APMichael Posted April 24, 2020 Share Posted April 24, 2020 On 24/04/2020 at 03:25, don_dolarson said: The previously proposed application Caprine left over some files in C:\Users\%USERPROFILE%\AppData\Roaming\Caprine after it's uninstallation, and disappeared from CCleaner. About 70MB of data. We can change the detection, but CCleaner will still only delete the folders and files defined in Winapp2.ini after uninstalling the application. A complete removal of all leftovers after an uninstall will always require manual work or a special uninstaller tool. On 24/04/2020 at 07:20, siliconman01 said: ... [NetworkList *] ... Testing this entry, on reboot of the system, it causes an alert message to appear in the Notification tray asking if the user wants to make the network discoverable. The default value is Yes. This could be a bit discerning for users to who are running multiple computers on a network. Right! This entry deletes the data and few but important settings of all networks ever connected. This may not be a big problem on a stationary PC with only one network connection, but on a Notebook with many changing network connections (different private, business and public networks) this must be set again for each network as desired. Windows saves the network/firewall category (Public, Private, Domain) there, hence the request after a reboot. Also, some people change the name of a LAN there (under Windows 7 this was even possible via the Control Panel). Link to comment Share on other sites More sharing options...
APMichael Posted April 24, 2020 Share Posted April 24, 2020 Winapp2ool update:https://github.com/MoscaDotTo/Winapp2/releases Many thanks to @Winapp2.ini for his hard work! Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/d4404678fffbd62cc1ab0f859f87cfcc930f0773 Only adjustments for the new Winapp2ool version. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted April 24, 2020 Author Share Posted April 24, 2020 Hopefully this version doesn't suffer from the same false positive problem the previous ones have but if it does we'll use the release version on the page above as the watershed release to have vendors whitelist winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
siliconman01 Posted April 25, 2020 Share Posted April 25, 2020 11 hours ago, Winapp2.ini said: Hopefully this version doesn't suffer from the same false positive problem the previous ones have but if it does we'll use the release version on the page above as the watershed release to have vendors whitelist KIS 2020 is not barking at the new version yet. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
ricktendo64 Posted April 25, 2020 Share Posted April 25, 2020 12 hours ago, Winapp2.ini said: Hopefully this version doesn't suffer from the same false positive problem the previous ones have but if it does we'll use the release version on the page above as the watershed release to have vendors whitelist MS Antivirus did flag the latest version Question: What happened to the Default entries and how how do I add them back using winapp2ool? Link to comment Share on other sites More sharing options...
APMichael Posted April 25, 2020 Share Posted April 25, 2020 2 hours ago, ricktendo64 said: MS Antivirus did flag the latest version Question: What happened to the Default entries and how how do I add them back using winapp2ool? The VirusTotal summary is still clean:https://www.virustotal.com/gui/file/59467eb6dac8716afbd617f7e01b1b32dc00056ad2dd92f4016ae721809fd1af/detection Did you possibly mean blocking by SmartScreen? About your question:https://github.com/MoscaDotTo/Winapp2/issues/412 You could use the previous version 1.02 for this. Select "WinappDebug" (1) and enable "Toggle Autocorrect" (3). When you execute "Run" (1) the lines will be inserted automatically again. Link to comment Share on other sites More sharing options...
dvdbane Posted April 25, 2020 Share Posted April 25, 2020 Hi i just notice some of the cleaning entries were missing from my ccleaner did anyone else experience this? Win 8.1 ccleaner v5.65 [Search Charm History] ID=2411 LangSecRef=3025 Default=True DetectOS=6.3|6.3 FileKey1=%LocalAppData%\Microsoft\Windows\ConnectedSearch\History|*.lnk and this entry missing from my ccleaner too but i think this is cc bug or is it just me? Link to comment Share on other sites More sharing options...
APMichael Posted April 26, 2020 Share Posted April 26, 2020 On 26/04/2020 at 00:47, dvdbane said: ... i just notice some of the cleaning entries were missing from my ccleaner ... This problem is not caused by Winapp2.ini, it is definitely a bug in the current CCleaner version. A DetectOS according to the scheme "DetectOS=from|to" does not work anymore. Edit: https://community.ccleaner.com/topic/58081-detectos/ Link to comment Share on other sites More sharing options...
APMichael Posted April 27, 2020 Share Posted April 27, 2020 Thanks for the new entries. Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/ea91bacc032800bd1e82d17c4ed6afab1c80baf0 Winapp3.ini update:https://github.com/MoscaDotTo/Winapp2/commit/2a168556bf228258d1d1b5dfea625e379b558335 And get the new Winapp2ool version 1.4:https://github.com/MoscaDotTo/Winapp2/releases Link to comment Share on other sites More sharing options...
Winapp2.ini Posted April 27, 2020 Author Share Posted April 27, 2020 On 25/04/2020 at 02:20, ricktendo64 said: MS Antivirus did flag the latest version Question: What happened to the Default entries and how how do I add them back using winapp2ool? Winapp2ool isn't able to do this but you can add the defaults back in very easily using a find&replace that supports extended characters or regex like notepad++ Replace "]" with "]\nDefault=False" in winapp2.ini using Notepad++ set to Extended to add the "Default=False" line back into every entry automatically winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
siliconman01 Posted April 30, 2020 Share Posted April 30, 2020 (edited) On 25/04/2020 at 01:37, siliconman01 said: KIS 2020 is not barking at the new version yet. KIS 2020 suddenly started quarantining V1.4.7419.18289 of Winapp2ool.exe Had to add to KIS 2020 exclusions. KIS 2020 blocks it as VHO:Trojan.Win32.Sdum.gen Edited April 30, 2020 by siliconman01 Added Trojan ID Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted April 30, 2020 Author Share Posted April 30, 2020 32 minutes ago, siliconman01 said: KIS 2020 suddenly started quarantining V1.4.7419.18289 of Winapp2ool.exe Had to add to KIS 2020 exclusions. KIS 2020 blocks it as VHO:Trojan.Win32.Sdum.gen This hasn't shown up on VirusTotal yet but I'll submit it to them through their False Positive page, thanks for the TrojanID winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Winapp2.ini Posted April 30, 2020 Author Share Posted April 30, 2020 On 25/04/2020 at 02:20, ricktendo64 said: MS Antivirus did flag the latest version Question: What happened to the Default entries and how how do I add them back using winapp2ool? winapp2ool beta now has a feature in WinappDebug that allows you to override the empty default value and specify the one you'd like, inserting it into entries who are missing it. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
siliconman01 Posted May 1, 2020 Share Posted May 1, 2020 (edited) 15 hours ago, Winapp2.ini said: This hasn't shown up on VirusTotal yet but I'll submit it to them through their False Positive page, thanks for the TrojanID HitManPro also detects the Trojan as long as Kaspersky is falsely detecting it. UPDATE as of 01-May-2020 04:30 am EDT. It appears that Kaspersky has corrected the false positive. Both KIS 2020 and HitmanPro now scan clear. Edited May 1, 2020 by siliconman01 False Positive Corrected Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted May 1, 2020 Author Share Posted May 1, 2020 6 hours ago, siliconman01 said: UPDATE as of 01-May-2020 04:30 am EDT. It appears that Kaspersky has corrected the false positive. Both KIS 2020 and HitmanPro now scan clear. Hooray! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
siliconman01 Posted May 1, 2020 Share Posted May 1, 2020 50 minutes ago, Winapp2.ini said: Hooray! Apparently, Kaspersky uses the Build and Version number of Windows 10 to issue corrections on False Positives. Kaspersky has not caught up with the latest Insider Build 19619.1000 Version 2004 and is continuing to flag Winapp2ool.exe on my Insider test computer. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted May 1, 2020 Author Share Posted May 1, 2020 the latest winapp2ool beta build includes support for adding a whitelist and a blacklist to the trim process. simply fill a whitelist.ini and/or blacklist.ini file with the headers (you don't need the whole entry, just the [Header *] of entries you want to never trim or always trim entries in whitelist.ini will always be kept in the file, irrespective of whether or not the detection criteria are met entries in blacklist.ini will never be kept in the file, likewise. The menu might be a little wonky! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
siliconman01 Posted May 1, 2020 Share Posted May 1, 2020 18 minutes ago, Winapp2.ini said: the latest winapp2ool beta build includes support for adding a whitelist and a blacklist to the trim process. simply fill a whitelist.ini and/or blacklist.ini file with the headers (you don't need the whole entry, just the [Header *] of entries you want to never trim or always trim entries in whitelist.ini will always be kept in the file, irrespective of whether or not the detection criteria are met entries in blacklist.ini will never be kept in the file, likewise. The menu might be a little wonky! Is the beta version 1.4.7426.13493 ?? Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted May 1, 2020 Author Share Posted May 1, 2020 2 minutes ago, siliconman01 said: Is the beta version 1.4.7426.13493 ?? Any build with 1.4.7426.xxxxx was built today, I've been working actively on the beta today so as of the time of this post the latest build is 1.4.7426.15697. A link is available in the first post, or you can toggle beta participation from a non-beta build in the settings winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
siliconman01 Posted May 1, 2020 Share Posted May 1, 2020 I have a Whitelist.ini and Blacklist.ini in my CCleaner folder. Using Winapp2ool.exe v1.4.7426.15696, the Whitelist.ini and Blacklist.ini appear to be honored. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
siliconman01 Posted May 2, 2020 Share Posted May 2, 2020 (edited) Winapp2ool.exe v1.4.7426.15696 does not save the useblacklist=TRUE status in winapp2ool.ini when using both a Whitelist and Blacklist in the CCleaner folder. [Trim] MergeFile1_Name=winapp2.ini MergeFile1_Dir=C:\Program Files\CCleaner MergeFile3_Name=winapp2.ini MergeFile3_Dir=C:\Program Files\CCleaner DownloadFileToTrim=False ModuleSettingsChanged=True TrimFile1_Name=whitelist.ini TrimFile1_Dir=C:\Program Files\CCleaner TrimFile2_Name=whitelist.ini TrimFile2_Dir=C:\Program Files\CCleaner TrimFile3_Name=winapp2.ini TrimFile3_Dir=C:\Program Files\CCleaner TrimFile4_Name=blacklist.ini TrimFile4_Dir=C:\Program Files\CCleaner UseWhiteList=True useBlackList=False UPDATE: If UseWhiteList=True and useBlacklist=True at the same time, a TRIM removes all of the Winapp2.ini entries and leaves only the Whitelist entries....weird. Edited May 2, 2020 by siliconman01 UPDATE Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted May 2, 2020 Author Share Posted May 2, 2020 5 hours ago, siliconman01 said: Winapp2ool.exe v1.4.7426.15696 does not save the useblacklist=TRUE status in winapp2ool.ini when using both a Whitelist and Blacklist in the CCleaner folder. [Trim] MergeFile1_Name=winapp2.ini MergeFile1_Dir=C:\Program Files\CCleaner MergeFile3_Name=winapp2.ini MergeFile3_Dir=C:\Program Files\CCleaner DownloadFileToTrim=False ModuleSettingsChanged=True TrimFile1_Name=whitelist.ini TrimFile1_Dir=C:\Program Files\CCleaner TrimFile2_Name=whitelist.ini TrimFile2_Dir=C:\Program Files\CCleaner TrimFile3_Name=winapp2.ini TrimFile3_Dir=C:\Program Files\CCleaner TrimFile4_Name=blacklist.ini TrimFile4_Dir=C:\Program Files\CCleaner UseWhiteList=True useBlackList=False UPDATE: If UseWhiteList=True and useBlacklist=True at the same time, a TRIM removes all of the Winapp2.ini entries and leaves only the Whitelist entries....weird. I can't reproduce the behavior described in the update winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
siliconman01 Posted May 3, 2020 Share Posted May 3, 2020 I'm not seeing that behavior either on Beta version 1.4.7427.18038. It seems to be working okay [Trim] TrimFile1_Name=winapp2.ini TrimFile1_Dir=C:\Program Files\CCleaner TrimFile2_Name=whitelist.ini TrimFile2_Dir=C:\Program Files\CCleaner TrimFile3_Name=winapp2.ini TrimFile3_Dir=C:\Program Files\CCleaner TrimFile4_Name=blacklist.ini TrimFile4_Dir=C:\Program Files\CCleaner DownloadFileToTrim=False UseWhiteList=True useBlackList=True ModuleSettingsChanged=True Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
siliconman01 Posted May 3, 2020 Share Posted May 3, 2020 Also, please keep in mind that Kaspersky and HitmanPro continue to flag these new betas as VHO:Trojan.Win32.Sdum.gen. (false positive needs fixed before a new public release of Winapp2ool.exe). Kaspersky even blocks a VirusTotal submission as a malicious website. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted May 3, 2020 Author Share Posted May 3, 2020 Unfortunately I can only go by VirusTotal and it currently shows clear. https://www.virustotal.com/gui/file/5ba3effd47aed9b57a31d3398fcd35168be2d83001f78653c74ce6f141e8c9e2/detection It seems kaspersky is being particularly hostile here, but I'm not sure why as none of these vendors provide tremendous information on their flagging motivations (for good reasons I suppose) winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
