CCleaner Community Forums
Winapp2.ini additions
I have Adblock Plus installed on Chrome. Whenever I use CCleaner, it resets Adblock Plus settings and I get a first-run window showing in snapshot1 when I open Chrome the next time. The highlighted files in snapshot2 are causing this issue. I was able to exclude the file with extension “ldb” but how can I exclude the MANIFEST-000007 file? The file names are different each time Chrome is being wiped with CCleaner.
[Chrome HTML5 Storage*]
LangSecRef=3029
SpecialDetect=DET_CHROME
DetectFile1=%LocalAppData%\Chromium
DetectFile2=%LocalAppData%\Google\Chrome
DetectFile3=%LocalAppData%\Google\Chrome SxS
DetectFile4=%ProgramFiles%\Google\Chrome
DetectFile5=%ProgramFiles%\Google\Chrome SxS
DetectFile6=%LocalAppData%\Torch
DetectFile7=%LocalAppData%\SuperBird
Default=False
FileKey1=%LocalAppData%\Google\Chrome*\User Data\*\File System|*.*|REMOVESELF
FileKey2=%LocalAppData%\Chrome Plus\User Data\*\File System|*.*|REMOVESELF
FileKey3=%LocalAppData%\Chromium\User Data\*\File System|*.*|REMOVESELF
FileKey4=%LocalAppData%\Flock\User Data\*\File System|*.*|REMOVESELF
FileKey5=%LocalAppData%\Google\Chrome\User Data\*\File System|*.*|REMOVESELF
FileKey6=%LocalAppData%\Google\Chrome SxS\User Data\*\File System|*.*|REMOVESELF
FileKey7=%LocalAppData%\Rockmelt\User Data\*\File System|*.*|REMOVESELF
FileKey8=%LocalAppData%\SRWare Iron\User Data\*\File System|*.*|REMOVESELF
FileKey9=%LocalAppData%\Torch\User Data\*\File System|*.*|REMOVESELF
FileKey10=%LocalAppData%\SuperBird\User Data\*\File System|*.*|REMOVESELF
Link to post
Please read my previous post again. This entry has nothing to do with RFA. Programs that use Armadillo software protection store hidden streams in %CommonAppData%\TEMP|*.*|RECURSE location. When CCleaner tries to remove that folder, it causes issues for Explorer.exe. I have some programs on my system that use Armadillo software protection.
Sorry I was referring to
FileKey2=%UserProfile%\|*.tmp
FileKey3=%LocalAppData%\Microsoft\Windows|*.tmp
in your suggested change to the RFA entry
Link to post
  • Moderators
LangSecRef=3029
Default=False
If you want Comodo Dragon in that list these can also be included (I already had these in my Comodo Dragon cleaners):
Two detections:
Detect=HKLM\Software\ComodoGroup\Dragon
DetectFile=%LocalAppData%\COMODO\Dragon
I don't know about using REMOVESELF, so I opted for RECURSE instead:
FileKey##=%LocalAppData%\COMODO\Dragon\User Data\Default\File System|*.*|RECURSE
I'm just surprised you've gotten Adblock Plus to work in a Chrome browser! Allot of people were posting bugs about it always resetting itself to the default settings with no subscription filters, etc., and I noticed the same.
Link to post
So I noticed windows cleanup has an option to remove old windows udates that are no longer needed. I am wondering if it is possible for Winapp2 to have their own cleaning rule to cleanup old windows updates?
Link to post
Two detections:
I'm using Chrome Version 35.0.1916.114. I don't have an issue with Adblock Plus. For me it is the %LocalAppData%\Chrome Plus\User Data\*\File System|*.*|REMOVESELF which is resetting it. I have tested it about ten times.
Link to post
After compressing the registry with RFA, sometimes it leaves NTUSER.tmp and UsrClass.tmp files in those locations.
Link to post
Merged [Tag&Rename 3.7*] entry into this. There is a new version of this program, version 3.8, that also uses the same registry path (HKCU\Software\Softpointer\Tag&Rename3.7). So basically this covers versions 3, 3.7 & 3.8.
[Tag&Rename 3*]
LangSecRef=3024
Detect=HKCU\Software\Softpointer\Tag&Rename3\Config
Detect2=HKCU\Software\Softpointer\Tag&Rename3.7\Config
Default=False
RegKey1=HKCU\Software\Softpointer\Tag&Rename3\Config|FCurrentFolder
RegKey2=HKCU\Software\Softpointer\Tag&Rename3\Config|FHistoryList
RegKey3=HKCU\Software\Softpointer\Tag&Rename3\Config|FileListHeader
RegKey4=HKCU\Software\Softpointer\Tag&Rename3.7\Config|FCurrentFolder
RegKey5=HKCU\Software\Softpointer\Tag&Rename3.7\Config|FHistoryList
RegKey6=HKCU\Software\Softpointer\Tag&Rename3.7\Config|FileListHeader
RegKey7=HKCU\Software\Softpointer\Tag&Rename3.7\Config|HistoryList
Edited by SMalik
Link to post
I don't have MS Office on my system but this entry still shows up in CCleaner. Please change the detect path of this entry.
[MS Office Picture Manager More*]
LangSecRef=3021
Detect=HKCU\Software\Microsoft\Office
Default=False
FileKey1=%AppData%\Microsoft\OIS\Toolbars.dat
Link to post
Revised Entries
Changed from Detect to DetectFile.
I have Windows 8.1 with 3 user accounts all with Administrative rights. These programs do not create any registry data for user accounts other than the one being used to install these programs.
[iMobie PhoneClean*]
LangSecRef=3024
DetectFile=%AppData%\iMobie\PhoneClean
Default=False
FileKey1=%AppData%\iMobie\PhoneClean\AutoUpdate|*.*|RECURSE
FileKey2=%AppData%\iMobie\PhoneClean\DeviceBackup\Backup|*.*|RECURSE
FileKey3=%AppData%\iMobie\PhoneClean\DeviceBackup\Restore|*.*|RECURSE
FileKey4=%AppData%\iMobie\PhoneClean\EasyLoseFiles|*.*|RECURSE
FileKey5=%AppData%\iMobie\PhoneClean\ErrorLog|*.*|RECURSE
FileKey6=%AppData%\iMobie\PhoneClean\iMobieConfig|*.*|RECURSE
ExcludeKey1=PATH|%AppData%\iMobie\PhoneClean\iMobieConfig\ConfigReg.ini
[iMobie PhoneTrans Pro*]
LangSecRef=3024
DetectFile=%AppData%\iMobie\PhoneTrans
Default=False
FileKey1=%AppData%\iMobie\Backup|*.*|RECURSE
FileKey2=%AppData%\iMobie\PhoneTrans\AutoUpdate|*.*|RECURSE
FileKey3=%AppData%\iMobie\PhoneTrans\ErrorLog|*.*|RECURSE
FileKey4=%AppData%\iMobie\PhoneTrans\iMobieConfig|*.*|RECURSE
ExcludeKey1=PATH|%AppData%\iMobie\PhoneTrans\iMobieConfig\ConfigReg.ini
Link to post
[Tag&Rename 3*]
LangSecRef=3024
Default=False
I have problems with:
It delts all album covers...
Link to post
You're right. That should be excluded. By the way its not my entry, I just merged two together.
Link to post
  • Moderators
LangSecRef=3021
Default=False
It would probably need to have a DetectFile= for Toolbars.dat instead of that generic Detect= because of the many versions of MS Office that would require every version being listed if doing specific registry paths or specific program files paths.
Link to post
I think an entry for "%UserProfile%\AppData\Local\Temp|*.*|recurse" would be added.  Maybe with approbiate warnings...
I also did a scan for folders named TMP, TEMP, and CACHE and have included the results in the spoiler below.  The first number is the number of folders under the named folder, then the total number of files under the named folder, and 3rd is the folder name.
for %fldr in (@c:\Users\Galloway\Desktop\Temp_Tmp.txt) echo %@format[3,%@eval[%@files[/s /h "%fldr\*",d]-2]] %@format[3,%@files[/s /h "%fldr\*",-d]] %fldr
-2 1 C:\My Programs\Express Archiver\Temp
-2 0 C:\My Programs\Multi-Edit 2008\Polystyle\internal\cache
-2 7 C:\Program Files\Common Files\Microsoft\ART\Backup\Google Chrome\Default\Cache
-2 0 C:\Program Files\Common Files\Microsoft\ART\Backup\Google Chrome\Default\Extensions\Temp
-2 0 C:\Program Files (x86)\Temp
1 0 C:\Program Files (x86)\GreenTree Applications\YTD Video Downloader\plugins\access\.svn\tmp
1 0 C:\Program Files (x86)\GreenTree Applications\YTD Video Downloader\plugins\audio_filter\.svn\tmp
1 0 C:\Program Files (x86)\GreenTree Applications\YTD Video Downloader\plugins\audio_mixer\.svn\tmp
1 0 C:\Program Files (x86)\GreenTree Applications\YTD Video Downloader\plugins\audio_output\.svn\tmp
1 0 C:\Program Files (x86)\GreenTree Applications\YTD Video Downloader\plugins\codec\.svn\tmp
1 0 C:\Program Files (x86)\GreenTree Applications\YTD Video Downloader\plugins\video_filter\.svn\tmp
1 0 C:\Program Files (x86)\GreenTree Applications\YTD Video Downloader\plugins\video_output\.svn\tmp
-2 0 C:\Program Files (x86)\Hp\Temp
2 3 C:\Program Files (x86)\JDownloader\tmp
-2 9 C:\Program Files (x86)\jv16 PowerTools 2014\Cache
-2 0 C:\Program Files (x86)\Yahoo!\Messenger\Cache
-2 0 C:\ProgramData\Hewlett-Packard\HP Client Services\cache
-1 1 C:\ProgramData\Hewlett-Packard\HP Support Framework\Logs\Temp
-2 36 C:\ProgramData\Hewlett-Packard\HP Support Framework\Resources\ContactOption\Cache
-2 0 C:\ProgramData\HP\Installer\Temp
-2 0 C:\ProgramData\Microsoft\IdentityCRL\production\temp
-2 0 C:\ProgramData\Microsoft\RAC\Temp
-1 4 C:\ProgramData\Microsoft\Windows\DRM\Cache
-2 1 C:\Users\Administrator\AppData\Local\Temp
-2 0 C:\Users\Administrator\AppData\Local\Google\Chrome\User Data\Default\Cache
-2 0 C:\Users\Administrator\AppData\LocalLow\Sun\Java\Deployment\cache
-2 0 C:\Users\Administrator\AppData\Roaming\Multi Edit Software\Multi-Edit\11\Config.04\Tmp
-2 0 C:\Users\Default\AppData\Local\Temp
40 114 C:\Users\Galloway\AppData\Local\Temp
-2 0 C:\Users\Galloway\AppData\Local\Adobe\Acrobat\11.0\Cache
-2 0 C:\Users\Galloway\AppData\Local\Amazon\Kindle\Cache
-2 39 C:\Users\Galloway\AppData\Local\Amazon Cloud Player\Data\App Cache\Application Cache\Cache
-2 0 C:\Users\Galloway\AppData\Local\Amazon Cloud Player\Data\Artwork Cache\tmp
-2 0 C:\Users\Galloway\AppData\Local\GlobalSCAPE\CuteFTP Pro\7.0\Cache
-2 0 C:\Users\Galloway\AppData\Local\Google\Chrome\User Data\Default\Cache
3 48 C:\Users\Galloway\AppData\Local\VirtualStore\Program Files (x86)\Yahoo!\Messenger\Cache
1 0 C:\Users\Galloway\AppData\LocalLow\Temp
32 0 C:\Users\Galloway\AppData\LocalLow\Microsoft\Windows Live\Setup\tmp
-2 0 C:\Users\Galloway\AppData\LocalLow\Sun\Java\Deployment\cache
-1 0 C:\Users\Galloway\AppData\LocalLow\Sun\Java\Deployment\tmp
-2 1 C:\Users\Galloway\AppData\Roaming\ACD Systems\ACDSee\Cache
-2 0 C:\Users\Galloway\AppData\Roaming\aignes\AM-DeadLink\temp
-2 0 C:\Users\Galloway\AppData\Roaming\Microsoft\IdentityCRL\temp
-2 0 C:\Users\Galloway\AppData\Roaming\Multi Edit Software\Multi-Edit\11\Config.04\Tmp
-2 0 C:\Users\Galloway\AppData\Roaming\Skype\csgalloway27609\media_messaging\media_cache\asyncdb\tmp
-2 0 C:\Users\Galloway\AppData\Roaming\Skype\csgalloway27609\media_messaging\storage_db\asyncdb\tmp
-2 0 C:\Users\Galloway\AppData\Roaming\Skype\csgalloway27609\qikdb\tmp
-2 0 C:\Users\Galloway\AppData\Roaming\Skype\live#3acharlessgalloway\qikdb\tmp
-2 0 C:\Users\Galloway\AppData\Roaming\Skype\live#3akipperjill\qikdb\tmp
-2 0 C:\Windows\Temp
-2 0 C:\Windows\assembly\temp
-2 0 C:\Windows\assembly\tmp
-2 0 C:\Windows\assembly\NativeImages_v2.0.50727_32\Temp
-2 0 C:\Windows\assembly\NativeImages_v2.0.50727_64\Temp
-2 0 C:\Windows\assembly\NativeImages_v4.0.30319_32\Temp
-2 0 C:\Windows\assembly\NativeImages_v4.0.30319_64\Temp
-1 1 C:\Windows\System32\DriverStore\Temp
0 4 C:\Windows\winsxs\Temp
Link to post
[JDownloader Logs*]LangSecRef=3022Detect=HKLM\Software\JDownloaderDetectFile=%ProgramFiles%\JDownloaderDefault=FalseFileKey1=%ProgramFiles%\JDownloader|*.log;updateLog.txt;*.lck;*.log.*FileKey2=%UserProfile%\.jd_home|JDownloader.logFileKey3=%UserProfile%\.jd_home\logs|*.0FileKey4=%LocalAppData%\VirtualStore\Program Files*\JDownloader|*.log;updateLog.txt;*.lck;*.log.*FileKey5=%ProgramFiles%\JDownloader\logs|*.logFileKey6=%LocalAppData%\VirtualStore\Program Files*\JDownloader\logs|*.log
add
;*.log.*
and filekey 5&6
Link to post
It's a problem with already existing cleaning of AQQ IM. In winapp2.ini is:
[AQQ Cache*]
LangSecRef=3022
Detect=HKCU\Software\Wapster\AQQ
Default=False
FileKey1=%UserProfile%\WapSter\AQQ Folder\Profiles\*\Data\Cache|*.*
FileKey2=%UserProfile%\WapSter\AQQ Folder\Profiles\*\Data\PrivateCache|*.*
FileKey3=%UserProfile%\WapSter\AQQ Folder\Profiles\*\Data\Avatars|*.*
FileKey4=%UserProfile%\WapSter\AQQ Folder\Profiles\*\Data\LocalAvatars|*.*
[AQQ Chat History*]
LangSecRef=3022
Warning=This will delete your chat history.
Default=False
FileKey1=%UserProfile%\WapSter\AQQ Folder\Profiles\*\Data\Archive|*.DC2
[AQQ Temps*]
LangSecRef=3022
Default=False
FileKey1=%UserProfile%\WapSter\AQQ Folder\Profiles\*\Data\Temp|*.*
This must be changed into:
[AQQ Cache*]
LangSecRef=3022
Detect=HKCU\Software\MyPortal\AQQ
Default=False
FileKey1=%LocalAppData%\MyPortal\AQQ Folder\Profiles\*\Data\Cache|*.*
FileKey2=%LocalAppData%\MyPortal\AQQ Folder\Profiles\*\Data\PrivateCache|*.*
FileKey3=%LocalAppData%\MyPortal\AQQ Folder\Profiles\*\Data\Avatars|*.*
FileKey4=%LocalAppData%\MyPortal\AQQ Folder\Profiles\*\Data\LocalAvatars|*.*
FileKey5=%UserProfile%\WapSter\AQQ Folder\Profiles\*\Data\Cache|*.*
FileKey6=%UserProfile%\WapSter\AQQ Folder\Profiles\*\Data\PrivateCache|*.*
FileKey7=%UserProfile%\WapSter\AQQ Folder\Profiles\*\Data\Avatars|*.*
FileKey8=%UserProfile%\WapSter\AQQ Folder\Profiles\*\Data\LocalAvatars|*.*
[AQQ Chat History*]
LangSecRef=3022
Default=False
FileKey1=%LocalAppData%\MyPortal\AQQ Folder\Profiles\*\Data\Archive|*.DC2
FileKey2=%UserProfile%\WapSter\AQQ Folder\Profiles\*\Data\Archive|*.DC2
[AQQ Temps*]
LangSecRef=3022
Default=False
FileKey1=%LocalAppData%\MyPortal\AQQ Folder\Profiles\*\Data\Temp|*.*
FileKey2=%UserProfile%\WapSter\AQQ Folder\Profiles\*\Data\Temp|*.*
Link to post
[NirSoft AddrView LastUrlAddr*]
LangSecRef=3024
Detect=HKCU\Software\NirSoft\AddrView\
Default=False
RegKey1=HKCU\Software\NirSoft\AddrView|LastUrlAddr
-new
[sonic Visualiser*]
LangSecRef=3023
DetectFile1=%UserProfile%\.Sonic Visualiser
Detect2=HKCU\Software\sonic-visualiser\
Default=False
FileKey1=%UserProfile%\.Sonic Visualiser\cache|*.*
-add detect2
I have problems to delt these entries ....
[Paint.NET More*]
LangSecRef=3021
Detect=HKCU\Software\Paint.NET
Default=False
FileKey1=%LocalAppData%\Paint.NET|*.*|RECURSE
RegKey1=HKCU\Software\Paint.NET|LastFileDialogDirectory
RegKey2=HKCU\Software\Paint.NET|File/MostRecent/Path0
RegKey3=HKCU\Software\Paint.NET|File/MostRecent/Path1
RegKey4=HKCU\Software\Paint.NET|File/MostRecent/Path2
RegKey5=HKCU\Software\Paint.NET|File/MostRecent/Path3
RegKey6=HKCU\Software\Paint.NET|File/MostRecent/Path4
RegKey7=HKCU\Software\Paint.NET|File/MostRecent/Path5
RegKey8=HKCU\Software\Paint.NET|File/MostRecent/Path6
RegKey9=HKCU\Software\Paint.NET|File/MostRecent/Path7
RegKey10=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail0
RegKey11=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail1
RegKey12=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail2
RegKey13=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail3
RegKey14=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail4
RegKey15=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail5
RegKey16=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail6
RegKey17=HKCU\Software\Paint.NET|File/MostRecent/Thumbnail7
they come from the new Paint.net 4.0  but ccleaner is unable to clean that.. why?
Link to post
Got this email today
(No, this email's not real, it's http://deadfake.com)
Rob@winapp2.com
New Project
Ok Hi again,
0.5) This has nothing to do with the project, but what do you think is better?
Gilmore Girls or One three hill? I'm for Gilmore Girls.
0.6) Please help this person "bhunter".
Tell him, that he has to install the version of CCleaner to his own account. (Just Me)
With this probably his problem should be solved. His "Public" account is broken.
forum.piriform.com/index.php?showtopic=41170
1.)
Please avoid constructions like "\|" and just replace it with "|",
cause it works and you spend a few bytes and the code is a bit more effective.
For example:
[Argus Monitor*]
LangSecRef=3024
Detect=HKCU\Software\Argotronic\Argus Monitor
Default=False
FileKey1=%Documents%\|ArgusMonitor_EventLog.txt;ArgusMonitor_CSVLog.csv
FileKey2=%ProgramFiles%\|ArgusMonitor_EventLog.txt;ArgusMonitor_CSVLog.csv
FileKey3=%LocalAppData%\VirtualStore\Program Files*\|ArgusMonitor_EventLog.txt;ArgusMonitor_CSVLog.csv
...should be...
[Argus Monitor*]
LangSecRef=3024
Default=False
FileKey1=%Documents%|ArgusMonitor_EventLog.txt;ArgusMonitor_CSVLog.csv
FileKey2=%ProgramFiles%|ArgusMonitor_EventLog.txt;ArgusMonitor_CSVLog.csv
FileKey3=%LocalAppData%\VirtualStore\Program Files*|ArgusMonitor_EventLog.txt;ArgusMonitor_CSVLog.csv
2.)
Thank you CSGalloway for the entries you send. We will have more entries I'll add.
But please next time tick all entries and clean them and close all running programs
like google chrome and your background processes, because the list is much more longer
if you don't clean the actual entries, which are already in. But however thank you very much.
It will help us more. we will head soon (2015/2016) to 1 MB great winapp2.ini file with over 3000 entries.
(It will take about a minute on a dual core pc to initialize, I would prefer to use trim.bat)
3.) We must compress the most entries into one. Cause it will make all much more clear and smaller.
For example we could compress this
[jv16 PowerTools 2011 Backup Files*]
LangSecRef=3024
DetectFile=%ProgramFiles%\jv16 PowerTools 2011\jv16PT.exe
Default=False
FileKey1=%ProgramFiles%\jv16 PowerTools 2011\Backups|*.*|RECURSE
FileKey2=%ProgramFiles%\jv16 PowerTools 2011\Settings|UserActionLog.txt
FileKey3=%LocalAppData%\VirtualStore\Program Files*\jv16 PowerTools 2011\Backups|*.*|RECURSE
FileKey4=%LocalAppData%\VirtualStore\Program Files*\jv16 PowerTools 2011\Settings|UserActionLog.txt
ExcludeKey1=FILE|%ProgramFiles%\jv16 PowerTools 2011\Backups\License.xbin_backup
[jv16 PowerTools 2012 Backup Files*]
LangSecRef=3024
DetectFile=%ProgramFiles%\jv16 PowerTools 2012\jv16PT.exe
Default=False
FileKey1=%ProgramFiles%\jv16 PowerTools 2012\Backups|*.*|RECURSE
FileKey2=%ProgramFiles%\jv16 PowerTools 2012\Settings|UserActionLog.txt
FileKey3=%LocalAppData%\VirtualStore\Program Files*\jv16 PowerTools 2012\Backups|*.*|RECURSE
FileKey4=%LocalAppData%\VirtualStore\Program Files*\jv16 PowerTools 2012\Settings|UserActionLog.txt
ExcludeKey1=FILE|%ProgramFiles%\jv16 PowerTools 2012\Backups\License.xbin_backup
[jv16 PowerTools 2013 Backup Files*]
LangSecRef=3024
DetectFile=%ProgramFiles%\jv16 PowerTools 2013\jv16PT.exe
Default=False
FileKey1=%ProgramFiles%\jv16 PowerTools 2013\Backups|*.*|RECURSE
FileKey2=%ProgramFiles%\jv16 PowerTools 2013\Settings|UserActionLog.txt
FileKey3=%LocalAppData%\VirtualStore\Program Files*\jv16 PowerTools 2013\Backups|*.*|RECURSE
FileKey4=%LocalAppData%\VirtualStore\Program Files*\jv16 PowerTools 2013\Settings|UserActionLog.txt
ExcludeKey1=FILE|%ProgramFiles%\jv16 PowerTools 2013\Backups\License.xbin_backup
[jv16 PowerTools 2014 Backup Files*]
LangSecRef=3024
DetectFile=%ProgramFiles%\jv16 PowerTools 2014\jv16PT.exe
Default=False
FileKey1=%ProgramFiles%\jv16 PowerTools 2014\Backups|*.*|RECURSE
FileKey2=%ProgramFiles%\jv16 PowerTools 2014\Settings|UserActionLog.txt
FileKey3=%LocalAppData%\VirtualStore\Program Files*\jv16 PowerTools 2014\Backups|*.*|RECURSE
FileKey4=%LocalAppData%\VirtualStore\Program Files*\jv16 PowerTools 2014\Settings|UserActionLog.txt
ExcludeKey1=FILE|%ProgramFiles%\jv16 PowerTools 2014\Backups\License.xbin_backup
to:
[jv16 PowerTools Backup Files*]
LangSecRef=3024
DetectFile1=%ProgramFiles%\jv16 PowerTools 2011\jv16PT.exe
DetectFile2=%ProgramFiles%\jv16 PowerTools 2012\jv16PT.exe
DetectFile3=%ProgramFiles%\jv16 PowerTools 2013\jv16PT.exe
DetectFile4=%ProgramFiles%\jv16 PowerTools 2014\jv16PT.exe
Default=False
FileKey1=%ProgramFiles%\jv16 PowerTools *\Backups|*.*|RECURSE
FileKey2=%ProgramFiles%\jv16 PowerTools *\Settings|UserActionLog.txt
FileKey3=%LocalAppData%\VirtualStore\Program Files*\jv16 PowerTools *\Backups|*.*|RECURSE
FileKey4=%LocalAppData%\VirtualStore\Program Files*\jv16 PowerTools *\Settings|UserActionLog.txt
ExcludeKey1=FILE|%ProgramFiles%\jv16 PowerTools *\Backups\License.xbin_backup
(I don't know, if Excludekey work with *)
4.)
I have managed to know, where the files like "Gut123.tmp" comes. They are coming from Google Chromes Updates Temps.
Therefore we should add:
[Chrome Installer*]
LangSecRef=3029
DetectFile1=%LocalAppData%\Google\Chrome
DetectFile2=%LocalAppData%\Google\Chrome SxS
DetectFile3=%ProgramFiles%\Google\Chrome
DetectFile4=%ProgramFiles%\Google\Chrome SxS
Default=False
Warning=Running this may remove Chrome's ability to automatically update to future versions on some computers.
FileKey1=%LocalAppData%\Google\Chrome*\Application\*\Installer|*.7z|RECURSE
FileKey2=%ProgramFiles%\Google\Chrome*\Application\*\Installer|*.7z|RECURSE
FileKey3=%LocalAppData%\Google\Update\*\*\Installer|*.7z|RECURSE
FileKey4=%ProgramFiles%\Google\Update\*\*\Installer|*.7z|RECURSE
FileKey5=%ProgramFiles%|GUT*tmp
I have added Filekey5. It's not located in the Google Chromes path, it's located in %ProgramFiles%.
It's not important after installation. It's about 20-35 mb great file.
5.)
there are still people, who don't understand the working of [userless Files Extension 2] entry.
It should never be added to the project, cause it's a advanced cleaning routine, which is finding
more files, which are harmless and harmfull. And we want to add the harmless one into the project.
I'm showing you all these on a example of my pc:
First of all I'm cleaning everthing ticked on.
Second I copy this into winapp2.ini:
[useless File Extension 2.1*]
LangSecRef=3025
Warning= Please don't clean with this entry, because it's for analyzing Useless files. Please post the scanned text and upload in winapp2.ini forum. Thanks.
Detect=HKLM\SOFTWARE\Microsoft
Default=False
FileKey1=%SystemDrive%|*.diz;*.tmp;*.temp;*.chk;*.old;*.gid;*.nch;*.wbk;*.fts;*.ftg;*.$$$;*log.txt;*.err;*.---;*.~*;*.??$;*.___;*.log;*.~mp;*._mp;*.dmp;*.prv;*.sik;*.bak;CHKLIST.MS;*.ilk;*.aps;*.ncb;*.pch;*.$db;*.?$?;*.??~;*.?~?;*.db$;*.^;*._dd;*._detmp;chklist.*;mscreate.dir;log*.txt;*.log?;*ERRORLOG*;*report.txt;*tmp*;*Cache*;*fix*.*;*report*.xml;*log.dat|RECURSE
FileKey2=%CommonAppData%|*temp*
FileKey3=%ProgramFiles%|*temp*
FileKey4=%AppData%|*temp*
ExcludeKey1=FILE|%CommonAppData%\Microsoft\Search\Data\Applications\Windows|*.chk
ExcludeKey2=FILE|%CommonAppData%\Microsoft\Search\Data\Applications\Windows|*.log
ExcludeKey3=FILE|%WinDir%\ServiceProfiles\LocalService\NTUSER.bak
ExcludeKey4=FILE|%WinDir%\ServiceProfiles\LocalService\NTUSER.rhk.LOG1
ExcludeKey5=FILE|%WinDir%\ServiceProfiles\LocalService\NTUSER.rhk.LOG2
ExcludeKey6=FILE|%WinDir%\ServiceProfiles\NetworkService\NTUSER.bak
ExcludeKey7=FILE|%WinDir%\ServiceProfiles\NetworkService\NTUSER.rhk.LOG1
ExcludeKey8=FILE|%WinDir%\ServiceProfiles\NetworkService\NTUSER.rhk.LOG2
ExcludeKey9=FILE|%WinDir%\System32\LocalGroupAdminAdd.log
ExcludeKey10=FILE|%WinDir%\System32\Local_LLU.log
ExcludeKey11=FILE|%WinDir%\System32\Network_LLU.log
ExcludeKey12=FILE|%WinDir%\System32\config\BCD-Template.LOG
ExcludeKey13=FILE|%WinDir%\System32\config\COMPONENTS.LOG
ExcludeKey14=FILE|%WinDir%\System32\config\DEFAULT.LOG
ExcludeKey15=FILE|%WinDir%\System32\config\SAM.LOG
ExcludeKey16=FILE|%WinDir%\System32\config\SECURITY.LOG
ExcludeKey17=FILE|%WinDir%\System32\config\SOFTWARE.LOG
ExcludeKey18=FILE|%WinDir%\System32\config\SYSTEM.LOG
ExcludeKey19=FILE|%WinDir%\System32\config\COMPONENTS.LOG
ExcludeKey20=FILE|%WinDir%\System32\config\COMPONENTS.LOG1
ExcludeKey21=FILE|%WinDir%\System32\config\COMPONENTS.LOG2
ExcludeKey22=FILE|%WinDir%\System32\config\RegBack\DEFAULT.LOG1
ExcludeKey23=FILE|%WinDir%\System32\config\RegBack\DEFAULT.LOG2
ExcludeKey24=FILE|%WinDir%\System32\config\RegBack\SAM.LOG1
ExcludeKey25=FILE|%WinDir%\System32\config\RegBack\SAM.LOG2
ExcludeKey26=FILE|%WinDir%\System32\config\RegBack\SECURITY.LOG1
ExcludeKey27=FILE|%WinDir%\System32\config\RegBack\SECURITY.LOG2
ExcludeKey28=FILE|%WinDir%\System32\config\RegBack\SOFTWARE.LOG1
ExcludeKey29=FILE|%WinDir%\System32\config\RegBack\SOFTWARE.LOG2
ExcludeKey30=FILE|%WinDir%\System32\config\RegBack\SYSTEM.LOG1
ExcludeKey31=FILE|%WinDir%\System32\config\RegBack\SYSTEM.LOG2
ExcludeKey32=FILE|%WinDir%\System32\config\systemprofile\ntuser.dat.LOG
ExcludeKey33=FILE|%WinDir%\System32\config\systemprofile\ntuser.dat.LOG1
ExcludeKey34=FILE|%WinDir%\System32\config\systemprofile\ntuser.dat.LOG2
ExcludeKey35=FILE|%WinDir%\System32\Msdtc\MSDTC.LOG
ExcludeKey36=FILE|%WinDir%\System32\Msdtc\Trace\dtctrace.log
ExcludeKey37=FILE|%WinDir%\System32\SMI\Store\Machine\schema.dat.LOG
ExcludeKey38=FILE|%WinDir%\System32\SMI\Store\Machine\SCHEMA.DAT.LOG1
ExcludeKey39=FILE|%WinDir%\System32\SMI\Store\Machine\SCHEMA.DAT.LOG2
ExcludeKey40=FILE|%WinDir%\System32\sysprep\Panther\setupact.log
ExcludeKey41=FILE|%WinDir%\System32\sysprep\Panther\setuperr.log
ExcludeKey42=FILE|%WinDir%\System32\sysprep\Panther\IE\setupact.log
ExcludeKey43=FILE|%WinDir%\System32\sysprep\Panther\IE\setuperr.log
ExcludeKey44=FILE|%WinDir%\SysWOW64\config\DEFAULT.ba
k
ExcludeKey45=FILE|%WinDir%\SysWOW64\config\SAM.bak
ExcludeKey46=FILE|%WinDir%\SysWOW64\config\SECURITY.bak
ExcludeKey47=FILE|%WinDir%\SysWOW64\config\SOFTWARE.bak
ExcludeKey48=FILE|%WinDir%\SysWOW64\config\DEFAULT.rhk.LOG1
ExcludeKey49=FILE|%WinDir%\SysWOW64\config\DEFAULT.rhk.LOG2
ExcludeKey50=FILE|%WinDir%\SysWOW64\config\SAM.rhk.LOG1
ExcludeKey51=FILE|%WinDir%\SysWOW64\config\SAM.rhk.LOG2
ExcludeKey52=FILE|%WinDir%\SysWOW64\config\SECURITY.rhk.LOG1
ExcludeKey53=FILE|%WinDir%\SysWOW64\config\SECURITY.rhk.LOG2
ExcludeKey54=FILE|%WinDir%\SysWOW64\config\SOFTWARE.rhk.LOG1
ExcludeKey55=FILE|%WinDir%\SysWOW64\config\SOFTWARE.rhk.LOG2
ExcludeKey56=FILE|%WinDir%\SysWOW64\config\systemprofile\ntuser.dat.LOG1
ExcludeKey57=FILE|%WinDir%\SysWOW64\config\systemprofile\ntuser.dat.LOG2
ExcludeKey58=FILE|%WinDir%\ServiceProfiles\LocalService\NTUSER.DAT.LOG
ExcludeKey59=FILE|%WinDir%\ServiceProfiles\NetworkService\NTUSER.DAT.LOG
ExcludeKey60=FILE|%WinDir%\ServiceProfiles\NetworkService\AppData\Local\Temp\MpCmdRun.log
ExcludeKey61=FILE|%WinDir%\SoftwareDistribution\DataStore\Logs\edb.chk
ExcludeKey62=FILE|%UserProfile%\Administrator\ntuser.dat.LOG1
ExcludeKey63=FILE|%UserProfile%\Administrator\ntuser.dat.LOG2
ExcludeKey64=FILE|%UserProfile%\Administrator\AppData\Local\Microsoft\Windows\UsrClass.dat.LOG1
ExcludeKey65=FILE|%UserProfile%\Administrator\AppData\Local\Microsoft\Windows\UsrClass.dat.LOG2
ExcludeKey66=FILE|%UserProfile%\Administrator\AppData\Local\Microsoft\Windows\WebCache\V01.log
ExcludeKey67=FILE|%UserProfile%\Default\NTUSER.DAT.LOG
ExcludeKey68=FILE|%UserProfile%\Default\NTUSER.DAT.LOG1
ExcludeKey69=FILE|%UserProfile%\Default\NTUSER.DAT.LOG2
(A litte update Exclude 54-69, thanks CSGalloway) (Improved Filekey1, thanks to CSGalloway ) (And Improved Excludekey 1 and 2) (Added Filekey2-3) (Added Warning)
Third, I'm ticking this entry
Fourth, I'm scanning, not cleaning (cause these could delete very important files)
Fifth, here are the results of my pc in actual:
ANALYSIS COMPLETE - (67.135 secs)
13,0 MB to be removed. (Approximate size)
Details of files to be deleted (Note: No files have been deleted yet)
Windows - MS Search    1.024 KB    1 files
Windows - Useless File Extension 2.1*    12.273 KB    50 files
C:\ProgramData\Microsoft\Search\Data\Applications\Windows\MSS0005A.log    1.024 KB
C:\klcp_iph_migpq9sxcjtpgtm1xv7hixeou6e7rne88xrm7mntexaa8a3xtpd1y0mew.tmp    136 KB
C:\log\log.log    1 KB
C:\log\log.log    1 KB
C:\Program Files (x86)\Common Files\Web Solution Mart\8.0.11\fwcCMARP_20140529.log    3 KB
C:\Program Files (x86)\HDD Health\is-C4K8V.tmp    3.171 KB
C:\ProgramData\StarMoney 7.0\profil\smpms.log    23 KB
C:\ProgramData\StarMoney 7.0\profil\StarMoneyOnlineUpdate.log    19 KB
C:\ProgramData\StarMoney Business 4.0\profil\smpms.log    25 KB
C:\ProgramData\StarMoney Business 4.0\profil\StarMoneyOnlineUpdate.log    20 KB
C:\ProgramData\StarMoney Business 5.0\profil\StarMoneyOnlineUpdate.log    2 KB
C:\Users\All Users\Microsoft\Search\Data\Applications\Windows\MSS.chk    8 KB
C:\Users\All Users\Microsoft\Search\Data\Applications\Windows\MSS0005A.log    1.024 KB
C:\Users\All Users\StarMoney 7.0\profil\smpms.log    23 KB
C:\Users\All Users\StarMoney 7.0\profil\StarMoneyOnlineUpdate.log    19 KB
C:\Users\All Users\StarMoney Business 4.0\profil\smpms.log    25 KB
C:\Users\All Users\StarMoney Business 4.0\profil\StarMoneyOnlineUpdate.log    20 KB
C:\Users\All Users\StarMoney Business 5.0\profil\StarMoneyOnlineUpdate.log    2 KB
C:\Users\Boss\AppData\Local\Aiseesoft Studio\Aiseesoft Total Video Converter Platinum\fileinfolog.txt    1 KB
C:\Users\Boss\AppData\Local\nimbuzz\nimbuzz.log    3 KB
C:\Users\Boss\AppData\Roaming\Bitcoin\db.log    1 KB
C:\Users\Boss\AppData\Roaming\Bitcoin\debug.log    12 KB
C:\Users\Boss\AppData\Roaming\Bitcoin\blocks\index\LOG.old    64 KB
C:\Users\Boss\AppData\Roaming\Bitcoin\blocks\index\000006.log    0 KB
C:\Users\Boss\AppData\Roaming\Bitcoin\chainstate\LOG.old    64 KB
C:\Users\Boss\AppData\Roaming\Bitcoin\chainstate\000006.log    1 KB
C:\Users\Boss\AppData\Roaming\Intermedia Software\Helium 10\Logs\startlog.txt    1 KB
C:\Users\Boss\AppData\Roaming\log\log.log    1 KB
C:\Windows\SysWOW64\config\DEFAULT.bak    4.352 KB
C:\Windows\SysWOW64\config\systemprofile\AppData\Roaming\hddhealth_s.log    1 KB
Sixth:
I'm removing the doubled entries and Windows Search Index Logs:
C:\log\log.log    1 KB
Seventh: You must just copy this content above to the community and this would be enough for a normal user to do:
Eight: I'm removing afterwards the entry [useless File Extension 2.1*], so I not delete any important logs, which
have not been discused in the forum. The only bad thing, that we don't have regkeys, if they exist.
Therefore we can just add Detectfile and not Detect. It would be better, if you could share the regfiles,
cause no one wants to install the software.
Ninth: By the way, here are the new entries, this is the I'm finding file for the next update very easy:
[ESET NOD32 Antivirus Backups*]
LangSecRef=3021
Detect=HKLM\Software\ESET\ESET Security
Default=False
Warning=This will clean your Backup files.
FileKey1=%CommonAppData%\ESET\ESET NOD32 Antivirus\backup|*.*|RECURSE
Found these in the Pastebin of SMalik:
C:\Documents and Settings\All Users\Application Data\ESET\ESET NOD32 Antivirus\backup\em000_32-1066.dat.bak
C:\Documents and Settings\All Users\Application Data\ESET\ESET NOD32 Antivirus\backup\em001_32-1605.dat.bak
C:\Documents and Settings\All Users\Application Data\ESET\ESET NOD32 Antivirus\backup\em002_32-17766.dat.bak
C:\Documents and Settings\All Users\Application Data\ESET\ESET NOD32 Antivirus\backup\em002_32-17772.dat.bak
C:\Documents and Settings\All Users\Application Data\ESET\ESET NOD32 Antivirus\backup\em003_32-1168.dat.bak
C:\Documents and Settings\All Users\Application Data\ESET\ESET NOD32 Antivirus\backup\em004_32-1112.dat.bak
C:\Documents and Settings\All Users\Application Data\ESET\ESET NOD32 Antivirus\backup\em005_32-1116.dat.bak
C:\Documents and Settings\All Users\Application Data\ESET\ESET NOD32 Antivirus\backup\em006_32-1097.dat.bak
C:\Documents and Settings\All Users\Application Data\ESET\ESET NOD32 Antivirus\backup\em009_32-1272.dat.bak
C:\Documents and Settings\All Users\Application Data\ESET\ESET NOD32 Antivirus\backup\em015_32-1006.dat.bak
C:\Documents and Settings\All Users\Application Data\ESET\ESET NOD32 Antivirus\backup\em017_32-1194.dat.bak
C:\Documents and Settings\All Users\Application Data\ESET\ESET NOD32 Antivirus\backup\em018_32-1157.dat.bak
C:\Documents and Settings\All Users\Application Data\ESET\ESET NOD32 Antivirus\backup\em019_32-1109.dat.bak
C:\Documents and Settings\All Users\Application Data\ESET\ESET NOD32 Antivirus\backup\em022_32-1047.dat.bak
C:\Documents and Settings\All Users\Application Data\ESET\ESET NOD32 Antivirus\backup\em023_32-4037.dat.bak
C:\Documents and Settings\All Users\Application Data\ESET\ESET NOD32 Antivirus\backup\em023_32-4039.dat.bak
C:\Documents and Settings\All Users\Application Data\ESET\ESET NOD32 Antivirus\backup\em024_32-1015.dat.bak
C:\Documents and Settings\All Users\Application Data\ESET\ESET NOD32 Antivirus\backup\em031_32-1002.dat.bak
[uTorrent More*]
LangSecRef=3022
Detect=HKCU\Software\BitTorrent\uTorrent
Default=False
FileKey1=%ProgramFiles%\uTorrent|*.tmp;*.old
Improved Filekey1 by adding *.old
C:\Documents and Settings\Administrator\Application Data\uTorrent\resume.dat.old
C:\Documents and Settings\Administrator\Application Data\uTorrent\settings.dat.old
[K-Lite Codec Pack*]
LangSecRef=3023
Detect=HKLM\Software\KLCodecPack
Default=False
FileKey1=%ProgramFiles%\K-Lite|*.log;*.txt|RECURSE
FileKey2=%ProgramFiles%\K-Lite Codec Pack|*.log;*.txt|RECURSE
FileKey3=%SystemDrive%|*klcp_itp_*.tmp;*klcp_iph_*.tmp;
FileKey4=%UserProfile%\Desktop|klcp_codec_log.txt
FileKey5=%LocalAppData%\VirtualStore\Program Files*\K-Lite|*.log;*.txt|RECURSE
FileKey6=%LocalAppData%\VirtualStore\Program Files*\K-Lite Codec Pack|*.log;*.txt|RECURSE
RegKey1=HKU\S-1-5-21-1409082233-152049171-725345543-500\Software\Gabest\vsfilter\DefTextPathes|Path0
RegKey2=HKU\S-1-5-21-1409082233-152049171-725345543-500\Software\Gabest\vsfilter\DefTextPathes|Path1
RegKey3=HKU\S-1-5-21-1409082233-152049171-725345543-500\Software\Gabest\vsfilter\DefTextPathes|Path2
Improved Filekey3
Found these:
[HDD Health*]
LangSecRef=3022
Detect=HKLM\SYSTEM\CurrentControlSet\services\HDDHealth
Default=False
FileKey1=%ProgramFiles%\HDD Health|*.tmp
FileKey2=%WinDir%\SysWOW64\config\systemprofile\AppData\Roaming|*.log
Found these:
[bitcoin*]
LangSecRef=3022
Detect1=HKLM\SOFTWARE\Wow6432Node\Bitcoin Core (32-bit)
Detect2=HKCU\Software\Bitcoin
Detect3=HKCU\Software\Bitcoin Core (32-bit)
Default=False
FileKey1=%AppData%\Bitcoin|*.log;*.old
Found these:
[Helium Music Manager*]
LangSecRef=3023
Detect1=HKCU\Software\Intermedia Software\Helium 8
Detect2=HKCU\Software\Intermedia Software\Helium 9
Detect3=HKCU\Software\Intermedia Software\Helium 10
Default=False
FileKey1=%AppData%\Intermedia Software\Helium *\Logs|*.*
Added Detect3
Found these:
[starMoney*]
LangSecRef=3021
DetectFile1=%CommonAppData%\StarMoney 7.0
DetectFile2=%CommonAppData%\StarMoney 8.0
DetectFile3=%CommonAppData%\StarMoney 9.0
DetectFile3=%CommonAppData%\StarMoney Business 4.0
DetectFile3=%CommonAppData%\StarMoney Business 5.0
Default=False
FileKey1=%CommonAppData%\StarMoney *|*.log|RECURSE
FileKey2=%LocalAppData%\VirtualStore\ProgramData\StarMoney *|*.log|RECURSE
Added more Detectfiles, which now recognize more versions.
Found these:
[Driver Magician*]
LangSecRef=3021
Detect=HKCU\Software\Driver Magician
Default=False
FileKey1=%AppData%\Driver Magician|HiddenUpdate.txt
[CD Recovery Toolbox Free*]
LangSecRef=3021
Warning= This will delete your restored CD/DVD. Please clean it, after you have backed it up somewhere else.
Detect=HKCU\Software\CD Recovery Toolbox Free
Default=False
FileKey1=%SystemDrive%|_CDRestored|REMOVESELF
Found these:
HKEY_CURRENT_USER\Software\CD Recovery Toolbox Free
C:\_CDRestored
[Nimbuzz Logs*]
LangSecRef=3022
Detect=HKCU\Software\Nimbuzz
Default=False
FileKey1=%AppData%\nimbuzz|*.log
Found these:
HKEY_CURRENT_USER\Software\Nimbuzz
[Aiseesoft Studio Logs*]
LangSecRef=3023
Detect=HKCU\Software\Aiseesoft Studio
Default=False
FileKey1=%AppData%\log|*.*|REMOVESELF
FileKey2=%AppData%\Aiseesoft Studio|fileinfolog.txt;*.log|RECURSE
FileKey3=%SystemDrive%\log|*.*|REMOVESELF
Found these:
C:\log\log.log    1 KB
[Kate's Video Toolkit Logs*]
LangSecRef=3023
Detect=HKCU\Software\Web Solution Mart\Kate's Video Toolkit
Default=False
FileKey1=%CommonAppData%\Web Solution Mart\*|*.log|RECURSE
Found these:
HKEY_CURRENT_USER\Software\Web Solution Mart\Kate's Video Toolkit
[MS Office 2013 SkyDrive/OneDrive Logs*]
LangSecRef=3021
Detect=HKCU\Software\Microsoft\SkyDrive
Default=False
FileKey1=%LocalAppData%\Microsoft\SkyDrive\Setup\Logs|*.*
FileKey2=%LocalAppData%\Microsoft\SkyDrive\logs|*.*
Added Filekey2 and changed name of Entry.
Found these:
C:\Users\Galloway\AppData\Local\Microsoft\SkyDrive\logs\GALLOWAY-HP.dev=0.2013-03-11.0128.4792-1.log    3 KB
C:\Users\Galloway\AppData\Local\Microsoft\SkyDrive\logs\GALLOWAY-HP.dev=0.2013-03-11.0129.6396-1.log    6 KB
C:\Users\Galloway\AppData\Local\Microsoft\SkyDrive\logs\SkyDrive.exe.err.2013-03-11-052853.160.log    1 KB
C:\Users\Galloway\AppData\Local\Microsoft\SkyDrive\logs\SkyDrive.exe.reg.2013-03-11-052853.159.log    5 KB
C:\Users\Galloway\AppData\Local\Microsoft\SkyDrive\setup\logs\2013-01-13_153202_1f60-5b0.log    8 KB
C:\Users\Galloway\AppData\Local\Microsoft\SkyDrive\setup\logs\2013-01-13_153203_1ecc-548.log    8 KB
C:\Users\Galloway\AppData\Local\Microsoft\SkyDrive\setup\logs\2013-01-13_153203_8a8-1508.log    11 KB
C:\Users\Galloway\AppData\Local\Microsoft\SkyDrive\setup\logs\2013-03-11_012853_12b8-158.log    8 KB
C:\Users\Galloway\AppData\Local\Microsoft\SkyDrive\setup\logs\2013-03-11_012856_8f8-1808.log    7 KB
C:\Users\Galloway\AppData\Local\Microsoft\SkyDrive\setup\logs\2013-03-11_012857_1370-1bbc.log    11 KB
C:\Users\Galloway\AppData\Local\Microsoft\SkyDrive\setup\logs\2013-03-11_012935_18fc-bc8.log    1 KB
C:\Users\Galloway\AppData\Local\Microsoft\SkyDrive\setup\logs\2014-02-22_155712_2f60-1d4c.log    7 KB
C:\Users\Galloway\AppData\Local\Microsoft\SkyDrive\setup\logs\2014-02-22_155713_1cec-2270.log    14 KB
C:\Users\Galloway\AppData\Local\Microsoft\SkyDrive\setup\logs\2014-04-24_203335_1b98-1618.log    7 KB
C:\Users\Galloway\AppData\Local\Microsoft\SkyDrive\setup\logs\2014-04-24_203340_1ba0-1088.log    14 KB
C:\Users\Boss\AppData\Local\Microsoft\SkyDrive\logs\BOSS-PC.dev=0.2014-06-12.1532.1424-1.log    6 KB
C:\Users\Boss\AppData\Local\Microsoft\SkyDrive\logs\SkyDrive.exe.err.2014-06-12-133240.768.log    1 KB
C:\Users\Boss\AppData\Local\Microsoft\SkyDrive\logs\SkyDrive.exe.reg.2014-06-12-133240.768.log    6 KB
[jv16 PowerTools Logs*]
LangSecRef=3024
DetectFile1=%ProgramFiles%\jv16 PowerTools 2009\jv16PT.exe
DetectFile2=%ProgramFiles%\jv16 PowerTools 2010\jv16PT.exe
DetectFile3=%ProgramFiles%\jv16 PowerTools 2011\jv16PT.exe
DetectFile4=%ProgramFiles%\jv16 PowerTools 2012\jv16PT.exe
DetectFile5=%ProgramFiles%\jv16 PowerTools 2013\jv16PT.exe
DetectFile6=%ProgramFiles%\jv16 PowerTools 2014\jv16PT.exe
Default=False
FileKey1=%ProgramFiles%\jv16 PowerTools *|*log.txt;*.log
This entry will delete all log Files for All versions.
Found these:
C:\Program Files (x86)\jv16 PowerTools 2014\PreStartupWorker_Log.txt    119 KB
C:\Program Files (x86)\jv16 PowerTools 2014\RegCompact_log.txt    2 KB
C:\Program Files (x86)\jv16 PowerTools 2014\Decrap.log    9 KB
C:\Program Files (x86)\jv16 PowerTools 2014\Software.log    436 KB
[TuneUp Utilities Logs*]
LangSecRef=3024
Detect=HKCU\Software\TuneUp
Default=False
FileKey1=%LocalAppData%\TuneUp Software|*.log|RECURSE
FileKey2=%CommonAppData%\TuneUp Software\TuneUp Utilities *|*.log|RECURSE
I have added "siliconman01"'s Filkey as Filekey2. Now it will delete much more.
[Yahoo Messenger Logs*]
LangSecRef=3022
Detect=HKCU\Software\Yahoo\pager
Default=False
FileKey1=%LocalAppData%\VirtualStore\*\Yahoo!\Messenger\logs|*.log
FileKey2=%ProgramFiles%\Yahoo!\Messenger|*.log
FileKey3=%LocalAppdata%\VirtualStore\Program Files (x86)\Yahoo!\Messenger\Cache|*.log;*.tmp
I added Filekey2/3.
Found these:
C:\Users\Galloway\AppData\Local\VirtualStore\Program Files (x86)\Yahoo!\Messenger\Cache\9G0IMTf7KSnOtr1pRkveNQ--.ProfileMap.dat.tmp    0 KB
[VNCViewer 5*]
LangSecRef=3024
Detect=HKCU\Software\RealVNC\vncviewer\
Default=False
RegKey1=HKCU\Software\RealVNC\vncviewer\MRU
FileKey1=%LocalAppData%\RealVNC|*.log
Added Filekey1
[Delfix*]
LangSecRef=3024
DetectFile=%SystemDrive%\DelFix.txt
Default=False
FileKey1=%SystemDrive%|DelFix.txt
Found these:
C:\DelFix.txt    1 KB
[Adobe Air More*]
LangSecRef=3024
DetectFile=%LocalAppData%\Adobe\Air
Default=True
FileKey1=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Adobe\AIR\logs|*.*
Found these on CSGAlloways List:
C:\Windows\SysWOW64\config\systemprofile\AppData\Local\Adobe\AIR\logs\Install.log    7 KB
[DVBDream*]
LangSecRef=3024
Detect1=HKLM\SOFTWARE\DVBDream
Detect2=HKLM\SOFTWARE\Wow6432Node\DVBDream
Default=False
FileKey1=%SystemDrive%\dvbdream\Logs|*.*
FileKey2=%SystemDrive%\dvbdream|*.log;*.bak;*levellog*|RECURSE
FileKey3=%ProgramFiles%\dvbdream\Logs|*.*
FileKey4=%ProgramFiles%\dvbdream|*.log;*.bak;*levellog*|RECURSE
The normal installation Path recommendends is C:, but if some users should install to Program Files, then it
will be deletet through Filekey3 and 4.
Found these:
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\DVBDream
C:\dvbdream\Settings.bak    18 KB
C:\dvbdream\Logs\bda.log    1 KB
[DVBDream Recordings*]
LangSecRef=3024
Warning= This will delete your recordings. Please backup first, then clean.
Default=False
FileKey1=%SystemDrive%\dvbdream\Record|*.*
FileKey2=%ProgramFiles%\dvbdream\Record|*.*
Found these:
c:\dvbdream\Record\
[intel Installation Logs*]
LangSecRef=3024
Detect1=HKCU\Software\Intel
Detect2=HKLM\Software\Intel
Default=False
FileKey1=%SystemDrive%\Intel*|*.*|REMOVESELF
FileKey2=%UserProfile%\Intel\Logs|*log
FileKey3=%ProgramFiles%\Intel\InfInst|*.*|REMOVESELF
FileKey4=%WinDir%\debug\intel\logs|*.*|REMOVESELF
FileKey5=%WinDir%\SysWOW64\config\systemprofile\Intel\Logs|*.*|REMOVESELF
FileKey6=%WinDir%\System32\config\systemprofile\Intel\Logs|*.*|REMOVESELF
FileKey7=%LocalAppData%\VirtualStore\Program Files*\Intel\InfInst|*.*|REMOVESELF
FileKey8=%CommonAppData%\intel|*.log|REMOVESELF
Added Filekey8
Found these:
C:\ProgramData\intel\IntelControlCenter.log    30 KB
C:\ProgramData\intel\IntelGFX.log    60 KB
C:\ProgramData\intel\IntelGFXCoin.log    1 KB
C:\ProgramData\intel\intelme\IntelAMT.log    35 KB
[Windows Temporary Files More*]
LangSecRef=3025
Detect=HKLM\Software\Microsoft
Default=False
FileKey1=%CommonAppData%\TEMP|*.*|REMOVESELF
FileKey2=%LocalAppData%\VirtualStore\ProgramData\TEMP|*.*|REMOVESELF
FileKey3=%LocalAppData%\Temp|*.*
Added Filekey3 and changed Detectfile to Detect, which should be faster.
Found these:
C:\Users\Galloway\AppData\Local\Temp\DIO58FA.tmp    47 KB
C:\Users\Galloway\AppData\Local\Temp\MAR425C.tmp    2 KB
C:\Users\Galloway\AppData\Local\Temp\MAR4357.tmp    2 KB
C:\Users\Galloway\AppData\Local\Temp\RedboxLog.txt    4 KB
C:\Users\Galloway\AppData\Local\Temp\AdobeARM.log    1 KB
C:\Users\Galloway\AppData\Local\Temp\hpqddusr.log    1 KB
C:\Users\Galloway\AppData\Local\Temp\jusched.log    1 KB
[CyberLink Power2Go9*]
LangSecRef=3025
Detect=HKLM\SOFTWARE\Wow6432Node\CyberLink\Power2Go9
Default=False
FileKey1=%ProgramFiles%\CyberLink\Power2Go9\Template\Cyberlink\frame|*.tmp|REMOVESELF
Found these:
C:\Program Files (x86)\CyberLink\Power2Go9\Template\Cyberlink\frame\leg272.tmp    213 KB
C:\Program Files (x86)\CyberLink\Power2Go9\Template\Cyberlink\frame\leg273.tmp    129 KB
C:\Program Files (x86)\CyberLink\Power2Go9\Template\Cyberlink\frame\leg274.tmp    213 KB
C:\Program Files (x86)\CyberLink\Power2Go9\Template\Cyberlink\frame\leg275.tmp    213 KB
C:\Program Files (x86)\CyberLink\Power2Go9\Template\Cyberlink\frame\leg276.tmp    129 KB
C:\Program Files (x86)\CyberLink\Power2Go9\Template\Cyberlink\frame\leg277.tmp    129 KB
C:\Program Files (x86)\CyberLink\Power2Go9\Template\Cyberlink\frame\legB1B.tmp    212 KB
C:\Program Files (x86)\CyberLink\Power2Go9\Template\Cyberlink\frame\legF2.tmp    157 KB
C:\Program Files (x86)\Cyberlink\Power2Go9\Template\Cyberlink\frame\leg272.tmp    213 KB
C:\Program Files (x86)\Cyberlink\Power2Go9\Template\Cyberlink\frame\leg273.tmp    129 KB
C:\Program Files (x86)\Cyberlink\Power2Go9\Template\Cyberlink\frame\leg274.tmp    213 KB
C:\Program Files (x86)\Cyberlink\Power2Go9\Template\Cyberlink\frame\leg275.tmp    213 KB
C:\Program Files (x86)\Cyberlink\Power2Go9\Template\Cyberlink\frame\leg276.tmp    129 KB
C:\Program Files (x86)\Cyberlink\Power2Go9\Template\Cyberlink\frame\leg277.tmp    129 KB
C:\Program Files (x86)\Cyberlink\Power2Go9\Template\Cyberlink\frame\legB1B.tmp    212 KB
C:\Program Files (x86)\Cyberlink\Power2Go9\Template\Cyberlink\frame\legF2.tmp    157 KB
[Windows Defender Cache*]
LangSecRef=3024
DetectOS=|6.1
Detect=HKLM\Software\Microsoft\Windows Defender
Default=False
FileKey1=%CommonAppData%\Microsoft\Windows Defender\Scans|mpcache-*.bin*|RECURSE
C:\ProgramData\Microsoft\Windows Defender\Scans\mpcache-DD6F2CF892AF43896A46CB58CB3AF1A44B0ECBBD.bin    3.009 KB
C:\ProgramData\Microsoft\Windows Defender\Scans\mpcache-DD6F2CF892AF43896A46CB58CB3AF1A44B0ECBBD.bin.67    6.976 KB
C:\ProgramData\Microsoft\Windows Defender\Scans\mpcache-DD6F2CF892AF43896A46CB58CB3AF1A44B0ECBBD.bin.7E    1.960 KB
C:\ProgramData\Microsoft\Windows Defender\Scans\mpcache-DD6F2CF892AF43896A46CB58CB3AF1A44B0ECBBD.bin.80    4.500 KB
C:\ProgramData\Microsoft\Windows Defender\Scans\mpcache-DD6F2CF892AF43896A46CB58CB3AF1A44B0ECBBD.bin.87    680 KB
C:\ProgramData\Microsoft\Windows Defender\Scans\mpcache-DD6F2CF892AF43896A46CB58CB3AF1A44B0ECBBD.bin.A0    3.404 KB
C:\ProgramData\Microsoft\Windows Defender\Scans\mpcache-DD6F2CF892AF43896A46CB58CB3AF1A44B0ECBBD.bin.VE0    47.188 KB
C:\ProgramData\Microsoft\Windows Defender\Scans\mpcache-DD6F2CF892AF43896A46CB58CB3AF1A44B0ECBBD.bin.VE1    3.968 KB
C:\ProgramData\Microsoft\Windows Defender\Scans\mpcache-DD6F2CF892AF43896A46CB58CB3AF1A44B0ECBBD.bin.VF    1.763 KB
[HitManPro*]
LangSecRef=3024
Detect1=HKCU\Software\HitMan Pro
Detect2=HKCU\Software\HitMan Pro 2
Detect3=HKCU\Software\HitMan Pro 3
Detect4=HKLM\SOFTWARE\Wow6432Node\HitmanPro
Default=False
FileKey1=%ProgramFiles%\Hitman Pro*\downloads|*.*
FileKey2=%ProgramFiles%\Hitman Pro*\logs|*.htm
FileKey3=%ProgramFiles%\Hitman Pro*\updates|*.*
FileKey4=%LocalAppData%\VirtualStore\Program Files*\Hitman Pro*\downloads|*.*
FileKey5=%LocalAppData%\VirtualStore\Program Files*\Hitman Pro*\logs|*.htm
FileKey6=%LocalAppData%\VirtualStore\Program Files*\Hitman Pro*\updates|*.*
FileKey7=%CommonAppData%\HitmanPro\Logs|*.*
FileKey8=%LocalAppData%\VirtualStore\ProgramData\HitmanPro\Logs|*.*
Added Detect4, so it will now delete the below logfiles.
Found these:
C:\ProgramData\HitmanPro\Logs\HitmanPro_20130729_1556.log    4 KB
C:\ProgramData\HitmanPro\Logs\HitmanPro_20131217_1850.log    4 KB
C:\ProgramData\HitmanPro\Logs\HitmanPro_20131217_1910.log    4 KB
[HP Install Logs*]
LangSecRef=3021
Detect=HKCU\Software\HP
DetectFile=%CommonAppData%\HP
Default=False
FileKey1=%CommonAppData%|hpzinstall.log
FileKey2=%UserProfile%\All Users|hpzinstall.log
FileKey3=%LocalAppData%\VirtualStore\ProgramData|hpzinstall.log
FileKey4=%AppData%\HP\WebRegLogs|WebRegLog.txt
FileKey5=%SystemDrive%\hp\bin\logs|*.log
FileKey6=%CommonAppData%\Hewlett-Packard|*.log;*Log.txt|RECURSE
FileKey7=%SystemDrive%\SYSTEM.SAV|*.log;*Log.txt|RECURSE
Added Filekey 5-7
Found these:
C:\Users\Galloway\AppData\Roaming\HP\WebRegLogs\WebRegLog.txt    1 KB
C:\hp\bin\logs\CeementUpdate.log    1 KB
C:\hp\bin\logs\wizinstaller.log    1 KB
C:\ProgramData\Hewlett-Packard\HP Client Services\log\MorpheusService.0.log    1,025 KB
C:\ProgramData\Hewlett-Packard\HP Setup\Logs\newBeeClient.log    680 KB
C:\ProgramData\Hewlett-Packard\HP Setup\Logs\rollingHPTCS.log    163 KB
C:\ProgramData\Hewlett-Packard\HP Support Framework\Debug\HPSFDebugLog.txt    5 KB
C:\ProgramData\Hewlett-Packard\Recovery\Log\DEPLOY.log    14 KB
C:\ProgramData\Hewlett-Packard\Recovery\Log\RecoveryCook.log    6 KB
C:\ProgramData\Hewlett-Packard\Recovery\Log\RecoveryOOBE.log    6 KB
C:\ProgramData\Hewlett-Packard\Recovery\Log\RMSCRIPT.LOG    11 KB
C:\ProgramData\Hewlett-Packard\Setup Manager\Logs\dstLog.txt    13 KB
C:\Program Files (x86)\Hewlett-Packard\HP Health Check\ActiveCheck\ACLMlog.log    280 KB
C:\Program Files (x86)\Hewlett-Packard\HP LinkUp\Receiver\setup.log    1 KB
C:\Program Files (x86)\Hewlett-Packard\HP Support Framework\Resources\HPTouchCheck\Resources\VisionDiags\test.log    1 KB
C:\Program Files (x86)\Hewlett-Packard\Recovery\HPRM_BCD_FIX.LOG    1 KB
C:\Program Files (x86)\Hewlett-Packard\Setup Manager\hpDSTResources.Build.CppClean.log    1 KB
C:\SYSTEM.SAV\LOGS\EvtLog.txt    2 KB
C:\SYSTEM.SAV\LOGS\HPU_InstallLog.txt    6 KB
C:\SYSTEM.SAV\LOGS\HPU_MSI_InstallLog.txt    157 KB
C:\SYSTEM.SAV\LOGS\OTP_Symantec_log.txt    220 KB
C:\SYSTEM.SAV\LOGS\softPaqLog.txt    2 KB
C:\SYSTEM.SAV\LOGS\HPEULA.err    1 KB
C:\SYSTEM.SAV\LOGS\AdobeFlash.log    9 KB
C:\SYSTEM.SAV\LOGS\AdobeFlashMsi.log    36 KB
C:\SYSTEM.SAV\LOGS\amazonenvironment.log    7 KB
C:\SYSTEM.SAV\LOGS\amazoninstallenv.log    3 KB
C:\SYSTEM.SAV\LOGS\BingBar.msi_install.log    9,052 KB
C:\SYSTEM.SAV\LOGS\BuildWinRE2.log    17 KB
C:\SYSTEM.SAV\LOGS\ceement.log    152 KB
C:\SYSTEM.SAV\LOGS\checkdhcp.log    2 KB
C:\SYSTEM.SAV\LOGS\eDocsSetup.log    208 KB
C:\SYSTEM.SAV\LOGS\ehelp.log    1 KB
C:\SYSTEM.SAV\LOGS\eHelpSetup.log    797 KB
C:\SYSTEM.SAV\LOGS\HPAA.log    1 KB
C:\SYSTEM.SAV\LOGS\HPAuto_x64.log    173 KB
C:\SYSTEM.SAV\LOGS\HPBranding.log    1 KB
C:\SYSTEM.SAV\LOGS\HPClientService_x64.log    184 KB
C:\SYSTEM.SAV\LOGS\hpdownloadstoreenv.log    3 KB
C:\SYSTEM.SAV\LOGS\hpdownloadstoreenvironment.log    6 KB
C:\SYSTEM.SAV\LOGS\HPFeedback.log    3 KB
C:\SYSTEM.SAV\LOGS\HPMovieStore.log    1 KB
C:\SYSTEM.SAV\LOGS\hpmuidir.log    1 KB
C:\SYSTEM.SAV\LOGS\HPSA.log    46 KB
C:\SYSTEM.SAV\LOGS\HPTouchSmartRecipeBox_msi.log    6 KB
C:\SYSTEM.SAV\LOGS\HPWallpaper.log    4 KB
C:\SYSTEM.SAV\LOGS\install_FPP.log    178 KB
C:\SYSTEM.SAV\LOGS\Kobo.log    1 KB
C:\SYSTEM.SAV\LOGS\LaunchEzSetup.log    1 KB
C:\SYSTEM.SAV\LOGS\MCTutorials.log    11 KB
C:\SYSTEM.SAV\LOGS\MDXredist.log.log    14 KB
C:\SYSTEM.SAV\LOGS\MSOffice2010.log    5 KB
C:\SYSTEM.SAV\LOGS\nis.log    1 KB
C:\SYSTEM.SAV\LOGS\PDFComplete.log    6 KB
C:\SYSTEM.SAV\LOGS\PostUser.log    1 KB
C:\SYSTEM.SAV\LOGS\postwizinstaller.log    1 KB
C:\SYSTEM.SAV\LOGS\preuser.log    1 KB
C:\SYSTEM.SAV\LOGS\PT_OTP.Log    13 KB
C:\SYSTEM.SAV\LOGS\PT_VIP.Log    12 KB
C:\SYSTEM.SAV\LOGS\PT_VIP_Setup.Log    2 KB
C:\SYSTEM.SAV\LOGS\RealtekAudio_Setup.log    1 KB
C:\SYSTEM.SAV\LOGS\SetEnvVarsfpp.log    1 KB
C:\SYSTEM.SAV\LOGS\SetFPPEnv_StartFPP.log    37 KB
C:\SYSTEM.SAV\LOGS\vcredist_x64.log    346 KB
C:\SYSTEM.SAV\LOGS\vcw.log    1 KB
C:\SYSTEM.SAV\LOGS\WildTangent.log    41 KB
C:\SYSTEM.SAV\LOGS\WizInstaller.log    633 KB
C:\SYSTEM.SAV\LOGS\WizInstallerEnv.log    19 KB
C:\SYSTEM.SAV\LOGS\WMC.log    2 KB
C:\SYSTEM.SAV\LOGS\drivers\drivers.log.txt    524 KB
C:\SYSTEM.SAV\LOGS\GenMLTXTFiles\CheckBIDFB.log    2 KB
C:\SYSTEM.SAV\LOGS\GenMLTXTFiles\cpcinfo.log    29 KB
C:\SYSTEM.SAV\LOGS\GenMLTXTFiles\GenMLTXTFiles-Pass1.log    1 KB
C:\SYSTEM.SAV\LOGS\GenMLTXTFiles\GenMLTXTFiles-Pass2.log    0 KB
C:\SYSTEM.SAV\LOGS\GenMLTXTFiles\GenMLTXTFiles.log    26 KB
C:\SYSTEM.SAV\LOGS\GenMLTXTFiles\GenMLTXTFiles2.log    3 KB
C:\SYSTEM.SAV\LOGS\GenMLTXTFiles\hwd_master\GenMLTXTFiles-Pass2.log    0 KB
C:\SYSTEM.SAV\LOGS\HPSmartCenter\InstallLog.txt    4 KB
C:\SYSTEM.SAV\LOGS\HPSmartCenter\MSI_InstallLog.txt    92 KB
C:\SYSTEM.SAV\LOGS\IE9\IE9_BASE.LOG    435 KB
C:\SYSTEM.SAV\LOGS\MS1LOGS\MS1RUN.LOG    1 KB
C:\SYSTEM.SAV\LOGS\MS3LOGS\MS3RUN.LOG    16 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2393802.log.txt    90 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2425227.log.txt    102 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2475792.log.txt    116 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2479943.log.txt    153 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2484033.log.txt    215 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2485376.log.txt    153 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2488113.log.txt    145 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2491683.log.txt    91 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2492386.log.txt    399 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2496898.log.txt    769 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2503665.log.txt    104 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2505438.log.txt    125 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2505454.log.txt    101 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2506014.log.txt    166 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2506212.log.txt    157 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2506928.log.txt    93 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2507618.log.txt    184 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2509553.log.txt    103 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2510531.log.txt    121 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2511250.log.txt    198 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2515325.log.txt    97 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2529073.log.txt    137 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2532531.log.txt    93 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2536275.log.txt    120 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2536276.log.txt    125 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2541014.log.txt    92 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2544521.log.txt    90 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2544893.log.txt    98 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2545698.log.txt    183 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2547666.log.txt    157 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2552343.log.txt    165 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2556532.log.txt    182 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2560656.log.txt    376 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2561821.log.txt    96 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2562937.log.txt    96 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2563227.log.txt    160 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2563894.log.txt    98 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2564958.log.txt    232 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2567053.log.txt    159 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2567680.log.txt    421 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2570791.log.txt    1,709 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2570947.log.txt    157 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2579686.log.txt    219 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2586448.log.txt    828 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB2616676.log.txt    100 KB
C:\SYSTEM.SAV\LOGS\qfelogs\KB982018.log.txt    990 KB
C:\SYSTEM.SAV\LOGS\Recovery\DEPLOY.log    14 KB
C:\SYSTEM.SAV\LOGS\Recovery\RecoveryCook.log    6 KB
C:\SYSTEM.SAV\LOGS\Recovery\RecoveryOOBE.log    6 KB
C:\SYSTEM.SAV\LOGS\Recovery\RMSCRIPT.LOG    11 KB
C:\SYSTEM.SAV\LOGS\TouchSmart\Facebook.log    1 KB
C:\SYSTEM.SAV\LOGS\TouchSmart\HPCalendar.log    1 KB
C:\SYSTEM.SAV\LOGS\TouchSmart\HPCalendar_msi.log    7 KB
C:\SYSTEM.SAV\LOGS\TouchSmart\HPClock.log    1 KB
C:\SYSTEM.SAV\LOGS\TouchSmart\HPClock_msi.log    6 KB
C:\SYSTEM.SAV\LOGS\TouchSmart\HPNotes.log    1 KB
C:\SYSTEM.SAV\LOGS\TouchSmart\HPNotes_msi.log    7 KB
C:\SYSTEM.SAV\LOGS\TouchSmart\HPRss.log    2 KB
C:\SYSTEM.SAV\LOGS\TouchSmart\HPRss_msi.log    11 KB
C:\SYSTEM.SAV\LOGS\TouchSmart\HPWeather.log    2 KB
C:\SYSTEM.SAV\LOGS\TouchSmart\TSRecipeBox.log    2 KB
C:\SYSTEM.SAV\LOGS\TouchSmart\wizinstaller.log    2 KB
C:\SYSTEM.SAV\LOGS\windows\setupact.log    510 KB
C:\SYSTEM.SAV\LOGS\windows\setupapi.dev.log    2,981 KB
C:\SYSTEM.SAV\LOGS\windows\setupapi.offline.log    4,685 KB
C:\SYSTEM.SAV\LOGS\windows\setuperr.log    0 KB
C:\SYSTEM.SAV\LOGS\windows\UnattendGC_setupact.log    40 KB
C:\SYSTEM.SAV\LOGS\windows\UnattendGC_setuperr.log    0 KB
C:\SYSTEM.SAV\LOGS\windows\WindowsUpdate.log    5 KB
C:\SYSTEM.SAV\LOGS\windows\winsat.log    24 KB
C:\SYSTEM.SAV\LOGS\WLive\2012-02-29_16-32_c8c-sx06aw43.log    614 KB
C:\SYSTEM.SAV\util\INSTALL.LOG    918 KB
[HP Install Temps*]
LangSecRef=3021
Default=False
FileKey1=%CommonAppData%\HP\Installer\Temp|*.*
FileKey2=%CommonAppData%\HP\Temp|*.*
FileKey3=%ProgramFiles%\HP\Temp|*.*|RECURSE
FileKey4=%UserProfile%\All Users\HP\Installer\Temp|*.*
FileKey5=%LocalAppData%\VirtualStore\Program Files*\HP\Temp|*.*|RECURSE
FileKey6=%LocalAppData%\VirtualStore\ProgramData\HP\Installer\Temp|*.*
FileKey7=%LocalAppData%\VirtualStore\ProgramData\HP\Temp|*.*
FileKey8=%WinDir%|*.dat.temp
Found these:
C:\Windows\hpoins37.dat.temp    169 KB
C:\Windows\hpomdl37.dat.temp    1 KB
[HP Installation Files*]
LangSecRef=3024
DetectFile1=%SystemDrive%\swsetup
DetectFile2=%SystemDrive%\HP Universal Print Driver
Default=False
Warning=This will delete your HP installation files.
FileKey1=%SystemDrive%\swsetup|*.*|REMOVESELF
FileKey2=%SystemDrive%\HP Universal Print Driver|*.*|REMOVESELF
Found these, but normally they should be deleted, you might ask CSGalloway:
C:\SWSETUP\APP\PreReq2\HP\HPVision\1c12\src\vision.log    3,407 KB
C:\SWSETUP\APP\Support\HP\HPSA\6.1\src\HPSA\setup.log    1 KB
C:\SWSETUP\SP58915\setup.log    1 KB
C:\SWSETUP\SP64126\setup.log    1 KB
C:\SWSETUP\APP\Applications\CyberLink\LabelPrint\2.5.4507\src\setup.log    1 KB
C:\SWSETUP\APP\Applications\CyberLink\Power2Go\6.1.5705\src\setup.log    1 KB
[backup Assist*]
LangSecRef=3024
DetectFile=%SystemDrive%\Z_UserFiles
Default=False
FileKey1=%SystemDrive%\Z_UserFiles|*.err;*log.txt;*.log;*.diz;*.old;CHKLIST.MS|RECURSE
Found these on CSGalloways list:
C:\Z_UserFiles\JPSoft\ERR_000\TCC_10.00_76.err    1 KB
C:\Z_UserFiles\JPSoft\ERR_000\TCC_11.00_38.err    1 KB
C:\Z_UserFiles\JPSoft\ERR_000\TCC_9.02_157.err    1 KB
C:\Z_UserFiles\JPSoft\ERR_000\TCMD32_8.02_106.err    1 KB
C:\Z_UserFiles\Office\TXT_000\Active Setup Log.txt    11 KB
C:\Z_UserFiles\Office\TXT_000\altlog.txt    84 KB
C:\Z_UserFiles\Office\TXT_000\BOOTLOG.TXT    1 KB
C:\Z_UserFiles\Office\TXT_000\brndlog.txt    1 KB
C:\Z_UserFiles\Office\TXT_000\C55LOG.TXT    1 KB
C:\Z_UserFiles\Office\TXT_000\ChangeLog.txt    5 KB
C:\Z_UserFiles\Office\TXT_000\FAULTLOG.TXT    131 KB
C:\Z_UserFiles\Office\TXT_000\FFASTLOG.TXT    23 KB
C:\Z_UserFiles\Office\TXT_000\Fix IE Log.txt    12 KB
C:\Z_UserFiles\Office\TXT_000\fwlog.txt    1 KB
C:\Z_UserFiles\Office\TXT_000\HunterErrorLog.txt    1 KB
C:\Z_UserFiles\Office\TXT_000\IE Uninstall Log.Txt    73 KB
C:\Z_UserFiles\Office\TXT_000\INSTLOG.TXT    1 KB
C:\Z_UserFiles\Office\TXT_000\log.txt    1,150 KB
C:\Z_UserFiles\Office\TXT_000\mmjblog.txt    126 KB
C:\Z_UserFiles\Office\TXT_000\musicnet_aol-040926-log.txt    9 KB
C:\Z_UserFiles\Office\TXT_000\NDISLOG.TXT    0 KB
C:\Z_UserFiles\Office\TXT_000\NETLOG.TXT    48 KB
C:\Z_UserFiles\Office\TXT_000\NEWSLOG.TXT    3 KB
C:\Z_UserFiles\Office\TXT_000\OEWABLog.txt    3 KB
C:\Z_UserFiles\Office\TXT_000\old_log.txt    41 KB
C:\Z_UserFiles\Office\TXT_000\RealArcade-log.txt    7 KB
C:\Z_UserFiles\Office\TXT_000\RealPlayer-log.txt    14 KB
C:\Z_UserFiles\Office\TXT_000\Reg Restore Log.txt    7 KB
C:\Z_UserFiles\Office\TXT_000\Reg Save Log.txt    3 KB
C:\Z_UserFiles\Office\TXT_000\resetlog.txt    5 KB
C:\Z_UserFiles\Office\TXT_000\SchedLog.Txt    32 KB
C:\Z_UserFiles\Office\TXT_000\setuplog.txt    730 KB
C:\Z_UserFiles\Office\TXT_000\Update-log.txt    1 KB
C:\Z_UserFiles\Office\TXT_000\UserActionLog.txt    127 KB
C:\Z_UserFiles\Office\TXT_000\WebRegLog.txt    2 KB
C:\Z_UserFiles\Office\TXT_000\wplog.txt    0 KB
C:\Z_UserFiles\Office\TXT_000\Logged.txt    16 KB
C:\Z_UserFiles\Office\TXT_000\LOGIN.TXT    1 KB
C:\Z_UserFiles\Office\TXT_000\LOGS.txt    64 KB
C:\Z_UserFiles\Office\TXT_001\BOOTLOG.TXT    131 KB
C:\Z_UserFiles\Office\TXT_001\FAULTLOG.TXT    131 KB
C:\Z_UserFiles\Office\TXT_001\Fix IE Log.txt    12 KB
C:\Z_UserFiles\Office\TXT_001\HunterErrorLog.txt    0 KB
C:\Z_UserFiles\Office\TXT_001\IE Uninstall Log.Txt    73 KB
C:\Z_UserFiles\Office\TXT_001\log.txt    270 KB
C:\Z_UserFiles\Office\TXT_001\OEWABLog.txt    3 KB
C:\Z_UserFiles\Office\TXT_001\RealPlayer-log.txt    37 KB
C:\Z_UserFiles\Office\TXT_001\Reg Restore Log.txt    7 KB
C:\Z_UserFiles\Office\TXT_001\SETUPLOG.TXT    128 KB
C:\Z_UserFiles\Office\TXT_001\LOGIN.TXT    1 KB
C:\Z_UserFiles\Office\TXT_002\log.txt    26 KB
C:\Z_UserFiles\Unkn\---_000\MSOFFICE.---    1 KB
C:\Z_UserFiles\Unkn\---_000\POWERPNT.---    1 KB
C:\Z_UserFiles\Unkn\---_000\PROTOCOL.---    1 KB
C:\Z_UserFiles\Unkn\---_000\QTW.---    1 KB
C:\Z_UserFiles\Unkn\---_000\SYSTEM.---    3 KB
C:\Z_UserFiles\Unkn\---_000\WIN.---    10 KB
C:\Z_UserFiles\Unkn\BAK_000\settings.bak    5 KB
C:\Z_UserFiles\Unkn\DIZ_000\file_id(0).diz    1 KB
C:\Z_UserFiles\Unkn\DIZ_000\file_id(1).diz    1 KB
C:\Z_UserFiles\Unkn\DIZ_000\file_id(2).diz    1 KB
C:\Z_UserFiles\Unkn\DIZ_000\file_id(3).diz    1 KB
C:\Z_UserFiles\Unkn\DIZ_000\file_id(4).diz    1 KB
C:\Z_UserFiles\Unkn\DIZ_000\file_id(5).diz    1 KB
C:\Z_UserFiles\Unkn\DIZ_000\file_id(6).diz    1 KB
C:\Z_UserFiles\Unkn\DIZ_000\file_id.diz    1 KB
C:\Z_UserFiles\Unkn\DIZ_000\vendinfo.diz    17 KB
C:\Z_UserFiles\Unkn\DIZ_001\FILE_ID.DIZ    1 KB
C:\Z_UserFiles\Unkn\DIZ_002\File_id.diz    1 KB
C:\Z_UserFiles\Unkn\DIZ_003\file_id.diz    1 KB
C:\Z_UserFiles\Unkn\DIZ_004\File_id.diz    1 KB
C:\Z_UserFiles\Unkn\DIZ_005\FILE_ID.DIZ    1 KB
C:\Z_UserFiles\Unkn\DIZ_006\FILE_ID.DIZ    1 KB
C:\Z_UserFiles\Unkn\DIZ_007\FILE_ID.DIZ    1 KB
C:\Z_UserFiles\Unkn\DIZ_008\FILE_ID.DIZ    1 KB
C:\Z_UserFiles\Unkn\DIZ_009\file_id.diz    1 KB
C:\Z_UserFiles\Unkn\FTG_000\CTDetect.ftg    0 KB
C:\Z_UserFiles\Unkn\ILK_000\tcsh-x86.ilk    1,524 KB
C:\Z_UserFiles\Unkn\INI_000\errorlog.ini    101 KB
C:\Z_UserFiles\Unkn\LOG_000\#0!!!!!!!!cumthirsty_girls.DALnet.20031010.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\#0!!!!!NudeInPublic.DALnet.20030902.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\#0!!!!!NudeInPublic.DALnet.20030909.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\#0!fantasyf***sluts.DALnet.20030902.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\#0!fantasyf***sluts.DALnet.20030909.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\#0!f***mywife.DALnet.20030902.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\#0!f***mywife.DALnet.20040119.log    2 KB
C:\Z_UserFiles\Unkn\LOG_000\#30+masturbation.DALnet.20030902.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\#30+masturbation.DALnet.20030909.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\#30+masturbation.DALnet.20030911.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\#30+masturbation.DALnet.20031010.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\#30+masturbation.DALnet.20031013.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\#30+masturbation.DALnet.20031018.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\#30+masturbation.DALnet.20040119.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\#30+masturbation.UnderNet.20030911.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\#30+masturbation.UnderNet.20031010.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\#asians.DALnet.20030902.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\#asians.DALnet.20030909.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\#asians.DALnet.20030911.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\#asians.DALnet.20031010.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\#asians.DALnet.20031013.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\#asians.DALnet.20031018.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\#asians.DALnet.20040119.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\#asians.UnderNet.20030911.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\#asians.UnderNet.20031010.log    2 KB
C:\Z_UserFiles\Unkn\LOG_000\#bedsex.DALnet.20040119.log    4 KB
C:\Z_UserFiles\Unkn\LOG_000\#celebs-n-models.20040701.log    227 KB
C:\Z_UserFiles\Unkn\LOG_000\#celebs_n_models.20040701.log    227 KB
C:\Z_UserFiles\Unkn\LOG_000\#cocksuckingwhores.20040901.log    198 KB
C:\Z_UserFiles\Unkn\LOG_000\#cocksuckingwhores.20041001.log    4 KB
C:\Z_UserFiles\Unkn\LOG_000\#cocksuckingwhores.20041101.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\#cocksuckingwhores.20050201.log    8 KB
C:\Z_UserFiles\Unkn\LOG_000\#cocksuckingwhores.20050401.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\#familysex.DALnet.20040119.log    14 KB
C:\Z_UserFiles\Unkn\LOG_000\#Hottub.DALnet.20031018.log    6 KB
C:\Z_UserFiles\Unkn\LOG_000\#nwofamily.20040601.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\#pune.DALnet.20040119.log    3 KB
C:\Z_UserFiles\Unkn\LOG_000\#SENSUALSEX.20040901.log    259 KB
C:\Z_UserFiles\Unkn\LOG_000\#sensualsex.20041001.log    6 KB
C:\Z_UserFiles\Unkn\LOG_000\#sensualsex.20041101.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\#sensualsex.20050201.log    13 KB
C:\Z_UserFiles\Unkn\LOG_000\#sensualsex.20050401.log    4 KB
C:\Z_UserFiles\Unkn\LOG_000\#SexpicsFservers.20040901.log    94 KB
C:\Z_UserFiles\Unkn\LOG_000\#sextalk.20040901.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\#sexy.DALnet.20040119.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\#sp.com.20040601.log    12 KB
C:\Z_UserFiles\Unkn\LOG_000\#sp.com.20040701.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\#sp.com.20040901.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\#sp.com.20041001.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\#sp.com.20041101.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\#sp.com.20050201.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\#sp.com.20050401.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\20021230.log    12 KB
C:\Z_UserFiles\Unkn\LOG_000\2007-11-07_19-49_120c.log    29 KB
C:\Z_UserFiles\Unkn\LOG_000\2008-01-29_17-56_1620.log    8 KB
C:\Z_UserFiles\Unkn\LOG_000\2008-04-25_23-56_1490.log    30 KB
C:\Z_UserFiles\Unkn\LOG_000\2008-05-25_22-13_1818.log    11 KB
C:\Z_UserFiles\Unkn\LOG_000\2008-08-11_21-22_6f0.log    11 KB
C:\Z_UserFiles\Unkn\LOG_000\2008-08-11_22-09_8a0.log    11 KB
C:\Z_UserFiles\Unkn\LOG_000\2008-08-11_22-20_1600.log    22 KB
C:\Z_UserFiles\Unkn\LOG_000\2013_0217_230912_CHARLES_G_RoboForm_Online.log    4 KB
C:\Z_UserFiles\Unkn\LOG_000\2013_0218_091050_CHARLES_G_RoboForm_Online.log    3 KB
C:\Z_UserFiles\Unkn\LOG_000\2013_0221_151059_CHARLES_G_RoboForm_Online.log    4 KB
C:\Z_UserFiles\Unkn\LOG_000\2013_0224_004044_CHARLES_G_RoboForm_Online.log    4 KB
C:\Z_UserFiles\Unkn\LOG_000\AD-Windows_Live_Mail__04262008_00-00.log    10 KB
C:\Z_UserFiles\Unkn\LOG_000\AD-Windows_Live_Messenger__08112008_22-22.log    9 KB
C:\Z_UserFiles\Unkn\LOG_000\AD-Windows_Live_Messenger__11072007_19-51.log    9 KB
C:\Z_UserFiles\Unkn\LOG_000\AD-Windows_Live_Sign-in_Assistant__04262008_00-02.log    9 KB
C:\Z_UserFiles\Unkn\LOG_000\AD-Windows_Live_Sign-in_Assistant__11072007_19-52.log    9 KB
C:\Z_UserFiles\Unkn\LOG_000\agent.log    937 KB
C:\Z_UserFiles\Unkn\LOG_000\Ashlar.20040701.log    2 KB
C:\Z_UserFiles\Unkn\LOG_000\audio.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\autosave.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\backup.log    3 KB
C:\Z_UserFiles\Unkn\LOG_000\Bamoose.20040901.log    2 KB
C:\Z_UserFiles\Unkn\LOG_000\BH.LOG    1,905 KB
C:\Z_UserFiles\Unkn\LOG_000\Birdhunter.20040701.log    11 KB
C:\Z_UserFiles\Unkn\LOG_000\blastcln.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\ccAlert.log    16 KB
C:\Z_UserFiles\Unkn\LOG_000\CCAPP.LOG    146 KB
C:\Z_UserFiles\Unkn\LOG_000\ccEmlPxy.log    96 KB
C:\Z_UserFiles\Unkn\LOG_000\ccEvtMgr.log    123 KB
C:\Z_UserFiles\Unkn\LOG_000\ccLgView.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\ccProd.log    14 KB
C:\Z_UserFiles\Unkn\LOG_000\ccPwdSvc.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\ccSetMgr.log    48 KB
C:\Z_UserFiles\Unkn\LOG_000\ccVrTrst.log    52 KB
C:\Z_UserFiles\Unkn\LOG_000\CFGWIZ-NAV.log    2 KB
C:\Z_UserFiles\Unkn\LOG_000\CFGWIZ_NAV.log    2 KB
C:\Z_UserFiles\Unkn\LOG_000\CherryPopper.DALnet.20031010.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\Chr_stof.20040701.log    45 KB
C:\Z_UserFiles\Unkn\LOG_000\CleanUp!.log    7 KB
C:\Z_UserFiles\Unkn\LOG_000\CloneSpy.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\cmsetacl.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\command.log    8 KB
C:\Z_UserFiles\Unkn\LOG_000\comsetup.log    142 KB
C:\Z_UserFiles\Unkn\LOG_000\CRSWPP.LOG    1 KB
C:\Z_UserFiles\Unkn\LOG_000\dahotfix.log    18 KB
C:\Z_UserFiles\Unkn\LOG_000\Decrap.log    134 KB
C:\Z_UserFiles\Unkn\LOG_000\DefAlert.log    16 KB
C:\Z_UserFiles\Unkn\LOG_000\default.LOG    1 KB
C:\Z_UserFiles\Unkn\LOG_000\Dir.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\DirectX.log    79 KB
C:\Z_UserFiles\Unkn\LOG_000\Dirhist.log    0 KB
C:\Z_UserFiles\Unkn\LOG_000\DtcInstall.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\dw.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\EasyClea.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\edb00081.log    128 KB
C:\Z_UserFiles\Unkn\LOG_000\error.log    0 KB
C:\Z_UserFiles\Unkn\LOG_000\EVOLVE.LOG    8 KB
C:\Z_UserFiles\Unkn\LOG_000\FaxSetup.log    389 KB
C:\Z_UserFiles\Unkn\LOG_000\FILEPANE.LOG    1 KB
C:\Z_UserFiles\Unkn\LOG_000\FltrInst1.log    74 KB
C:\Z_UserFiles\Unkn\LOG_000\GatorHDPlugin.log-old.log    8 KB
C:\Z_UserFiles\Unkn\LOG_000\GatorHDPlugin.log_old.log    8 KB
C:\Z_UserFiles\Unkn\LOG_000\GatorPdpSetup.log    19 KB
C:\Z_UserFiles\Unkn\LOG_000\helpctr.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\history.log    99 KB
C:\Z_UserFiles\Unkn\LOG_000\HotBlonde.20050201.log    2 KB
C:\Z_UserFiles\Unkn\LOG_000\hpqrrx08.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\I-Windows_Live_Mail__04262008_00-00.log    806 KB
C:\Z_UserFiles\Unkn\LOG_000\I-Windows_Live_Messenger__08112008_22-22.log    1,175 KB
C:\Z_UserFiles\Unkn\LOG_000\I-Windows_Live_Messenger__11072007_19-51.log    1,175 KB
C:\Z_UserFiles\Unkn\LOG_000\I-Windows_Live_Sign-in_Assistant__04262008_00-02.log    130 KB
C:\Z_UserFiles\Unkn\LOG_000\I-Windows_Live_Sign-in_Assistant__11072007_19-52.log    230 KB
C:\Z_UserFiles\Unkn\LOG_000\IEPatchUninstall.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\iis6.log    478 KB
C:\Z_UserFiles\Unkn\LOG_000\IMScan.log    8 KB
C:\Z_UserFiles\Unkn\LOG_000\imsins.log    2 KB
C:\Z_UserFiles\Unkn\LOG_000\INNERINSTALL.LOG    3 KB
C:\Z_UserFiles\Unkn\LOG_000\INSTALL.LOG    300 KB
C:\Z_UserFiles\Unkn\LOG_000\JohnZee.DALnet.20040119.log    2 KB
C:\Z_UserFiles\Unkn\LOG_000\JPSOFT.LOG    5 KB
C:\Z_UserFiles\Unkn\LOG_000\jupdate-1.4.2_03-b02.log    3 KB
C:\Z_UserFiles\Unkn\LOG_000\jupdate-1.4.2_05-b04.log    3 KB
C:\Z_UserFiles\Unkn\LOG_000\jupdate-1.4.2_06-b03.log    4 KB
C:\Z_UserFiles\Unkn\LOG_000\jupdate-1.5.0_01-b08.log    3 KB
C:\Z_UserFiles\Unkn\LOG_000\jupdate-1.5.0_02-b09.log    3 KB
C:\Z_UserFiles\Unkn\LOG_000\jupdate_1.4.2_03_b02.log    3 KB
C:\Z_UserFiles\Unkn\LOG_000\jupdate_1.4.2_05_b04.log    3 KB
C:\Z_UserFiles\Unkn\LOG_000\jupdate_1.4.2_06_b03.log    4 KB
C:\Z_UserFiles\Unkn\LOG_000\jupdate_1.5.0_01_b08.log    3 KB
C:\Z_UserFiles\Unkn\LOG_000\jupdate_1.5.0_02_b09.log    3 KB
C:\Z_UserFiles\Unkn\LOG_000\KB810243.log    15 KB
C:\Z_UserFiles\Unkn\LOG_000\KB817778.log    9 KB
C:\Z_UserFiles\Unkn\LOG_000\KB820291.log    8 KB
C:\Z_UserFiles\Unkn\LOG_000\KB821253.log    6 KB
C:\Z_UserFiles\Unkn\LOG_000\KB822603.log    6 KB
C:\Z_UserFiles\Unkn\LOG_000\KB823182.log    17 KB
C:\Z_UserFiles\Unkn\LOG_000\KB824105.log    22 KB
C:\Z_UserFiles\Unkn\LOG_000\KB824141.log    18 KB
C:\Z_UserFiles\Unkn\LOG_000\KB824146.log    18 KB
C:\Z_UserFiles\Unkn\LOG_000\KB825119.log    9 KB
C:\Z_UserFiles\Unkn\LOG_000\KB826939.log    25 KB
C:\Z_UserFiles\Unkn\LOG_000\KB826942.log    12 KB
C:\Z_UserFiles\Unkn\LOG_000\KB828028.log    8 KB
C:\Z_UserFiles\Unkn\LOG_000\KB828035.log    10 KB
C:\Z_UserFiles\Unkn\LOG_000\KB828741.log    11 KB
C:\Z_UserFiles\Unkn\LOG_000\KB829558.log    7 KB
C:\Z_UserFiles\Unkn\LOG_000\KB833998.log    5 KB
C:\Z_UserFiles\Unkn\LOG_000\KB834707.log    8 KB
C:\Z_UserFiles\Unkn\LOG_000\KB835732.log    15 KB
C:\Z_UserFiles\Unkn\LOG_000\KB837001.log    4 KB
C:\Z_UserFiles\Unkn\LOG_000\KB837272.log    4 KB
C:\Z_UserFiles\Unkn\LOG_000\KB839643-DirectX9.log    4 KB
C:\Z_UserFiles\Unkn\LOG_000\KB839643_DirectX9.log    4 KB
C:\Z_UserFiles\Unkn\LOG_000\KB839645.log    8 KB
C:\Z_UserFiles\Unkn\LOG_000\KB840315.log    5 KB
C:\Z_UserFiles\Unkn\LOG_000\KB840374.log    18 KB
C:\Z_UserFiles\Unkn\LOG_000\KB841873.log    6 KB
C:\Z_UserFiles\Unkn\LOG_000\KB842773.log    6 KB
C:\Z_UserFiles\Unkn\LOG_000\KB867282.log    11 KB
C:\Z_UserFiles\Unkn\LOG_000\KB873333.log    16 KB
C:\Z_UserFiles\Unkn\LOG_000\KB873339.log    10 KB
C:\Z_UserFiles\Unkn\LOG_000\KB883939.log    17 KB
C:\Z_UserFiles\Unkn\LOG_000\KB885250.log    11 KB
C:\Z_UserFiles\Unkn\LOG_000\KB885295.log    4 KB
C:\Z_UserFiles\Unkn\LOG_000\KB885835.log    11 KB
C:\Z_UserFiles\Unkn\LOG_000\KB885836.log    10 KB
C:\Z_UserFiles\Unkn\LOG_000\KB886185.log    6 KB
C:\Z_UserFiles\Unkn\LOG_000\KB887742.log    10 KB
C:\Z_UserFiles\Unkn\LOG_000\KB887797.log    10 KB
C:\Z_UserFiles\Unkn\LOG_000\KB888113.log    14 KB
C:\Z_UserFiles\Unkn\LOG_000\KB888302.log    10 KB
C:\Z_UserFiles\Unkn\LOG_000\KB890046.log    11 KB
C:\Z_UserFiles\Unkn\LOG_000\KB890047.log    11 KB
C:\Z_UserFiles\Unkn\LOG_000\KB890175.log    10 KB
C:\Z_UserFiles\Unkn\LOG_000\KB890859.log    14 KB
C:\Z_UserFiles\Unkn\LOG_000\KB890923.log    17 KB
C:\Z_UserFiles\Unkn\LOG_000\KB891781.log    11 KB
C:\Z_UserFiles\Unkn\LOG_000\KB893066.log    27 KB
C:\Z_UserFiles\Unkn\LOG_000\KB893086.log    13 KB
C:\Z_UserFiles\Unkn\LOG_000\KB893803.log    5 KB
C:\Z_UserFiles\Unkn\LOG_000\KB893803v2.log    5 KB
C:\Z_UserFiles\Unkn\LOG_000\KB894391.log    8 KB
C:\Z_UserFiles\Unkn\LOG_000\KB896358.log    12 KB
C:\Z_UserFiles\Unkn\LOG_000\KB896422.log    16 KB
C:\Z_UserFiles\Unkn\LOG_000\KB896428.log    10 KB
C:\Z_UserFiles\Unkn\LOG_000\KB898461.log    7 KB
C:\Z_UserFiles\Unkn\LOG_000\LogA-0002.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\LogA_0002.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\LUINSTALL.LOG    22 KB
C:\Z_UserFiles\Unkn\LOG_000\ME100X.LOG    4 KB
C:\Z_UserFiles\Unkn\LOG_000\ME100XC.LOG    8 KB
C:\Z_UserFiles\Unkn\LOG_000\ME110.LOG    1 KB
C:\Z_UserFiles\Unkn\LOG_000\ME110CMD.LOG    1 KB
C:\Z_UserFiles\Unkn\LOG_000\ME110X.LOG    1 KB
C:\Z_UserFiles\Unkn\LOG_000\ME110XC.LOG    3 KB
C:\Z_UserFiles\Unkn\LOG_000\ME91X.LOG    4 KB
C:\Z_UserFiles\Unkn\LOG_000\ME91XC.LOG    4 KB
C:\Z_UserFiles\Unkn\LOG_000\ME9X.LOG    1 KB
C:\Z_UserFiles\Unkn\LOG_000\ME9XC.LOG    1 KB
C:\Z_UserFiles\Unkn\LOG_000\MedCtrOC.log    28 KB
C:\Z_UserFiles\Unkn\LOG_000\Mikeeee.20040901.log    2 KB
C:\Z_UserFiles\Unkn\LOG_000\MMPlayPref.log    5 KB
C:\Z_UserFiles\Unkn\LOG_000\mofcomp.log    15 KB
C:\Z_UserFiles\Unkn\LOG_000\MONWOW0.LOG    1 KB
C:\Z_UserFiles\Unkn\LOG_000\MrbStat.log    0 KB
C:\Z_UserFiles\Unkn\LOG_000\mrt.log    3 KB
C:\Z_UserFiles\Unkn\LOG_000\msgsocm.log    20 KB
C:\Z_UserFiles\Unkn\LOG_000\msmqinst.log    130 KB
C:\Z_UserFiles\Unkn\LOG_000\MSP5900-U Modem.log    2 KB
C:\Z_UserFiles\Unkn\LOG_000\MSP5900_U_Modem.log    2 KB
C:\Z_UserFiles\Unkn\LOG_000\msshlib2.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\MyCustom.log    6 KB
C:\Z_UserFiles\Unkn\LOG_000\MYDEFRAG.LOG    1 KB
C:\Z_UserFiles\Unkn\LOG_000\NAVAPSCR.log    5 KB
C:\Z_UserFiles\Unkn\LOG_000\NAVAPW32.LOG    43 KB
C:\Z_UserFiles\Unkn\LOG_000\NAVCfgWizDll.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\NavEmail.log    5 KB
C:\Z_UserFiles\Unkn\LOG_000\NAVEvent.log    5 KB
C:\Z_UserFiles\Unkn\LOG_000\NAVInst.log    6 KB
C:\Z_UserFiles\Unkn\LOG_000\Navlcom.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\NAVLUCBK.LOG    15 KB
C:\Z_UserFiles\Unkn\LOG_000\NAVOptRf.log    3 KB
C:\Z_UserFiles\Unkn\LOG_000\NAVOpts.log    5 KB
C:\Z_UserFiles\Unkn\LOG_000\NAVSTATS.log    5 KB
C:\Z_UserFiles\Unkn\LOG_000\NAVTasks.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\NAVUI.log    18 KB
C:\Z_UserFiles\Unkn\LOG_000\netfxocm.log    67 KB
C:\Z_UserFiles\Unkn\LOG_000\NetSetup.LOG    5 KB
C:\Z_UserFiles\Unkn\LOG_000\Norton Rescue.LOG    1 KB
C:\Z_UserFiles\Unkn\LOG_000\Norton SystemWorks.LOG    1 KB
C:\Z_UserFiles\Unkn\LOG_000\Norton_Rescue.LOG    1 KB
C:\Z_UserFiles\Unkn\LOG_000\Norton_SystemWorks.LOG    1 KB
C:\Z_UserFiles\Unkn\LOG_000\NsA.20040901.log    31 KB
C:\Z_UserFiles\Unkn\LOG_000\ntdtcsetup.log    86 KB
C:\Z_UserFiles\Unkn\LOG_000\ntuser.dat.LOG    1 KB
C:\Z_UserFiles\Unkn\LOG_000\ocgen.log    206 KB
C:\Z_UserFiles\Unkn\LOG_000\ocmsn.log    19 KB
C:\Z_UserFiles\Unkn\LOG_000\offitems.log    240 KB
C:\Z_UserFiles\Unkn\LOG_000\Parallel cable on LPT1.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\Parallel_cable_on_LPT1.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\Pics_Plus.20040901.log    28 KB
C:\Z_UserFiles\Unkn\LOG_000\POLYSTYLE.LOG    13 KB
C:\Z_UserFiles\Unkn\LOG_000\pstore.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\Q322011.log    11 KB
C:\Z_UserFiles\Unkn\LOG_000\Q327979.log    14 KB
C:\Z_UserFiles\Unkn\LOG_000\Q814995.log    10 KB
C:\Z_UserFiles\Unkn\LOG_000\Q819696.log    18 KB
C:\Z_UserFiles\Unkn\LOG_000\Q828026.log    15 KB
C:\Z_UserFiles\Unkn\LOG_000\qtplugin.log    3 KB
C:\Z_UserFiles\Unkn\LOG_000\regopt.log    2 KB
C:\Z_UserFiles\Unkn\LOG_000\replog.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\rf_load_settings_2013_02_17.log    2 KB
C:\Z_UserFiles\Unkn\LOG_000\rf_load_settings_2013_02_18.log    2 KB
C:\Z_UserFiles\Unkn\LOG_000\rf_load_settings_2013_02_19.log    2 KB
C:\Z_UserFiles\Unkn\LOG_000\rf_load_settings_2013_02_20.log    2 KB
C:\Z_UserFiles\Unkn\LOG_000\rf_load_settings_2013_02_21.log    2 KB
C:\Z_UserFiles\Unkn\LOG_000\rf_load_settings_2013_02_22.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\rf_load_settings_2013_02_23.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\rf_load_settings_2013_02_24.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\rf_load_settings_2013_02_25.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\rf_load_settings_2013_02_26.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\rf_load_settings_2013_02_27.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\rf_sync_mru_2013_02_17.log    2 KB
C:\Z_UserFiles\Unkn\LOG_000\rf_sync_mru_2013_02_18.log    2 KB
C:\Z_UserFiles\Unkn\LOG_000\rf_sync_mru_2013_02_19.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\rf_sync_mru_2013_02_20.log    2 KB
C:\Z_UserFiles\Unkn\LOG_000\rf_sync_mru_2013_02_21.log    2 KB
C:\Z_UserFiles\Unkn\LOG_000\rf_sync_mru_2013_02_23.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\rf_sync_mru_2013_02_24.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\rf_sync_mru_2013_02_25.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\rf_sync_mru_2013_02_26.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\rf_sync_mru_2013_02_27.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\Rick35_.DALnet.log    2 KB
C:\Z_UserFiles\Unkn\LOG_000\Rick35_.DALnet1.DALnet.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\Rick35__.DALnet.log    2 KB
C:\Z_UserFiles\Unkn\LOG_000\Rick35__.DALnet1.DALnet.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\rjimport.log    28 KB
C:\Z_UserFiles\Unkn\LOG_000\SahAgent.log    6 KB
C:\Z_UserFiles\Unkn\LOG_000\SAM.LOG    1 KB
C:\Z_UserFiles\Unkn\LOG_000\SceRoot.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\scesetup.log    372 KB
C:\Z_UserFiles\Unkn\LOG_000\SECURITY.LOG    1 KB
C:\Z_UserFiles\Unkn\LOG_000\semgr.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\SensationsBot.20050201.log    2 KB
C:\Z_UserFiles\Unkn\LOG_000\Serial cable on COM1.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\Serial_cable_on_COM1.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\sessmgr.setup.log    2 KB
C:\Z_UserFiles\Unkn\LOG_000\SETUP.LOG    8 KB
C:\Z_UserFiles\Unkn\LOG_000\setupact.log    176 KB
C:\Z_UserFiles\Unkn\LOG_000\setupapi.log    665 KB
C:\Z_UserFiles\Unkn\LOG_000\sitesnag.log    24 KB
C:\Z_UserFiles\Unkn\LOG_000\software.LOG    1 KB
C:\Z_UserFiles\Unkn\LOG_000\SoulStealer.20040901.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\spupdsvc.log    29 KB
C:\Z_UserFiles\Unkn\LOG_000\spupdwxp.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\SrvLnch.log    38 KB
C:\Z_UserFiles\Unkn\LOG_000\SttgMsi.log    4 KB
C:\Z_UserFiles\Unkn\LOG_000\svcpack.log    607 KB
C:\Z_UserFiles\Unkn\LOG_000\SYMEVENT.LOG    13 KB
C:\Z_UserFiles\Unkn\LOG_000\system.LOG    1 KB
C:\Z_UserFiles\Unkn\LOG_000\tabletoc.log    19 KB
C:\Z_UserFiles\Unkn\LOG_000\TempKey.LOG    1 KB
C:\Z_UserFiles\Unkn\LOG_000\TMPLPANE.LOG    1 KB
C:\Z_UserFiles\Unkn\LOG_000\TOPSTYLE.LOG    1 KB
C:\Z_UserFiles\Unkn\LOG_000\tsoc.log    186 KB
C:\Z_UserFiles\Unkn\LOG_000\TWAIN.LOG    0 KB
C:\Z_UserFiles\Unkn\LOG_000\Uninstall.log    12 KB
C:\Z_UserFiles\Unkn\LOG_000\update.log    7 KB
C:\Z_UserFiles\Unkn\LOG_000\updspapi.log    9 KB
C:\Z_UserFiles\Unkn\LOG_000\userdiff.LOG    1 KB
C:\Z_UserFiles\Unkn\LOG_000\v08.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\v14.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\volx.DALnet.20031018.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\wavexdbg.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\wbemcore.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\wiadebug.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\wiaservc.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\WILES.LOG    1 KB
C:\Z_UserFiles\Unkn\LOG_000\Windows Update.log    210 KB
C:\Z_UserFiles\Unkn\LOG_000\WindowsLiveMail.log    8 KB
C:\Z_UserFiles\Unkn\LOG_000\Windows_Update.log    210 KB
C:\Z_UserFiles\Unkn\LOG_000\wininetd.log    5 KB
C:\Z_UserFiles\Unkn\LOG_000\WINLIST.LOG    1 KB
C:\Z_UserFiles\Unkn\LOG_000\WinMgmt.log    23 KB
C:\Z_UserFiles\Unkn\LOG_000\wmiadap.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\wmsetup.log    278 KB
C:\Z_UserFiles\Unkn\LOG_000\wmsetup10.log    1 KB
C:\Z_UserFiles\Unkn\LOG_000\xpsp1hfm.log    9 KB
C:\Z_UserFiles\Unkn\LOG_000\yacs.log    12 KB
C:\Z_UserFiles\Unkn\LOG_000\Yang.20040901.log    3 KB
C:\Z_UserFiles\Unkn\LOG_000\ypager.log    947 KB
C:\Z_UserFiles\Unkn\LOG_001\ccAlert.log    1 KB
C:\Z_UserFiles\Unkn\LOG_001\ccVrTrst.log    1 KB
C:\Z_UserFiles\Unkn\LOG_001\dahotfix.log    7 KB
C:\Z_UserFiles\Unkn\LOG_001\Directx.log    259 KB
C:\Z_UserFiles\Unkn\LOG_001\history.log    1 KB
C:\Z_UserFiles\Unkn\LOG_001\INSTALL.LOG    47 KB
C:\Z_UserFiles\Unkn\LOG_001\LUINSTALL.LOG    21 KB
C:\Z_UserFiles\Unkn\LOG_001\MyDefrag.log    1 KB
C:\Z_UserFiles\Unkn\LOG_001\NAVAPSCR.log    1 KB
C:\Z_UserFiles\Unkn\LOG_001\NAVEvent.log    1 KB
C:\Z_UserFiles\Unkn\LOG_001\NAVLUCBK.LOG    1 KB
C:\Z_UserFiles\Unkn\LOG_001\NAVOptRf.log    6 KB
C:\Z_UserFiles\Unkn\LOG_001\NAVTasks.log    1 KB
C:\Z_UserFiles\Unkn\LOG_001\offitems.log    89 KB
C:\Z_UserFiles\Unkn\LOG_001\sitesnag.log    9 KB
C:\Z_UserFiles\Unkn\LOG_001\Software.log    208 KB
C:\Z_UserFiles\Unkn\LOG_001\SYMEVENT.LOG    4 KB
C:\Z_UserFiles\Unkn\LOG_001\v08.log    1 KB
C:\Z_UserFiles\Unkn\LOG_001\v14.log    1 KB
C:\Z_UserFiles\Unkn\LOG_001\Windows Update.log    112 KB
C:\Z_UserFiles\Unkn\LOG_001\WindowsLiveMail.log    4,991 KB
C:\Z_UserFiles\Unkn\LOG_001\wmsetup.log    111 KB
C:\Z_UserFiles\Unkn\LOG_001\yacs.log    16 KB
C:\Z_UserFiles\Unkn\LOG_001\ypager.log    598 KB
C:\Z_UserFiles\Unkn\LOG_002\ccVrTrst.log    1 KB
C:\Z_UserFiles\Unkn\LOG_002\INSTALL.LOG    5 KB
C:\Z_UserFiles\Unkn\LOG_002\MYDEFRAG.LOG    7 KB
C:\Z_UserFiles\Unkn\LOG_003\ccVrTrst.log    11 KB
C:\Z_UserFiles\Unkn\LOG_003\install.log    5 KB
C:\Z_UserFiles\Unkn\LOG_004\install.log    4 KB
C:\Z_UserFiles\Unkn\LOG_005\INSTALL.LOG    7 KB
C:\Z_UserFiles\Unkn\LOG_006\INSTALL.LOG    46 KB
C:\Z_UserFiles\Unkn\LOG_007\install.log    88 KB
C:\Z_UserFiles\Unkn\LOG_008\INSTALL.LOG    5 KB
C:\Z_UserFiles\Unkn\LOG_009\INSTALL.LOG    3 KB
C:\Z_UserFiles\Unkn\LOG_010\INSTALL.LOG    2 KB
C:\Z_UserFiles\Unkn\LOG_011\INSTALL.LOG    4 KB
C:\Z_UserFiles\Unkn\LOG_012\INSTALL.LOG    3 KB
C:\Z_UserFiles\Unkn\LOG_013\INSTALL.LOG    1 KB
C:\Z_UserFiles\Unkn\LOG_014\INSTALL.LOG    2 KB
C:\Z_UserFiles\Unkn\MS_000\CHKLIST.MS    1 KB
C:\Z_UserFiles\Unkn\OLD_000\Foldersdbx.old    409 KB
C:\Z_UserFiles\Unkn\OLD_001\Foldersdbx.old    409 KB
C:\Z_UserFiles\Unkn\PRV_000\BOOTLOG.PRV    66 KB
C:\Z_UserFiles\Unkn\WBK_000\AutoRecovery save of Wheel and Axle.wbk    133 KB
C:\Z_UserFiles\Unkn\_MP_000\_INS5176._MP    535 KB
C:\Z_UserFiles\Unkn\~EAP_000\profiles.~eap    4 KB
[Windows Live Setup Logs*]
LangSecRef=3022
Detect1=HKLM\Software\Microsoft\Windows Live
Detect2=HKCU\Software\Microsoft\Windows Live Mail
Default=False
FileKey1=%CommonAppData%\Microsoft\WLSetup\Cablogs|*.*|RECURSE
FileKey2=%CommonAppData%\Microsoft\WLSetup\Logs|*.*|RECURSE
FileKey3=%LocalAppData%\Microsoft\WLSetup\Cablogs|*.*|RECURSE
FileKey4=%LocalAppData%\Microsoft\WLSetup\Logs|*.*|RECURSE
FileKey5=%CommonAppData%\WLInstaller|*.log
FileKey6=%LocalAppData%\VirtualStore\ProgramData\Microsoft\WLSetup\Cablogs|*.*|RECURSE
FileKey7=%LocalAppData%\VirtualStore\ProgramData\Microsoft\WLSetup\Logs|*.*|RECURSE
FileKey8=%LocalAppData%\VirtualStore\ProgramData\WLInstaller|*.log
I have added Detect2, because now these files below should be found.
Found these:
C:\Users\Galloway\AppData\Local\Microsoft\WLSetup\Logs\2014-05-10_12-30_114c-3hecpk9f.log    8 KB
C:\Users\Galloway\AppData\Local\Microsoft\WLSetup\Logs\2014-05-11_01-39_13d8-c7e8qho1.log    12 KB
C:\Users\Galloway\AppData\Local\Microsoft\WLSetup\Logs\2014-05-11_15-46_1428-rv3pbavs.log    12 KB
C:\Users\Galloway\AppData\Local\Microsoft\WLSetup\Logs\2014-05-19_16-55_138-g8cwivve.log    12 KB
C:\Users\Galloway\AppData\Local\Microsoft\WLSetup\Logs\2014-05-20_15-19_1b28-m12xiuug.log    12 KB
C:\Users\Galloway\AppData\Local\Microsoft\WLSetup\Logs\2014-05-21_15-00_3028-ufyx75zl.log    12 KB
C:\Users\Galloway\AppData\Local\Microsoft\WLSetup\Logs\2014-05-22_14-54_ca8-nmvntnjv.log    12 KB
C:\Users\Galloway\AppData\Local\Microsoft\WLSetup\Logs\2014-05-22_18-01_50c-846ikvqb.log    8 KB
C:\Users\Galloway\AppData\Local\Microsoft\WLSetup\Logs\2014-05-26_12-11_1ea0-q9jdawtu.log    8 KB
C:\Users\Galloway\AppData\Local\Microsoft\WLSetup\Logs\2014-05-27_10-15_1a2c-ysntakkx.log    8 KB
C:\Users\Galloway\AppData\Local\Microsoft\WLSetup\Logs\2014-05-29_19-37_a5c-ojj4ysau.log    8 KB
C:\Users\Administrator\AppData\Local\Microsoft\Windows Live\Contacts\Default\15.4\DBStore\edb.chk    8 KB
C:\Users\Administrator\AppData\Local\Microsoft\Windows Live\Contacts\Default\15.4\DBStore\LogFiles\edb.log    4,096 KB
C:\Users\Administrator\AppData\Local\Microsoft\Windows Live\Contacts\Default\15.5\DBStore\edb.chk    8 KB
C:\Users\Administrator\AppData\Local\Microsoft\Windows Live\Contacts\Default\15.5\DBStore\LogFiles\edb.log    4,096 KB
C:\Users\Administrator\AppData\Local\Microsoft\Windows Live\Contacts\Default\DBStore\edb.chk    8 KB
C:\Users\Administrator\AppData\Local\Microsoft\Windows Live\Contacts\Default\DBStore\LogFiles\edb.log    4,096 KB
C:\Users\Administrator\AppData\Local\Microsoft\Windows Live\Contacts\Default\W4CR1\DBStore\edb.chk    8 KB
C:\Users\Administrator\AppData\Local\Microsoft\Windows Live\Contacts\Default\W4CR1\DBStore\LogFiles\edb.log    4,096 KB
C:\Users\Administrator\AppData\Local\Microsoft\WLSetup\Logs\2014-01-05_16-55_420-nluy92sb.log    3 KB
C:\Users\Administrator\AppData\Local\Microsoft\WLSetup\Logs\2014-01-05_16-55_8b8-mhvntt02.log    4 KB
C:\Users\Administrator\AppData\Local\Microsoft\WLSetup\Logs\2014-01-05_16-55_d54-sog48nm2.log    7 KB
C:\Users\Administrator\AppData\Local\Microsoft\WLSetup\Logs\2014-01-05_16-55_dc0-4o7l05vp.log    6 KB
C:\ProgramData\Microsoft\WLSetup\Logs\2013-01-13_15-30_1340-h2n4e8tw.log    572 KB
C:\ProgramData\Microsoft\WLSetup\Logs\2013-03-08_17-52_2350-453y24zm.log    20 KB
C:\ProgramData\Microsoft\WLSetup\Logs\2013-04-12_14-05_b98-5yj3gj5i.log    11 KB
C:\ProgramData\Microsoft\WLSetup\Logs\2013-04-12_14-07_17dc-l5bpoxcg.log    534 KB
C:\ProgramData\Microsoft\WLSetup\Logs\2013-04-12_14-09_46c-a0pkkgyc.log    103 KB
C:\ProgramData\Microsoft\WLSetup\Logs\2013-04-12_16-55_cd8-2bh2drsz.log    406 KB
C:\ProgramData\Microsoft\WLSetup\Logs\2014-01-03_14-15_6a0-61pmu7ry.log    393 KB
C:\ProgramData\Microsoft\WLSetup\Logs\2014-01-03_16-17_1670-9wd50e0o.log    534 KB
C:\ProgramData\Microsoft\WLSetup\Logs\2014-01-03_16-23_4e8-t5n3fap5.log    314 KB
C:\ProgramData\Microsoft\WLSetup\Logs\2014-02-22_15-55_15bc-h4yikfv7.log    342 KB
C:\ProgramData\Microsoft\WLSetup\Logs\2014-04-24_20-15_4bc-imsczpf5.log    344 KB
[AI Roboform*]
LangSecRef=3022
Detect=HKCU\Software\Siber Systems
Default=False
FileKey1=%AppData%\RoboForm\_gsdata_mirrors_|*.*|RECURSE
FileKey2=%AppData%\RoboForm\_mirrors_|*.*|RECURSE
FileKey3=%Documents%\My RoboForm Data\_gsdata_|*.log;*.gss;*.gsl|RECURSE
FileKey4=%Documents%\My RoboForm Data|mru.rfo;cache.rfo|RECURSE
FileKey5=%Documents%\My RoboForm Data\*|mru.rfo;cache.rfo|RECURSE
RegKey1=HKCU\Software\Siber Systems|_InstallerDir
RegKey2=HKCU\Software\Siber Systems\RoboForm\Query-MRU
ExcludeKey1=FILE|%ProgramFiles%\Siber Systems\AI RoboForm\affid.txt
I have improved Filekey 1-4 with RECURSE. Now it will delete all Logs here below.
Found these:
C:\Users\Galloway\AppData\LocalLow\Siber Systems\RoboForm\UserData\_gsdata_\2014-0601-131519-GALLOWAY-HP-RoboForm Online.log    7 KB
C:\Users\Galloway\AppData\LocalLow\Siber Systems\RoboForm\UserData\_gsdata_\rf-act-2014-05-30.log    1 KB
C:\Users\Galloway\AppData\LocalLow\Siber Systems\RoboForm\UserData\_gsdata_\rf-sync-mru-2014-05-25.log    1 KB
C:\Users\Galloway\AppData\LocalLow\Siber Systems\RoboForm\UserData\_gsdata_\rf-sync-mru-2014-05-26.log    1 KB
C:\Users\Galloway\AppData\LocalLow\Siber Systems\RoboForm\UserData\_gsdata_\rf-sync-mru-2014-05-27.log    1 KB
C:\Users\Galloway\AppData\LocalLow\Siber Systems\RoboForm\UserData\_gsdata_\rf-sync-mru-2014-05-28.log    1 KB
C:\Users\Galloway\AppData\LocalLow\Siber Systems\RoboForm\UserData\_gsdata_\rf-sync-mru-2014-05-29.log    1 KB
C:\Users\Galloway\AppData\LocalLow\Siber Systems\RoboForm\UserData\_gsdata_\rf-sync-mru-2014-05-30.log    2 KB
C:\Users\Galloway\AppData\LocalLow\Siber Systems\RoboForm\UserData\_gsdata_\rf-sync-mru-2014-05-31.log    1 KB
C:\Users\Galloway\AppData\LocalLow\Siber Systems\RoboForm\UserData\_gsdata_\rf-sync-mru-2014-06-01.log    1 KB
C:\Users\Galloway\AppData\LocalLow\Siber Systems\RoboForm\UserData\_gsdata_\rf-sync-mru-2014-06-02.log    1 KB
C:\Users\Galloway\AppData\LocalLow\Siber Systems\RoboForm\UserData\_gsdata_\rf-sync-mru-2014-06-03.log    1 KB
C:\Users\Galloway\AppData\Roaming\RoboForm\_mirrors_\file-C-Users-Galloway-Documents-My RoboForm Data-Default Profile\2014-0603-113904-GALLOWAY-HP-RoboForm Online.log    2 KB
C:\Users\Galloway\AppData\Roaming\RoboForm\_mirrors_\https-online.roboform.com-users-CSGalloway\2014-0603-113904-GALLOWAY-HP-RoboForm Online.log    2 KB
C:\Users\Galloway\Documents\My RoboForm Data\Default Profile\_gsdata_\2014-0601-131519-GALLOWAY-HP-RoboForm Online.log    7 KB
C:\Users\Galloway\Documents\My RoboForm Data\Default Profile\_gsdata_\rf-act-2014-05-30.log    1 KB
C:\Users\Galloway\Documents\My RoboForm Data\Default Profile\_gsdata_\rf-sync-mru-2014-05-25.log    1 KB
C:\Users\Galloway\Documents\My RoboForm Data\Default Profile\_gsdata_\rf-sync-mru-2014-05-26.log    1 KB
C:\Users\Galloway\Documents\My RoboForm Data\Default Profile\_gsdata_\rf-sync-mru-2014-05-27.log    1 KB
C:\Users\Galloway\Documents\My RoboForm Data\Default Profile\_gsdata_\rf-sync-mru-2014-05-28.log    1 KB
C:\Users\Galloway\Documents\My RoboForm Data\Default Profile\_gsdata_\rf-sync-mru-2014-05-29.log    1 KB
C:\Users\Galloway\Documents\My RoboForm Data\Default Profile\_gsdata_\rf-sync-mru-2014-05-30.log    2 KB
C:\Users\Galloway\Documents\My RoboForm Data\Default Profile\_gsdata_\rf-sync-mru-2014-05-31.log    1 KB
C:\Users\Galloway\Documents\My RoboForm Data\Default Profile\_gsdata_\rf-sync-mru-2014-06-01.log    1 KB
C:\Users\Galloway\Documents\My RoboForm Data\Default Profile\_gsdata_\rf-sync-mru-2014-06-02.log    1 KB
C:\Users\Galloway\Documents\My RoboForm Data\Default Profile\_gsdata_\rf-sync-mru-2014-06-03.log    1 KB
[My Horse and Me*]
Section=Games
Detect1=HKLM\Software\My Horse and Me 2
Detect2=HKLM\SOFTWARE\Atari\Mein Pferd und ich Demo
Detect3=HKLM\SOFTWARE\Wow6432Node\Atari\Mein Pferd und ich Demo
Detect4=HKLM\SOFTWARE\Atari\Mein Pferd und ich
Detect5=HKLM\SOFTWARE\Wow6432Node\Atari\Mein Pferd und ich
Default=False
FileKey1=%ProgramFiles%\Atari\W!Games\My Horse and Me|++ Finish log.txt;++ Start log.txt;*.log|RECURSE
FileKey2=%LocalAppData%\VirtualStore\Program Files*\Atari\W!Games\My Horse and Me|++ Finish log.txt;++ Start log.txt;*.log|RECURSE
FileKey3=%ProgramFiles%\Atari\My Horse and Me|++ Finish log.txt;++ Start log.txt;*.log|RECURSE
FileKey4=%LocalAppData%\VirtualStore\Atari\My Horse and Me|++ Finish log.txt;++ Start log.txt;*.log|RECURSE
FileKey5=%ProgramFiles%\Atari\Mein Pferd und ich*\System|++ Finish log.txt;++ Start log.txt;*.log|RECURSE
FileKey6=%LocalAppData%\VirtualStore\Atari\Mein Pferd und ich*\System|++ Finish log.txt;++ Start log.txt;*.log|RECURSE
Added Filekey3-6. Filekey5 and Filekey 6 are for the german version.
Added Detect2-5. It was in my registry for the german version of the game.
And I added a "*" to Mein Pferd und ich , because if this is only for the Demo.
It will hopefully detect the full version of the game to.
Found these:
C:\Program Files (x86)\Atari\Mein Pferd und ich Demo\System\RealityEngine.log    3 KB
[Apple Application Logs*]
LangSecRef=3021
Detect=HKCU\Software\Apple Computer, Inc.
Default=False
FileKey1=%AppData%\Apple Computer\logs|*.log
FileKey2=%UserProfile%\Apple Computer\logs|*.log
FileKey3=%WinDir%\System32\config\systemprofile\AppData\Roaming\Apple Computer\Logs|*.log
FileKey4=%WinDir%\SysWOW64\config\systemprofile\AppData\Roaming\Apple Computer\Logs|*.log
Added Filekey2, but I don't really know, if it's deleting Administrator.
C:\Users\Administrator\AppData\Roaming\Apple Computer\Logs\asl.032624_05May14.log    6 KB
C:\Users\Administrator\AppData\Roaming\Apple Computer\Logs\asl.160117_14May14.log    6 KB
C:\Users\Administrator\AppData\Roaming\Apple Computer\Logs\asl.173858_14May14.log    6 KB
C:\Users\Administrator\AppData\Roaming\Apple Computer\Logs\asl.175505_14May14.log    6 KB
C:\Users\Administrator\AppData\Roaming\Apple Computer\Logs\asl.225834_08May14.log    6 KB
C:\Users\Galloway\AppData\Roaming\Apple Computer\Logs\asl.113855_03Jun14.log    6 KB
[MyDefrag Logs*]
LangSecRef=3021
Detect=HKCU\Software\MyDefrag
Default=False
FileKey1=%ProgramFiles%\MyDefrag *|*.log
FileKey2=%ProgramFiles%\MyDefrag *\LOGs|*.*
HKEY_CURRENT_USER\Software\MyDefrag
C:\Program Files\MyDefrag v4.3.1\MyDefrag.log    5 KB
C:\Program Files\MyDefrag v4.3.1\System Disk Level Zero.log    1 KB
C:\Program Files\MyDefrag v4.3.1\LOGs\Jaspion System Disk - Level 0 - Hourly.log    25 KB
C:\Program Files\MyDefrag v4.3.1\LOGs\Jaspion System Disk - Level III - Monthly - Automatic.log    184 KB
C:\Program Files\MyDefrag v4.3.1\LOGs\MyDefrag.log    441 KB
[Total Commander Logs*]
LangSecRef=3021
Detect1=HKCU\Software\Ghisler\Total Commander
Detect2=HKLM\SOFTWARE\Ghisler\Total Commander
Default=False
FileKey1=%SystemDrive%\TCMD\HowTo|*.err
FileKey2=%SystemDrive%\TCMD\MyLOGS|*.*
FileKey3=%SystemDrive%\TCMD\TCMDLogs|*.*
FileKey4=%ProgramFiles%\TCMD\HowTo|*.err
FileKey5=%ProgramFiles%\TCMD\MyLOGS|*.*
FileKey6=%ProgramFiles%\TCMD\TCMDLogs|*.*
The standard folder is C:, but if someone wants to install to Programfiles, it okay to.
HKEY_CURRENT_USER\Software\Ghisler\Total Commander
C:\TCMD\HowTo\TCC_10.00_78.err    1 KB
C:\TCMD\HowTo\TCC_11.00_52.err    1 KB
C:\TCMD\HowTo\TCC_12.11_76.err    1 KB
C:\TCMD\HowTo\TCC_13.04_63.err    1 KB
C:\TCMD\HowTo\TCC_14.02_44.err    1 KB
C:\TCMD\HowTo\TCC_14.03_54.err    1 KB
C:\TCMD\HowTo\TCC_15.00_36.err    1 KB
C:\TCMD\HowTo\TCC_9.02_157.err    1 KB
C:\TCMD\HowTo\TCMD32_8.02_106.err    1 KB
C:\TCMD\MyLOGS\MoveMe_1.log    17 KB
C:\TCMD\MyLOGS\MoveMe_2.log    23 KB
C:\TCMD\TCMDLogs\CMDHistory.log    2 KB
C:\TCMD\TCMDLogs\DIRHistory.log    1 KB
C:\TCMD\TCMDLogs\TCCommandLog.log    1 KB
C:\TCMD\TCMDLogs\TCErrorLog.log    1 KB
C:\TCMD\TCMDLogs\TCHistoryLog.log    2 KB
[Forte*]
LangSecRef=3025
Detect1=HKLM\SOFTWARE\Forte
Detect2=HKLM\SOFTWARE\Wow6432Node\Forte
Default=False
FileKey1=%SystemDrive%\My Data\ForteAgent|*.bak;*.log
FileKey2=%AppData%\Forte\Agent|errorlog.xml;*.log|RECURSE
Found these:
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Forte
C:\My Data\ForteAgent\agentini.bak    34 KB
C:\Users\Boss\AppData\Roaming\Forte\Agent\agentini.bak    21 KB
C:\Users\Boss\AppData\Roaming\Forte\Agent\errorlog.xml    1 KB
C:\Users\Galloway\AppData\Roaming\Forte\Agent\errorlog.xml    1 KB
This is part 1, part2 will come.
Link to post
  • Moderators
Got this email today
He may not want a debate over the usage of \|
however I've made entries before and seen stuff that won't clean without using it like that.
Link to post
Register a new account
Sign in
