siliconman01 Posted June 19, 2019 Share Posted June 19, 2019 1 hour ago, APMichael said: Just to be safe: Is the pattern "*tmp" correct or was the dot accidentally forgotten? Ouch! It should be *.tmp. My apologies for my error. I also find that the following other modules has the same error. [Clover *] FileKey1=%LocalAppData%\Clover\User Data\Default\JumpListIcons*|*tmp [HomeCinema CyberLink *] %ProgramFiles%\HomeCinema\PowerProducer\Template\Cyberlink\frame|*tmp Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted June 19, 2019 Moderators Share Posted June 19, 2019 New entry [MiniTool Partition Wizard *] LangSecRef=3024 Default=False Detect=HKCU\Software\MiniTool Software Limited\MiniTool Partition Wizard FileKey1=%ProgramFiles%\MiniTool Partition Wizard *|log.txt Link to comment Share on other sites More sharing options...
APMichael Posted June 19, 2019 Share Posted June 19, 2019 3 hours ago, siliconman01 said: Ouch! It should be *.tmp. My apologies for my error. Thank you very much for your quick reply. I think we could probably merge FileKey7+8 then: FileKey7=%CommonAppData%\Dell\Drivers\*|*.log;*.tmp|RECURSE Would that be okay with you? 3 hours ago, siliconman01 said: I also find that the following other modules has the same error. [Clover *] FileKey1=%LocalAppData%\Clover\User Data\Default\JumpListIcons*|*tmp [HomeCinema CyberLink *] %ProgramFiles%\HomeCinema\PowerProducer\Template\Cyberlink\frame|*tmp Thank you, but are you sure it's the same error? The entries are very old. I also checked a Winapp2.ini from 2016 and there is no dot either. I don't know if we should add the dot or not. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted June 19, 2019 Author Share Posted June 19, 2019 I think the Clover entry is correct as it is, IIRC. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted June 19, 2019 Share Posted June 19, 2019 Revised Entry Changed DetectFile to Detect Removed RegKey1 & RegKey2 [Wondershare Helper Compact *] LangSecRef=3021 Detect=HKLM\SOFTWARE\Wondershare\Wondershare Helper Compact Default=False FileKey1=%CommonProgramFiles%\Wondershare\Wondershare Helper Compact|ProductUpdateLists.xml;WSHelper.exe_temp;WSHelperSetup.exe_temp FileKey2=%CommonProgramFiles%\Wondershare\Wondershare Helper Compact\DATADICT|*.*|RECURSE FileKey3=%CommonProgramFiles%\Wondershare\Wondershare Helper Compact\Log|*.*|RECURSE FileKey4=%CommonProgramFiles%\Wondershare\Wondershare Helper Compact\Temp|*.*|RECURSE Link to comment Share on other sites More sharing options...
siliconman01 Posted June 20, 2019 Share Posted June 20, 2019 (edited) 13 hours ago, APMichael said: Thank you very much for your quick reply. I think we could probably merge FileKey7+8 then: FileKey7=%CommonAppData%\Dell\Drivers\*|*.log;*.tmp|RECURSE Would that be okay with you? Thank you, but are you sure it's the same error? The entries are very old. I also checked a Winapp2.ini from 2016 and there is no dot either. I don't know if we should add the dot or not. FileKey7 did not seem to cleaning out the DUPLogDir folder. That is why I added FileKey8. Go ahead and merge them and I will monitor it to make sure it is working. As for the other modules with *tmp, I found them doing a scan (using *tmp) through winapp2.ini and just assumed they were in error....so don't take my guidance on them. In fact if you scan using *log, there are a couple of modules that have *logs instead of *.log Edited June 20, 2019 by siliconman01 Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
SMalik Posted June 20, 2019 Share Posted June 20, 2019 This entry should be removed. I have Microsoft Office Home and Student 2016. Whenever I wipe files from this location, it breaks Office. [MS Office Click-to-Run Updates *] LangSecRef=3021 Detect1=HKCU\Software\Microsoft\Office\15.0 Detect2=HKCU\Software\Microsoft\Office\16.0 Default=False Warning=This can remove downloaded update files even before they are applied. FileKey1=%CommonAppData%\Microsoft\ClickToRun\ProductReleases|*.*|RECURSE Link to comment Share on other sites More sharing options...
SMalik Posted June 20, 2019 Share Posted June 20, 2019 Revised Entry I think the entry name should be changed from [HTML5 Store *] to [Indexed Databases *]. Excluded 'storage\permanent' directory. It keeps default search engine related files here. When these files are wiped from the 'permanent' directory, Firefox startup becomes slow. The Web Search bar in the middle does not show up for long. Removed ExcludeKeys [Indexed Databases *] LangSecRef=3026 Detect1=HKLM\Software\Mozilla\Pale Moon Detect2=HKLM\Software\Mozilla\SeaMonkey Detect3=HKLM\Software\Mozilla\Waterfox DetectFile=%AppData%\Mozilla\Firefox Default=False FileKey1=%AppData%\Moonchild Productions\Pale Moon\Profiles\*\storage\temporary|*.*|RECURSE FileKey2=%AppData%\Mozilla\Firefox\Profiles\*\storage\temporary|*.*|RECURSE FileKey3=%AppData%\Mozilla\SeaMonkey\Profiles\*\storage\temporary|*.*|RECURSE FileKey4=%AppData%\Waterfox\Profiles\*\storage\temporary|*.*|RECURSE Link to comment Share on other sites More sharing options...
APMichael Posted June 22, 2019 Share Posted June 22, 2019 Thanks for the replies and the new and revised entries. Winapp2.ini updates:https://github.com/MoscaDotTo/Winapp2/commit/6c5f6db49ec288be856bf9275d7efc0d73d29b94https://github.com/MoscaDotTo/Winapp2/commit/45a9022d58f2bdf182b0309a583dd20efe48caa2https://github.com/MoscaDotTo/Winapp2/commit/40391053454e156e8c2f79d3ad6cbacd161b186dhttps://github.com/MoscaDotTo/Winapp2/commit/45cc4c1f4a4d96cb5d312b2b646b278dd3040315 Link to comment Share on other sites More sharing options...
SMalik Posted June 22, 2019 Share Posted June 22, 2019 I think the [Backup *] entry should be merged into the [Google Update *] entry because the rest of the rollback files are being wiped in [Google Update *]. Otherwise, we should just remove it. Link to comment Share on other sites More sharing options...
SMalik Posted June 25, 2019 Share Posted June 25, 2019 Revised Entry Added: %CommonAppData%\Microsoft\MapData\mapscache|*.*|RECURSE %CommonAppData%\Microsoft\MapData|events.log [Maps *] DetectOS=10.0| LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.WindowsMaps_8wekyb3d8bbwe Default=False FileKey1=%CommonAppData%\Microsoft\MapData\mapscache|*.*|RECURSE FileKey2=%CommonAppData%\Microsoft\MapData|events.log FileKey3=%LocalAppData%\Packages\Microsoft.WindowsMaps_*\AC\AppCache|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.WindowsMaps_*\AC\INet*|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.WindowsMaps_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.WindowsMaps_*\AC\NVIDIA Corporation\NV_Cache|*.* FileKey7=%LocalAppData%\Packages\Microsoft.WindowsMaps_*\AC\Temp|*.*|RECURSE FileKey8=%LocalAppData%\Packages\Microsoft.WindowsMaps_*\AC\TokenBroker\Cache|*.*|RECURSE FileKey9=%LocalAppData%\Packages\Microsoft.WindowsMaps_*\LocalCache|*.*|RECURSE FileKey10=%LocalAppData%\Packages\Microsoft.WindowsMaps_*\LocalState\Cache|*.*|RECURSE FileKey11=%LocalAppData%\Packages\Microsoft.WindowsMaps_*\TempState|*.*|RECURSE Link to comment Share on other sites More sharing options...
SMalik Posted June 25, 2019 Share Posted June 25, 2019 I think we should remove the [Mail and Calendar *] entry and just keep the [Windows Communications Apps *]. Some other Microsoft Store apps also use this, other than Mail and Calendar. Changed: DetectOS=6.2|6.3| to DetectOS=10.0| Added: %LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\TokenBroker\Cache|*.*|RECURSE %LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\LocalCache|*.*|RECURSE %LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\LocalState\AppData\Local\Office\*\WebServiceCache\AllUsers\officeclient.microsoft.com|*.*|RECURSE Removed: %LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\AppCache|*.*|RECURSE %LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\PRICache|*.*|RECURSE %LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\LocalState\LiveComm\*\*\DBStore\LogFiles|edbtmp.log [Windows Communications Apps *] DetectOS=10.0| LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\microsoft.windowscommunicationsapps_8wekyb3d8bbwe DetectFile=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Comms\Unistore\data|AggregateCache.uca FileKey2=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\AppCache|*.*|RECURSE FileKey3=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\INet*|*.*|RECURSE FileKey4=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\Microsoft\CLR_v4.0\UsageLogs|*.*|RECURSE FileKey5=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey6=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey7=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\Temp|*.*|RECURSE FileKey8=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\TokenBroker\Cache|*.*|RECURSE FileKey9=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\LocalCache|*.*|RECURSE FileKey10=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\LocalState\AppData\Local\Office\*\WebServiceCache\AllUsers\officeclient.microsoft.com|*.*|RECURSE FileKey11=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\TempState|*.*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\microsoft.windowscommunicationsapps_8wekyb3d8bbwe\SearchHistory Link to comment Share on other sites More sharing options...
Moderators Nergal Posted June 25, 2019 Moderators Share Posted June 25, 2019 Never mind my last (now deleted) comment I misread something ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
APMichael Posted June 26, 2019 Share Posted June 26, 2019 10 hours ago, SMalik said: I think we should remove the [Mail and Calendar *] entry and just keep the [Windows Communications Apps *]. Some other Microsoft Store apps also use this, other than Mail and Calendar. ... Thanks, just to be safe: Shouldn't we rename and revise the newer entry [Mail and Calendar *] and remove the older entry [Windows Communications Apps *]? Or are all FileKeys of the older entry [Windows Communications Apps *] still valid for the latest App version for Windows 10? Link to comment Share on other sites More sharing options...
SMalik Posted June 26, 2019 Share Posted June 26, 2019 2 hours ago, APMichael said: Thanks, just to be safe: Shouldn't we rename and revise the newer entry [Mail and Calendar *] and remove the older entry [Windows Communications Apps *]? Or are all FileKeys of the older entry [Windows Communications Apps *] still valid for the latest App version for Windows 10? I just updated the entry. I have added a few and removed a few unnecessary FileKeys. Now, it is fine. Link to comment Share on other sites More sharing options...
APMichael Posted June 26, 2019 Share Posted June 26, 2019 25 minutes ago, SMalik said: I just updated the entry. I have added a few and removed a few unnecessary FileKeys. Now, it is fine. Great! Thank you very much. Link to comment Share on other sites More sharing options...
SMalik Posted June 27, 2019 Share Posted June 27, 2019 The proper way to name programs/apps entries should be as they show in the Start Menu. I suggest changing [Microsoft Photos *] to [Photos *] and [My Office *] to [Office *]. Link to comment Share on other sites More sharing options...
siliconman01 Posted June 28, 2019 Share Posted June 28, 2019 New entries: [Win32WebViewHost *] & [Edge Apprep.ChxApp *] [Win32WebViewHost *] DetectOS=10.0| LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Win32WebViewHost_cw5n1h2txyewy DetectFile=%LocalAppData%\Packages\Microsoft.Win32WebViewHost_cw5n1h2txyewy Default=False FileKey1=%LocalAppData%\Packages\Microsoft.Win32WebViewHost_*\AC\*\INet*|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.Win32WebViewHost_*\AC\*\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.Win32WebViewHost_*\AC\*\NVIDIA Corporation\NV_Cache|*.* FileKey4=%LocalAppData%\Packages\Microsoft.Win32WebViewHost_*\AC\*\Temp|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.Win32WebViewHost_*\TempState|*.*|RECURSE [Edge Apprep.ChxApp *] DetectOS=10.0| LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Windows.Apprep.ChxApp_cw5n1h2txyewy DetectFile=%LocalAppData%\Packages\Microsoft.Windows.Apprep.ChxApp_cw5n1h2txyewy Default=False FileKey1=%LocalAppData%\Packages\Microsoft.Windows.Apprep.ChxApp_*\AC\INet*|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.Windows.Apprep.ChxApp_*\AC\NVIDIA Corporation\NV_Cache|*.* FileKey3=%LocalAppData%\Packages\Microsoft.Windows.Apprep.ChxApp_*\AC\Temp|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.Windows.Apprep.ChxApp_*\TempState|*.*|RECURSE Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
SMalik Posted June 29, 2019 Share Posted June 29, 2019 Revised Entry Added: %LocalAppData%\Microsoft\Internet Explorer|*.log;*.txt %LocalAppData%\Microsoft\Internet Explorer\CacheStorage|*.*|RECURSE [Internet Explorer *] LangSecRef=3022 Detect=HKCU\Software\Microsoft\Internet Explorer Default=False FileKey1=%AppData%\Microsoft\Internet Explorer\UserData|*.*|RECURSE FileKey2=%LocalAppData%\Microsoft\Internet Explorer|*.log;*.txt FileKey3=%LocalAppData%\Microsoft\Internet Explorer\CacheStorage|*.*|RECURSE FileKey4=%LocalAppData%\Microsoft\Windows\AppCache|*.*|RECURSE FileKey5=%LocalAppData%\Microsoft\Windows\IECompat*Cache|*.*|RECURSE FileKey6=%LocalAppData%\Microsoft\Windows\WebCache|*.*|RECURSE FileKey7=%LocalAppData%\Microsoft\Windows\WebCache.old|*.*|REMOVESELF FileKey8=%LocalAppData%\Packages\windows_ie_ac_*\AC\AppCache|*.*|RECURSE FileKey9=%LocalAppData%\Packages\windows_ie_ac_*\AC\IECompat*Cache|*.*|RECURSE FileKey10=%LocalAppData%\Packages\windows_ie_ac_*\AC\IEDownloadHistory|*.*|RECURSE FileKey11=%LocalAppData%\Packages\windows_ie_ac_*\AC\INet*|*.*|RECURSE FileKey12=%LocalAppData%\Packages\windows_ie_ac_*\AC\Microsoft\CLR_v4.0\UsageLogs|*.*|RECURSE FileKey13=%LocalAppData%\Packages\windows_ie_ac_*\AC\Microsoft\CryptnetUrlCache\*|*.* FileKey14=%LocalAppData%\Packages\windows_ie_ac_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey15=%LocalAppData%\Packages\windows_ie_ac_*\AC\Microsoft\Internet Explorer\Emie*List|*.*|RECURSE FileKey16=%LocalAppData%\Packages\windows_ie_ac_*\AC\PRICache|*.*|RECURSE FileKey17=%LocalAppData%\Packages\windows_ie_ac_*\AC\Temp|*.*|RECURSE FileKey18=%LocalAppData%\Packages\windows_ie_ac_*\LocalState\Cache|*.*|RECURSE FileKey19=%LocalAppData%\Packages\windows_ie_ac_*\LocalState\navigationHistory|*.*|RECURSE FileKey20=%LocalAppData%\Packages\windows_ie_ac_*\TempState|*.*|RECURSE FileKey21=%LocalLowAppData%\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey22=%WinDir%\System32\config\Systemprofile\AppData\Local\Microsoft\Windows\INetCache|*.*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppContainer\Storage\windows_ie_ac_001\Internet Explorer\DOMStorage RegKey2=HKCU\Software\Microsoft\Internet Explorer\LowRegistry\Audio\PolicyConfig\PropertyStore RegKey3=HKCU\Software\Microsoft\Internet Explorer\LowRegistry\DOMStorage RegKey4=HKCU\Software\Microsoft\Internet Explorer\Main\FeatureControl RegKey5=HKCU\Software\Microsoft\Internet Explorer\Recovery\PendingDelete RegKey6=HKCU\Software\Microsoft\Windows\CurrentVersion\Ext\Stats ExcludeKey1=FILE|%LocalAppData%\Microsoft\Windows\INetCache\IE\|container.dat ExcludeKey2=FILE|%LocalAppData%\Packages\windows_ie_ac_*\AC\INetCache\|container.dat Link to comment Share on other sites More sharing options...
SMalik Posted June 29, 2019 Share Posted June 29, 2019 Revised Entry Added: %UserProfile%\.cache|*.*|REMOVESELF [Wondershare UniConverter *] LangSecRef=3023 Detect=HKLM\Software\Wondershare\Wondershare UniConverter Default=False FileKey1=%CommonAppData%\Wondershare MediaServer|*.txt FileKey2=%CommonAppData%\Wondershare\ProductFeatures\*Logs|*.*|RECURSE FileKey3=%CommonAppData%\Wondershare\UniConverter\DataTrack|tmp;*.bak;*.log FileKey4=%CommonAppData%\Wondershare\WAF\ProductFeatures\*Logs|*.*|RECURSE FileKey5=%ProgramFiles%\Wondershare\Video Converter Ultimate(CPC)\Log|*.*|RECURSE FileKey6=%SystemDrive%\UniConverter\Downloaded\temp|*.*|REMOVESELF FileKey7=%UserProfile%\.cache|*.*|REMOVESELF Link to comment Share on other sites More sharing options...
APMichael Posted June 29, 2019 Share Posted June 29, 2019 Thanks for the revised and new entries. Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/f531031f7e5d04f66780529b5705c5acc52e7da5 Link to comment Share on other sites More sharing options...
siliconman01 Posted July 1, 2019 Share Posted July 1, 2019 (edited) New entry: [Casper System Copy Pgm Crash Files *] [Casper System Copy Pgm Crash Files *] LangSecRef=3024 Detect1=HKCU\Software\Future Systems Solutions\Casper Detect2=HKCU\Software\Future Systems Solutions\Casper 10 Default=False FileKey1=%CommonAppData%\Future Systems Solutions\Casper\Minidump|*.* New entry: [SGX Default_Error_Stack Message *] Note: Intel SGX will place these error messages in the System32 folder if SGX is having a crash problem on the user system. I discovered 177 of these messages on my Dell XPS 15 (9575) 2in1. [SGX Default_Error_Stack Message *] DetectOS=10.0| LangSecRef=3024 Detect=HKCU\Software\Intel\SGX_PSW Default=False FileKey1=%WinDir%\System32|Default_error_Stack-*.txt New entry: [AtomTime Pro Logs *] [AtomTime Pro Logs *] LangSecRef=3024 Detect=HKLM\Software\NaissanInnovations\AtomTime Default=False FileKey1=%ProgramFiles%\AtomTime Pro|*.log New entry: [Dell SupportAssistAgent *] [Dell SupportAssistAgent *] LangSecRef=3024 Detect=HKLM\Software\Dell\SupportAssistAgent Default=False FileKey1=%CommonAppData%\PCDr\*\snapshots\*|*.* FileKey2=%CommonAppData%\SupportAssist\Client\Agent\Downloads|*.*|RECURSE FileKey3=%CommonAppData%\SupportAssist\Client\Agent\Logs\ApplicationLogs|*.* FileKey4=%CommonAppData%\SupportAssist\Client\Agent\Logs\ClickStream|*.* FileKey5=%CommonAppData%\SupportAssist\Client\Agent\Logs\Driver|*.* FileKey6=%CommonAppData%\SupportAssist\Client\Agent\Logs\HardwareActivityLogs|*.* FileKey7=%CommonAppData%\SupportAssist\Client\Agent\Logs\SoftwareActivityLogs|*.*|RECURSE FileKey8=%CommonAppData%\SupportAssist\Client\SRE|*.log FileKey9=%CommonAppData%\SupportAssist\Client\SRE\ExtendedLogs|*.* FileKey10=%CommonAppData%\SupportAssist\Client\TechnicianToolkit\Library\Logs|*.*|RECURSE FileKey11=%CommonAppData%\SupportAssist\Client\TechnicianToolkit\Library\RegBackup|*.* FileKey12=%CommonAppData%\SupportAssist\Client\TechnicianToolkit\Library\Temp|*.*|RECURSE Modified entry: [DisplayFusion *] Added *.log to FileKey2 [DisplayFusion *] LangSecRef=3024 Detect=HKCU\Software\Binary Fortress Software\DisplayFusion Default=False FileKey1=%AppData%\DisplayFusion|DisplayFusionSetup.log;DisplayFusionSetup.exe;DisplayFusion.log;DebugInfo.* FileKey2=%CommonAppData%\Binary Fortress Software\DisplayFusion|DisplayFusionSetup.exe;*.log Edited July 1, 2019 by siliconman01 Added [Dell SupportAssistAgent *] Modified entry: [DisplayFusion *] Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
APMichael Posted July 1, 2019 Share Posted July 1, 2019 3 hours ago, siliconman01 said: [SGX Default_Error_Stack Message *] DetectOS=10.0| LangSecRef=3024 Detect=HKCU\Software\Intel\SGX_PSW Default=False FileKey1=%WinDir%\System32|Default_error_Stack-*.txt Would it be okay with you if we add the FileKey to the entry [Intel Logs *]? 3 hours ago, siliconman01 said: [Dell SupportAssistAgent *] LangSecRef=3024 Detect=HKLM\Software\Dell\SupportAssistAgent Default=False FileKey1=%CommonAppData%\PCDr\*\snapshots\*|*.* FileKey2=%CommonAppData%\SupportAssist\Client\Agent\Downloads|*.*|RECURSE FileKey3=%CommonAppData%\SupportAssist\Client\Agent\Logs\ApplicationLogs|*.* FileKey4=%CommonAppData%\SupportAssist\Client\Agent\Logs\ClickStream|*.* FileKey5=%CommonAppData%\SupportAssist\Client\Agent\Logs\Driver|*.* FileKey6=%CommonAppData%\SupportAssist\Client\Agent\Logs\HardwareActivityLogs|*.* FileKey7=%CommonAppData%\SupportAssist\Client\Agent\Logs\SoftwareActivityLogs|*.*|RECURSE FileKey8=%CommonAppData%\SupportAssist\Client\SRE|*.log FileKey9=%CommonAppData%\SupportAssist\Client\SRE\ExtendedLogs|*.* FileKey10=%CommonAppData%\SupportAssist\Client\TechnicianToolkit\Library\Logs|*.*|RECURSE FileKey11=%CommonAppData%\SupportAssist\Client\TechnicianToolkit\Library\RegBackup|*.* FileKey12=%CommonAppData%\SupportAssist\Client\TechnicianToolkit\Library\Temp|*.*|RECURSE Are there important log files? Otherwise we could merge FileKey3 to 7: FileKey3=%CommonAppData%\SupportAssist\Client\Agent\Logs\*|*.*|RECURSE Link to comment Share on other sites More sharing options...
siliconman01 Posted July 1, 2019 Share Posted July 1, 2019 5 hours ago, APMichael said: Would it be okay with you if we add the FileKey to the entry [Intel Logs *]? Are there important log files? Otherwise we could merge FileKey3 to 7: FileKey3=%CommonAppData%\SupportAssist\Client\Agent\Logs\*|*.*|RECURSE Your recommended merge is perfectly okay. Sure glad that you examine and recommend our entries so that Winapp2.ini will be most efficient. [Dell SupportAssistAgent *] LangSecRef=3024 Detect=HKLM\Software\Dell\SupportAssistAgent Default=False FileKey1=%CommonAppData%\PCDr\*\snapshots\*|*.* FileKey2=%CommonAppData%\SupportAssist\Client\Agent\Downloads|*.*|RECURSE FileKey3=%CommonAppData%\SupportAssist\Client\Agent\Logs\*|*.*|RECURSE FileKey4=%CommonAppData%\SupportAssist\Client\SRE|*.log FileKey5=%CommonAppData%\SupportAssist\Client\SRE\ExtendedLogs|*.* FileKey6=%CommonAppData%\SupportAssist\Client\TechnicianToolkit\Library\Logs|*.*|RECURSE FileKey7=%CommonAppData%\SupportAssist\Client\TechnicianToolkit\Library\RegBackup|*.* FileKey8=%CommonAppData%\SupportAssist\Client\TechnicianToolkit\Library\Temp|*.*|RECURSE Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
APMichael Posted July 1, 2019 Share Posted July 1, 2019 1 hour ago, siliconman01 said: Your recommended merge is perfectly okay. Sure glad that you examine and recommend our entries so that Winapp2.ini will be most efficient. Great! Thank you very much for your prompt reply. Link to comment Share on other sites More sharing options...
