Winapp2.ini Posted August 24, 2023 Author Share Posted August 24, 2023 Looking into this - I have been traveling for family matters for several weeks without access to my devices, apologies for the radio silence on this. The duplicate entry will also be fixed shortly. Thank you for your patience. The application FileActivityWatch can be helpful in narrowing down things like this. I also suspect /AC/ directory cleaning may be too aggressive - I only use a local account and did not encounter and issues during testing before pushing those changes. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
APMichael Posted August 26, 2023 Share Posted August 26, 2023 @Winapp2.ini Thank you for your reply. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 26, 2023 Author Share Posted August 26, 2023 I can duplicate this using a roaming account. Still trying to narrow down the exact cause of the issue. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
siliconman01 Posted August 29, 2023 Share Posted August 29, 2023 On both my Windows 10x64 Pro and Windows 11x64 Pro systems, I run only a local user account. My personal logon/account picture on these systems is stored in the Pictures folder of my user account. In CCleaner, if I have Applications>Windows>[Windows Subsystems *] active/checkmarked, it causes the picture to display as the "no picture at all" icon. It does not corrupt or remove my account/logon picture from the Pictures folder. I do get an error message if I try to restore the picture via Settings>Acounts>Your Info. This error goes away on system reboot. I have no idea what code Windows Subsystems is causing this problem. [Windows Subsystems *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows FileKey1=%LocalAppData%\Microsoft\Windows Sidebar\Cache|*|RECURSE FileKey2=%LocalAppData%\Microsoft\Windows\AppCache|*|RECURSE FileKey3=%LocalAppData%\Microsoft\Windows\SettingSync\metastore|*.jrs FileKey4=%LocalAppData%\Microsoft\Windows\SettingSync\remotemetastore\*|*.jrs FileKey5=%LocalAppData%\Microsoft\Windows\WebCache|*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.Windows.CloudExperienceHost_*\AC|*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.Windows.CloudExperienceHost_*\LocalCache|*|RECURSE FileKey8=%LocalAppData%\Packages\Microsoft.Windows.CloudExperienceHost_*\LocalState\Cache|*|RECURSE FileKey9=%LocalAppData%\Packages\Microsoft.Windows.CloudExperienceHost_*\Settings|*.log* FileKey10=%LocalAppData%\Packages\Microsoft.Windows.CloudExperienceHost_*\TempState|*|RECURSE FileKey11=%ProgramData%\Microsoft\RAC\PublishedData|*.log;*.jrs FileKey12=%ProgramData%\Microsoft\RAC\StateData|*.log;*.jrs FileKey13=%ProgramData%\Microsoft\RAC\Temp|* FileKey14=%ProgramData%\Microsoft\Windows\DeviceMetadataCache\dmrccache.bak|*|REMOVESELF FileKey15=%ProgramData%\Microsoft\Windows\Sqm\Manifest|*.bin FileKey16=%ProgramData%\Microsoft\Windows\Sqm\Sessions|*.psqm;*.sqm FileKey17=%SystemDrive%\Documents and Settings\LocalService\Application Data\PeerNetworking|*|RECURSE FileKey18=%UserProfile%\Documents\Remote Assistance Logs|*.xml FileKey19=%WinDir%\$regcmp$|*|REMOVESELF FileKey20=%WinDir%\ehome|PRDMOWrapper.log FileKey21=%WinDir%\msdownld.tmp|*|REMOVESELF FileKey22=%WinDir%\ServiceProfiles\LocalService\AppData\Local\Microsoft\Windows|qwavecache.dat FileKey23=%WinDir%\ServiceProfiles\LocalService\AppData\Roaming\PeerNetworking|*|RECURSE FileKey24=%WinDir%\ServiceProfiles\NetworkService\AppData\Local\PeerDist*|*.chk;*.jrs FileKey25=%WinDir%\System32|PRDMOWrapper.log;qwavecache.dat FileKey26=%WinDir%\System32\config\systemprofile\AppData\Local\Microsoft\Device Metadata\dmrccache\downloads|*.tmp FileKey27=%WinDir%\System32\config\systemprofile\AppData\Local\tw-*.tmp|empty.check|REMOVESELF FileKey28=%WinDir%\System32\sru|*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\MuiCache RegKey2=HKCU\Software\Classes\MIME\Database\Content Type RegKey3=HKCU\Software\Local AppWizard-Generated Applications RegKey4=HKCU\Software\Microsoft\Keyboard\Native Media Players RegKey5=HKCU\Software\Microsoft\Windows\Shell\MUICache RegKey6=HKCU\Software\Microsoft\Windows\ShellNoRoam\MUICache RegKey7=HKLM\Software\Microsoft\ESENT\Process RegKey8=HKLM\Software\Microsoft\Windows\CurrentVersion\Explorer\VolumeCaches\Active Setup Temp Folders|Folder RegKey9=HKLM\Software\Microsoft\Windows\CurrentVersion\Setup|Installation Sources RegKey10=HKLM\Software\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\VolumeCaches\Active Setup Temp Folders|Folder Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 8940 PC and Dell XPS 16 9640 Laptop. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 29, 2023 Author Share Posted August 29, 2023 probably FileKey6=%LocalAppData%\Packages\Microsoft.Windows.CloudExperienceHost_*\AC|*|RECURSE of the issues, this is the one I can reproduce most consistently. Probably the .tbacctpic* files in \AC\TokenBroker\Accounts winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
siliconman01 Posted August 29, 2023 Share Posted August 29, 2023 51 minutes ago, Winapp2.ini said: probably FileKey6=%LocalAppData%\Packages\Microsoft.Windows.CloudExperienceHost_*\AC|*|RECURSE of the issues, this is the one I can reproduce most consistently. Probably the .tbacctpic* files in \AC\TokenBroker\Accounts Yep, FileKey6 does appear to cause the problem with the pic. I took it out and tested it on my Win10 and Win11 systems. Thanks very much for the solution. It's been bugging me for weeks. [Windows Subsystems *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows FileKey1=%LocalAppData%\Microsoft\Windows Sidebar\Cache|*|RECURSE FileKey2=%LocalAppData%\Microsoft\Windows\AppCache|*|RECURSE FileKey3=%LocalAppData%\Microsoft\Windows\SettingSync\metastore|*.jrs FileKey4=%LocalAppData%\Microsoft\Windows\SettingSync\remotemetastore\*|*.jrs FileKey5=%LocalAppData%\Microsoft\Windows\WebCache|*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.Windows.CloudExperienceHost_*\LocalCache|*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.Windows.CloudExperienceHost_*\LocalState\Cache|*|RECURSE FileKey8=%LocalAppData%\Packages\Microsoft.Windows.CloudExperienceHost_*\Settings|*.log* FileKey9=%LocalAppData%\Packages\Microsoft.Windows.CloudExperienceHost_*\TempState|*|RECURSE FileKey10=%ProgramData%\Microsoft\RAC\PublishedData|*.log;*.jrs FileKey11=%ProgramData%\Microsoft\RAC\StateData|*.log;*.jrs FileKey12=%ProgramData%\Microsoft\RAC\Temp|* FileKey13=%ProgramData%\Microsoft\Windows\DeviceMetadataCache\dmrccache.bak|*|REMOVESELF FileKey14=%ProgramData%\Microsoft\Windows\Sqm\Manifest|*.bin FileKey15=%ProgramData%\Microsoft\Windows\Sqm\Sessions|*.psqm;*.sqm FileKey16=%SystemDrive%\Documents and Settings\LocalService\Application Data\PeerNetworking|*|RECURSE FileKey17=%UserProfile%\Documents\Remote Assistance Logs|*.xml FileKey18=%WinDir%\$regcmp$|*|REMOVESELF FileKey19=%WinDir%\ehome|PRDMOWrapper.log FileKey20=%WinDir%\msdownld.tmp|*|REMOVESELF FileKey21=%WinDir%\ServiceProfiles\LocalService\AppData\Local\Microsoft\Windows|qwavecache.dat FileKey22=%WinDir%\ServiceProfiles\LocalService\AppData\Roaming\PeerNetworking|*|RECURSE FileKey23=%WinDir%\ServiceProfiles\NetworkService\AppData\Local\PeerDist*|*.chk;*.jrs FileKey24=%WinDir%\System32|PRDMOWrapper.log;qwavecache.dat FileKey25=%WinDir%\System32\config\systemprofile\AppData\Local\Microsoft\Device Metadata\dmrccache\downloads|*.tmp FileKey26=%WinDir%\System32\config\systemprofile\AppData\Local\tw-*.tmp|empty.check|REMOVESELF FileKey27=%WinDir%\System32\sru|*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\MuiCache RegKey2=HKCU\Software\Classes\MIME\Database\Content Type RegKey3=HKCU\Software\Local AppWizard-Generated Applications RegKey4=HKCU\Software\Microsoft\Keyboard\Native Media Players RegKey5=HKCU\Software\Microsoft\Windows\Shell\MUICache RegKey6=HKCU\Software\Microsoft\Windows\ShellNoRoam\MUICache RegKey7=HKLM\Software\Microsoft\ESENT\Process RegKey8=HKLM\Software\Microsoft\Windows\CurrentVersion\Explorer\VolumeCaches\Active Setup Temp Folders|Folder RegKey9=HKLM\Software\Microsoft\Windows\CurrentVersion\Setup|Installation Sources RegKey10=HKLM\Software\Wow6432Node\Microsoft\Windows\CurrentVersion\Explorer\VolumeCaches\Active Setup Temp Folders|Folder Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 8940 PC and Dell XPS 16 9640 Laptop. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
siliconman01 Posted August 30, 2023 Share Posted August 30, 2023 Thanks for the Winapp2.ini update. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 8940 PC and Dell XPS 16 9640 Laptop. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
siliconman01 Posted September 3, 2023 Share Posted September 3, 2023 Is Winapp2ool.ini version 1.5.8000.34368 considered a beta release or a public release? Reason for my question is that my older brother's Winapp2ool.ini does not offer to update to 1.5.8000.34368 (he is not set to accept beta updates). Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 8940 PC and Dell XPS 16 9640 Laptop. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
APMichael Posted September 3, 2023 Share Posted September 3, 2023 JFYI: @Winapp2.ini has released another Winapp2.ini update (v230901). Link to comment Share on other sites More sharing options...
SMalik Posted September 3, 2023 Share Posted September 3, 2023 Revised Entry [Windows Shell - Folder View Settings *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\BagMRU RegKey2=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags RegKey3=HKCU\Software\Microsoft\Windows\ShellNoRoam\BagMRU RegKey4=HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags On XP: HKCU\Software\Microsoft\Windows\ShellNoRoam\BagMRU HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags Windows after XP: HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\BagMRU HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags Removed unnecessary: HKCU\Software\Classes\Wow6432Node\Local Settings\Software\Microsoft\Windows\Shell\BagMRU HKCU\Software\Classes\Wow6432Node\Local Settings\Software\Microsoft\Windows\Shell\Bags https://www.jeroentielen.nl/explaining-the-bagsbagmru-registry-tree-trying/ New Entries [Windows Shell - Desktop View Settings *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Warning=This will reset Desktop view settings to default. RegKey1=HKCU\Software\Microsoft\Windows\Shell\BagMRU RegKey2=HKCU\Software\Microsoft\Windows\Shell\Bags This resets Desktop view settings to default. Also removes history of previously removed Desktop shortcuts. [Notification Area Icons Cache *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows RegKey1=HKEY_CURRENT_USER\Control Panel\NotifyIconSettings RegKey2=HKEY_CURRENT_USER\SOFTWARE\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\TrayNotify Link to comment Share on other sites More sharing options...
Winapp2.ini Posted September 5, 2023 Author Share Posted September 5, 2023 On 03/09/2023 at 03:44, siliconman01 said: Is Winapp2ool.ini version 1.5.8000.34368 considered a beta release or a public release? Reason for my question is that my older brother's Winapp2ool.ini does not offer to update to 1.5.8000.34368 (he is not set to accept beta updates). 1.5.8000.34368 is indeed intended to be public, I neglected to build the application for release. I will fix this soon winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
PICPro Posted September 6, 2023 Share Posted September 6, 2023 There are a couple of issues in [Firefox Caches*] in winapp2.ini in version 290901. 1. "xulstore.json" has been included for deletion in the %AppData% profiles. Deleting xulstore.json causes the menu bar setting to be lost in Firefox, FirefoxESR, Librewolf, Palemoon, etc. and the status bar view settings in Palemoon. This file doesn't contain personal data or urls or other privacy related issues that I can tell. It is just for maintaining the toolbar presence and window locations. I think that xulstore.json should be removed from those lists (FileKey2, 8, 14, 20, 26, 32, 38) 2. Basilisk is included in the %LocalAppData% FileKeys (FileKey43, 44, 45). Basilisk is not included in the %AppData% FileKeys with the other browsers. Basilisk should be added back in here starting at FileKey7 and can have the same treatment the same as Palemoon. This browser is back in active development now for some time. Thank you. Link to comment Share on other sites More sharing options...
PICPro Posted September 6, 2023 Share Posted September 6, 2023 Also xulstore.json in FileKey60 of [Firefox Caches *] in Winapp2.ini. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted September 6, 2023 Author Share Posted September 6, 2023 5 hours ago, PICPro said: There are a couple of issues in [Firefox Caches*] in winapp2.ini in version 290901. 1. "xulstore.json" has been included for deletion in the %AppData% profiles. Deleting xulstore.json causes the menu bar setting to be lost in Firefox, FirefoxESR, Librewolf, Palemoon, etc. and the status bar view settings in Palemoon. This file doesn't contain personal data or urls or other privacy related issues that I can tell. It is just for maintaining the toolbar presence and window locations. I think that xulstore.json should be removed from those lists (FileKey2, 8, 14, 20, 26, 32, 38) 2. Basilisk is included in the %LocalAppData% FileKeys (FileKey43, 44, 45). Basilisk is not included in the %AppData% FileKeys with the other browsers. Basilisk should be added back in here starting at FileKey7 and can have the same treatment the same as Palemoon. This browser is back in active development now for some time. Thank you. noted re: xulstore.json, I have had to delete this file in the past to fix broken view settings and thought that perhaps it generally is automatically generated based on my testing but as always, many are the browser configurations . it's not my intention that the mainline winapp2.ini file include "corrective" deletion routines for stuff like this! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
PICPro Posted September 7, 2023 Share Posted September 7, 2023 4 hours ago, Winapp2.ini said: noted re: xulstore.json, I have had to delete this file in the past to fix broken view settings and thought that perhaps it generally is automatically generated based on my testing but as always, many are the browser configurations . xulstore.json is automatically regenerated if deleted, however, since the previous contents are lost that had view and position setting, the newly generated file has the firefox defaults like after a fresh install. The customization of the View->Toolbar settings are lost along with some window dimensions. It makes sense to delete it if it is corrupt, and then re-set things up. But this isn't something that you would want to clear when cleaning up cached items. Link to comment Share on other sites More sharing options...
siliconman01 Posted September 7, 2023 Share Posted September 7, 2023 On 05/09/2023 at 09:36, Winapp2.ini said: 1.5.8000.34368 is indeed intended to be public, I neglected to build the application for release. I will fix this soon Thanks. Please let us know when it is updated so I work with my older brother via DUO to update his system. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 8940 PC and Dell XPS 16 9640 Laptop. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
CSGalloway Posted September 7, 2023 Share Posted September 7, 2023 This is from another cleaner so i'd like to get an entry written for CCleaner winapp2.ini please: Run external command: taskkill.exe /f /IM explorer.exe ?B Delete 24B C:\Users\csgal\AppData\Local\Microsoft\Windows\Explorer\thumbcache_1280.db Delete 1MB C:\Users\csgal\AppData\Local\Microsoft\Windows\Explorer\thumbcache_16.db Delete 24B C:\Users\csgal\AppData\Local\Microsoft\Windows\Explorer\thumbcache_1920.db Delete 1MB C:\Users\csgal\AppData\Local\Microsoft\Windows\Explorer\thumbcache_256.db Delete 24B C:\Users\csgal\AppData\Local\Microsoft\Windows\Explorer\thumbcache_2560.db Delete 1MB C:\Users\csgal\AppData\Local\Microsoft\Windows\Explorer\thumbcache_32.db Delete 24B C:\Users\csgal\AppData\Local\Microsoft\Windows\Explorer\thumbcache_48.db Delete 24B C:\Users\csgal\AppData\Local\Microsoft\Windows\Explorer\thumbcache_768.db Delete 1MB C:\Users\csgal\AppData\Local\Microsoft\Windows\Explorer\thumbcache_96.db Delete 24B C:\Users\csgal\AppData\Local\Microsoft\Windows\Explorer\thumbcache_custom_stream.db Delete 24B C:\Users\csgal\AppData\Local\Microsoft\Windows\Explorer\thumbcache_exif.db Delete 7.4kB C:\Users\csgal\AppData\Local\Microsoft\Windows\Explorer\thumbcache_idx.db Delete 24B C:\Users\csgal\AppData\Local\Microsoft\Windows\Explorer\thumbcache_sr.db Delete 24B C:\Users\csgal\AppData\Local\Microsoft\Windows\Explorer\thumbcache_wide.db Delete 24B C:\Users\csgal\AppData\Local\Microsoft\Windows\Explorer\thumbcache_wide_alternate.db Run external command: C:\WINDOWS\explorer.exe C:\WINDOWS\explorer.exe ?B Link to comment Share on other sites More sharing options...
Winapp2.ini Posted September 7, 2023 Author Share Posted September 7, 2023 2 hours ago, CSGalloway said: This is from another cleaner so i'd like to get an entry written for CCleaner winapp2.ini please: Run external command: taskkill.exe /f /IM explorer.exe ?B Delete 24B C:\Users\csgal\AppData\Local\Microsoft\Windows\Explorer\thumbcache_1280.db Delete 1MB C:\Users\csgal\AppData\Local\Microsoft\Windows\Explorer\thumbcache_16.db Delete 24B C:\Users\csgal\AppData\Local\Microsoft\Windows\Explorer\thumbcache_1920.db Delete 1MB C:\Users\csgal\AppData\Local\Microsoft\Windows\Explorer\thumbcache_256.db Delete 24B C:\Users\csgal\AppData\Local\Microsoft\Windows\Explorer\thumbcache_2560.db Delete 1MB C:\Users\csgal\AppData\Local\Microsoft\Windows\Explorer\thumbcache_32.db Delete 24B C:\Users\csgal\AppData\Local\Microsoft\Windows\Explorer\thumbcache_48.db Delete 24B C:\Users\csgal\AppData\Local\Microsoft\Windows\Explorer\thumbcache_768.db Delete 1MB C:\Users\csgal\AppData\Local\Microsoft\Windows\Explorer\thumbcache_96.db Delete 24B C:\Users\csgal\AppData\Local\Microsoft\Windows\Explorer\thumbcache_custom_stream.db Delete 24B C:\Users\csgal\AppData\Local\Microsoft\Windows\Explorer\thumbcache_exif.db Delete 7.4kB C:\Users\csgal\AppData\Local\Microsoft\Windows\Explorer\thumbcache_idx.db Delete 24B C:\Users\csgal\AppData\Local\Microsoft\Windows\Explorer\thumbcache_sr.db Delete 24B C:\Users\csgal\AppData\Local\Microsoft\Windows\Explorer\thumbcache_wide.db Delete 24B C:\Users\csgal\AppData\Local\Microsoft\Windows\Explorer\thumbcache_wide_alternate.db Run external command: C:\WINDOWS\explorer.exe C:\WINDOWS\explorer.exe ?B winapp2.ini cannot stop programs or services so cannot clean things that require it automatically winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
APMichael Posted September 7, 2023 Share Posted September 7, 2023 6 hours ago, CSGalloway said: This is from another cleaner so i'd like to get an entry written for CCleaner winapp2.ini please: Run external command: taskkill.exe /f /IM explorer.exe ?B Delete 24B C:\Users\csgal\AppData\Local\Microsoft\Windows\Explorer\thumbcache_1280.db ... This is already cleaned up by CCleaner's built-in cleanup rule [Thumbnail Cache]. Sometimes the files are locked, but basically they can be cleaned with it. Link to comment Share on other sites More sharing options...
CSGalloway Posted September 7, 2023 Share Posted September 7, 2023 Might be off-topic but one system had a RunProgram verb - I thought it was CCleaner but maybe i am wrong Link to comment Share on other sites More sharing options...
Moderators Andavari Posted September 10, 2023 Moderators Share Posted September 10, 2023 Should this be added into Microsoft Edge Chromium cleaning? Don't know if it's safe to clean or not, but I've been nuking it on my system with no ill effects. Would need someone else to test and verify if it should or shouldn't be cleaned before it's just blindly added into the community winapp2.ini. "C:\Users\UserProfileName\AppData\Local\Microsoft\Edge\User Data\Module Info Cache" [Edge Module Info Cache *] LangSecRef=3006 DetectFile=%LocalAppData%\Microsoft\Edge* FileKey1=%LocalAppData%\Microsoft\Edge*\User Data\|Module Info Cache Link to comment Share on other sites More sharing options...
PICPro Posted September 12, 2023 Share Posted September 12, 2023 I agree that "Module Info Cache" should be deleted. I don't find any harm in deleting it. Since it may affect some aspect of the browsers that I don't use, hopefully others can test this too. Other Chromium based browsers have this file too. For for Vivaldi, the path is: %LocalAppData%\Vivaldi\User Data|Module Info Cache For Opera, the path is: %AppData%\Opera Software\Opera Stable|Module Info Cache OperaGX is similar. I don't have Google Chrome to test with. The file contains paths and filenames to many of the installed programs and Windows files. If you use a sophisticated text editor like Notepad++, and turn off the control and non-printing characters and set the text encoding, you can easily view the plain text portion of the file. Vivaldi recreates "Module Info Cache" when a non-private window is closed. Opera recreates the file when a URL is loaded, even in a private window. The newly recreated files were significantly smaller. Because this file may contain references to programs that have been uninstalled or files that may have been deleted, it represents a small privacy risk. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted September 12, 2023 Moderators Share Posted September 12, 2023 2 hours ago, PICPro said: Because this file may contain references to programs that have been uninstalled or files that may have been deleted, it represents a small privacy risk. That's why I started having CCleaner delete it, seemed odd it would have references to other programs, etc. It was somewhat alarming seeing all the stuff it had inside it, and is perplexing why a browser would even need to keep a cache like that. Seems sort of like some data-mining for profiling the user, they all want our data at no cost. Link to comment Share on other sites More sharing options...
siliconman01 Posted September 14, 2023 Share Posted September 14, 2023 Modified entry: [Snagit *] Added FileKey8 [Snagit *] LangSecRef=3021 Detect=HKCU\Software\TechSmith\Snagit FileKey1=%LocalAppData%\TechSmith\Logs|*.log FileKey2=%LocalAppData%\TechSmith\Snagit|Tray.bin FileKey3=%LocalAppData%\TechSmith\Snagit\*\NativeCrashReporting\Reports|*.dmp|RECURSE FileKey4=%LocalAppData%\TechSmith\Snagit\*\WebView2Cache\EBWebView\*\GPUCache|*|REMOVESELF FileKey5=%LocalAppData%\TechSmith\Snagit\CrashDumps|*|RECURSE FileKey6=%LocalAppData%\TechSmith\Snagit\DataStore\AppIcons|*.ico FileKey7=%LocalAppData%\TechSmith\Snagit\DataStore\WebSiteIcons|*.ico FileKey8=%LocalAppData%\TechSmith\Snagit\License|*.log FileKey9=%LocalAppData%\TechSmith\Snagit\Thumbnails|*|RECURSE FileKey10=%LocalAppData%\TechSmith\Snagit\TrackerbirdFiles|*.log* FileKey11=%ProgramData%\TechSmith\Uploader|*.log FileKey12=%Public%\TechSmith\Snagit\License|*.cache;*.log FileKey13=%UserProfile%\Documents|SnagitDebug.log FileKey14=%UserProfile%\Documents\Snagit|*.snagx FileKey15=%UserProfile%\Documents\Snagit\.metadata|*|RECURSE RegKey1=HKCU\Software\TechSmith\Snagit\9|StampCustomFolder RegKey2=HKCU\Software\TechSmith\Snagit\10|StampCustomFolder RegKey3=HKCU\Software\TechSmith\Snagit\11|CaptureCount RegKey4=HKCU\Software\TechSmith\Snagit\11|CaptureOpenCount RegKey5=HKCU\Software\TechSmith\Snagit\11|OutputDirLastUsed RegKey6=HKCU\Software\TechSmith\Snagit\11|VidOutputDirLastUsed RegKey7=HKCU\Software\TechSmith\Snagit\11\SnagItEditor\Tray|Thumbnailsize RegKey8=HKCU\Software\TechSmith\Snagit\12|CaptureCount RegKey9=HKCU\Software\TechSmith\Snagit\12|CaptureOpenCount RegKey10=HKCU\Software\TechSmith\Snagit\12|OutputDirLastUsed RegKey11=HKCU\Software\TechSmith\Snagit\12|VidOutputDirLastUsed RegKey12=HKCU\Software\TechSmith\Snagit\12\SnagItEditor\Tray|Thumbnailsize RegKey13=HKCU\Software\TechSmith\Snagit\13|CaptureCount RegKey14=HKCU\Software\TechSmith\Snagit\13|CaptureOpenCount RegKey15=HKCU\Software\TechSmith\Snagit\13|OutputDirLastUsed RegKey16=HKCU\Software\TechSmith\Snagit\13|VidOutputDirLastUsed RegKey17=HKCU\Software\TechSmith\Snagit\13\Recent Captures RegKey18=HKCU\Software\TechSmith\Snagit\13\SnagitEditor\Recent File List RegKey19=HKCU\Software\TechSmith\Snagit\13\SnagItEditor\Tray|Thumbnailsize RegKey20=HKCU\Software\TechSmith\Snagit\18|CaptureCount RegKey21=HKCU\Software\TechSmith\Snagit\18|CaptureOpenCount RegKey22=HKCU\Software\TechSmith\Snagit\18|OutputDirLastUsed RegKey23=HKCU\Software\TechSmith\Snagit\18|VidOutputDirLastUsed RegKey24=HKCU\Software\TechSmith\Snagit\18\Recent Captures RegKey25=HKCU\Software\TechSmith\Snagit\18\SnagitEditor\Recent File List RegKey26=HKCU\Software\TechSmith\Snagit\18\SnagItEditor\Tray|Thumbnailsize RegKey27=HKCU\Software\TechSmith\Snagit\19|CaptureCount RegKey28=HKCU\Software\TechSmith\Snagit\19|CaptureOpenCount RegKey29=HKCU\Software\TechSmith\Snagit\19|OutputDirLastUsed RegKey30=HKCU\Software\TechSmith\Snagit\19|VidOutputDirLastUsed RegKey31=HKCU\Software\TechSmith\Snagit\19\Recent Captures RegKey32=HKCU\Software\TechSmith\Snagit\19\SnagitEditor\Recent File List RegKey33=HKCU\Software\TechSmith\Snagit\19\SnagItEditor\Tray|Thumbnailsize RegKey34=HKCU\Software\TechSmith\Snagit\20|CaptureCount RegKey35=HKCU\Software\TechSmith\Snagit\20|CaptureOpenCount RegKey36=HKCU\Software\TechSmith\Snagit\20|OutputDirLastUsed RegKey37=HKCU\Software\TechSmith\Snagit\20|VidOutputDirLastUsed RegKey38=HKCU\Software\TechSmith\Snagit\20\Recent Captures RegKey39=HKCU\Software\TechSmith\Snagit\20\SnagitEditor\Recent File List RegKey40=HKCU\Software\TechSmith\Snagit\20\SnagItEditor\Tray|Thumbnailsize RegKey41=HKCU\Software\TechSmith\Snagit\21|CaptureCount RegKey42=HKCU\Software\TechSmith\Snagit\21|CaptureOpenCount RegKey43=HKCU\Software\TechSmith\Snagit\21|OutputDirLastUsed RegKey44=HKCU\Software\TechSmith\Snagit\21|VidOutputDirLastUsed RegKey45=HKCU\Software\TechSmith\Snagit\21\Recent Captures RegKey46=HKCU\Software\TechSmith\Snagit\21\SnagitEditor\Recent File List RegKey47=HKCU\Software\TechSmith\Snagit\21\SnagItEditor\Tray|Thumbnailsize RegKey48=HKCU\Software\TechSmith\Snagit\22|CaptureCount RegKey49=HKCU\Software\TechSmith\Snagit\22|CaptureOpenCount RegKey50=HKCU\Software\TechSmith\Snagit\22|OutputDirLastUsed RegKey51=HKCU\Software\TechSmith\Snagit\22|VidOutputDirLastUsed RegKey52=HKCU\Software\TechSmith\Snagit\22\Recent Captures RegKey53=HKCU\Software\TechSmith\Snagit\22\SnagitEditor\Recent File List RegKey54=HKCU\Software\TechSmith\Snagit\22\SnagItEditor\Tray|Thumbnailsize Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 8940 PC and Dell XPS 16 9640 Laptop. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
siliconman01 Posted September 21, 2023 Share Posted September 21, 2023 New addition: [LogiOptionsPlus Cache *] [LogiOptionsPlus Cache *] LangSecRef=3024 Detect=HKLM\Software\Logitech\LogiOptionsPlus FileKey1=%ProgramData%\LogiOptionsPlus\Cache|*.* Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 8940 PC and Dell XPS 16 9640 Laptop. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
