Winapp2.ini additions
Winapp2.ini
Here is an entry that I use. It wipes locally stored user names and passwords. I think we should add it, maybe with a warning.
[Credentials *]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows
Default=False
FileKey1=%LocalAppData%\Microsoft\Credentials|*.*|RECURSE
FileKey2=%AppData%\Microsoft\Credentials|*.*|RECURSE
FileKey3=%WinDir%\ServiceProfiles\LocalService\AppData\Local\Microsoft\Credentials|*.*|RECURSE
FileKey4=%WinDir%\ServiceProfiles\NetworkService\AppData\Local\Microsoft\Credentials|*.*|RECURSE
Link to comment
[Credentials *]
LangSecRef=3025
Default=False
What is the impact of deleting the files above?  Sounds a bit risky to me.   Winapp3.ini ??
Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System);  Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC.  ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system):   Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI Burner, Rainmeter, Windows Sidebar, and many more.
Link to comment
User names and passwords that you log on to websites or other computers on a network.
It is completely safe.
Link to comment
  • Moderators
I think, but am unsure, that this removal may cause havok for people who use a microsoft login for windows 10
Link to comment
I fear that people will already be angry that "we" have deleted their credentials for their NAS share. (That's why I don't understand why CCleaner also has built-in entries for passwords. IMHO passwords are not crap.)
Link to comment
Revised Entry
I think we should change the Detect from HKLM\Software\Microsoft\Windows\CurrentVersion\Explorer\WindowsUpdate to HKCU\Software\Microsoft\Windows
[Windows Update *]
LangSecRef=3025
Default=False
FileKey1=%WinDir%\Logs\waasmedic|*.*|RECURSE
FileKey2=%WinDir%\Logs\WindowsUpdate|*.*|RECURSE
FileKey3=%WinDir%\SoftwareDistribution\DataStore\Logs|*.*|RECURSE
Link to comment
Let's bring this entry back.
The Security Token Service provides brokered authentication for web services. Previously there was an issue when removing Token Broker Cache files on a Windows Insider Preview build. It was removing Windows Insider account login info. The issue was fixed in the later insider preview build.
[Security Service Token Cache *]
LangSecRef=3025
Default=False
FileKey1=%LocalAppData%\Microsoft\TokenBroker\Cache|*.*|RECURSE
Link to comment
New Entry
System should be restarted after wiping these caches.
Works well in Windows Safe Mode.
[Windows Start Cache *]
DetectOS=10.0|
LangSecRef=3025
Default=False
FileKey1=%LocalAppData%\Microsoft\Windows\Caches|*.*|RECURSE
FileKey2=%CommonAppData%\Microsoft\Windows\Caches|*.*|RECURSE
FileKey3=%WinDir%\ServiceProfiles\LocalService\AppData\Local\Microsoft\Windows\Caches|*.*|RECURSE
Link to comment
New Entry
DetectOS=10.0|
LangSecRef=3025
Default=False
Sounds more like a candidate for Winapp3.ini
Link to comment
It is already in the Winapp3.ini: [Windows Search Cache *]. It was removed in 2013 because it crashed explorer.exe in Windows 7/8 and temporarily removed all Metro apps from the Windows 8 start screen.
The revised entry is now only for Windows 10, but since Safe Mode and/or a reboot are required, it would be better if it remains a Winapp3.ini entry.
Link to comment
With all the previous discussion about "Action Center" on Windows 10, it does not seem to be agreed by the global community that "Action Center" is not the correct name.  Perhaps we should rethink the change that was made a few days back, eh?
https://www.bleepingcomputer.com/news/microsoft/microsoft-releases-cumulative-update-kb4476976-to-fix-action-center-issues/
Link to comment
32 minutes ago, siliconman01 said:
With all the previous discussion about "Action Center" on Windows 10, it does not seem to be agreed by the global community that "Action Center" is not the correct name.  Perhaps we should rethink the change that was made a few days back, eh? ...
:lol: Yes, if you right-click on the balloon icon in the lower right corner, the menu should also display "Open action center". But Microsoft also calls it "Notifications and Action Center", so the current entry name [Notifications *] is ok for me.
Link to comment
  • Moderators
Is it considered bad, or taboo to clean things located in (on Win10): C:\ProgramData
Reason I ask is because on my Win10 system I've found two things in my opinion worth cleaning, but when looking in winapp2.ini and searching I see nothing in there that targets in particular: %ProgramData%
Link to comment
No, we clean a lot of files under C:\ProgramData. Search for entries using the variable %CommonAppData% (=C:\ProgramData).
Link to comment
  • Moderators
Thank you, good to know.
New (removes archived disk surface scan logs):
[Acer Care Center *]
LangSecRef=3024
Detect=HKLM\SOFTWARE\OEM\CareCenter
Default=False
FileKey1=%CommonAppData%\Acer\CareCenter\DebugLog\SurfaceCheck|log*.txt
Updated (added FileKey3, which removes a backup duplicate of the downloaded setup .EXE file)
[Samsung Magician *]
LangSecRef=3021
Detect=HKLM\Software\Samsung Magician
Default=False
FileKey1=%LocalAppData%\VirtualStore\Program Files*\Samsung\Samsung Magician|*.log;*.txt|RECURSE
FileKey2=%LocalAppData%\VirtualStore\Program Files*\Samsung\Samsung Magician\Log*|*.*
FileKey3=%CommonAppData%\Samsung\Backup|*.exe
FileKey4=%ProgramFiles%\Samsung Magician\Logs|*.*
FileKey5=%ProgramFiles%\Samsung\Samsung Magician\Log*|*.*
RegKey1=HKCU\Software\Local AppWizard-Generated Applications\SamsungMagician
Link to comment
  • Moderators
New (cleans logs).
[Micron Storage Executive *]
LangSecRef=3024
Detect=HKLM\SOFTWARE\Micron\StorageExecutive
Default=False
FileKey1=%ProgramFiles%\Micron Technology\Micron Storage Executive\logs|*.txt
Edit / Note:
CCleaner is unable to find or clean those text logs if Micron Storage Executive's SSD caching service called Momentum Cache ("Micron Cache Monitor Service") is running at boot to "boost" the SSD speed.
Link to comment
Modified entry:   [Dell Logs *]
Added:  FileKey14=%LocalAppData%\Dell\DellMobileConnect|*.log
[Dell Logs *]
LangSecRef=3024
Detect1=HKLM\Software\Dell\MUP
Detect2=HKLM\Software\Dell\UpdateService
Detect3=HKLM\Software\PC-Doctor
DetectFile1=%AppData%\Creative\DELL Webcam Center
DetectFile2=%CommonAppData%\Dell
DetectFile3=%LocalAppData%\Dell
DetectFile4=%LocalAppData%\SupportSoft\DellSupportCenter
DetectFile5=%ProgramFiles%\Dell*
Default=False
FileKey1=%AppData%\Creative\DELL Webcam Center|MO_Log.txt
FileKey2=%AppData%\PCDr\*\Logs|*.*
FileKey3=%CommonAppData%\Dell\*\Log|*.*
FileKey4=%CommonAppData%\Dell\*\Logs|*.*
FileKey5=%CommonAppData%\Dell\Drivers\*|*.tmp
FileKey6=%CommonAppData%\Dell\Update|*.txt
FileKey7=%CommonAppData%\Dell\UpdateService\Clients\Update|*.log
FileKey8=%CommonAppData%\PCDr\*\Cache|*.xml
FileKey9=%CommonAppData%\PCDr\*\Cache\archives|*.*|RECURSE
FileKey10=%CommonAppData%\PCDr\*\Cache\BUMA|*.*
FileKey11=%CommonAppData%\PCDr\*\Cache\DriverScan|*.*
FileKey12=%CommonAppData%\PCDr\*\Logs|*.log
FileKey13=%LocalAppData%\Dell\*\Log|*.*
FileKey15=%LocalAppData%\SupportSoft\DellSupportCenter\*\state\logs|*.*
FileKey16=%ProgramFiles%\Dell*|*.log|RECURSE
Link to comment
Modified entry:  [AMD/ATI *]
Added:  FileKey7=%ProgramFiles%\AMD\CIM\Log|*.log
[AMD/ATI *]
LangSecRef=3024
Detect1=HKLM\Software\AMD
Detect2=HKLM\Software\ATI
Detect3=HKLM\Software\ATI Technologies
DetectFile=%ProgramFiles%\ATI Technologies\ATI.ACE
Default=False
FileKey1=%CommonAppData%\AMD\Fuel|*.txt
FileKey2=%CommonAppData%\AMD\KDB|*.log
FileKey3=%LocalAppData%\AMD\Fuel|ClientProxyLog*.*
FileKey4=%LocalAppData%\AMD\GLCache|*.*|RECURSE
FileKey5=%LocalAppData%\ATI\ACE|*.txt
FileKey6=%ProgramFiles%\AMD\amdkmpfd|*.*|REMOVESELF
FileKey8=%ProgramFiles%\AMD\OverDrive|*.log
FileKey9=%ProgramFiles%\ATI Technologies|*.log|RECURSE
FileKey10=%ProgramFiles%\ATI Technologies|cccutil64.txt
FileKey11=%ProgramFiles%\ATI\CIM\Reports|*.*
FileKey12=%SystemDrive%\AMD|*.*|REMOVESELF
FileKey13=%SystemDrive%\ATI|*.*|REMOVESELF
FileKey14=%WinDir%\System32|CCCInstall*.log
FileKey15=%WinDir%\SysWOW64|CCCInstall*.log
Link to comment
Register a new account
Sign in
Important Information
