Winapp2.ini Posted September 9, 2019 Author Share Posted September 9, 2019 20 hours ago, dvdbane said: Hi @Winapp2.ini winapp2ool v1.2.7175.37819 weird thing happen when using trim for this location HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Foxit Software\Foxit Reader Detect=HKLM\Software\Foxit Software\Foxit Reader = trimmed(wrong) Detect=HKLM\Software\Foxit Software = not trim(correct) tested this location HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\SHAREit Technologies\SHAREit and winapp2ool trim correctly just for testing purpose, tested this location \SHAREit Technologies\SHAREit Tech and winapp2ool trim correctly [Foxit Reader **] LangSecRef=3021 Detect=HKLM\Software\Foxit Software\Foxit Reader Default=False Thanks for pointing this out, I'll look into it when I get some time winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
siliconman01 Posted September 10, 2019 Share Posted September 10, 2019 Modified entry: [Syncios Cell Phone Backup & Manage *] Added FileKey1. And yes the misspelling of sycnios (misspelled syncios by program developer) is correct. [Syncios Cell Phone Backup & Manage *] LangSecRef=3024 Detect1=HKCU\Software\Syncios Detect2=HKCU\Software\Syncios Data Transfer Default=False FileKey1=%AppData%\app_sycnios_transfer_loader|*.*|REMOVESELF FileKey2=%AppData%\Syncios|android.log;log.txt FileKey3=%AppData%\Syncios Data Transfer|*.log|RECURSE FileKey4=%Documents%\Syncios Data Transfer|preference_conf.ini.old.bak Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
APMichael Posted September 16, 2019 Share Posted September 16, 2019 Thanks for the modified entry. Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/01a2ad4cef959173e49e3a0e9ce02a2ccfbed4ba Link to comment Share on other sites More sharing options...
don_dolarson Posted September 18, 2019 Share Posted September 18, 2019 I've a new tab page extension and whenever I clean chrome temporary files in CCleaner, the new tab page extension settings resets to defaults and I need to import them once a week as CCleaner is set to auto scan every week. How can I find this file to add it to exclusions so I will not be forced to import settings anymore? Link to comment Share on other sites More sharing options...
APMichael Posted September 18, 2019 Share Posted September 18, 2019 15 hours ago, don_dolarson said: I've a new tab page extension and whenever I clean chrome temporary files in CCleaner, the new tab page extension settings resets to defaults and I need to import them once a week as CCleaner is set to auto scan every week. How can I find this file to add it to exclusions so I will not be forced to import settings anymore? Please make sure that you are using the latest version of Winapp2.ini. The responsible CCleaner entry must then be found: Right-click on the first Google Chrome entry and select "Clean <entry name>". Then check to see if the issue occurs. If not, continue with the next Google Chrome entry until the responsible CCleaner entry is found. Link to comment Share on other sites More sharing options...
don_dolarson Posted September 18, 2019 Share Posted September 18, 2019 There is a problem with only this extension. I've latest winapp2.ini of course. I've localized these files/file (by modified time right after temporary folder cleanup and importing extension settings) and the extension is saving settings (thumbnails) in Default/Cache folder of Chrome. Files in this folder are re-created with every Chrome temporary files cleaning, and names of these files are different every time after they've been cleaned. I think it's then impossible Link to comment Share on other sites More sharing options...
APMichael Posted September 18, 2019 Share Posted September 18, 2019 Some months ago, an issue with another extension was reported. The responsible entry was [Google Chrome - Session]. You can try excluding the following folder and see if it helps: C:\Users\<your username>\AppData\Local\Google\Chrome\User Data\Default\Extension State\ Link to comment Share on other sites More sharing options...
SMalik Posted September 18, 2019 Share Posted September 18, 2019 Revised Entry Removed *.lst from FileKey2 and FileKey3 completely because they are in the built-in entry. [Adobe Reader DC *] LangSecRef=3021 Detect=HKLM\Software\Adobe\Acrobat Reader\DC Default=False FileKey1=%AppData%\Adobe\Acrobat\DC\Security\CRLCache|*.*|RECURSE FileKey2=%LocalAppData%\Adobe\Acrobat\DC|IconCacheRdr*.dat;UserCache.bin FileKey3=%LocalAppData%\Adobe\Acrobat\DC\ToolsSearchCacheRdr|*.*|RECURSE FileKey4=%LocalLowAppData%\Adobe\Acrobat\DC|ReaderMessages FileKey5=%LocalLowAppData%\Adobe\Acrobat\DC\ConnectorIcons|*.*|RECURSE FileKey6=%LocalLowAppData%\Adobe\Acrobat\DC\Search|*.*|RECURSE FileKey7=%LocalLowAppData%\Adobe\AcroCef\DC\Acrobat\Cache|*.*|RECURSE RegKey1=HKCU\Software\Adobe\Acrobat Reader\DC\AVConversionFromPDF RegKey2=HKCU\Software\Adobe\Acrobat Reader\DC\AVConversionToPDF RegKey3=HKCU\Software\Adobe\Acrobat Reader\DC\AVGeneral\cDockables RegKey4=HKCU\Software\Adobe\Acrobat Reader\DC\AVGeneral\cRecentToolsList RegKey5=HKCU\Software\Adobe\Acrobat Reader\DC\AVGeneral\cToolbars RegKey6=HKCU\Software\Adobe\Acrobat Reader\DC\RememberedViews\cNoCategoryFiles RegKey7=HKCU\Software\Adobe\Acrobat Reader\DC\ShareIdentity RegKey8=HKCU\Software\Adobe\Adobe Synchronizer\DC Link to comment Share on other sites More sharing options...
don_dolarson Posted September 18, 2019 Share Posted September 18, 2019 7 hours ago, APMichael said: Some months ago, an issue with another extension was reported. The responsible entry was [Google Chrome - Session]. You can try excluding the following folder and see if it helps: C:\Users\<your username>\AppData\Local\Google\Chrome\User Data\Default\Extension State\ Thank you for your engagement. Adding this folder to exclusions hasn't resolved the problem. The extension name I've a problem with is Home - New Tab Page. You can see on attached screenshot what's happening after cleaning temporary files... all images/thumbnails are flushed. 14 of them thumbnails are stored locally on my hard drive and 7 are from an URL somewhere in internet. Settings looks to be OK. It's just these thumbnails I've a problem with... I've just discovered an interesting thing with this extension. It looks like it's doing an automatic backup. I can't tell you for now how often it's doing it and what is included in it, but it automatically backup settings and thumbnails and I just need 2 clicks to restore to state from last backup. It's not that much to be done which I couldn't do once a week, but I'd prefer to do it automatically, as it should do it. I'm getting a message when restoring it. Link to comment Share on other sites More sharing options...
APMichael Posted September 19, 2019 Share Posted September 19, 2019 Ok, I think I found the responsible CCleaner entry: [Google Chrome - Internet Cache]. So it is not caused by the Winapp2.ini. To protect the icons of your extension, you should exclude these two folders: C:\Users\<your username>\AppData\Local\Google\Chrome\User Data\Default\File System\000\ C:\Users\<your username>\AppData\Local\Google\Chrome\User Data\Default\File System\Origins\ Note: The "000" folder may have a different number. But right after cleaning up all temporary files and importing the extension settings, it should be "000". Link to comment Share on other sites More sharing options...
don_dolarson Posted September 19, 2019 Share Posted September 19, 2019 You're a king man! It was these 2 folders Link to comment Share on other sites More sharing options...
APMichael Posted September 19, 2019 Share Posted September 19, 2019 Great! I'm glad I could help. Link to comment Share on other sites More sharing options...
siliconman01 Posted September 19, 2019 Share Posted September 19, 2019 1 hour ago, APMichael said: Ok, I think I found the responsible CCleaner entry: [Google Chrome - Internet Cache]. So it is not caused by the Winapp2.ini. To protect the icons of your extension, you should exclude these two folders:C:\Users\<your username>\AppData\Local\Google\Chrome\User Data\Default\File System\000\ C:\Users\<your username>\AppData\Local\Google\Chrome\User Data\Default\File System\Origins\ Note: The "000" folder may have a different number. But right after cleaning up all temporary files and importing the extension settings, it should be "000". Should these be added as ExcludeKey's to [Edge Internet Cache CC *] ??? [Edge Internet Cache CC *] Section=Microsoft Edge Insider DetectFile=%LocalAppData%\Microsoft\Edge* Default=False FileKey1=%LocalAppData%\Microsoft\Edge*|*.tmp|RECURSE FileKey2=%LocalAppData%\Microsoft\Edge*\User Data|*-journal|RECURSE FileKey3=%LocalAppData%\Microsoft\Edge*\User Data\*\Cache|*.*|RECURSE FileKey4=%LocalAppData%\Microsoft\Edge*\User Data\*\File System|*.*|REMOVESELF FileKey5=%LocalAppData%\Microsoft\Edge*\User Data\*\GPUCache|*.* FileKey6=%LocalAppData%\Microsoft\Edge*\User Data\*\Service Worker|*.*|REMOVESELF FileKey7=%LocalAppData%\Microsoft\Edge*\User Data\*\Storage\ext\*\def\GPUCache|*.* FileKey8=%LocalAppData%\Microsoft\Edge*\User Data\ShaderCache\GPUCache|*.* Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
APMichael Posted September 19, 2019 Share Posted September 19, 2019 3 hours ago, siliconman01 said: Should these be added as ExcludeKey's to [Edge Internet Cache CC *] ??? I do not think so, because this is a special case only for this one extension. (The extension possibly does not comply with the specifications for Chrome extensions?) CCleaner's built-in entry has been removing these folders (HTML5 Storage) for a very long time now, without any issue reports. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted September 22, 2019 Moderators Share Posted September 22, 2019 From what I've experienced with Chrome/Chromium based browsers since 2014 the main don't touch directories will have "Local Extension Settings" in the path, which is why I exclude mine in CCleaner, etc., for SRWare Iron Portable. Link to comment Share on other sites More sharing options...
APMichael Posted September 23, 2019 Share Posted September 23, 2019 Thanks for the revised entry and the replies. Winapp2.ini updates:https://github.com/MoscaDotTo/Winapp2/commit/65a0564df9b27c516edfde530a00a466c366b3d5https://github.com/MoscaDotTo/Winapp2/commit/4a9d5257de081c68c43c77900d18acc41d664554 Link to comment Share on other sites More sharing options...
siliconman01 Posted September 24, 2019 Share Posted September 24, 2019 Modified entry: [Samsung Magician *] Added FileKey6 to remove a 1 gbyte folder that Magician 6.0.0 creates during installation. Not needed. Note: This huge folder is created and then left hanging if the user performs a "Benchmark All" via Magician and then cancel during the scan. Changed LangSecRef from 3021 to 3024 because Magician is a utility type program. [Samsung Magician *] LangSecRef=3024 Detect=HKLM\Software\Samsung Magician Default=False FileKey1=%CommonAppData%\Samsung\Backup|*.exe FileKey2=%CommonAppData%\Samsung\Samsung Magician|*.exe|RECURSE FileKey3=%CommonAppData%\Samsung\Samsung Magician\PB|*.txt FileKey4=%ProgramFiles%\Samsung Magician\Logs|*.* FileKey5=%ProgramFiles%\Samsung\Samsung Magician\Log*|*.* FileKey6=%SystemDrive%\MagicianPerf*|*.*|REMOVESELF RegKey1=HKCU\Software\Local AppWizard-Generated Applications\SamsungMagician Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
SMalik Posted September 28, 2019 Share Posted September 28, 2019 Revised Entry Changed the name from [HP Printer Control *] to [HP Smart *] Removed: %LocalAppData%\Packages\*.HPPrinterControl_*\LocalState|*.*|RECURSE Added: %LocalAppData%\Packages\*.HPPrinterControl_*\LocalCache|*.*|RECURSE %LocalAppData%\Packages\*.HPPrinterControl_*\TempState|*.*|RECURSE [HP Smart *] LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\AD2F1837.HPPrinterControl_v10z8vjag6ke6 Default=False FileKey1=%LocalAppData%\Packages\*.HPPrinterControl_*\AC\AppCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\*.HPPrinterControl_*\AC\INet*|*.*|RECURSE FileKey3=%LocalAppData%\Packages\*.HPPrinterControl_*\AC\Microsoft\CLR_v4.0*|*.log|RECURSE FileKey4=%LocalAppData%\Packages\*.HPPrinterControl_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey5=%LocalAppData%\Packages\*.HPPrinterControl_*\AC\Temp|*.*|RECURSE FileKey6=%LocalAppData%\Packages\*.HPPrinterControl_*\LocalCache|*.*|RECURSE FileKey7=%LocalAppData%\Packages\*.HPPrinterControl_*\TempState|*.*|RECURSE Link to comment Share on other sites More sharing options...
Moderators Andavari Posted September 28, 2019 Moderators Share Posted September 28, 2019 On 24/09/2019 at 01:15, siliconman01 said: Modified entry: [Samsung Magician *] Added FileKey6 to remove a 1 gbyte folder that Magician 6.0.0 creates during installation. Not needed. Note: This huge folder is created and then left hanging if the user performs a "Benchmark All" via Magician and then cancel during the scan. Changed LangSecRef from 3021 to 3024 because Magician is a utility type program. [Samsung Magician *] LangSecRef=3024 Detect=HKLM\Software\Samsung Magician Default=False FileKey1=%CommonAppData%\Samsung\Backup|*.exe FileKey2=%CommonAppData%\Samsung\Samsung Magician|*.exe|RECURSE FileKey3=%CommonAppData%\Samsung\Samsung Magician\PB|*.txt FileKey4=%ProgramFiles%\Samsung Magician\Logs|*.* FileKey5=%ProgramFiles%\Samsung\Samsung Magician\Log*|*.* FileKey6=%SystemDrive%\MagicianPerf*|*.*|REMOVESELF RegKey1=HKCU\Software\Local AppWizard-Generated Applications\SamsungMagician My Samsung SSD isn't my boot drive it's a secondary as drive E:\. I found a 1GB hidden file that Samsung Magician 6.0.0 created on it after I benchmarked (did not cancel the benchmark) using it, and looking at the drive S.M.A.R.T. data, etc.: E:\mict.dat This new version is sloppy, first I couldn't download it due to the frivolous complete b.s. daily download limit (come on I've spent hundreds of dollars on Samsung SSDs), and now the huge junk files it creates including a hidden one. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted September 29, 2019 Author Share Posted September 29, 2019 On 09/09/2019 at 19:47, Winapp2.ini said: Thanks for pointing this out, I'll look into it when I get some time @dvdbane Do the keys that are not in wow64node exist on your system too? winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
APMichael Posted September 30, 2019 Share Posted September 30, 2019 On 10/09/2019 at 01:47, Winapp2.ini said: Thanks for pointing this out, I'll look into it when I get some time JFYI: I didn't install Foxit Reader, so I simply added the two registry keys "Foxit Software\Foxit Reader" under "HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\". Now you can run TRIM and the results will be as follows: On 09/09/2019 at 12:02, APMichael said: If the entry uses "Detect=HKLM\Software\Foxit Software\Foxit Reader", Trim does not detect it (and trims it out). If the entry uses "Detect=HKLM\Software\Foxit Software", Trim detects it. Link to comment Share on other sites More sharing options...
APMichael Posted September 30, 2019 Share Posted September 30, 2019 Thanks for the modified/revised entries. Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/1b825563b1a9b465e91e4f539973f67da94f55fe Link to comment Share on other sites More sharing options...
dvdbane Posted September 30, 2019 Share Posted September 30, 2019 16 hours ago, Winapp2.ini said: @dvdbane Do the keys that are not in wow64node exist on your system too? Sorry, i don't understand this question or you can use this step to test. I did test using this step too on other pc 3 hours ago, APMichael said: JFYI: I didn't install Foxit Reader, so I simply added the two registry keys "Foxit Software\Foxit Reader" under "HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\". Link to comment Share on other sites More sharing options...
siliconman01 Posted October 4, 2019 Share Posted October 4, 2019 Modified entry: [Syncios Cell Phone Backup & Manage *] Added FileKey4 [Syncios Cell Phone Backup & Manage *] LangSecRef=3024 Detect1=HKCU\Software\Syncios Detect2=HKCU\Software\Syncios Data Transfer Default=False FileKey1=%AppData%\app_sycnios_transfer_loader|*.*|REMOVESELF FileKey2=%AppData%\Syncios|android.log;log.txt FileKey3=%AppData%\Syncios Data Transfer|*.log|RECURSE FileKey4=%AppData%\Syncios Data Transfer\GPUCache|*.* FileKey5=%Documents%\Syncios Data Transfer|preference_conf.ini.old.bak Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
siliconman01 Posted October 4, 2019 Share Posted October 4, 2019 Modified entry: [Snagit *] Added FileKey1 [Snagit *] LangSecRef=3021 Detect=HKCU\Software\TechSmith\Snagit Warning=This will delete the backups of the captures. Default=False FileKey1=%AppData%\TechSmith\Snagit *\Identity|*.* FileKey2=%CommonAppData%\TechSmith\Uploader|*.log FileKey3=%Documents%|SnagitDebug.log FileKey4=%LocalAppData%\TechSmith\Logs|*.log FileKey5=%LocalAppData%\TechSmith\Snagit|Tray.bin FileKey6=%LocalAppData%\TechSmith\Snagit\CrashDumps|*.*|RECURSE FileKey7=%LocalAppData%\TechSmith\Snagit\DataStore|*.SNAG;*.SNAGundo;*.MP4 FileKey8=%LocalAppData%\TechSmith\Snagit\DataStore\AppIcons|*.ico FileKey9=%LocalAppData%\TechSmith\Snagit\DataStore\WebSiteIcons|*.ico FileKey10=%LocalAppData%\TechSmith\Snagit\Thumbnails|*.*|RECURSE FileKey11=%LocalAppData%\TechSmith\Snagit\TrackerbirdFiles|*.log;*.logtmp RegKey1=HKCU\Software\TechSmith\Snagit\9|StampCustomFolder RegKey2=HKCU\Software\TechSmith\Snagit\10|StampCustomFolder RegKey3=HKCU\Software\TechSmith\Snagit\11|CaptureCount RegKey4=HKCU\Software\TechSmith\Snagit\11|CaptureOpenCount RegKey5=HKCU\Software\TechSmith\Snagit\11|OutputDirLastUsed RegKey6=HKCU\Software\TechSmith\Snagit\11|VidOutputDirLastUsed RegKey7=HKCU\Software\TechSmith\Snagit\11\SnagItEditor\Tray|Thumbnailsize RegKey8=HKCU\Software\TechSmith\Snagit\12|CaptureCount RegKey9=HKCU\Software\TechSmith\Snagit\12|CaptureOpenCount RegKey10=HKCU\Software\TechSmith\Snagit\12|OutputDirLastUsed RegKey11=HKCU\Software\TechSmith\Snagit\12|VidOutputDirLastUsed RegKey12=HKCU\Software\TechSmith\Snagit\12\SnagItEditor\Tray|Thumbnailsize RegKey13=HKCU\Software\TechSmith\Snagit\13|CaptureCount RegKey14=HKCU\Software\TechSmith\Snagit\13|CaptureOpenCount RegKey15=HKCU\Software\TechSmith\Snagit\13|OutputDirLastUsed RegKey16=HKCU\Software\TechSmith\Snagit\13|VidOutputDirLastUsed RegKey17=HKCU\Software\TechSmith\Snagit\13\Recent Captures RegKey18=HKCU\Software\TechSmith\Snagit\13\SnagitEditor\Recent File List RegKey19=HKCU\Software\TechSmith\Snagit\13\SnagItEditor\Tray|Thumbnailsize RegKey20=HKCU\Software\TechSmith\Snagit\18|CaptureCount RegKey21=HKCU\Software\TechSmith\Snagit\18|CaptureOpenCount RegKey22=HKCU\Software\TechSmith\Snagit\18|OutputDirLastUsed RegKey23=HKCU\Software\TechSmith\Snagit\18|VidOutputDirLastUsed RegKey24=HKCU\Software\TechSmith\Snagit\18\Recent Captures RegKey25=HKCU\Software\TechSmith\Snagit\18\SnagitEditor\Recent File List RegKey26=HKCU\Software\TechSmith\Snagit\18\SnagItEditor\Tray|Thumbnailsize RegKey27=HKCU\Software\TechSmith\Snagit\19|CaptureCount RegKey28=HKCU\Software\TechSmith\Snagit\19|CaptureOpenCount RegKey29=HKCU\Software\TechSmith\Snagit\19|OutputDirLastUsed RegKey30=HKCU\Software\TechSmith\Snagit\19|VidOutputDirLastUsed RegKey31=HKCU\Software\TechSmith\Snagit\19\Recent Captures RegKey32=HKCU\Software\TechSmith\Snagit\19\SnagitEditor\Recent File List RegKey33=HKCU\Software\TechSmith\Snagit\19\SnagItEditor\Tray|Thumbnailsize RegKey34=HKCU\Software\TechSmith\Snagit\Stamps|StampCustomFolder Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
