APMichael Posted April 17, 2019 Share Posted April 17, 2019 14 hours ago, Andavari said: On 13.4.2019 at 22:36, SMalik said: [Permissions *] ... FileKey2=%AppData%\Mozilla\Firefox\Profiles\*|permissions.sqlite ... CCleaner's already built-in Site Preferences already cleans that exact file, at least in Firefox ESR Portable v60.6.1esr. That's right, thanks. After using the build-in entry, the date (and size) of the file changes. Unfortunately, the file will not be deleted. Question to all: Should we rename the entry to [Site Preferences *] and still add it for those who want to make sure that all traces are really removed? Your opinions are welcome. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted April 17, 2019 Moderators Share Posted April 17, 2019 Doesn't matter to me either way, I was just reporting that CCleaner cleaned it. Link to comment Share on other sites More sharing options...
siliconman01 Posted April 18, 2019 Share Posted April 18, 2019 Modified entry: [PDF-XChange Editor *] Changed FileKey1; Added FileKey2 [PDF-XChange Editor *] LangSecRef=3021 Detect=HKCU\Software\Tracker Software\PDFXEditor Default=False FileKey1=%CommonAppData%\Tracker Software\TrackerUpdate|TrackerUpdate.exe.del FileKey2=%CommonAppData%\Tracker Software\TrackerUpdate\Download|*.* Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted April 18, 2019 Moderators Share Posted April 18, 2019 Added: * FileKey2 - removes the backup copy of the installer which they've moved into a different folder with the newest version, so I've made it so it will recursively remove it. * FileKey3 - removes a new log [Samsung Magician *] LangSecRef=3021 Detect=HKLM\Software\Samsung Magician Default=False FileKey1=%CommonAppData%\Samsung\Backup|*.exe FileKey2=%CommonAppData%\Samsung\Samsung Magician|*.exe|RECURSE FileKey3=%CommonAppData%\Samsung\Samsung Magician\PB|*.txt FileKey4=%ProgramFiles%\Samsung Magician\Logs|*.* FileKey5=%ProgramFiles%\Samsung\Samsung Magician\Log*|*.* RegKey1=HKCU\Software\Local AppWizard-Generated Applications\SamsungMagician Link to comment Share on other sites More sharing options...
don_dolarson Posted April 18, 2019 Share Posted April 18, 2019 How to get cookies and all clean up stuff visible for Brave browser? Brave lines exists in winapp2 file, but can't see anything about Brave inside CCleaner. Link to comment Share on other sites More sharing options...
APMichael Posted April 18, 2019 Share Posted April 18, 2019 2 hours ago, don_dolarson said: How to get cookies and all clean up stuff visible for Brave browser? Brave lines exists in winapp2 file, but can't see anything about Brave inside CCleaner. The entries are listed under the section "Google Chrome", there is no separate section "Brave Browser". The entries always clean up all installed Chromium-based browsers at once. You should also add the browser to CCleaner using one of the following methods:https://www.ccleaner.com/docs/ccleaner/advanced-usage/ccleaner-ini-files/how-to-clean-user-data-from-non-standard-mozilla-browsers CustomLocation1=CHROME|path_to_user_profile:https://forum.piriform.com/search/?q=CustomLocation1=CHROME Example: CustomLocation1=CHROME|C:\Users\<your user name>\AppData\Local\BraveSoftware\Brave-Browser\User Data\Default Link to comment Share on other sites More sharing options...
don_dolarson Posted April 18, 2019 Share Posted April 18, 2019 I don't think you sent me the right link because everything in there is about Mozilla based browsers, not Chromium. Not even "CustomLocation" exist in ccleaner.ini Do you mean that the "Chrome" section in CCleaner (both for app cleaning in the main cleaning section and in settings for saving cookies) is responsible for both Chrome and Brave at the same time and I can't clean each of them, separately? Does it work out of the box CCleaner + winapp2.ini then or do I need to make some changes? Link to comment Share on other sites More sharing options...
Moderators Andavari Posted April 18, 2019 Moderators Share Posted April 18, 2019 2 hours ago, don_dolarson said: Not even "CustomLocation" exist in ccleaner.ini It's not in there by default, you have to manually create it. And you'll need to input it in order for CCleaner to detect and clean a "clone" of Chrome/Chromium if it doesn't already clean the browser - the same would go if for instance using a portable version of any browser. What CCleaner cleans will be under the "Google Chrome" heading in CCleaner. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted April 19, 2019 Moderators Share Posted April 19, 2019 5 hours ago, don_dolarson said: I don't think you sent me the right link because everything in there is about Mozilla based browsers, not Chromium. Not even "CustomLocation" exist in ccleaner.ini Just replace the word firefox with CHROME for it to work ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
APMichael Posted April 19, 2019 Share Posted April 19, 2019 12 hours ago, don_dolarson said: I don't think you sent me the right link because everything in there is about Mozilla based browsers, not Chromium. Not even "CustomLocation" exist in ccleaner.ini Do you mean that the "Chrome" section in CCleaner (both for app cleaning in the main cleaning section and in settings for saving cookies) is responsible for both Chrome and Brave at the same time and I can't clean each of them, separately? Does it work out of the box CCleaner + winapp2.ini then or do I need to make some changes? Unfortunately, Piriform never updated the manual, so the manual still only mentions Mozilla-based browsers. But it also works for Chromium-based browsers. Correct, the section "Google Chrome" in CCleaner is responsible for all Chromium-based browsers at the same time. It is not possible to clean each of them individually. If you put only the file Winapp2.ini in CCleaner's program folder, only the entries of the file Winapp2.ini will clean the Brave browser. However, if you want a complete cleaning, with the built-in entries of CCleaner, you have to add the "CustomLocation1" in your ccleaner.ini. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted April 20, 2019 Moderators Share Posted April 20, 2019 19 hours ago, APMichael said: Unfortunately, Piriform never updated the manual, so the manual still only mentions Mozilla-based browsers. That's why they need a proper Wiki, since some things on that help site are incomplete or outright wrong and they know about it because they've been told countless times. Link to comment Share on other sites More sharing options...
APMichael Posted April 20, 2019 Share Posted April 20, 2019 Thanks for the new and modified entries. Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/6c134ef7668f627b24bbfcc95e32fdbc4b4680a8 Link to comment Share on other sites More sharing options...
Moderators Andavari Posted April 23, 2019 Moderators Share Posted April 23, 2019 Added: DetectFile=%CommonAppData%\Oracle\Java Reason: Crucial/Micron Storage Executive uses a packaged/portable non-installed version of Java that writes usage data in the location of FileKey2. [Java *] LangSecRef=3022 Detect1=HKLM\Software\JavaSoft\Java Plug-in Detect2=HKLM\Software\JavaSoft\Java Runtime Environment Detect3=HKLM\Software\JavaSoft\Java Web Start DetectFile=%CommonAppData%\Oracle\Java Default=False FileKey1=%AppData%\Sun\Java\Deployment\SystemCache|*.*|RECURSE FileKey2=%CommonAppData%\Oracle\Java\.oracle_jre_usage|*.* FileKey3=%LocalAppData%\Sun\Java\Deployment\*Cache|*.*|RECURSE FileKey4=%LocalLowAppData%\Sun\Java\Deployment\SystemCache|*.*|RECURSE FileKey5=%ProgramFiles%\Java\jre*|*PATCH.ERR FileKey6=%ProgramFiles%\Java\jre*\lib\security|*.bak FileKey7=%SystemDrive%\Users\*\.oracle_jre_usage|*.*|REMOVESELF FileKey8=%WinDir%\System32\config\systemprofile\AppData\LocalLow\Sun\Java\Deployment\Cache|*.*|RECURSE FileKey9=%WinDir%\SysWOW64\config\systemprofile\AppData\LocalLow\Sun\Java\Deployment\Cache|*.*|RECURSE Link to comment Share on other sites More sharing options...
APMichael Posted April 29, 2019 Share Posted April 29, 2019 Winapp2.ini updates:https://github.com/MoscaDotTo/Winapp2/commit/e700e7cb6b6ce2b33c4fbab4be92ec42d536fe71https://github.com/MoscaDotTo/Winapp2/commit/ff1cb36ce624340e5eb69b5ae3420ec38fffa7e6https://github.com/MoscaDotTo/Winapp2/commit/f08ba60a0d88a041b65e5b624721c397d8d00822 Link to comment Share on other sites More sharing options...
siliconman01 Posted April 29, 2019 Share Posted April 29, 2019 Thanks for incorporating the MS Edge Insider cleaning modules. This new browser is working great on my systems. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
APMichael Posted April 29, 2019 Share Posted April 29, 2019 2 hours ago, siliconman01 said: Thanks for incorporating the MS Edge Insider cleaning modules. This new browser is working great on my systems. Thank you very much for providing most of the them! I think MS will certainly be more successful with the new Edge. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted April 30, 2019 Moderators Share Posted April 30, 2019 Added: Detect1 Reason: Some 2017 & 2018 PC's still had that old version 14 pre-installed by the PC manufacturer. [CyberLink PowerDVD *] LangSecRef=3023 Detect1=HKCU\Software\CyberLink\PowerDVD14 Detect2=HKCU\Software\CyberLink\PowerDVD15 Detect3=HKCU\Software\CyberLink\PowerDVD16 Detect4=HKCU\Software\CyberLink\PowerDVD17 Detect5=HKCU\Software\CyberLink\PowerDVD18 Detect6=HKCU\Software\CyberLink\PowerDVD19 Default=False FileKey1=%CommonAppData%\Cyberlink\Evoparser|*.xml FileKey2=%LocalAppData%\Cyberlink\DigitalHome|*.log|RECURSE FileKey3=%LocalAppData%\Cyberlink\PowerDVD*|*.log|RECURSE FileKey4=%LocalAppData%\Cyberlink\PowerDVD*\cache*|*.*|RECURSE FileKey5=%LocalAppData%\Cyberlink\PowerDVD*\CL_DMP_Browser|*.*|RECURSE RegKey1=HKCU\Software\CyberLink\PowerDVD15\CLMPSvc\MediaObj\MediaCache5\Data5 RegKey2=HKCU\Software\CyberLink\PowerDVD15\CLMPSvc\MediaObj\MediaCache5\ProgramInfo RegKey3=HKCU\Software\CyberLink\PowerDVD15\CLMPSvc\MediaObj\MediaCache5\Thumbnail5 RegKey4=HKCU\Software\CyberLink\PowerDVD16\CLMPSvc\MediaObj\MediaCache5\Data5 RegKey5=HKCU\Software\CyberLink\PowerDVD16\CLMPSvc\MediaObj\MediaCache5\ProgramInfo RegKey6=HKCU\Software\CyberLink\PowerDVD16\CLMPSvc\MediaObj\MediaCache5\Thumbnail5 RegKey7=HKCU\Software\CyberLink\PowerDVD17\CLMPSvc\MediaObj\MediaCache5\Data5 RegKey8=HKCU\Software\CyberLink\PowerDVD17\CLMPSvc\MediaObj\MediaCache5\ProgramInfo RegKey9=HKCU\Software\CyberLink\PowerDVD17\CLMPSvc\MediaObj\MediaCache5\Thumbnail5 RegKey10=HKCU\Software\CyberLink\PowerDVD18\CLMPSvc\MediaObj\MediaCache5\Data5 RegKey11=HKCU\Software\CyberLink\PowerDVD18\CLMPSvc\MediaObj\MediaCache5\ProgramInfo RegKey12=HKCU\Software\CyberLink\PowerDVD18\CLMPSvc\MediaObj\MediaCache5\Thumbnail5 RegKey13=HKCU\Software\CyberLink\PowerDVD19\CLMPSvc\MediaObj\MediaCache5\Data5 RegKey14=HKCU\Software\CyberLink\PowerDVD19\CLMPSvc\MediaObj\MediaCache5\ProgramInfo RegKey15=HKCU\Software\CyberLink\PowerDVD19\CLMPSvc\MediaObj\MediaCache5\Thumbnail5 Link to comment Share on other sites More sharing options...
siliconman01 Posted April 30, 2019 Share Posted April 30, 2019 Should there be RegKey entries added for PowerDVD 14 ? Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
SMalik Posted May 4, 2019 Share Posted May 4, 2019 New Entry [Ashampoo PDF Pro *] LangSecRef=3021 Detect1=HKCU\Software\Ashampoo\Ashampoo PDF Detect2=HKCU\Software\Ashampoo\Ashampoo PDF Pro 2 Default=False FileKey1=%LocalAppData%\Ashampoo PDF\*|lastFileOpenned.txt RegKey1=HKCU\Software\Ashampoo\Ashampoo PDF\Recent File List Link to comment Share on other sites More sharing options...
Moderators Andavari Posted May 4, 2019 Moderators Share Posted May 4, 2019 On 4/30/2019 at 01:24, siliconman01 said: Should there be RegKey entries added for PowerDVD 14 ? I personally couldn't find anything additional worth adding in that's stored within the Windows registry. Link to comment Share on other sites More sharing options...
ricktendo64 Posted May 5, 2019 Share Posted May 5, 2019 Any chance you could add Outlook Recent Searches https://www.howto-outlook.com/howto/clearmru.htm [Outlook Recent Searches *] LangSecRef=3021 Detect1=HKCU\Software\Microsoft\Office\11.0\Outlook Detect2=HKCU\Software\Microsoft\Office\12.0\Outlook Detect3=HKCU\Software\Microsoft\Office\14.0\Outlook Detect4=HKCU\Software\Microsoft\Office\15.0\Outlook Detect5=HKCU\Software\Microsoft\Office\16.0\Outlook Default=True RegKey1=HKCU\Software\Microsoft\Office\11.0\Outlook\Profiles\Outlook\0a0d020000000000c000000000000046|101f0445 RegKey2=HKCU\Software\Microsoft\Office\12.0\Outlook\Profiles\Outlook\0a0d020000000000c000000000000046|101f0445 RegKey3=HKCU\Software\Microsoft\Office\14.0\Outlook\Profiles\Outlook\0a0d020000000000c000000000000046|101f0445 RegKey4=HKCU\Software\Microsoft\Office\15.0\Outlook\Profiles\Outlook\0a0d020000000000c000000000000046|101f0445 RegKey5=HKCU\Software\Microsoft\Office\16.0\Outlook\Profiles\Outlook\0a0d020000000000c000000000000046|101f0445 I post the default profile name Outlook but this may vary, is there a way for winapp2ool to query the registry for the profile name and replace "Outlook"? Link to comment Share on other sites More sharing options...
APMichael Posted May 6, 2019 Share Posted May 6, 2019 Winapp2.ini updates:https://github.com/MoscaDotTo/Winapp2/commit/6fd8702ce4d928f6badf2a5cad71ef60b5e0c916https://github.com/MoscaDotTo/Winapp2/commit/aa24a3cf03958bfbeed353377cf7bc1d671f9b5bhttps://github.com/MoscaDotTo/Winapp2/commit/6787d6577e582237ec3d9ab5f895c63638dc9b9f On 5.5.2019 at 07:53, ricktendo64 said: [Outlook Recent Searches *] ... I post the default profile name Outlook but this may vary, is there a way for winapp2ool to query the registry for the profile name and replace "Outlook"? I have added your entry to Winapp2.ini. I guess it will work for most Outlook users. Maybe @Winapp2.ini can add this feature in a future version of Winapp2ool. Link to comment Share on other sites More sharing options...
ricktendo64 Posted May 8, 2019 Share Posted May 8, 2019 On 5/6/2019 at 04:44, APMichael said: I have added your entry to Winapp2.ini. I guess it will work for most Outlook users. Maybe @Winapp2.ini can add this feature in a future version of Winapp2ool. Thank you, yea I hope it can be added because I know multiple people who create multiple outlook profiles and when you do this you can have outlook prompt you to ask what profile you want to open... Example: Work or Personal profiles Link to comment Share on other sites More sharing options...
Winapp2.ini Posted May 8, 2019 Author Share Posted May 8, 2019 On 5/5/2019 at 01:53, ricktendo64 said: Any chance you could add Outlook Recent Searches https://www.howto-outlook.com/howto/clearmru.htm [Outlook Recent Searches *] LangSecRef=3021 Detect1=HKCU\Software\Microsoft\Office\11.0\Outlook Detect2=HKCU\Software\Microsoft\Office\12.0\Outlook Detect3=HKCU\Software\Microsoft\Office\14.0\Outlook Detect4=HKCU\Software\Microsoft\Office\15.0\Outlook Detect5=HKCU\Software\Microsoft\Office\16.0\Outlook Default=True RegKey1=HKCU\Software\Microsoft\Office\11.0\Outlook\Profiles\Outlook\0a0d020000000000c000000000000046|101f0445 RegKey2=HKCU\Software\Microsoft\Office\12.0\Outlook\Profiles\Outlook\0a0d020000000000c000000000000046|101f0445 RegKey3=HKCU\Software\Microsoft\Office\14.0\Outlook\Profiles\Outlook\0a0d020000000000c000000000000046|101f0445 RegKey4=HKCU\Software\Microsoft\Office\15.0\Outlook\Profiles\Outlook\0a0d020000000000c000000000000046|101f0445 RegKey5=HKCU\Software\Microsoft\Office\16.0\Outlook\Profiles\Outlook\0a0d020000000000c000000000000046|101f0445 I post the default profile name Outlook but this may vary, is there a way for winapp2ool to query the registry for the profile name and replace "Outlook"? Would all subkeys of \Profiles\Outlook\***** necessarily be a profile folder? If so this wouldn't be too difficult to create support for, I don't think. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
CSGalloway Posted May 9, 2019 Share Posted May 9, 2019 New Entry [OE Classic*] LanSecRef= Detect=HKCU\Software\OEClassic Default-False FileKey1=%LocalAppData%\OEClassic\Prg|*.*|RECURSE Not sure of the ocorrect value for LanSecRef = can't find it documents on here... Link to comment Share on other sites More sharing options...
