APMichael Posted March 31, 2020 Share Posted March 31, 2020 On 30/03/2020 at 19:39, ricktendo64 said: Thanks, note the following can be removed from winapp3.ini "All App Packages" ... Thanks for the hint. Link to comment Share on other sites More sharing options...
wixud Posted April 1, 2020 Share Posted April 1, 2020 This sh!t freezed programm after updating,little bit scared when programm stuck at launching.... Link to comment Share on other sites More sharing options...
APMichael Posted April 1, 2020 Share Posted April 1, 2020 3 hours ago, wixud said: This sh!t freezed programm after updating,little bit scared when programm stuck at launching.... You simply have to wait longer, because CCleaner now has to process thousands of new entries. When all entries have been processed, CCleaner is ready for operation again. To speed up the start again, you can use the Trim function of Winapp2ool. Please read post #1: https://community.ccleaner.com/topic/32310-winapp2ini-additions/?tab=comments#comment-175835 Link to comment Share on other sites More sharing options...
wixud Posted April 1, 2020 Share Posted April 1, 2020 (edited) 37 minutes ago, APMichael said: You simply have to wait longer, because CCleaner now has to process thousands of new entries. When all entries have been processed, CCleaner is ready for operation again. To speed up the start again, you can use the Trim function of Winapp2ool. Please read post #1: https://community.ccleaner.com/topic/32310-winapp2ini-additions/?tab=comments#comment-175835 Meh,old piriforms ccleaner was way better than this clone... Edited April 1, 2020 by wixud Link to comment Share on other sites More sharing options...
Moderators Andavari Posted April 1, 2020 Moderators Share Posted April 1, 2020 (edited) On 30/03/2020 at 00:19, siliconman01 said: This code works fine. I run with Offline accounts. I have to stop services "CDPUserSvc_44dec" and "Connected Devices Platform Service" prior to cleaning. I only use an offline account too. When I used SMalik's revised [Activity History *] cleaner I had to stop both of these services for it to work (full names as seen in Services): * Connected Devices Platform Service * Connected Devices Platform User Service_48409 I wonder if it's safe to just disable those two services, or not? Edit: I'll answer my own question. It cannot be left disabled because it screws with things like Win10's Night Light, and who knows what else that's tied into it, so I won't even bother cleaning Activity History again. Edited April 1, 2020 by Andavari Link to comment Share on other sites More sharing options...
APMichael Posted April 1, 2020 Share Posted April 1, 2020 1 hour ago, Andavari said: ... When I used SMalik's revised [Activity History *] cleaner I had to stop both of these services for it to work (full names as seen in Services): * Connected Devices Platform Service * Connected Devices Platform User Service_48409 I wonder if it's safe to just disable those two services, or not? ... I also only use offline accounts and still have both folders on all systems. I found out that the service "Connected Devices Platform User Service_xxxxx" is responsible for the folder "random string" and the service "Connected Devices Platform Service" for the folder "L.username". The service "Connected Devices Platform User Service_xxxxx" can only be disabled permanently via the registry. However, since the service is no longer used only for sync tasks, it is better not to disable it - as you have already written. After deleting the cache databases, I have not noticed any side effects, at least until now. Link to comment Share on other sites More sharing options...
don_dolarson Posted April 1, 2020 Share Posted April 1, 2020 Thank you for adding Process Hacker to the latest database update However, I've found another "cached" installation/update package located in %USERPROFILE%\AppData\Roaming\Process Hacker\Cache folder. There's another "NYGWEFSCZHOPGSU" folder inside of it and a processhacker-build-setup.exe file there. Link to comment Share on other sites More sharing options...
APMichael Posted April 2, 2020 Share Posted April 2, 2020 15 hours ago, don_dolarson said: ... However, I've found another "cached" installation/update package located in %USERPROFILE%\AppData\Roaming\Process Hacker\Cache folder. There's another "NYGWEFSCZHOPGSU" folder inside of it and a processhacker-build-setup.exe file there. The full path is then the following, correct? %AppData%\Process Hacker\Cache\NYGWEFSCZHOPGSU\processhacker-build-setup.exe However, I guess the folder name is randomly generated. Since it is located in a folder called "Cache", the question arises whether you can simply delete the entire contents of the folder. Can you please try if deleting the entire contents of the folder "Cache" will cause problems? Thanks a lot! Link to comment Share on other sites More sharing options...
don_dolarson Posted April 2, 2020 Share Posted April 2, 2020 Yes, the folder is located there and I guess it too! I've deleted whole folder with it's content and everything works like normal. No issues. Haven't seen any other file/folder in this "Cache" folder. I've found another unneeded crap on my PC. These are coming from LibreOffice. A folder named program_old0 and program_old located in C:\Program Files\LibreOffice. I don't know what are they for but I've deleted them both and everything runs just fine. I guess they're some rest files from updating the application since there's another "program" folder in C:\Program Files\LibreOffice which contains exactly the same but newer created files. Both program_old folders occupied total of 50MB space on disk. Link to comment Share on other sites More sharing options...
APMichael Posted April 2, 2020 Share Posted April 2, 2020 Thanks for testing and your reply. Here the revised entry: [Process Hacker *] LangSecRef=3024 DetectFile=%ProgramFiles%\Process Hacker Default=False FileKey1=%AppData%\Process Hacker\Cache|*.*|RECURSE FileKey2=%ProgramFiles%\Process Hacker|processhacker-setup.exe LibreOffice now seems to omit the version number in the folder name, so I modified the entry: [LibreOffice *] LangSecRef=3021 Detect=HKLM\Software\LibreOffice Default=False FileKey1=%AppData%\LibreOffice\*\cache|*.log FileKey2=%AppData%\LibreOffice\*\User\backup|*.* FileKey3=%AppData%\LibreOffice\*\User\extensions\shared|log.* FileKey4=%AppData%\LibreOffice\*\User\temp|*.* FileKey5=%AppData%\LibreOffice\*\User\uno_packages\cache|log.* FileKey6=%ProgramFiles%\LibreOffice*\program_old*|*.*|REMOVESELF Link to comment Share on other sites More sharing options...
PICPro Posted April 6, 2020 Share Posted April 6, 2020 OpenOffice can use the same treatment for program_old* folders (added filekey7): [OpenOffice.org *] LangSecRef=3021 Detect1=HKLM\Software\OpenOffice Detect2=HKLM\Software\OpenOffice.org Default=False FileKey1=%AppData%\OpenOffice*\*\user|*.log;*.log.txt;*.tmp;registrymodifications.xcu;registration.xml|RECURSE FileKey2=%AppData%\OpenOffice*\*\user\config\imagecache|*.* FileKey3=%AppData%\OpenOffice*\*\user\registry\cache|*.* FileKey4=%AppData%\OpenOffice*\*\user\registry\data\org\openoffice\Office|Views.xcu;Writer.xcu;Common.xcu;Histories.xcu FileKey5=%AppData%\OpenOffice*\*\user\registry\data\org\openoffice\ucb|Hierarchy.xcu;Store.xcu FileKey6=%ProgramFiles%\OpenOffice*\program|*.log|RECURSE FileKey7=%ProgramFiles%\OpenOffice*\program_old*|*.*|REMOVESELF FileKey8=%ProgramFiles%\OpenOffice*\share\uno_packages\cache\uno_packages|*.tmp;*.log;log.txt Link to comment Share on other sites More sharing options...
PICPro Posted April 6, 2020 Share Posted April 6, 2020 I'm thinking that we should have an entry to remove the html5 offline cache files from Mozilla based browsers. Ccleaner doesn't seem to do it natively and clearing the cache in the browsers seems to still leave the index.sqlite file, or it gets created as the browser exits if you manually delete it. [Offline Cache *] LangSecRef=3026 Detect1=HKLM\Software\ComodoGroup\IceDragon Detect2=HKLM\Software\FlashPeak\SlimBrowser Detect3=HKLM\Software\Mozilla\Basilisk Detect4=HKLM\Software\Mozilla\Pale Moon Detect5=HKLM\Software\Mozilla\SeaMonkey Detect6=HKLM\Software\Mozilla\Waterfox DetectFile=%AppData%\Mozilla\Firefox Default=False FileKey1=%LocalAppData%\Comodo\IceDragon\Profiles\*\OfflineCache|*.* FileKey2=%LocalAppData%\FlashPeak\SlimBrowser\Profiles\*\OfflineCache|*.* FileKey3=%LocalAppData%\Moonchild Productions\Basilisk\Profiles\*\OfflineCache|*.* FileKey4=%LocalAppData%\Moonchild Productions\Pale Moon\Profiles\*\OfflineCache|*.* FileKey5=%LocalAppData%\Mozilla\Firefox\Profiles\*\OfflineCache|*.* FileKey6=%LocalAppData%\Mozilla\SeaMonkey\Profiles\*\OfflineCache|*.* FileKey7=%LocalAppData%\Waterfox\Profiles\*\OfflineCache|*.* I can't test SlimBrowser or IceDragon. The other FileKeys seem to work correctly. Link to comment Share on other sites More sharing options...
APMichael Posted April 6, 2020 Share Posted April 6, 2020 (edited) 2 hours ago, PICPro said: I'm thinking that we should have an entry to remove the html5 offline cache files from Mozilla based browsers. Ccleaner doesn't seem to do it natively and clearing the cache in the browsers seems to still leave the index.sqlite file, or it gets created as the browser exits if you manually delete it. ... I'm not sure. If this is not cleaned up by CCleaner, then someone would probably have made an entry for it a long time ago. If you search the forum for "OfflineCache", CCleaner seems to clean it up. The entry "Cookies" should do this. CCleaner cleans up the database directly (and therefore does not delete the ".sqlite" file itself). https://community.ccleaner.com/topic/32310-winapp2ini-additions/page/263/?tab=comments#comment-288245 Quote: "... [Pale Moon - Offline Cache*] ... ok, found with Firefox -> Cookies (!!!) ..." Edit: I can now confirm that the "OfflineCache" is cleaned by CCleaner (entry "Cookies"). You can test it yourself as follows: - Open a website using the offline cache: https://html.spec.whatwg.org/demos/offline/clock/clock2.html - Check "appcache" with: about:cache - Close Firefox and run CCleaner entry "Cookies". - You can now see that CCleaner deletes the subfolders of "OfflineCache". - Open Firefox and check "appcache" again: about:cache - You can see that there are no more entries. (The CCleaner entry "Compact Databases" then reduces the size of the cleaned ".sqlite" file back to the original size of 256 KB.) Edited April 6, 2020 by APMichael Link to comment Share on other sites More sharing options...
APMichael Posted April 6, 2020 Share Posted April 6, 2020 Thanks for the suggestions and revised entries. Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/b84a73fb8322bfb42a14e621fd41a408b627fb5e Link to comment Share on other sites More sharing options...
siliconman01 Posted April 14, 2020 Share Posted April 14, 2020 Modified entry: [CyberLink PowerDVD *] Added changes for newly released PowerDVD20 [CyberLink PowerDVD *] LangSecRef=3023 Detect1=HKCU\Software\CyberLink\PowerDVD14 Detect2=HKCU\Software\CyberLink\PowerDVD15 Detect3=HKCU\Software\CyberLink\PowerDVD16 Detect4=HKCU\Software\CyberLink\PowerDVD17 Detect5=HKCU\Software\CyberLink\PowerDVD18 Detect6=HKCU\Software\CyberLink\PowerDVD19 Detect7=HKCU\Software\CyberLink\PowerDVD20 Default=False FileKey1=%CommonAppData%\Cyberlink\Evoparser|*.xml FileKey2=%LocalAppData%\Cyberlink\DigitalHome|*.log|RECURSE FileKey3=%LocalAppData%\Cyberlink\PowerDVD*|*.log|RECURSE FileKey4=%LocalAppData%\Cyberlink\PowerDVD*\cache*|*.*|RECURSE FileKey5=%LocalAppData%\Cyberlink\PowerDVD*\CL_DMP_Browser|*.*|RECURSE FileKey6=%LocalAppData%\Cyberlink\PowerDVD*\DB*\computer|*.db|RECURSE FileKey7=%LocalAppData%\Cyberlink\PowerDVD*\DefaultMember|*.*|RECURSE RegKey1=HKCU\Software\CyberLink\PowerDVD15\CLMPSvc\MediaObj\MediaCache5\Data5 RegKey2=HKCU\Software\CyberLink\PowerDVD15\CLMPSvc\MediaObj\MediaCache5\ProgramInfo RegKey3=HKCU\Software\CyberLink\PowerDVD15\CLMPSvc\MediaObj\MediaCache5\Thumbnail5 RegKey4=HKCU\Software\CyberLink\PowerDVD16\CLMPSvc\MediaObj\MediaCache5\Data5 RegKey5=HKCU\Software\CyberLink\PowerDVD16\CLMPSvc\MediaObj\MediaCache5\ProgramInfo RegKey6=HKCU\Software\CyberLink\PowerDVD16\CLMPSvc\MediaObj\MediaCache5\Thumbnail5 RegKey7=HKCU\Software\CyberLink\PowerDVD17\CLMPSvc\MediaObj\MediaCache5\Data5 RegKey8=HKCU\Software\CyberLink\PowerDVD17\CLMPSvc\MediaObj\MediaCache5\ProgramInfo RegKey9=HKCU\Software\CyberLink\PowerDVD17\CLMPSvc\MediaObj\MediaCache5\Thumbnail5 RegKey10=HKCU\Software\CyberLink\PowerDVD18\CLMPSvc\MediaObj\MediaCache5\Data5 RegKey11=HKCU\Software\CyberLink\PowerDVD18\CLMPSvc\MediaObj\MediaCache5\ProgramInfo RegKey12=HKCU\Software\CyberLink\PowerDVD18\CLMPSvc\MediaObj\MediaCache5\Thumbnail5 RegKey13=HKCU\Software\CyberLink\PowerDVD19\CLMPSvc\MediaObj\MediaCache5\Data5 RegKey14=HKCU\Software\CyberLink\PowerDVD19\CLMPSvc\MediaObj\MediaCache5\ProgramInfo RegKey15=HKCU\Software\CyberLink\PowerDVD19\CLMPSvc\MediaObj\MediaCache5\Thumbnail5 RegKey16=HKCU\Software\CyberLink\PowerDVD20\CLMPSvc\MediaObj\MediaCache5\Data5 RegKey17=HKCU\Software\CyberLink\PowerDVD20\CLMPSvc\MediaObj\MediaCache5\ProgramInfo RegKey18=HKCU\Software\CyberLink\PowerDVD20\CLMPSvc\MediaObj\MediaCache5\Thumbnail5 Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
SMalik Posted April 14, 2020 Share Posted April 14, 2020 Revised Entry Added: *.xml in FileKey3 [Messaging *] DetectOS=10.0| LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Messaging_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.Messaging_*\AC\INet*|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.Messaging_*\AC\Temp|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.Messaging_*\LocalCache|*.etl;*.xml FileKey4=%LocalAppData%\Packages\Microsoft.Messaging_*\LocalState\Cache|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.Messaging_*\TempState|*.*|RECURSE Link to comment Share on other sites More sharing options...
APMichael Posted April 20, 2020 Share Posted April 20, 2020 Thanks for the modified/revised entries. Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/ae7b169afd579bb15f5f799e8162e242483958e2 Link to comment Share on other sites More sharing options...
Willy2 Posted April 20, 2020 Share Posted April 20, 2020 - For those who use Outlook Express Classic: [OE Classic *] LangSecRef=3022 Detect=HKCU\Software\OEClassic Default=False FileKey1=%LocalAppData%\OEClassic\Prg\Res|*.*|RECURSE FileKey2=%LocalAppData%\OEClassic\Prg\T|*.*|RECURSE ExcludeKey1=PATH|%LocalAppData%\OEClassic\Prg\Res\|dict-*.aff ExcludeKey2=PATH|%LocalAppData%\OEClassic\Prg\Res\|dict-*.dic ExcludeKey3=PATH|%LocalAppData%\OEClassic\Prg\Res\|dict-*.license (The last 3 "ExcludeKey" entries make sure that the spelling checker doesn't get "wiped out") - Questions: 1) Does it matter that "ExcludeKey1=" comes after "FileKey=" ?? Would it matter if I would reverse the sequence and put "ExcludeKey=" before "FileKey=" ?? 2) Was this already included in a previous "Winapp2.ini" ?? I got these entries through the program CCEnhancer (not supported by the folks of CCleaner and use it therefore at your own risk). System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc A discussion always stimulates the braincells !!! Link to comment Share on other sites More sharing options...
APMichael Posted April 20, 2020 Share Posted April 20, 2020 1 hour ago, Willy2 said: ... [OE Classic *] ... 1) Does it matter that "ExcludeKey1=" comes after "FileKey=" ?? Would it matter if I would reverse the sequence and put "ExcludeKey=" before "FileKey=" ?? 2) Was this already included in a previous "Winapp2.ini" ?? I got these entries through the program CCEnhancer (not supported by the folks of CCleaner and use it therefore at your own risk). 1) No, the order does not matter. For a fast and automated error checking, however, an order had to be determined. And since only very few entries have ExcludeKeys, they were placed at the end of an entry. 2) Yes, the corrected entry is already included since last December. The tool you mentioned does not use its own Winapp2.ini file, but downloads ours from GitHub. Therefore, it's also better to report problems with entries directly here or on GitHub, rather than in the tool's forum. Link to comment Share on other sites More sharing options...
ricktendo64 Posted April 22, 2020 Share Posted April 22, 2020 Sorry if this has been asked before, but can winapp2ool change all Default=False entries to True? Also is there command line argument to achieve this? Thanks Link to comment Share on other sites More sharing options...
Moderators Andavari Posted April 22, 2020 Moderators Share Posted April 22, 2020 (edited) If you can't wait. To change things like that in mass in a text document I use Metapad (it's outdated), but I suppose something more modern like Notepad++ could also achieve it. You'd just need to use the Replace feature. Edit: Actually Notepad can do it. The one caveat using it though is it doesn't count/tell you how many items it changed - but it does work! Edited April 22, 2020 by Andavari Link to comment Share on other sites More sharing options...
APMichael Posted April 22, 2020 Share Posted April 22, 2020 3 hours ago, ricktendo64 said: Sorry if this has been asked before, but can winapp2ool change all Default=False entries to True? ... No, this function does not exist. But as @Andavari has already written, "=False" can be simply replaced by "=True" with Notepad. (By the way, you can also right-click on a section name in CCleaner and select "Check all". But this does not directly change the Winapp2.ini.) Link to comment Share on other sites More sharing options...
SMalik Posted April 23, 2020 Share Posted April 23, 2020 New Entry [NetworkList *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False RegKey1=HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\NetworkList\Profiles RegKey2=HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\NetworkList\Signatures\Unmanaged Link to comment Share on other sites More sharing options...
don_dolarson Posted April 24, 2020 Share Posted April 24, 2020 The previously proposed application Caprine left over some files in C:\Users\%USERPROFILE%\AppData\Roaming\Caprine after it's uninstallation, and disappeared from CCleaner. About 70MB of data. Link to comment Share on other sites More sharing options...
siliconman01 Posted April 24, 2020 Share Posted April 24, 2020 6 hours ago, SMalik said: New Entry [NetworkList *] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False RegKey1=HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\NetworkList\Profiles RegKey2=HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\NetworkList\Signatures\Unmanaged Testing this entry, on reboot of the system, it causes an alert message to appear in the Notification tray asking if the user wants to make the network discoverable. The default value is Yes. This could be a bit discerning for users to who are running multiple computers on a network. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
