSE
FileKey14=%LocalAppData%\TechSmith\Snagit\TrackerbirdFiles|*.log;*.logtmp
FileKey15=%Public%\TechSmith\Snagit\License|*.cache;*.log
RegKey1=HKCU\Software\TechSmith\Snagit\9|StampCustomFolder
RegKey2=HKCU\Software\TechSmith\Snagit\10|StampCustomFolder
RegKey3=HKCU\Software\TechSmith\Snagit\11|CaptureCount
RegKey4=HKCU\Software\TechSmith\Snagit\11|CaptureOpenCount
RegKey5=HKCU\Software\TechSmith\Snagit\11|OutputDirLastUsed
RegKey6=HKCU\Software\TechSmith\Snagit\11|VidOutputDirLastUsed
RegKey7=HKCU\Software\TechSmith\Snagit\11\SnagItEditor\Tray|Thumbnailsize
RegKey8=HKCU\Software\TechSmith\Snagit\12|CaptureCount
RegKey9=HKCU\Software\TechSmith\Snagit\12|CaptureOpenCount
RegKey10=HKCU\Software\TechSmith\Snagit\12|OutputDirLastUsed
RegKey11=HKCU\Software\TechSmith\Snagit\12|VidOutputDirLastUsed
RegKey12=HKCU\Software\TechSmith\Snagit\12\SnagItEditor\Tray|Thumbnailsize
RegKey13=HKCU\Software\TechSmith\Snagit\13|CaptureCount
RegKey14=HKCU\Software\TechSmith\Snagit\13|CaptureOpenCount
RegKey15=HKCU\Software\TechSmith\Snagit\13|OutputDirLastUsed
RegKey16=HKCU\Software\TechSmith\Snagit\13|VidOutputDirLastUsed
RegKey17=HKCU\Software\TechSmith\Snagit\13\Recent Captures
RegKey18=HKCU\Software\TechSmith\Snagit\13\SnagitEditor\Recent File List
RegKey19=HKCU\Software\TechSmith\Snagit\13\SnagItEditor\Tray|Thumbnailsize
RegKey20=HKCU\Software\TechSmith\Snagit\18|CaptureCount
RegKey21=HKCU\Software\TechSmith\Snagit\18|CaptureOpenCount
RegKey22=HKCU\Software\TechSmith\Snagit\18|OutputDirLastUsed
RegKey23=HKCU\Software\TechSmith\Snagit\18|VidOutputDirLastUsed
RegKey24=HKCU\Software\TechSmith\Snagit\18\Recent Captures
RegKey25=HKCU\Software\TechSmith\Snagit\18\SnagitEditor\Recent File List
RegKey26=HKCU\Software\TechSmith\Snagit\18\SnagItEditor\Tray|Thumbnailsize
RegKey27=HKCU\Software\TechSmith\Snagit\19|CaptureCount
RegKey28=HKCU\Software\TechSmith\Snagit\19|CaptureOpenCount
RegKey29=HKCU\Software\TechSmith\Snagit\19|OutputDirLastUsed
RegKey30=HKCU\Software\TechSmith\Snagit\19|VidOutputDirLastUsed
RegKey31=HKCU\Software\TechSmith\Snagit\19\Recent Captures
RegKey32=HKCU\Software\TechSmith\Snagit\19\SnagitEditor\Recent File List
RegKey33=HKCU\Software\TechSmith\Snagit\19\SnagItEditor\Tray|Thumbnailsize
RegKey34=HKCU\Software\TechSmith\Snagit\20|CaptureCount
RegKey35=HKCU\Software\TechSmith\Snagit\20|CaptureOpenCount
RegKey36=HKCU\Software\TechSmith\Snagit\20|OutputDirLastUsed
RegKey37=HKCU\Software\TechSmith\Snagit\20|VidOutputDirLastUsed
RegKey38=HKCU\Software\TechSmith\Snagit\20\Recent Captures
RegKey39=HKCU\Software\TechSmith\Snagit\20\SnagitEditor\Recent File List
RegKey40=HKCU\Software\TechSmith\Snagit\20\SnagItEditor\Tray|Thumbnailsize
RegKey41=HKCU\Software\TechSmith\Snagit\21|CaptureCount
RegKey42=HKCU\Software\TechSmith\Snagit\21|CaptureOpenCount
RegKey43=HKCU\Software\TechSmith\Snagit\21|OutputDirLastUsed
RegKey44=HKCU\Software\TechSmith\Snagit\21|VidOutputDirLastUsed
RegKey45=HKCU\Software\TechSmith\Snagit\21\Recent Captures
RegKey46=HKCU\Software\TechSmith\Snagit\21\SnagitEditor\Recent File List
RegKey47=HKCU\Software\TechSmith\Snagit\21\SnagItEditor\Tray|Thumbnailsize
RegKey48=HKCU\Software\TechSmith\Snagit\22|CaptureCount
RegKey49=HKCU\Software\TechSmith\Snagit\22|CaptureOpenCount
RegKey50=HKCU\Software\TechSmith\Snagit\22|OutputDirLastUsed
RegKey51=HKCU\Software\TechSmith\Snagit\22|VidOutputDirLastUsed
RegKey52=HKCU\Software\TechSmith\Snagit\22\Recent Captures
RegKey53=HKCU\Software\TechSmith\Snagit\22\SnagitEditor\Recent File List
RegKey54=HKCU\Software\TechSmith\Snagit\22\SnagItEditor\Tray|Thumbnailsize
Link to comment
Modified entry:  [Weather Watcher Live *]
Added FileKey2
LangSecRef=3021
Detect=HKCU\Software\VB and VBA Program Settings\Weather Watcher Live
FileKey1=%AppData%\WeatherWatcherLive|WeatherWatcherLive.log
FileKey2=%AppData%\WeatherWatcherLive\LatestChanges|*.*
FileKey3=%AppData%\WeatherWatcherLive\Temp|*.*
Link to comment
Modified entry:  [RivetNetworks *]
Added FileKey1
[RivetNetworks *]
LangSecRef=3024
Detect=HKLM\Software\RivetNetworks
FileKey1=%CommonAppData%\RivetNetworks\ImageCache|*.*
FileKey2=%CommonAppData%\RivetNetworks\Killer|*.log
FileKey3=%WinDir%\System32\drivers\RivetNetworks\Killer|*.log
Link to comment
  • 2 weeks later...
Revised entry
changed DetectFile
added FileKeys 1, 3, 4, 9, 10
[Wondershare Dr.Fone *]
LangSecRef=3021
DetectFile=%ProgramFiles%\Wondershare\Wondershare Dr.Fone
FileKey1=%AppData%\DataEraser_Temp|*.*|RECURSE
FileKey2=%CommonAppData%\Wondershare\dr.fone\log|*.*|RECURSE
FileKey3=%CommonAppData%\Wondershare\dr.fone\Wondershare_DataEraser_Clean|*.*|RECURSE
FileKey4=%CommonAppData%\Wondershare\DriverInstall|*.log
FileKey5=%CommonAppData%\Wondershare\WAF\Log|*.*|RECURSE
FileKey6=%CommonAppData%\Wondershare\WAF\ProductFeatures\*Logs|*.*|RECURSE
FileKey7=%CommonAppData%\Wondershare\WSRoot|*.tmp
FileKey8=%CommonAppData%\Wondershare\WSRoot\Logs|*.*|RECURSE
FileKey9=%CommonAppData%\WsAppHelper\Dr.Fone|*.log
FileKey10=%ProgramFiles%\Wondershare\MirrorGo\Log|*.*|RECURSE
Link to comment
- The latest version of REAL Player (v20.1.0.312, released in early May (???) 2022) has adopted a kind of Chrome like storage of (temporary) files. That requires some additional lines for "winapp.ini":
FileKey20=%LocalAppData%\Real\RealPlayer\EBWebview\Default\Code Cache\js\*.*
FileKey21=%LocalAppData%\Real\RealPlayer\EBWebview\Default\Cache\Cache_Data\*.*
FileKey20=%LocalAppData%\Real\RealPlayer\EBWebview\*.*
See also the picture attached:
System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc
A discussion always stimulates the braincells !!!
Link to comment
Had to improve the previous post in 2 ways. Am I correct that the "|" character indicates that CC should only look for files and not directories ?
FileKey20=%LocalAppData%\Real\RealPlayer\EBWebview\Default\Code Cache\js\|*.*
FileKey21=%LocalAppData%\Real\RealPlayer\EBWebview\Default\Cache\Cache_Data\|*.*
FileKey22=%LocalAppData%\Real\RealPlayer\EBWebview\|*.*
Link to comment
3 hours ago, Willy2 said:
... Am I correct that the "|" character indicates that CC should only look for files and not directories ? ...
The pipe symbol is just the separator for the file pattern. Directories are only deleted if |RECURSE or |REMOVESELF is also used.
Link to comment
1 hour ago, Winapp2.ini said:
Pardon my ignorance, but how am I to handle this via winapp2ool ?
Link to comment
Revised entry
This should be removed: %AppData%\Techsmith\Snagit\Preferences\Output\*|*.*|REMOVESELF
[Snagit *]
LangSecRef=3021
FileKey1=%CommonAppData%\TechSmith\Uploader|*.log
FileKey2=%Documents%|SnagitDebug.log
FileKey3=%Documents%\Snagit|*.snagx
FileKey4=%Documents%\Snagit\.metadata|*.*|RECURSE
FileKey5=%LocalAppData%\TechSmith\Logs|*.log
FileKey6=%LocalAppData%\TechSmith\Snagit|Tray.bin
FileKey7=%LocalAppData%\TechSmith\Snagit\*\NativeCrashReporting\Reports|*.dmp|RECURSE
FileKey8=%LocalAppData%\TechSmith\Snagit\*\WebView2Cache\EBWebView\*\GPUCache|*.*|REMOVESELF
FileKey9=%LocalAppData%\TechSmith\Snagit\CrashDumps|*.*|RECURSE
FileKey10=%LocalAppData%\TechSmith\Snagit\DataStore\AppIcons|*.ico
FileKey11=%LocalAppData%\TechSmith\Snagit\DataStore\WebSiteIcons|*.ico
FileKey12=%LocalAppData%\TechSmith\Snagit\Thumbnails|*.*|RECURSE
FileKey13=%LocalAppData%\TechSmith\Snagit\TrackerbirdFiles|*.log;*.logtmp
FileKey14=%Public%\TechSmith\Snagit\License|*.cache;*.log
Link to comment
Revised entry
Changed FileKey4 to |*.*|RECURSE
[Wondershare UniConverter *]
LangSecRef=3023
Detect1=HKLM\Software\Wondershare\Wondershare UniConverter
Detect2=HKLM\Software\Wondershare\Wondershare UniConverter 13
FileKey1=%CommonAppData%\Wondershare\ProductFeatures\*Logs|*.*|RECURSE
FileKey2=%CommonAppData%\Wondershare\UniConverter*\DataTrack|tmp;*.bak;*.log
FileKey3=%CommonAppData%\Wondershare\UniConverter*\TempThumbDir|*.*|RECURSE
FileKey4=%CommonAppData%\Wondershare\UniConverter*\UpdatePackge|*.*|RECURSE
FileKey5=%CommonAppData%\Wondershare\WAF\ProductFeatures\*Logs|*.*|RECURSE
FileKey6=%ProgramFiles%\Wondershare\*UniConverter*\Log|*.*|RECURSE
FileKey7=%Public%\Documents\Wondershare|*.*|REMOVESELF
FileKey8=%SystemDrive%|logWSVCUUpdateHelper.log
FileKey9=%SystemDrive%\Wondershare UniConverter\Downloaded\temp|*.*|REMOVESELF
FileKey10=%UserProfile%\.cache|*.*|REMOVESELF
Link to comment
  • 2 weeks later...
On 11/06/2022 at 10:48, Winapp2.ini said:
This work is nearing completion, take a look at the current diff between the latest available version and the next major update
a link to the plain text version of this is available in this comment; it is best viewed with a monowidth font (read: it's probably borderline unreadable without a monowidth font)
Link to comment
The latest release of Winapp2ool crashes when a Trim is attempted.  This is on both Windows 10x64 and Windows 11x64.
Link to comment
Here is the Event Viewer info when winapp2ool aborts.
Faulting application name: winapp2ool.exe, version: 1.5.8165.37514, time stamp: 0x627b0855
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc0000005
Fault offset: 0x00007ffbc7ba55de
Faulting process id: 0x4868
Faulting application start time: 0x01d8935db164fde8
Faulting application path: C:\Program Files\CCleaner\winapp2ool.exe
Faulting module path: unknown
Report Id: ae882961-c925-4d49-9257-2b2c82f76208
Faulting package full name:
Faulting package-relative application ID:
Link to comment
Register a new account
Sign in
Important Information
