Winapp2.ini additions
Winapp2.ini
2 hours ago, CSGalloway said:
I would assume just extract the winapp1.ini from the ccleaner.exe or ccleqaner64.exe using tghe /export command line option then edit the winapp1.ini and just comment out using ";" the lines you don't want processed.
Thanks for pointing me in the right direction.  Here is how it actually works.
-  Using CCDump.exe, extract Winapp.ini from CCleaner
-  Rename Winapp.ini to Winapp1.ini
-  Edit Winapp1.ini to either comment out or remove all the cleaning modules/code that you do NOT want CCleaner to use.
-  Once Winapp1.ini is edited and saved, CCleaner will use Winapp1.ini instead of Winapp.ini
Of course, this process would have to be repeated each time a new version of CCleaner is released to ensure that any revisions to Winapp.ini are obtained.
Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System);  Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC.  ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system):   Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more.
Link to comment
  • Moderators
6 hours ago, siliconman01 said:
Btw APMichael,
Do you know how to set up Winapp1.ini so that it will not show such entries as [Twitter Metro] and several Bing entries link [Bing Finance]?  I cannot seem to find any instructions on how to do this little known trick.
Run export (ccleaner.exe /export) rename winapp.ini to winapp1.ini.  delete entries you don't want from the ini, profit.
Link to comment
Modified entry:  [Scan *]
Added:
FileKey2=%LocalAppData%\Packages\Microsoft.WindowsScan_*\AC\NVIDIA Corporation\NV_Cache|*.*
Modified other keys to match current structure.
[Scan *]
DetectOS=10.0|
LangSecRef=3031
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.WindowsScan_8wekyb3d8bbwe
Default=False
FileKey1=%LocalAppData%\Packages\Microsoft.WindowsScan_*\AC\INet*|*.*|RECURSE
FileKey3=%LocalAppData%\Packages\Microsoft.WindowsScan_*\AC\Temp|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\Microsoft.WindowsScan_*\AC\TokenBroker\Cache|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\Microsoft.WindowsScan_*\LocalCache|*.*|RECURSE
FileKey6=%LocalAppData%\Packages\Microsoft.WindowsScan_*\LocalState\Cache|*.*|RECURSE
FileKey7=%LocalAppData%\Packages\Microsoft.WindowsScan_*\TempState|*.*|RECURSE
Modified entry:  [Sway *]
Added:
FileKey4=%LocalAppData%\Packages\Microsoft.Office.Sway_*\AC\Microsoft\Internet Explorer\DOMStore\*|*.*|REMOVESELF
FileKey5=%LocalAppData%\Packages\Microsoft.Office.Sway_*\AC\NVIDIA Corporation\NV_Cache|*.*
[Sway *]
DetectOS=10.0|
LangSecRef=3031
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Office.Sway_8wekyb3d8bbwe
Default=False
FileKey1=%LocalAppData%\Packages\Microsoft.Office.Sway_*\AC\AppCache|*.*|RECURSE
FileKey2=%LocalAppData%\Packages\Microsoft.Office.Sway_*\AC\INet*|*.*|RECURSE
FileKey3=%LocalAppData%\Packages\Microsoft.Office.Sway_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE
FileKey6=%LocalAppData%\Packages\Microsoft.Office.Sway_*\AC\Temp|*.*|RECURSE
FileKey7=%LocalAppData%\Packages\Microsoft.Office.Sway_*\AC\TokenBroker\Cache|*.*|RECURSE
FileKey8=%LocalAppData%\Packages\Microsoft.Office.Sway_*\LocalCache|*.*|RECURSE
FileKey9=%LocalAppData%\Packages\Microsoft.Office.Sway_*\LocalState\Cache|*.*|RECURSE
FileKey10=%LocalAppData%\Packages\Microsoft.Office.Sway_*\TempState|*.*|RECURSE
Modified entry:  [Windows Communications Apps *]
Added DetectOS=6.2|6.3  because this app does not apply to Windows 10
DetectOS=6.2|6.3
LangSecRef=3031
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\microsoft.windowscommunicationsapps_8wekyb3d8bbwe
DetectFile=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_8wekyb3d8bbwe
Default=False
FileKey1=%LocalAppData%\Comms\Unistore\data|AggregateCache.uca
FileKey2=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\AppCache|*.*|RECURSE
FileKey3=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\INet*|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\Microsoft\CLR_v4.0\UsageLogs|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE
FileKey6=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE
FileKey7=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\PRICache|*.*|RECURSE
FileKey8=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\Temp|*.*|RECURSE
FileKey9=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\LocalState\LiveComm\*\*\DBStore\LogFiles|edbtmp.log
FileKey10=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\TempState|*.*|RECURSE
RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\microsoft.windowscommunicationsapps_8wekyb3d8bbwe\SearchHistory
Modified entry:  [People *]
Added:
FileKey2=%LocalAppData%\Packages\Microsoft.People_*\AC\NVIDIA Corporation\NV_Cache|*.*
[People *]
DetectOS=10.0|
LangSecRef=3031
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.People_8wekyb3d8bbwe
Default=False
FileKey1=%LocalAppData%\Packages\Microsoft.People_*\AC\INet*|*.*|RECURSE
FileKey3=%LocalAppData%\Packages\Microsoft.People_*\AC\Temp|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\Microsoft.People_*\LocalCache|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\Microsoft.People_*\LocalState\Cache|*.*|RECURSE
FileKey6=%LocalAppData%\Packages\Microsoft.People_*\LocalState\DiagOutputDir|*.etl
FileKey7=%LocalAppData%\Packages\Microsoft.People_*\TempState|*.*|RECURSE
New entry:  [Mail and Calendar *]
DetectOS=10.0|
LangSecRef=3031
Default=False
FileKey1=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\INet*|*.*|RECURSE
FileKey2=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\Microsoft\CryptnetUrlCache\*|*.*
FileKey3=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\NVIDIA Corporation\NV_Cache|*.*
FileKey4=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\Temp|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\TokenBroker\Cache|*.*
FileKey6=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\LocalCache|*.*|RECURSE
FileKey7=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\LocalState|*.etl
FileKey8=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\TempState|*.*|RECURSE
Modified entry:  [WinJS *]
Added:
FileKey6=%LocalAppData%\Packages\Microsoft.WinJS.*.*_*\AC\NVIDIA Corporation\NV_Cache|*.*
[WinJS *]
LangSecRef=3031
Detect1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.WinJS.1.0_8wekyb3d8bbwe
Detect2=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.WinJS.2.0_8wekyb3d8bbwe
DetectFile=%LocalAppData%\Packages\Microsoft.WinJS.*.0_8wekyb3d8bbwe
Default=False
FileKey1=%LocalAppData%\Packages\Microsoft.WinJS.*.*_*\AC\AppCache|*.*|RECURSE
FileKey2=%LocalAppData%\Packages\Microsoft.WinJS.*.*_*\AC\INet*|*.*|RECURSE
FileKey3=%LocalAppData%\Packages\Microsoft.WinJS.*.*_*\AC\Microsoft\CLR_v4.0\UsageLogs|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\Microsoft.WinJS.*.*_*\AC\Microsoft\CryptnetUrlCache\*|*.*
FileKey5=%LocalAppData%\Packages\Microsoft.WinJS.*.*_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE
FileKey7=%LocalAppData%\Packages\Microsoft.WinJS.*.*_*\AC\PRICache|*.*
FileKey8=%LocalAppData%\Packages\Microsoft.WinJS.*.*_*\AC\Temp|*.*
FileKey9=%LocalAppData%\Packages\Microsoft.WinJS.*.*_*\LocalState\*Cache|*.*|RECURSE
FileKey10=%LocalAppData%\Packages\Microsoft.WinJS.*.*_*\LocalState\navigationHistory|*.*|RECURSE
FileKey11=%LocalAppData%\Packages\Microsoft.WinJS.*.*_*\TempState|*.*|RECURSE
Link to comment
Looks like there is a Tsunami in this thread.
Why do we have to add "NVIDIA Corporation/NV_Cache" location in all the Microsoft Store apps?
NVIDIA Shader Cache (NVIDIA Corporation/NV_Cache) files get created into "%LocalAppData%\Temp" and some apps' Temp folders. We already have Microsoft Store apps' Temp locations covered in the app entries.
NVIDIA Shader Cache does not target all apps. If someone is having NVIDIA Shader Cache files created in other locations, there is some thing wrong with their NVIDIA driver installation. They would need a clean install of the driver.
https://forums.geforce.com/default/topic/738794/hello-and-how-to-remove-folder-/
https://forums.gearboxsoftware.com/t/nvidia-cards-and-the-shader-cache-in-windows/1573020
The owner of Winapp2.ini should take control back. It was so nice before and It is getting so annoying now. Everyday, some people start something weird here.
Link to comment
Here we go again...
I have high end Nvidia GPUs on my systems and my Nvidia driver software up in the 400 series of releases.  Once the 400 series of drivers were released the location of the NVidia code  in Store Apps moved from the Temp location to it's own dedicated location as shown in the pic below.  And there is nothing wrong with my Nvidia driver installations.  And in addition, many of the cleaning modules in Winapp2.ini for Store Apps are not current with the file structures now in the Packages folder or they apply to Windows 8/8.1 and not Windows 10.
IF APMichael and Winapp2 (Robert) do not want updates to keep up with Microsoft changes, then I'll stop posting them and go another route.
And BTW...scan back through this forum thread and observe the number of times SMalik has posted many changes in rapid sequence. :wacko:
Link to comment
New entry: [Windows File Manager *]
DetectOS=10.0|
LangSecRef=3031
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.WindowsFileManager_8wekyb3d8bbwe
Default=False
FileKey1=%LocalAppData%\Packages\Microsoft.WindowsFileManager_*\AC\INet*|*.*|RECURSE
FileKey2=%LocalAppData%\Packages\Microsoft.WindowsFileManager_*\AC\Temp|*.*|RECURSE
FileKey3=%LocalAppData%\Packages\Microsoft.WindowsFileManager_*\LocalCache\Local\*|*.*|REMOVESELF
FileKey4=%LocalAppData%\Packages\Microsoft.WindowsFileManager_*\LocalCache\LocalLow\Microsoft\CryptnetUrlCache\*|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\Microsoft.WindowsFileManager_*\LocalCache\LocalLow\Temp|*.*|RECURSE
FileKey6=%LocalAppData%\Packages\Microsoft.WindowsFileManager_*\LocalCache\Roaming\*|*.*|REMOVESELF
FileKey7=%LocalAppData%\Packages\Microsoft.WindowsFileManager_*\LocalCache\Temp|*.*|REMOVESELF
FileKey8=%LocalAppData%\Packages\Microsoft.WindowsFileManager_*\TempState|*.*|RECURSE
New entry: [OneDrive *]
[OneDrive *]
DetectOS=10.0|
LangSecRef=3031
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\microsoft.microsoftskydrive_8wekyb3d8bbwe
Default=False
FileKey1=%LocalAppData%\Packages\microsoft.microsoftskydrive_*\AC\INet*|*.*|RECURSE
FileKey2=%LocalAppData%\Packages\microsoft.microsoftskydrive_*\AC\NVIDIA Corporation\NV_Cache|*.*
FileKey3=%LocalAppData%\Packages\microsoft.microsoftskydrive_*\AC\Temp|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\microsoft.microsoftskydrive_*\LocalCache|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\microsoft.microsoftskydrive_*\LocalState\Logs|*.log
FileKey6=%LocalAppData%\Packages\microsoft.microsoftskydrive_*\TempState|*.*|RECURSE
Modified entry:  [Shell Experience Host *]
Based on the latest Windows 10 file structure in Packages for this App
DetectOS=10.0|
LangSecRef=3031
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Windows.ShellExperienceHost_cw5n1h2txyewy
Default=False
FileKey1=%LocalAppData%\Packages\Microsoft.Windows.ShellExperienceHost_*\AC\INet*|*.*|RECURSE
FileKey2=%LocalAppData%\Packages\Microsoft.Windows.ShellExperienceHost_*\AC\Microsoft\Windows\*|*.*|REMOVESELF
FileKey3=%LocalAppData%\Packages\Microsoft.Windows.ShellExperienceHost_*\AC\Temp|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\Microsoft.Windows.ShellExperienceHost_*\LocalCache|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\Microsoft.Windows.ShellExperienceHost_*\TempState|*.*|RECURSE
Modified entry: [Print 3D *]
Changed name from [Print3D] to [Print 3D *]
[Print 3D *]
DetectOS=10.0|
LangSecRef=3031
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Print3D_8wekyb3d8bbwe
Default=False
FileKey1=%LocalAppData%\Packages\Microsoft.Print3D_*\AC\INet*|*.*|RECURSE
FileKey2=%LocalAppData%\Packages\Microsoft.Print3D_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE
FileKey3=%LocalAppData%\Packages\Microsoft.Print3D_*\AC\NVIDIA Corporation\NV_Cache|*.*
FileKey4=%LocalAppData%\Packages\Microsoft.Print3D_*\AC\Temp|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\Microsoft.Print3D_*\LocalCache|*.*|RECURSE
FileKey6=%LocalAppData%\Packages\Microsoft.Print3D_*\LocalState\Cache|*.*|RECURSE
FileKey7=%LocalAppData%\Packages\Microsoft.Print3D_*\TempState|*.*|RECURSE
Modified entry:  [Paint 3D *]
[Paint 3D *]
DetectOS=10.0|
LangSecRef=3031
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.MSPaint_8wekyb3d8bbwe
DetectFile=%LocalAppData%\Packages\Microsoft.MSPaint_8wekyb3d8bbwe
Default=False
FileKey1=%LocalAppData%\Packages\Microsoft.MSPaint_*\AC\INet*|*.*|RECURSE
FileKey2=%LocalAppData%\Packages\Microsoft.MSPaint_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE
FileKey3=%LocalAppData%\Packages\Microsoft.MSPaint_*\AC\NVIDIA Corporation\NV_Cache|*.*
FileKey4=%LocalAppData%\Packages\Microsoft.MSPaint_*\AC\Temp|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\Microsoft.MSPaint_*\LocalCache|*.*|RECURSE
FileKey6=%LocalAppData%\Packages\Microsoft.MSPaint_*\LocalState\Projects\WorkingFolder*|*.*|REMOVESELF
FileKey7=%LocalAppData%\Packages\Microsoft.MSPaint_*\LocalState\Textures|*.*
FileKey8=%LocalAppData%\Packages\Microsoft.MSPaint_*\TempState|*.*|RECURSE
Modified entry:  [Alarms and Clocks *]
Changed name from [Alarms *] to [Alarms and Clocks *]
DetectOS=10.0|
LangSecRef=3031
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.WindowsAlarms_8wekyb3d8bbwe
Default=False
FileKey1=%LocalAppData%\Packages\Microsoft.WindowsAlarms_*\AC\INet*|*.*|RECURSE
FileKey2=%LocalAppData%\Packages\Microsoft.WindowsAlarms_*\AC\NVIDIA Corporation\NV_Cache|*.*
FileKey3=%LocalAppData%\Packages\Microsoft.WindowsAlarms_*\AC\Temp|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\Microsoft.WindowsAlarms_*\LocalCache|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\Microsoft.WindowsAlarms_*\LocalState|*.*|RECURSE
FileKey6=%LocalAppData%\Packages\Microsoft.WindowsAlarms_*\TempState|*.*|RECURSE
Modified entry:  [Tips *]
[Tips *]
DetectOS=10.0|
LangSecRef=3031
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Getstarted_8wekyb3d8bbwe
Default=False
FileKey1=%LocalAppData%\Packages\Microsoft.Getstarted_*\AC\INet*|*.*|RECURSE
FileKey2=%LocalAppData%\Packages\Microsoft.Getstarted_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE
FileKey3=%LocalAppData%\Packages\Microsoft.Getstarted_*\AC\NVIDIA Corporation\NV_Cache|*.*
FileKey4=%LocalAppData%\Packages\Microsoft.Getstarted_*\AC\Temp|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\Microsoft.Getstarted_*\LocalCache|*.*|RECURSE
FileKey6=%LocalAppData%\Packages\Microsoft.Getstarted_*\LocalState\Cache|*.*|RECURSE
FileKey7=%LocalAppData%\Packages\Microsoft.Getstarted_*\TempState|*.*|RECURSE
Link to comment
  • Moderators
Too bad CCleaner (or some other tool) doesn't exist to completely simplify and hasten the ability to make new cleaning entries/routines for the lot of repeating sub-folder structures without having to make unique individual cleaners which seems to be a reoccurring theme for Win10.
Link to comment
Revised Entry
There is no harm in deleting files with the .txt extension from %LocalAppData%\Packages\Microsoft.Windows.Cortana_*\LocalState\DeviceSearchCache
Short paths like "\*Cache" or "\INet*" should not be used. I don't know of any other privacy cleaning programs that use this pattern.
Filekey1 thru 6 has "\Microsoft.*Cortana_*" and Filekey7 thru 9 has "Microsoft.Windows.Cortana_*". I wonder why?
Removed: ExcludeKey1=PATH|%LocalAppData%\Packages\Microsoft.Windows.Cortana_*\LocalState\DeviceSearchCache\|*.*
Changed: %LocalAppData%\Packages\Microsoft.Windows.Cortana_*\LocalState\*Cache|*.*|RECURSE to %LocalAppData%\Packages\Microsoft.Windows.Cortana_*\LocalState\Cache|*.*|RECURSE
Added: %LocalAppData%\Packages\Microsoft.Windows.Cortana_*\LocalState\DeviceSearchCache|*.txt
[Cortana *]
LangSecRef=3031
Detect1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Cortana_8wekyb3d8bbwe
Detect2=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Windows.Cortana_cw5n1h2txyewy
Default=False
FileKey1=%LocalAppData%\Packages\Microsoft.*Cortana_*\AC\AppCache|*.*|RECURSE
FileKey2=%LocalAppData%\Packages\Microsoft.*Cortana_*\AC\INet*|*.*|RECURSE
FileKey3=%LocalAppData%\Packages\Microsoft.*Cortana_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\Microsoft.*Cortana_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\Microsoft.*Cortana_*\AC\Temp|*.*|RECURSE
FileKey6=%LocalAppData%\Packages\Microsoft.*Cortana_*\TempState|*.*|RECURSE
FileKey7=%LocalAppData%\Packages\Microsoft.Windows.Cortana_*\LocalCache|*.*|RECURSE
FileKey8=%LocalAppData%\Packages\Microsoft.Windows.Cortana_*\LocalState\Cache|*.*|RECURSE
FileKey9=%LocalAppData%\Packages\Microsoft.Windows.Cortana_*\LocalState\DeviceSearchCache|*.txt
Link to comment
Revised Entry
Added: %LocalLowAppData%\Adobe\AcroCef\DC\Acrobat\Cache|*.*|RECURSE
[Adobe Reader DC *]
LangSecRef=3021
Detect=HKLM\Software\Adobe\Acrobat Reader\DC
Default=False
FileKey1=%LocalAppData%\Adobe\Acrobat\DC|UserCache.bin
FileKey2=%LocalLowAppData%\Adobe\AcroCef\DC\Acrobat\Cache|*.*|RECURSE
FileKey3=%AppData%\Adobe\Acrobat\DC\Security\CRLCache|*.*|RECURSE
RegKey1=HKCU\Software\Adobe\Acrobat Reader\DC\AVConversionFromPDF
RegKey2=HKCU\Software\Adobe\Acrobat Reader\DC\AVConversionToPDF
RegKey3=HKCU\Software\Adobe\Acrobat Reader\DC\AVGeneral\cDockables
RegKey4=HKCU\Software\Adobe\Acrobat Reader\DC\AVGeneral\cRecentToolsList
RegKey5=HKCU\Software\Adobe\Acrobat Reader\DC\AVGeneral\cToolbars
RegKey6=HKCU\Software\Adobe\Acrobat Reader\DC\RememberedViews\cNoCategoryFiles
RegKey7=HKCU\Software\Adobe\Acrobat Reader\DC\ShareIdentity
RegKey8=HKCU\Software\Adobe\Adobe Synchronizer\DC
Link to comment
New Entry
[Registered Service Workers *]
LangSecRef=3026
Detect1=HKLM\Software\Mozilla\Pale Moon
Detect2=HKLM\Software\Mozilla\SeaMonkey
Detect3=HKLM\Software\Mozilla\Waterfox
DetectFile=%AppData%\Mozilla\Firefox
Default=False
FileKey1=%AppData%\Moonchild Productions\Pale Moon\Profiles\*|serviceworker.txt
FileKey2=%AppData%\Mozilla\Firefox\Profiles\*|serviceworker.txt
FileKey3=%AppData%\Mozilla\SeaMonkey\Profiles\*|serviceworker.txt
FileKey4=%AppData%\Waterfox\Profiles\*|serviceworker.txt
Link to comment
  • Moderators
8 minutes ago, SMalik said:
New Entry
LangSecRef=3026
Default=False
Why not use detectspecial firefox instead of the limited detects you used.
Link to comment
  • Moderators
11 minutes ago, SMalik said:
I think that is better.
You think which is better? Mine or yours.  Just wondering
Link to comment
New Entry
To remove opened files history, user.config file should be deleted. Deleting user.config file will also reset Windows PowerShell ISE to its defaults.
[Windows PowerShell ISE *]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows
Default=False
FileKey1=%LocalAppData%\Microsoft_Corporation\PowerShell_ISE.exe_*\*|user.config
FileKey2=%LocalAppData%\Microsoft_Corporation\PowerShell_ISE.exe_*\*\AutoSaveFiles|*.*|RECURSE
FileKey3=%LocalAppData%\Microsoft_Corporation\PowerShell_ISE.exe_*\*\AutoSaveInformation|*.*|RECURSE
Link to comment
New entry:  [Cortana Show Me *]
[Cortana Show Me *]
LangSecRef=3031
Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.CortanaFollowMe_8wekyb3d8bbwe
Default=False
FileKey1=%LocalAppData%\Packages\Microsoft.CortanaFollowMe_*\AC\INet*|*.*|RECURSE
FileKey2=%LocalAppData%\Packages\Microsoft.CortanaFollowMe_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE
FileKey3=%LocalAppData%\Packages\Microsoft.CortanaFollowMe_*\AC\NVIDIA Corporation\NV_Cache|*.*
FileKey4=%LocalAppData%\Packages\Microsoft.CortanaFollowMe_*\AC\Temp|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\Microsoft.CortanaFollowMe_*\LocalCache\Local\*|*.*|RECURSE
FileKey6=%LocalAppData%\Packages\Microsoft.CortanaFollowMe_*\LocalCache\Local\LocalLow\Microsoft\CryptUrlCache\*|*.*|RECURSE
FileKey7=%LocalAppData%\Packages\Microsoft.CortanaFollowMe_*\LocalState|*.*|RECURSE
FileKey8=%LocalAppData%\Packages\Microsoft.CortanaFollowMe_*\TempState|*.*|RECURSE
Link to comment
17 hours ago, SMalik said:
... There is no harm in deleting files with the .txt extension from %LocalAppData%\Packages\Microsoft.Windows.Cortana_*\LocalState\DeviceSearchCache ...
I'm sorry, but you're wrong. If you delete the *.txt files, you're breaking Cortana. Please read the previous posts (have you ever read what other people have written?) and the issue report on GitHub. After a reboot, the search for settings and applications no longer works correctly. And please don't discuss this any further with me, because other people (not me) have reported the problems and also confirmed the fix. Thanks for respecting that!
... Short paths like "\*Cache" or "\INet*" should not be used. I don't know of any other privacy cleaning programs that use this pattern. ...
This has already been discussed. By the way, why do you always care what other cleaners do? If every cleaner would do the same, then it is not necessary to have different cleaners...
... Filekey1 thru 6 has "\Microsoft.*Cortana_*" and Filekey7 thru 9 has "Microsoft.Windows.Cortana_*". I wonder why? ...
Because this is one of the few remaining entries that combines the version of Windows 8/8.1 and Windows 10. Therefore it has two different Detects.
Link to comment
If you use SpecialDetect, the Detects and DetectFiles for the other browsers will be ignored. This is a strange behavior of CCleaner. And that's why we don't use SpecialDetect in Winapp2.ini anymore.
Link to comment
  • Moderators
Good to know, I must've forgotten that
Link to comment
I hear minefields can be dangerous :ph34r:
Link to comment
Deleting these .txt files from that location in Cortana doesn't break Cortana. Have you tried this yourself? If I had control of the Winapp2.ini file, like you, I would test each and every entry myself.
Link to comment
Register a new account
Sign in
Important Information
