APMichael Posted May 9, 2019 Share Posted May 9, 2019 16 hours ago, Winapp2.ini said: Would all subkeys of \Profiles\Outlook\***** necessarily be a profile folder? If so this wouldn't be too difficult to create support for, I don't think. As far as I know, every subkey of \Profiles\ is a profile. The default profile name is Outlook, but you can also add additional profiles, e.g.: HKCU\Software\Microsoft\Office\16.0\Outlook\Profiles\Outlook\ HKCU\Software\Microsoft\Office\16.0\Outlook\Profiles\Personal\ HKCU\Software\Microsoft\Office\16.0\Outlook\Profiles\Work\ Link to comment Share on other sites More sharing options...
APMichael Posted May 9, 2019 Share Posted May 9, 2019 On 9.5.2019 at 02:43, CSGalloway said: New Entry [OE Classic*] .. Not sure of the ocorrect value for LanSecRef = can't find it documents on here... I guess it should be LangSecRef=3022 (= Internet). For the readme simply click on the GitHub link in the first post. Edit: Sorry, LangSecRef for the category Internet is 3022. Link to comment Share on other sites More sharing options...
CSGalloway Posted May 9, 2019 Share Posted May 9, 2019 5 hours ago, APMichael said: I guess it should be LangSecRef=3021 (= Internet). For the readme simply click on the GitHub link in the first post. I think it would be a good suggestion if a similar readme post could be added near the front of this thread..... here... OE Classic is a replacement for Outlook Express..... Link to comment Share on other sites More sharing options...
Winapp2.ini Posted May 9, 2019 Author Share Posted May 9, 2019 1 hour ago, CSGalloway said: I think it would be a good suggestion if a similar readme post could be added near the front of this thread..... here... OE Classic is a replacement for Outlook Express..... I added a link directly to the Creating Entries section of the ReadMe to the top level post. For sanity/version control reasons, it's much easier to link to GitHub resources from this thread than to maintain separate copies winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
CSGalloway Posted May 9, 2019 Share Posted May 9, 2019 2 hours ago, Winapp2.ini said: I added a link directly to the Creating Entries section of the ReadMe to the top level post. For sanity/version control reasons, it's much easier to link to GitHub resources from this thread than to maintain separate copies Thank you for adding a link...... Link to comment Share on other sites More sharing options...
ricktendo64 Posted May 9, 2019 Share Posted May 9, 2019 On 5/8/2019 at 13:10, Winapp2.ini said: Would all subkeys of \Profiles\Outlook\***** necessarily be a profile folder? If so this wouldn't be too difficult to create support for, I don't think. I tried creating a new profile, but it did not create any folders in %AppData% or %LocalAppData%. If you have outlook installed you can try creating a custom profile using the "Mail" Setup app in User Accounts Link to comment Share on other sites More sharing options...
siliconman01 Posted May 11, 2019 Share Posted May 11, 2019 Modified entry: [DisplayFusion *] Added FileKey2 (see https://www.displayfusion.com/Discussions/View/can-this-setup-file-be-deleted/?ID=2cef12d4-073e-462f-8d20-f8ea4ed8ecca ) [DisplayFusion *] LangSecRef=3024 Detect=HKCU\Software\Binary Fortress Software\DisplayFusion Default=False FileKey1=%AppData%\DisplayFusion|DisplayFusionSetup.log;DisplayFusionSetup.exe;DisplayFusion.log;DebugInfo.* FileKey2=%CommonAppData%\Binary Fortress Software\DisplayFusion|DisplayFusionSetup.exe Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
APMichael Posted May 13, 2019 Share Posted May 13, 2019 Winapp2.ini updates:https://github.com/MoscaDotTo/Winapp2/commit/ddd6117bb987744e136e141073fa1be8091b0a77https://github.com/MoscaDotTo/Winapp2/commit/d55cc4e04850436d1774a16fb8b7cd2728c8a852 Link to comment Share on other sites More sharing options...
siliconman01 Posted May 20, 2019 Share Posted May 20, 2019 Modified entry: [Acrok Video Converter Ultimate *] Added FileKey1 [Acrok Video Converter Ultimate *] LangSecRef=3023 Detect=HKCU\Software\Acrok Software\Acrok Video Converter Ultimate Default=False FileKey1=%AppData%\Acrok Software\Blu-ray Plugin\Log|*.log FileKey2=%AppData%\Acrok\Acrok Video Converter Ultimate|*.dmp FileKey3=%AppData%\Acrok\Acrok Video Converter Ultimate\log|*.* FileKey4=%AppData%\Auxre\Blu-ray Plugin|*.log FileKey5=%UserProfile%\.BDAccess|*.*|RECURSE Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
siliconman01 Posted May 20, 2019 Share Posted May 20, 2019 Modified entry: [MS Search *] Added *.searchconnector-ms to FileKey2 [MS Search *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\GatherLogs\SystemIndex|*.*|RECURSE FileKey2=%UserProfile%\Searches|*.search-ms;*.searchconnector-ms RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Search\JumplistData Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
SMalik Posted May 21, 2019 Share Posted May 21, 2019 Revised Entry Removed: FileKey6=%LocalAppData%\Packages\Microsoft.MSPaint_*\LocalState\Projects\WorkingFolder*|*.*|REMOVESELF FileKey7=%LocalAppData%\Packages\Microsoft.MSPaint_*\LocalState\Textures|*.* [Paint 3D *] DetectOS=10.0| LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.MSPaint_8wekyb3d8bbwe DetectFile=%LocalAppData%\Packages\Microsoft.MSPaint_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.MSPaint_*\AC\INet*|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.MSPaint_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.MSPaint_*\AC\NVIDIA Corporation\NV_Cache|*.* FileKey4=%LocalAppData%\Packages\Microsoft.MSPaint_*\AC\Temp|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.MSPaint_*\LocalCache|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.MSPaint_*\TempState|*.*|RECURSE Link to comment Share on other sites More sharing options...
SMalik Posted May 21, 2019 Share Posted May 21, 2019 Revised Entry Changed FileKey7=%LocalAppData%\Packages\Microsoft.SkypeApp_*\LocalState|*.*|RECURSE to FileKey7=%LocalAppData%\Packages\Microsoft.SkypeApp_*\LocalState\logs|*.*|RECURSE [Skype App *] LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.SkypeApp_kzf8qxf38zg5c DetectFile=%LocalAppData%\Packages\Microsoft.SkypeApp_kzf8qxf38zg5c Default=False FileKey1=%LocalAppData%\Packages\Microsoft.SkypeApp_*\AC\AppCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.SkypeApp_*\AC\INet*|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.SkypeApp_*\AC\Microsoft\CryptnetUrlCache\*|*.* FileKey4=%LocalAppData%\Packages\Microsoft.SkypeApp_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.SkypeApp_*\AC\NVIDIA Corporation\NV_Cache|*.* FileKey6=%LocalAppData%\Packages\Microsoft.SkypeApp_*\AC\PRICache|*.* FileKey7=%LocalAppData%\Packages\Microsoft.SkypeApp_*\LocalState\logs|*.*|RECURSE FileKey8=%LocalAppData%\Packages\Microsoft.SkypeApp_*\TempState|*.*|RECURSE Link to comment Share on other sites More sharing options...
SMalik Posted May 21, 2019 Share Posted May 21, 2019 Revised Entry Changed [Updates *] to [Google Update *] Changed LangSecRef=3029 to LangSecRef=3021 [Google Update *] LangSecRef=3021 Detect=HKCU\Software\Google\Update Default=False FileKey1=%ProgramFiles%\Google\Update\Download|*.*|RECURSE FileKey2=%ProgramFiles%\Google\Update\Install|*.*|RECURSE FileKey3=%ProgramFiles%\Google\Update\Offline|*.*|RECURSE Link to comment Share on other sites More sharing options...
APMichael Posted May 22, 2019 Share Posted May 22, 2019 9 hours ago, SMalik said: Revised Entry Changed [Updates *] to [Google Update *] Changed LangSecRef=3029 to LangSecRef=3021 ... Thanks for the revised entry, but did you see that the entry [Updates *] also contains FileKeys for other Chromium-based browsers? I think you just want to separate Google Update because it also updates other Google software, right? Then I suggest that we use the following entries: [Updates *] LangSecRef=3029 Detect1=HKCU\Software\BraveSoftware Detect2=HKCU\Software\CocCoc\Browser Detect3=HKCU\Software\Torch Default=False FileKey1=%LocalAppData%\CocCoc\Update\Download|*.*|RECURSE FileKey2=%LocalAppData%\CocCoc\Update\Install|*.*|RECURSE FileKey3=%LocalAppData%\CocCoc\Update\Offline|*.*|RECURSE FileKey4=%LocalAppData%\Torch\Update\Download|*.*|RECURSE FileKey5=%LocalAppData%\Torch\Update\Install|*.*|RECURSE FileKey6=%LocalAppData%\Torch\Update\Offline|*.*|RECURSE FileKey7=%ProgramFiles%\BraveSoftware\Update\Download|*.*|RECURSE FileKey8=%ProgramFiles%\BraveSoftware\Update\Install|*.*|RECURSE FileKey9=%ProgramFiles%\BraveSoftware\Update\Offline|*.*|RECURSE [Google Update *] LangSecRef=3021 Detect=HKCU\Software\Google\Update Default=False FileKey1=%LocalAppData%\Google\Update\Download|*.*|RECURSE FileKey2=%LocalAppData%\Google\Update\Install|*.*|RECURSE FileKey3=%LocalAppData%\Google\Update\Offline|*.*|RECURSE FileKey4=%ProgramFiles%\Google\Update\Download|*.*|RECURSE FileKey5=%ProgramFiles%\Google\Update\Install|*.*|RECURSE FileKey6=%ProgramFiles%\Google\Update\Offline|*.*|RECURSE Google Update can also be found at %LocalAppData%\Google\Update\, e.g. if you install Google Chrome Canary. Link to comment Share on other sites More sharing options...
SMalik Posted May 22, 2019 Share Posted May 22, 2019 11 hours ago, APMichael said: Thanks for the revised entry, but did you see that the entry [Updates *] also contains FileKeys for other Chromium-based browsers? I think you just want to separate Google Update because it also updates other Google software, right? Then I suggest that we use the following entries: [Updates *] LangSecRef=3029 Detect1=HKCU\Software\BraveSoftware Detect2=HKCU\Software\CocCoc\Browser Detect3=HKCU\Software\Torch Default=False FileKey1=%LocalAppData%\CocCoc\Update\Download|*.*|RECURSE FileKey2=%LocalAppData%\CocCoc\Update\Install|*.*|RECURSE FileKey3=%LocalAppData%\CocCoc\Update\Offline|*.*|RECURSE FileKey4=%LocalAppData%\Torch\Update\Download|*.*|RECURSE FileKey5=%LocalAppData%\Torch\Update\Install|*.*|RECURSE FileKey6=%LocalAppData%\Torch\Update\Offline|*.*|RECURSE FileKey7=%ProgramFiles%\BraveSoftware\Update\Download|*.*|RECURSE FileKey8=%ProgramFiles%\BraveSoftware\Update\Install|*.*|RECURSE FileKey9=%ProgramFiles%\BraveSoftware\Update\Offline|*.*|RECURSE [Google Update *] LangSecRef=3021 Detect=HKCU\Software\Google\Update Default=False FileKey1=%LocalAppData%\Google\Update\Download|*.*|RECURSE FileKey2=%LocalAppData%\Google\Update\Install|*.*|RECURSE FileKey3=%LocalAppData%\Google\Update\Offline|*.*|RECURSE FileKey4=%ProgramFiles%\Google\Update\Download|*.*|RECURSE FileKey5=%ProgramFiles%\Google\Update\Install|*.*|RECURSE FileKey6=%ProgramFiles%\Google\Update\Offline|*.*|RECURSE Google Update can also be found at %LocalAppData%\Google\Update\, e.g. if you install Google Chrome Canary. Yes, other Google programs use same locations to keep update files. I have Google Earth and it keeps updates in there. I agree that we should also add %LocalAppData% Link to comment Share on other sites More sharing options...
APMichael Posted May 23, 2019 Share Posted May 23, 2019 Thanks for your reply and the revised entries. Thanks of course also to all others for their new or revised entries. Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/69030c80e2ac9102c6a438d605ef7111ba8bbdd1 Link to comment Share on other sites More sharing options...
SMalik Posted May 23, 2019 Share Posted May 23, 2019 Revised Entry Added: %LocalAppData%\Packages\Microsoft.SkypeApp_*\LocalState\DiagOutputDir|*.txt [Skype App *] LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.SkypeApp_kzf8qxf38zg5c DetectFile=%LocalAppData%\Packages\Microsoft.SkypeApp_kzf8qxf38zg5c Default=False FileKey1=%LocalAppData%\Packages\Microsoft.SkypeApp_*\AC\AppCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.SkypeApp_*\AC\INet*|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.SkypeApp_*\AC\Microsoft\CryptnetUrlCache\*|*.* FileKey4=%LocalAppData%\Packages\Microsoft.SkypeApp_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.SkypeApp_*\AC\NVIDIA Corporation\NV_Cache|*.* FileKey6=%LocalAppData%\Packages\Microsoft.SkypeApp_*\AC\PRICache|*.* FileKey7=%LocalAppData%\Packages\Microsoft.SkypeApp_*\LocalState\DiagOutputDir|*.txt FileKey8=%LocalAppData%\Packages\Microsoft.SkypeApp_*\LocalState\logs|*.*|RECURSE FileKey9=%LocalAppData%\Packages\Microsoft.SkypeApp_*\TempState|*.*|RECURSE Link to comment Share on other sites More sharing options...
Moderators Andavari Posted May 24, 2019 Moderators Share Posted May 24, 2019 New entry to clean logs associated with Intel Driver & Support Assistant: [Intel DSA Logs *] LangSecRef=3024 Detect=HKCU\Software\Intel\Driver and Support Assistant Default=False FileKey1=%CommonAppData%\Intel\DSA|*.log;*.log.bak Link to comment Share on other sites More sharing options...
siliconman01 Posted May 25, 2019 Share Posted May 25, 2019 (edited) New entries: [Intel Management Engine Components Logs *] & [Intel WiFi Logs *] [Intel Management Engine Components Logs *] LangSecRef=3024 DetectFile=%ProgramFiles%\Intel\Intel(R) Management Engine Components Default=False FileKey1=%ProgramFiles%\Intel\Intel(R) Management Engine Components\MEWMIProv|log.txt FileKey2=%ProgramFiles%\Intel\Intel(R) Management Engine Components\MEWMIProv\Internal|*.log [Intel WiFi Logs *] LangSecRef=3024 DetectFile=%ProgramFiles%\Intel\WiFi Default=False FileKey1=%ProgramFiles%\Intel\WiFi|*.log FileKey2=%ProgramFiles%\Intel\Wifi\AutoImport|AutoImportLog.txt FileKey3=%ProgramFiles%\Intel\WiFi\UnifiedLogging|*.log Edited May 26, 2019 by siliconman01 Fixed DetectFile in [Intel Management Engine Components Logs *] Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted May 25, 2019 Moderators Share Posted May 25, 2019 @siliconman01 [Intel Management Engine Components Logs *] Doesn't have a path for the DetectFile. Link to comment Share on other sites More sharing options...
SMalik Posted May 25, 2019 Share Posted May 25, 2019 New Entries UWP Universal Windows Platform (formerly Windows Store apps and Metro-style apps) These paths store information about Microsoft Store programs and games already removed from the system [Stored UWP Programs Information *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False RegKey1=HKCU\Software\Microsoft\Phone\ShellUI\WindowSizing RegKey2=HKCU\Software\Microsoft\UserData\UninstallTimes This path keeps information about installation and updates of Microsoft Store programs and games already removed from the system [Stored Store Install Information *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False RegKey1=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\InstallService\State\CategoryCache Link to comment Share on other sites More sharing options...
siliconman01 Posted May 26, 2019 Share Posted May 26, 2019 13 hours ago, Andavari said: @siliconman01 [Intel Management Engine Components Logs *] Doesn't have a path for the DetectFile. Fixed....thanks ! Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
SMalik Posted May 27, 2019 Share Posted May 27, 2019 On 3/14/2019 at 08:36, Andavari said: There's been bug reports with it's cookie cleaning abilities (or lack there of) in v5.54 and 5.55, just one topic that explains it:https://forum.piriform.com/topic/53534-ccleaner-554-not-detecting-or-deleting-cookies/ I have CCleaner v5.57. Looks like the cookies cleaning issue has been fixed. So I think the [Cookies *] entry should be removed from Google Chrome. Link to comment Share on other sites More sharing options...
SMalik Posted May 27, 2019 Share Posted May 27, 2019 Revised Entry Changed name from [Internet Cache *] to [Network Persistence Statistics *] [Network Persistence Statistics *] LangSecRef=3029 Detect1=HKCU\Software\7Star\7Star Detect2=HKCU\Software\360Browser\Browser Detect3=HKCU\Software\Amigo Detect4=HKCU\Software\BraveSoftware Detect5=HKCU\Software\CentBrowser Detect6=HKCU\Software\ChromePlus Detect7=HKCU\Software\Chromium\PreferenceMACs Detect8=HKCU\Software\CocCoc\Browser Detect9=HKCU\Software\Comodo\Dragon Detect10=HKCU\Software\Coowon\Coowon Detect11=HKCU\Software\Epic Privacy Browser Detect12=HKCU\Software\Flock Detect13=HKCU\Software\Iridium Detect14=HKCU\Software\RockMelt Detect15=HKCU\Software\Slimjet Detect16=HKCU\Software\Superbird Detect17=HKCU\Software\Torch Detect18=HKCU\Software\Vivaldi Detect19=HKCU\Software\Yandex\YandexBrowser DetectFile1=%AppData%\brave DetectFile2=%LocalAppData%\Google\Chrome* Default=False FileKey1=%AppData%\brave|*.ldb;*.log;CURRENT;LOCK;MANIFEST-*;Network Persistent State;Origin Bound Certs FileKey2=%LocalAppData%\7Star\7Star\User Data|*-journal FileKey3=%LocalAppData%\7Star\7Star\User Data\*|*.ldb;*.log;CURRENT;LOCK;MANIFEST-*;Network Persistent State;Origin Bound Certs FileKey4=%LocalAppData%\360Browser\Browser\User Data|*-journal FileKey5=%LocalAppData%\360Browser\Browser\User Data\*|*.ldb;*.log;CURRENT;LOCK;MANIFEST-*;Network Persistent State;Origin Bound Certs FileKey6=%LocalAppData%\Amigo\User Data|*-journal FileKey7=%LocalAppData%\Amigo\User Data\*|*.ldb;*.log;CURRENT;LOCK;MANIFEST-*;Network Persistent State;Origin Bound Certs FileKey8=%LocalAppData%\BraveSoftware\Brave-Browser*\User Data|*-journal FileKey9=%LocalAppData%\BraveSoftware\Brave-Browser*\User Data\*|*.ldb;*.log;CURRENT;LOCK;MANIFEST-*;Network Persistent State;Origin Bound Certs FileKey10=%LocalAppData%\CentBrowser\User Data|*-journal FileKey11=%LocalAppData%\CentBrowser\User Data\*|*.ldb;*.log;CURRENT;LOCK;MANIFEST-*;Network Persistent State;Origin Bound Certs FileKey12=%LocalAppData%\Chromium\User Data|*-journal FileKey13=%LocalAppData%\Chromium\User Data\*|*.ldb;*.log;CURRENT;LOCK;MANIFEST-*;Network Persistent State;Origin Bound Certs FileKey14=%LocalAppData%\CocCoc\Browser\User Data|*-journal FileKey15=%LocalAppData%\CocCoc\Browser\User Data\*|*.ldb;*.log;CURRENT;LOCK;MANIFEST-*;Network Persistent State;Origin Bound Certs FileKey16=%LocalAppData%\Comodo\Dragon\User Data|*-journal FileKey17=%LocalAppData%\Comodo\Dragon\User Data\*|*.ldb;*.log;CURRENT;LOCK;MANIFEST-*;Network Persistent State;Origin Bound Certs FileKey18=%LocalAppData%\Coowon\Coowon\User Data|*-journal FileKey19=%LocalAppData%\Coowon\Coowon\User Data\*|*.ldb;*.log;CURRENT;LOCK;MANIFEST-*;Network Persistent State;Origin Bound Certs FileKey20=%LocalAppData%\Epic Privacy Browser\User Data|*-journal FileKey21=%LocalAppData%\Epic Privacy Browser\User Data\*|*.ldb;*.log;CURRENT;LOCK;MANIFEST-*;Network Persistent State;Origin Bound Certs FileKey22=%LocalAppData%\Flock\User Data|*-journal FileKey23=%LocalAppData%\Flock\User Data\*|*.ldb;*.log;CURRENT;LOCK;MANIFEST-*;Network Persistent State;Origin Bound Certs FileKey24=%LocalAppData%\Google\Chrome*\User Data|*-journal FileKey25=%LocalAppData%\Google\Chrome*\User Data\*|*.ldb;*.log;CURRENT;LOCK;MANIFEST-*;Network Persistent State;Origin Bound Certs FileKey26=%LocalAppData%\Iridium\User Data|*-journal FileKey27=%LocalAppData%\Iridium\User Data\*|*.ldb;*.log;CURRENT;LOCK;MANIFEST-*;Network Persistent State;Origin Bound Certs FileKey28=%LocalAppData%\MapleStudio\ChromePlus\User Data|*-journal FileKey29=%LocalAppData%\MapleStudio\ChromePlus\User Data\*|*.ldb;*.log;CURRENT;LOCK;MANIFEST-*;Network Persistent State;Origin Bound Certs FileKey30=%LocalAppData%\RockMelt\User Data|*-journal FileKey31=%LocalAppData%\RockMelt\User Data\*|*.ldb;*.log;CURRENT;LOCK;MANIFEST-*;Network Persistent State;Origin Bound Certs FileKey32=%LocalAppData%\Slimjet\User Data|*-journal FileKey33=%LocalAppData%\Slimjet\User Data\*|*.ldb;*.log;CURRENT;LOCK;MANIFEST-*;Network Persistent State;Origin Bound Certs FileKey34=%LocalAppData%\Superbird\User Data|*-journal FileKey35=%LocalAppData%\Superbird\User Data\*|*.ldb;*.log;CURRENT;LOCK;MANIFEST-*;Network Persistent State;Origin Bound Certs FileKey36=%LocalAppData%\Torch\User Data|*-journal FileKey37=%LocalAppData%\Torch\User Data\*|*.ldb;*.log;CURRENT;LOCK;MANIFEST-*;Network Persistent State;Origin Bound Certs FileKey38=%LocalAppData%\Vivaldi\User Data|*-journal FileKey39=%LocalAppData%\Vivaldi\User Data\*|*.ldb;*.log;CURRENT;LOCK;MANIFEST-*;Network Persistent State;Origin Bound Certs FileKey40=%LocalAppData%\Yandex\YandexBrowser\User Data|*-journal FileKey41=%LocalAppData%\Yandex\YandexBrowser\User Data\*|*.ldb;*.log;CURRENT;LOCK;MANIFEST-*;Network Persistent State;Origin Bound Certs Link to comment Share on other sites More sharing options...
SMalik Posted May 27, 2019 Share Posted May 27, 2019 Also, [Internet History *] should be removed from Google Chrome. CCleaner does the job now. Link to comment Share on other sites More sharing options...
