JDPower Posted July 27, 2014 Share Posted July 27, 2014 EDIT: [steam Logs*] Section=Games Detect=HKCU\Software\Valve\Steam FileKey1=%ProgramFiles%\Steam|*.log;*log.last;connection_log_*.txt;*_log.txt;remote_connections.txt;vr*_*.txt|RECURSE FileKey2=%ProgramFiles%\Valve\Steam|Steam.log FileKey3=%ProgramFiles%\Valve\Steam\SteamLogs|*.log FileKey4=%ProgramFiles%\Steam\vr\\runtime\logs|*.*|RECURSE FileKey5=%AppData%\SteamVR\Logs|*.*|REMOVESELF FileKey6=%LocalAppData%\VirtualStore\Program Files*\Steam|*.log;*log.last;connection_log_*.txt;*_log.txt;remote_connections.txt;vr*_*.txt|RECURSE FileKey7=%LocalAppData%\VirtualStore\Program Files*\Valve\Steam|Steam.log FileKey8=%LocalAppData%\VirtualStore\Program Files*\Valve\Steam\SteamLogs|*.log Added FileKey 4. You've got a double backslash in your filekey4 Link to comment Share on other sites More sharing options...
ROCKNROLL Posted July 28, 2014 Share Posted July 28, 2014 Didn't notice that. I fixed it. I am a maintainer for Winapp2. I also have a open-source group on Steam. http://steamcommunity.com/groups/opencommunity Link to comment Share on other sites More sharing options...
siliconman01 Posted July 31, 2014 Share Posted July 31, 2014 Revised Entry: Added FileKey3 to accommodate the latest V6.0 of SUPERAntiSpyware [SUPERAntiSpyware (Logs) More*] LangSecRef=3024 Detect=HKCU\Software\SUPERAntiSpyware.com\SUPERAntiSpyware Default=False FileKey1=%CommonAppData%\!SASCORE\AppLogs|*.dmp;*.SDB FileKey2=%LocalAppData%\VirtualStore\ProgramData\!SASCORE\AppLogs|*.dmp;*.SDB FileKey3=%CommonAppData%\SUPERAntiSpyware.com\SUPERAntiSpyware\Applogs\|*.dmp;*.SDB;*.ZIP Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
SMalik Posted August 1, 2014 Share Posted August 1, 2014 Revised Entry Changed the highlighted from REMOVESELF to RECURSE. I think you should be careful adding entries with REMOVESELF. [Apple MobileSync Backup*]LangSecRef=3023DetectFile=%AppData%\Apple Computer\MobileSync\BackupWarning=This will delete all your iPhone backups.Default=FalseFileKey1=%AppData%\Apple Computer\MobileSync\Backup|*.*|RECURSE Link to comment Share on other sites More sharing options...
Moderators Nergal Posted August 1, 2014 Moderators Share Posted August 1, 2014 I think you should be careful adding entries with REMOVESELF. Agree ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
Moderators Andavari Posted August 1, 2014 Moderators Share Posted August 1, 2014 I think you should be careful adding entries with REMOVESELF. Especially if a software can't "restore self" from a missing directory and gives error dialogs. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 1, 2014 Author Share Posted August 1, 2014 With MobileSync backups, directory names are unique and not reused, so it may be better to prune the empty directories winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Coffee4Joe Posted August 3, 2014 Share Posted August 3, 2014 Added FileKey2= [Hex Chat Logs*] LangSecRef=3024 DetectFile=%AppData%\HexChat Default=False FileKey1=%AppData%\HexChat\logs|*.*|REMOVESELF FileKey2=%AppData%\HexChat\scrollback|*.*|REMOVESELF Link to comment Share on other sites More sharing options...
CSGalloway Posted August 3, 2014 Share Posted August 3, 2014 Need entry for Trend Micro Titanium Internet Security please.... Link to comment Share on other sites More sharing options...
Moderators Nergal Posted August 3, 2014 Moderators Share Posted August 3, 2014 Need entry for Trend Micro Titanium Internet Security please.... Uhhhh can't you give us more to go on? ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
CSGalloway Posted August 4, 2014 Share Posted August 4, 2014 Uhhhh can't you give us more to go on? http://www.trendmicro.com/us/home/products/software/internet-security/ Link to comment Share on other sites More sharing options...
Moderators Nergal Posted August 4, 2014 Moderators Share Posted August 4, 2014 http://www.trendmicro.com/us/home/products/software/internet-security/ no, tell us what needs cleaning in it, give us a registry entry to detect it.Basically ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to comment Share on other sites More sharing options...
siliconman01 Posted August 4, 2014 Share Posted August 4, 2014 Revised Entry: Added FileKey6 for wireless devices [Logitech Setpoint 6 (Logs)*] LangSecRef=3024 Detect=HKCU\Software\Logitech\Setpoint Default=False FileKey1=%AppData%\Logishrd\sp6_Log|*.*|REMOVESELF FileKey2=%WinDir%\System32|lvcoinst.log FileKey3=%CommonAppData%\LogiShrd|*.log|RECURSE FileKey4=%ProgramFiles%\Common Files\logishrd|*.log|RECURSE FileKey5=%LocalAppData%\VirtualStore\Program Files*\Common Files\logishrd|*.log|RECURSE FileKey6=%CommonAppData%\Logitech\KHAL\Battery\|*.log Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
CSGalloway Posted August 5, 2014 Share Posted August 5, 2014 I got an error when uninstalling JDownloader - an EXCLUDE needs to be added for it. the file is at: C:\Program Files (x86)\JDownloader\.install4j\files.log Link to comment Share on other sites More sharing options...
back_track Posted August 5, 2014 Share Posted August 5, 2014 I got an error when uninstalling JDownloader - an EXCLUDE needs to be added for it. the file is at: C:\Program Files (x86)\JDownloader\.install4j\files.log the problem comes from the recurse FileKey1=%ProgramFiles%\JDownloader|*.log;updateLog.txt;*.lck;*.log.*|RECURSE this filekey is only used in jd 1 not in 2 xD But where comes the recurse ? [JDownloader Logs*]LangSecRef=3022Detect=HKLM\Software\JDownloaderDetectFile=%ProgramFiles%\JDownloaderDefault=FalseFileKey1=%ProgramFiles%\JDownloader|*.log;updateLog.txt;*.lck;*.log.*FileKey2=%UserProfile%\.jd_home|JDownloader.logFileKey3=%UserProfile%\.jd_home\logs|*.0FileKey4=%LocalAppData%\VirtualStore\Program Files*\JDownloader|*.log;updateLog.txt;*.lck;*.log.*FileKey5=%ProgramFiles%\JDownloader\logs|*.logFileKey6=%LocalAppData%\VirtualStore\Program Files*\JDownloader\logs|*.log add ;*.log.* and filekey 5&6 also in jd2 entry is the recurses are funny xD. Please also add the execludekey but we have to test the complete files in the path \.install4j .... Link to comment Share on other sites More sharing options...
Hav0c Posted August 7, 2014 Share Posted August 7, 2014 Some entries for TeamSpeak 3, use discretion. [TeamSpeak3 Themes*] LangSecRef=3022 Detect=HKCU\Software\TeamSpeak 3 Client Default=False Warnin=This will set the Theme to System default FileKey1=%LocalAppData%\TeamSpeak 3 Client\styles|*.*|RECURSE ExcludeKey1=FILE|%LocalAppData%\TeamSpeak 3 Client\styles\default* ExcludeKey2=PATH|%LocalAppData%\TeamSpeak 3 Client\styles\default [TeamSpeak3 Icon Packs*] LangSecRef=3022 Detect=HKCU\Software\TeamSpeak 3 Client Default=False Warning=This may cuase your icons to look funny. To correct Options-->Design-->Icon Pack set to default FileKey1=%LocalAppData%\TeamSpeak 3 Client\gfx|*.zip ExcludeKey1=FILE|%LocalAppData%\TeamSpeak 3 Client\gfx\default.zip [TeamSpeak3 News*] LangSecRef=3022 Detect=HKCU\Software\TeamSpeak 3 Client Default=False FileKey1=%LocalAppData%\TeamSpeak 3 Client\news|*.*|RECURSE Know this will not be included in .ini that why standalone ! [TeamSpeak3 (Lng)*] Section=Language Files Detect=HKCU\Software\TeamSpeak 3 Client Default=False Warning=This will delete all language files excluding the Default language. FileKey1=%LocalAppData%\TeamSpeak 3 Client\translations|*.qm Every line of code written by man can be undone by man . "A loser in the real world is still a loser in the net!" - .hack//SIGN . Getting old is inevitable, growing up is optional !! Link to comment Share on other sites More sharing options...
Hav0c Posted August 10, 2014 Share Posted August 10, 2014 So K-Lite changed their MPC language files location, here is the update. [K-Lite Media Player Classic (Lng)*] Section=Language Files Detect=HKLM\SOFTWARE\Classes\Applications\mpc-hc.exe Default=False Warning=This will delete all language files excluding the Default language. FileKey1=%ProgramFiles%\K-Lite Codec Pack\MPC-HC\Lang|*.*|REMOVESELF FileKey2=%ProgramFiles%\K-Lite Codec Pack\MPC-HC64\Lang|*.*|REMOVESELF Every line of code written by man can be undone by man . "A loser in the real world is still a loser in the net!" - .hack//SIGN . Getting old is inevitable, growing up is optional !! Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 14, 2014 Author Share Posted August 14, 2014 Just a heads up in advance, unless the next CCleaner drops by next thursday, I might be pretty late on updating winapp2.ini alongside it, because I'm moving for and beginning school next week, and I'm unsure whether or not I'm bringing my desktop on move-in day / going to have time between move in and transfer orientation. Hopefully I'll be able to get everything done in a timely fashion winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted August 14, 2014 Moderators Share Posted August 14, 2014 Good luck with the move and new school year. Winapp2.ini update can wait... your future cannot Support contact https://support.piriform.com/hc/en-us/requests/new?ticket_form_id=86507 support@ccleaner.com Link to comment Share on other sites More sharing options...
JDPower Posted August 14, 2014 Share Posted August 14, 2014 Good luck with the move and new school year. Winapp2.ini update can wait... your future cannot Seconded, real life comes first. Hope it all goes smoothly Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 19, 2014 Author Share Posted August 19, 2014 Hi, just some problems with Winapp2.ini, I list them here: %Documents% works in CCleaner but doesn't exist in Windows 7 %ProgramFiles% works for both x86 and x64 in CCleaner... [Ace Explorer Browser*] FileKey1=%AppData%\Ace Explorer\recentclose.ini => %AppData%\Ace Explorer|recentclose.ini [Free PDF XP Logs*] FileKey1=%SystemDrive%IfpRedmon.log => %SystemDrive%|IfpRedmon.log [MS IE6 Installation Temps*] DetectFile2=%WinDir%|msdownld.tmp => %WinDir%\msdownld.tmp [MS Office Picture Manager More*] FileKey1=%AppData%\Microsoft\OIS\Toolbars.dat => |Toolbars.dat [Reddit To Go!*] FileKey3=%LocalAppData%\Packages\*.RedditToGo_*\AC\Microsoft\CryptnetUrlCache\MetaData*.* => ? [slimBoat*] FileKey3=%LocalAppData%\FlashPeak\SlimBoat\history => ? [WinSAT Shader Cache*] DetectOS=6.0 => 6.0| ? via facebook this evening, mostly missing pipes, fixed them up on my end winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted August 22, 2014 Share Posted August 22, 2014 Revised Entry Changed FileKey1=%LocalAppData%\CrashRpt\UnsentCrashReports\*|*.*|RECURSE to FileKey1=%LocalAppData%\CrashRpt\UnsentCrashReports|*.*|RECURSE [Ashampoo Snap 7*]LangSecRef=3024Detect=HKCU\Software\Ashampoo\Ashampoo Snap 7Default=FalseFileKey1=%LocalAppData%\CrashRpt\UnsentCrashReports|*.*|RECURSE Link to comment Share on other sites More sharing options...
siliconman01 Posted August 23, 2014 Share Posted August 23, 2014 Modified Entries for TuneUp Utilities code. Incorporates new AVG PC TuneUp 2014 code which is the latest name and software for TuneUp Utilities [AVG PC TuneUp & TuneUp Utilities (Backups)*] LangSecRef=3024 Detect1=HKCU\Software\TuneUp Detect2=HKCU\Software\AVG\AWL\RegistryCleaner Default=False Warning=This removes ALL backups created by TuneUp Utilities during its registry and other cleaning activities. FileKey1=%AppData%\TuneUp Software\*\Backups|*.rcb FileKey2=%AppData%\AVG\AWL*\Backups\|*.rcb [AVG PC TuneUp & TuneUp Utilities (CrashDumps)*] LangSecRef=3024 Detect1=HKCU\Software\TuneUp Detect2=HKCU\Software\AVG\AWL\RegistryCleaner Default=False Warning=This removes ALL crash/dump files saved by program TuneUp Utilities. FileKey1=%AppData%\TuneUp Software\TuneUp Utilities\CrashDumps|*.* FileKey2=%AppData%\AVG\AWL*\CrashDumps\|*.* [AVG PC TuneUp & TuneUp Utilities Installation/Update Logs*] LangSecRef=3024 Detect1=HKCU\Software\TuneUp Detect2=HKCU\Software\AVG\AWL\RegistryCleaner Default=False FileKey1=%CommonAppData%\TuneUp Software\TuneUp Utilities *\|*.log FileKey2=%CommonAppData%\Avg\AWL*\|*.log [AVG PC TuneUp & TuneUp Utilities Logs*] LangSecRef=3024 Detect1=HKCU\Software\TuneUp Detect2=HKCU\Software\AVG\AWL\RegistryCleaner Default=False FileKey1=%LocalAppData%\TuneUp Software|*.log|RECURSE FileKey2=%CommonAppData%\TuneUp Software\TuneUp Utilities *|*.log|RECURSE FileKey3=%LocalAppData%\Avg\Log\|*.log;zappapi.log.1|RECURSE [AVG PC TuneUp & TuneUp Utilities Reg Defrag Cleanup*] LangSecRef=3024 Detect1=HKCU\Software\TuneUp\Utilities\10.0 Detect2=HKCU\Software\TuneUp\Utilities\12.0 Detect3=HKCU\Software\TuneUp\Utilities\13.0 Detect4=HKCU\Software\TuneUp\Utilities\14.0 Detect5=HKCU\Software\AVG\AWL\RegistryCleaner Default=False FileKey1=%LocalAppData%\Microsoft\Windows|USRCLASS.DAT_tureg_new.LOG*;USRCLASS.DAT_tureg_old FileKey2=%SystemDrive%\Boot|BCD_tureg_new.LOG*;BCD_tureg_old FileKey3=%SystemDrive%\Documents and Settings\LocalService|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_old FileKey4=%SystemDrive%\Documents and Settings\LocalService.NT*|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_old FileKey5=%SystemDrive%\Documents and Settings\NetworkService|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_old FileKey6=%SystemDrive%\Documents and Settings\NetworkService.NT*|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_old FileKey7=%UserProfile%|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_old FileKey8=%WinDir%\ServiceProfiles\LocalService|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_old FileKey9=%WinDir%\ServiceProfiles\NetworkService|NTUSER.DAT_tureg_new.LOG*;NTUSER.DAT_tureg_old FileKey10=%WinDir%\System32\config|COMPONENTS_tureg_new.LOG*;COMPONENTS_tureg_old;DEFAULT_tureg_new.LOG*;DEFAULT_tureg_old;SAM_tureg_new.LOG*;SAM_tureg_old;SECURITY_tureg_new.LOG*;SECURITY_tureg_old;SOFTWARE_tureg_new.LOG*;SOFTWARE_tureg_old;SYSTEM_tureg_new.LOG*;SYSTEM_tureg_old;DRIVERS_tureg_new.LOG*;DRIVERS_tureg_old Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more. Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted August 23, 2014 Moderators Share Posted August 23, 2014 @ siliconman01 I have read that the AVG Tune Up and Tune Up Utilities are different. See post here from Borislav Angelov (you don't need to be a Facebook member to read it) https://www.facebook.com/AVG/posts/10152269259473663 Support contact https://support.piriform.com/hc/en-us/requests/new?ticket_form_id=86507 support@ccleaner.com Link to comment Share on other sites More sharing options...
back_track Posted August 25, 2014 Share Posted August 25, 2014 add filekey 7 [NVIDIA GFExperience Logs*] LangSecRef=3023 Detect=HKLM\Software\NVIDIA Corporation Default=False FileKey1=%SystemDrive%\NvidiaLogging\GFExperience|GridClientLog.log*|RECURSE FileKey2=%CommonAppData%\NVIDIA Corporation\ShadowPlay|CaptureCore.log;*.bak;*.stat FileKey3=%CommonAppData%\NVIDIA Corporation\GeForce Experience\Logs|GfeClientLog.log FileKey4=%LocalAppData%\NVIDIA Corporation\ShadowPlay|*.log;*.bak FileKey5=%LocalAppData%\VirtualStore\ProgramData\NVIDIA Corporation\ShadowPlay|CaptureCore.log;*.bak;*.stat FileKey6=%LocalAppData%\VirtualStore\ProgramData\NVIDIA Corporation\GeForce Experience\Logs|GfeClientLog.log FileKey7=%LocalAppData%\NVIDIA Corporation\GFExperience|GFExperienceOld.log Link to comment Share on other sites More sharing options...
