siliconman01 Posted March 27, 2019 Share Posted March 27, 2019 (edited) 34 minutes ago, APMichael said: Would "DetectFile=%CommonAppData%\CanonBJ\IJPrinter\CNMWindows" possibly work or does this path/folder also exist on your system? The CNMWindows folder exists, yes, so that would not resolve the issue from my viewpoint. Edited March 27, 2019 by siliconman01 included registry pic Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
APMichael Posted March 27, 2019 Share Posted March 27, 2019 Ok, thanks for your quick reply. Link to comment Share on other sites More sharing options...
APMichael Posted April 1, 2019 Share Posted April 1, 2019 Quote The post has been deleted. Please see the post below. (https://forum.piriform.com/topic/32310-winapp2ini-additions/?page=314&tab=comments#comment-305111) Thank you, but is this entry really safe? I guess you're only using the MCT to create an ISO file, right? Because if you read the many articles about these folders, it seems you also need these folders for a Windows rollback if you have used the MCT for a Windows upgrade (or if Windows has upgraded itself). For example: https://www.howtogeek.com/268667/what-is-the-windows.bt-folder-and-can-you-delete-it/. There is also an entry in the Winapp3.ini: [Old Windows Installation *]. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted April 1, 2019 Moderators Share Posted April 1, 2019 Didn't know that, I only used it to create a USB Flash Drive installer. I've deleted my post after reading your link to protect anyone who might blindly use it without knowing. Link to comment Share on other sites More sharing options...
CSGalloway Posted April 2, 2019 Share Posted April 2, 2019 I see an entry for [Auslogics Registry Defrag*] is in the winapp2.ini but not showing up on my system. I am using windows 7 x64. The places where Auslogics is mentioned in my registry are the following: HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Auslogics\Registry Defrag\11.x The reports are stored in "C:\ProgramData\Auslogics\Registry Defrag\11.x\Reports" Link to comment Share on other sites More sharing options...
APMichael Posted April 2, 2019 Share Posted April 2, 2019 17 hours ago, Andavari said: Didn't know that, I only used it to create a USB Flash Drive installer... Thanks for your reply. 12 hours ago, CSGalloway said: I see an entry for [Auslogics Registry Defrag*] is in the winapp2.ini but not showing up on my system. I am using windows 7 x64... This should work (Detect does not require "Wow6432Node"): [Auslogics Registry Defrag *] LangSecRef=3024 Detect1=HKCU\Software\Auslogics\Registry Defrag Detect2=HKLM\Software\Auslogics\Registry Defrag Default=False FileKey1=%AppData%\Auslogics\Registry Defrag\Logs|*.* FileKey2=%AppData%\Auslogics\Registry Defrag\Reports|*.* FileKey3=%CommonAppData%\Auslogics\Registry Defrag\*.x\Reports|*.* Link to comment Share on other sites More sharing options...
siliconman01 Posted April 3, 2019 Share Posted April 3, 2019 Modified entry: [Xbox/ Xbox Game Overlay/Xbox Identity Provider *] Changed name from [Xbox *] to [Xbox/ Xbox Game Overlay/Xbox Identity Provider *] because this code covers three Xbox Apps Added Detect2=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.XboxIdentityProvider_8wekyb3d8bbwe Added FileKey23=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\AC\Nvidia Corporation\NV_Cache|*.* [Xbox/Xbox Game Overlay/Xbox Identity Provider *] DetectOS=10.0| LangSecRef=3031 Detect1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.XboxApp_8wekyb3d8bbwe Detect2=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.XboxIdentityProvider_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.XboxApp_*\AC\INet*|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.XboxApp_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.XboxApp_*\AC\Temp|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.XboxApp_*\AC\TokenBroker\Cache|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.XboxApp_*\LocalCache|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.XboxApp_*\LocalState|*.log*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.XboxApp_*\LocalState\*Cache|*.*|RECURSE FileKey8=%LocalAppData%\Packages\Microsoft.XboxApp_*\LocalState\DiagOutputDir|*.txt FileKey9=%LocalAppData%\Packages\Microsoft.XboxApp_*\LocalState\SmartGlass|*.log FileKey10=%LocalAppData%\Packages\Microsoft.XboxApp_*\TempState|*.*|RECURSE FileKey11=%LocalAppData%\Packages\Microsoft.XboxGameOverlay_*\AC\INet*|*.*|RECURSE FileKey12=%LocalAppData%\Packages\Microsoft.XboxGameOverlay_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey13=%LocalAppData%\Packages\Microsoft.XboxGameOverlay_*\AC\Temp|*.*|RECURSE FileKey14=%LocalAppData%\Packages\Microsoft.XboxGameOverlay_*\LocalCache|*.*|RECURSE FileKey15=%LocalAppData%\Packages\Microsoft.XboxGameOverlay_*\LocalState\Cache|*.*|RECURSE FileKey16=%LocalAppData%\Packages\Microsoft.XboxGameOverlay_*\LocalState\DiagOutputDir|*.txt FileKey17=%LocalAppData%\Packages\Microsoft.XboxGameOverlay_*\TempState|*.*|RECURSE FileKey18=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\AC\INet*|*.*|RECURSE FileKey19=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\AC\Microsoft\CLR_v4.0*|*.log FileKey20=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\AC\Microsoft\CLR_v4.0*\NativeImages\Temp|*.*|RECURSE FileKey21=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\AC\Microsoft\CLR_v4.0*\UsageLogs|*.*|RECURSE FileKey22=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey23=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\AC\Nvidia Corporation\NV_Cache|*.* FileKey24=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\AC\Temp|*.*|RECURSE FileKey25=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\AC\TokenBroker\Cache|*.*|RECURSE FileKey26=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\LocalCache|*.*|RECURSE FileKey27=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\LocalState\Cache|*.*|RECURSE FileKey28=%LocalAppData%\Packages\Microsoft.XboxIdentityProvider_*\TempState|*.*|RECURSE Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
APMichael Posted April 3, 2019 Share Posted April 3, 2019 Thanks! IMHO we should continue to use [Xbox *], as the other apps are actually only hidden "sub-apps" of the Xbox app. (And if we add more "sub-apps" in the future, the name will be far too long.) https://forum.piriform.com/topic/32310-winapp2ini-additions/?page=302&tab=comments#comment-302515 Link to comment Share on other sites More sharing options...
siliconman01 Posted April 3, 2019 Share Posted April 3, 2019 5 hours ago, APMichael said: Thanks! IMHO we should continue to use [Xbox *], as the other apps are actually only hidden "sub-apps" of the Xbox app. (And if we add more "sub-apps" in the future, the name will be far too long.) https://forum.piriform.com/topic/32310-winapp2ini-additions/?page=302&tab=comments#comment-302515 Leaving the name as [Xbox *] is fine with me. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
APMichael Posted April 4, 2019 Share Posted April 4, 2019 Thanks! Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/c8c6096cc27fa9e79360f2ac07cc8ef3b69c3dc5 Link to comment Share on other sites More sharing options...
SMalik Posted April 8, 2019 Share Posted April 8, 2019 Revised Entry Removing files from the two locations listed below breaking up the Microsoft Apps Live Tile feature. These should be removed. Removed: %LocalAppData%\Microsoft\Windows\Notifications|*.db;*.db-shm;*.db-wal;*.tmp %WinDir%\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Notifications|*.db;*.db-shm;*.db-wal;*.tmp [Push Notifications *] DetectOS=10.0| LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%LocalAppData%\Microsoft\Windows\Notifications\wpnidm|*.*|RECURSE FileKey2=%WinDir%\System32\config\systemprofile\AppData\Local\Microsoft\Windows\Notifications\wpnidm|*.*|RECURSE RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\PushNotifications\wpnidm RegKey2=HKU\.DEFAULT\Software\Microsoft\Windows\CurrentVersion\PushNotifications\wpnidm Link to comment Share on other sites More sharing options...
212eta Posted April 10, 2019 Share Posted April 10, 2019 I use a Google Chrome Extension called Translate Selected Text For example, I visited THIS web-page, selected text, and translated it: When selecting the Winapp2.ini entries: Extensions State* , History*, and Logs*, the above Chrome Extension becomes neutralized (i.e. it becomes no longer available via the Right-Click). The same happens when I select to clear the Google Chrome entry Session of CCleaner. Link to comment Share on other sites More sharing options...
APMichael Posted April 10, 2019 Share Posted April 10, 2019 2 hours ago, 212eta said: ... When selecting the Winapp2.ini entries: Extensions State*, History*, and Logs*, the above Chrome Extension becomes neutralized (i.e. it becomes no longer available via the Right-Click). ... Referring to the entry names you are using an old version of Winapp2.ini. Please update to the latest version. Link to comment Share on other sites More sharing options...
212eta Posted April 10, 2019 Share Posted April 10, 2019 I updated to the latest version of winapp2.ini for CCleaner. Logs* and Session entries STILL exist and the respective Chrome Extension becomes neutralized (i.e. it becomes no longer available via the Right-Click). Link to comment Share on other sites More sharing options...
Moderators Nergal Posted April 10, 2019 Moderators Share Posted April 10, 2019 (edited) 8 hours ago, 212eta said: I updated to the latest version for CCleaner. Logs* and Session entries STILL exist and the respective Chrome Extension becomes neutralized (i.e. it becomes no longer available via the Right-Click). No he means the latest version of winapp2 which seems to have edited rules that fix the issue you have (caused by your old winapp2) Edited April 11, 2019 by Nergal ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
Moderators Andavari Posted April 10, 2019 Moderators Share Posted April 10, 2019 That's why I have exclusions in CCleaner as it pertains to SRWare Iron's extensions, extension settings, etc., i.e.; can't be broken inadvertently. Chrome/Chromium based browsers extensions easily break if cleaning the wrong thing, hence it's worthwhile having them excluded. Link to comment Share on other sites More sharing options...
212eta Posted April 11, 2019 Share Posted April 11, 2019 10 hours ago, Nergal said: No he means the latest version of winapp2 which seems to have edited rules that fix the issue you have (caused by your old winapp2) I corrected my Post, HERE. The last release of winapp2.ini STILL includes entries Logs* and Session which BOTH damage the respective Chrome Extension. Link to comment Share on other sites More sharing options...
APMichael Posted April 11, 2019 Share Posted April 11, 2019 3 hours ago, 212eta said: ... The last release of winapp2.ini STILL includes entries Logs* and Session which BOTH damage the respective Chrome Extension. Thanks for the update. I tested the extension and the Winapp2.ini entries [Logs *] and [Internet History *], formerly [History *], do not damage it. We fixed the entry [Logs *] some time ago and it now only removes usual logfiles. But I can confirm that the built-in entry of CCleaner [Google Chrome - Session] damages the extension. As a workaround, you can exclude the following folder in the CCleaner options: C:\Users\<your username>\AppData\Local\Google\Chrome\User Data\Default\Extension State\ Please report this bug under "CCleaner Bug Reporting": https://forum.piriform.com/forum/8-ccleaner-bug-reporting/. Thank you! Link to comment Share on other sites More sharing options...
siliconman01 Posted April 11, 2019 Share Posted April 11, 2019 Or you could switch to "One Click Translate" extension which is not affected by Sessions being cleaned by CCleaner Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
APMichael Posted April 11, 2019 Share Posted April 11, 2019 Thanks for the revised entry. Winapp2.ini updates:https://github.com/MoscaDotTo/Winapp2/commit/3cde3abef95e59a5dbbf193e8c7c7e7d01f0cef3https://github.com/MoscaDotTo/Winapp2/commit/30f6dc2c3e544c384887c09d87f17ea622140a75https://github.com/MoscaDotTo/Winapp2/commit/a82bfb3616910b685514ec439ece079b225fb999 Link to comment Share on other sites More sharing options...
SMalik Posted April 13, 2019 Share Posted April 13, 2019 Revised Entry Added: cookies.sqlite-shm cookies.sqlite-wal [Cookies and HSTS Cookies *] LangSecRef=3026 Detect1=HKLM\Software\Mozilla\Pale Moon Detect2=HKLM\Software\Mozilla\SeaMonkey Detect3=HKLM\Software\Mozilla\Waterfox DetectFile=%AppData%\Mozilla\Firefox Default=False Warning=This will delete all cookies at once. Overrides the option "Cookies to Keep". FileKey1=%AppData%\Moonchild Productions\Pale Moon\Profiles\*|cookies.sqlite;cookies.sqlite-shm;cookies.sqlite-wal;SiteSecurityServiceState.txt FileKey2=%AppData%\Mozilla\Firefox\Profiles\*|cookies.sqlite;cookies.sqlite-shm;cookies.sqlite-wal;SiteSecurityServiceState.txt FileKey3=%AppData%\Mozilla\SeaMonkey\Profiles\*|cookies.sqlite;cookies.sqlite-shm;cookies.sqlite-wal;SiteSecurityServiceState.txt FileKey4=%AppData%\Waterfox\Profiles\*|cookies.sqlite;cookies.sqlite-shm;cookies.sqlite-wal;SiteSecurityServiceState.txt Link to comment Share on other sites More sharing options...
SMalik Posted April 13, 2019 Share Posted April 13, 2019 New Entries [Alternate Services *] LangSecRef=3026 Detect1=HKLM\Software\Mozilla\Pale Moon Detect2=HKLM\Software\Mozilla\SeaMonkey Detect3=HKLM\Software\Mozilla\Waterfox DetectFile=%AppData%\Mozilla\Firefox Default=False FileKey1=%AppData%\Moonchild Productions\Pale Moon\Profiles\*|AlternateServices.txt FileKey2=%AppData%\Mozilla\Firefox\Profiles\*|AlternateServices.txt FileKey3=%AppData%\Mozilla\SeaMonkey\Profiles\*|AlternateServices.txt FileKey4=%AppData%\Waterfox\Profiles\*|AlternateServices.txt [Content Preferences *] LangSecRef=3026 Detect1=HKLM\Software\Mozilla\Pale Moon Detect2=HKLM\Software\Mozilla\SeaMonkey Detect3=HKLM\Software\Mozilla\Waterfox DetectFile=%AppData%\Mozilla\Firefox Default=False FileKey1=%AppData%\Moonchild Productions\Pale Moon\Profiles\*|content-prefs.sqlite FileKey2=%AppData%\Mozilla\Firefox\Profiles\*|content-prefs.sqlite FileKey3=%AppData%\Mozilla\SeaMonkey\Profiles\*|content-prefs.sqlite FileKey4=%AppData%\Waterfox\Profiles\*|content-prefs.sqlite [Permissions *] LangSecRef=3026 Detect1=HKLM\Software\Mozilla\Pale Moon Detect2=HKLM\Software\Mozilla\SeaMonkey Detect3=HKLM\Software\Mozilla\Waterfox DetectFile=%AppData%\Mozilla\Firefox Default=False FileKey1=%AppData%\Moonchild Productions\Pale Moon\Profiles\*|permissions.sqlite FileKey2=%AppData%\Mozilla\Firefox\Profiles\*|permissions.sqlite FileKey3=%AppData%\Mozilla\SeaMonkey\Profiles\*|permissions.sqlite FileKey4=%AppData%\Waterfox\Profiles\*|permissions.sqlite [Sessionstore Backups *] LangSecRef=3026 Detect1=HKLM\Software\Mozilla\Pale Moon Detect2=HKLM\Software\Mozilla\SeaMonkey Detect3=HKLM\Software\Mozilla\Waterfox DetectFile=%AppData%\Mozilla\Firefox Default=False FileKey1=%AppData%\Moonchild Productions\Pale Moon\Profiles\*\sessionstore-backups|*.*|RECURSE FileKey2=%AppData%\Mozilla\Firefox\Profiles\*\sessionstore-backups|*.*|RECURSE FileKey3=%AppData%\Mozilla\SeaMonkey\Profiles\*\sessionstore-backups|*.*|RECURSE FileKey4=%AppData%\Waterfox\Profiles\*\sessionstore-backups|*.*|RECURSE Link to comment Share on other sites More sharing options...
APMichael Posted April 14, 2019 Share Posted April 14, 2019 13 hours ago, SMalik said: ... [Sessionstore Backups *] ... FileKey2=%AppData%\Mozilla\Firefox\Profiles\*\sessionstore-backups|*.*|RECURSE ... Thanks for the entries. In my tests the built-in entry "Firefox - Session" already cleans this folder completely. Link to comment Share on other sites More sharing options...
siliconman01 Posted April 16, 2019 Share Posted April 16, 2019 Modified entry: [CyberLink PowerDVD *] Added Detect5 & RegKey13/14/15 for newly released Cyberlink PowerDVD 19 [CyberLink PowerDVD *] LangSecRef=3023 Detect1=HKCU\Software\CyberLink\PowerDVD15 Detect2=HKCU\Software\CyberLink\PowerDVD16 Detect3=HKCU\Software\CyberLink\PowerDVD17 Detect4=HKCU\Software\CyberLink\PowerDVD18 Detect5=HKCU\Software\CyberLink\PowerDVD19 Default=False FileKey1=%CommonAppData%\Cyberlink\Evoparser|*.xml FileKey2=%LocalAppData%\Cyberlink\DigitalHome|*.log|RECURSE FileKey3=%LocalAppData%\Cyberlink\PowerDVD*|*.log|RECURSE FileKey4=%LocalAppData%\Cyberlink\PowerDVD*\cache*|*.*|RECURSE FileKey5=%LocalAppData%\Cyberlink\PowerDVD*\CL_DMP_Browser|*.*|RECURSE RegKey1=HKCU\Software\CyberLink\PowerDVD15\CLMPSvc\MediaObj\MediaCache5\Data5 RegKey2=HKCU\Software\CyberLink\PowerDVD15\CLMPSvc\MediaObj\MediaCache5\ProgramInfo RegKey3=HKCU\Software\CyberLink\PowerDVD15\CLMPSvc\MediaObj\MediaCache5\Thumbnail5 RegKey4=HKCU\Software\CyberLink\PowerDVD16\CLMPSvc\MediaObj\MediaCache5\Data5 RegKey5=HKCU\Software\CyberLink\PowerDVD16\CLMPSvc\MediaObj\MediaCache5\ProgramInfo RegKey6=HKCU\Software\CyberLink\PowerDVD16\CLMPSvc\MediaObj\MediaCache5\Thumbnail5 RegKey7=HKCU\Software\CyberLink\PowerDVD17\CLMPSvc\MediaObj\MediaCache5\Data5 RegKey8=HKCU\Software\CyberLink\PowerDVD17\CLMPSvc\MediaObj\MediaCache5\ProgramInfo RegKey9=HKCU\Software\CyberLink\PowerDVD17\CLMPSvc\MediaObj\MediaCache5\Thumbnail5 RegKey10=HKCU\Software\CyberLink\PowerDVD18\CLMPSvc\MediaObj\MediaCache5\Data5 RegKey11=HKCU\Software\CyberLink\PowerDVD18\CLMPSvc\MediaObj\MediaCache5\ProgramInfo RegKey12=HKCU\Software\CyberLink\PowerDVD18\CLMPSvc\MediaObj\MediaCache5\Thumbnail5 RegKey13=HKCU\Software\CyberLink\PowerDVD19\CLMPSvc\MediaObj\MediaCache5\Data5 RegKey14=HKCU\Software\CyberLink\PowerDVD19\CLMPSvc\MediaObj\MediaCache5\ProgramInfo RegKey15=HKCU\Software\CyberLink\PowerDVD19\CLMPSvc\MediaObj\MediaCache5\Thumbnail5 Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted April 16, 2019 Moderators Share Posted April 16, 2019 On 4/13/2019 at 15:36, SMalik said: [Permissions *] LangSecRef=3026 Detect1=HKLM\Software\Mozilla\Pale Moon Detect2=HKLM\Software\Mozilla\SeaMonkey Detect3=HKLM\Software\Mozilla\Waterfox DetectFile=%AppData%\Mozilla\Firefox Default=False FileKey1=%AppData%\Moonchild Productions\Pale Moon\Profiles\*|permissions.sqlite FileKey2=%AppData%\Mozilla\Firefox\Profiles\*|permissions.sqlite FileKey3=%AppData%\Mozilla\SeaMonkey\Profiles\*|permissions.sqlite FileKey4=%AppData%\Waterfox\Profiles\*|permissions.sqlite CCleaner's already built-in Site Preferences already cleans that exact file, at least in Firefox ESR Portable v60.6.1esr. Link to comment Share on other sites More sharing options...
