siliconman01 Posted February 28 Share Posted February 28 It's a bit tricky to update to the latest Beta version of Winapp2ool.exe from the previous stable version. it had a few false starts before I got the latest beta to Trim properly. It kept trimming down to 6 cleaning modules. Everything else was Poof!. 1. Change Whitelist.ini to Includes.ini; Change Blacklist.ini to Excludes.ini 2. Install the latest beta v1.5.8448.28847 3. Restore all settings(7) to the default state. 4. Start selecting your desired settings 5. In the TRIM section (2), reset all the TRIM settings to the default state.(9). Then set your desired settings in the TRIM section. Now it trims properly., Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted February 28 Author Share Posted February 28 in 1.5, I fixed a few settings which weren't being properly saved/initialized to disk. it's likely that when the tool re-initalized after updating it corrupted the expected state of the settings (resetting the broken settings to default and producing unexpected behavior). I think Diff was most affected by this but it's possible Trim was as well. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
siliconman01 Posted March 1 Share Posted March 1 New entry: [Windows 11 Notepad *] [Windows 11 Notepad *] DetectOS=10.0| LangSecRef=3031 DetectFile=%LocalAppData%\Packages\Microsoft.WindowsNotepad_8wekyb3d8bbwe FileKey1=%LocalAppData%\Packages\Microsoft.WindowsNotepad_*\SystemAppData\Helium|User.dat Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
siliconman01 Posted March 2 Share Posted March 2 Modifed entry: [Samsung Magician *] Added FileKey9 and FileKey10 [Samsung Magician *] LangSecRef=3024 Detect=HKLM\Software\Samsung Magician FileKey1=%AppData%\Samsung Magician\GPUCache|*.*|REMOVESELF FileKey2=%AppData%\Samsung Magician\Local Storage\leveldb|*.old FileKey3=%AppData%\Samsung Magician\Session Storage|*.old FileKey4=%CommonAppData%\Samsung\Backup|*.exe FileKey5=%CommonAppData%\Samsung\Samsung Magician|*.exe;*.mdmp|RECURSE FileKey6=%CommonAppData%\Samsung\Samsung Magician\PB|*.txt FileKey7=%ProgramFiles%\Samsung Magician\Logs|*.* FileKey8=%ProgramFiles%\Samsung\Samsung Magician\Log*|*.* FileKey9=%ProgramFiles%\Samsung\Samsung Magician\MigrationService|*.log FileKey10=%ProgramFiles%\Samsung\Samsung Magician\MigrationService\Logs|*.* FileKey11=%SystemDrive%\MagicianPerf*|*.*|REMOVESELF RegKey1=HKCU\Software\Local AppWizard-Generated Applications\SamsungMagician Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
PICPro Posted March 2 Share Posted March 2 In Winapp2.ini 20230301 there is: [Windows Temporary Files *] LangSecRef=3025 Detect=HKLM\Software\Microsoft\Windows FileKey1=%SystemDrive%\Documents and Settings\LocalService*\Local Settings\Temp|*|RECURSE FileKey2=%SystemDrive%\Documents and Settings\NetworkService*\Local Settings\Temp|*|RECURSE FileKey3=%Temp%|*|REMOVESELF FileKey4=%WinDir%\ServiceProfiles\*\AppData\Local\Temp|*|REMOVESELF FileKey5=%WinDir%\System32\config\systemprofile\AppData\Local\Temp|*|REMOVESELF FileKey6=%WinDir%\System32\config\systemprofile\Local Settings\Temp|*|REMOVESELF FileKey7=%WinDir%\SystemTemp|*|REMOVESELF FileKey8=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Temp|*|REMOVESELF FileKey9=%WinDir%\TEMP|*|REMOVESELF Filekey3 will remove everything from the %Temp% folder. This can affect running, active applications. CCleaner already cleans this folder (System->Temporary Files) for files older than 24h by default or can clean it fully if the user changes the setting. Because some web browsers make temp files in %Temp%, and sometimes leave them behind, there is an argument for cleaning some temp files sooner, but it is probably better to make specific %Temp% cleaning rules for the leftover files from the application of interest that one wants to remove when cleaning and add them to their own custom.ini file. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted March 3 Moderators Share Posted March 3 New: [Sumatra PDF Portable *] LangSecRef=3021 DetectFile1=%SystemDrive%\PortableApps\SumatraPDFPortable\SumatraPDFPortable.exe FileKey1=%SystemDrive%\PortableApps\SumatraPDFPortable\Data\settings\sumatrapdfcache|*.* Link to comment Share on other sites More sharing options...
SMalik Posted March 4 Share Posted March 4 Revised entry Added: FileKey6 [Windows Installer *] LangSecRef=3025 Detect=HKLM\Software\Microsoft\Windows\CurrentVersion\Installer FileKey1=%SystemDrive%\Config.msi|*|REMOVESELF FileKey2=%WinDir%\Installer|*.tmp|RECURSE FileKey3=%WinDir%\Installer|SourceHash{*};wix{*}.SchedServiceConfig.rmi FileKey4=%WinDir%\Installer\Config.Msi|*|REMOVESELF FileKey5=%WinDir%\Installer\MSI*.tmp-|*|REMOVESELF FileKey6=%WinDir%\System32\config\systemprofile\AppData\Local|*.tmp|RECURSE Link to comment Share on other sites More sharing options...
siliconman01 Posted March 4 Share Posted March 4 New entry: [CloseAll - Close All Windows *] [CloseAll - Close All Windows *] LangSecRef=3024 Detect=HKLM\Software\Alexander Avdonin\CloseAll FileKey1=%ProgramFiles%\CloseAll|*.rtf;*.txt Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
siliconman01 Posted March 5 Share Posted March 5 New entry: [Display Driver Uninstaller Logs *] [Display Driver Uninstaller Logs *] LangSecRef=3024 DetectFile=%ProgramFiles%\Display Driver Uninstaller FileKey1=%ProgramFiles%\Display Driver Uninstaller\DDU Logs|*.* Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
siliconman01 Posted March 5 Share Posted March 5 On Windows 11, the user entered search variable is not cleared when CCleaner is executed. It is cleared on Windows 10. Anyone have a suggestion as to where this variable is located and what entry in Winapp2.ini needs to be adjusted? Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
siliconman01 Posted March 5 Share Posted March 5 Modified entry: [Dell *] Added FileKey3 [Dell *] LangSecRef=3024 Detect1=HKLM\Software\Dell Detect2=HKLM\Software\PC-Doctor DetectFile1=%AppData%\Creative\DELL Webcam Center DetectFile2=%CommonAppData%\Dell DetectFile3=%LocalAppData%\Dell DetectFile4=%LocalAppData%\SupportSoft\DellSupportCenter DetectFile5=%ProgramFiles%\Dell* FileKey1=%AppData%\Creative\DELL Webcam Center|MO_Log.txt FileKey2=%AppData%\PCDr\*\Logs|* FileKey3=%CommonAppData%\Dell\*|*.log FileKey4=%CommonAppData%\Dell\*\Log*|*|RECURSE FileKey5=%CommonAppData%\Dell\D3\pla\*\*|*.log;*.txt|REMOVESELF FileKey6=%CommonAppData%\Dell\D3\Resources\Logs\serilog|* FileKey7=%CommonAppData%\Dell\Drivers\*|*.log;*.tmp|RECURSE FileKey8=%CommonAppData%\Dell\orca\deviceq|* FileKey9=%CommonAppData%\Dell\SupportAssist|*|RECURSE FileKey10=%CommonAppData%\Dell\TrustedDevice|*.log FileKey11=%CommonAppData%\Dell\Update|*.txt FileKey12=%CommonAppData%\Dell\UpdateService|*.log;*.txt|RECURSE FileKey13=%CommonAppData%\PCDr\*\Logs|* FileKey14=%LocalAppData%\Dell\*\Log|* FileKey15=%LocalAppData%\Dell\DellMobileConnect|*.log FileKey16=%LocalAppData%\SupportSoft\DellSupportCenter\*\state\logs|* FileKey17=%ProgramFiles%\Dell*|*.log|RECURSE Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
APMichael Posted March 6 Share Posted March 6 21 hours ago, siliconman01 said: On Windows 11, the user entered search variable is not cleared when CCleaner is executed. It is cleared on Windows 10. Anyone have a suggestion as to where this variable is located and what entry in Winapp2.ini needs to be adjusted? The latest version of Notepad (11.2302.16.0) has unfortunately moved the search string from the file "User.dat" to the following file: %LocalAppData%\Packages\Microsoft.WindowsNotepad_*\Settings\settings.dat But beware, this brings back the problem that deleting the file also deletes all user settings! Link to comment Share on other sites More sharing options...
siliconman01 Posted March 6 Share Posted March 6 Thanks for the info, APMichael. Seems like the boys and girls at MS enjoy making it difficult to love Windows 11. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
APMichael Posted March 13 Share Posted March 13 On 02/03/2023 at 18:39, PICPro said: In Winapp2.ini 20230301 there is: [Windows Temporary Files *] LangSecRef=3025 Detect=HKLM\Software\Microsoft\Windows FileKey1=%SystemDrive%\Documents and Settings\LocalService*\Local Settings\Temp|*|RECURSE FileKey2=%SystemDrive%\Documents and Settings\NetworkService*\Local Settings\Temp|*|RECURSE FileKey3=%Temp%|*|REMOVESELF FileKey4=%WinDir%\ServiceProfiles\*\AppData\Local\Temp|*|REMOVESELF FileKey5=%WinDir%\System32\config\systemprofile\AppData\Local\Temp|*|REMOVESELF FileKey6=%WinDir%\System32\config\systemprofile\Local Settings\Temp|*|REMOVESELF FileKey7=%WinDir%\SystemTemp|*|REMOVESELF FileKey8=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Temp|*|REMOVESELF FileKey9=%WinDir%\TEMP|*|REMOVESELF Filekey3 will remove everything from the %Temp% folder. This can affect running, active applications. CCleaner already cleans this folder (System->Temporary Files) for files older than 24h by default or can clean it fully if the user changes the setting. ... I would also suggest that FileKey3 and especially FileKey9 should be removed as they are already cleaned up by CCleaner and other cleaning tools. In addition, the various Windows-owned Temp folders should not be removed using REMOVESELF, but only cleaned up using RECURSE. Otherwise, permission problems may occur here, as probably reported here: https://community.ccleaner.com/topic/64368-windows-installer-error-code2203-in-v60910300-winapp2ini-230301-win1122h2/. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted March 13 Author Share Posted March 13 Hi sorry I've been away, some business in real life has come up, as it seems to so often these days :( Just some small updates which I will elaborate on in longer form at a later date: I'm in the process of making some changes which require meaningful changes to Diff in winapp2ool to handle processing, which is why activity appears to have stopped. There is a pending set of changes that require that winapp2ool update to handle gracefully, although the current public version will handle them fine (albeit noisily). There's going to be some annoying overlap with CCleaner for the immediate future while I pivot how the file is maintained and built. The short version is it's going Non-CCleaner by default for the maintenance and then a CCleaner version similar to what has previously been default will be generated using winapp2ool. essentially. it is much easier to automate modifying a non-ccleaner file into a ccleaner version than the reverse which is how it is currently done and has been for a very long time. Part of a wider project which I will elaborate on later. I am taking note of the conflicts that arise with CCleaner, but for now most of the conflicting changes (ie. where ccleaner and winapp2.ini both target the same thing) will remain in place, as I am no intentionally longer avoiding these collisions. edit: of course, if something is a problem and not merely a conflict with CCleaner, I am trying to be proactive as well... winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
APMichael Posted March 13 Share Posted March 13 24 minutes ago, Winapp2.ini said: ... I am taking note of the conflicts that arise with CCleaner, but for now most of the conflicting changes (ie. where ccleaner and winapp2.ini both target the same thing) will remain in place, as I am no intentionally longer avoiding these collisions. edit: of course, if something is a problem and not merely a conflict with CCleaner, I am trying to be proactive as well... Thank you for your reply. Ok, for me this is no problem in principle, if there are overlaps with CCleaner's built-in cleanup rules. To fix the possible problems with the entry [Windows Temporary Files *], it should probably also be sufficient to replace all REMOVESELF with RECURSE. Link to comment Share on other sites More sharing options...
GhostMotley Posted March 15 Share Posted March 15 On 13/03/2023 at 13:11, APMichael said: I would also suggest that FileKey3 and especially FileKey9 should be removed as they are already cleaned up by CCleaner and other cleaning tools. In addition, the various Windows-owned Temp folders should not be removed using REMOVESELF, but only cleaned up using RECURSE. Otherwise, permission problems may occur here, as probably reported here: https://community.ccleaner.com/topic/64368-windows-installer-error-code2203-in-v60910300-winapp2ini-230301-win1122h2/. Thank you for this, I've been reinstalling Windows 11 over the last few hours and it would constantly brick. In Winapp2, I changed things to the following [Windows Temporary Files *] LangSecRef=3025 Detect=HKLM\Software\Microsoft\Windows FileKey1=%SystemDrive%\Documents and Settings\LocalService*\Local Settings\Temp|*|RECURSE FileKey2=%SystemDrive%\Documents and Settings\NetworkService*\Local Settings\Temp|*|RECURSE FileKey3=%WinDir%\ServiceProfiles\*\AppData\Local\Temp|*|RECURSE FileKey4=%WinDir%\System32\config\systemprofile\AppData\Local\Temp|*|RECURSE FileKey5=%WinDir%\System32\config\systemprofile\Local Settings\Temp|*|RECURSE FileKey6=%WinDir%\SystemTemp|*|RECURSE FileKey7=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Temp|*|RECURSE And have run CCleaner several times and have been able to install applications without Error 2203. Before Error 2203 would always come up and even after trying sfc /scannow, changing permissions and even doing a full Windows feature upgrade, I could not resolve the error. Link to comment Share on other sites More sharing options...
siliconman01 Posted March 16 Share Posted March 16 The new Winapp2.ini release does not appear to include any of the recently posted changes on this forum. Does that mean they are rejected or what? Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
APMichael Posted March 16 Share Posted March 16 3 hours ago, siliconman01 said: The new Winapp2.ini release does not appear to include any of the recently posted changes on this forum. Does that mean they are rejected or what? It was just a hot fix for the [Windows Temporary Files *] entry, as this one causes serious problems: The entry not only cleaned up the temp folders, but also deleted the temp folders themselves. However, the new temp folders automatically recreated by Windows then no longer have their original permissions and owners. 11 hours ago, GhostMotley said: ... And have run CCleaner several times and have been able to install applications without Error 2203. Before Error 2203 would always come up and even after trying sfc /scannow, changing permissions and even doing a full Windows feature upgrade, I could not resolve the error. Thank you for your confirmation that this is causing the problems. Unfortunately, Windows' self-healing capabilities are in great need of improvement. Microsoft should definitely improve SFC! Link to comment Share on other sites More sharing options...
Winapp2.ini Posted March 16 Author Share Posted March 16 15 hours ago, GhostMotley said: Thank you for this, I've been reinstalling Windows 11 over the last few hours and it would constantly brick. In Winapp2, I changed things to the following [Windows Temporary Files *] LangSecRef=3025 Detect=HKLM\Software\Microsoft\Windows FileKey1=%SystemDrive%\Documents and Settings\LocalService*\Local Settings\Temp|*|RECURSE FileKey2=%SystemDrive%\Documents and Settings\NetworkService*\Local Settings\Temp|*|RECURSE FileKey3=%WinDir%\ServiceProfiles\*\AppData\Local\Temp|*|RECURSE FileKey4=%WinDir%\System32\config\systemprofile\AppData\Local\Temp|*|RECURSE FileKey5=%WinDir%\System32\config\systemprofile\Local Settings\Temp|*|RECURSE FileKey6=%WinDir%\SystemTemp|*|RECURSE FileKey7=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Temp|*|RECURSE And have run CCleaner several times and have been able to install applications without Error 2203. Before Error 2203 would always come up and even after trying sfc /scannow, changing permissions and even doing a full Windows feature upgrade, I could not resolve the error. has dism been any help? dism /online /cleanup-image /restorehealth winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
APMichael Posted March 17 Share Posted March 17 @Winapp2.ini Another problematic side effect from merging: All [... Cookies *] entries for the different browsers delete the stored passwords, because they delete the file "Login Data"! A separate entry is urgently required here in each case. Thanks in advance. Link to comment Share on other sites More sharing options...
PICPro Posted March 17 Share Posted March 17 On 16/03/2023 at 03:22, APMichael said: It was just a hot fix for the [Windows Temporary Files *] entry, as this one causes serious problems: The entry not only cleaned up the temp folders, but also deleted the temp folders themselves. However, the new temp folders automatically recreated by Windows then no longer have their original permissions and owners. Just a note for people using version 230316 that the "non-ccleaner" version of winapp2.ini still has the problematic [Windows Temporary Files *] so be careful and check. Link to comment Share on other sites More sharing options...
fierycloud Posted March 18 Share Posted March 18 On 16/03/2023 at 22:17, Winapp2.ini said: has dism been any help? dism /online /cleanup-image /restorehealth In my case, it still got error code 2203 after "DISM /Online /Cleanup-Image /RestoreHealth" and "sfc /scannow". 10 hours ago, APMichael said: @Winapp2.ini Another problematic side effect from merging: All [... Cookies *] entries for the different browsers delete the stored passwords, because they delete the file "Login Data"! A separate entry is urgently required here in each case. Thanks in advance. I used to wonder that if the chrome related google login status changes, it seemed to be in the "search engine data" before march version, but is in the "Auto Fill Data" after March. But I just found that the code edit seem to be made till Dec 5, 2022 . Quote https://github.com/MoscaDotTo/Winapp2/commit/27115f9138f682ed4b584c3ba04d971ea0c5a838 moved to [Auto Fill Data *]FileKey1=%LocalAppData%\Chromium\User Data\*|Web Data FileKey2=%LocalAppData%\CocCoc\Browser\User Data\*|Web Data FileKey3=%LocalAppData%\Comodo\Dragon\User Data\*|Web Data FileKey4=%LocalAppData%\Epic Privacy Browser\User Data\*|Web Data FileKey5=%LocalAppData%\Google\Chrome*\User Data\*|Web Data FileKey6=%LocalAppData%\Iridium\User Data\*|Web Data FileKey7=%LocalAppData%\Slimjet\User Data\*|Web Data FileKey8=%LocalAppData%\Yandex\YandexBrowser\User Data\*|Web Data moved from [Search Engines Data *] LangSecRef=3029 Detect1=HKCU\Software\Chromium\PreferenceMACs Detect2=HKCU\Software\CocCoc\Browser Detect3=HKCU\Software\Comodo\Dragon Detect4=HKCU\Software\Epic Privacy Browser Detect5=HKCU\Software\Iridium Detect6=HKCU\Software\Slimjet Detect7=HKCU\Software\Yandex\YandexBrowser DetectFile=%LocalAppData%\Google\Chrome* Warning=This also removes all AutoFill data ("Saved Form Information"). FileKey1=%LocalAppData%\Chromium\User Data\*|Web Data FileKey2=%LocalAppData%\CocCoc\Browser\User Data\*|Web Data FileKey3=%LocalAppData%\Comodo\Dragon\User Data\*|Web Data FileKey4=%LocalAppData%\Epic Privacy Browser\User Data\*|Web Data FileKey5=%LocalAppData%\Google\Chrome*\User Data\*|Web Data FileKey6=%LocalAppData%\Iridium\User Data\*|Web Data FileKey7=%LocalAppData%\Slimjet\User Data\*|Web Data FileKey8=%LocalAppData%\Yandex\YandexBrowser\User Data\*|Web Data Link to comment Share on other sites More sharing options...
GhostMotley Posted March 18 Share Posted March 18 On 16/03/2023 at 14:17, Winapp2.ini said: has dism been any help? dism /online /cleanup-image /restorehealth Hello, unfortunately it didn't. I tried the below multiple times and restarted in between runs, no success. Dism.exe /Online /Cleanup-Image /AnalyzeComponentStore DISM.exe /online /Cleanup-Image /StartComponentCleanup DISM.exe /online /Cleanup-Image /SPSuperseded DISM.exe /online /Cleanup-Image /StartComponentCleanup /ResetBase Dism /Online /Cleanup-Image /ScanHealth Dism /Online /Cleanup-Image /CheckHealth Dism /Online /Cleanup-Image /RestoreHealth sfc /scannow Link to comment Share on other sites More sharing options...
SMalik Posted March 21 Share Posted March 21 I think we should have a separate entry for Intel Driver and Support Assistant [Intel Driver and Support Assistant *] LangSecRef=3024 Detect=HKCU\Software\Intel\Driver and Support Assistant FileKey1=%CommonAppData%\Intel\DSA\Logs|*.bak;*.log;*.txt FileKey2=%CommonAppData%\Intel\GCC|*.txt FileKey3=%CommonAppData%\Intel\Intel Extreme Tuning Utility\Logs|*.*|RECURSE FileKey4=%CommonAppData%\Intel\Logs|*.*|RECURSE FileKey5=%WinDir%\System32\config\systemprofile\AppData\Local\Intel\GCC|*.txt Link to comment Share on other sites More sharing options...
