siliconman01 Posted February 14, 2019 Share Posted February 14, 2019 Here is the string of Search errors that occur on my Windows 10x64 Pro systems if I delete the Project entries and reboot the system. MS Search fails to start up because of corrupt index files. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
APMichael Posted February 14, 2019 Share Posted February 14, 2019 10 hours ago, SMalik said: The programs I mentioned in my previous post wipe the traces and then restart the system to wipe files locked by Windows or other programs. Ok, thanks for your reply. But this is a special feature of the other programs, they delete these locked files in a special phase of the boot process. I don't think you can do the same by simply rebooting Windows manually after using CCleaner. Whether Windows is rebooted manually after using CCleaner or not should not matter then, because CCleaner can't delete these files anyway, right? Link to comment Share on other sites More sharing options...
APMichael Posted February 14, 2019 Share Posted February 14, 2019 5 hours ago, siliconman01 said: In my opinion it is not the intent of the CCleaner developers to force or advocate users to reboot their system following using CCleaner. ... Yes, this cannot be intentional, as it would also collide with the "Smart Cleaning" or "Schedule" function of CCleaner. By the way, you have the "Search" errors even though you rebooted Windows after using CCleaner, right? So a reboot didn't help... Link to comment Share on other sites More sharing options...
siliconman01 Posted February 14, 2019 Share Posted February 14, 2019 26 minutes ago, APMichael said: Yes, this cannot be intentional, as it would also collide with the "Smart Cleaning" or "Schedule" function of CCleaner. By the way, you have the "Search" errors even though you rebooted Windows after using CCleaner, right? So a reboot didn't help... The errors occur during the reboot/startup, not when the files are deleted prior to the reboot....if I understand your question corrected. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
APMichael Posted February 14, 2019 Share Posted February 14, 2019 I just wanted to say that if [MS Search *] is supposed to be an entry that needs a reboot for a successful cleanup, why do the errors only occur after a reboot? Then the theory with the necessary reboot cannot be completely correct. Link to comment Share on other sites More sharing options...
siliconman01 Posted February 14, 2019 Share Posted February 14, 2019 40 minutes ago, APMichael said: I just wanted to say that if [MS Search *] is supposed to be an entry that needs a reboot for a successful cleanup, why do the errors only occur after a reboot? Then the theory with the necessary reboot cannot be completely correct. I assume that these files have already been read by the Windows Search service on the previous reboot, so it does not access them again until reboot. (I do not know what changes these files during normal operation. I assume that MS Search will crash if some event requires Search to need these deleted files.) Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
APMichael Posted February 14, 2019 Share Posted February 14, 2019 I enabled "Windows Sarch" again and did some tests. Now I can confirm that the current entry causes multiple "Search" errors and a rebuild of the index after a reboot. The reason for this behavior is that the .000 files are locked and CCleaner cannot delete them. The only way to avoid this problem is to use "Windows Safe Mode". But using "Windows Safe Mode" for CCleaner is not the default and we cannot force users to use it either. Since the current entry breaks "Windows Search" (if CCleaner is used as usual) and therefore always causes a rebuilding of the search index, the corresponding keys should be moved to Winapp3.ini. Link to comment Share on other sites More sharing options...
APMichael Posted February 14, 2019 Share Posted February 14, 2019 @siliconman01 Just to be safe: Is the name of the entry correct? Because there is a "Dell Mobile Connect" app and a "Dell Customer Connect" app. https://www.microsoft.com/en-us/p/dell-mobile-connect/9nx51w9gbs5thttps://www.microsoft.com/en-us/p/dell-customer-connect/9nf0ggq5s6qx On 9.2.2019 at 17:57, siliconman01 said: Several new entries for Dell Apps in Windows Store [Dell Mobile Connect *] LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\DellInc.DellCustomerConnect_htrsf667h5kn2 Default=False FileKey1=%LocalAppData%\Packages\DellInc.DellCustomerConnect_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey2=%LocalAppData%\Packages\DellInc.DellCustomerConnect_*\AC\Temp|*.*|RECURSE FileKey3=%LocalAppData%\Packages\DellInc.DellCustomerConnect_*\LocalCache\Local\Microsoft\CLR_v4.0_32\UsageLogs|*.log FileKey4=%LocalAppData%\Packages\DellInc.DellCustomerConnect_*\LocalState\serilog|*.txt FileKey5=%LocalAppData%\Packages\DellInc.DellCustomerConnect_*\TempState|*.*|RECURSE ... Link to comment Share on other sites More sharing options...
siliconman01 Posted February 14, 2019 Share Posted February 14, 2019 44 minutes ago, APMichael said: @siliconman01 Just to be safe: Is the name of the entry correct? Because there is a "Dell Mobile Connect" app and a "Dell Customer Connect" app. https://www.microsoft.com/en-us/p/dell-mobile-connect/9nx51w9gbs5thttps://www.microsoft.com/en-us/p/dell-customer-connect/9nf0ggq5s6qx This should be [Dell Customer Connect *]....sorry. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
siliconman01 Posted February 14, 2019 Share Posted February 14, 2019 New entry: [Dell Mobile Connect *] (The right one ) [Dell Mobile Connect *] LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\ScreenovateTechnologies.DellMobileConnect_0vhbc3ng4wbp0 Default=False FileKey1=%LocalAppData%\Packages\ScreenovateTechnologies.DellMobileConnect_*\AC\INet*|*.*|RECURSE FileKey2=%LocalAppData%\Packages\ScreenovateTechnologies.DellMobileConnect_*\AC\Temp|*.*|RECURSE FileKey3=%LocalAppData%\Packages\ScreenovateTechnologies.DellMobileConnect_*\LocalCache\Local\Dell\DellMobileConnect|*.log FileKey4=%LocalAppData%\Packages\ScreenovateTechnologies.DellMobileConnect_*\LocalCache\Local\Microsoft\CLR_v4.0\UsageLogs|*.log FileKey5=%LocalAppData%\Packages\ScreenovateTechnologies.DellMobileConnect_*\LocalCache\LocalLow\Microsoft\CryptnetURLCache\*|*.*|RECURSE FileKey6=%LocalAppData%\Packages\ScreenovateTechnologies.DellMobileConnect_*\TempState|*.*|RECURSE Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
SMalik Posted February 14, 2019 Share Posted February 14, 2019 We are making a mistake removing FileKeys related to Search Stream logs and Search Indexing traces. They hold information about searches. Link to comment Share on other sites More sharing options...
SMalik Posted February 14, 2019 Share Posted February 14, 2019 @APMichael Like I said before, CCleaner can't wipe some of the traces in the entries listed below successfully because some of the traces are locked by Windows or programs similar to MS Search. Let's remove all of these. Internet Explorer Microsoft Edge Cortana Cached File Extensions Compatibility Assistant Delivery Optimization Fonts Cache Icon Cache Jump Lists LocalService LocalSystem Microsoft Store NetworkService Plex Media Server Power Efficiency Diagnostics Push Notifications TeamViewer Windows Error Reporting Windows Logs Windows ShellBags Windows Subsystems Windows Update Link to comment Share on other sites More sharing options...
Moderators Andavari Posted February 14, 2019 Moderators Share Posted February 14, 2019 You shouldn't take it personal in my opinion, yes nobody likes seeing cleaners they've took the time to make get removed or reduced in "effectiveness." but with that stated what's in winapp2.ini should be safe for the whole community instead of possibly causing an issue that not everyone will have the expertise to repair. That's why whenever I submit a cleaner I've made that's too aggressive for the community (mostly in the past with some Firefox cleaners) and would make someone furious and that would get rejected for submission or later removed I just neuter it from the get-go and then submit a safe version of it. It's another reason to sit on a cleaner we make instead of getting in a hurry to submit something without testing it more thoroughly, especially if it involves cleaning something built into Windows we may not know the full effect of. Link to comment Share on other sites More sharing options...
SMalik Posted February 14, 2019 Share Posted February 14, 2019 Revised Entry Added: FileKey2 [Adobe Reader DC *] LangSecRef=3021 Detect=HKLM\Software\Adobe\Acrobat Reader\DC Default=False FileKey1=%LocalAppData%\Adobe\Acrobat\DC|UserCache.bin FileKey2=%AppData%\Adobe\Acrobat\DC\Security\CRLCache|*.*|RECURSE RegKey1=HKCU\Software\Adobe\Acrobat Reader\DC\AVConversionFromPDF RegKey2=HKCU\Software\Adobe\Acrobat Reader\DC\AVConversionToPDF RegKey3=HKCU\Software\Adobe\Acrobat Reader\DC\AVGeneral\cDockables RegKey4=HKCU\Software\Adobe\Acrobat Reader\DC\AVGeneral\cRecentToolsList RegKey5=HKCU\Software\Adobe\Acrobat Reader\DC\AVGeneral\cToolbars RegKey6=HKCU\Software\Adobe\Acrobat Reader\DC\RememberedViews\cNoCategoryFiles RegKey7=HKCU\Software\Adobe\Acrobat Reader\DC\ShareIdentity RegKey8=HKCU\Software\Adobe\Adobe Synchronizer\DC Link to comment Share on other sites More sharing options...
SMalik Posted February 15, 2019 Share Posted February 15, 2019 4 hours ago, Andavari said: You shouldn't take it personal in my opinion, yes nobody likes seeing cleaners they've took the time to make get removed or reduced in "effectiveness." but with that stated what's in winapp2.ini should be safe for the whole community instead of possibly causing an issue that not everyone will have the expertise to repair. That's why whenever I submit a cleaner I've made that's too aggressive for the community (mostly in the past with some Firefox cleaners) and would make someone furious and that would get rejected for submission or later removed I just neuter it from the get-go and then submit a safe version of it. It's another reason to sit on a cleaner we make instead of getting in a hurry to submit something without testing it more thoroughly, especially if it involves cleaning something built into Windows we may not know the full effect of. I’m not taking it personally, but it’s hard work. Some people here make smaller things seem much bigger, without understanding the context behind it. All known privacy cleaner programs wipe these traces in Windows Search. These traces can hold all search related things, which is a privacy concern. Link to comment Share on other sites More sharing options...
APMichael Posted February 15, 2019 Share Posted February 15, 2019 14 hours ago, SMalik said: @APMichael Like I said before, CCleaner can't wipe some of the traces in the entries listed below successfully because some of the traces are locked by Windows or programs similar to MS Search. Let's remove all of these. ... No, why should we? You obviously did not read what siliconman01 and I wrote: If the current entry is used without "Windows Safe Mode", it BREAKS the "Windows Search". And that is the big difference to the entries you mentioned! Because the other entries do not break anything! The reason why we will remove the FileKeys is not that CCleaner cannot delete these files or that "Windows Safe Mode" is needed for a complete cleaning, they are removed because they BREAK a function. When an entry or key breaks a function, it is removed, that was always the policy. So please calm down and do not take such things personally. By the way, there were many entries that were removed only on your request, while other people still liked the entries... 10 hours ago, SMalik said: I’m not taking it personally, but it’s hard work. Some people here make smaller things seem much bigger, without understanding the context behind it. All known privacy cleaner programs wipe these traces in Windows Search. These traces can hold all search related things, which is a privacy concern. Right, the rest of us are not working hard at it at all. Thank you so much for your appreciation. As long as CCleaner is not able to remove locked files, a few entries will not work as in other cleaner programs that have this ability. Therefore, CCleaner cannot be fully compared with these programs. Yes, it may be a privacy concern in this case, but with the limited functions of a Winapp2.ini respectively CCleaner it is not possible to make a safe/harmless entry. But people who are more familiar with Winapp2.ini can still easily add their own entries. (Thanks to Winapp2ool this is now very easy.) And these people will also know how to use "Windows Safe Mode" for some of the entries. Link to comment Share on other sites More sharing options...
APMichael Posted February 15, 2019 Share Posted February 15, 2019 Thank you very much for all your replies and entries. Winapp2.ini update:https://github.com/MoscaDotTo/Winapp2/commit/26cd94044d952b62d0782a06c86eaf6f6d22eeb2 Link to comment Share on other sites More sharing options...
SMalik Posted February 15, 2019 Share Posted February 15, 2019 7 hours ago, APMichael said: No, why should we? You obviously did not read what siliconman01 and I wrote: If the current entry is used without "Windows Safe Mode", it BREAKS the "Windows Search". And that is the big difference to the entries you mentioned! Because the other entries do not break anything! The reason why we will remove the FileKeys is not that CCleaner cannot delete these files or that "Windows Safe Mode" is needed for a complete cleaning, they are removed because they BREAK a function. When an entry or key breaks a function, it is removed, that was always the policy. So please calm down and do not take such things personally. By the way, there were many entries that were removed only on your request, while other people still liked the entries... Why not? I already mentioned that some of the traces in those entries are locked and cannot be wiped. Not all programs leave error logs in Event Viewer. Link to comment Share on other sites More sharing options...
siliconman01 Posted February 16, 2019 Share Posted February 16, 2019 Modified entry: [Ookla Speed Test *] Added: FileKey3=%LocalAppData%\Packages\Ookla.SpeedtestbyOokla_*\AC\Nvidia Corporation\NV_Cache|*.* [Ookla Speed Test *] LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Ookla.SpeedtestbyOokla_43tkc6nmykmb6 DetectFile=%LocalAppData%\Packages\Ookla.SpeedtestbyOokla_43tkc6nmykmb6 Default=False FileKey1=%LocalAppData%\Packages\Ookla.SpeedtestbyOokla_*\AC\INet*|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Ookla.SpeedtestbyOokla_*\AC\Microsoft\CryptnetUrlCache\*|*.* FileKey3=%LocalAppData%\Packages\Ookla.SpeedtestbyOokla_*\AC\Nvidia Corporation\NV_Cache|*.* FileKey4=%LocalAppData%\Packages\Ookla.SpeedtestbyOokla_*\AC\Temp|*.* FileKey5=%LocalAppData%\Packages\Ookla.SpeedtestbyOokla_*\LocalState|*.tmp|RECURSE FileKey6=%LocalAppData%\Packages\Ookla.SpeedtestbyOokla_*\LocalState\Unity\Local.*\Analytics\ArchivedEvents\*|*.*|REMOVESELF FileKey7=%LocalAppData%\Packages\Ookla.SpeedtestbyOokla_*\TempState|*.*|RECURSE Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
siliconman01 Posted February 16, 2019 Share Posted February 16, 2019 New entries: [Canon Inkjet Print Utility *] [Text Input *] [Windows Defender Security Health *] [Canon Inkjet Print Utility *] LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\34791E63.CanonInkjetPrintUtility_6e5tt8cgb93ep Default=False FileKey1=%LocalAppData%\Packages\34791E63.CanonInkjetPrintUtility_*\AC\INet*|*.*|RECURSE FileKey2=%LocalAppData%\Packages\34791E63.CanonInkjetPrintUtility_*\AC\Microsoft\CLR_v4.0_32\UsageLogs|*.* FileKey3=%LocalAppData%\Packages\34791E63.CanonInkjetPrintUtility_*\AC\Nvidia Corporation\NV_Cache|*.* FileKey4=%LocalAppData%\Packages\34791E63.CanonInkjetPrintUtility_*\AC\Temp|*.* FileKey5=%LocalAppData%\Packages\34791E63.CanonInkjetPrintUtility_*\TempState|*.*|RECURSE [Text Input *] DetectOS=10.0| LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\InputApp_cw5n1h2txyewy DetectFile=%UserProfile%\LocalAppData\Packages\InputApp_cw5n1h2txyewy Default=False FileKey1=%LocalAppData%\Packages\InputApp_*\AC\INet*|*.*|RECURSE FileKey2=%LocalAppData%\Packages\InputApp_*\AC\NVIDIA Corporation\NV_Cache|*.* FileKey3=%LocalAppData%\Packages\InputApp_*\AC\Temp|*.*|RECURSE FileKey4=%LocalAppData%\Packages\InputApp_*\LocalCache|*.*|RECURSE FileKey5=%LocalAppData%\Packages\InputApp_*\TempState|*.*|RECURSE [Windows Defender Security Health *] DetectOS=10.0| LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Windows.SecHealthUI_cw5n1h2txyewy Default=False FileKey1=%LocalAppData%\Packages\Microsoft.Windows.SecHealthUI_*\AC\INet*|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.Windows.SecHealthUI_*\AC\NVIDIA Corporation\NV_Cache|*.* FileKey3=%LocalAppData%\Packages\Microsoft.Windows.SecHealthUI_*\AC\Temp|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.Windows.SecHealthUI_*\LocalCache|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.Windows.SecHealthUI_*\TempState|*.*|RECURSE Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
siliconman01 Posted February 16, 2019 Share Posted February 16, 2019 Multiple modified entries: Changed the name of [Weather *] to [Bing Weather *] because there are many weather apps in Store. In all the modified apps I included clearing out the NV_Cache for systems with NVIDIA GPUs. Example below FileKey5=%LocalAppData%\Packages\Microsoft.Windows.CloudExperienceHost_*\AC\NVIDIA Corporation\NV_Cache|*.* [Netflix *] LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\4DF9E0F8.Netflix_mcm4njqhnhss8 DetectFile=%LocalAppData%\Packages\4DF9E0F8.Netflix_mcm4njqhnhss8 Default=False FileKey1=%LocalAppData%\Packages\4DF9E0F8.Netflix_*\AC\INet*|*.*|RECURSE FileKey2=%LocalAppData%\Packages\4DF9E0F8.Netflix_*\AC\Microsoft\CLR_v4.0\UsageLogs|*.*|RECURSE FileKey3=%LocalAppData%\Packages\4DF9E0F8.Netflix_*\AC\Microsoft\CryptnetUrlCache\*|*.* FileKey4=%LocalAppData%\Packages\4DF9E0F8.Netflix_*\AC\Nvidia Corporation\NV_Cache|*.* FileKey5=%LocalAppData%\Packages\4DF9E0F8.Netflix_*\AC\PRICache|*.* FileKey6=%LocalAppData%\Packages\4DF9E0F8.Netflix_*\AC\Temp|*.* FileKey7=%LocalAppData%\Packages\4DF9E0F8.Netflix_*\AppData\Indexed DB|*.log FileKey8=%LocalAppData%\Packages\4DF9E0F8.Netflix_*\LocalState|*.tmp|RECURSE FileKey9=%LocalAppData%\Packages\4DF9E0F8.Netflix_*\LocalState\LiveTile|*.* FileKey10=%LocalAppData%\Packages\4DF9E0F8.Netflix_*\TempState|*.*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\4DF9E0F8.Netflix_mcm4njqhnhss8\SearchHistory [Get Help *] DetectOS=10.0| LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.GetHelp_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.GetHelp_*\AC\AppCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.GetHelp_*\AC\INet*|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.GetHelp_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.GetHelp_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.GetHelp_*\AC\Nvidia Corporation\NV_Cache|*.* FileKey6=%LocalAppData%\Packages\Microsoft.GetHelp_*\AC\Temp|*.*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.GetHelp_*\AC\TokenBroker\Cache|*.*|RECURSE FileKey8=%LocalAppData%\Packages\Microsoft.GetHelp_*\LocalCache|*.*|RECURSE FileKey9=%LocalAppData%\Packages\Microsoft.GetHelp_*\LocalState\Cache|*.*|RECURSE FileKey10=%LocalAppData%\Packages\Microsoft.GetHelp_*\TempState|*.*|RECURSE [Snip & Sketch *] DetectOS=10.0| LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.ScreenSketch_8wekyb3d8bbwe DetectFile=%LocalAppData%\Packages\Microsoft.ScreenSketch_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.ScreenSketch_*\AC\INet*|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.ScreenSketch_*\AC\NVIDIA Corporation\NV_Cache|*.* FileKey3=%LocalAppData%\Packages\Microsoft.ScreenSketch_*\AC\Temp|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.ScreenSketch_*\LocalCache|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.ScreenSketch_*\LocalState\Cache|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.ScreenSketch_*\TempState|*.*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.ScreenSketch_8wekyb3d8bbwe\PersistedPickerData\Microsoft.ScreenSketch_8wekyb3d8bbwe!App\AppSnipAndSketchFileSaveSettings|LastLocation RegKey2=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.ScreenSketch_8wekyb3d8bbwe\PersistedPickerData\Microsoft.ScreenSketch_8wekyb3d8bbwe!App\DefaultOpenFileSingle|LastLocation [Maps *] DetectOS=10.0| LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.WindowsMaps_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.WindowsMaps_*\AC\AppCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.WindowsMaps_*\AC\INet*|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.WindowsMaps_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.WindowsMaps_*\AC\NVIDIA Corporation\NV_Cache|*.* FileKey5=%LocalAppData%\Packages\Microsoft.WindowsMaps_*\AC\Temp|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.WindowsMaps_*\AC\TokenBroker\Cache|*.*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.WindowsMaps_*\LocalCache|*.*|RECURSE FileKey8=%LocalAppData%\Packages\Microsoft.WindowsMaps_*\LocalState\Cache|*.*|RECURSE FileKey9=%LocalAppData%\Packages\Microsoft.WindowsMaps_*\TempState|*.*|RECURSE [OneNote *] LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Office.OneNote_8wekyb3d8bbwe DetectFile=%LocalAppData%\Packages\Microsoft.Office.OneNote_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.Office.OneNote_*\AC\INet*|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.Office.OneNote_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.Office.OneNote_*\AC\NVIDIA Corporation\NV_Cache|*.* FileKey4=%LocalAppData%\Packages\Microsoft.Office.OneNote_*\AC\Temp|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.Office.OneNote_*\AC\TokenBroker\Cache|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.Office.OneNote_*\LocalState\AppData\Local|msodata*.dat FileKey7=%LocalAppData%\Packages\Microsoft.Office.OneNote_*\LocalState\AppData\Local\Office\16.0\WebServiceCache\AllUsers\office*client.microsoft.com|*.*|RECURSE FileKey8=%LocalAppData%\Packages\Microsoft.Office.OneNote_*\LocalState\AppData\Local\Office\OTele|*.*|RECURSE FileKey9=%LocalAppData%\Packages\Microsoft.Office.OneNote_*\LocalState\AppData\Local\OneNote\16.0|*.onecache FileKey10=%LocalAppData%\Packages\Microsoft.Office.OneNote_*\LocalState\AppData\Local\OneNote\16.0\OneNote*Cache_Files|*.*|RECURSE FileKey11=%LocalAppData%\Packages\Microsoft.Office.OneNote_*\TempState|*.*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Office.OneNote_8wekyb3d8bbwe\SearchHistory [Feedback Hub *] DetectOS=10.0| LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.WindowsFeedbackHub_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.WindowsFeedbackHub_*\AC\INet*|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.WindowsFeedbackHub_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.WindowsFeedbackHub_*\AC\NVIDIA Corporation\NV_Cache|*.* FileKey4=%LocalAppData%\Packages\Microsoft.WindowsFeedbackHub_*\AC\Temp|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.WindowsFeedbackHub_*\LocalCache|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.WindowsFeedbackHub_*\LocalState\DiagOutputDir|*.txt FileKey7=%LocalAppData%\Packages\Microsoft.WindowsFeedbackHub_*\TempState|*.*|RECURSE [Accounts Control *] DetectOS=10.0| LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.AccountsControl_cw5n1h2txyewy Default=False FileKey1=%LocalAppData%\Packages\Microsoft.AccountsControl_*\AC\AppCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.AccountsControl_*\AC\INet*|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.AccountsControl_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.AccountsControl_*\AC\NVIDIA Corporation\NV_Cache|*.* FileKey5=%LocalAppData%\Packages\Microsoft.AccountsControl_*\AC\Temp|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.AccountsControl_*\AC\TokenBroker\Cache|*.*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.AccountsControl_*\LocalCache|*.*|RECURSE FileKey8=%LocalAppData%\Packages\Microsoft.AccountsControl_*\LocalState\Cache|*.*|RECURSE FileKey9=%LocalAppData%\Packages\Microsoft.AccountsControl_*\TempState|*.*|RECURSE [YourPhone *] DetectOS=10.0| LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.YourPhone_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.YourPhone_*\AC\INet*|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.YourPhone_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.YourPhone_*\AC\NVIDIA Corporation\NV_Cache|*.* FileKey4=%LocalAppData%\Packages\Microsoft.YourPhone_*\AC\Temp|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.YourPhone_*\LocalCache|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.YourPhone_*\LocalState\Cache|*.*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.YourPhone_*\TempState|*.*|RECURSE [Bing Weather *] LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.BingWeather_8wekyb3d8bbwe DetectFile=%LocalAppData%\Packages\Microsoft.BingWeather_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.BingWeather_*\AC\AppCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.BingWeather_*\AC\INet*|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.BingWeather_*\AC\Microsoft\CLR_v4.0|*.log FileKey4=%LocalAppData%\Packages\Microsoft.BingWeather_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.BingWeather_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.BingWeather_*\AC\NVIDIA Corporation\NV_Cache|*.* FileKey7=%LocalAppData%\Packages\Microsoft.BingWeather_*\AC\PRICache|*.*|RECURSE FileKey8=%LocalAppData%\Packages\Microsoft.BingWeather_*\AC\Temp|*.*|RECURSE FileKey9=%LocalAppData%\Packages\Microsoft.BingWeather_*\AC\TokenBroker\Cache|*.*|RECURSE FileKey10=%LocalAppData%\Packages\Microsoft.BingWeather_*\LocalState|*.tmp FileKey11=%LocalAppData%\Packages\Microsoft.BingWeather_*\LocalState\Cache|*.*|RECURSE FileKey12=%LocalAppData%\Packages\Microsoft.BingWeather_*\LocalState\navigationHistory|*.*|RECURSE FileKey13=%LocalAppData%\Packages\Microsoft.BingWeather_*\TempState|*.*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.BingWeather_8wekyb3d8bbwe\SearchHistory [Cloud Experience Host *] DetectOS=10.0| LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Windows.CloudExperienceHost_cw5n1h2txyewy Default=False FileKey1=%LocalAppData%\Packages\Microsoft.Windows.CloudExperienceHost_*\AC\AppCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.Windows.CloudExperienceHost_*\AC\INet*|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.Windows.CloudExperienceHost_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.Windows.CloudExperienceHost_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.Windows.CloudExperienceHost_*\AC\NVIDIA Corporation\NV_Cache|*.* FileKey6=%LocalAppData%\Packages\Microsoft.Windows.CloudExperienceHost_*\AC\Temp|*.*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.Windows.CloudExperienceHost_*\LocalCache|*.*|RECURSE FileKey8=%LocalAppData%\Packages\Microsoft.Windows.CloudExperienceHost_*\LocalState\Cache|*.*|RECURSE FileKey9=%LocalAppData%\Packages\Microsoft.Windows.CloudExperienceHost_*\TempState|*.*|RECURSE [Stocks and Futures *] LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\24877CutthroatSoftware.StocksandFutures_xgnzh3xnefnqe Default=False FileKey1=%LocalAppData%\Packages\24877CutthroatSoftware.StocksandFutures_*\AC\INet*|*.*|RECURSE FileKey2=%LocalAppData%\Packages\24877CutthroatSoftware.StocksandFutures_*\AC\Microsoft\CryptnetUrlCache\*|*.* FileKey3=%LocalAppData%\Packages\24877CutthroatSoftware.StocksandFutures_*\AC\NVIDIA Corporation\NV_Cache|*.* FileKey4=%LocalAppData%\Packages\24877CutthroatSoftware.StocksandFutures_*\AC\Temp|*.* FileKey5=%LocalAppData%\Packages\24877CutthroatSoftware.StocksandFutures_*\AppData\Indexed DB|*.log FileKey6=%LocalAppData%\Packages\24877CutthroatSoftware.StocksandFutures_*\LocalState|*.tmp|RECURSE FileKey7=%LocalAppData%\Packages\24877CutthroatSoftware.StocksandFutures_*\TempState|*.*|RECURSE Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
siliconman01 Posted February 16, 2019 Share Posted February 16, 2019 More modified entries to Clean NV_Cache [Movies & TV *] LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.ZuneVideo_8wekyb3d8bbwe DetectFile=%LocalAppData%\Packages\Microsoft.ZuneVideo_8wekyb3d8bbwe* Default=False FileKey1=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\AC\AppCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\AC\INet*|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\AC\Microsoft\CLR_v4.0\UsageLogs|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\AC\NVIDIA Corporation\NV_Cache|*.* FileKey7=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\AC\PRICache|*.*|RECURSE FileKey8=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\AC\Temp|*.*|RECURSE FileKey9=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\AC\TokenBroker\Cache|*.*|RECURSE FileKey10=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\LocalCache\PlayReady|*.*|RECURSE FileKey11=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\LocalState\Database\anonymous|*.log FileKey12=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\LocalState\ImageCache|*.*|RECURSE FileKey13=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\LocalState\ImageRetrievalFailure|*.*|RECURSE FileKey14=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\LocalState\ImageStore|*.*|RECURSE FileKey15=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\LocalState\navigationHistory|*.*|RECURSE FileKey16=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\LocalState\PlayReady|*.*|RECURSE FileKey17=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\TempState|*.*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.ZuneVideo_8wekyb3d8bbwe\SearchHistory\SearchHistory [Dell SupportAssist *] LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\DellInc.DellSupportAssistforPCs_htrsf667h5kn2 Default=False FileKey1=%LocalAppData%\Packages\DellInc.DellSupportAssistforPCs_*\AC\AppCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\DellInc.DellSupportAssistforPCs_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey3=%LocalAppData%\Packages\DellInc.DellSupportAssistforPCs_*\AC\NVIDIA Corporation\NV_Cache|*.* FileKey4=%LocalAppData%\Packages\DellInc.DellSupportAssistforPCs_*\AC\Temp|*.*|RECURSE FileKey5=%LocalAppData%\Packages\DellInc.DellSupportAssistforPCs_*\LocalCache\Local\Microsoft\CLR_v4.0_32\UsageLogs|*.log FileKey6=%LocalAppData%\Packages\DellInc.DellSupportAssistforPCs_*\LocalCache\Local\Microsoft\Windows\Caches|*.*|RECURSE FileKey7=%LocalAppData%\Packages\DellInc.DellSupportAssistforPCs_*\TempState|*.*|RECURSE [Lock App *] DetectOS=10.0| LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.LockApp_cw5n1h2txyewy Default=False FileKey1=%LocalAppData%\Packages\Microsoft.LockApp_*\AC\AppCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.LockApp_*\AC\INet*|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.LockApp_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.LockApp_*\AC\NVIDIA Corporation\NV_Cache|*.* FileKey5=%LocalAppData%\Packages\Microsoft.LockApp_*\AC\Temp|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.LockApp_*\AC\TokenBroker\Cache|*.*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.LockApp_*\LocalCache|*.*|RECURSE FileKey8=%LocalAppData%\Packages\Microsoft.LockApp_*\LocalState\Cache|*.*|RECURSE FileKey9=%LocalAppData%\Packages\Microsoft.LockApp_*\TempState|*.*|RECURSE [Alarms *] DetectOS=10.0| LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.WindowsAlarms_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.WindowsAlarms_*\AC\INet*|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.WindowsAlarms_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey3=%LocalAppData%\Packages\Microsoft.WindowsAlarms_*\AC\NVIDIA Corporation\NV_Cache|*.* FileKey4=%LocalAppData%\Packages\Microsoft.WindowsAlarms_*\AC\Temp|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.WindowsAlarms_*\LocalCache|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.WindowsAlarms_*\LocalState\Cache|*.*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.WindowsAlarms_*\TempState|*.*|RECURSE Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
siliconman01 Posted February 16, 2019 Share Posted February 16, 2019 New entries: [Dell Digital Delivery *] [Start Menu Experience Host *] [Dell Digital Delivery *] LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\DellInc.DellDigitalDelivery_htrsf667h5kn2 Default=False FileKey1=%LocalAppData%\Packages\DellInc.DellDigitalDelivery_*\AC\INet*|*.*|RECURSE FileKey2=%LocalAppData%\Packages\DellInc.DellDigitalDelivery_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey3=%LocalAppData%\Packages\DellInc.DellDigitalDelivery_*\AC\NVIDIA Corporation\NV_Cache|*.* FileKey4=%LocalAppData%\Packages\DellInc.DellDigitalDelivery_*\AC\Temp|*.*|RECURSE FileKey5=%LocalAppData%\Packages\DellInc.DellDigitalDelivery_*\LocalState\serilog|*.txt FileKey6=%LocalAppData%\Packages\DellInc.DellDigitalDelivery_*\TempState|*.*|RECURSE [Start Menu Experience Host *] DetectOS=10.0| LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Windows.StartMenuExperienceHost_cw5n1h2txyewy Default=False FileKey1=%LocalAppData%\Packages\Microsoft.Windows.StartMenuExperienceHost_*\AC\INet*|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.Windows.StartMenuExperienceHost_*\AC\NVIDIA Corporation\NV_Cache|*.* FileKey3=%LocalAppData%\Packages\Microsoft.Windows.StartMenuExperienceHost_*\AC\Temp|*.*|RECURSE Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
siliconman01 Posted February 16, 2019 Share Posted February 16, 2019 And finally (for now) more modified apps to clear NV_Cache [Dell Customer Connect *] LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\DellInc.DellCustomerConnect_htrsf667h5kn2 Default=False FileKey1=%LocalAppData%\Packages\DellInc.DellCustomerConnect_*\AC\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey2=%LocalAppData%\Packages\DellInc.DellCustomerConnect_*\AC\NVIDIA Corporation\NV_Cache|*.* FileKey3=%LocalAppData%\Packages\DellInc.DellCustomerConnect_*\AC\Temp|*.*|RECURSE FileKey4=%LocalAppData%\Packages\DellInc.DellCustomerConnect_*\LocalCache\Local\Microsoft\CLR_v4.0_32\UsageLogs|*.log FileKey5=%LocalAppData%\Packages\DellInc.DellCustomerConnect_*\LocalState\serilog|*.txt FileKey6=%LocalAppData%\Packages\DellInc.DellCustomerConnect_*\TempState|*.*|RECURSE [Dell Help & Support *] LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\DellInc.DellHelpSupport_htrsf667h5kn2 Default=False FileKey1=%LocalAppData%\Packages\DellInc.DellHelpSupport_*\AC\NVIDIA Corporation\NV_Cache|*.* FileKey2=%LocalAppData%\Packages\DellInc.DellHelpSupport_*\AC\Temp|*.*|RECURSE FileKey3=%LocalAppData%\Packages\DellInc.DellHelpSupport_*\LocalCache\Local\Dell\DHSC\Logs|*.log FileKey4=%LocalAppData%\Packages\DellInc.DellHelpSupport_*\LocalCache\Local\Microsoft\CLR_v4.0\UsageLogs|*.log FileKey5=%LocalAppData%\Packages\DellInc.DellHelpSupport_*\TempState|*.*|RECURSE [Dell Mobile Connect *] LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\ScreenovateTechnologies.DellMobileConnect_0vhbc3ng4wbp0 Default=False FileKey1=%LocalAppData%\Packages\ScreenovateTechnologies.DellMobileConnect_*\AC\INet*|*.*|RECURSE FileKey2=%LocalAppData%\Packages\ScreenovateTechnologies.DellMobileConnect_*\AC\NVIDIA Corporation\NV_Cache|*.* FileKey3=%LocalAppData%\Packages\ScreenovateTechnologies.DellMobileConnect_*\AC\Temp|*.*|RECURSE FileKey4=%LocalAppData%\Packages\ScreenovateTechnologies.DellMobileConnect_*\LocalCache\Local\Dell\DellMobileConnect|*.log FileKey5=%LocalAppData%\Packages\ScreenovateTechnologies.DellMobileConnect_*\LocalCache\Local\Microsoft\CLR_v4.0\UsageLogs|*.log FileKey6=%LocalAppData%\Packages\ScreenovateTechnologies.DellMobileConnect_*\LocalCache\LocalLow\Microsoft\CryptnetURLCache\*|*.*|RECURSE FileKey7=%LocalAppData%\Packages\ScreenovateTechnologies.DellMobileConnect_*\TempState|*.*|RECURSE [Dell Power Manager *] LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\DellInc.DellPowerManager_htrsf667h5kn2 Default=False FileKey1=%LocalAppData%\Packages\DellInc.DellPowerManager_*\AC\NVIDIA Corporation\NV_Cache|*.* FileKey2=%LocalAppData%\Packages\DellInc.DellPowerManager_*\AC\Temp|*.*|RECURSE FileKey3=%LocalAppData%\Packages\DellInc.DellPowerManager_*\LocalCache\Local\Microsoft\CLR_v4.0\UsageLogs|*.log FileKey4=%LocalAppData%\Packages\DellInc.DellPowerManager_*\TempState|*.*|RECURSE [Dell PremierColor *] LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\PortraitDisplays.DellPremierColor_2dgmkzkw4h30c Default=False FileKey1=%LocalAppData%\Packages\PortraitDisplays.DellPremierColor_*\AC\NVIDIA Corporation\NV_Cache|*.* FileKey2=%LocalAppData%\Packages\PortraitDisplays.DellPremierColor_*\AC\Temp|*.*|RECURSE FileKey3=%LocalAppData%\Packages\PortraitDisplays.DellPremierColor_*\LocalCache\Local\Microsoft\Windows\Caches|*.db FileKey4=%LocalAppData%\Packages\PortraitDisplays.DellPremierColor_*\TempState|*.*|RECURSE [Dell Product Registration *] LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\DellInc.DellProductRegistration_htrsf667h5kn2 Default=False FileKey1=%LocalAppData%\Packages\DellInc.DellProductRegistration_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey2=%LocalAppData%\Packages\DellInc.DellProductRegistration_*\AC\NVIDIA Corporation\NV_Cache|*.* FileKey3=%LocalAppData%\Packages\DellInc.DellProductRegistration_*\AC\Temp|*.*|RECURSE FileKey4=%LocalAppData%\Packages\DellInc.DellProductRegistration_*\LocalCache\Local\Dell\Product Registration\UILog|*.htm FileKey5=%LocalAppData%\Packages\DellInc.DellProductRegistration_*\LocalCache\Local\Microsoft\CLR_v4.0\UsageLogs|*.log FileKey6=%LocalAppData%\Packages\DellInc.DellProductRegistration_*\LocalCache\LocalLow\Microsoft\CryptnetUrlCache\*|*.*|RECURSE FileKey7=%LocalAppData%\Packages\DellInc.DellProductRegistration_*\TempState|*.*|RECURSE [Dell UpDate *] LangSecRef=3031 Detect=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\DellInc.DellUpdate_htrsf667h5kn2 Default=False FileKey1=%LocalAppData%\Packages\DellInc.DellUpdate_*\AC\NVIDIA Corporation\NV_Cache|*.* FileKey2=%LocalAppData%\Packages\DellInc.DellUpdate_*\AC\Temp|*.*|RECURSE FileKey3=%LocalAppData%\Packages\DellInc.DellUpdate_*\LocalCache\Local\Microsoft\CLR_v4.0\UsageLogs|*.log FileKey4=%LocalAppData%\Packages\DellInc.DellUpdate_*\LocalCache\Local\Microsoft\Windows\Caches|*.* FileKey5=%LocalAppData%\Packages\DellInc.DellUpdate_*\TempState|*.*|RECURSE [Nvidia *] Added FileKey13=%LocalAppData%\NVIDIA Corporation\NV_Cache|*.* [NVIDIA *] LangSecRef=3024 Detect=HKLM\Software\NVIDIA Corporation Default=False FileKey1=%AppData%\NVIDIA\*Cache|*.*|RECURSE FileKey2=%CommonAppData%\NVIDIA|*.log;*.log_backup1;Resource.old;*.bak|RECURSE FileKey3=%CommonAppData%\NVIDIA Corporation|*.log;*bak;*log.*;*.old;*.stat|RECURSE FileKey4=%CommonAppData%\NVIDIA Corporation\Downloader|*.*|RECURSE FileKey5=%CommonAppData%\NVIDIA Corporation\GeForce Experience\Update|*.*|RECURSE FileKey6=%CommonAppData%\NVIDIA Corporation\NV_Cache|*.* FileKey7=%CommonAppData%\NVIDIA Corporation\NvFBCPlugin|log*.txt FileKey8=%CommonAppData%\NVIDIA\NvBackend\Updatus\DownloadManager|*.* FileKey9=%CommonAppData%\NVIDIA\Updatus\DownloadManager|*.* FileKey10=%LocalAppData%\NVIDIA Corporation|*.log;*.bak;*.old|RECURSE FileKey11=%LocalAppData%\NVIDIA Corporation\*\CefCache|Cookies;Cookies-journal;QuotaManager;QuotaManager-journal FileKey12=%LocalAppData%\NVIDIA Corporation\*\CefCache\*Cache|*.*|RECURSE FileKey13=%LocalAppData%\NVIDIA Corporation\NV_Cache|*.* FileKey14=%LocalAppData%\NVIDIA\NvBackend|*.log;*.bak FileKey15=%ProgramFiles%\NVIDIA Corporation\NetworkAccessManager\Apache Group\Apache2\logs|*.* FileKey16=%SystemDrive%\NvidiaLogging\GFExperience|GridClientLog.log*|RECURSE Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted February 16, 2019 Moderators Share Posted February 16, 2019 Misspelled entry in winapp2.ini:[Geek Unistaller *] LangSecRef=3024 Detect=HKCU\Software\Geek Uninstaller Default=False FileKey1=%AppData%\Geek Uninstaller|*.log;*cache.dat Correction:[Geek Uninstaller *] LangSecRef=3024 Detect=HKCU\Software\Geek Uninstaller Default=False FileKey1=%AppData%\Geek Uninstaller|*.log;*cache.dat Link to comment Share on other sites More sharing options...
