SMalik Posted June 5, 2019 Share Posted June 5, 2019 Revised Entry https://forum.piriform.com/topic/32310-winapp2ini-additions/?do=findComment&comment=306852 Windows XP RegKey1 thru RegKey4 ExcludeKey1 & ExcludeKey7 Windows Vista - Windows 7 RegKey5 thru RegKey8 ExcludeKey2, ExcludeKey3 & ExcludeKey7 Windows 8.1/10 RegKey9 thru RegKey14 and RegKey1 thru RegKey2 ExcludeKey4 thru ExcludeKey7 [Windows ShellBags *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False Warning=This will reset folders size, view, icon or position settings to default and remove traces of the folders that do not exist anymore. RegKey1=HKCU\Software\Microsoft\Windows\Shell\BagMRU RegKey2=HKCU\Software\Microsoft\Windows\Shell\Bags RegKey3=HKCU\Software\Microsoft\Windows\ShellNoRoam\BagMRU RegKey4=HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags RegKey5=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\BagMRU RegKey6=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags RegKey7=HKCU\Software\Classes\WOW6432Node\Local Settings\Software\Microsoft\Windows\Shell\BagMRU RegKey8=HKCU\Software\Classes\WOW6432Node\Local Settings\Software\Microsoft\Windows\Shell\Bags RegKey9=HKCR\Local Settings\Software\Microsoft\Windows\Shell\BagMRU RegKey10=HKCR\Local Settings\Software\Microsoft\Windows\Shell\Bags RegKey11=HKCU\Local Settings\Software\Microsoft\Windows\Shell\BagMRU RegKey12=HKCU\Local Settings\Software\Microsoft\Windows\Shell\Bags RegKey13=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\BagMRU RegKey14=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags ExcludeKey1=REG|HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags\AllFolders ExcludeKey2=REG|HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders ExcludeKey3=REG|HKCU\Software\Classes\WOW6432Node\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders ExcludeKey4=REG|HKCR\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders ExcludeKey5=REG|HKCU\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders ExcludeKey6=REG|HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders ExcludeKey7=REG|HKCU\Software\Microsoft\Windows\Shell\Bags\1\Desktop Link to comment Share on other sites More sharing options...
APMichael Posted June 5, 2019 Share Posted June 5, 2019 6 hours ago, SMalik said: ... Added (replaced): HKCR\Local Settings\Software\Microsoft\Windows\Shell\BagMRU HKCR\Local Settings\Software\Microsoft\Windows\Shell\Bags ... [Windows ShellBags *] ... RegKey1=HKCR\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\BagMRU RegKey2=HKCR\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags ... ExcludeKey1=REG|HKCR\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders ... I think you forgot to remove "Software\Classes\" from RegKey1+2 and ExcludeKey1, right? 6 hours ago, SMalik said: ... Removed ExcludeKeys. These paths don't exist REG|HKCU\Software\Microsoft\Windows\Shell\Bags\AllFolders REG|HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags\AllFolders ... I would suggest to keep the removed ExcludeKeys . As far as I know, they only exist on older versions of Windows (and also depend on 32/64 bit). Link to comment Share on other sites More sharing options...
Winapp2.ini Posted June 5, 2019 Author Share Posted June 5, 2019 I think the same is true of the ExcludeKey's paired RegKeys winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted June 6, 2019 Share Posted June 6, 2019 11 hours ago, APMichael said: I think you forgot to remove "Software\Classes\" from RegKey1+2 and ExcludeKey1, right? I would suggest to keep the removed ExcludeKeys . As far as I know, they only exist on older versions of Windows (and also depend on 32/64 bit). You're right "Software\Classes\" from RegKey1+2 and ExcludeKey1 should be removed. I tested on 32-bit and 64-bit systems. Link to comment Share on other sites More sharing options...
SMalik Posted June 7, 2019 Share Posted June 7, 2019 Revised Entries Changed name from [Session Manager *] to [App Compat Cache *] Removed: FileKey1 & FileKey2 and added into [Windows Logs *] entry. [App Compat Cache *] LangSecRef=3025 Detect=HKLM\Software\Microsoft\Windows Default=False RegKey1=HKLM\System\CurrentControlSet\Control\Session Manager\AppCompatCache|AppCompatCache RegKey2=HKLM\System\CurrentControlSet\Control\Session Manager\AppCompatCache|CacheMainSdb RegKey3=HKLM\System\CurrentControlSet\Control\Session Manager\AppCompatCache|SdbTime Added: FileKey9 & FileKey10 [Windows Logs *] LangSecRef=3025 Detect=HKLM\Software\Microsoft\Windows Default=False FileKey1=%CommonAppData%\Microsoft\Network\Downloader|*.*|RECURSE FileKey2=%CommonAppData%\Microsoft\Windows Security Health\Logs|*.*|RECURSE FileKey3=%CommonAppData%\USOShared\Logs|*.*|RECURSE FileKey4=%LocalAppData%\ConnectedDevicesPlatform|*.log FileKey5=%LocalAppData%\Diagnostics|*.*|RECURSE FileKey6=%ProgramFiles%\UNP\Logs|*.* FileKey7=%SystemDrive%\PerfLogs\System\Diagnostics|*.*|RECURSE FileKey8=%SystemDrive%\PerfLogs\System\Performance|*.*|RECURSE FileKey9=%WinDir%\AppCompat\Programs|*.txt;*.xml FileKey10=%WinDir%\AppCompat\Programs\Install|*.txt;*.xml FileKey11=%WinDir%\debug\WIA|*.log FileKey12=%WinDir%\inf|*.log* FileKey13=%WinDir%\Logs\CBS|*.cab FileKey14=%WinDir%\Logs\dosvc|*.*|RECURSE FileKey15=%WinDir%\Logs\NetSetup|*.*|RECURSE FileKey16=%WinDir%\Logs\SIH|*.*|RECURSE FileKey17=%WinDir%\Logs\WindowsBackup|*.etl FileKey18=%WinDir%\Panther|cbs.log;DDACLSys.log;miglog.xml;Migrep.html;PostGatherPnPList.log;PreGatherPnPList.log FileKey19=%WinDir%\Panther\FastCleanup|*.log FileKey20=%WinDir%\Panther\Rollback|*.txt FileKey21=%WinDir%\Panther\UnattendGC|diagerr.xml;diagwrn.xml FileKey22=%WinDir%\repair|setup.log FileKey23=%WinDir%\security\logs|*.*|RECURSE FileKey24=%WinDir%\System32\catroot2|*.chk;*.log;*.jrs;*.txt FileKey25=%WinDir%\System32\LogFiles\HTTPERR|*.log FileKey26=%WinDir%\System32\LogFiles\Scm|*.*|RECURSE FileKey27=%WinDir%\System32\LogFiles\setupcln|*.*|RECURSE FileKey28=%WinDir%\System32\LogFiles\Srt|*.*|RECURSE FileKey29=%WinDir%\System32\LogFiles\WMI|*.*|RECURSE FileKey30=%WinDir%\System32\SleepStudy|*.etl FileKey31=%WinDir%\System32\SleepStudy\ScreenOn|*.etl FileKey32=%WinDir%\System32\sysprep\Panther\IE|diagerr.xml;diagwrn.xml;*.log FileKey33=%WinDir%\System32\WDI\*|snapshot.etl|REMOVESELF FileKey34=%WinDir%\System32\WDI\LogFiles\StartupInfo|*.*|RECURSE RegKey1=HKLM\Software\Microsoft\RADAR\HeapLeakDetection\DiagnosedApplications RegKey2=HKLM\Software\Microsoft\Tracing RegKey3=HKLM\Software\Wow6432Node\Microsoft\RADAR\HeapLeakDetection\DiagnosedApplications RegKey4=HKLM\Software\Wow6432Node\Microsoft\Tracing Link to comment Share on other sites More sharing options...
Winapp2.ini Posted June 7, 2019 Author Share Posted June 7, 2019 Would those filekeys be okay in [Windows Logs *]? winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted June 7, 2019 Share Posted June 7, 2019 17 hours ago, Winapp2.ini said: Would those filekeys be okay in [Windows Logs *]? I think that is fine. I just added those FileKeys into [Windows Logs *] entry. Link to comment Share on other sites More sharing options...
SMalik Posted June 8, 2019 Share Posted June 8, 2019 Some information on Windows ShellBags https://support.microsoft.com/en-us/help/813711 Windows XP HKCU\Software\Microsoft\Windows\Shell\BagMRU HKCU\Software\Microsoft\Windows\Shell\Bags HKCU\Software\Microsoft\Windows\ShellNoRoam\BagMRU HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags Windows Vista or Windows 7 32-bit HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\BagMRU HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags HKCU\Software\Microsoft\Windows\Shell\BagMRU HKCU\Software\Microsoft\Windows\Shell\Bags Windows Vista or Windows 7 64-bit HKCU\Software\Classes\WOW6432Node\Local Settings\Software\Microsoft\Windows\Shell\BagMRU HKCU\Software\Classes\WOW6432Node\Local Settings\Software\Microsoft\Windows\Shell\Bags HKCU\Software\Microsoft\Windows\Shell\BagMRU HKCU\Software\Microsoft\Windows\Shell\Bags Windows 8.1/10 32-bit HKCR\Local Settings\Software\Microsoft\Windows\Shell\BagMRU HKCR\Local Settings\Software\Microsoft\Windows\Shell\Bags HKCU\Local Settings\Software\Microsoft\Windows\Shell\BagMRU HKCU\Local Settings\Software\Microsoft\Windows\Shell\Bags HKCU\Software\Microsoft\Windows\Shell\BagMRU HKCU\Software\Microsoft\Windows\Shell\Bags Windows 8.1/10 64-bit HKCR\Local Settings\Software\Microsoft\Windows\Shell\BagMRU HKCR\Local Settings\Software\Microsoft\Windows\Shell\Bags HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\BagMRU HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags HKCU\Software\Microsoft\Windows\Shell\BagMRU HKCU\Software\Microsoft\Windows\Shell\Bags Link to comment Share on other sites More sharing options...
SMalik Posted June 8, 2019 Share Posted June 8, 2019 I have edited the [Windows ShellBags *] entry. Added support for Windows Vista and Windows 7 64-bit. Also, some other changes. https://forum.piriform.com/topic/32310-winapp2ini-additions/?do=findComment&comment=306742 Link to comment Share on other sites More sharing options...
APMichael Posted June 8, 2019 Share Posted June 8, 2019 Thanks for the research. The entry needed some minor corrections: RegKey13+14 are duplicates of RegKey5+6 and ExcludeKey6 is a duplicate of ExcludeKey2. The sorting is not alphabetical (triggers errors in WinappDebug). Revised entry: [Windows ShellBags *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False Warning=This will reset folders size, view, icon or position settings to default and remove traces of the folders that do not exist anymore. RegKey1=HKCR\Local Settings\Software\Microsoft\Windows\Shell\BagMRU RegKey2=HKCR\Local Settings\Software\Microsoft\Windows\Shell\Bags RegKey3=HKCU\Local Settings\Software\Microsoft\Windows\Shell\BagMRU RegKey4=HKCU\Local Settings\Software\Microsoft\Windows\Shell\Bags RegKey5=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\BagMRU RegKey6=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags RegKey7=HKCU\Software\Classes\WOW6432Node\Local Settings\Software\Microsoft\Windows\Shell\BagMRU RegKey8=HKCU\Software\Classes\WOW6432Node\Local Settings\Software\Microsoft\Windows\Shell\Bags RegKey9=HKCU\Software\Microsoft\Windows\Shell\BagMRU RegKey10=HKCU\Software\Microsoft\Windows\Shell\Bags RegKey11=HKCU\Software\Microsoft\Windows\ShellNoRoam\BagMRU RegKey12=HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags ExcludeKey1=REG|HKCR\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders ExcludeKey2=REG|HKCU\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders ExcludeKey3=REG|HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders ExcludeKey4=REG|HKCU\Software\Classes\WOW6432Node\Local Settings\Software\Microsoft\Windows\Shell\Bags\AllFolders ExcludeKey5=REG|HKCU\Software\Microsoft\Windows\Shell\Bags\1\Desktop ExcludeKey6=REG|HKCU\Software\Microsoft\Windows\ShellNoRoam\Bags\AllFolders Link to comment Share on other sites More sharing options...
SMalik Posted June 8, 2019 Share Posted June 8, 2019 Revised Entry Added: RegKey1 [Scan *] DetectOS=10.0| LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.WindowsScan_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.WindowsScan_*\AC\INet*|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.WindowsScan_*\AC\NVIDIA Corporation\NV_Cache|*.* FileKey3=%LocalAppData%\Packages\Microsoft.WindowsScan_*\AC\Temp|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.WindowsScan_*\AC\TokenBroker\Cache|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.WindowsScan_*\LocalCache|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.WindowsScan_*\LocalState\Cache|*.*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.WindowsScan_*\TempState|*.*|RECURSE RegKey1=HKCU\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.WindowsScan_8wekyb3d8bbwe\PersistedStorageItemTable\ManagedByApp Link to comment Share on other sites More sharing options...
SMalik Posted June 8, 2019 Share Posted June 8, 2019 Revised Entry Changed name from [Tipard Converter *] to [Tipard Video Converter *] [Tipard Video Converter *] LangSecRef=3023 Detect1=HKCU\Software\Tipard Studio\Tipard Video Converter Detect2=HKCU\Software\Tipard Studio\Tipard Video Converter Ultimate Default=False FileKey1=%LocalAppData%\Tipard Studio\Tipard *|*.txt RegKey1=HKCU\Software\Tipard Studio\Tipard Video Converter\Edit|LastVideoFilePath RegKey2=HKCU\Software\Tipard Studio\Tipard Video Converter Ultimate\Edit|LastVideoFilePath Link to comment Share on other sites More sharing options...
SMalik Posted June 8, 2019 Share Posted June 8, 2019 New Entries Tipard Video Converter and Tipard Total Media Converter are two different programs. Please keep the entries separated. Same thing with Wondershare UniConverter and Wondershare Video Converter. [Tipard Total Media Converter *] LangSecRef=3023 Detect=HKCU\Software\Tipard Studio\Tipard Total Media Converter Default=False FileKey1=%LocalAppData%\Tipard Studio\Tipard *|*.txt RegKey1=HKCU\Software\Tipard Studio\Tipard Total Media Converter\Edit|LastVideoFilePath [Wondershare UniConverter *] LangSecRef=3023 Detect=HKLM\SOFTWARE\Wondershare\Wondershare UniConverter Default=False FileKey1=%SystemDrive%\UniConverter\Downloaded\temp|*.*|REMOVESELF FileKey2=%ProgramFiles%\Wondershare\Video Converter Ultimate(CPC)\Log|*.*|RECURSE FileKey3=%CommonAppData%\Wondershare\ProductFeatures\*Logs|*.*|RECURSE FileKey4=%CommonAppData%\Wondershare\UniConverter\DataTrack|tmp;*.bak;*.log FileKey5=%CommonAppData%\Wondershare\WAF\ProductFeatures\*Logs|*.*|RECURSE FileKey6=%CommonAppData%\Wondershare MediaServer|*.txt Link to comment Share on other sites More sharing options...
APMichael Posted June 10, 2019 Share Posted June 10, 2019 Thanks for the new and revised entries. Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/b55df926687ea91c53f0f0af4124565f6b81e214 Link to comment Share on other sites More sharing options...
SMalik Posted June 10, 2019 Share Posted June 10, 2019 1 hour ago, APMichael said: Thanks for the new and revised entries. Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/b55df926687ea91c53f0f0af4124565f6b81e214 I use Tipard Total Media Converter. They don't have Tipard Total Media Converter Platinum. [Tipard Total Media Converter *] LangSecRef=3023 Detect1=HKCU\Software\Tipard Studio\Tipard Total Media Converter Detect2=HKCU\Software\Tipard Studio\Tipard Total Media Converter Platinum Link to comment Share on other sites More sharing options...
APMichael Posted June 10, 2019 Share Posted June 10, 2019 1 hour ago, SMalik said: I use Tipard Total Media Converter. They don't have Tipard Total Media Converter Platinum. .... But it was once available and not everyone always buys an update/upgrade. That's why we should keep it. Many other entries also support older versions of programs. Link to comment Share on other sites More sharing options...
dvdbane Posted June 14, 2019 Share Posted June 14, 2019 On 6/2/2019 at 20:32, SMalik said: I suggest changing the name of [Web Data *] to [Search Engines Data *]. Removed: Warning=This will remove Autofill, Autocomplete, Search Engines keyword, Sign-in and Credit Card info.There is no need to have a warning. [Search Engines Data *] can someone check again this entry? i don't use chrome much so i only test autofill and this entry remove autofill Link to comment Share on other sites More sharing options...
APMichael Posted June 14, 2019 Share Posted June 14, 2019 4 hours ago, dvdbane said: ... i don't use chrome much so i only test autofill and this entry remove autofill ... Thank you for pointing that out. If the entry deletes the Autofill data, then we better add the warning again. Link to comment Share on other sites More sharing options...
siliconman01 Posted June 15, 2019 Share Posted June 15, 2019 Modified entry: [Dell Update *] Added FileKey1 [Dell Update *] LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\DellInc.DellUpdate_htrsf667h5kn2 Default=False FileKey1=%CommonAppData%\Dell\UpdateService\Downloads\*|*.*|REMOVESELF FileKey2=%LocalAppData%\Packages\DellInc.DellUpdate_*\AC\NVIDIA Corporation\NV_Cache|*.* FileKey3=%LocalAppData%\Packages\DellInc.DellUpdate_*\AC\Temp|*.*|RECURSE FileKey4=%LocalAppData%\Packages\DellInc.DellUpdate_*\LocalCache\Local\Microsoft\CLR_v4.0\UsageLogs|*.log FileKey5=%LocalAppData%\Packages\DellInc.DellUpdate_*\LocalCache\Local\Microsoft\Windows\Caches|*.* FileKey6=%LocalAppData%\Packages\DellInc.DellUpdate_*\TempState|*.*|RECURSE Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
siliconman01 Posted June 15, 2019 Share Posted June 15, 2019 Modified entry: [Dell Logs *] Added FileKey5/6/8 [Dell Logs *] LangSecRef=3024 Detect1=HKLM\Software\Dell\MUP Detect2=HKLM\Software\Dell\UpdateService Detect3=HKLM\Software\PC-Doctor DetectFile1=%AppData%\Creative\DELL Webcam Center DetectFile2=%CommonAppData%\Dell DetectFile3=%LocalAppData%\Dell DetectFile4=%LocalAppData%\SupportSoft\DellSupportCenter DetectFile5=%ProgramFiles%\Dell* Default=False FileKey1=%AppData%\Creative\DELL Webcam Center|MO_Log.txt FileKey2=%AppData%\PCDr\*\Logs|*.* FileKey3=%CommonAppData%\Dell\*\Log|*.* FileKey4=%CommonAppData%\Dell\*\Logs|*.* FileKey5=%CommonAppData%\Dell\D3\pla\*\*|*.txt|REMOVESELF FileKey6=%CommonAppData%\Dell\D3\Resources\Logs\serilog|*.* FileKey7=%CommonAppData%\Dell\Drivers\*|*.tmp FileKey8=%CommonAppData%\Dell\Drivers\*\DUPLogDir|*.log;*tmp FileKey9=%CommonAppData%\Dell\Update|*.txt FileKey10=%CommonAppData%\Dell\UpdateService\Clients\Update|*.log FileKey11=%CommonAppData%\Dell\UpdateService\UpdatePackage\Log|*.txt FileKey12=%CommonAppData%\PCDr\*\Cache|*.xml FileKey13=%CommonAppData%\PCDr\*\Cache\archives|*.*|RECURSE FileKey14=%CommonAppData%\PCDr\*\Cache\BUMA|*.* FileKey15=%CommonAppData%\PCDr\*\Cache\DriverScan|*.* FileKey16=%CommonAppData%\PCDr\*\Logs|*.log FileKey17=%LocalAppData%\Dell\*\Log|*.* FileKey18=%LocalAppData%\Dell\DellMobileConnect|*.log FileKey19=%LocalAppData%\SupportSoft\DellSupportCenter\*\state\logs|*.* FileKey20=%ProgramFiles%\Dell*|*.log|RECURSE Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
SMalik Posted June 15, 2019 Share Posted June 15, 2019 I guess we need this back. The built-in entry is not cleaning all of the DOM storage. https://forum.piriform.com/topic/32310-winapp2ini-additions/?do=findComment&comment=306636 [DOM Storage *] LangSecRef=3026 Detect1=HKLM\Software\Mozilla\Pale Moon Detect2=HKLM\Software\Mozilla\SeaMonkey Detect3=HKLM\Software\Mozilla\Waterfox DetectFile=%AppData%\Mozilla\Firefox Default=False FileKey1=%AppData%\Moonchild Productions\Pale Moon\Profiles\*|webappsstore.sqlite FileKey2=%AppData%\Mozilla\Firefox\Profiles\*|webappsstore.sqlite FileKey3=%AppData%\Mozilla\SeaMonkey\Profiles\*|webappsstore.sqlite FileKey4=%AppData%\Waterfox\Profiles\*|webappsstore.sqlite Link to comment Share on other sites More sharing options...
SMalik Posted June 15, 2019 Share Posted June 15, 2019 New Entries [Suggested UWP Programs *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\ContentDeliveryManager\SuggestedApps [Taskbar Programs Statistic *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\FeatureUsage\AppBadgeUpdated RegKey2=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\FeatureUsage\AppLaunch RegKey3=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\FeatureUsage\AppSwitched RegKey4=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\FeatureUsage\ShowJumpView RegKey5=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\FeatureUsage\TrayButtonClicked Link to comment Share on other sites More sharing options...
siliconman01 Posted June 16, 2019 Share Posted June 16, 2019 Modified entry: [Dell Installation Files *] Removed Detect1 and Detect2. Added DetectFile for users who install a Dell component (such as Dell Monitor) on a non-Dell system [Dell Installation Files *] LangSecRef=3024 DetectFile=%SystemDrive%\Dell Warning=This will delete your Dell installation files. Default=False FileKey1=%SystemDrive%\dell|*.*|REMOVESELF Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
APMichael Posted June 17, 2019 Share Posted June 17, 2019 Thanks for the new and revised entries. Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/56f81edca62b5fb4653d0a1a5801e6fbc52f8fc4 Link to comment Share on other sites More sharing options...
APMichael Posted June 19, 2019 Share Posted June 19, 2019 On 15.6.2019 at 12:06, siliconman01 said: Modified entry: [Dell Logs *] Added FileKey5/6/8 ... FileKey8=%CommonAppData%\Dell\Drivers\*\DUPLogDir|*.log;*tmp ... Just to be safe: Is the pattern "*tmp" correct or was the dot accidentally forgotten? Link to comment Share on other sites More sharing options...
