siliconman01 Posted November 13, 2019 Share Posted November 13, 2019 In recent days, when I run Winappool version 1.02, it states that the tool is offline. Is this fact or is there a problem somewhere? I am running Windows 10x64 Pro Build 18363.476 V1909 and my default browser is MS Edge Chromium. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
APMichael Posted November 13, 2019 Share Posted November 13, 2019 11 hours ago, SMalik said: ... Can we change the entry name to [Crash Reports *]? 11 hours ago, Nergal said: Sounds a little generic. How about CrashRPT Reports Also, the entry name [Crash Reports *] is already in use (and two entries with the same name are not possible). Link to comment Share on other sites More sharing options...
SMalik Posted November 13, 2019 Share Posted November 13, 2019 11 hours ago, APMichael said: Also, the entry name [Crash Reports *] is already in use (and two entries with the same name are not possible). How about [CrashRPT Logs *] ? Link to comment Share on other sites More sharing options...
Moderators Nergal Posted November 13, 2019 Moderators Share Posted November 13, 2019 39 minutes ago, SMalik said: How about [CrashRPT Logs *] ? I like it ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
Winapp2.ini Posted November 13, 2019 Author Share Posted November 13, 2019 15 hours ago, siliconman01 said: In recent days, when I run Winappool version 1.02, it states that the tool is offline. Is this fact or is there a problem somewhere? I am running Windows 10x64 Pro Build 18363.476 V1909 and my default browser is MS Edge Chromium. This is an error, I'll look into it when I've some time this week winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
don_dolarson Posted November 13, 2019 Share Posted November 13, 2019 May we user suggest an application to add for cleaning so it's gonna be there whenever winapp2.ini file is updated? Just installed an application, updated winapp2 file but the application isn't there. It leaves about 200MB of updates after it's done. I don't see "include folder" option in CCleaner. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted November 13, 2019 Moderators Share Posted November 13, 2019 16 minutes ago, don_dolarson said: May we user suggest an application to add for cleaning so it's gonna be there whenever winapp2.ini file is updated? Just installed an application, updated winapp2 file but the application isn't there. It leaves about 200MB of updates after it's done. I don't see "include folder" option in CCleaner. You can suggest, but it's better to provide us with an entry yourself as only suggesting relies heavily on someone else with that program (which depending on the application may not be many or any) ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
don_dolarson Posted November 13, 2019 Share Posted November 13, 2019 Amazing. It's about an application called Messenger for Desktop. It leaves update package files inside folder C:\Users\%USERDATA%\AppData\Local\MessengerForDesktop-updater Link to comment Share on other sites More sharing options...
APMichael Posted November 14, 2019 Share Posted November 14, 2019 10 hours ago, don_dolarson said: Amazing. It's about an application called Messenger for Desktop. It leaves update package files inside folder C:\Users\%USERDATA%\AppData\Local\MessengerForDesktop-updater Thanks, but we also need a program path or registry key to detect the program (and create a new entry for it). You can find instructions for new entries here: https://github.com/MoscaDotTo/Winapp2#creating-entries. I have found all the information and already created the new entry for you: [Messenger for Desktop *] LangSecRef=3022 DetectFile=%LocalAppData%\Programs\messengerfordesktop Default=False FileKey1=%LocalAppData%\messengerfordesktop-updater|*.*|RECURSE Link to comment Share on other sites More sharing options...
don_dolarson Posted November 14, 2019 Share Posted November 14, 2019 Ummm, do I need to do anything else or you already did it for me and it's about to wait for winapp2.ini update now? I can check what is needed and supply you with these informations. Thank you in advance if you did that for me. Will remember it next time I suggest a new program to add. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted November 14, 2019 Moderators Share Posted November 14, 2019 16 hours ago, SMalik said: How about [CrashRPT Logs *] ? How about [Ashampoo CrashRPT Logs *] or whatever. Can't imagine someone remembering exactly what that generic folder path in Windows is associated with later on if it doesn't have the vendor name attached to it since Ashampoo products don't have a unique LangSecRef. ---------------------------- Edit: Perhaps also, just giving ideas: [Ashampoo Snap CrashRpt *] Section=Crash Reports DetectFile=%LocalAppData%\CrashRpt Default=False FileKey1=%LocalAppData%\CrashRpt|*.*|RECURSE Link to comment Share on other sites More sharing options...
APMichael Posted November 14, 2019 Share Posted November 14, 2019 1 hour ago, don_dolarson said: Ummm, do I need to do anything else or you already did it for me and it's about to wait for winapp2.ini update now? I can check what is needed and supply you with these informations. Thank you in advance if you did that for me. Will remember it next time I suggest a new program to add. You don't have to do anything. I will add the new entry with the next update (next week). Link to comment Share on other sites More sharing options...
APMichael Posted November 14, 2019 Share Posted November 14, 2019 1 hour ago, Andavari said: How about [Ashampoo CrashRPT Logs *] or whatever. Can't imagine someone remembering exactly what that generic folder path in Windows is associated with later on if it doesn't have the vendor name attached to it since Ashampoo products don't have a unique LangSecRef. ... JFYI: Ashampoo is not the vendor of CrashRpt. CrashRpt is a library used by various programs.https://forum.piriform.com/topic/32310-winapp2ini-additions/page/325/?tab=comments#comment-312266http://crashrpt.sourceforge.net/ Link to comment Share on other sites More sharing options...
siliconman01 Posted November 16, 2019 Share Posted November 16, 2019 (edited) On 13/11/2019 at 18:29, Winapp2.ini said: This is an error, I'll look into it when I've some time this week It's interesting that Windows 10x64 Pro Insider Build 19025 (released 15-Nov) cleared this issue on my test machine. It still exists on my other systems with Windows 10x64 Pro Version 1909 however. NOTE: As of 18-November, this issue no longer exists on any of my systems. Winapp2 must have fixed things up...as he normally does! Edited November 18, 2019 by siliconman01 NOTE: Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
APMichael Posted November 18, 2019 Share Posted November 18, 2019 Thanks for the revised entry and all replies. Winapp2.ini updates:https://github.com/MoscaDotTo/Winapp2/commit/08b7ff5e01b0a0f7203982e2cc8c3b322864ba52https://github.com/MoscaDotTo/Winapp2/commit/7f256aa25f1b893ba8b0b5efaa0ba52b3109d81e Winapp3.ini update:https://github.com/MoscaDotTo/Winapp2/commit/f2863f2d0f3a799171adb3e8d8f5d5a1206b0d92 Link to comment Share on other sites More sharing options...
siliconman01 Posted November 21, 2019 Share Posted November 21, 2019 If any Winapp2.ini user also uses program "Internet Download Manager" but does NOT use Chrome or Chrome based browser, the user is subject to a potential issue/conflict when you update Internet Download Manager (IDM) to version 6.35 Build 12. This new update inserts a registry key HKCU\Software\Cococ to permit an IDM browser extension to be added into the Cococ browser (IDM adds this registry key irrespective of whether the Cococ browser is installed or not). Many Winapp2.ini cleaning modules for Chrome and Chrome based browsers perform a Detect=HKCU\Software\Cococ to determine if this chrome based browser (Cococ) is installed on the user system. Therefore once the user updates to IDM v6.35 Build 12, he/she may start seeing numerous inapplicable Chrome cleaning modules in the Applications tab when the user installs a new Winapp2.ini and performs the TRIM. There is no "clean" solution to this problem that I can think of....perhaps Robert or APMichael can ?? What I have done on my systems is add a Custom module to my Winapp2.ini as shown below to delete this registry key HKCU\Software\Cococ [Internet Download Manager Registry *] LangSecRef=3024 Detect=HKLM\Software\Internet Download Manager Default=False RegKey1=HKCU\Software\CocCoc Obviously I do not know what the IDM developer's plans are to add more browsers to IDM's supported browsers, but additional browser keys may show up in future IDM updates that will result in the same problem. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
APMichael Posted November 21, 2019 Share Posted November 21, 2019 4 hours ago, siliconman01 said: If any Winapp2.ini user also uses program "Internet Download Manager" ... Maybe you can report this to the developers as a bug. It is easy for them to query if the registry key for CocCoc already exists and if the additional keys/values they want to add are necessary or not. It looks like a bug, because this only happens with the registry key for CocCoc. In the registry key for Chrome they do not add any additional keys/values (if Chrome is not installed). The only solution would be to modify the Detects for all Chrome/Chromium entries. But this would be a lot of effort because of an obviously buggy program. Link to comment Share on other sites More sharing options...
SMalik Posted November 23, 2019 Share Posted November 23, 2019 FileKeys with "%LocalAppData%\Packages\*\LocalCache|*.*|RECURSE" and "%LocalAppData%\Packages\*\LocalState\Cache|*.*|RECURSE" should be removed from all Microsoft Store apps. I just noticed some apps keep some important files here. %LocalAppData%\Packages\AppleInc.iTunes_nzyj5cx40ttqa\LocalCache\Roaming\Apple Computer\Preferences Link to comment Share on other sites More sharing options...
APMichael Posted November 23, 2019 Share Posted November 23, 2019 2 hours ago, SMalik said: FileKeys with "%LocalAppData%\Packages\*\LocalCache|*.*|RECURSE" and "%LocalAppData%\Packages\*\LocalState\Cache|*.*|RECURSE" should be removed from all Microsoft Store apps. I just noticed some apps keep some important files here. %LocalAppData%\Packages\AppleInc.iTunes_nzyj5cx40ttqa\LocalCache\Roaming\Apple Computer\Preferences ... You already noticed this when you added the entry last year, because your entry [iTunes App *] does not delete these preferences at all: [iTunes App *] DetectOS=10.0| LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\AppleInc.iTunes_nzyj5cx40ttqa Default=False FileKey1=%LocalAppData%\Packages\AppleInc.iTunes_*\AC\INet*|*.*|RECURSE FileKey2=%LocalAppData%\Packages\AppleInc.iTunes_*\AC\Temp|*.*|RECURSE FileKey3=%LocalAppData%\Packages\AppleInc.iTunes_*\LocalCache\Local\Apple Computer\iTunes|Cache.db;*.xml FileKey4=%LocalAppData%\Packages\AppleInc.iTunes_*\LocalCache\Local\Microsoft\Windows\Caches|*.*|RECURSE FileKey5=%LocalAppData%\Packages\AppleInc.iTunes_*\LocalCache\LocalLow\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey6=%LocalAppData%\Packages\AppleInc.iTunes_*\LocalCache\Roaming\Apple Computer\iTunes\Cookies|Cookies.binarycookies FileKey7=%LocalAppData%\Packages\AppleInc.iTunes_*\LocalCache\Roaming\Apple Computer\Logs|*.*|RECURSE FileKey8=%LocalAppData%\Packages\AppleInc.iTunes_*\SystemAppData\Helium\Cache|*.*|RECURSE FileKey9=%LocalAppData%\Packages\AppleInc.iTunes_*\TempState|*.*|RECURSE FileKey10=%WinDir%\System32\config\systemprofile\AppData\Roaming\Apple Computer\Logs|*.*|RECURSE https://forum.piriform.com/topic/32310-winapp2ini-additions/page/291/?tab=comments#comment-296677 (And sorry, but we don't do mass changes anymore, because all mass changes of the past had to be reversed after a few weeks. We haven't had a single issue report for the app entries so far, so a precautionary change doesn't make sense. If an app really should lose important settings, please report the app, respectively its entry, here. Then we can change the FileKeys or add ExcludeKeys.) Link to comment Share on other sites More sharing options...
APMichael Posted December 3, 2019 Share Posted December 3, 2019 Winapp2.ini updates:https://github.com/MoscaDotTo/Winapp2/commit/089f076227f9fb63b2afe4b4c0ed28d1e2a127dahttps://github.com/MoscaDotTo/Winapp2/commit/77953a2b781744c8a92f64d56feff9cad38de696 Link to comment Share on other sites More sharing options...
siliconman01 Posted December 9, 2019 Share Posted December 9, 2019 Modified entry: [Ashampoo Burning Studio *] Added Detect12 for the newly released Ashampoo Burning Studio 21. NOTE: I'm not seeing any RegKeys that need to be added for this new version. They may show up once the program is used for its various task. [Ashampoo Burning Studio *] LangSecRef=3021 Detect1=HKCU\Software\Ashampoo\Ashampoo Burning Studio 5 Detect2=HKCU\Software\Ashampoo\Ashampoo Burning Studio 6 Detect3=HKCU\Software\Ashampoo\Ashampoo Burning Studio 7 Detect4=HKCU\Software\Ashampoo\Ashampoo Burning Studio 8 Detect5=HKCU\Software\Ashampoo\Ashampoo Burning Studio 12 Detect6=HKCU\Software\Ashampoo\Ashampoo Burning Studio 14 Detect7=HKCU\Software\Ashampoo\Ashampoo Burning Studio 15 Detect8=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16 Detect9=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18 Detect10=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19 Detect11=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20 Detect12=HKCU\Software\Ashampoo\Ashampoo Burning Studio 21 Detect13=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2007 Detect14=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2009 Detect15=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016 Detect16=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017 Detect17=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018 Detect18=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019 Default=False FileKey1=%AppData%\Ashampoo|*.log;*.txt;*.xml|RECURSE FileKey2=%LocalAppData%\Ashampoo\BaNT|*.*|RECURSE RegKey1=HKCU\Software\Ashampoo\Ashampoo Burning Studio 5\Burn Image Project\SelectImage RegKey2=HKCU\Software\Ashampoo\Ashampoo Burning Studio 5\Data Disc Project\AddDialog RegKey3=HKCU\Software\Ashampoo\Ashampoo Burning Studio 5\Data Disc Project\DumpImage RegKey4=HKCU\Software\Ashampoo\Ashampoo Burning Studio 5\Unknown Project\AddDialog RegKey5=HKCU\Software\Ashampoo\Ashampoo Burning Studio 6\Burn Image Project\SelectImage RegKey6=HKCU\Software\Ashampoo\Ashampoo Burning Studio 6\Data Disc Project\AddDialog RegKey7=HKCU\Software\Ashampoo\Ashampoo Burning Studio 6\Unknown Project\AddDialog RegKey8=HKCU\Software\Ashampoo\Ashampoo Burning Studio 7\Burn Image Project\SelectImage RegKey9=HKCU\Software\Ashampoo\Ashampoo Burning Studio 7\Data Disc Project\AddDialog RegKey10=HKCU\Software\Ashampoo\Ashampoo Burning Studio 7\Unknown Project\AddDialog RegKey11=HKCU\Software\Ashampoo\Ashampoo Burning Studio 8\Data Disc Project\AddDialog RegKey12=HKCU\Software\Ashampoo\Ashampoo Burning Studio 14\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory RegKey13=HKCU\Software\Ashampoo\Ashampoo Burning Studio 14\tempFiles RegKey14=HKCU\Software\Ashampoo\Ashampoo Burning Studio 15\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory RegKey15=HKCU\Software\Ashampoo\Ashampoo Burning Studio 15\tempFiles RegKey16=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory RegKey17=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Backup Project\BackupOptions|CustomLocation RegKey18=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\BDMV Disc Project\SelectBDMVFolder|BdmvPath RegKey19=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Browse Image Project\BrowseImageFile|ImagePath RegKey20=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey21=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey22=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Burn Image Project\SelectImage|ImagePath RegKey23=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Data Disc Project\DumpImage|ImagePath RegKey24=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory RegKey25=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\DVD-Video Disc Project\MoviesPage|Path RegKey26=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\DVD-Video Disc Project\SaveDialog_authed.CMoviesPage.Movies|InitialDirectory RegKey27=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Logs RegKey28=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\tempFiles RegKey29=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Unknown Project RegKey30=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\VCD Project\SaveDialog_OnAddMovies|InitialDirectory RegKey31=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\VIDEO_TS Disc Project\DumpImage|ImagePath RegKey32=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath RegKey33=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory RegKey34=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Backup Project\BackupOptions|CustomLocation RegKey35=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\BDMV Disc Project\SelectBDMVFolder|BdmvPath RegKey36=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Browse Image Project\BrowseImageFile|ImagePath RegKey37=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey38=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey39=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Burn Image Project\SelectImage|ImagePath RegKey40=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Data Disc Project\DumpImage|ImagePath RegKey41=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory RegKey42=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\DVD-Video Disc Project\MoviesPage|Path RegKey43=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\DVD-Video Disc Project\SaveDialog_authed.CMoviesPage.Movies|InitialDirectory RegKey44=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Logs RegKey45=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\tempFiles RegKey46=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\Unknown Project RegKey47=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\VCD Project\SaveDialog_OnAddMovies|InitialDirectory RegKey48=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\VIDEO_TS Disc Project\DumpImage|ImagePath RegKey49=HKCU\Software\Ashampoo\Ashampoo Burning Studio 18\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath RegKey50=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory RegKey51=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Backup Project\BackupOptions|CustomLocation RegKey52=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\BDMV Disc Project\SelectBDMVFolder|BdmvPath RegKey53=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Browse Image Project\BrowseImageFile|ImagePath RegKey54=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey55=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey56=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Burn Image Project\SelectImage|ImagePath RegKey57=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Data Disc Project\DumpImage|ImagePath RegKey58=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory RegKey59=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\DVD-Video Disc Project\MoviesPage|Path RegKey60=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\DVD-Video Disc Project\SaveDialog_authed.CMoviesPage.Movies|InitialDirectory RegKey61=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Logs RegKey62=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\tempFiles RegKey63=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\Unknown Project RegKey64=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\VCD Project\SaveDialog_OnAddMovies|InitialDirectory RegKey65=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\VIDEO_TS Disc Project\DumpImage|ImagePath RegKey66=HKCU\Software\Ashampoo\Ashampoo Burning Studio 19\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath RegKey67=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory RegKey68=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Backup Project\BackupOptions|CustomLocation RegKey69=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\BDMV Disc Project\SelectBDMVFolder|BdmvPath RegKey70=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Browse Image Project\BrowseImageFile|ImagePath RegKey71=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey72=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey73=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Burn Image Project\SelectImage|ImagePath RegKey74=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Data Disc Project\DumpImage|ImagePath RegKey75=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory RegKey76=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\DVD-Video Disc Project\MoviesPage|Path RegKey77=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\DVD-Video Disc Project\SaveDialog_authed.CMoviesPage.Movies|InitialDirectory RegKey78=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Logs RegKey79=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\tempFiles RegKey80=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\Unknown Project RegKey81=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\VCD Project\SaveDialog_OnAddMovies|InitialDirectory RegKey82=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\VIDEO_TS Disc Project\DumpImage|ImagePath RegKey83=HKCU\Software\Ashampoo\Ashampoo Burning Studio 20\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath RegKey84=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2007\Burn Image Project\AddDialog RegKey85=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2007\Data Disc Project\AddDialog RegKey86=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2007\Dump Image Project\DumpImage RegKey87=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2007\Unknown Project\AddDialog RegKey88=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory RegKey89=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Backup Project\BackupOptions|CustomLocation RegKey90=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Browse Image Project\BrowseImageFile|ImagePath RegKey91=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey92=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey93=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Burn Image Project\SelectImage|ImagePath RegKey94=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Data Disc Project\DumpImage|ImagePath RegKey95=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory RegKey96=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Logs RegKey97=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\tempFiles RegKey98=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Unknown Project RegKey99=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\VCD Project\SaveDialog_OnAddMovies|InitialDirectory RegKey100=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\VIDEO_TS Disc Project\DumpImage|ImagePath RegKey101=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath RegKey102=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory RegKey103=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Backup Project\BackupOptions|CustomLocation RegKey104=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Browse Image Project\BrowseImageFile|ImagePath RegKey105=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey106=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey107=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Burn Image Project\SelectImage|ImagePath RegKey108=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Data Disc Project\DumpImage|ImagePath RegKey109=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory RegKey110=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Logs RegKey111=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\tempFiles RegKey112=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\Unknown Project RegKey113=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\VCD Project\SaveDialog_OnAddMovies|InitialDirectory RegKey114=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\VIDEO_TS Disc Project\DumpImage|ImagePath RegKey115=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2017\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath RegKey116=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory RegKey117=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Backup Project\BackupOptions|CustomLocation RegKey118=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Browse Image Project\BrowseImageFile|ImagePath RegKey119=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey120=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey121=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Burn Image Project\SelectImage|ImagePath RegKey122=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Data Disc Project\DumpImage|ImagePath RegKey123=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory RegKey124=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Logs RegKey125=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\tempFiles RegKey126=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\Unknown Project RegKey127=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\VCD Project\SaveDialog_OnAddMovies|InitialDirectory RegKey128=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\VIDEO_TS Disc Project\DumpImage|ImagePath RegKey129=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2018\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath RegKey130=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory RegKey131=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\Backup Project\BackupOptions|CustomLocation RegKey132=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\Browse Image Project\BrowseImageFile|ImagePath RegKey133=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey134=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory RegKey135=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\Burn Image Project\SelectImage|ImagePath RegKey136=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\Data Disc Project\DumpImage|ImagePath RegKey137=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory RegKey138=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\Logs RegKey139=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\tempFiles RegKey140=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\Unknown Project RegKey141=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\VCD Project\SaveDialog_OnAddMovies|InitialDirectory RegKey142=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\VIDEO_TS Disc Project\DumpImage|ImagePath RegKey143=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2019\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted December 9, 2019 Moderators Share Posted December 9, 2019 143 regkey in that ashampoo entry. Why's it so big? Can it not be paired down some? I notice it includes many different ashampoo versions, are there any that are old enough to remove? ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
Moderators Andavari Posted December 12, 2019 Moderators Share Posted December 12, 2019 I thought they were combined at one point, but I could be wrong. Link to comment Share on other sites More sharing options...
siliconman01 Posted December 12, 2019 Share Posted December 12, 2019 With CCleaner users still running Windows XP, Vista, 7, I suspect that there are those who continue to use older versions of many 3rd party applications such as Ashampoo Burning Studio...particularly 3rd party applications that charge a fee to upgrade such as Ashampoo. That said, I suspect versions 5-12, 2007, 2009 could be eliminated without impacting significant numbers of CCleaner users. JMO. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
APMichael Posted December 13, 2019 Share Posted December 13, 2019 Thanks for the modified entry and the replies. Right, the entries were combined during the last big overhaul. Unfortunately, CCleaner does not support wildcards in RegKeys, so it is not possible to merge them. Winapp2.ini updates:https://github.com/MoscaDotTo/Winapp2/commit/3a051deeff8d1f16121fac746cbb06a93a347bechttps://github.com/MoscaDotTo/Winapp2/commit/30b0212ccb92794010b6fbed3e539dbdbe983827 Link to comment Share on other sites More sharing options...
